Pull request for tpm-20012023
Hi Tom,
The following changes since commit 53c47c59e638cc118c272235db516bb541dad0ac:
Merge tag 'dm-pull-18jan23' of https://source.denx.de/u-boot/custodians/u-boot-dm (2023-01-19 09:46:57 -0500)
https://source.denx.de/u-boot/custodians/u-boot-tpm/ tags/tpm-20012023
for you to fetch changes up to eda976d36a37d459da5908fb922173a4bafe8666:
tee: optee: fix uuid comparisons on service discovery (2023-01-20 10:04:56 +0200)
The pipeline https://source.denx.de/u-boot/custodians/u-boot-tpm/-/pipelines/14793 seems fine.
Please pull!
Regards /Ilias
---------------------------------------------------------------- I've added myself as a co-maintainer on the TEE tree and I'll be carrying those patches from now.
There's a size comparison fix when looking TAs (trusted apps) that can be scanned over a pseudo-bus provided by OP-TEE. Up to now we were only comparing the first 4/8 bytes of the UUID.
There's also some additions to the firmware TPM driver which will allow to be automatically scanned if the TA is compiled with that support.
Finally a print when probing for an RNG device provided by OP-TEE is properly adjusted.
---------------------------------------------------------------- Ilias Apalodimas (4): tee: optee: fix a print error on rng probing MAINTAINERS: add a new entry on TEE MAINTAINERS tpm2: ftpm: add the device in the OP-TEE services list tee: optee: fix uuid comparisons on service discovery
MAINTAINERS | 3 +++ drivers/tee/optee/core.c | 4 ++-- drivers/tpm/tpm2_ftpm_tee.c | 3 +++ 3 files changed, 8 insertions(+), 2 deletions(-)
On Fri, Jan 20, 2023 at 11:18:59AM +0200, Ilias Apalodimas wrote:
Hi Tom,
Please pull!
Regards /Ilias
Ilias Apalodimas
