Please pull u-boot-marvell/master
Hi Tom,
please pull the next batch of Marvell MVEBU updates. It consists this time mostly of fixes and very local enhancements.
Here the summary log:
---------------------------------------------------------------- - MVEBU Espressobin fixes and enhancements (fix switch security issue, enable MVNETA, enable SD-card, fix COMPHY nodes, default env variables, etc) - MMC Xenon: Set signal voltage and max base clock - a37xx PCI driver: Depend on DM_GPIO and remove #ifdef's ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=48&view=resul...
Thanks, Stefan
The following changes since commit 9f04a634ef331b4fc6b3e677f276156192a413c7:
Merge branch '2020-08-27-misc-fixes' (2020-08-28 08:51:37 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 64430efe6960bee0d0a392c0391d815a70a1805d:
arm: mvebu: Espressobin: Update README.marvell file (2020-08-31 14:45:53 +0200)
---------------------------------------------------------------- Evan Wang (1): mmc: xenon: set signal voltage and max base clock
Marek Behún (1): arm64: dts: armada-3720-espressobin: fix COMPHY nodes
Pali Rohár (11): arm: mvebu: Espressobin: Disallow forwarding packets between wan and lan ports arm: mvebu: Espressobin: Enable CONFIG_MVNETA arm64: a37xx: pci: Make PCIe Reset GPIO DT compatible with Linux kernel DT arm64: a37xx: pci: Assert PERST# signal when unloading driver arm: mvebu: Espressobin: Make SPI env offset compatible with Marvell's U-Boot arm: mvebu: Espressobin: Setup MTD partitions when booting kernel arm64: a37xx: pci: Depends on DM_GPIO arm: mvebu: Espressobin: Move env load addresses arm: mvebu: Espressobin: Change default loadaddr arm: mvebu: Espressobin: Define fdt_addr and kernel_addr env aliases arm: mvebu: Espressobin: Update README.marvell file
Wilson Ding (1): arm: dts: a37x0: enable sd card support on espressobin
arch/arm/dts/armada-3720-db.dts | 2 +- arch/arm/dts/armada-3720-espressobin.dts | 30 ++++++-- arch/arm/dts/armada-3720-turris-mox.dts | 2 +- board/Marvell/mvebu_armada-37xx/board.c | 109 ++++++++++++++++++++++++++++ configs/mvebu_espressobin-88f3720_defconfig | 5 +- doc/README.marvell | 40 +++++++++- drivers/mmc/xenon_sdhci.c | 79 +++++++++++++++++++- drivers/pci/Kconfig | 1 + drivers/pci/pci-aardvark.c | 29 +++++--- include/configs/mvebu_armada-37xx.h | 15 ++-- 10 files changed, 284 insertions(+), 28 deletions(-)
Stefan Roese
