[U-Boot] [PULL] u-boot-atmel/master -> u-boot-arm/master
Dear Albert Aribaud,
please pull the following changes into u-boot-arm/master.
The following changes since commit 9170818a4e004af7893fa0113f6e5b4afafded55:
kconfiglib: change SPDX-License-Identifier to ISC (2014-09-17 21:03:18 -0400)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 015b18c642d9b0f92d1b35f6d6ed73a6a0b29675:
ARM: at91sam9rlek: convert to generic board support (2014-09-19 00:11:24 +0200)
---------------------------------------------------------------- Bo Shen (7): ARM: atmel: sama5d3xek: add nor flash init function ARM: atmel: sama5d3xek: enable NOR flash support ARM: atmel: sama5d3: add timings register ARM: atmel: use pcr to enable or disable peripheral clock ARM: atmel: add pcr related definition USB: ohci-at91: use pcr to enable or disable clock USB: ehci-atmel: use pcr to enable or disable clock
Boris BREZILLON (1): mtd: atmel_nand: Disable subpage NAND write when using Atmel PMECC
Wu, Josh (3): mtd: atmel-nand: use pmecc_readl(b)/pmecc_writel to access the pmecc register ARM: at91sam9n12ek: convert to generic board support ARM: at91sam9rlek: convert to generic board support
arch/arm/cpu/armv7/at91/clock.c | 24 +++++++++-- arch/arm/include/asm/arch-at91/at91_pmc.h | 6 ++- arch/arm/include/asm/arch-at91/clk.h | 1 + arch/arm/include/asm/arch-at91/sama5d3.h | 1 + arch/arm/include/asm/arch-at91/sama5d3_smc.h | 3 +- board/atmel/sama5d3xek/sama5d3xek.c | 58 ++++++++++++++++++++++++++ drivers/mtd/nand/atmel_nand.c | 22 +++++----- drivers/mtd/nand/atmel_nand_ecc.h | 3 ++ drivers/usb/host/ehci-atmel.c | 8 ++++ drivers/usb/host/ohci-at91.c | 8 ++-- include/configs/at91sam9n12ek.h | 1 + include/configs/at91sam9rlek.h | 2 + include/configs/sama5d3xek.h | 13 +++++- 13 files changed, 129 insertions(+), 21 deletions(-)
Hi Andreas,
On Fri, 19 Sep 2014 08:32:28 +0200, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks!
(7 boards fail to build after like before this PR, namely openrd_client tricorder_flash tricorder cm_fx6 openrd_ultimate trimslice openrd_base, all of which are accounted for)
Amicalement,
Albert ARIBAUD
Andreas Bießmann
