Re: [U-Boot] [linux-sunxi] Re: [PATCH 14/17] sunxi: Pine64: defconfig: enable SPL FIT support
2017年3月3日 17:55于 Andre Przywara andre.przywara@arm.com写道:
On 03/03/17 09:22, Maxime Ripard wrote:
On Thu, Mar 02, 2017 at 12:03:20AM +0800, Icenowy Zheng wrote:
2017年3月1日 23:51于 Maxime Ripard maxime.ripard@free-electrons.com写道:
Hi Andre,
On Wed, Mar 01, 2017 at 02:25:26AM +0000, Andre Przywara wrote:
The Pine64 (and all other 64-bit Allwinner boards) need to load an ARM Trusted Firmware image beside the actual U-Boot proper. This can now be easily achieved by using the just extended SPL FIT loading support, so enable it in the Pine64 defconfig. Also add the FIT image as a build target to 64-bit sunxi board to trigger the respective Makefile rules.
Signed-off-by: Andre Przywara andre.przywara@arm.com
configs/pine64_plus_defconfig | 6 ++++++ include/configs/sunxi-common.h | 4 ++++ 2 files changed, 10 insertions(+)
diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 7c7d86f..2b47157 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -3,9 +3,14 @@ CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN50I=y CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" +CONFIG_OF_LIST="sun50i-a64-pine64 sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_OF_LIBFDT=y
I'm not sure we want to force down that support to all our users.
A64 boards are now unusable without proper ATF.
That's debatable, but that's not really what I meant. What I meant was that they're perfectly usable without FIT.
But this is a defconfig for a certain, and the Pine64 is not really usable without ATF at the moment in an upstream tree.
Do you want a CONFIG_LOAD_ATF wrapper option, that would make it easier to select / deselect?
I will try to adapt ARMv8 PSCI on A64.
(But I don't know ARM assembly well... both 32 and 64)
Cheers, Andre.
-- You received this message because you are subscribed to the Google Groups "linux-sunxi" group. To unsubscribe from this group and stop receiving emails from it, send an email to linux-sunxi+unsubscribe@googlegroups.com. For more options, visit https://groups.google.com/d/optout.
Icenowy Zheng
