[U-Boot] [PATCH] ARM: da850-evm: Enable SPI Flash and NAND Flash when booting NOR
Historically there have been various boot options, SPI flash, NAND or NOR. The NOR flash is mutually exclusive with MMC, but it isn't mutually exclusive with NAND or SPI Flash, so this patch enables both NAND flash and SPI Flash when booting from NOR.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 2d5710076d..c9c34a0c29 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -234,7 +234,8 @@ const struct pinmux_resource pinmuxes[] = { PINMUX_ITEM(emifa_pins_cs3), PINMUX_ITEM(emifa_pins_cs4), PINMUX_ITEM(emifa_pins_nand), -#elif defined(CONFIG_USE_NOR) +#endif +#ifdef CONFIG_USE_NOR PINMUX_ITEM(emifa_pins_cs2), PINMUX_ITEM(emifa_pins_nor), #endif diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index b4e0d08d7f..e92650178c 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -24,14 +24,15 @@ CONFIG_CMD_DM=y # CONFIG_CMD_GPT is not set # CONFIG_CMD_MMC is not set CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y # CONFIG_CMD_PART is not set # CONFIG_CMD_SF is not set # CONFIG_CMD_SPI is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_TIME is not set CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.2" -CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.2:1m(u-boot),128k(u-boot-env),-(spare)" +CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.2,nor1=spi1.0,nand0=nand512" +CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.2:1m(u-boot),128k(u-boot-env),-(spare);spi1.0:32k(SPL),480k(u-boot),64k(u-boot-env),7552k(kernel-spare),64k(MAC-Address);nand512:128k(u-boot env),512k(u-boot),128k(spl-os),8m(kernel),-(rootfs)" CONFIG_CMD_DIAG=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" @@ -49,10 +50,13 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_EMAC=y
Adam Ford
