[U-Boot] [PATCH V3] Add Boundary Devices Nitrogen6X boards
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- Changes for V2: - Update tXS, tXPR as noted by Benoît Thébaudeau - Use struct hdmi_regs and readb()/writeb() as noted by Wolfgang Denk - Use get_ram_size() instead of imx_ddr_size() - Remote unneeded CONFIG_ARP_TIMEOUT
Changes for V3: - Don't use get_ram_size(). Explicitly use CONFIG_DDR_MB from boards.cfg
MAINTAINERS | 8 + board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg | 58 ++ board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 58 ++ board/boundary/nitrogen6x/6x_bootscript.txt | 63 ++ .../boundary/nitrogen6x/6x_bootscript_android.txt | 64 ++ .../nitrogen6x/6x_bootscript_android_recovery.txt | 64 ++ board/boundary/nitrogen6x/6x_upgrade.txt | 45 + board/boundary/nitrogen6x/800mhz_2x128mx16.cfg | 58 ++ board/boundary/nitrogen6x/800mhz_2x256mx16.cfg | 58 ++ board/boundary/nitrogen6x/800mhz_4x128mx16.cfg | 57 ++ board/boundary/nitrogen6x/800mhz_4x256mx16.cfg | 58 ++ board/boundary/nitrogen6x/Makefile | 41 + board/boundary/nitrogen6x/README | 92 ++ board/boundary/nitrogen6x/clocks.cfg | 46 + board/boundary/nitrogen6x/ddr-setup.cfg | 112 +++ board/boundary/nitrogen6x/nitrogen6dl.cfg | 45 + board/boundary/nitrogen6x/nitrogen6dl2g.cfg | 45 + board/boundary/nitrogen6x/nitrogen6q.cfg | 45 + board/boundary/nitrogen6x/nitrogen6q2g.cfg | 45 + board/boundary/nitrogen6x/nitrogen6s.cfg | 45 + board/boundary/nitrogen6x/nitrogen6s1g.cfg | 45 + board/boundary/nitrogen6x/nitrogen6x.c | 895 ++++++++++++++++++++ boards.cfg | 6 + include/configs/nitrogen6x.h | 285 +++++++ 24 files changed, 2338 insertions(+) create mode 100644 board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/6x_bootscript.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt create mode 100644 board/boundary/nitrogen6x/6x_upgrade.txt create mode 100644 board/boundary/nitrogen6x/800mhz_2x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_2x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/Makefile create mode 100644 board/boundary/nitrogen6x/README create mode 100644 board/boundary/nitrogen6x/clocks.cfg create mode 100644 board/boundary/nitrogen6x/ddr-setup.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s1g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6x.c create mode 100644 include/configs/nitrogen6x.h
diff --git a/MAINTAINERS b/MAINTAINERS index 175bbe2..f490d62 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1037,6 +1037,14 @@ Pali Rohár pali.rohar@gmail.com
nokia_rx51 ARM ARMV7 (OMAP34xx SoC)
+Eric Nelson eric.nelson@boundarydevices.com + nitrogen6dl i.MX6DL 1GB + nitrogen6dl2g i.MX6DL 2GB + nitrogen6q i.MX6Q/6D 1GB + nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6s i.MX6S 512MB + nitrogen6s1g i.MX6S 1GB + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg new file mode 100644 index 0000000..16a37d0 --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x00020036 +DATA 4, MX6_MMDC_P0_MDCFG0, 0x555A7974 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xDB538F64 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x005A1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x09444040 +DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04088032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x19308030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42720306 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x026F0266 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x4273030A +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x02740240 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x45393B3E +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x403A3747 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x40434541 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x473E4A3B +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0011000E +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x000E001B +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00190015 +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x00070018 +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg new file mode 100644 index 0000000..0607703 --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x00020036 +DATA 4, MX6_MMDC_P0_MDCFG0, 0x898E7974 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xDB538F64 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x008E1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x09444040 +DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 +DATA 4, MX6_MMDC_P0_MDASP, 0x00000047 +DATA 4, MX6_MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04088032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x19308030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x43040319 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x03040279 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x43040321 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x03030251 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4d434248 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x42413c4d +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x34424543 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x49324933 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x001a0017 +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00170027 +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x000a001f +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/6x_bootscript.txt b/board/boundary/nitrogen6x/6x_bootscript.txt new file mode 100644 index 0000000..061b3a4 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript.txt @@ -0,0 +1,63 @@ +setenv bootargs enable_wait_mode=off +setenv nextcon 0; + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + setenv fbmem "fbmem=28M"; + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +i2c dev 2 +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs $fbmem +setenv bootargs "$bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 rootwait" + +if test "sata" = "${dtype}" ; then + setenv bootargs "$bootargs root=/dev/sda1" ; +else + setenv "bootargs $bootargs root=/dev/mmcblk0p1" ; +fi +${fs}load ${dtype} ${disk}:1 10800000 /boot/uImage && bootm 10800000 ; +echo "Error loading kernel image" diff --git a/board/boundary/nitrogen6x/6x_bootscript_android.txt b/board/boundary/nitrogen6x/6x_bootscript_android.txt new file mode 100644 index 0000000..0982cf8 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk} + +setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ; + +i2c dev 2 + +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=28M"; + else + setenv fbcon ${fbcon},28M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000 +echo "Error loading kernel image" diff --git a/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt new file mode 100644 index 0000000..0982cf8 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk} + +setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ; + +i2c dev 2 + +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=28M"; + else + setenv fbcon ${fbcon},28M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000 +echo "Error loading kernel image" diff --git a/board/boundary/nitrogen6x/6x_upgrade.txt b/board/boundary/nitrogen6x/6x_upgrade.txt new file mode 100644 index 0000000..0d8e8e5 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_upgrade.txt @@ -0,0 +1,45 @@ +setenv stdout serial,vga +echo "check U-Boot" ; +setenv offset 0x400 +if ${fs}load ${dtype} ${disk}:1 12000000 u-boot.imx || ${fs}load ${dtype} ${disk}:1 12000000 u-boot.nopadding ; then + echo "read $filesize bytes from SD card" ; + if sf probe || sf probe || \ + sf probe 1 27000000 || sf probe 1 27000000 ; then + echo "probed SPI ROM" ; + if sf read 0x12400000 $offset $filesize ; then + if cmp.b 0x12000000 0x12400000 $filesize ; then + echo "------- U-Boot versions match" ; + else + echo "Need U-Boot upgrade" ; + echo "Program in 5 seconds" ; + for n in 5 4 3 2 1 ; do + echo $n ; + sleep 1 ; + done + echo "erasing" ; + sf erase 0 0x50000 ; + # two steps to prevent bricking + echo "programming" ; + sf write 0x12000000 $offset $filesize ; + echo "verifying" ; + if sf read 0x12400000 $offset $filesize ; then + if cmp.b 0x12000000 0x12400000 $filesize ; then + while echo "---- U-Boot upgraded. reset" ; do + sleep 120 + done + else + echo "Read verification error" ; + fi + else + echo "Error re-reading EEPROM" ; + fi + fi + else + echo "Error reading boot loader from EEPROM" ; + fi + else + echo "Error initializing EEPROM" ; + fi ; +else + echo "No U-Boot image found on SD card" ; +fi diff --git a/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg new file mode 100644 index 0000000..de33e65 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x40435323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x00431023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000017 +DATA 4, MX6_MMDC_P0_MDCTL, 0x83190000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg new file mode 100644 index 0000000..19707cf --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x696C5323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x006C1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x84190000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg new file mode 100644 index 0000000..dd6a423 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x40435323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x00431023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x420F020F +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x01760175 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x41640171 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x015E0160 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x45464B4A +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x49484A46 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x40402E32 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3A3A3231 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x003A003A +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0030002F +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x002F0038 +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x00270039 +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg new file mode 100644 index 0000000..d5d06e2 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x696C5323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x006C1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000047 +DATA 4, MX6_MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/Makefile b/board/boundary/nitrogen6x/Makefile new file mode 100644 index 0000000..fe1e5e0 --- /dev/null +++ b/board/boundary/nitrogen6x/Makefile @@ -0,0 +1,41 @@ +# +# Copyright (C) 2012-2013, Guennadi Liakhovetski lg@denx.de +# (C) Copyright 2012-2013 Freescale Semiconductor, Inc. +# Copyright (C) 2013, Boundary Devices info@boundarydevices.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := nitrogen6x.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/boundary/nitrogen6x/README b/board/boundary/nitrogen6x/README new file mode 100644 index 0000000..5049093 --- /dev/null +++ b/board/boundary/nitrogen6x/README @@ -0,0 +1,92 @@ +U-Boot for the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards + +This file contains information for the port of +U-Boot to the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards. + +1. Boot source, boot from SPI NOR +--------------------------------- +The configuration in this directory supports both the +Nitrogen6X and Freescale SabreLite board, but in a +different fashion from Freescale's implementation in +board/freescale/mx6qsabrelite. + +In particular, this image supports booting from SPI NOR +and saving the environment to SPI NOR. + +It does not support 'boot from SD' at offset 0x400 +except through the 'bmode' command. + http://lists.denx.de/pipermail/u-boot/2012-August/131151.html + +2. Boots using 6x_bootscript on SATA or SD card +----------------------------------------------- +The default bootcmd for these boards is configured +to look for and source a boot script named '6x_bootscript' +in the root of the first partition of the following +devices: + + sata 0 + mmc 0 + mmc 1 + +They're searched in the order listed above, trying both the +ext2 and fat filesystems. + +2. Maintaining the SPI NOR +-------------------------- +A couple of convenience commands + + clearenv - clear environment to factory default + upgradeu - look and source a boot script named + '6x_upgrade' to upgrade the U-Boot version + in SPI NOR. The search is the same as for + 6x_bootscript described above. + +3. Display support +------------------ +U-Boot support for the following displays is configured by +default: + + HDMI - 1024 x 768 for maximum compatibility + Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1) + wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600) + wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480) + +Since the ipuv3_fb display driver currently supports only a single display, +this code auto-detects panel by probing the HDMI Phy for Hot Plug Detect +or the I2C touch controller of the LVDS and RGB displays in the priority +listed above. + +Setting 'panel' environment variable to one of the names above will +override auto-detection and force activation of the specified panel. + +4. Building +------------ + +To build U-Boot for one of the Nitrogen6x or SabreLite board: + + make nitrogen6x_config + make u-boot.imx + +Note that 'nitrogen6x' is a placeholder. The complete list of supported +board configurations is shown in tha MAINTAINERS file: + nitrogen6q i.MX6Q/6D 1GB + nitrogen6dl i.MX6DL 1GB + nitrogen6s i.MX6S 512MB + nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6dl2g i.MX6DL 2GB + nitrogen6s1g i.MX6S 1GB + +The -6q variants support either the i.MX6Quad or i.MX6Dual processors +and are configured for a 64-bit memory bus at 1066 MHz. + +The -6dl variants also use a 64-bit memory bus, operated at 800MHz. + +The -6s variants use a 32-bit memory bus at 800MHz. + +If you place the u-boot.imx into a single-partition SD card +along with a binary version of the boot script 6x_upgrade.txt, +you can program it using 'upgradeu': + + U-Boot> run upgradeu diff --git a/board/boundary/nitrogen6x/clocks.cfg b/board/boundary/nitrogen6x/clocks.cfg new file mode 100644 index 0000000..e7d1f86 --- /dev/null +++ b/board/boundary/nitrogen6x/clocks.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0x00FFF300 +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F diff --git a/board/boundary/nitrogen6x/ddr-setup.cfg b/board/boundary/nitrogen6x/ddr-setup.cfg new file mode 100644 index 0000000..c315812 --- /dev/null +++ b/board/boundary/nitrogen6x/ddr-setup.cfg @@ -0,0 +1,112 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* + * DDR3 settings + * MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock), + * memory bus width: 64 bits x16/x32/x64 + * MX6DL ddr is limited to 800 MHz(400 MHz clock) + * memory bus width: 64 bits x16/x32/x64 + * MX6SOLO ddr is limited to 800 MHz(400 MHz clock) + * memory bus width: 32 bits x16/x32 + */ +DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000030 + +DATA 4, MX6_IOM_GRP_B0DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B1DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B2DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B3DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B4DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B5DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B6DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B7DS, 0x00000030 +DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 + +DATA 4, MX6_IOM_DRAM_DQM0, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM1, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM2, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM3, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM4, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM5, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM6, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM7, 0x00020030 + +DATA 4, MX6_IOM_DRAM_CAS, 0x00020030 +DATA 4, MX6_IOM_DRAM_RAS, 0x00020030 +DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00020030 +DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00020030 + +DATA 4, MX6_IOM_DRAM_RESET, 0x000e0030 +DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 +DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 + +DATA 4, MX6_IOM_DRAM_SDODT0, 0x00003030 +DATA 4, MX6_IOM_DRAM_SDODT1, 0x00003030 + +/* (differential input) */ +DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 +/* (differential input) */ +DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 +/* disable ddr pullups */ +DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 + +/* Read data DQ Byte0-3 delay */ +DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 + +/* + * MDMISC mirroring interleaved (row/bank/col) + */ +DATA 4, MX6_MMDC_P0_MDMISC, 0x00081740 + +/* + * MDSCR con_req + */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 diff --git a/board/boundary/nitrogen6x/nitrogen6dl.cfg b/board/boundary/nitrogen6x/nitrogen6dl.cfg new file mode 100644 index 0000000..d6da96c --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_4x128mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6dl2g.cfg b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg new file mode 100644 index 0000000..0b1c35c --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_4x256mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6q.cfg b/board/boundary/nitrogen6x/nitrogen6q.cfg new file mode 100644 index 0000000..680a853 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "1066mhz_4x128mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6q2g.cfg b/board/boundary/nitrogen6x/nitrogen6q2g.cfg new file mode 100644 index 0000000..f57ab0e --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q2g.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "1066mhz_4x256mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6s.cfg b/board/boundary/nitrogen6x/nitrogen6s.cfg new file mode 100644 index 0000000..b5af5cc --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_2x128mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6s1g.cfg b/board/boundary/nitrogen6x/nitrogen6s1g.cfg new file mode 100644 index 0000000..5aeefc8 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s1g.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_2x256mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c new file mode 100644 index 0000000..0dbb6d2 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -0,0 +1,895 @@ +/* + * Copyright (C) 2010-2013 Freescale Semiconductor, Inc. + * Copyright (C) 2013, Boundary Devices info@boundarydevices.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> +#include <malloc.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <micrel.h> +#include <miiphy.h> +#include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mxc_hdmi.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define BUTTON_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define WEAK_PULLUP (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_SLOW) + +#define WEAK_PULLDOWN (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_SLOW) + +#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm) + +int dram_init(void) +{ + gd->ram_size = CONFIG_DDR_MB * 1024 * 1024; + + return 0; +} + +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_SD3_DAT6__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT7__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_EIM_D26__UART2_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +/* I2C1, SGTL5000 */ +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_EIM_D21__GPIO_3_21 | PC, + .gp = IMX_GPIO_NR(3, 21) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D28__GPIO_3_28 | PC, + .gp = IMX_GPIO_NR(3, 28) + } +}; + +/* I2C2 Camera, MIPI */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_KEY_COL3__GPIO_4_12 | PC, + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO_4_13 | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +/* I2C3, J15 - RGB connector */ +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_5__I2C3_SCL | PC, + .gpio_mode = MX6_PAD_GPIO_5__GPIO_1_5 | PC, + .gp = IMX_GPIO_NR(1, 5) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_16__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_16__GPIO_7_11 | PC, + .gp = IMX_GPIO_NR(7, 11) + } +}; + +iomux_v3_cfg_t const usdhc3_pads[] = { + MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__GPIO_7_0 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const usdhc4_pads[] = { + MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D6__GPIO_2_6 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const enet_pads1[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* pin 35 - 1 (PHY_AD2) on reset */ + MX6_PAD_RGMII_RXC__GPIO_6_30 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 32 - 1 - (MODE0) all */ + MX6_PAD_RGMII_RD0__GPIO_6_25 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 31 - 1 - (MODE1) all */ + MX6_PAD_RGMII_RD1__GPIO_6_27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 28 - 1 - (MODE2) all */ + MX6_PAD_RGMII_RD2__GPIO_6_28 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 27 - 1 - (MODE3) all */ + MX6_PAD_RGMII_RD3__GPIO_6_29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ + MX6_PAD_RGMII_RX_CTL__GPIO_6_24 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 42 PHY nRST */ + MX6_PAD_EIM_D23__GPIO_3_23 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_ENET_RXD0__GPIO_1_27 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const enet_pads2[] = { + MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +/* wl1271 pads on nitrogen6x */ +iomux_v3_cfg_t const wl12xx_pads[] = { + (MX6_PAD_NANDF_CS1__GPIO_6_14 & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(WEAK_PULLDOWN), + (MX6_PAD_NANDF_CS2__GPIO_6_15 & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(OUTPUT_40OHM), + (MX6_PAD_NANDF_CS3__GPIO_6_16 & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(OUTPUT_40OHM), +}; +#define WL12XX_WL_IRQ_GP IMX_GPIO_NR(6, 14) +#define WL12XX_WL_ENABLE_GP IMX_GPIO_NR(6, 15) +#define WL12XX_BT_ENABLE_GP IMX_GPIO_NR(6, 16) + +/* Button assignments for J14 */ +static iomux_v3_cfg_t const button_pads[] = { + /* Menu */ + MX6_PAD_NANDF_D1__GPIO_2_1 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Back */ + MX6_PAD_NANDF_D2__GPIO_2_2 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Labelled Search (mapped to Power under Android) */ + MX6_PAD_NANDF_D3__GPIO_2_3 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Home */ + MX6_PAD_NANDF_D4__GPIO_2_4 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Volume Down */ + MX6_PAD_GPIO_19__GPIO_4_5 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Volume Up */ + MX6_PAD_GPIO_18__GPIO_7_13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), +}; + +static void setup_iomux_enet(void) +{ + gpio_direction_output(IMX_GPIO_NR(3, 23), 0); /* SABRE Lite PHY rst */ + gpio_direction_output(IMX_GPIO_NR(1, 27), 0); /* Nitrogen6X PHY rst */ + gpio_direction_output(IMX_GPIO_NR(6, 30), 1); + gpio_direction_output(IMX_GPIO_NR(6, 25), 1); + gpio_direction_output(IMX_GPIO_NR(6, 27), 1); + gpio_direction_output(IMX_GPIO_NR(6, 28), 1); + gpio_direction_output(IMX_GPIO_NR(6, 29), 1); + imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1)); + gpio_direction_output(IMX_GPIO_NR(6, 24), 1); + + /* Need delay 10ms according to KSZ9021 spec */ + udelay(1000 * 10); + gpio_set_value(IMX_GPIO_NR(3, 23), 1); /* SABRE Lite PHY reset */ + gpio_set_value(IMX_GPIO_NR(1, 27), 1); /* Nitrogen6X PHY reset */ + + imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); +} + +iomux_v3_cfg_t const usb_pads[] = { + MX6_PAD_GPIO_17__GPIO_7_12 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); +} + +#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{ + imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); + + /* Reset USB hub */ + gpio_direction_output(IMX_GPIO_NR(7, 12), 0); + mdelay(2); + gpio_set_value(IMX_GPIO_NR(7, 12), 1); + + return 0; +} +#endif + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC3_BASE_ADDR}, + {USDHC4_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret; + + if (cfg->esdhc_base == USDHC3_BASE_ADDR) { + gpio_direction_input(IMX_GPIO_NR(7, 0)); + ret = !gpio_get_value(IMX_GPIO_NR(7, 0)); + } else { + gpio_direction_input(IMX_GPIO_NR(2, 6)); + ret = !gpio_get_value(IMX_GPIO_NR(2, 6)); + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + s32 status = 0; + u32 index = 0; + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + + for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { + switch (index) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) then supported by the board (%d)\n", + index + 1, CONFIG_SYS_FSL_USDHC_NUM); + return status; + } + + status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + } + + return status; +} +#endif + +u32 get_board_rev(void) +{ + return 0x63000; +} + +#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t const ecspi1_pads[] = { + /* SS1 */ + MX6_PAD_EIM_D19__GPIO_3_19 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +void setup_spi(void) +{ + gpio_direction_output(CONFIG_SF_DEFAULT_CS, 1); + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, + ARRAY_SIZE(ecspi1_pads)); +} +#endif + +int board_phy_config(struct phy_device *phydev) +{ + /* min rx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x0); + /* min tx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x0); + /* max rx/tx clock delay, min rx/tx control */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf0f0); + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + uint32_t base = IMX_FEC_BASE; + struct mii_dev *bus = NULL; + struct phy_device *phydev = NULL; + int ret; + + setup_iomux_enet(); + +#ifdef CONFIG_FEC_MXC + bus = fec_get_miibus(base, -1); + if (!bus) + return 0; + /* scan phy 4,5,6,7 */ + phydev = phy_find_by_mask(bus, (0xf << 4), PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + free(bus); + return 0; + } + printf("using phy at %d\n", phydev->addr); + ret = fec_probe(bis, -1, base, bus, phydev); + if (ret) { + printf("FEC MXC: %s:failed\n", __func__); + free(phydev); + free(bus); + } +#endif + return 0; +} + +static void setup_buttons(void) +{ + imx_iomux_v3_setup_multiple_pads(button_pads, + ARRAY_SIZE(button_pads)); +} + +#ifdef CONFIG_CMD_SATA + +int setup_sata(void) +{ + struct iomuxc_base_regs *const iomuxc_regs + = (struct iomuxc_base_regs *) IOMUXC_BASE_ADDR; + int ret = enable_sata_clock(); + if (ret) + return ret; + + clrsetbits_le32(&iomuxc_regs->gpr[13], + IOMUXC_GPR13_SATA_MASK, + IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB + |IOMUXC_GPR13_SATA_PHY_7_SATA2M + |IOMUXC_GPR13_SATA_SPEED_3G + |(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT) + |IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED + |IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16 + |IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB + |IOMUXC_GPR13_SATA_PHY_2_TX_1P104V + |IOMUXC_GPR13_SATA_PHY_1_SLOW); + + return 0; +} +#endif + +#if defined(CONFIG_VIDEO_IPUV3) + +static iomux_v3_cfg_t const backlight_pads[] = { + /* Backlight on RGB connector: J15 */ + MX6_PAD_SD1_DAT3__GPIO_1_21 | MUX_PAD_CTRL(NO_PAD_CTRL), +#define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21) + + /* Backlight on LVDS connector: J6 */ + MX6_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), +#define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) +}; + +static iomux_v3_cfg_t const rgb_pads[] = { + MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, + MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2, + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3, + MX6_PAD_DI0_PIN4__GPIO_4_20, + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0, + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1, + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2, + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3, + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4, + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5, + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6, + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7, + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8, + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9, + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10, + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11, + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12, + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13, + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14, + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15, + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16, + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17, + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18, + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19, + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20, + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21, + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22, + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, +}; + +struct display_info_t { + int bus; + int addr; + int pixfmt; + int (*detect)(struct display_info_t const *dev); + void (*enable)(struct display_info_t const *dev); + struct fb_videomode mode; +}; + + +static int detect_hdmi(struct display_info_t const *dev) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + return readb(&hdmi->phy_stat0) & HDMI_PHY_HPD; +} + +static void enable_hdmi(struct display_info_t const *dev) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + u8 reg; + printf("%s: setup HDMI monitor\n", __func__); + reg = readb(&hdmi->phy_conf0); + reg |= HDMI_PHY_CONF0_PDZ_MASK; + writeb(reg, &hdmi->phy_conf0); + + udelay(3000); + reg |= HDMI_PHY_CONF0_ENTMDS_MASK; + writeb(reg, &hdmi->phy_conf0); + udelay(3000); + reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; + writeb(reg, &hdmi->phy_conf0); + writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); +} + +static int detect_i2c(struct display_info_t const *dev) +{ + return ((0 == i2c_set_bus_num(dev->bus)) + && + (0 == i2c_probe(dev->addr))); +} + +static void enable_lvds(struct display_info_t const *dev) +{ + struct iomuxc *iomux = (struct iomuxc *) + IOMUXC_BASE_ADDR; + u32 reg = readl(&iomux->gpr[2]); + reg |= IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT; + writel(reg, &iomux->gpr[2]); + gpio_direction_output(LVDS_BACKLIGHT_GP, 1); +} + +static void enable_rgb(struct display_info_t const *dev) +{ + imx_iomux_v3_setup_multiple_pads( + rgb_pads, + ARRAY_SIZE(rgb_pads)); + gpio_direction_output(RGB_BACKLIGHT_GP, 1); +} + +static struct display_info_t const displays[] = {{ + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = detect_hdmi, + .enable = enable_hdmi, + .mode = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x4, + .pixfmt = IPU_PIX_FMT_LVDS666, + .detect = detect_i2c, + .enable = enable_lvds, + .mode = { + .name = "Hannstar-XGA", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x38, + .pixfmt = IPU_PIX_FMT_LVDS666, + .detect = detect_i2c, + .enable = enable_lvds, + .mode = { + .name = "wsvga-lvds", + .refresh = 60, + .xres = 1024, + .yres = 600, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x48, + .pixfmt = IPU_PIX_FMT_RGB666, + .detect = detect_i2c, + .enable = enable_rgb, + .mode = { + .name = "wvga-rgb", + .refresh = 57, + .xres = 800, + .yres = 480, + .pixclock = 37037, + .left_margin = 40, + .right_margin = 60, + .upper_margin = 10, + .lower_margin = 10, + .hsync_len = 20, + .vsync_len = 10, + .sync = 0, + .vmode = FB_VMODE_NONINTERLACED +} } }; + +int board_video_skip(void) +{ + int i; + int ret; + char const *panel = getenv("panel"); + if (!panel) { + for (i = 0; i < ARRAY_SIZE(displays); i++) { + struct display_info_t const *dev = displays+i; + if (dev->detect(dev)) { + panel = dev->mode.name; + printf("auto-detected panel %s\n", panel); + break; + } + } + if (!panel) { + panel = displays[0].mode.name; + printf("No panel detected: default to %s\n", panel); + } + } else { + for (i = 0; i < ARRAY_SIZE(displays); i++) { + if (!strcmp(panel, displays[i].mode.name)) + break; + } + } + if (i < ARRAY_SIZE(displays)) { + ret = ipuv3_fb_init(&displays[i].mode, 0, + displays[i].pixfmt); + if (!ret) { + displays[i].enable(displays+i); + printf("Display: %s (%ux%u)\n", + displays[i].mode.name, + displays[i].mode.xres, + displays[i].mode.yres); + } else + printf("LCD %s cannot be configured: %d\n", + displays[i].mode.name, ret); + } else { + printf("unsupported panel %s\n", panel); + ret = -EINVAL; + } + return (0 != ret); +} + +static void setup_display(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + + int reg; + + /* Turn on LDB0,IPU,IPU DI0 clocks */ + reg = __raw_readl(&mxc_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET + |MXC_CCM_CCGR3_LDB_DI0_MASK; + writel(reg, &mxc_ccm->CCGR3); + + /* Turn on HDMI PHY clock */ + reg = __raw_readl(&mxc_ccm->CCGR2); + reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK + |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; + writel(reg, &mxc_ccm->CCGR2); + + /* clear HDMI PHY reset */ + writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); + + /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ + writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); + writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); + + /* set LDB0, LDB1 clk select to 011/011 */ + reg = readl(&mxc_ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + |MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + |(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->cs2cdr); + + reg = readl(&mxc_ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &mxc_ccm->cscmr2); + + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) + |(CHSCCDR_PODF_DIVIDE_BY_3 + <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); + + reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES + |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH + |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW + |IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT + |IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT + |IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED + |IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; + writel(reg, &iomux->gpr[2]); + + reg = readl(&iomux->gpr[3]); + reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) + | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 + <<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); + writel(reg, &iomux->gpr[3]); + + /* backlights off until needed */ + imx_iomux_v3_setup_multiple_pads(backlight_pads, + ARRAY_SIZE(backlight_pads)); + gpio_direction_input(LVDS_BACKLIGHT_GP); + gpio_direction_input(RGB_BACKLIGHT_GP); +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + /* Disable wl1271 For Nitrogen6w */ + gpio_direction_input(WL12XX_WL_IRQ_GP); + gpio_direction_output(WL12XX_WL_ENABLE_GP, 0); + gpio_direction_output(WL12XX_BT_ENABLE_GP, 0); + + imx_iomux_v3_setup_multiple_pads(wl12xx_pads, ARRAY_SIZE(wl12xx_pads)); + setup_buttons(); + +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + return 0; +} + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + +#ifdef CONFIG_CMD_SATA + setup_sata(); +#endif + + return 0; +} + +int checkboard(void) +{ + if (gpio_get_value(WL12XX_WL_IRQ_GP)) + puts("Board: Nitrogen6X\n"); + else + puts("Board: SABRE Lite\n"); + + return 0; +} + +struct button_key { + char const *name; + unsigned gpnum; + char ident; +}; + +static struct button_key const buttons[] = { + {"back", IMX_GPIO_NR(2, 2), 'B'}, + {"home", IMX_GPIO_NR(2, 4), 'H'}, + {"menu", IMX_GPIO_NR(2, 1), 'M'}, + {"search", IMX_GPIO_NR(2, 3), 'S'}, + {"volup", IMX_GPIO_NR(7, 13), 'V'}, + {"voldown", IMX_GPIO_NR(4, 5), 'v'}, +}; + +/* + * generate a null-terminated string containing the buttons pressed + * returns number of keys pressed + */ +static int read_keys(char *buf) +{ + int i, numpressed = 0; + for (i = 0; i < ARRAY_SIZE(buttons); i++) { + if (!gpio_get_value(buttons[i].gpnum)) + buf[numpressed++] = buttons[i].ident; + } + buf[numpressed] = '\0'; + return numpressed; +} + +static int do_kbd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + char envvalue[ARRAY_SIZE(buttons)+1]; + int numpressed = read_keys(envvalue); + setenv("keybd", envvalue); + return numpressed == 0; +} + +U_BOOT_CMD( + kbd, 1, 1, do_kbd, + "Tests for keypresses, sets 'keybd' environment variable", + "Returns 0 (true) to shell if key is pressed." +); + +#ifdef CONFIG_PREBOOT +static char const kbd_magic_prefix[] = "key_magic"; +static char const kbd_command_prefix[] = "key_cmd"; + +static void preboot_keys(void) +{ + int numpressed; + char keypress[ARRAY_SIZE(buttons)+1]; + numpressed = read_keys(keypress); + if (numpressed) { + char *kbd_magic_keys = getenv("magic_keys"); + char *suffix; + /* + * loop over all magic keys + */ + for (suffix = kbd_magic_keys; *suffix; ++suffix) { + char *keys; + char magic[sizeof(kbd_magic_prefix) + 1]; + sprintf(magic, "%s%c", kbd_magic_prefix, *suffix); + keys = getenv(magic); + if (keys) { + if (!strcmp(keys, keypress)) + break; + } + } + if (*suffix) { + char cmd_name[sizeof(kbd_command_prefix) + 1]; + char *cmd; + sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix); + cmd = getenv(cmd_name); + if (cmd) { + setenv("preboot", cmd); + return; + } + } + } +} +#endif + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int misc_init_r(void) +{ +#ifdef CONFIG_PREBOOT + preboot_keys(); +#endif + +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + return 0; +} diff --git a/boards.cfg b/boards.cfg index 7a0b79d..fb3b197 100644 --- a/boards.cfg +++ b/boards.cfg @@ -255,6 +255,12 @@ mx6qsabreauto arm armv7 mx6qsabreauto freesca mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg eco5pk arm armv7 eco5pk 8dtech omap3 +nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 +nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 +nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 +nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 +nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 +nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,SDRAM_MB=1024 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3 diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h new file mode 100644 index 0000000..93e7fe4 --- /dev/null +++ b/include/configs/nitrogen6x.h @@ -0,0 +1,285 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * + * Configuration settings for the Boundary Devices Nitrogen6X + * and Freescale i.MX6Q Sabre Lite boards. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_MACH_TYPE 3769 + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE + +#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8)) +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#endif + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + +/* OCOTP Configs */ +#define CONFIG_CMD_IMXOTP +#ifdef CONFIG_CMD_IMXOTP +#define CONFIG_IMX_OTP +#define IMX_OTP_BASE OCOTP_BASE_ADDR +#define IMX_OTP_ADDR_MAX 0x7F +#define IMX_OTP_DATA_ERROR_VAL 0xBADABADA +#define IMX_OTPWRITE_ENABLED +#endif + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#ifdef CONFIG_MX6Q +#define CONFIG_CMD_SATA +#endif + +/* + * SATA Configs + */ +#ifdef CONFIG_CMD_SATA +#define CONFIG_DWC_AHSATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_DWC_AHSATA_PORT_ID 0 +#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR +#define CONFIG_LBA48 +#define CONFIG_LIBATA +#endif + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 6 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_MXC_USB_PORT 1 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 + +/* Miscellaneous commands */ +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_SETEXPR + +/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_CMD_HDMIDETECT +#define CONFIG_CONSOLE_MUX + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_PREBOOT "" + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#ifdef CONFIG_CMD_SATA +#define CONFIG_DRIVE_SATA "sata " +#else +#define CONFIG_DRIVE_SATA +#endif + +#ifdef CONFIG_CMD_MMC +#define CONFIG_DRIVE_MMC "mmc " +#else +#define CONFIG_DRIVE_MMC +#endif + +#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_SATA CONFIG_DRIVE_MMC + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttymxc1\0" \ + "clearenv=if sf probe || sf probe || sf probe 1 ; then " \ + "sf erase 0xc0000 0x2000 && " \ + "echo restored environment to factory default ; fi\0" \ + "bootcmd=for dtype in " CONFIG_DRIVE_TYPES \ + "; do " \ + "for disk in 0 1 ; do ${dtype} dev ${disk} ;" \ + "for fs in fat ext2 ; do " \ + "${fs}load " \ + "${dtype} ${disk}:1 " \ + "10008000 " \ + "/6x_bootscript" \ + "&& source 10008000 ; " \ + "done ; " \ + "done ; " \ + "done; " \ + "setenv stdout serial,vga ; " \ + "echo ; echo 6x_bootscript not found ; " \ + "echo ; echo serial console at 115200, 8N1 ; echo ; " \ + "echo details at http://boundarydevices.com/6q_bootscript ; " \ + "setenv stdout serial\0" \ + "upgradeu=for dtype in " CONFIG_DRIVE_TYPES \ + "; do " \ + "for disk in 0 1 ; do ${dtype} dev ${disk} ;" \ + "for fs in fat ext2 ; do " \ + "${fs}load ${dtype} ${disk}:1 10008000 " \ + "/6x_upgrade " \ + "&& source 10008000 ; " \ + "done ; " \ + "done ; " \ + "done\0" \ + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10010000 +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +/* #define CONFIG_ENV_IS_IN_MMC */ +#define CONFIG_ENV_IS_IN_SPI_FLASH + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (8 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#define CONFIG_SYS_DCACHE_OFF + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#define CONFIG_CMD_BMP + +#define CONFIG_CMD_TIME +#define CONFIG_SYS_ALT_MEMTEST + +#endif /* __CONFIG_H */
On 11/03/2013 19:44, Eric Nelson wrote:
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com
Best regards, Stefano Babic
Eric Nelson
Stefano Babic
