Hi, I'm working on a var-som-mx6 board with an original kernel version 3.0.35 that I have updated to a 3.14.28 version builded with Yocto Dizzy. It seems all ok but, sometimes, after software or hardware reboot the system hangs on u-boot. It seems some issue with environment variables cause, when loading reaches u-boot prompt, sometimes it hangs after executing "printenv" or some other command.
Before that problem I have seen messages like these: "*** Warning - bad CRC, using default environment" or "## Warning: Unknown environment variable access method '@'". What could these mean? What could be the problem?
All those problems don't appear if I turn-off and turn-on the board by main switch, In these cases it always load successfully and I can access without any problem to u-boot environment variables.
thank you again for the attention best regards Andrea
Software Department software@teseo.com
------------------------------------------------------------------------------------------------------------- TESEO spa via Agnelli, 49 63023 FERMO (FM) ITALY Tel. +39 0734 628818 -- Fax. +39 0734 628816
Disclaimer: This electronic mail transmission may contain legally privileged and/or confidential information. Do not read this if you are not the person(s) named. Any use, distribution, copying or disclosure by any other person is strictly prohibited. If you receive this transmission by mistake destroy the original transmission and its attachments without reading or saving in any manner.
Andrea Di Chiara
