[U-Boot] [PATCH 0/7] fs: fat: convert to kconfig + switch some TI platforms
Here is an attempt to convert FAT filesystem configuraition to kconfig. And switch of some TI platforms to use the newly introduced support.
Tested on OMAP-L138 LCDK board. Build tested using: $ tools/buildman/buildman am33 am43 omap davinci keystone
Sekhar Nori (7): fs: fat: add kbuild configuration support configs: k2*_evm: let each board decide env location configs: k2g_evm: make sure config fallbacks take effect config_fallbacks: add additional fallbacks for fat filesystem configs: am335x: siemens: migrate to enabling FAT FS using kconfig board: ti: enable support for writing to fat partition configs: omapl138_lcdk: enable fat filesystem support
board/ti/common/Kconfig | 1 + configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/thuban_defconfig | 1 + fs/fat/Kconfig | 24 ++++++++++++++++++++++++ include/config_fallbacks.h | 9 ++++++++- include/configs/am43xx_evm.h | 1 - include/configs/k2e_evm.h | 4 ++++ include/configs/k2g_evm.h | 7 ++++--- include/configs/k2hk_evm.h | 4 ++++ include/configs/k2l_evm.h | 4 ++++ include/configs/siemens-am33x-common.h | 1 - include/configs/ti_armv7_common.h | 8 -------- include/configs/ti_armv7_keystone2.h | 3 --- 16 files changed, 54 insertions(+), 17 deletions(-)
Add Kconfig symbols for various configurations supported by FAT filesystem support code.
CONFIG_SUPPORT_VFAT has been left out since its force enabled in include/fat.h and probably should get removed at some point.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- Resend of https://patchwork.ozlabs.org/patch/769770/ with no changes. Now sending again along with a bigger series.
fs/fat/Kconfig | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/fs/fat/Kconfig b/fs/fat/Kconfig index e69de29bb2d1..e7978aae67d2 100644 --- a/fs/fat/Kconfig +++ b/fs/fat/Kconfig @@ -0,0 +1,24 @@ +config FS_FAT + bool "Enable FAT filesystem support" + help + This provides support for reading images from File Allocation Table + (FAT) filesystem. FAT filesystem is a legacy, lightweight filesystem. + It is useful mainly for its wide compatibility with various operating + systems. You can also enable CMD_FAT to get access to fat commands. + +config FAT_WRITE + bool "Enable FAT filesystem write support" + depends on FS_FAT + help + This provides support for creating and writing new files to an + existing FAT filesystem partition. + +config FS_FAT_MAX_CLUSTSIZE + int "Set maximum possible clusersize" + default 65536 + depends on FS_FAT + help + Set the maximum possible clustersize for the FAT filesytem. This + is the smallest amount of disk space that can be used to hold a + file. Unless you have an extremely tight memory memory constraints, + leave the default.
Not all TI Keystone2 EVMs want environment in NAND flash. K2G EVM which has an MMC/SD slot, keep environment in a FAT partition on SD card.
Since ti_armv7_keystone2.h defines environment is in NAND, boards which do not follow that have to #undef'ine that configuration. This leads to ugly ordering issues around where exactly the include of ti_armv7_keystone2.h can come in within the k2*_evm.h files.
Move environment location to config file of each board. This should make it easy to change it for any one board without affecting all other boards.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- include/configs/k2e_evm.h | 4 ++++ include/configs/k2g_evm.h | 2 +- include/configs/k2hk_evm.h | 4 ++++ include/configs/k2l_evm.h | 4 ++++ include/configs/ti_armv7_keystone2.h | 3 --- 5 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 3a7993e8290c..b186bfc89151 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -27,6 +27,10 @@ "name_uboot=u-boot-spi-k2e-evm.gph\0" \ "name_fs=arago-console-image-k2e-evm.cpio.gz\0"
+#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x100000 + #include <configs/ti_armv7_keystone2.h>
/* SPL SPI Loader Configuration */ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index bee1be794baf..9a07eacb8e7a 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -63,8 +63,8 @@ #define CONFIG_PHY_MICREL #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */
-#undef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_IS_IN_FAT +#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 202167bdef79..9598bc6976e9 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -27,6 +27,10 @@ "name_uboot=u-boot-spi-k2hk-evm.gph\0" \ "name_fs=arago-console-image-k2hk-evm.cpio.gz\0"
/* SPL SPI Loader Configuration */ diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index a7ccdd117cd2..d054276e61eb 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -27,6 +27,10 @@ "name_uboot=u-boot-spi-k2l-evm.gph\0" \ "name_fs=arago-console-image-k2l-evm.cpio.gz\0"
/* SPL SPI Loader Configuration */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 3161c50abb14..512c28a5f075 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -185,9 +185,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_NAND_NO_SUBPAGE_WRITE -#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_MTD_PARTITIONS #define CONFIG_RBTREE #define CONFIG_LZO
Since config fallbacks contained in include/config_fallbacks.h come into k2g_evm.h file through ti_armv7_keystone2.h, it should be the last file included.
Without this, #define of FAT_WRITE when environment is in FAT does not happen as the environment location is decided later in the file.
Similar issues can come with other config fallbacks implemented.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- include/configs/k2g_evm.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 9a07eacb8e7a..1cc35769840f 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -48,8 +48,6 @@ "get_pmmc_${boot} run_pmmc get_mon_${boot} run_mon " \ "get_fdt_${boot} get_kern_${boot} run_kern"
-#include <configs/ti_armv7_keystone2.h> - /* SPL SPI Loader Configuration */ #define CONFIG_SPL_TEXT_BASE 0x0c080000
@@ -80,4 +78,7 @@ #endif
#define SPI_MTD_PARTS KEYSTONE_SPI1_MTD_PARTS + +#include <configs/ti_armv7_keystone2.h> + #endif /* __CONFIG_K2G_EVM_H */
Add fallbacks needed to keep all boards building while they are migrated to use Kconfig symbols instead of defines in <board>_config.h files for FAT filesystem.
These should eventually go away once Kconfig select or imply statements are put in place and duplicated defines in <board>_config.h removed.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- include/config_fallbacks.h | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 5a698a8349ab..a4a4d5514070 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -29,10 +29,17 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } #endif
-#if defined(CONFIG_CMD_FAT) && !defined(CONFIG_FS_FAT) +#if (defined(CONFIG_CMD_FAT) || \ + defined(CONFIG_ENV_IS_IN_FAT) || \ + defined(CONFIG_SPL_FAT_SUPPORT)) && \ + !defined(CONFIG_FS_FAT) #define CONFIG_FS_FAT #endif
+#if defined(CONFIG_ENV_IS_IN_FAT) && !defined(CONFIG_FAT_WRITE) +#define CONFIG_FAT_WRITE +#endif + #if (defined(CONFIG_CMD_EXT4) || defined(CONFIG_CMD_EXT2)) && \ !defined(CONFIG_FS_EXT4) #define CONFIG_FS_EXT4
Now that there is Kconfig symbol available for enabling FAT filesystem support, migrate to using it for Siemens AM335x based boards.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/thuban_defconfig | 1 + include/configs/siemens-am33x-common.h | 1 - 5 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 0e50b3109ea2..b6f6a767f62b 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -66,3 +66,4 @@ CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_OMAP_WATCHDOG=y +CONFIG_FS_FAT=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index b6911fd71743..1733a041b2e2 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -66,3 +66,4 @@ CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_OMAP_WATCHDOG=y +CONFIG_FS_FAT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index f77d4d408793..6998fcc32e6b 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -66,3 +66,4 @@ CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_OMAP_WATCHDOG=y +CONFIG_FS_FAT=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 914f70fd6a01..25494778e5a4 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -66,3 +66,4 @@ CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_OMAP_WATCHDOG=y +CONFIG_FS_FAT=y diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 91618676752f..b5705b71693c 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -120,7 +120,6 @@
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#define CONFIG_FS_FAT
#define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
Enable support for writing to FAT partitions on TI's boards.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- board/ti/common/Kconfig | 1 + include/configs/am43xx_evm.h | 1 - include/configs/ti_armv7_common.h | 8 -------- 3 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/board/ti/common/Kconfig b/board/ti/common/Kconfig index 1187cf54337f..0517b1dfdf12 100644 --- a/board/ti/common/Kconfig +++ b/board/ti/common/Kconfig @@ -26,6 +26,7 @@ config TI_COMMON_CMD_OPTIONS imply CMD_EXT4_WRITE imply CMD_FASTBOOT if FASTBOOT imply CMD_FAT + imply FAT_WRITE if CMD_FAT imply CMD_FS_GENERIC imply CMD_GPIO imply CMD_GPT diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 25f63e831142..1d8e39c20352 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -75,7 +75,6 @@ #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" -#define CONFIG_FAT_WRITE
#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 0bd3c9f94cfa..5321ed6b0919 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -145,14 +145,6 @@ #define CONFIG_SUPPORT_RAW_INITRD
/* - * Common filesystems support. When we have removable storage we - * enabled a number of useful commands and support. - */ -#if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_FAT_WRITE -#endif - -/* * Our platforms make use of SPL to initalize the hardware (primarily * memory) enough for full U-Boot to be loaded. We make use of the general * SPL framework found under common/spl/. Given our generally common memory
I included the Kconfig logic here in the first patch in the series, and then migrated it with everything else.
Now that we have ability to enable FAT filesystem support through Kconfig symbols, do it for OMAP-L138 LCDK board.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- configs/omapl138_lcdk_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index ff5e06de299d..13585cff30a4 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -29,4 +29,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y +CONFIG_FS_FAT=y CONFIG_OF_LIBFDT=y
This really should be via CMD_FAT so that the code is used, as we have a symbol for FS_FAT to use it with either of CMD_FAT or ENV_IS_IN_FAT. Thanks!
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
Signed-off-by: Tom Rini trini@konsulko.com --- This replaces the original 5/7 and migrates everything.
README | 20 +------------------- arch/Kconfig | 5 +++-- arch/arm/Kconfig | 13 +++++++++++++ configs/am335x_baltos_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_prompt_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_shc_sdboot_prompt_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_imx6_nospl_com_defconfig | 1 + configs/apalis_imx6_nospl_it_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cairo_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/cl-som-am57x_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/cm_t54_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_imx6_nospl_defconfig | 1 + configs/ds109_defconfig | 2 +- configs/duovero_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/hikey_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 2 +- configs/ls1021aiot_sdcard_defconfig | 2 +- configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/mx7ulp_evk_defconfig | 1 + configs/mx7ulp_evk_plugin_defconfig | 1 + configs/novena_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/pepper_defconfig | 1 + configs/pic32mzdask_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/sama5d2_ptc_nandflash_defconfig | 1 + configs/sama5d2_ptc_spiflash_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + include/configs/apalis-tk1.h | 3 --- include/configs/apalis_imx6.h | 1 - include/configs/apalis_t30.h | 3 --- include/configs/at91-sama5_common.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/bcm23550_w1d.h | 3 --- include/configs/bcm28155_ap.h | 3 --- include/configs/bcm_ep_board.h | 3 --- include/configs/brppt1.h | 1 - include/configs/brxre1.h | 7 ------- include/configs/colibri_imx6.h | 1 - include/configs/colibri_t20.h | 4 ---- include/configs/colibri_t30.h | 3 --- include/configs/devkit8000.h | 1 - include/configs/ds109.h | 1 - include/configs/etamin.h | 2 -- include/configs/exynos-common.h | 3 --- include/configs/hikey.h | 1 - include/configs/ls1021aiot.h | 2 -- include/configs/ls1043ardb.h | 3 --- include/configs/m28evk.h | 2 -- include/configs/m53evk.h | 2 -- include/configs/ma5d4evk.h | 5 ----- include/configs/mx7ulp_evk.h | 3 --- include/configs/novena.h | 1 - include/configs/pic32mzdask.h | 2 -- include/configs/picosam9g45.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 2 -- include/configs/rk3036_common.h | 2 -- include/configs/rk3188_common.h | 2 -- include/configs/rk3288_common.h | 2 -- include/configs/rk3328_common.h | 2 -- include/configs/rk3399_common.h | 2 -- include/configs/rpi.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/sama5d2_ptc.h | 4 ---- include/configs/sama5d3_xplained.h | 4 ---- include/configs/sama5d3xek.h | 4 ---- include/configs/sandbox.h | 2 -- include/configs/siemens-am33x-common.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/socfpga_arria10_socdk.h | 3 +-- include/configs/socfpga_arria5_socdk.h | 2 -- include/configs/socfpga_cyclone5_socdk.h | 2 -- include/configs/socfpga_de0_nano_soc.h | 2 -- include/configs/socfpga_de10_nano.h | 2 -- include/configs/socfpga_de1_soc.h | 2 -- include/configs/socfpga_is1.h | 2 -- include/configs/socfpga_mcvevk.h | 2 -- include/configs/socfpga_sockit.h | 2 -- include/configs/socfpga_socrates.h | 2 -- include/configs/socfpga_sr1500.h | 2 -- include/configs/socfpga_vining_fpga.h | 2 -- include/configs/sunxi-common.h | 2 -- include/configs/tegra-common-post.h | 3 --- include/configs/tegra-common.h | 1 - include/configs/ti816x_evm.h | 2 -- include/configs/ti_armv7_keystone2.h | 1 - include/configs/uniphier.h | 1 - include/configs/xilinx_zynqmp.h | 4 ---- include/configs/zynq-common.h | 1 - include/fat.h | 3 --- scripts/config_whitelist.txt | 3 --- 155 files changed, 103 insertions(+), 166 deletions(-)
diff --git a/README b/README index 77d46d2b42..075d919df3 100644 --- a/README +++ b/README @@ -840,7 +840,6 @@ The following options need to be configured: that work for multiple fs types CONFIG_CMD_FS_UUID * Look up a filesystem UUID CONFIG_CMD_SAVEENV saveenv - CONFIG_CMD_FAT * FAT command support CONFIG_CMD_FLASH flinfo, erase, protect CONFIG_CMD_FPGA FPGA device initialization support CONFIG_CMD_GO * the 'go' command (exec code) @@ -1065,8 +1064,6 @@ The following options need to be configured: - Partition Labels (disklabels) Supported: Zero or more of the following: CONFIG_MAC_PARTITION Apple's MacOS partition table. - CONFIG_DOS_PARTITION MS Dos partition table, traditional on the - Intel architecture, USB sticks, etc. CONFIG_ISO_PARTITION ISO partition table, used on CDROM etc. CONFIG_EFI_PARTITION GPT partition table, common when EFI is the bootloader. Note 2TB partition limit; see @@ -1519,21 +1516,6 @@ The following options need to be configured: CONFIG_SYS_JFFS2_FIRST_BANK, CONFIG_SYS_JFFS2_NUM_BANKS Define these for a default partition on a NOR device
-- FAT(File Allocation Table) filesystem write function support: - CONFIG_FAT_WRITE - - Define this to enable support for saving memory data as a - file in FAT formatted partition. - - This will also enable the command "fatwrite" enabling the - user to write files to FAT. - -- FAT(File Allocation Table) filesystem cluster size: - CONFIG_FS_FAT_MAX_CLUSTSIZE - - Define the max cluster size for fat operations else - a default value of 65536 will be defined. - - Keyboard Support: See Kconfig help for available keyboard drivers.
@@ -3870,7 +3852,7 @@ but it can not erase, write this NOR flash by SRIO or PCIE interface. environment.
- CONFIG_FAT_WRITE: - This should be defined. Otherwise it cannot save the environment file. + This must be enabled. Otherwise it cannot save the environment file.
- CONFIG_ENV_IS_IN_MMC:
diff --git a/arch/Kconfig b/arch/Kconfig index e0e4e8486c..e44767113d 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -70,14 +70,15 @@ config SANDBOX select DM_SPI select DM_GPIO select DM_MMC - imply CRC32_VERIFY imply CMD_GETTIME imply CMD_HASH imply CMD_IO imply CMD_IOTRACE - imply LZMA imply CMD_LZMADEC + imply CRC32_VERIFY + imply FAT_WRITE imply HASH_VERIFY + imply LZMA
config SH bool "SuperH architecture" diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index a8118ce0df..deb7b24682 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -477,6 +477,7 @@ config ARCH_BCM283X select DM_SERIAL select DM_GPIO select OF_CONTROL + imply FAT_WRITE
config TARGET_VEXPRESS_CA15_TC2 bool "Support vexpress_ca15_tc2" @@ -496,17 +497,20 @@ config TARGET_BCM23550_W1D bool "Support bcm23550_w1d" select CPU_V7 imply CRC32_VERIFY + imply FAT_WRITE
config TARGET_BCM28155_AP bool "Support bcm28155_ap" select CPU_V7 imply CRC32_VERIFY + imply FAT_WRITE
config TARGET_BCMCYGNUS bool "Support bcmcygnus" select CPU_V7 imply CRC32_VERIFY imply CMD_HASH + imply FAT_WRITE imply HASH_VERIFY
config TARGET_BCMNSP @@ -530,6 +534,7 @@ config ARCH_EXYNOS select DM_SPI select DM_GPIO select DM_KEYBOARD + imply FAT_WRITE
config ARCH_S5PC1XX bool "Samsung S5PC1XX" @@ -602,6 +607,7 @@ config ARCH_RMOBILE select DM select DM_SERIAL select BOARD_EARLY_INIT_F + imply FAT_WRITE imply SYS_THUMB_BUILD
config TARGET_S32V234EVB @@ -634,6 +640,7 @@ config ARCH_SOCFPGA select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION select SYS_THUMB_BUILD imply CRC32_VERIFY + imply FAT_WRITE
config ARCH_SUNXI bool "Support sunxi (Allwinner) SoCs" @@ -657,6 +664,7 @@ config ARCH_SUNXI select USB_STORAGE if DISTRO_DEFAULTS select USB_KEYBOARD if DISTRO_DEFAULTS select USE_TINY_PRINTF + imply FAT_WRITE imply PRE_CONSOLE_BUFFER imply SPL_GPIO_SUPPORT imply SPL_LIBCOMMON_SUPPORT @@ -700,6 +708,7 @@ config ARCH_ZYNQ select SPL_CLK select CLK_ZYNQ imply CMD_CLK + imply FAT_WRITE
config ARCH_ZYNQMP bool "Support Xilinx ZynqMP Platform" @@ -713,9 +722,11 @@ config ARCH_ZYNQMP select SPL_BOARD_INIT if SPL select SPL_CLK select DM_USB if USB + imply FAT_WRITE
config TEGRA bool "NVIDIA Tegra" + imply FAT_WRITE
config TARGET_VEXPRESS64_AEMV8A bool "Support vexpress_aemv8a" @@ -974,6 +985,7 @@ config ARCH_UNIPHIER select SPL_OF_CONTROL if SPL select SPL_PINCTRL if SPL select SUPPORT_SPL + imply FAT_WRITE help Support for UniPhier SoC family developed by Socionext Inc. (formerly, System LSI Business Division of Panasonic Corporation) @@ -1016,6 +1028,7 @@ config ARCH_ROCKCHIP select DM_USB if USB select DM_PWM select DM_REGULATOR + imply FAT_WRITE
config TARGET_THUNDERX_88XX bool "Support ThunderX 88xx" diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 590673b37c..f210cca87f 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -60,4 +60,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 55ed8f3654..31019e30a0 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -44,4 +44,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index fa468f05e7..651e194ae6 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -49,6 +49,7 @@ CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_FDT_FIXUP_PARTITIONS=y # CONFIG_GENERATE_SMBIOS_TABLE is not set diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 1068678a7c..ab912bbc53 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -39,4 +39,5 @@ CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 85b24a548a..7d75c5cc7a 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -39,4 +39,5 @@ CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 9117407065..322a070dea 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -40,4 +40,5 @@ CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index e71e54b3f5..c5d8dcae87 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -37,4 +37,5 @@ CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index bd66fbc7b1..185258de08 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -39,4 +39,5 @@ CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index bd66fbc7b1..185258de08 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -39,4 +39,5 @@ CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index bae1dfec23..86035d2897 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -37,4 +37,5 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 6a307066eb..20874dd0bc 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -58,4 +58,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 84766e8674..c0d0bcc668 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -55,4 +55,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index a98a97fa42..870ed0fb24 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -72,3 +72,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_FAT_WRITE=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 33e7f91e43..6048e6c911 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -62,4 +62,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index c712cf91df..d171cf0754 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -49,6 +49,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Toradex" CONFIG_G_DNL_VENDOR_NUM=0x1b67 CONFIG_G_DNL_PRODUCT_NUM=0x4000 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set diff --git a/configs/apalis_imx6_nospl_com_defconfig b/configs/apalis_imx6_nospl_com_defconfig index f5f4e3de7f..6611c4306d 100644 --- a/configs/apalis_imx6_nospl_com_defconfig +++ b/configs/apalis_imx6_nospl_com_defconfig @@ -42,5 +42,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Toradex" CONFIG_G_DNL_VENDOR_NUM=0x1b67 CONFIG_G_DNL_PRODUCT_NUM=0x4020 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/apalis_imx6_nospl_it_defconfig b/configs/apalis_imx6_nospl_it_defconfig index 0de47fe360..dba0a7c670 100644 --- a/configs/apalis_imx6_nospl_it_defconfig +++ b/configs/apalis_imx6_nospl_it_defconfig @@ -42,5 +42,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Toradex" CONFIG_G_DNL_VENDOR_NUM=0x1b67 CONFIG_G_DNL_PRODUCT_NUM=0x4020 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 18b6ddf7cf..d8ba087d38 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -49,3 +49,4 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index e7e8a014c6..d13eed0c15 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -48,3 +48,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 9a40c41f36..edf98810bf 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -42,3 +42,4 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index ddeeeefa1e..fbe11ef6cd 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -54,3 +54,4 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 67e18b6268..62e50b63f4 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -19,6 +19,7 @@ CONFIG_HASH_VERIFY=y CONFIG_CMD_FAT=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_SHA1=y CONFIG_SHA256=y CONFIG_OF_LIBFDT=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 7811273e92..d866b6014f 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -63,4 +63,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 1765ec4fa9..ef73fbfde1 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -54,6 +54,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 1bdbf90495..3566223190 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -58,4 +58,5 @@ CONFIG_USB_STORAGE=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_LCD=y CONFIG_OMAP_WATCHDOG=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index ed7432d7f4..f07a46b78f 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -58,4 +58,5 @@ CONFIG_USB_STORAGE=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_LCD=y CONFIG_OMAP_WATCHDOG=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 02b5ff60e2..333e204310 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -66,4 +66,5 @@ CONFIG_USB_STORAGE=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_LCD=y CONFIG_OMAP_WATCHDOG=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 940793b5a6..f558886067 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -57,5 +57,6 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index da28e13d6b..d96a71a828 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -34,4 +34,5 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 2f4c694a0a..579df941d4 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -41,4 +41,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index ef76033779..8485137f1a 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -53,4 +53,5 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index dbb1c3b886..876e3320b7 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -50,4 +50,5 @@ CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index bec96aec98..d813cc54fb 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -68,4 +68,5 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index eef2f89dc3..ec26f999ba 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -43,4 +43,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index fcb7c53797..d8307b0836 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -49,6 +49,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Toradex" CONFIG_G_DNL_VENDOR_NUM=0x1b67 CONFIG_G_DNL_PRODUCT_NUM=0x4000 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set diff --git a/configs/colibri_imx6_nospl_defconfig b/configs/colibri_imx6_nospl_defconfig index fbf9306eeb..df24f17b2d 100644 --- a/configs/colibri_imx6_nospl_defconfig +++ b/configs/colibri_imx6_nospl_defconfig @@ -42,5 +42,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Toradex" CONFIG_G_DNL_VENDOR_NUM=0x1b67 CONFIG_G_DNL_PRODUCT_NUM=0x4000 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 46ac56797f..d8f373b492 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -12,7 +12,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y -CONFIG_DOS_PARTITION=y +CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 9e0ac20985..b945875adf 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -28,4 +28,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 2c6f52494a..d43fd14a8a 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index b112be2ef5..5981d2f530 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -16,3 +16,4 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_K3=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index c81dfdfbdb..6e0a5e9812 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -47,5 +47,6 @@ CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 9098451d84..5908a35629 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -36,5 +36,6 @@ CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 56be1a1b23..53399e7523 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -28,5 +28,6 @@ CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index bc3e5d9091..a884e5a10c 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +# CONFIG_FAT_WRITE is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 3deda487ce..3628367df0 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -4,7 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_GPT=y -CONFIG_DOS_PARTITION=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 089ea34334..e412024349 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -7,7 +7,7 @@ CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_CMD_GPT=y -CONFIG_DOS_PARTITION=y +CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index fbd106ef92..944e39dda1 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -41,4 +41,5 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index a7bf29731e..a33a601236 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -37,4 +37,5 @@ CONFIG_CMD_UBI=y CONFIG_USB=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index a267c9a55f..eca10d3c85 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -40,5 +40,6 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index c457d348d3..6ab7cb77e6 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -7,6 +7,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index c457d348d3..6ab7cb77e6 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -7,6 +7,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 49b963c64f..3c7589bf78 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -39,4 +39,5 @@ CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 64971c139c..eb780ab223 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -42,4 +42,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="TI" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 3be4a1d0b3..e360780d25 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -44,4 +44,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 3aa7ba3f58..d219ad011f 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index c985c86d6d..8c0e830048 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -30,4 +30,5 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 8fdf76076c..3d91f137e8 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -27,4 +27,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 7229142896..dda4030ecc 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -25,4 +25,5 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index bd799b7dc3..f5ac38b47c 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -48,4 +48,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 354438e1ef..cb351e4e67 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -30,4 +30,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y +# CONFIG_FAT_WRITE is not set CONFIG_OF_LIBFDT=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index f278075b44..6b4e229f50 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -57,4 +57,5 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 5fa60b7785..6baca9650b 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -57,4 +57,5 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 6d4d8ada49..8693dea534 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -56,4 +56,5 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index a7d67bf472..4b122d6d8c 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -40,4 +40,5 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 9eb80766ed..688b989419 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -42,5 +42,6 @@ CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_PIC32=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index f34dfe9fdb..aa61e4b65a 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -35,4 +35,5 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 60e0b720bb..1eba299242 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NET=y CONFIG_CMD_NFS=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_CMD_DHCP=y CONFIG_CMD_USB=y CONFIG_USB=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index d6f1840eab..5bd762da79 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NET=y CONFIG_CMD_NFS=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_CMD_DHCP=y CONFIG_CMD_USB=y CONFIG_USB=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index c3e04573b4..8aeab15bfb 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -35,3 +35,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Samsung" CONFIG_G_DNL_VENDOR_NUM=0x04e8 CONFIG_G_DNL_PRODUCT_NUM=0x6601 +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d2_ptc_nandflash_defconfig b/configs/sama5d2_ptc_nandflash_defconfig index 239bfdd66b..66edd31bfe 100644 --- a/configs/sama5d2_ptc_nandflash_defconfig +++ b/configs/sama5d2_ptc_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_FAT=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_USB=y diff --git a/configs/sama5d2_ptc_spiflash_defconfig b/configs/sama5d2_ptc_spiflash_defconfig index 21014b937c..8771e0846c 100644 --- a/configs/sama5d2_ptc_spiflash_defconfig +++ b/configs/sama5d2_ptc_spiflash_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_FAT=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_USB=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index f064a43c6b..b60e00ce5a 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -74,3 +74,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 32a21f9294..8c34e64bc5 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -49,3 +49,4 @@ CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 34c4de17b9..9c72a67572 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -49,3 +49,4 @@ CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 42c31111a1..10db9c96c6 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -49,3 +49,4 @@ CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index d28d1d9a33..533dbcd00d 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -65,3 +65,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 6f2432473d..d00ef6a633 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -62,3 +62,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 994bc048ba..74719854a0 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -74,3 +74,4 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index dd0263cea2..a75767be85 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -69,3 +69,4 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 069fbcc0a3..1d8491cdb7 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -70,3 +70,4 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 4fc44e5747..e23df47ce6 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -68,3 +68,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 204d128395..68da5f9400 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -72,3 +72,4 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_LCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index dc49372e48..148f70360b 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 +# CONFIG_SPL_FAT_SUPPORT is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm011" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 16cd613110..943efdb141 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 +# CONFIG_SPL_FAT_SUPPORT is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 4396db0eb1..5c029109e2 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 +# CONFIG_SPL_FAT_SUPPORT is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm013" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index 2c49729caa..c3cade9ea6 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -50,9 +50,6 @@ #define CONFIG_TFTP_BLOCKSIZE 16352 #define CONFIG_TFTP_TSIZE
-/* Miscellaneous commands */ -#define CONFIG_FAT_WRITE - #undef CONFIG_IPADDR #define CONFIG_IPADDR 192.168.10.2 #define CONFIG_NETMASK 255.255.255.0 diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 83a09153b4..8be586b51f 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -66,7 +66,6 @@
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ #define CONFIG_BOUNCE_BUFFER -#define CONFIG_FAT_WRITE
#ifdef CONFIG_MX6Q #define CONFIG_CMD_SATA diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index cdb50cc28b..9772d8b5c3 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -46,9 +46,6 @@ #define CONFIG_TFTP_BLOCKSIZE 16352 #define CONFIG_TFTP_TSIZE
-/* Miscellaneous commands */ -#define CONFIG_FAT_WRITE - /* Increase console I/O buffer size */ #undef CONFIG_SYS_CBSIZE #define CONFIG_SYS_CBSIZE 1024 diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index dbd4d843eb..dea8130046 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -54,7 +54,6 @@ #else /* u-boot env in sd/mmc card */ #define CONFIG_ENV_IS_IN_FAT -#define CONFIG_FAT_WRITE #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 010ebdbd40..a0c5b9afae 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -115,7 +115,6 @@ #define FAT_ENV_DEVICE_AND_PART "0" #define FAT_ENV_FILE "uboot.env" #define CONFIG_ENV_IS_IN_FAT -#define CONFIG_FAT_WRITE #define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 411d7412af..50ddbd6475 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -160,7 +160,6 @@ #else /* Use file in FAT file to save environment */ #define CONFIG_ENV_IS_IN_FAT -#define CONFIG_FAT_WRITE #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_FILE "uboot.env" #define FAT_ENV_DEVICE_AND_PART "0" diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 7dcf7913de..8a8eb7c34f 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -127,7 +127,6 @@
/* bootstrap + u-boot + env + linux in mmc */ #define CONFIG_ENV_IS_IN_FAT -#define CONFIG_FAT_WRITE #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_FILE "uboot.env" #define FAT_ENV_DEVICE_AND_PART "0" diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 33cc5fc7aa..fd2dbed137 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -147,7 +147,6 @@ #else /* CONFIG_SYS_USE_MMC */ /* bootstrap + u-boot + env + linux in mmc */ #define CONFIG_ENV_IS_IN_FAT -#define CONFIG_FAT_WRITE #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_FILE "uboot.env" #define FAT_ENV_DEVICE_AND_PART "0" diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index 9a36a4c5d7..02ae65ff57 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -109,9 +109,6 @@ /* Initial upstream - boot to cmd prompt only */ #define CONFIG_BOOTCOMMAND ""
-/* Commands */ -#define CONFIG_FAT_WRITE - #undef CONFIG_USB_GADGET_VBUS_DRAW #define CONFIG_USB_GADGET_VBUS_DRAW 0 #define CONFIG_USBID_ADDR 0x34052c46 diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index bb61e5b8c8..5a85f7fa9c 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -108,9 +108,6 @@ /* Initial upstream - boot to cmd prompt only */ #define CONFIG_BOOTCOMMAND ""
-/* Commands */ -#define CONFIG_FAT_WRITE - #define CONFIG_USBID_ADDR 0x34052c46
#endif /* __BCM28155_AP_H */ diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index fa7eff5428..2afbbea140 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -62,9 +62,6 @@
#define CONFIG_MX_CYCLIC
-/* Commands */ -#define CONFIG_FAT_WRITE - /* Enable Time Command */
/* Misc utility code */ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 521d097f8a..10e8f88810 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -276,7 +276,6 @@ MMCARGS * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE #endif /* CONFIG_MMC, ... */ diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 99846890e0..5814d748d9 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -118,12 +118,5 @@ BUR_COMMON_ENV \ #define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT -/* - * Common filesystems support. When we have removable storage we - * enabled a number of useful commands and support. - */ -#if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_FAT_WRITE -#endif /* CONFIG_MMC, ... */
#endif /* __CONFIG_BRXRE1_H__ */ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 8f4022a134..82812e577a 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -64,7 +64,6 @@
/* Network */ #define CONFIG_FEC_MXC diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index 03f6863169..7355f78fcf 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -67,10 +67,6 @@ #define CONFIG_LZO #define CONFIG_RBTREE
-/* Debug commands */ - -/* Miscellaneous commands */ -#define CONFIG_FAT_WRITE
#define BOARD_EXTRA_ENV_SETTINGS \ "mtdparts=" MTDPARTS_DEFAULT "\0" diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 853cd52878..53ff33e4b9 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -44,9 +44,6 @@ #define CONFIG_TFTP_BLOCKSIZE 16352 #define CONFIG_TFTP_TSIZE
-/* Miscellaneous commands */ -#define CONFIG_FAT_WRITE - /* Increase console I/O buffer size */ #undef CONFIG_SYS_CBSIZE #define CONFIG_SYS_CBSIZE 1024 diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index c892b5faa9..92ce1273c6 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -94,7 +94,6 @@ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */
#undef CONFIG_SUPPORT_RAW_INITRD -#undef CONFIG_FAT_WRITE
/* BOOTP/DHCP options */ #define CONFIG_BOOTP_SUBNETMASK diff --git a/include/configs/ds109.h b/include/configs/ds109.h index 4c874367fd..133b2b023c 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -24,7 +24,6 @@ * Commands configuration */ #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
/* * mv-plug-common.h should be defined after CMD configs since it used them diff --git a/include/configs/etamin.h b/include/configs/etamin.h index a0152a4a43..1662dbf197 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -87,8 +87,6 @@ "led4=60,0,1\0" \ "led5=63,0,1\0"
-#undef CONFIG_CMD_FAT - /* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */
diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index ade66a4330..031586b0df 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -41,9 +41,6 @@ /* PWM */ #define CONFIG_PWM
-/* Command definition*/ -#define CONFIG_FAT_WRITE - /* Miscellaneous configurable options */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 1024 /* Print Buffer Size */ diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 0fb6fb3b60..2b4fec4bd4 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -111,7 +111,6 @@ #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "1:1" #define FAT_ENV_FILE "uboot.env" -#define CONFIG_FAT_WRITE #define CONFIG_ENV_VARS_UBOOT_CONFIG
/* Monitor Command Prompt */ diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index d6839c0916..c1ec2d440c 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -158,8 +158,6 @@ #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN)
-#define CONFIG_CMD_FAT - /* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SPI_FLASH_SPANSION diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 2647b150b4..51e7624c63 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -302,9 +302,6 @@ #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI #define CONFIG_CMD_SCSI -#ifndef CONFIG_CMD_FAT -#define CONFIG_CMD_FAT -#endif #ifndef CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT2 #endif diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index c4717238bb..8dea0313a3 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -14,8 +14,6 @@ #define CONFIG_TIMESTAMP /* Print image info with timestamp */
/* U-Boot Commands */ -#define CONFIG_FAT_WRITE - #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index b237cea1da..51812257e1 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -20,8 +20,6 @@ /* * U-Boot Commands */ -#define CONFIG_FAT_WRITE - #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_CMD_SATA diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 6dc1fb047e..bb661400ec 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -15,11 +15,6 @@ #define CONFIG_SYS_USE_SERIALFLASH 1
/* - * U-Boot Commands - */ -#define CONFIG_FAT_WRITE - -/* * Memory configurations */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 37f365dc55..288a8894d1 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -45,9 +45,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_SIZE SZ_8K
-#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION - /* Using ULP WDOG for reset */ #define WDOG_BASE_ADDR WDG1_RBASE
diff --git a/include/configs/novena.h b/include/configs/novena.h index 6cb1807a8e..1f1bf15af7 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -17,7 +17,6 @@ #include "mx6_common.h"
/* U-Boot Commands */ -#define CONFIG_FAT_WRITE #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA
diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index 2dcc6c4539..c5bfdec8fa 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -90,8 +90,6 @@ */ /* FAT FS */ #define CONFIG_SUPPORT_VFAT -#define CONFIG_FS_FAT -#define CONFIG_FAT_WRITE
/* EXT4 FS */ #define CONFIG_FS_EXT4 diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 998a7a344b..c83e559a5a 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -116,7 +116,6 @@ #define FAT_ENV_DEVICE_AND_PART "0" #define FAT_ENV_FILE "uboot.env" #define CONFIG_ENV_IS_IN_FAT -#define CONFIG_FAT_WRITE #define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 3a719c0b37..365950d729 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -14,7 +14,6 @@ #define CONFIG_CMD_SDRAM
/* Support File sytems */ -#define CONFIG_FAT_WRITE #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index e73bc61856..8da3e7a235 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -13,7 +13,6 @@ #include <asm/arch/rmobile.h>
#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE @@ -24,7 +23,6 @@ #define CONFIG_SUPPORT_RAW_INITRD
/* Support File sytems */ -#define CONFIG_FAT_WRITE #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 2893f80c9f..836c5e3fed 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -36,8 +36,6 @@ /* MMC/SD IP block */ #define CONFIG_BOUNCE_BUFFER
-#define CONFIG_FAT_WRITE - #define CONFIG_SYS_SDRAM_BASE 0x60000000 #define CONFIG_NR_DRAM_BANKS 1 #define SDRAM_BANK_SIZE (512UL << 20UL) diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 81a1553390..a1e0eb7c8d 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -61,8 +61,6 @@ /* MMC/SD IP block */ #define CONFIG_BOUNCE_BUFFER
-#define CONFIG_FAT_WRITE - #define CONFIG_SYS_SDRAM_BASE 0x60000000 #define CONFIG_NR_DRAM_BANKS 1 #define SDRAM_BANK_SIZE (2UL << 30) diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 4cf71fa17e..ecf2675255 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -38,8 +38,6 @@ /* MMC/SD IP block */ #define CONFIG_BOUNCE_BUFFER
-#define CONFIG_FAT_WRITE - /* RAW SD card / eMMC locations. */ #define CONFIG_SYS_SPI_U_BOOT_OFFS (128 << 10)
diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index b0dcd48209..7ccbc9b241 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -28,8 +28,6 @@ #define CONFIG_BOUNCE_BUFFER
#define CONFIG_SUPPORT_VFAT -#define CONFIG_FS_FAT -#define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4
/* RAW SD card / eMMC locations. */ diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 49f56f23de..7a8a442336 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -43,8 +43,6 @@ #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000
/* RAW SD card / eMMC locations. */ diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 7b9017ff99..d715eaad14 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -97,7 +97,6 @@ #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" -#define CONFIG_FAT_WRITE #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_SYS_LOAD_ADDR 0x1000000 #define CONFIG_PREBOOT "usb start" diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index e49b3d9580..c328e43dd6 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -210,7 +210,6 @@ #define CONFIG_SYS_ONENAND_BASE 0xB0000000
/* write support for filesystems */ -#define CONFIG_FAT_WRITE #define CONFIG_EXT4_WRITE
/* GPT */ diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 57fa67d234..7607f94640 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -77,10 +77,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2_PTC"
-#if defined(CONFIG_CMD_USB) -#define CONFIG_CMD_FAT -#endif - /* Ethernet Hardware */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 074c7568f0..fbe26cae21 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -74,10 +74,6 @@ #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #endif
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_FAT_WRITE -#endif - #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#if CONFIG_SYS_USE_NANDFLASH diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 9540a4a0ff..891d6a0f79 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -101,10 +101,6 @@ #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 #endif
#ifdef CONFIG_SYS_USE_SERIALFLASH diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index fbbd6cd99b..31ceb5402f 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -29,8 +29,6 @@
-#define CONFIG_FS_FAT -#define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE #define CONFIG_HOST_MAX_DEVICES 4 diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 9161867675..b5705b7169 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -120,7 +120,6 @@
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#define CONFIG_FS_FAT
#define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 99b5b23d29..4e0b9b1252 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -129,7 +129,6 @@ /* Command line configuration */ #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP -#define CONFIG_CMD_FAT #define CONFIG_CMD_USB #define CONFIG_CMD_MII #define CONFIG_CMD_MMC diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h index 7ea780b48b..3b59b6a106 100644 --- a/include/configs/socfpga_arria10_socdk.h +++ b/include/configs/socfpga_arria10_socdk.h @@ -8,8 +8,7 @@ #define __CONFIG_SOCFGPA_ARRIA10_H__
#include <asm/arch/base_addr_a10.h> -/* U-Boot Commands */ -#define CONFIG_FAT_WRITE + #define CONFIG_HW_WATCHDOG
/* Booting Linux */ diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index b60d007478..fe4031910b 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -8,8 +8,6 @@
#include <asm/arch/base_addr_ac5.h>
-/* U-Boot Commands */ -#define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
/* Memory configurations */ diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index dfe4980b85..be56521121 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index dd5933d43c..320c585a39 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_de10_nano.h b/include/configs/socfpga_de10_nano.h index 302ec200bd..ef693b0038 100644 --- a/include/configs/socfpga_de10_nano.h +++ b/include/configs/socfpga_de10_nano.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_de1_soc.h b/include/configs/socfpga_de1_soc.h index 014828bc08..522ac74ffe 100644 --- a/include/configs/socfpga_de1_soc.h +++ b/include/configs/socfpga_de1_soc.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_is1.h b/include/configs/socfpga_is1.h index 3585eeb3c4..68403aa744 100644 --- a/include/configs/socfpga_is1.h +++ b/include/configs/socfpga_is1.h @@ -9,8 +9,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index 2d367026b6..ee85708b7a 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index c9fc5c90d9..c75acc0749 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index 5dc929852b..a08fa9ff4c 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 64e1595cbe..4366061f77 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -8,8 +8,6 @@
-#define CONFIG_FAT_WRITE - #define CONFIG_HW_WATCHDOG
/* Memory configurations */ diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index 251dd0e901..e2bdfb12f9 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -8,8 +8,6 @@
/* Memory configurations */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index f042f0d0c2..9b514ff37a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -180,8 +180,6 @@
#define CONFIG_SYS_MONITOR_LEN (768 << 10) /* 768 KiB */
-#define CONFIG_FAT_WRITE /* enable write access */ - #define CONFIG_SPL_FRAMEWORK
#ifndef CONFIG_ARM64 /* AArch64 FEL support is not ready yet */ diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 1a4a7e2320..c03efd852a 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -118,9 +118,6 @@ #ifdef CONFIG_FS_EXT4 #undef CONFIG_FS_EXT4 #endif -#ifdef CONFIG_FS_FAT -#undef CONFIG_FS_FAT -#endif
/* remove USB */ #ifdef CONFIG_USB_EHCI_TEGRA diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 7ca5c0b9da..723435e0ae 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -99,7 +99,6 @@
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> -#define CONFIG_FAT_WRITE #endif
#endif /* _TEGRA_COMMON_H_ */ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 2303970d88..68eb08f812 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -50,8 +50,6 @@
#define CONFIG_CMD_ASKENV
-#define CONFIG_FS_FAT - /* * Only one of the following two options (DDR3/DDR2) should be enabled * CONFIG_TI816X_EVM_DDR2 diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 77ea9b9fe8..ac8dabd9ca 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -196,7 +196,6 @@ /* USB Configuration */ #define CONFIG_USB_XHCI_KEYSTONE #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_FS_FAT #define CONFIG_USB_SS_BASE KS2_USB_SS_BASE #define CONFIG_USB_HOST_XHCI_BASE KS2_USB_HOST_XHCI_BASE #define CONFIG_DEV_USB_PHY_BASE KS2_DEV_USB_PHY_BASE diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index bc57e8a73a..e45b506eba 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -116,7 +116,6 @@
/* USB */ #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 4 -#define CONFIG_FAT_WRITE
/* SD/MMC */ #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 1b43620540..c56cd8c98b 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -82,10 +82,6 @@ # define FAT_ENV_INTERFACE "mmc" #endif
-#if defined(CONFIG_MMC_SDHCI_ZYNQ) || defined(CONFIG_ZYNQMP_USB) -# define CONFIG_FAT_WRITE -#endif - #ifdef CONFIG_NAND_ARASAN # define CONFIG_CMD_NAND_LOCK_UNLOCK # define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index df4765c076..4b6b088851 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -129,7 +129,6 @@
#if defined(CONFIG_MMC_SDHCI_ZYNQ) || defined(CONFIG_ZYNQ_USB) # define CONFIG_SUPPORT_VFAT -# define CONFIG_FAT_WRITE #endif
#if defined(CONFIG_ZYNQ_I2C0) || defined(CONFIG_ZYNQ_I2C1) diff --git a/include/fat.h b/include/fat.h index e38f3808af..71879f01ca 100644 --- a/include/fat.h +++ b/include/fat.h @@ -18,9 +18,6 @@ #define VFAT_MAXSEQ 9 /* Up to 9 of 13 2-byte UTF-16 entries */ #define PREFETCH_BLOCKS 2
-#ifndef CONFIG_FS_FAT_MAX_CLUSTSIZE -#define CONFIG_FS_FAT_MAX_CLUSTSIZE 65536 -#endif #define MAX_CLUSTSIZE CONFIG_FS_FAT_MAX_CLUSTSIZE
#define DIRENTSPERBLOCK (mydata->sect_size / sizeof(dir_entry)) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index ee95359d79..e9531687f3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -854,7 +854,6 @@ CONFIG_FASTBOOT_FLASH_FILLBUF_SIZE CONFIG_FASTBOOT_FLASH_NAND_DEV CONFIG_FASTBOOT_FLASH_NAND_TRIMFFS CONFIG_FAST_FLASH_BIT -CONFIG_FAT_WRITE CONFIG_FB_ADDR CONFIG_FB_BACKLIGHT CONFIG_FB_DEFERRED_IO @@ -985,8 +984,6 @@ CONFIG_FSMC_NAND_BASE CONFIG_FSMTDBLK CONFIG_FSNOTIFY CONFIG_FS_EXT4 -CONFIG_FS_FAT -CONFIG_FS_FAT_MAX_CLUSTSIZE CONFIG_FS_POSIX_ACL CONFIG_FTAHBC020S CONFIG_FTAHBC020S_BASE
On Sat, Jun 03, 2017 at 06:00:04PM -0400, Tom Rini wrote:
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
Signed-off-by: Tom Rini trini@konsulko.com
Sekhar Nori
