[U-Boot] [PATCH 2/4] arm: zynq: Dont define SDRAM_BASE and SDRAM_SIZE in .h
Remove the SDRAM_BASE nad SDRAM_SIZE as it can now get these details from DT using 'commit 327f66622391 ("lib: fdtdec: Fill initial ram top with DDR start value from dt")'
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- include/configs/zynq_cse.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/zynq_cse.h b/include/configs/zynq_cse.h index 2f5843f..adc02f0 100644 --- a/include/configs/zynq_cse.h +++ b/include/configs/zynq_cse.h @@ -41,7 +41,4 @@ #undef CONFIG_SYS_MALLOC_LEN #define CONFIG_SYS_MALLOC_LEN 0x1000
-#define CONFIG_SYS_SDRAM_BASE 0xfffc0000 -#define CONFIG_SYS_SDRAM_SIZE 0x40000 - #endif /* __CONFIG_ZYNQ_CSE_H */ -- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
Add configuration files/dtses for mini u-boot configuration which runs on smaller footprint of memory. This configuration has only required nand flash support.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-cse-nand.dts | 90 +++++++++++++++++++++++++++++++++++++++++ configs/zynq_cse_nand_defconfig | 50 +++++++++++++++++++++++ 3 files changed, 141 insertions(+) create mode 100644 arch/arm/dts/zynq-cse-nand.dts create mode 100644 configs/zynq_cse_nand_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a0349a8..71b7c3a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -128,6 +128,7 @@ dtb-$(CONFIG_ARCH_UNIPHIER_SLD8) += \
dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-cc108.dtb \ + zynq-cse-nand.dtb \ zynq-cse-qspi-single.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \ diff --git a/arch/arm/dts/zynq-cse-nand.dts b/arch/arm/dts/zynq-cse-nand.dts new file mode 100644 index 0000000..9df5f9a --- /dev/null +++ b/arch/arm/dts/zynq-cse-nand.dts @@ -0,0 +1,90 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Xilinx CSE NAND board DTS + * + * Copyright (C) 2018 Xilinx, Inc. + */ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + model = "Zynq CSE NAND Board"; + compatible = "xlnx,zynq-cse-nand", "xlnx,zynq-7000"; + + aliases { + serial0 = &dcc; + }; + + memory@fffc0000 { + device_type = "memory"; + reg = <0x0 0x400000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + dcc: dcc { + compatible = "arm,dcc"; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + + amba: amba { + u-boot,dm-pre-reloc; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&intc>; + ranges; + + intc: interrupt-controller@f8f01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xF8F01000 0x1000>, + <0xF8F00100 0x100>; + }; + + slcr: slcr@f8000000 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "xlnx,zynq-slcr", "syscon", "simple-bus"; + reg = <0xF8000000 0x1000>; + ranges; + clkc: clkc@100 { + u-boot,dm-pre-reloc; + #clock-cells = <1>; + compatible = "xlnx,ps7-clkc"; + fclk-enable = <0xf>; + clock-output-names = "armpll", "ddrpll", + "iopll", "cpu_6or4x", + "cpu_3or2x", "cpu_2x", "cpu_1x", + "ddr2x", "ddr3x", "dci", + "lqspi", "smc", "pcap", "gem0", + "gem1", "fclk0", "fclk1", + "fclk2", "fclk3", "can0", + "can1", "sdio0", "sdio1", + "uart0", "uart1", "spi0", + "spi1", "dma", "usb0_aper", + "usb1_aper", "gem0_aper", + "gem1_aper", "sdio0_aper", + "sdio1_aper", "spi0_aper", + "spi1_aper", "can0_aper", + "can1_aper", "i2c0_aper", + "i2c1_aper", "uart0_aper", + "uart1_aper", "gpio_aper", + "lqspi_aper", "smc_aper", + "swdt", "dbg_trc", "dbg_apb"; + reg = <0x100 0x100>; + }; + }; + }; + +}; + +&dcc { + status = "okay"; +}; diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig new file mode 100644 index 0000000..7c7e143 --- /dev/null +++ b/configs/zynq_cse_nand_defconfig @@ -0,0 +1,50 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x100000 +CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_SYS_MALLOC_LEN=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_PROMPT="Zynq> " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_SPL is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_CLK is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +# CONFIG_CMD_MISC is not set +# CONFIG_PARTITIONS is not set +CONFIG_OF_EMBED=y +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_ZYNQ=y +# CONFIG_EFI_LOADER is not set -- 2.7.4
- zynq-cse-nand.dtb \ zynq-cse-qspi-single.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \
- Xilinx CSE NAND board DTS
- Copyright (C) 2018 Xilinx, Inc.
+/dts-v1/;
- #address-cells = <1>;
- #size-cells = <1>;
- model = "Zynq CSE NAND Board";
- compatible = "xlnx,zynq-cse-nand", "xlnx,zynq-7000";
- aliases {
serial0 = &dcc;
- memory@fffc0000 {
this will be reported by latest DTC. This is
- chosen {
- dcc: dcc {
- amba: amba {
#size-cells = <1>;
ranges;
<0xF8F00100 0x100>;
we can save some space by removing this intc node too.
#size-cells = <1>;
ranges;
clkc: clkc@100 {
#clock-cells = <1>;
we can remove this.
+&dcc {
- status = "okay";
M
Add configuration files/dtses for mini u-boot configuration which runs on smaller footprint OCM memory. This configuration only has required parallel nor flash support.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-cse-nor.dts | 88 ++++++++++++++++++++++++++++++++++++++++++ configs/zynq_cse_nor_defconfig | 50 ++++++++++++++++++++++++ 3 files changed, 139 insertions(+) create mode 100644 arch/arm/dts/zynq-cse-nor.dts create mode 100644 configs/zynq_cse_nor_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 71b7c3a..9e29fe6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -129,6 +129,7 @@ dtb-$(CONFIG_ARCH_UNIPHIER_SLD8) += \ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-cc108.dtb \ zynq-cse-nand.dtb \ + zynq-cse-nor.dtb \ zynq-cse-qspi-single.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \ diff --git a/arch/arm/dts/zynq-cse-nor.dts b/arch/arm/dts/zynq-cse-nor.dts new file mode 100644 index 0000000..ba6f9a1 --- /dev/null +++ b/arch/arm/dts/zynq-cse-nor.dts @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Xilinx CSE NOR board DTS + * + * Copyright (C) 2018 Xilinx, Inc. + */ +/dts-v1/; +#include "zynq-7000.dtsi" + +/ { + #address-cells = <1>; + #size-cells = <1>; + model = "Zynq CSE NOR Board"; + compatible = "xlnx,zynq-cse-nor", "xlnx,zynq-7000"; + + aliases { + serial0 = &dcc; + }; + + memory@fffc0000 { + device_type = "memory"; + reg = <0xFFFC0000 0x40000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + dcc: dcc { + compatible = "arm,dcc"; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + + amba: amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&intc>; + ranges; + + intc: interrupt-controller@f8f01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xF8F01000 0x1000>, + <0xF8F00100 0x100>; + }; + + slcr: slcr@f8000000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "xlnx,zynq-slcr", "syscon", "simple-bus"; + reg = <0xF8000000 0x1000>; + ranges; + clkc: clkc@100 { + #clock-cells = <1>; + compatible = "xlnx,ps7-clkc"; + fclk-enable = <0xf>; + clock-output-names = "armpll", "ddrpll", + "iopll", "cpu_6or4x", + "cpu_3or2x", "cpu_2x", "cpu_1x", + "ddr2x", "ddr3x", "dci", + "lqspi", "smc", "pcap", "gem0", + "gem1", "fclk0", "fclk1", + "fclk2", "fclk3", "can0", + "can1", "sdio0", "sdio1", + "uart0", "uart1", "spi0", + "spi1", "dma", "usb0_aper", + "usb1_aper", "gem0_aper", + "gem1_aper", "sdio0_aper", + "sdio1_aper", "spi0_aper", + "spi1_aper", "can0_aper", + "can1_aper", "i2c0_aper", + "i2c1_aper", "uart0_aper", + "uart1_aper", "gpio_aper", + "lqspi_aper", "smc_aper", + "swdt", "dbg_trc", "dbg_apb"; + reg = <0x100 0x100>; + }; + }; + }; + +}; + +&dcc { + status = "okay"; +}; diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig new file mode 100644 index 0000000..842d520 --- /dev/null +++ b/configs/zynq_cse_nor_defconfig @@ -0,0 +1,50 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_ZYNQ_M29EW_WB_HACK=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" +CONFIG_BOOTDELAY=-1 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_PROMPT="Zynq> " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_SPL is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_CLK is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +# CONFIG_CMD_MISC is not set +# CONFIG_PARTITIONS is not set +CONFIG_OF_EMBED=y +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_MMC is not set +CONFIG_MTD_NOR_FLASH=y +# CONFIG_EFI_LOADER is not set -- 2.7.4
- zynq-cse-nor.dtb \ zynq-cse-qspi-single.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \
- Xilinx CSE NOR board DTS
- model = "Zynq CSE NOR Board";
- compatible = "xlnx,zynq-cse-nor", "xlnx,zynq-7000";
- aliases {
serial0 = &dcc;
- memory@fffc0000 {
- chosen {
- dcc: dcc {
- amba: amba {
#size-cells = <1>;
ranges;
<0xF8F00100 0x100>;
#size-cells = <1>;
ranges;
clkc: clkc@100 {
#clock-cells = <1>;
+&dcc {
- status = "okay";
This looks good. We are hardcoding 16M flash via zynq-common.h It will be good to have an option to change it at build time.
It means some ifdefs there would be enough or moving it to Kconfig.
Thanks, Michal
this sha1 will be pretty much bogus.
M
Michal Simek
