[PATCH] test/py: mii: Add tests for mii command
Add below test cases for mii commands: mii_info -To display MII PHY info mii_list - To list MII devices mii_set_device - To set MII device mii_read - To reads register from MII PHY address mii_dump - To display data from MII PHY address
Signed-off-by: Love Kumar love.kumar@amd.com --- test/py/tests/test_mii.py | 68 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 68 insertions(+) create mode 100644 test/py/tests/test_mii.py
diff --git a/test/py/tests/test_mii.py b/test/py/tests/test_mii.py new file mode 100644 index 000000000000..b213df3e3f2e --- /dev/null +++ b/test/py/tests/test_mii.py @@ -0,0 +1,68 @@ +# SPDX-License-Identifier: GPL-2.0 +# (C) Copyright 2023, Advanced Micro Devices, Inc. + +import pytest +import re + +""" +Note: This test doesn't rely on boardenv_* configuration value but they can +change test behavior. + +For example: + +# Setup env__mii_deive_test_skip to True if tests with ethernet PHY devices +# should be skipped. For example: Missing PHY device +env__mii_device_test_skip = True + +It also checks for MII PHY device exist or not, it skips the test if PHY device +does not exist. +""" + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_info(u_boot_console): + if u_boot_console.config.env.get("env__mii_device_test_skip", False): + pytest.skip("MII device test is not enabled!") + expected_output = "PHY" + output = u_boot_console.run_command("mii info") + if not re.search(r"PHY (.+?):", output): + pytest.skip("PHY device does not exist!") + assert expected_output in output + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_list(u_boot_console): + if u_boot_console.config.env.get("env__mii_device_test_skip", False): + pytest.skip("MII device test is not enabled!") + expected_output = "Current device" + output = u_boot_console.run_command("mii device") + if not re.search(r"Current device: '(.+?)'", output): + pytest.skip("PHY device does not exist!") + assert expected_output in output + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_set_device(u_boot_console): + test_mii_list(u_boot_console) + output = u_boot_console.run_command("mii device") + eth_num = re.search(r"MII devices: '(.+?)'", output).groups()[0] + u_boot_console.run_command(f"mii device {eth_num}") + output = u_boot_console.run_command("echo $?") + assert output.endswith("0") + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_read(u_boot_console): + test_mii_list(u_boot_console) + output = u_boot_console.run_command("mii info") + eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16)) + u_boot_console.run_command(f"mii read {eth_addr} 0") + output = u_boot_console.run_command("echo $?") + assert output.endswith("0") + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_dump(u_boot_console): + test_mii_list(u_boot_console) + expected_response = "PHY control register" + output = u_boot_console.run_command("mii info") + eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16)) + response = u_boot_console.run_command(f"mii dump {eth_addr} 0") + assert expected_response in response + output = u_boot_console.run_command("echo $?") + assert output.endswith("0")
+For example:
- if u_boot_console.config.env.get("env__mii_device_test_skip", False):
- expected_output = "PHY"
- output = u_boot_console.run_command("mii info")
- if not re.search(r"PHY (.+?):", output):
- assert expected_output in output
- expected_output = "Current device"
- output = u_boot_console.run_command("mii device")
- if not re.search(r"Current device: '(.+?)'", output):
- test_mii_list(u_boot_console)
- eth_num = re.search(r"MII devices: '(.+?)'", output).groups()[0]
- u_boot_console.run_command(f"mii device {eth_num}")
- output = u_boot_console.run_command("echo $?")
OK, so this here breaks the next test for me: => mii device FEC0 => mii info Incorrect PHY address. Range should be 0-31 mii - MII utility commands ...
But doing "mii info 0" next does work. However, what also works if I have not done "mii device FEC0" but just "mii device" then "mii info" works. And if I do "mii info 0" and then "mii info" it also works, because I assume there's some struct member being set somewhere or similar?
So good news / bad news, the test looks good and seems to have found an issue that needs to be resolved. The question is, does this patch work as-is on your platforms? I suspect it does and this is just a problem on the FEC driver as it looked OK on another platform here real quick, and I just want to confirm.
A thing I'm not sure about now is on my j721e_evm_a72: => mii device MII devices: 'mdio@f00' 'ethernet@46000000port@1' Current device: 'mdio@f00' => mii info => => mii device 'ethernet@46000000port@1' => mii info 0 PHY 0x00: OUI = 0x80028, Model = 0x23, Rev = 0x01, 100baseT, FDX
Which I think matches how things are overall on this platform. So, I don't know if it's reasonable to say I should just disable the test here entirely, or if the test should be able to / require device to be set. Especially since I think as-written it's finding a bug in FEC stuff.
Love Kumar
