pull request of u-boot-fsl-qoriq for v2020.10
Dear Tom,
Please find my pull-request for u-boot-fsl-qoriq/master https://travis-ci.org/github/p-priyanka-jain/u-boot/builds/712122749
Summary Bug fixes and updates on ls2088a,ls1028a, ls1046a, ls1043a, ls1012a lx2-watchdog support layerscape:pci-endpoint support, spin table relocation fixes and cleanups fsl-crypto: RNG support and bug fixes
Thanks Priyanka ------------------- The following changes since commit ada61f1ee2a4eaa1b29d699b5ba940483171df8a:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-riscv (2020-07-24 08:43:08 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq.git HEAD
for you to fetch changes up to 636999f21cdd901f1d78323456447ce956410776:
configs: ls2088a: Restore CONFIG_ENV_ADDR to IFC-NOR (2020-07-27 14:24:15 +0530)
---------------------------------------------------------------- Biwen Li (6): I2C: ls1043a, ls1046a: enable SYS_I2C_MXC i2c: mxc: move i2c_early_init_f to common function freescale: ls1046aqds: enable secure system counter freescale: ls1046aqds: drop ifdef CONFIG_SYS_I2C freescale: ls1043aqds: enable secure system counter freescale: ls1043aqds: drop ifdef CONFIG_SYS_I2C
Chaitanya Sakinam (1): armv8: ls1012a: RGMII ports require internal delay
Era Tiwari (1): configs: ls1088ardb: Add support for usb boot target
Heinrich Schuchardt (2): crypto/fsl: correct printf() statement. crypto/fsl: unused value in caam_hash_update()
Hou Zhiqiang (2): arm64: ls1043a: Remove the workaround of erratum A-009929 pci: layerscape: Add specific config entry for RC and EP mode driver
Kuldeep Singh (3): net: pfe_eth: Use spi_flash_read API to access flash memory configs: ls1012a: Increase CONFIG_SYS_MALLOC_LEN value configs: ls2088a: Restore CONFIG_ENV_ADDR to IFC-NOR
Manish Tomar (1): configs:ls1046afrwy: Add tfa secure boot defconfig
Michael Walle (21): armv8: ls1028a: move FSL_LAYERSCAPE to kconfig armv8: layerscape: fix spin-table support armv8: layerscape: pretty print info about SMP cores armv8: layerscape: properly use CPU_RELEASE_ADDR armv8: layerscape: move spin table into own module armv8: layerscape: load function pointer using ADR armv8: layerscape: fix alignment for spin table armv8: layerscape: remove determine_mp_bootpg() armv8: layerscape: simplify get_spin_tbl_addr() calls armv8: layerscape: make wake_secondary_core_n() static armv8: layerscape: drop first .ltorg directive in spintable.S armv8: layerscape: clean exported symbols in spintable.S armv8: layerscape: relocate spin table if EFI_LOADER is enabled armv8: layerscape: rework spin table crypto/fsl: fix unaligned access crypto/fsl: make SEC%u status line consistent crypto/fsl: export caam_get_era() crypto/fsl: support newer SEC modules crypto/fsl: don't regenerate secure keys crypto/fsl: instantiate the RNG with prediciton resistance crypto/fsl: add RNG support
Udit Agarwal (1): include/configs: ls1012a: Remove fdt_high env variable
Vladimir Oltean (1): fsl_dspi: Introduce DT bindings for CS-SCK and SCK-CS delays
Wasim Khan (1): arm: dts: lx2160a: Increase configuration window size
Xiaowei Bao (9): pci: layerscape: Split the EP and RC driver pci_ep: Add the init function armv8: dts: ls1046a: Add the PCIe EP node pcie_ep: layerscape: Add the multiple function support pci_ep: layerscape: Add the workaround for errata A-009460 pci_ep: layerscape: Add Support for ls2085a and ls2080a EP mode pci_ep: layerscape: Add the SRIOV VFs of PF support pci: layerscape: Modify the ls_pcie_dump_atu function pci_ep: layerscape: Add the PCIe EP mode support for lx2160a-v2
Yangbo Lu (4): Drop global data sdhc_adapter for powerpc Move eSDHC adapter card identification to board files board: fsl: lx2160aqds: identify SDHC adapter during board init configs: lx2160aqds: enable CONFIG_BOARD_EARLY_INIT_R
Yuantian Tang (1): armv8: ls1028ardb: add xspi parameter to qixis command
Zhao Qiang (6): armv8: dts: fsl-lx2160a: add flash node under dspi to qds dts config: lx2160/2a: enable dspi Watchdog: introduce ARM SBSA watchdog driver arm64: lx2160a: dts: Add watchdog node configs: lx2160a: Enable Watchdog support arm: dts: ls1028a: Add dspi flash device node to qds
hui.song (2): armv8: gpio: add gpio feature dm: armv8: gpio: include <asm/arch/gpio.h> for fsl-layerscape
MAINTAINERS | 1 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 9 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 9 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 165 +------ arch/arm/cpu/armv8/fsl-layerscape/mp.c | 80 +++- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 15 - arch/arm/cpu/armv8/fsl-layerscape/spintable.S | 118 +++++ arch/arm/dts/fsl-ls1028a-qds.dtsi | 74 +++ arch/arm/dts/fsl-ls1046a.dtsi | 33 ++ arch/arm/dts/fsl-lx2160a-qds.dtsi | 99 ++++ arch/arm/dts/fsl-lx2160a.dtsi | 19 +- arch/arm/include/asm/arch-fsl-layerscape/gpio.h | 22 + arch/arm/include/asm/arch-fsl-layerscape/mp.h | 8 +- arch/arm/include/asm/gpio.h | 8 +- arch/powerpc/include/asm/global_data.h | 4 +- board/freescale/common/qixis.c | 13 + board/freescale/common/qixis.h | 14 +- board/freescale/ls1012ardb/eth.c | 2 +- board/freescale/ls1043aqds/ls1043aqds.c | 14 +- board/freescale/ls1046afrwy/MAINTAINERS | 5 + board/freescale/ls1046aqds/ls1046aqds.c | 14 +- board/freescale/lx2160a/lx2160a.c | 36 +- board/freescale/t208xqds/t208xqds.c | 29 +- common/board_r.c | 12 + configs/ls1012afrdm_qspi_defconfig | 2 +- configs/ls1012afrdm_tfa_defconfig | 2 +- configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1012afrwy_qspi_defconfig | 2 +- configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012afrwy_tfa_defconfig | 2 +- configs/ls1012aqds_qspi_defconfig | 2 +- configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012aqds_tfa_defconfig | 2 +- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1012ardb_qspi_defconfig | 2 +- configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012ardb_tfa_defconfig | 2 +- configs/ls1021aiot_qspi_defconfig | 2 +- configs/ls1021aiot_sdcard_defconfig | 2 +- configs/ls1021aqds_ddr4_nor_defconfig | 2 +- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 2 +- configs/ls1021aqds_nand_defconfig | 2 +- configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 2 +- configs/ls1021aqds_nor_defconfig | 2 +- configs/ls1021aqds_nor_lpuart_defconfig | 2 +- configs/ls1021aqds_qspi_defconfig | 2 +- configs/ls1021aqds_sdcard_ifc_defconfig | 2 +- configs/ls1021aqds_sdcard_qspi_defconfig | 2 +- configs/ls1021atsn_qspi_defconfig | 2 +- configs/ls1021atsn_sdcard_defconfig | 2 +- configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 2 +- configs/ls1021atwr_nor_defconfig | 2 +- configs/ls1021atwr_nor_lpuart_defconfig | 2 +- configs/ls1021atwr_qspi_defconfig | 2 +- .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 +- configs/ls1021atwr_sdcard_ifc_defconfig | 2 +- configs/ls1021atwr_sdcard_qspi_defconfig | 2 +- configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1028aqds_tfa_defconfig | 2 +- configs/ls1028aqds_tfa_lpuart_defconfig | 2 +- configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1028ardb_tfa_defconfig | 2 +- configs/ls1043aqds_defconfig | 2 +- configs/ls1043aqds_lpuart_defconfig | 2 +- configs/ls1043aqds_nand_defconfig | 2 +- configs/ls1043aqds_nor_ddr3_defconfig | 2 +- configs/ls1043aqds_qspi_defconfig | 2 +- configs/ls1043aqds_sdcard_ifc_defconfig | 2 +- configs/ls1043aqds_sdcard_qspi_defconfig | 2 +- configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1043aqds_tfa_defconfig | 2 +- configs/ls1043ardb_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_defconfig | 2 +- configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_nand_defconfig | 2 +- configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_sdcard_defconfig | 2 +- configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_tfa_defconfig | 2 +- configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 68 +++ configs/ls1046afrwy_tfa_defconfig | 3 +- configs/ls1046aqds_SECURE_BOOT_defconfig | 3 +- configs/ls1046aqds_defconfig | 3 +- configs/ls1046aqds_lpuart_defconfig | 3 +- configs/ls1046aqds_nand_defconfig | 3 +- configs/ls1046aqds_qspi_defconfig | 3 +- configs/ls1046aqds_sdcard_ifc_defconfig | 3 +- configs/ls1046aqds_sdcard_qspi_defconfig | 3 +- configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 3 +- configs/ls1046aqds_tfa_defconfig | 3 +- configs/ls1046ardb_emmc_defconfig | 3 +- configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 3 +- configs/ls1046ardb_qspi_defconfig | 3 +- configs/ls1046ardb_qspi_spl_defconfig | 3 +- configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 3 +- configs/ls1046ardb_sdcard_defconfig | 3 +- configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 3 +- configs/ls1046ardb_tfa_defconfig | 3 +- configs/ls1088aqds_defconfig | 2 +- configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1088aqds_qspi_defconfig | 2 +- configs/ls1088aqds_sdcard_ifc_defconfig | 2 +- configs/ls1088aqds_sdcard_qspi_defconfig | 2 +- configs/ls1088aqds_tfa_defconfig | 2 +- configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1088ardb_qspi_defconfig | 2 +- .../ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1088ardb_sdcard_qspi_defconfig | 2 +- configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1088ardb_tfa_defconfig | 2 +- configs/ls2080aqds_SECURE_BOOT_defconfig | 2 +- configs/ls2080aqds_defconfig | 2 +- configs/ls2080aqds_nand_defconfig | 2 +- configs/ls2080aqds_qspi_defconfig | 2 +- configs/ls2080aqds_sdcard_defconfig | 2 +- configs/ls2080ardb_SECURE_BOOT_defconfig | 2 +- configs/ls2080ardb_defconfig | 2 +- configs/ls2080ardb_nand_defconfig | 2 +- configs/ls2081ardb_defconfig | 2 +- configs/ls2088aqds_tfa_defconfig | 2 +- configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls2088ardb_qspi_defconfig | 2 +- configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls2088ardb_tfa_defconfig | 5 +- configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 5 +- configs/lx2160aqds_tfa_defconfig | 11 +- configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 4 +- configs/lx2160ardb_tfa_defconfig | 7 +- configs/lx2160ardb_tfa_stmm_defconfig | 4 +- doc/README.fsl-esdhc | 14 - doc/device-tree-bindings/spi/spi-mcf-dspi.txt | 4 + drivers/crypto/fsl/Kconfig | 14 + drivers/crypto/fsl/Makefile | 1 + drivers/crypto/fsl/desc.h | 2 + drivers/crypto/fsl/desc_constr.h | 27 +- drivers/crypto/fsl/fsl_hash.c | 2 +- drivers/crypto/fsl/jobdesc.c | 30 +- drivers/crypto/fsl/jobdesc.h | 7 +- drivers/crypto/fsl/jr.c | 111 ++++- drivers/crypto/fsl/rng.c | 88 ++++ drivers/crypto/fsl/sec.c | 10 +- drivers/i2c/mxc_i2c.c | 138 +++--- drivers/mmc/fsl_esdhc.c | 39 -- drivers/mmc/mmc-uclass.c | 4 +- drivers/mmc/mmc.c | 7 +- drivers/mmc/mmc_legacy.c | 7 +- drivers/mmc/mmc_private.h | 4 +- drivers/net/pfe_eth/pfe_eth.c | 2 +- drivers/net/pfe_eth/pfe_firmware.c | 45 +- drivers/pci/Kconfig | 29 +- drivers/pci/Makefile | 5 +- drivers/pci/pcie_layerscape.c | 510 ++------------------- drivers/pci/pcie_layerscape.h | 73 ++- drivers/pci/pcie_layerscape_ep.c | 332 ++++++++++++++ drivers/pci/pcie_layerscape_fixup.c | 79 ++-- drivers/pci/pcie_layerscape_rc.c | 379 +++++++++++++++ drivers/pci_endpoint/pci_ep-uclass.c | 11 + drivers/spi/fsl_dspi.c | 54 ++- drivers/watchdog/Kconfig | 9 + drivers/watchdog/Makefile | 1 + drivers/watchdog/sbsa_gwdt.c | 131 ++++++ include/configs/T208xQDS.h | 1 - include/configs/ls1012a2g5rdb.h | 2 +- include/configs/ls1012a_common.h | 10 +- include/configs/ls1012afrdm.h | 2 +- include/configs/ls1012afrwy.h | 2 +- include/configs/ls1012ardb.h | 2 +- include/configs/ls1028a_common.h | 3 +- include/configs/ls1028ardb.h | 4 +- include/configs/ls1043a_common.h | 5 +- include/configs/ls1046a_common.h | 3 +- include/configs/ls1088a_common.h | 2 +- include/configs/ls1088ardb.h | 1 + include/configs/ls2080a_common.h | 2 +- include/configs/lx2160a_common.h | 2 +- include/fsl_dspi.h | 1 + include/fsl_esdhc.h | 4 - include/fsl_sec.h | 61 ++- include/init.h | 1 + scripts/config_whitelist.txt | 1 - 181 files changed, 2317 insertions(+), 1084 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/spintable.S create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/gpio.h create mode 100644 configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig create mode 100644 drivers/crypto/fsl/rng.c create mode 100644 drivers/pci/pcie_layerscape_ep.c create mode 100644 drivers/pci/pcie_layerscape_rc.c create mode 100644 drivers/watchdog/sbsa_gwdt.c
On Mon, Jul 27, 2020 at 02:35:15PM +0000, Priyanka Jain wrote:
Dear Tom,
Thanks Priyanka
Priyanka Jain
