[U-Boot] [PATCH] sh: i2c: Add support I2C controller of SH7734
Renesas SH7734 has two I2C interfaceis. This supports these I2C.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/i2c/Makefile | 1 + drivers/i2c/sh_sh7734_i2c.c | 468 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 469 insertions(+), 0 deletions(-) create mode 100644 drivers/i2c/sh_sh7734_i2c.c
diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 504db03..506269d 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -44,6 +44,7 @@ COBJS-$(CONFIG_SPEAR_I2C) += spr_i2c.o COBJS-$(CONFIG_TSI108_I2C) += tsi108_i2c.o COBJS-$(CONFIG_U8500_I2C) += u8500_i2c.o COBJS-$(CONFIG_SH_I2C) += sh_i2c.o +COBJS-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/i2c/sh_sh7734_i2c.c b/drivers/i2c/sh_sh7734_i2c.c new file mode 100644 index 0000000..6c514b4 --- /dev/null +++ b/drivers/i2c/sh_sh7734_i2c.c @@ -0,0 +1,468 @@ +/* + * Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * Copyright (C) 2012 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> + +struct sh_i2c { + u8 iccr1; + u8 iccr2; + u8 icmr; + u8 icier; + u8 icsr; + u8 sar; + u8 icdrt; + u8 icdrr; + u8 nf2cyc; + u8 __pad0; + u8 __pad1; +}; + +static struct sh_i2c *base; +static u8 iccr1_cks, nf2cyc; + +/* ICCR1 */ +#define SH_I2C_ICCR1_ICE (1 << 7) +#define SH_I2C_ICCR1_RCVD (1 << 6) +#define SH_I2C_ICCR1_MST (1 << 5) +#define SH_I2C_ICCR1_TRS (1 << 4) +#define SH_I2C_ICCR1_MTRS \ + (SH_I2C_ICCR1_MST | SH_I2C_ICCR1_TRS) + +/* ICCR1 */ +#define SH_I2C_ICCR2_BBSY (1 << 7) +#define SH_I2C_ICCR2_SCP (1 << 6) +#define SH_I2C_ICCR2_SDAO (1 << 5) +#define SH_I2C_ICCR2_SDAOP (1 << 4) +#define SH_I2C_ICCR2_SCLO (1 << 3) +#define SH_I2C_ICCR2_IICRST (1 << 1) + +#define SH_I2C_ICIER_TIE (1 << 7) +#define SH_I2C_ICIER_TEIE (1 << 6) +#define SH_I2C_ICIER_RIE (1 << 5) +#define SH_I2C_ICIER_NAKIE (1 << 4) +#define SH_I2C_ICIER_STIE (1 << 3) +#define SH_I2C_ICIER_ACKE (1 << 2) +#define SH_I2C_ICIER_ACKBR (1 << 1) +#define SH_I2C_ICIER_ACKBT (1 << 0) + +#define SH_I2C_ICSR_TDRE (1 << 7) +#define SH_I2C_ICSR_TEND (1 << 6) +#define SH_I2C_ICSR_RDRF (1 << 5) +#define SH_I2C_ICSR_NACKF (1 << 4) +#define SH_I2C_ICSR_STOP (1 << 3) +#define SH_I2C_ICSR_ALOVE (1 << 2) +#define SH_I2C_ICSR_AAS (1 << 1) +#define SH_I2C_ICSR_ADZ (1 << 0) + +#define IRQ_WAIT 1000 + + +static void sh_i2c_send_stop(struct sh_i2c *base) +{ + writeb(readb(&base->iccr2) & ~(SH_I2C_ICCR2_BBSY | SH_I2C_ICCR2_SCP), + &base->iccr2); +} + +static int check_stop(struct sh_i2c *base) +{ + int i, ret = 1; + + for (i = 0 ; i < IRQ_WAIT ; i++) { + if (SH_I2C_ICSR_STOP & readb(&base->icsr)) { + ret = 0; + break; + } + udelay(10); + } + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_STOP, &base->icsr); + + return ret; +} + +static int check_tend(struct sh_i2c *base, int stop) +{ + int i, ret = 1; + + for (i = 0 ; i < IRQ_WAIT ; i++) { + if (SH_I2C_ICSR_TEND & readb(&base->icsr)) { + ret = 0; + break; + } + udelay(10); + } + + if (stop) { + u8 data; + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_STOP, &base->icsr); + + sh_i2c_send_stop(base); + } + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_TEND, &base->icsr); + + return ret; +} + +static int check_tdre(struct sh_i2c *base) +{ + int i; + + for (i = 0 ; i < IRQ_WAIT ; i++) { + if (SH_I2C_ICSR_TDRE & readb(&base->icsr)) + return 0; + udelay(10); + } + + return 1; +} + +static int check_rdrf(struct sh_i2c *base) +{ + int i; + + for (i = 0 ; i < IRQ_WAIT ; i++) { + if (SH_I2C_ICSR_RDRF & readb(&base->icsr)) + return 0; + udelay(10); + } + + return 1; +} + +static int check_bbsy(struct sh_i2c *base) +{ + int i; + + for (i = 0 ; i < IRQ_WAIT ; i++) { + if (!(SH_I2C_ICCR2_BBSY & readb(&base->iccr2))) + return 0; + udelay(10); + } + return 1; +} + +static int check_ackbr(struct sh_i2c *base) +{ + int i; + + for (i = 0 ; i < IRQ_WAIT ; i++) { + if (!(SH_I2C_ICIER_ACKBR & readb(&base->icier))) + return 0; + udelay(10); + } + + return 1; +} + +#if DEBUG +static void sh_i2c_dump_reg(struct sh_i2c *base) +{ + printf("iccr1 : %02X\n", readb(&base->iccr1)); + printf("iccr2 : %02X\n", readb(&base->iccr2)); + printf("icmr : %02X\n", readb(&base->icmr)); + printf("icier : %02X\n", readb(&base->icier)); + printf("icsr : %02X\n", readb(&base->icsr)); + printf("sar : %02X\n", readb(&base->sar)); + printf("icdrt : %02X\n", readb(&base->icdrt)); + printf("icdrr : %02X\n", readb(&base->icdrr)); + printf("nf2cyc: %02X\n", readb(&base->nf2cyc)); +} +#endif + +static void sh_i2c_reset(struct sh_i2c *base) +{ + writeb(readb(&base->iccr2) | SH_I2C_ICCR2_IICRST, + &base->iccr2); + + udelay(100); + + writeb(readb(&base->iccr2) & ~SH_I2C_ICCR2_IICRST, + &base->iccr2); +} + +static int i2c_set_addr(struct sh_i2c *base, u8 id, u8 reg) +{ + u8 data; + + if (check_bbsy(base)) { + printf("i2c bus busy\n"); + goto fail; + } + + writeb(readb(&base->iccr1) | SH_I2C_ICCR1_MTRS, + &base->iccr1); + + writeb((readb(&base->iccr2) | SH_I2C_ICCR2_BBSY) & ~SH_I2C_ICCR2_SCP, + &base->iccr2); + + writeb(id << 1, &base->icdrt); + + if (check_tend(base, 0)) { + printf("TEND check fail...\n"); + goto fail; + } + + if (check_ackbr(base)) { + check_tend(base, 0); + sh_i2c_send_stop(base); + goto fail; + } + + writeb(reg, &base->icdrt); + + if (check_tdre(base)) { + printf("TDRE check fail...\n"); + goto fail; + } + + if (check_tend(base, 0)) { + printf("TEND check fail...\n"); + goto fail; + } + + return 0; + +fail: + + return 1; +} + +static int +i2c_raw_write(struct sh_i2c *base, u8 id, u8 reg, u8 *val, int size) +{ + int i; + u8 data; + + if (i2c_set_addr(base, id, reg)) { + printf("Fail set slave address\n"); + return 1; + } + + for (i = 0 ; i < size ; i++) { + writeb(val[i], &base->icdrt); + check_tdre(base); + } + + check_tend(base, 1); + check_stop(base); + + udelay(100); + + writeb(readb(&base->iccr1) & ~SH_I2C_ICCR1_MTRS, + &base->iccr1); + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_TDRE, + &base->icsr); + + sh_i2c_reset(base); + + return 0; +} + +static u8 i2c_raw_read(struct sh_i2c *base, u8 id, u8 reg) +{ + u8 ret = 0; + + if (i2c_set_addr(base, id, reg)) { + printf("Fail set slave address\n"); + goto fail; + } + + writeb((readb(&base->iccr2) & ~SH_I2C_ICCR2_SCP) | SH_I2C_ICCR2_BBSY, + &base->iccr2); + + writeb(id << 1 | 1, &base->icdrt); + + if (check_tend(base, 0)) + printf("TDRE check fail...\n"); + + writeb((readb(&base->iccr1) & ~SH_I2C_ICCR1_TRS) | SH_I2C_ICCR1_MST, + &base->iccr1); + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_TDRE, + &base->icsr); + + writeb(readb(&base->icier) | SH_I2C_ICIER_ACKBT, + &base->icier); + + writeb(readb(&base->iccr1) | SH_I2C_ICCR1_RCVD, + &base->iccr1); + + /* read data (dummy) */ + ret = readb(&base->icdrr); + + if (check_rdrf(base)) { + printf("check RDRF error\n"); + goto fail; + } + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_STOP, + &base->icsr); + + udelay(1000); + + sh_i2c_send_stop(base); + + if (check_stop(base)) { + printf("check STOP error\n"); + goto fail; + } + + writeb(readb(&base->iccr1) & ~SH_I2C_ICCR1_MTRS, + &base->iccr1); + + writeb(readb(&base->icsr) & ~SH_I2C_ICSR_TDRE, + &base->icsr); + + /* data read */ + ret = readb(&base->icdrr); + +fail: + writeb(readb(&base->iccr1) & ~SH_I2C_ICCR1_RCVD, + &base->iccr1); + + return ret; +} + +#ifdef CONFIG_I2C_MULTI_BUS +static unsigned int current_bus; + +/** + * i2c_set_bus_num - change active I2C bus + * @bus: bus index, zero based + * @returns: 0 on success, non-0 on failure + */ +int i2c_set_bus_num(unsigned int bus) +{ + if ((bus < 0) || (bus >= CONFIG_SYS_MAX_I2C_BUS)) { + printf("Bad bus: %d\n", bus); + return -1; + } + + switch (bus) { + case 0: + base = (void *)CONFIG_SH_I2C_BASE0; + break; + case 1: + base = (void *)CONFIG_SH_I2C_BASE1; + break; + default: + return -1; + } + current_bus = bus; + + return 0; +} + +/** + * i2c_get_bus_num - returns index of active I2C bus + */ +unsigned int i2c_get_bus_num(void) +{ + return current_bus; +} +#endif + +#define SH_I2C_ICCL_CALC(clk, date, t_low, t_high) \ + ((clk / rate) * (t_low / t_low + t_high)) +#define SH_I2C_ICCH_CALC(clk, date, t_low, t_high) \ + ((clk / rate) * (t_high / t_low + t_high)) + +void i2c_init(int speed, int slaveaddr) +{ + int num, denom, tmp; + +#ifdef CONFIG_I2C_MULTI_BUS + current_bus = 0; +#endif + base = (struct sh_i2c *)CONFIG_SH_I2C_BASE0; + + if (speed == 400000) + iccr1_cks = 0x07; + else + iccr1_cks = 0x0F; + + nf2cyc = 1; + + /* Reset */ + sh_i2c_reset(base); + + /* ICE enable and set clock */ + writeb(SH_I2C_ICCR1_ICE | iccr1_cks, &base->iccr1); + writeb(nf2cyc, &base->nf2cyc); +} + +/* + * i2c_read: - Read multiple bytes from an i2c device + * + * The higher level routines take into account that this function is only + * called with len < page length of the device (see configuration file) + * + * @chip: address of the chip which is to be read + * @addr: i2c data address within the chip + * @alen: length of the i2c data address (1..2 bytes) + * @buffer: where to write the data + * @len: how much byte do we want to read + * @return: 0 in case of success + */ +int i2c_read(u8 chip, u32 addr, int alen, u8 *buffer, int len) +{ + int i = 0; + for (i = 0 ; i < len ; i++) + buffer[i] = i2c_raw_read(base, chip, addr + i); + + return 0; +} + +/* + * i2c_write: - Write multiple bytes to an i2c device + * + * The higher level routines take into account that this function is only + * called with len < page length of the device (see configuration file) + * + * @chip: address of the chip which is to be written + * @addr: i2c data address within the chip + * @alen: length of the i2c data address (1..2 bytes) + * @buffer: where to find the data to be written + * @len: how much byte do we want to read + * @return: 0 in case of success + */ +int i2c_write(u8 chip, u32 addr, int alen, u8 *buffer, int len) +{ + int ret; + + ret = i2c_raw_write(base, chip, addr, buffer, len); + + return 0; +} + +/* + * i2c_probe: - Test if a chip answers for a given i2c address + * + * @chip: address of the chip which is searched for + * @return: 0 if a chip was found, -1 otherwhise + */ +int i2c_probe(u8 chip) +{ + return 0; +}
Hello Nobuhiro,
- writeb(readb(&base->iccr2) & ~(SH_I2C_ICCR2_BBSY | SH_I2C_ICCR2_SCP),
&base->iccr2);
Please use clrbits_*
- int i, ret = 1;
- for (i = 0 ; i < IRQ_WAIT ; i++) {
ret = 0;
break;
udelay(10);
- if (stop) {
u8 data;
- writeb(readb(&base->icsr) & ~SH_I2C_ICSR_TEND, &base->icsr);
here too... please check globally.
wrong comment style.
here too.
- i2c_get_bus_num - returns index of active I2C bus
- int i = 0;
new line please.
- for (i = 0 ; i < len ; i++)
Beside of this minor comments patch looks good, thanks!
bye, Heiko
Thanks for your comment.
2012/2/6 Heiko Schocher hs@denx.de:
Hello Nobuhiro,
- &base->iccr2);
OK, but clrbits_* functions is not implement to SuperH and other. I will implement these functions to SuperH.
- int i, ret = 1;
- if (SH_I2C_ICSR_TEND & readb(&base->icsr)) {
- ret = 0;
- break;
- udelay(10);
- if (stop) {
- u8 data;
- writeb(readb(&base->icsr) & ~SH_I2C_ICSR_STOP, &base->icsr);
- sh_i2c_send_stop(base);
OK. I will changed from writeb to clr|set|clrsetbits_*.
OK.
here too.
OK.
- int i = 0;
new line please.
OK.
- buffer[i] = i2c_raw_read(base, chip, addr + i);
Thanks!
Nobuhiro
Heiko Schocher
Nobuhiro Iwamatsu
