[PATCH v2] efi_loader: Fix memory corruption on 32bit systems
The issue is this line:
new_efi = efi_prepare_aligned_image(efi, (u64 *)&efi_size);
The efi_size variable is type size_t and on a 32 bit system that's 32 bits. The u64 type is obviously 64 bits. So we write 8 bytes to a 4 byte buffer which corrupts memory.
Fix this by changing the type of efi_prepare_aligned_image() to a size_t pointer.
Signed-off-by: Dan Carpenter dan.carpenter@linaro.org --- v2: Change efi_prepare_aligned_image() instead of changing efi_image_authenticate(). This is a cleaner way to fix the problem.
include/efi_loader.h | 2 +- lib/efi_loader/efi_image_loader.c | 4 ++-- lib/efi_loader/efi_tcg2.c | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index b5fa0fe01ded..9c1a9ed16af6 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -1022,7 +1022,7 @@ bool efi_secure_boot_enabled(void);
bool efi_capsule_auth_enabled(void);
-void *efi_prepare_aligned_image(void *efi, u64 *efi_size); +void *efi_prepare_aligned_image(void *efi, size_t *efi_size);
bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, WIN_CERTIFICATE **auth, size_t *auth_len); diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 26df0da16c93..64980008403b 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -313,7 +313,7 @@ static int cmp_pe_section(const void *arg1, const void *arg2) * * Return: valid pointer to a image, return NULL if allocation fails. */ -void *efi_prepare_aligned_image(void *efi, u64 *efi_size) +void *efi_prepare_aligned_image(void *efi, size_t *efi_size) { size_t new_efi_size; void *new_efi; @@ -600,7 +600,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) if (!efi_secure_boot_enabled()) return true;
- new_efi = efi_prepare_aligned_image(efi, (u64 *)&efi_size); + new_efi = efi_prepare_aligned_image(efi, &efi_size); if (!new_efi) return false;
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 49f8a5e77cbf..d57afd0c498b 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -882,7 +882,7 @@ out: * * Return: status code */ -static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, +static efi_status_t tcg2_hash_pe_image(void *efi, size_t efi_size, struct tpml_digest_values *digest_list) { WIN_CERTIFICATE *wincerts = NULL;
Hi Dan,
- Return: valid pointer to a image, return NULL if allocation fails.
- new_efi = efi_prepare_aligned_image(efi, &efi_size); if (!new_efi) return false;
- Return: status code
Unfortunately the rabbit hole is a bit deeper with this one. tcg2_hash_pe_image() is called in - tcg2_measure_pe_image(). This one is called in efi_load_pe() and the type is indeed a size_t there, so that's fine - efi_tcg2_hash_log_extend_event(), this one is different... The function is described by the EFI spec [0] which mandates a u64... I think that was the reason efi_prepare_aligned_image() is using a u64 to begin with. This one uses the size only though not the pointer, but in a 32bit platform it would truncate s size > UINT_MAX.
[0] https://trustedcomputinggroup.org/wp-content/uploads/EFI-Protocol-Specificat...
Regards /Ilias
{ WIN_CERTIFICATE *wincerts = NULL; -- 2.39.2
On Thu, Jul 27, 2023 at 11:22:15AM +0300, Ilias Apalodimas wrote:
Hi Dan,
I have maybe misread something... I don't think this is a real issue. 32bit systems aren't going to be able to allocate that much memory anyway. Also there are a lot of size_t parameters already so it's not a new issue.
regards, dan carpenter
Hi Dan,
We should really use ulong for addresses and malloc() sizes.
Am 28. Juli 2023 03:51:55 MESZ schrieb Simon Glass sjg@google.com:
Hi Dan,
Please, do not abuse long.
According to the C specification the size of long is independent of the size of pointers.
Addresses should be pointers and sizes should be size_t.
Best regards
Heinrich
Dan Carpenter
Ilias Apalodimas
