[PATCH] arm: mach-k3: am642: Provide a way to obtain boot device for non SPLs
Let's provide get_boot_device() for AM64, similar to what we did in commit 2f9095e2bf59 ("arm: mach-k3: am625: Provide a way to obtain boot device for non SPLs") for AM62.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am642_init.c | 92 +--------------------------- arch/arm/mach-k3/am64x/Makefile | 2 + arch/arm/mach-k3/am64x/boot.c | 105 ++++++++++++++++++++++++++++++++ 4 files changed, 109 insertions(+), 91 deletions(-) create mode 100644 arch/arm/mach-k3/am64x/Makefile create mode 100644 arch/arm/mach-k3/am64x/boot.c
diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 1bd523329a4..3101f57d324 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -26,3 +26,4 @@ obj-$(CONFIG_SOC_K3_AM62P5) += am62p5_init.o endif obj-y += common.o security.o obj-$(CONFIG_SOC_K3_AM625) += am62x/ +obj-$(CONFIG_SOC_K3_AM642) += am64x/ diff --git a/arch/arm/mach-k3/am642_init.c b/arch/arm/mach-k3/am642_init.c index ddf47ef0a9b..feadad8c5a8 100644 --- a/arch/arm/mach-k3/am642_init.c +++ b/arch/arm/mach-k3/am642_init.c @@ -285,97 +285,7 @@ u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) } }
-static u32 __get_backup_bootmedia(u32 main_devstat) -{ - u32 bkup_bootmode = - (main_devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> - MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; - u32 bkup_bootmode_cfg = - (main_devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> - MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; - - switch (bkup_bootmode) { - case BACKUP_BOOT_DEVICE_UART: - return BOOT_DEVICE_UART; - - case BACKUP_BOOT_DEVICE_DFU: - if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) - return BOOT_DEVICE_USB; - return BOOT_DEVICE_DFU; - - - case BACKUP_BOOT_DEVICE_ETHERNET: - return BOOT_DEVICE_ETHERNET; - - case BACKUP_BOOT_DEVICE_MMC: - if (bkup_bootmode_cfg) - return BOOT_DEVICE_MMC2; - return BOOT_DEVICE_MMC1; - - case BACKUP_BOOT_DEVICE_SPI: - return BOOT_DEVICE_SPI; - - case BACKUP_BOOT_DEVICE_I2C: - return BOOT_DEVICE_I2C; - }; - - return BOOT_DEVICE_RAM; -} - -static u32 __get_primary_bootmedia(u32 main_devstat) -{ - u32 bootmode = (main_devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> - MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; - u32 bootmode_cfg = - (main_devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> - MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; - - switch (bootmode) { - case BOOT_DEVICE_OSPI: - fallthrough; - case BOOT_DEVICE_QSPI: - fallthrough; - case BOOT_DEVICE_XSPI: - fallthrough; - case BOOT_DEVICE_SPI: - return BOOT_DEVICE_SPI; - - case BOOT_DEVICE_ETHERNET_RGMII: - fallthrough; - case BOOT_DEVICE_ETHERNET_RMII: - return BOOT_DEVICE_ETHERNET; - - case BOOT_DEVICE_EMMC: - return BOOT_DEVICE_MMC1; - - case BOOT_DEVICE_NAND: - return BOOT_DEVICE_NAND; - - case BOOT_DEVICE_MMC: - if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> - MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) - return BOOT_DEVICE_MMC2; - return BOOT_DEVICE_MMC1; - - case BOOT_DEVICE_DFU: - if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> - MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) - return BOOT_DEVICE_USB; - return BOOT_DEVICE_DFU; - - case BOOT_DEVICE_NOBOOT: - return BOOT_DEVICE_RAM; - } - - return bootmode; -} - u32 spl_boot_device(void) { - u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); - - if (bootindex == K3_PRIMARY_BOOTMODE) - return __get_primary_bootmedia(devstat); - else - return __get_backup_bootmedia(devstat); + return get_boot_device(); } diff --git a/arch/arm/mach-k3/am64x/Makefile b/arch/arm/mach-k3/am64x/Makefile new file mode 100644 index 00000000000..acf09c3426c --- /dev/null +++ b/arch/arm/mach-k3/am64x/Makefile @@ -0,0 +1,2 @@ +# SPDX-License-Identifier: GPL-2.0+ +obj-y += boot.o diff --git a/arch/arm/mach-k3/am64x/boot.c b/arch/arm/mach-k3/am64x/boot.c new file mode 100644 index 00000000000..ce8ae941be6 --- /dev/null +++ b/arch/arm/mach-k3/am64x/boot.c @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/spl.h> + +static u32 __get_backup_bootmedia(u32 main_devstat) +{ + u32 bkup_bootmode = + (main_devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; + u32 bkup_bootmode_cfg = + (main_devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; + + switch (bkup_bootmode) { + case BACKUP_BOOT_DEVICE_UART: + return BOOT_DEVICE_UART; + + case BACKUP_BOOT_DEVICE_DFU: + if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + + case BACKUP_BOOT_DEVICE_ETHERNET: + return BOOT_DEVICE_ETHERNET; + + case BACKUP_BOOT_DEVICE_MMC: + if (bkup_bootmode_cfg) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BACKUP_BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BACKUP_BOOT_DEVICE_I2C: + return BOOT_DEVICE_I2C; + }; + + return BOOT_DEVICE_RAM; +} + +static u32 __get_primary_bootmedia(u32 main_devstat) +{ + u32 bootmode = (main_devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; + u32 bootmode_cfg = + (main_devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; + + switch (bootmode) { + case BOOT_DEVICE_OSPI: + fallthrough; + case BOOT_DEVICE_QSPI: + fallthrough; + case BOOT_DEVICE_XSPI: + fallthrough; + case BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BOOT_DEVICE_ETHERNET_RGMII: + fallthrough; + case BOOT_DEVICE_ETHERNET_RMII: + return BOOT_DEVICE_ETHERNET; + + case BOOT_DEVICE_EMMC: + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_NAND: + return BOOT_DEVICE_NAND; + + case BOOT_DEVICE_MMC: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> + MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_DFU: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + + case BOOT_DEVICE_NOBOOT: + return BOOT_DEVICE_RAM; + } + + return bootmode; +} + +u32 get_boot_device(void) +{ + u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); + u32 bootmode = *(u32 *)(CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX); + u32 bootmedia; + + if (bootmode == K3_PRIMARY_BOOTMODE) + bootmedia = __get_primary_bootmedia(devstat); + else + bootmedia = __get_backup_bootmedia(devstat); + + debug("%s: devstat = 0x%x bootmedia = 0x%x bootmode = %d\n", + __func__, devstat, bootmedia, bootmode); + + return bootmedia; +}
Wadim Egorov
