[U-Boot] Cannot run anything with u-boot
Dear u-boot Team,
perhaps i make any kind of stupid mistake, but i defintively cannot find any solution to my probem. So i hope you can help me.
Host System: Ubuntu 16.04 LTS in a Vitual Box on WIN10 Surface Pro 3 Destination: raspberry PI B 512mb Cross Compiler: Buildroot 2017.02 U-Boot: git: u-boot-2016.09.y
Build Cross Compiler without any problems Cross Compile Linux Kernel 4.9.13 from kernel.org without problems Starting zImage from SD via rename kernel.img without any problem
Making u-boot: make rpi_defconfig export PATH=$PATH:~/Embedded_Linux/raspi/buildroot-2017.02/output/host/usr/bin/ make CROSS_COMPILE=arm-linux- -j 3 Compile without problems
CP u-boot.bin => SD Card kernel.img CP hello_world.bin 00> sd card hello Starting Raspi: <<<<<<<<<<<<<<< Terminal output >>>>>>>>>>>>>>>>>> U-Boot 2016.09.01 (Mar 22 2017 - 11:01:10 +0100)
DRAM: 448 MiB RPI Model B rev2 (0xf) MMC: bcm2835_sdhci: 0 reading uboot.env
** Unable to read "uboot.env" from mmc0:1 ** Using default environment
In: serial Out: lcd Err: lcd Net: Net Initialization Skipped No ethernet found. starting USB... USB0: Core Release: 2.80a scanning bus 0 for devices... 3 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found scanning usb for ethernet devices... 1 Ethernet Device(s) found Hit any key to stop autoboot: 0 U-Boot> mmc rescan U-Boot> fatload mmc 0:1 0x00200000 hello reading hello 626 bytes read in 26 ms (23.4 KiB/s) U-Boot> go 0x00200000 ## Starting application at 0x00200000 ... ÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀ <after any keyY> ÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÁÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀ## Application terminated, rc = 0x0 U-Boot> <<<<<<<<<<<<<<< Terminal end >>>>>>>>>>>>>>>>
Bootz with working zimage freeze rpi Bootm with uimage freezing too
Have you any idea, was is wrong?
THANK YOU IN ADVANCE
Gesendet von Mail für Windows 10
technik@gothtec.de
