[U-Boot] more "#if 0" pedantry related to moving macros in header files
my apologies for yet more pedantic nitpickery, this time related to how to properly move/locate macro definitions in header files. i notice this bit in include/mpc8xx.h (note the two tests of "#if 0"):
/*----------------------------------------------------------------------- * TBSCR - Time Base Status and Control Register 11-26 */ #define TBSCR_TBIRQ7 0x8000 /* Time Base Interrupt Request 7 */ #define TBSCR_TBIRQ6 0x4000 /* Time Base Interrupt Request 6 */ #define TBSCR_TBIRQ5 0x2000 /* Time Base Interrupt Request 5 */ #define TBSCR_TBIRQ4 0x1000 /* Time Base Interrupt Request 4 */ #define TBSCR_TBIRQ3 0x0800 /* Time Base Interrupt Request 3 */ #define TBSCR_TBIRQ2 0x0400 /* Time Base Interrupt Request 2 */ #define TBSCR_TBIRQ1 0x0200 /* Time Base Interrupt Request 1 */ #define TBSCR_TBIRQ0 0x0100 /* Time Base Interrupt Request 0 */ #if 0 /* already in asm/8xx_immap.h */ #define TBSCR_REFA 0x0080 /* Reference Interrupt Status A */ #define TBSCR_REFB 0x0040 /* Reference Interrupt Status B */ #define TBSCR_REFAE 0x0008 /* Second Interrupt Enable A */ #define TBSCR_REFBE 0x0004 /* Second Interrupt Enable B */ #define TBSCR_TBF 0x0002 /* Time Base Freeze */ #define TBSCR_TBE 0x0001 /* Time Base Enable */ #endif
/*----------------------------------------------------------------------- * PISCR - Periodic Interrupt Status and Control Register 11-31 */ #undef PISCR_PIRQ /* TBD */ #define PISCR_PITF 0x0002 /* Periodic Interrupt Timer Freeze */ #if 0 /* already in asm/8xx_immap.h */ #define PISCR_PS 0x0080 /* Periodic interrupt Status */ #define PISCR_PIE 0x0004 /* Periodic Interrupt Enable */ #define PISCR_PTE 0x0001 /* Periodic Timer Enable */ #endif
sure enough, the parts that are "if 0"ed out are indeed in arch/powerpc/include/asm/8xx_immap.h:
#define TBSCR_TBIRQ_MASK ((ushort)0xff00) #define TBSCR_REFA ((ushort)0x0080) #define TBSCR_REFB ((ushort)0x0040) #define TBSCR_REFAE ((ushort)0x0008) #define TBSCR_REFBE ((ushort)0x0004) #define TBSCR_TBF ((ushort)0x0002) #define TBSCR_TBE ((ushort)0x0001)
... snip ...
#define PISCR_PIRQ_MASK ((ushort)0xff00) #define PISCR_PS ((ushort)0x0080) #define PISCR_PIE ((ushort)0x0004) #define PISCR_PTF ((ushort)0x0002) #define PISCR_PTE ((ushort)0x0001)
but this brings up the question, where should content like that properly be defined? it seems awkward to break the bit flag definitions for a single register over two header files (especially when they're not defined syntactically identically). is there a historical reason that that content is split over two header files?
oh, and about the above, there is only one reference in the entire tree to PISCR_PIRQ (where it's being undef'ed):
include/mpc8xx.h:#undef PISCR_PIRQ /* TBD */
so i'm guessing that's superfluous (perhaps the old form for defining PISCR_PIRQ_MASK?). i'd submit a patch to get rid of it, but i'll hold off if i can do a larger cleanup that covers that as well in one shot.
thoughts?
rday
p.s. hang on ... this bit in arch/powerpc/include/asm/8xx_immap.h:
#define RTCSC_RTCIRQ_MASK ((ushort)0xff00) #define RTCSC_SEC ((ushort)0x0080) #define RTCSC_ALR ((ushort)0x0040) #define RTCSC_38K ((ushort)0x0010) #define RTCSC_SIE ((ushort)0x0008) #define RTCSC_ALE ((ushort)0x0004) #define RTCSC_RTF ((ushort)0x0002) #define RTCSC_RTE ((ushort)0x0001)
i just noticed that none of the *_MASK macros are referenced anywhere in the entire source tree:
$ grep -r TBSCR_TBIRQ_MASK * arch/powerpc/include/asm/8xx_immap.h:#define TBSCR_TBIRQ_MASK ((ushort)0xff00) $ grep -r RTCSC_RTCIRQ_MASK * arch/powerpc/include/asm/8xx_immap.h:#define RTCSC_RTCIRQ_MASK ((ushort)0xff00) $ grep -r PISCR_PIRQ_MASK * arch/powerpc/include/asm/8xx_immap.h:#define PISCR_PIRQ_MASK ((ushort)0xff00) arch/powerpc/include/asm/immap_8260.h:#define PISCR_PIRQ_MASK ((ushort)0xff00) $
so what are they used for?
Dear "Robert P. J. Day",
In message alpine.LFD.2.20.1607170619400.5907@localhost.localdomain you wrote:
Yes, there is. MPC8xx was the very first processor PPCBoot was developed on, and code cam from several incompatible sources. As usual, there was never enough time for a real cleanup.
thoughts?
I doubt if this is really worth the efforts. MPC8xx is a dead horse, and has been so for a decade [which does not mean that there are not any products using it; even new ones...]. I guess MPC8xx will be removed in a not to far future...
For completeness. Many chip vendors tend to creatye huge (tens of thousands of lines) header files for their chips to give names to each and every possible bit and mask combination. In the end, only a tiny percentage of this will be used. We never tried to clean up such files to include only used defines [which is probably a bad idea anyway, as the next driver might need just the defines you remove now.]
Robert P. J. Day
