[U-Boot] Pull request: u-boot-usb (next)
The following changes since commit 48716e55b684927f5b33b2f9ac890e35309a1de4: Stefan Roese (1): mpc512x: Use serial_setbrg() in serial_init() to not duplicate the code
git://git.denx.de/u-boot-usb.git next
Remy Bohmer (2): Integrate USB gadget layer and USB CDC driver layer Connect the AT91 UDC to USB CDC-ethernet support
Vivek Mahajan (6): mpc8xxx: USB: Removed reenablement of its interface mpc8xxx: USB: Relocates ehci-fsl.h to include/usb mpc83xx: USB: Reorganized its support mpc85xx: USB: Add support mpc83xx: 8315erdb: Add USB related CONFIGs mpc85xx: 8536ds: Add USB related CONFIGs
cpu/mpc83xx/cpu_init.c | 19 +- drivers/usb/gadget/Makefile | 4 + drivers/usb/gadget/at91_udc.c | 1531 ++++++++++++++++++++++++++ drivers/usb/gadget/config.c | 119 ++ drivers/usb/gadget/epautoconf.c | 306 ++++++ drivers/usb/gadget/ether.c | 1897 +++++++++++++++++++++++++++++++++ drivers/usb/gadget/gadget_chips.h | 219 ++++ drivers/usb/gadget/usbstring.c | 165 +++ drivers/usb/host/ehci-fsl.c | 57 +- drivers/usb/host/ehci-fsl.h | 86 -- include/asm-arm/arch-at91/at91_dbgu.h | 69 ++ include/asm-arm/arch-at91/cpu.h | 99 ++ include/asm-arm/assembler.h | 97 ++ include/asm-arm/linkage.h | 11 + include/asm-arm/unaligned.h | 183 ++++ include/asm-ppc/immap_83xx.h | 5 +- include/asm-ppc/immap_85xx.h | 5 +- include/configs/MPC8315ERDB.h | 11 +- include/configs/MPC8536DS.h | 14 +- include/linux/usb/cdc.h | 224 ++++ include/linux/usb/ch9.h | 587 ++++++++++ include/linux/usb/gadget.h | 871 +++++++++++++++ include/net.h | 17 +- include/usb/at91_udc.h | 224 ++++ include/usb/ehci-fsl.h | 149 +++ lib_arm/Makefile | 2 + lib_arm/_io-readsb.S | 128 +++ lib_arm/_io-writesb.S | 99 ++ 28 files changed, 7065 insertions(+), 133 deletions(-) create mode 100644 drivers/usb/gadget/at91_udc.c create mode 100644 drivers/usb/gadget/config.c create mode 100644 drivers/usb/gadget/epautoconf.c create mode 100644 drivers/usb/gadget/ether.c create mode 100644 drivers/usb/gadget/gadget_chips.h create mode 100644 drivers/usb/gadget/usbstring.c delete mode 100644 drivers/usb/host/ehci-fsl.h create mode 100644 include/asm-arm/arch-at91/at91_dbgu.h create mode 100644 include/asm-arm/arch-at91/cpu.h create mode 100644 include/asm-arm/assembler.h create mode 100644 include/asm-arm/linkage.h create mode 100644 include/asm-arm/unaligned.h create mode 100644 include/linux/usb/cdc.h create mode 100644 include/linux/usb/ch9.h create mode 100644 include/linux/usb/gadget.h create mode 100644 include/usb/at91_udc.h create mode 100644 include/usb/ehci-fsl.h create mode 100644 lib_arm/_io-readsb.S create mode 100644 lib_arm/_io-writesb.S
Dear Remy Bohmer,
In message 3efb10970906081215v5f3e9f25g5ab1c3c28ec1af7f@mail.gmail.com you wrote:
Applied, thanks.
Remy Bohmer
