[U-Boot] [PATCH] allow config_distro_bootcmd to pass uuid to extlinux.conf
Set ptuuid and fsuuid variables to the partition / filesystem where we found extlinux.conf which allows us to use a replaceable parameter in the append line in extlinux.conf like this
append root=PARTUUID=${ptuuid}
this means we never have to hardcode a root=/dev/mmcblk0p1 type path anywhere.
Signed-off-by: Iain Paton ipaton0@gmail.com ---
Since the uuids are only looked for after we've already found extlinux.conf there's little cost/risk to making them available. I realise that assuming extlinux.conf is on the root partition isn't perfect but for the common case where it will be, there are many advantages to this.
include/config_distro_bootcmd.h | 2 ++ include/config_distro_defaults.h | 4 ++++ 2 files changed, 6 insertions(+)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index be616e8..dd4ab09 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -166,6 +166,8 @@ "bootpart=1\0" \ \ "boot_extlinux=" \ + "part uuid ${devtype} ${devnum}:${bootpart} ptuuid; " \ + "fsuuid ${devtype} ${devnum}:${bootpart} fsuuid; " \ "sysboot ${devtype} ${devnum}:${bootpart} any " \ "${scriptaddr} ${prefix}extlinux/extlinux.conf\0" \ \ diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index 1ecc0bb..03e1efb 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -38,8 +38,10 @@ #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_FS_UUID #define CONFIG_CMD_MII #define CONFIG_CMD_NET +#define CONFIG_CMD_PART #define CONFIG_CMD_PING #define CONFIG_CMD_PXE
@@ -53,4 +55,6 @@ #define CONFIG_SUPPORT_RAW_INITRD #define CONFIG_SYS_HUSH_PARSER
+#define CONFIG_PARTITION_UUIDS + #endif /* _CONFIG_CMD_DISTRO_DEFAULTS_H */
Wouldn't the distro/... that creates extlinux.conf simply put the UUID into the file when it's generated? That's how things normally work in similar setups such as grub.conf...
... and completely avoids the issue of U-Boot making assumptions about the partition layout that the distro installer used.
Perhaps, but that's just another assumption. No less valid than mine, just different.
Well making some information available hardly forces anyone to use it.
I'd like to be able to make use of some of the commands and information that are available and to do it in a way that's compatible with config_distro_bootcmd. Perhaps by expanding it's capabilities along the way, if that's acceptable.
Part of my motivation is to decouple the assumption that the user writable UUID will never change on disk and make the system unbootable and difficult to recover, using extlinux.conf is one step, the patch is another.
Ideally I want to largely ignore the u-boot environment and just use extlinux.conf, but without access to some of the discovered information from the boot process I'm just moving a set of hard coded assumptions from point A to point B. I may as well just use boot.scr in this case.
Is the intention that config_distro_bootcmd be rigid and inflexible, only catering to a single way of doing things?
It's also consistent with all the other (generic distro) boot methods that already exist e.g. for x86.
However, it affects the definition of extlinux.conf, since it means that variable references are expanded in the command-line parameter, which changes the definition/syntax of extlinux.conf. This isn't something that should happen via a patch to one bootloader, but by general agreement to change the specification of extlinux.conf's format.
If the user changes the UUID, it seems perfectly reasonable to require them to update any config files that mention this UUID, or rebuild their extlinux.conf from scratch using whatever mechanism is normally used to build it.
Again, this is entirely consistent with boot config files in grub, LILO, ...
Recovery from such a change seems very simple; just edit extlinux.conf so it's correct.
I don't understand this part.
The primary advantage is that extlinux.conf is not a bootloader-specific format, but will/does work across bootloaders. A secondary advantage is that it's a simple text file that any distro can genrate without requiring tools to create binary formats.
Any distro install script should be able to generate extlinux.conf just like it could generate boot.scr. The benefit is alignment in concepts. There was never an intent to remove the need to define the Linux kernel command-line.
The intention is to provide a single standard that works in a similar way to existing boot methods (e.g. on x86) that distros are already familiar with. Doing things differently from other boot methods breaks the usefulness of it.
I've to agree with Stephen here, both Debian and Fedora are already using the extlinux.conf support as it, it is not perfect, but the UUID stuff is not a problem.
Erm we (u-boot) already have support for using u-boot env variables in the "append" extlinux.conf statement.
I added this a while back to allow having:
append console=${console}
As different boards have different serial console names... (/dev/ttyS, /dev/ttyAMBA, etc.).
Ack.
Regards,
Hans
Hans de Goede
Iain Paton
Stephen Warren
