[U-Boot] DT overlay issues - dtc flags
I've tried to play around with Device Tree overlays (.dtbo files):
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu...
First of all, that document refers to a non-existing Documentation/devicetree/dt-object-internal.txt. Could someone please fix that one way or another?
In my particular example I've tried to extend the &i2c1 and &gpio nodes of 4.11-rc5 arm64 broadcom/bcm2837-rpi-3-b.dts. The above documentation prominently claims that this can be done via target = <&foo> syntax, but U-Boot's fdt apply command fails for such a file. If instead I use the alternative target-path = "/soc/..." then it works just fine.
As mentioned in the very bottom of the documentation, resolution of phandle target references requires a __symbols__ node in the base .dtb. IIUC this is only generated when passing the -@ dtc command line flag.
At first I thought this were an issue with how we build the .dtb files in openSUSE [1], but by my reading of the kernel Makefiles not passing -@ in DTC_FLAGS or cmd_dtc, you should run into the exact same issue.
I could think of a few ARMv7-M systems where such DT bloat might be undesired (small flash sector sizes), but then it would seem easier to suppress -@ where needed than to have a feature that by all practical means is half unusable by default.
U-Boot itself appears to face a similar issue in that its internal Device Trees are built without -@, and via Alex' distro boot extensions this internal DT is passed on via UEFI as fallback when no external .dtb file is found. So in the non-SPL case the DT should probably be built with -@, too.
Or am I misunderstanding something here?
Thanks, Andreas
[1] https://build.opensuse.org/package/view_file/Kernel:HEAD/dtb-aarch64/dtb-aar...
adding cc to myself so I will see replies.
Thanks, Andreas
I will.
The "target = <&foo>" syntax is the internal dtb syntax that the kernel expects. The plan is to hide this internal format so it is not visble at the source level, but that will require some more changes to the dtc compiler.
Yes, the kernel support for overlays is not complete. This is one of the issues that has not been addressed yet.
I don't have the rpi-3 documentation handy, so I'm going to take a wild guess that the &i2c1 and &gpio node changes that you need are for hardware on a hat. If so, the plan for the kernel is to describe the signals available via the hat connectors in the device tree and then make those signals available through the connector node instead of having the hat overlay directly reference the signal node. The connector abstraction has been discussed but is not implemented.
Thanks, Andreas
Andreas Färber
Frank Rowand
