[U-Boot] [PATCH 0/2] mtd: nand: fix two problems related to BBT scan
Masahiro Yamada (2): mtd: nand: Mark the BBT as scanned prior to calling scan_bbt again mtd: nand: do not scan BBT after scrub
drivers/mtd/nand/nand_base.c | 9 +++------ drivers/mtd/nand/nand_util.c | 4 +--- 2 files changed, 4 insertions(+), 9 deletions(-)
Commit 35c204d8a9d0 (nand: reinstate lazy bad block scanning) broke NAND_BBT_USE_FLASH feature.
Its git-log claimed that it reinstated the change as by commit fb49454b1b6c ("nand: reinstate lazy bad block scanning"), but it moved "chip->options |= NAND_BBT_SCANNED" below "chip->scan_bbt(mtd);".
It causes recursion if scan_bbt does not find a flash based BBT and tries to write one, and the attempt to erase the BBT area causes a bad block check.
Reinstate commit ff49ea8977b5 (NAND: Mark the BBT as scanned prior to calling scan_bbt.).
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Rostislav Lisovy lisovy@merica.cz Cc: Heiko Schocher hs@denx.de Cc: Scott Wood scottwood@freescale.com ---
drivers/mtd/nand/nand_base.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index d04c7ea..eaa4be1 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -635,8 +635,8 @@ static int nand_block_checkbad(struct mtd_info *mtd, loff_t ofs, int getchip, struct nand_chip *chip = mtd->priv;
if (!(chip->options & NAND_BBT_SCANNED)) { - chip->scan_bbt(mtd); chip->options |= NAND_BBT_SCANNED; + chip->scan_bbt(mtd); }
if (!chip->bbt)
Currently, "nand scrub" runs chip->scan_bbt at the end of nand_erase_opts() even if NAND_SKIP_BBTSCAN flag is set.
It violates the intention of NAND_SKIP_BBTSCAN.
Move NAND_SKIP_BBTSCAN flag check to nand_block_checkbad() so that chip->scan_bbt() is never run if NAND_SKIP_BBTSCAN is set.
Also, unset NAND_BBT_SCANNED flag instead of running chip->scan_bbt() right after scrub. We can be lazier here because the BBT is scanned at the next call of nand_block_checkbad().
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Scott Wood scottwood@freescale.com ---
drivers/mtd/nand/nand_base.c | 7 ++----- drivers/mtd/nand/nand_util.c | 4 +--- 2 files changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index eaa4be1..63bdf65 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -634,7 +634,8 @@ static int nand_block_checkbad(struct mtd_info *mtd, loff_t ofs, int getchip, { struct nand_chip *chip = mtd->priv;
- if (!(chip->options & NAND_BBT_SCANNED)) { + if (!(chip->options & NAND_SKIP_BBTSCAN) && + !(chip->options & NAND_BBT_SCANNED)) { chip->options |= NAND_BBT_SCANNED; chip->scan_bbt(mtd); } @@ -4325,10 +4326,6 @@ int nand_scan_tail(struct mtd_info *mtd) if (!mtd->bitflip_threshold) mtd->bitflip_threshold = mtd->ecc_strength;
- /* Check, if we should skip the bad block table scan */ - if (chip->options & NAND_SKIP_BBTSCAN) - chip->options |= NAND_BBT_SCANNED; - return 0; } EXPORT_SYMBOL(nand_scan_tail); diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index 024f6fb..afdd160 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -91,6 +91,7 @@ int nand_erase_opts(nand_info_t *meminfo, const nand_erase_options_t *opts) kfree(chip->bbt); } chip->bbt = NULL; + chip->options &= ~NAND_BBT_SCANNED; }
for (erased_length = 0; @@ -179,9 +180,6 @@ int nand_erase_opts(nand_info_t *meminfo, const nand_erase_options_t *opts) if (!opts->quiet) printf("\n");
- if (opts->scrub) - chip->scan_bbt(meminfo); - return 0; }
Masahiro Yamada
