[U-Boot] [PATCH] Exynos: clock: Fix a bug in PLL lock check condition
The condition for testing of PLL getting locked was incorrect. Rectify this error in this patch.
Reported-by: Alexei Fedorov alexie.fedorov@arm.com Signed-off-by: Hatim Ali hatim.rv@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- board/samsung/smdk5250/clock_init.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/board/samsung/smdk5250/clock_init.c b/board/samsung/smdk5250/clock_init.c index c009ae5..baa3042 100644 --- a/board/samsung/smdk5250/clock_init.c +++ b/board/samsung/smdk5250/clock_init.c @@ -494,35 +494,35 @@ void system_clock_init() val = set_pll(arm_clk_ratio->apll_mdiv, arm_clk_ratio->apll_pdiv, arm_clk_ratio->apll_sdiv); writel(val, &clk->apll_con0); - while (readl(&clk->apll_con0) & APLL_CON0_LOCKED) + while ((readl(&clk->apll_con0) & APLL_CON0_LOCKED) == 0) ;
/* Set MPLL */ writel(MPLL_CON1_VAL, &clk->mpll_con1); val = set_pll(mem->mpll_mdiv, mem->mpll_pdiv, mem->mpll_sdiv); writel(val, &clk->mpll_con0); - while (readl(&clk->mpll_con0) & MPLL_CON0_LOCKED) + while ((readl(&clk->mpll_con0) & MPLL_CON0_LOCKED) == 0) ;
/* Set BPLL */ writel(BPLL_CON1_VAL, &clk->bpll_con1); val = set_pll(mem->bpll_mdiv, mem->bpll_pdiv, mem->bpll_sdiv); writel(val, &clk->bpll_con0); - while (readl(&clk->bpll_con0) & BPLL_CON0_LOCKED) + while ((readl(&clk->bpll_con0) & BPLL_CON0_LOCKED) == 0) ;
/* Set CPLL */ writel(CPLL_CON1_VAL, &clk->cpll_con1); val = set_pll(mem->cpll_mdiv, mem->cpll_pdiv, mem->cpll_sdiv); writel(val, &clk->cpll_con0); - while (readl(&clk->cpll_con0) & CPLL_CON0_LOCKED) + while ((readl(&clk->cpll_con0) & CPLL_CON0_LOCKED) == 0) ;
/* Set GPLL */ writel(GPLL_CON1_VAL, &clk->gpll_con1); val = set_pll(mem->gpll_mdiv, mem->gpll_pdiv, mem->gpll_sdiv); writel(val, &clk->gpll_con0); - while (readl(&clk->gpll_con0) & GPLL_CON0_LOCKED) + while ((readl(&clk->gpll_con0) & GPLL_CON0_LOCKED) == 0) ;
/* Set EPLL */ @@ -530,7 +530,7 @@ void system_clock_init() writel(EPLL_CON1_VAL, &clk->epll_con1); val = set_pll(mem->epll_mdiv, mem->epll_pdiv, mem->epll_sdiv); writel(val, &clk->epll_con0); - while (readl(&clk->epll_con0) & EPLL_CON0_LOCKED) + while ((readl(&clk->epll_con0) & EPLL_CON0_LOCKED) == 0) ;
/* Set VPLL */ @@ -538,7 +538,7 @@ void system_clock_init() writel(VPLL_CON1_VAL, &clk->vpll_con1); val = set_pll(mem->vpll_mdiv, mem->vpll_pdiv, mem->vpll_sdiv); writel(val, &clk->vpll_con0); - while (readl(&clk->vpll_con0) & VPLL_CON0_LOCKED) + while ((readl(&clk->vpll_con0) & VPLL_CON0_LOCKED) == 0) ;
writel(CLK_SRC_CORE0_VAL, &clk->src_core0);
Acked-by: Simon Glass sjg@chromium.org _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Akshay Saraswat
Minkyu Kang
