[U-Boot] [PATCH v3 1/2] ARM: dts: dra7xx: Update spi-max-frequency for qspi slave node
Update the spi-max-frequency property of m25p80 flash slave to match that of TI QSPI controller node, so that QSPI operations happen at maximum supported frequency of 76.8MHz.
Signed-off-by: Vignesh R vigneshr@ti.com Reviewed-by: Jagan Teki jteki@openedev.com ---
v3: No changes.
arch/arm/dts/dra7-evm.dts | 2 +- arch/arm/dts/dra72-evm-common.dtsi | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index fe755c05841d..be36d456206d 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -505,7 +505,7 @@ spi-max-frequency = <76800000>; m25p80@0 { compatible = "s25fl256s1","spi-flash"; - spi-max-frequency = <64000000>; + spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/dra72-evm-common.dtsi b/arch/arm/dts/dra72-evm-common.dtsi index b0993e5bf7e0..1e1ca725577f 100644 --- a/arch/arm/dts/dra72-evm-common.dtsi +++ b/arch/arm/dts/dra72-evm-common.dtsi @@ -441,7 +441,7 @@ spi-max-frequency = <76800000>; m25p80@0 { compatible = "s25fl256s1", "spi-flash"; - spi-max-frequency = <64000000>; + spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>;
Fix the divider calculation logic to choose a value so that the resulting baudrate is either equal to or closest possible baudrate less than the requested value. While at that, cleanup ti_spi_set_speed().
Signed-off-by: Vignesh R vigneshr@ti.com ---
v3: Move SCLK disable and enable blocks together. v2: cleanup ti_spi_set_speed() a bit.
drivers/spi/ti_qspi.c | 16 +++++++--------- 1 file changed, 7 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 52520dff6325..da0488659049 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -16,6 +16,7 @@ #include <asm/omap_gpio.h> #include <asm/omap_common.h> #include <asm/ti-common/ti-edma3.h> +#include <linux/kernel.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -118,21 +119,18 @@ static void ti_spi_set_speed(struct ti_qspi_priv *priv, uint hz) if (!hz) clk_div = 0; else - clk_div = (priv->fclk / hz) - 1; + clk_div = DIV_ROUND_UP(priv->fclk, hz) - 1; + + /* truncate clk_div value to QSPI_CLK_DIV_MAX */ + if (clk_div > QSPI_CLK_DIV_MAX) + clk_div = QSPI_CLK_DIV_MAX;
debug("ti_spi_set_speed: hz: %d, clock divider %d\n", hz, clk_div);
/* disable SCLK */ writel(readl(&priv->base->clk_ctrl) & ~QSPI_CLK_EN, &priv->base->clk_ctrl); - - /* assign clk_div values */ - if (clk_div < 0) - clk_div = 0; - else if (clk_div > QSPI_CLK_DIV_MAX) - clk_div = QSPI_CLK_DIV_MAX; - - /* enable SCLK */ + /* enable SCLK and program the clk divider */ writel(QSPI_CLK_EN | clk_div, &priv->base->clk_ctrl); }
Applied to u-boot-spi/master
thanks!
thanks!
Jagan Teki
Vignesh R
