[U-Boot] U-boot build failes with armv5tel-reghat-linux-gnueabi-gcc (4.1.2)
Hi I am using u-boot-1.1.6 and building u-boot from my new board which includes nand flash support
If I build using armv5tel-reghat-linux-gnueabi-gcc (4.1.2) toolchain it gives build failure with below log
--start-group lib_generic/libgeneric.a board/Marvell/rd6281/librd6281.a cpu/arm926ejs/libarm926ejs.a cpu/arm926ejs/feroceon/libferoceon.a lib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a net/libnet.a disk/libdisk.a rtc/librtc.a dtt/libdtt.a drivers/libdrivers.a drivers/nand/libnand.a drivers/nand_legacy/libnand_legacy.a drivers/sk98lin/libsk98lin.a post/libpost.a post/cpu/libcpu.a common/libcommon.a --end-group -L /usr/lib/gcc/armv5tel-redhat-linux-gnueabi/4.1.2 -lgcc \ -Map u-boot.map -o u-boot /usr/lib/gcc/armv5tel-redhat-linux-gnueabi/4.1.2/libgcc.a(_divdi3.o):(.ARM.exidx+0x0): undefined reference to `__aeabi_unwind_cpp_pr0' /usr/lib/gcc/armv5tel-redhat-linux-gnueabi/4.1.2/libgcc.a(_udivdi3.o):(.ARM.exidx+0x0): undefined reference to `__aeabi_unwind_cpp_pr0' make: *** [u-boot] Error 1
Whereas, If I build the same code using codesoucery toolchain (arm2008q1) release (gcc ver 4.2.3) the build is sucessfull.
I want to go ahead with armv5tel-reghat-linux-gnueabi-gcc (4.1.2) Can someone suggest what is problem and how should I proceed?
Regards.. Prafulla . .
update the divdi3 and _udivdi3 implementation
I'll said
so please try this patch
please note I've just test it on one board
Best Regards, J.
Best Regards, J.
Any news?
Best Regards, J.
Hi Jean, First of all sorry for late feedback Thanks for your help. I tried to apply the above patch but it has lot of diff, On the other thread I have migrated to latest u-boot version and the problem got resolved :-) I think your patch is mainlined.
But I am facing now new problem... The earlier I was using u-boot ver 1.1.6 and my nand driver was working fine. With migration to latest u-boot I am always getting bad block errors (Skipping bad block 0x????)
What could be the problem?
Regards.. Prafulla. .
-----Original Message----- From: Jean-Christophe PLAGNIOL-VILLARD [mailto:plagnioj@jcrosoft.com] Sent: Sunday, November 23, 2008 5:57 AM To: Prafulla Wadaskar; u-boot@lists.denx.de Subject: Re: [U-Boot] U-boot build failes witharmv5tel-reghat-linux-gnueabi-gcc (4.1.2)
board which
(4.1.2) toolchain
--start-group
Best Regards, J.
Any news?
Best Regards, J.
could you be a few more specific?
CPU, NAND? your patch?
Best Regards, J.
was working fine.
block errors
Hi J Just now it is working I set chip_delay=1000 in board specific code, earlier it was 100 I am trying to get optimal value for the same
I am using arm926ejs based CPU and NAND01G-A, Soon I will provide a patch Thanks... Regards.. Prafulla . .
Prafulla Wadaskar
