[U-Boot] [U-Boot, v2, 07/14] clk: rockchip: Add rk3399 SARADC clock support
Spam detection software, running on the system "lists.denx.de", has identified this incoming email as possible spam. The original message has been attached to this so you can view it or label similar future email. If you have any questions, see @@CONTACT_ADDRESS@@ for details.
Content preview: The clk_saradc is dividing from the 24M, clk_saradc=24MHz/(saradc_div_con+1). SARADC integer divider control register is 8-bits width. Signed-off-by: David Wu david.wu@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com --- [...]
Content analysis details: (6.9 points, 5.0 required)
pts rule name description ---- ---------------------- -------------------------------------------------- 0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 1.2 RCVD_IN_BL_SPAMCOP_NET RBL: Received via a relay in bl.spamcop.net [Blocked - see http://www.spamcop.net/bl.shtml?58.22.7.114] 2.7 RCVD_IN_PSBL RBL: Received via a relay in PSBL [211.157.147.135 listed in psbl.surriel.com] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.135 listed in bl.mailspike.net] 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted
David Wu
