[U-Boot-Users] getting u-boot on the mv64360
Hi all,
I have an MV64360 board (IBM dev brd), that has PIBS on it. What's the best way to use u-boot with it?
I compiled u-boot with powepc-gcc-3.3.4 (compiled via crosstool), but PIBS fails to load the binary (.bin). (In fact, PIBS doesn't recognize any of the binaries).
So what's the recommended way? Should I put u-boot on the flash, overwriting PIBS? And since I don't have a BDI cable, how can I put u-boot on the board?
Too many questions, would be glad if anyone answered them.
Thanks, Amit.
Erase PIBS and install U-Boot instead ;-)
Then find out what PIBS expects.
Yes.
Get a BDI2000; the box also includes the required cable.
Hi Wolfgang,
heh, I would, if I had an exit-route in case u-boot didn't work for some reason (linker script fsck-up, etc.)
Yes, but even putting the modified PIBS on the board is scary... w/o a BDI. The docs say it supports .bin files, but the sources don't. It says it supports ELF, but hangs on some relocation. No idea where it dies.. it just stalls.
Yes.
Yup; I hope the "higher levels" clear it soon enough ;-)
Thanks, Amit.
Amit Shah
