Re: [U-Boot] Uboot send pull request
Do any of your above patches get v2 posted? At least I did not see any follow-up response [1] regarding to "riscv: ax25-ae350: Pass dtb address to u-boot with a1 register"
First of all you told me about that board_fdt_blob_setup() should be completely removed. Instead the simple fix should be add CONFIG_OF_PRIOR_STAGE to ax25-ae350_defconfig.
Then I explain you about that is for booting from flash. And you said In this case, we need support OF_CONTROL like other arch, eg: CONFIG_OF_EMBED and CONFIG_OF_SEPARATE.
In README, I don't find the limitation about when booting from flash, it can not use CONFIG_OF_BOARD.
That is why ax25-ae350 use CONFIG_OF_BOARD to support boot from RAM and ROM. It is a flexible approach to meet Andes' HW mechanism.
I think it is a configuration in ax25-ae350_defconfig. It will not affect qemu-riscv32(64)_defconfig.
That is why I do not prepare v2 to modify it as CONFIG_OF_EMBED or CONFIG_OF_SEPARATE as your willingness.
B.R Rick
[snip]
[1] https://lists.denx.de/pipermail/u-boot/2018-October/345903.html
Regards, Bin
Hi Rick,
Correct. However, when ax25-ae350's U-Boot boots from ROM, where does prior_stage_fdt_address get assigned to the ROM address? Besides, this variable is declared in fdtdec.h as follows:
#if CONFIG_IS_ENABLED(OF_PRIOR_STAGE) extern phys_addr_t prior_stage_fdt_address; #endif
It means only OF_PRIOR_STAGE will use this variable. But in your patch this was borrowed to support OF_BOARD, which is confusing I think. If U-Boot boots from reset vector, the canonical way to support DT is via CONFIG_OF_EMBED or CONFIG_OF_SEPARATE.
I understand it does not affect qemu riscv board. The thing is that I wasn't clear why you did that way for ax25-ae350.
Regards, Bin
Bin Meng bmeng.cn@gmail.com 於 2018年11月21日 週三 下午3:18寫道:
Hi Rick,
I have seen that declaration in fdtdec.h But I was referred to include\configs\bcmstb.h extern phys_addr_t prior_stage_fdt_address; and that is why I borrow prior_stage_fdt_address.
You do not point out this consideration directly, maybe that is why we have some thinking is different.
Actually I just want to remove the redundant code in start.S - li t0, CONFIG_SYS_SDRAM_BASE - SREG a2, 0(t0) so borrowed prior_stage_fdt_address in CONFIG_OF_BOARD
Rick
Regards, Bin
Rick Chen rickchen36@gmail.com 於 2018年11月21日 週三 下午4:53寫道:
Hi Rick,
SREG a2, 0(t0)
Maybe I can keep CONFIG_SYS_SDRAM_BASE and modify it as below li t0, CONFIG_SYS_SDRAM_BASE SREG a1, 0(t0)
But it is a little weird here.
Rick
Regards, Bin
Hi Rick,
Hi Rick,
It looks to me that bcmstb.h was an ad-hoc hack of using prior_stage_fdt_address. I don't think it was originally meant to do such. It intends to work with OF_PRIOR_STAGE only.
Sorry I wasn't that clear, as I was expecting we continue discussing on that patch thread.
SREG a2, 0(t0)
Regards, Bin
Bin Meng bmeng.cn@gmail.com 於 2018年11月27日 週二 下午5:54寫道:
Hi Rick,
Hi Rick,
I just refer to bcmstb.c phys_addr_t prior_stage_fdt_address BCMSTB_DATA_SECTION; bcmstb.h extern phys_addr_t prior_stage_fdt_address;
That is why I borrow and recycle to use it.
Yes. I have reply some of your questions in another email. Maybe we can move there and discuss further more. :)
Re: [PATCH v5 4/4] riscv: Remove redundant a2 store on DRAM base in start.S https://www.mail-archive.com/u-boot@lists.denx.de/msg307101.html
B.R Rick
SREG a2, 0(t0)
Regards, Bin
Bin Meng
Rick Chen
