[PATCH 1/1] riscv: show code leading to exception
To make analyzing exceptions easier output the code that leads to it. We already do the same on the ARM platform.
Here is an example:
=> exception ebreak Unhandled exception: Breakpoint EPC: 000000008ff5d50e RA: 000000008ff5d62c TVAL: 0000000000000000 EPC: 000000008020b50e RA: 000000008020b62c reloc adjusted
Code: 2785 0693 07a0 dce3 fef6 47a5 d563 00e7 (9002)
To disassemble the code we can use the decodecode script:
$ echo 'Code: 2785 0693 07a0 dce3 fef6 47a5 d563 00e7 (9002)' | \ CROSS_COMPILE=riscv64-linux-gnu- scripts/decodecode
Code: 2785 0693 07a0 dce3 fef6 47a5 d563 00e7 (9002) All code ======== 0: 2785 addiw a5,a5,1 2: 07a00693 li a3,122 6: fef6dce3 bge a3,a5,0xfffffffffffffffe a: 47a5 li a5,9 c: 00e7d563 bge a5,a4,0x16 10:* 9002 ebreak <-- trapping instruction ...
Code starting with the faulting instruction =========================================== 0: 9002 ebreak ...
As it is not always clear if the first 16 bits are at the start or in the middle of a 32bit instruction it may become necessary to strip the first u16 from the output before calling decodecode to get the correct disassembled code.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/riscv/lib/interrupts.c | 42 +++++++++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+)
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index 7525c152b8..31b8a6603c 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -51,6 +51,47 @@ static void show_regs(struct pt_regs *regs) #endif }
+/** + * instr_len() - get instruction length + * + * @i: low 16 bits of the instruction + * Return: number of u16 in instruction + */ +static int instr_len(u16 i) +{ + if ((i & 0x03) != 0x03) + return 1; + if ((i & 0x1c) != 0x1c) + return 2; + if ((i & 0x3f) == 0x1f) + return 3; + if ((i & 0x7f) == 0x3f) + return 4; + i = (i >> 12) & 0x07; + if (i < 7) + return i + 5; + /* Encoding for >= 192 bits is not yet defined */ + return 1; +} + +/** + * show_code() - display code leading to exception + * + * @epc: program counter + */ +static void show_code(ulong epc) +{ + u16 *pos = (u16 *)(epc & ~1UL); + int i, len = instr_len(*pos); + + printf("\nCode: "); + for (i = -8; i; ++i) + printf("%04x ", pos[i]); + printf("("); + for (i = 0; i < len; ++i) + printf("%04x%s", pos[i], i + 1 == len ? ")\n" : " "); +} + static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs) { static const char * const exception_code[] = { @@ -85,6 +126,7 @@ static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs) epc - gd->reloc_off, regs->ra - gd->reloc_off);
show_regs(regs); + show_code(epc); show_efi_loaded_images(epc); panic("\n"); } -- 2.30.2
Here is an example:
=> exception ebreak Unhandled exception: Breakpoint EPC: 000000008ff5d50e RA: 000000008ff5d62c TVAL: 0000000000000000 EPC: 000000008020b50e RA: 000000008020b62c reloc adjusted Code: 2785 0693 07a0 dce3 fef6 47a5 d563 00e7 (9002)
$ echo 'Code: 2785 0693 07a0 dce3 fef6 47a5 d563 00e7 (9002)' | \ CROSS_COMPILE=riscv64-linux-gnu- scripts/decodecode Code: 2785 0693 07a0 dce3 fef6 47a5 d563 00e7 (9002) All code ======== 0: 2785 addiw a5,a5,1 2: 07a00693 li a3,122 6: fef6dce3 bge a3,a5,0xfffffffffffffffe a: 47a5 li a5,9 c: 00e7d563 bge a5,a4,0x16 10:* 9002 ebreak <-- trapping instruction ... Code starting with the faulting instruction =========================================== 0: 9002 ebreak ...
- instr_len() - get instruction length
- @i: low 16 bits of the instruction
- Return: number of u16 in instruction
- if ((i & 0x03) != 0x03)
return 1;
- if ((i & 0x1c) != 0x1c)
Shouldn't this be 1f?
And TBH I would not bother dealing with >48-bit instructions, as not even 48-bit instructions have been standardized (with the closest candidate being [1] AFAIK). That would allow for simplification to
i &= 0b11111; if (i == 0b011111) return 3;
i &= 0b11; if (i == 0b11) return 2; return 1;
If we ever see a 64-bit instruction, we can come back and modify this.
--Sean
[1] https://github.com/riscv/riscv-code-size-reduction/blob/master/ISA%20proposa...
return 2;
- if ((i & 0x3f) == 0x1f)
return 3;
- if ((i & 0x7f) == 0x3f)
return 4;
- i = (i >> 12) & 0x07;
- if (i < 7)
return i + 5;
- /* Encoding for >= 192 bits is not yet defined */
- return 1;
- show_code() - display code leading to exception
- @epc: program counter
- u16 *pos = (u16 *)(epc & ~1UL);
- int i, len = instr_len(*pos);
- printf("\nCode: ");
- for (i = -8; i; ++i)
- printf("(");
- for (i = 0; i < len; ++i)
- static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs) { static const char * const exception_code[] = {
show_regs(regs);
- show_code(epc); show_efi_loaded_images(epc); panic("\n"); }
-- 2.30.2
Am 13. August 2021 03:34:58 MESZ schrieb Sean Anderson seanga2@gmail.com:
Here is an example:
return 1;
We already know that bits 0 and 1 are set here. We only have to check that not all of bits 2 - 4 are set.
Won't extending [1] to load 64 bit values result in 80 bit instructions?
Best regards
Heinrich
--Sean
return 2;
return 3;
return 4;
- if (i < 7)
return i + 5;
- return 1;
- printf("(");
show_regs(regs);
-- 2.30.2
Here is an example:
return 1;
*shrug* It's one instruction anyway and it helps clarity.
Yes? But I think it's extremely unlikely to happen. You can always just put your 64-bit literals in the data section. And true 64-bit addresses (where each bit must be specified) basically don't exist, since no one has that much memory. Even the 32-bit version is just a suggestion at this point, and I think the added complexity to instruction decoding will make 80-bit instructions just theory.
--Sean
Best regards
Heinrich
--Sean
return 2;
return 3;
return 4;
- if (i < 7)
return i + 5;
- return 1;
- printf("(");
show_regs(regs);
-- 2.30.2
Here is an example:
return 1;
Best regards
Heinrich
--Sean
return 2;
return 3;
return 4;
- if (i < 7)
return i + 5;
- return 1;
- printf("(");
show_regs(regs);
-- 2.30.2
Sean Anderson
