[U-Boot] [PATCH] Makefile: Do not pass -E to mkimage when SPL has full fitImage support
When the SPL has full fitImage support, do not generate fitImage with external data. The full fitImage code assumes the entire fitImage is loaded in RAM, and the SPL uses fdt_totalsize() to determine the size of the whole fitImage, which can not work with external data.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com --- Makefile | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 26db4e7b59..b69e6349e2 100644 --- a/Makefile +++ b/Makefile @@ -893,7 +893,7 @@ cmd_mkimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -d $< $@ \ >$(MKIMAGEOUTPUT) $(if $(KBUILD_VERBOSE:0=), && cat $(MKIMAGEOUTPUT))
quiet_cmd_mkfitimage = MKIMAGE $@ -cmd_mkfitimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -f $(U_BOOT_ITS) -E -p $(CONFIG_FIT_EXTERNAL_OFFSET) $@\ +cmd_mkfitimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -f $(U_BOOT_ITS) -p $(CONFIG_FIT_EXTERNAL_OFFSET) $@\ >$(MKIMAGEOUTPUT) $(if $(KBUILD_VERBOSE:0=), && cat $(MKIMAGEOUTPUT))
quiet_cmd_cat = CAT $@ @@ -1200,6 +1200,12 @@ u-boot-dtb.img u-boot.img u-boot.kwb u-boot.pbl u-boot-ivt.img: \ $(call if_changed,mkimage) $(BOARD_SIZE_CHECK)
+ifeq ($(CONFIG_SPL_LOAD_FIT_FULL),y) +MKIMAGEFLAGS_u-boot.itb = +else +MKIMAGEFLAGS_u-boot.itb = -E +endif + u-boot.itb: u-boot-nodtb.bin dts/dt.dtb $(U_BOOT_ITS) FORCE $(call if_changed,mkfitimage) $(BOARD_SIZE_CHECK)
