[PATCH 4/4] arm: histb: hi3798mv200: add initial support for Hi3798MV200 HC2910-2AGHD05 board
A board with Hi3798MV200 SoC and various peripherals. Details are in the board README.md.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- .../hi3798mv200-hc2910-2aghd05-u-boot.dtsi | 8 + arch/arm/dts/hi3798mv200-hc2910-2aghd05.dts | 71 ++++++ arch/arm/dts/hi3798mv200-u-boot.dtsi | 22 ++ arch/arm/dts/hi3798mv200.dtsi | 225 ++++++++++++++++++ arch/arm/mach-histb/Kconfig | 25 ++ board/skyworth/hc2910-2aghd05/Kconfig | 15 ++ board/skyworth/hc2910-2aghd05/MAINTAINERS | 6 + board/skyworth/hc2910-2aghd05/Makefile | 1 + board/skyworth/hc2910-2aghd05/README | 25 ++ .../skyworth/hc2910-2aghd05/hc2910-2aghd05.c | 26 ++ configs/hc2910_2aghd05_defconfig | 50 ++++ include/configs/hc2910-2aghd05.h | 6 + 12 files changed, 480 insertions(+) create mode 100644 arch/arm/dts/hi3798mv200-hc2910-2aghd05-u-boot.dtsi create mode 100644 arch/arm/dts/hi3798mv200-hc2910-2aghd05.dts create mode 100644 arch/arm/dts/hi3798mv200-u-boot.dtsi create mode 100644 arch/arm/dts/hi3798mv200.dtsi create mode 100644 board/skyworth/hc2910-2aghd05/Kconfig create mode 100644 board/skyworth/hc2910-2aghd05/MAINTAINERS create mode 100644 board/skyworth/hc2910-2aghd05/Makefile create mode 100644 board/skyworth/hc2910-2aghd05/README create mode 100644 board/skyworth/hc2910-2aghd05/hc2910-2aghd05.c create mode 100644 configs/hc2910_2aghd05_defconfig create mode 100644 include/configs/hc2910-2aghd05.h
diff --git a/arch/arm/dts/hi3798mv200-hc2910-2aghd05-u-boot.dtsi b/arch/arm/dts/hi3798mv200-hc2910-2aghd05-u-boot.dtsi new file mode 100644 index 0000000000..eb320761f2 --- /dev/null +++ b/arch/arm/dts/hi3798mv200-hc2910-2aghd05-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "hi3798mv200-u-boot.dtsi" + +/* The clock driver is missing */ +&sd0 { + status = "disabled"; +}; diff --git a/arch/arm/dts/hi3798mv200-hc2910-2aghd05.dts b/arch/arm/dts/hi3798mv200-hc2910-2aghd05.dts new file mode 100644 index 0000000000..c4ca5ed235 --- /dev/null +++ b/arch/arm/dts/hi3798mv200-hc2910-2aghd05.dts @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * DTS File for Skyworth HC2910 with board label 2AGHD05 set-top box. + * + * Released under the GPLv2 only. + */ + +/dts-v1/; + +#include "hi3798mv200.dtsi" + +/ { + // Usually known as Henan Guangdian HC2910 + model = "Skyworth HC2910 with board label 2AGHD05"; + compatible = "skyworth,hc2910-2aghd05", "hisilicon,hi3798mv200"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +&ehci { + status = "okay"; +}; + +&emmc { + fifo-depth = <256>; + clock-frequency = <200000000>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + non-removable; + bus-width = <8>; + status = "okay"; +}; + +&gmac { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + phy-handle = <ð_phy1>; + phy-mode = "rgmii"; + hisilicon,phy-reset-delays-us = <10000 10000 30000>; + + eth_phy1: phy@3 { + reg = <3>; + }; +}; + +&ohci { + status = "okay"; +}; + +&sd0 { + bus-width = <4>; + cap-sd-highspeed; + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; diff --git a/arch/arm/dts/hi3798mv200-u-boot.dtsi b/arch/arm/dts/hi3798mv200-u-boot.dtsi new file mode 100644 index 0000000000..8917bcf33d --- /dev/null +++ b/arch/arm/dts/hi3798mv200-u-boot.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot addition to: + * 1) use platform data for the console + * + */ + +#include <dt-bindings/reset/ti-syscon.h> + +/* The driver in U-Boot does not support "snps,dw-mshc" compatible. */ +&sd0 { + compatible = "hisilicon,hi3798mv200-dw-mshc"; +}; + +&sd1 { + compatible = "hisilicon,hi3798mv200-dw-mshc"; +}; + +/* The clock driver is missing */ +&uart0 { + clock = <75000000>; +}; diff --git a/arch/arm/dts/hi3798mv200.dtsi b/arch/arm/dts/hi3798mv200.dtsi new file mode 100644 index 0000000000..fedf87ac67 --- /dev/null +++ b/arch/arm/dts/hi3798mv200.dtsi @@ -0,0 +1,225 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * DTS File for HiSilicon Hi3798mv200 SoC. + * + * Released under the GPLv2 only. + */ + +#include <dt-bindings/clock/histb-clock.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy.h> +#include <dt-bindings/reset/ti-syscon.h> + +/ { + compatible = "hisilicon,hi3798mv200"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + reg = <0x0 0x0>; + enable-method = "psci"; + }; + + cpu@1 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + reg = <0x0 0x1>; + enable-method = "psci"; + }; + + cpu@2 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + reg = <0x0 0x2>; + enable-method = "psci"; + }; + + cpu@3 { + compatible = "arm,cortex-a53"; + device_type = "cpu"; + reg = <0x0 0x3>; + enable-method = "psci"; + }; + }; + + gic: interrupt-controller@f1001000 { + compatible = "arm,gic-400"; + reg = <0x0 0xf1001000 0x0 0x1000>, /* GICD */ + <0x0 0xf1002000 0x0 0x100>; /* GICC */ + #address-cells = <0>; + #interrupt-cells = <3>; + interrupt-controller; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>; + }; + + /* Initialization is done in boot loader */ + usb2_phy1: hsusb1_phy { + compatible = "usb-nop-xceiv"; + clocks = <&crg HISTB_USB2_PHY1_REF_CLK>; + clock-names = "main"; + #phy-cells = <0>; + }; + + soc: soc@f0000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0xf0000000 0x10000000>; + + crg: clock-reset-controller@8a22000 { + compatible = "hisilicon,hi3798mv200-crg", "syscon", "simple-mfd"; + reg = <0x8a22000 0x1000>; + #clock-cells = <1>; + #reset-cells = <2>; + }; + + sysctrl: system-controller@8000000 { + compatible = "hisilicon,hi3798mv200-sysctrl", "syscon"; + reg = <0x8000000 0x1000>; + #clock-cells = <1>; + #reset-cells = <2>; + }; + + perictrl: peripheral-controller@8a20000 { + compatible = "hisilicon,hi3798mv200-perictrl", "syscon", + "simple-mfd"; + reg = <0x8a20000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8a20000 0x1000>; + + combphy0: phy@850 { + compatible = "hisilicon,hi3798mv200-combphy"; + reg = <0x850 0x8>; + #phy-cells = <1>; + clocks = <&crg HISTB_COMBPHY0_CLK>; + resets = <&crg 0x188 4>; + assigned-clocks = <&crg HISTB_COMBPHY0_CLK>; + assigned-clock-rates = <100000000>; + hisilicon,fixed-mode = <PHY_TYPE_USB3>; + }; + }; + + pmx0: pinconf@8a21000 { + compatible = "pinconf-single"; + reg = <0x8a21000 0x180>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <7>; + }; + + uart0: serial@8b00000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x8b00000 0x1000>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sysctrl HISTB_UART0_CLK>; + clock-names = "apb_pclk"; + status = "disabled"; + }; + + sd0: mmc@9820000 { + compatible = "snps,dw-mshc"; + reg = <0x9820000 0x10000>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&crg HISTB_SDIO0_CIU_CLK>, + <&crg HISTB_SDIO0_BIU_CLK>; + clock-names = "ciu", "biu"; + resets = <&crg 0x9c 4>; + reset-names = "reset"; + status = "disabled"; + }; + + emmc: mmc@9830000 { + compatible = "hisilicon,hi3798mv200-dw-mshc"; + reg = <0x9830000 0x10000>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&crg HISTB_MMC_CIU_CLK>, + <&crg HISTB_MMC_BIU_CLK>, + <&crg HISTB_MMC_SAMPLE_CLK>, + <&crg HISTB_MMC_DRV_CLK>; + clock-names = "ciu", "biu", "ciu-sample", "ciu-drive"; + resets = <&crg 0xa0 4>; + reset-names = "reset"; + status = "disabled"; + }; + + gmac: ethernet@9840000 { + compatible = "hisilicon,hi3798mv200-gmac", "hisilicon,hisi-gmac-v2"; + reg = <0x9840000 0x1000>, + <0x984300c 0x4>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&crg HISTB_ETH0_MAC_CLK>, + <&crg HISTB_ETH0_MACIF_CLK>; + clock-names = "mac_core", "mac_ifc"; + resets = <&crg 0xcc 0>, + <&crg 0xcc 2>, + <&crg 0xcc 5>; + reset-names = "mac_core", "mac_ifc", "phy"; + status = "disabled"; + }; + + ohci: ohci@9880000 { + compatible = "generic-ohci"; + reg = <0x9880000 0x10000>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&crg HISTB_USB2_BUS_CLK>, + <&crg HISTB_USB2_12M_CLK>, + <&crg HISTB_USB2_48M_CLK>; + clock-names = "bus", "clk12", "clk48"; + resets = <&crg 0xb8 12>; + reset-names = "bus"; + status = "disabled"; + }; + + ehci: ehci@9890000 { + compatible = "generic-ehci"; + reg = <0x9890000 0x10000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&crg HISTB_USB2_BUS_CLK>, + <&crg HISTB_USB2_PHY_CLK>, + <&crg HISTB_USB2_UTMI_CLK>; + clock-names = "bus", "phy", "utmi"; + resets = <&crg 0xb8 12>, + <&crg 0xb8 16>, + <&crg 0xb8 13>; + reset-names = "bus", "phy", "utmi"; + phys = <&usb2_phy1>; + phy-names = "usb"; + status = "disabled"; + }; + + sd1: mmc@9c40000 { + compatible = "snps,dw-mshc"; + reg = <0x9c40000 0x10000>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&crg HISTB_SDIO1_CIU_CLK>, + <&crg HISTB_SDIO1_BIU_CLK>; + clock-names = "ciu", "biu"; + resets = <&crg 0x28c 4>; + reset-names = "reset"; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/mach-histb/Kconfig b/arch/arm/mach-histb/Kconfig index 78d40859a3..012dbfe8bc 100644 --- a/arch/arm/mach-histb/Kconfig +++ b/arch/arm/mach-histb/Kconfig @@ -11,4 +11,29 @@ config ARCH_HI3798MV2X
endchoice
+if ARCH_HI3798MV2X + +choice + prompt "Select a Hi3798M V2XX based board" + +config TARGET_HC2910_2AGHD05 + bool "Skyworth HC2910 with board label 2AGHD05" + help + Support for Skyworth HC2910 with board label 2AGHD05. This board features: + - Hisilicon Hi3798MV200 SoC (4xCortex-A53, Mali MP-450) + - 2GiB DRAM + - 8GiB eMMC, uSD slot + - Wifi and Bluetooth module + - 1x USB 2.0, 1x USB 3.0 host port + - HDMI + - SCI + - 3 LED - power, Wifi, Lock(?) + - 1x Fast Ethernet Controller, 1x GBe Ethernet Controller + +endchoice + +endif + +source "board/skyworth/hc2910-2aghd05/Kconfig" + endif diff --git a/board/skyworth/hc2910-2aghd05/Kconfig b/board/skyworth/hc2910-2aghd05/Kconfig new file mode 100644 index 0000000000..f85f1f2631 --- /dev/null +++ b/board/skyworth/hc2910-2aghd05/Kconfig @@ -0,0 +1,15 @@ +if TARGET_HC2910_2AGHD05 + +config SYS_BOARD + default "hc2910-2aghd05" + +config SYS_VENDOR + default "skyworth" + +config SYS_SOC + default "hi3798mv200" + +config SYS_CONFIG_NAME + default "hc2910-2aghd05" + +endif diff --git a/board/skyworth/hc2910-2aghd05/MAINTAINERS b/board/skyworth/hc2910-2aghd05/MAINTAINERS new file mode 100644 index 0000000000..2c1e750018 --- /dev/null +++ b/board/skyworth/hc2910-2aghd05/MAINTAINERS @@ -0,0 +1,6 @@ +HC2910 2AGHD05 BOARD +M: Yang Xiwen firbidden405@outlook.com +S: Maintained +F: board/skyworth/hc2910-2aghd05 +F: include/configs/hc2910-2aghd05.h +F: configs/hc2910_2aghd05_defconfig diff --git a/board/skyworth/hc2910-2aghd05/Makefile b/board/skyworth/hc2910-2aghd05/Makefile new file mode 100644 index 0000000000..193fd158fe --- /dev/null +++ b/board/skyworth/hc2910-2aghd05/Makefile @@ -0,0 +1 @@ +obj-y := hc2910-2aghd05.o diff --git a/board/skyworth/hc2910-2aghd05/README b/board/skyworth/hc2910-2aghd05/README new file mode 100644 index 0000000000..a838956e59 --- /dev/null +++ b/board/skyworth/hc2910-2aghd05/README @@ -0,0 +1,25 @@ +================================================================================ + Board Information +================================================================================ + +The board features the Hi3798M V200 with an integrated quad-core 64-bit ARM +Cortex A53 processor. +SOC Hisilicon Hi3798CV200 +CPU Quad-core ARM Cortex-A53 64 bit +DRAM DDR3/3L/4 SDRAM interface, maximum 32-bit data width 2 GB +USB 1x USB 2.0 ports 1x USB 3.0 ports +CONSOLE USB-micro port for console support +ETHERNET 1 GBe Ethernet, 1 MBe Ethernet +WIFI 802.11n with Bluebooth +CONNECTORS One connector for Smart Card One connector for TSI + + +================================================================================ + BUILD INSTRUCTIONS +================================================================================ + +The U-Boot relies on a modified l-loader and TF-A for Hi3798MV200. +The source for l-loader can be obtained at: [l-loader](https://github.com/185264646/l-loader) +The mainline port for TF-A is still under development. For now, you can use the TF-A for poplar directly. + +For more information, please refer to <board/hisilicon/poplar/README>. diff --git a/board/skyworth/hc2910-2aghd05/hc2910-2aghd05.c b/board/skyworth/hc2910-2aghd05/hc2910-2aghd05.c new file mode 100644 index 0000000000..abad5efdaf --- /dev/null +++ b/board/skyworth/hc2910-2aghd05/hc2910-2aghd05.c @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Board init file for Skyworth HC2910 2AGHD05 + */ + +#include <common.h> +#include <fdtdec.h> +#include <init.h> +#include <asm/system.h> +#include <linux/io.h> + +#define HI3798MV200_PERI_CTRL_BASE 0xf8a20000 +#define SDIO0_LDO_OFFSET 0x11c + +static int sdio0_set_ldo(void) +{ + // SDIO LDO bypassed, 3.3V + writel(HI3798MV200_PERI_CTRL_BASE + SDIO0_LDO_OFFSET, 0x60); + return 0; +} + +int board_init(void) +{ + sdio0_set_ldo(); + return 0; +} diff --git a/configs/hc2910_2aghd05_defconfig b/configs/hc2910_2aghd05_defconfig new file mode 100644 index 0000000000..dfd3e656b9 --- /dev/null +++ b/configs/hc2910_2aghd05_defconfig @@ -0,0 +1,50 @@ +CONFIG_ARM=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_HISTB=y +CONFIG_TEXT_BASE=0x00000000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_DEFAULT_DEVICE_TREE="hi3798mv200-hc2910-2aghd05" +CONFIG_SYS_PROMPT="HC2910# " +CONFIG_IDENT_STRING="HC2910" +CONFIG_SYS_LOAD_ADDR=0x800000 +# CONFIG_EXPERT is not set +CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=512 +CONFIG_SYS_PBSIZE=537 +CONFIG_CMD_BOOTDEV=y +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +CONFIG_CMD_NVEDIT_INFO=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MBR=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_CAT=y +CONFIG_CMD_EROFS=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +# CONFIG_GPIO is not set +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +CONFIG_MMC_DW=y +CONFIG_MMC_DW_K3=y +# CONFIG_POWER is not set +CONFIG_FS_BTRFS=y +CONFIG_FAT_WRITE=y +CONFIG_REGEX=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/hc2910-2aghd05.h b/include/configs/hc2910-2aghd05.h new file mode 100644 index 0000000000..3db9a474ec --- /dev/null +++ b/include/configs/hc2910-2aghd05.h @@ -0,0 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __HC2910_2AGHD05_CONFIG_H__ +#define __HC2910_2AGHD05_CONFIG_H__ + +#endif
Yang Xiwen
