[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Finally, this series adds support for the first ARMv8 SoC from Socionext Inc.
The following changes since commit 65341967ce9ef2656c61dcd3126536e8865c349d:
Merge branch 'master' of git://git.denx.de/u-boot-x86 (2016-04-22 07:25:18 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to b75e072c1c53cade2c3944433d852d7d6046661b:
ARM: uniphier: speed up loading kernel image from NOR device (2016-04-24 09:56:47 +0900)
---------------------------------------------------------------- Masahiro Yamada (13): pinctrl: uniphier: rename function/array names pinctrl: uniphier: fix NAND and SD pin-mux settings for PH1-LD11/LD20 ARM: uniphier: avoid unaligned access to DT on 64bit SoC ARM: dts: uniphier: use Ref Daughter board on PH1-LD20 Ref board ARM: dts: uniphier: move aliases node up to satisfy fdtgrep ARM: uniphier: add sg_set_iectrl_range() ARM: uniphier: carry on booting for Unknown boot mode ARM: uniphier: rework uniphier_set_fdt_file() ARM: uniphier: add PH1-LD20 SoC support ARM: uniphier: reserve the last 64 byte of SDRAM ARM: dts: uniphier: add SD controller node for PH1-LD20 clk: uniphier: add Media I/O clock driver support for PH1-LD20 ARM: uniphier: speed up loading kernel image from NOR device
arch/arm/dts/uniphier-ph1-ld11-ref.dts | 18 +- arch/arm/dts/uniphier-ph1-ld20-ref.dts | 19 +- arch/arm/dts/uniphier-ph1-ld20.dtsi | 17 ++ arch/arm/mach-uniphier/Kconfig | 5 + arch/arm/mach-uniphier/Makefile | 1 + arch/arm/mach-uniphier/arm64/Makefile | 10 + arch/arm/mach-uniphier/arm64/arm-cci500.c | 41 +++ arch/arm/mach-uniphier/arm64/mem_map.c | 28 ++ arch/arm/mach-uniphier/arm64/smp.S | 19 ++ arch/arm/mach-uniphier/arm64/smp_kick_cpus.c | 31 +++ arch/arm/mach-uniphier/arm64/timer.c | 38 +++ arch/arm/mach-uniphier/board_common.c | 6 +- arch/arm/mach-uniphier/board_early_init_f.c | 8 + arch/arm/mach-uniphier/board_late_init.c | 66 ++--- arch/arm/mach-uniphier/boards.c | 25 ++ arch/arm/mach-uniphier/boot-mode/Makefile | 1 + arch/arm/mach-uniphier/boot-mode/boot-device.h | 2 + arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c | 77 ++++++ arch/arm/mach-uniphier/boot-mode/boot-mode.c | 4 + arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c | 5 + arch/arm/mach-uniphier/clk/Makefile | 1 + arch/arm/mach-uniphier/clk/clk-ld20.c | 14 + arch/arm/mach-uniphier/cpu_info.c | 2 +- arch/arm/mach-uniphier/dram/Makefile | 1 + arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h | 41 +++ arch/arm/mach-uniphier/dram/umc-ld20-regs.h | 73 ++++++ arch/arm/mach-uniphier/dram/umc-ld20.c | 306 ++++++++++++++++++++++ arch/arm/mach-uniphier/dram_init.c | 10 +- arch/arm/mach-uniphier/early-clk/Makefile | 1 + arch/arm/mach-uniphier/early-clk/early-clk-ld20.c | 30 +++ arch/arm/mach-uniphier/init.h | 7 + arch/arm/mach-uniphier/init/Makefile | 1 + arch/arm/mach-uniphier/init/init-ld20.c | 53 ++++ arch/arm/mach-uniphier/init/init.c | 5 + arch/arm/mach-uniphier/memconf/Makefile | 1 + arch/arm/mach-uniphier/memconf/memconf-pxs2.c | 3 + arch/arm/mach-uniphier/pinctrl/Makefile | 1 + arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c | 46 ++++ arch/arm/mach-uniphier/sbc/Makefile | 1 + arch/arm/mach-uniphier/sg-regs.h | 11 +- configs/uniphier_ld20_defconfig | 28 ++ drivers/clk/uniphier/clk-uniphier-mio.c | 4 + drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 8 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 34 +-- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 34 +-- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 34 +-- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 34 +-- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 34 +-- drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 34 +-- include/configs/uniphier.h | 52 +++- 50 files changed, 1151 insertions(+), 174 deletions(-) create mode 100644 arch/arm/mach-uniphier/arm64/Makefile create mode 100644 arch/arm/mach-uniphier/arm64/arm-cci500.c create mode 100644 arch/arm/mach-uniphier/arm64/mem_map.c create mode 100644 arch/arm/mach-uniphier/arm64/smp.S create mode 100644 arch/arm/mach-uniphier/arm64/smp_kick_cpus.c create mode 100644 arch/arm/mach-uniphier/arm64/timer.c create mode 100644 arch/arm/mach-uniphier/boot-mode/boot-mode-ld20.c create mode 100644 arch/arm/mach-uniphier/clk/clk-ld20.c create mode 100644 arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h create mode 100644 arch/arm/mach-uniphier/dram/umc-ld20-regs.h create mode 100644 arch/arm/mach-uniphier/dram/umc-ld20.c create mode 100644 arch/arm/mach-uniphier/early-clk/early-clk-ld20.c create mode 100644 arch/arm/mach-uniphier/init/init-ld20.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c create mode 100644 configs/uniphier_ld20_defconfig
On Sun, Apr 24, 2016 at 10:04:05AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
