[U-Boot] [PATCH 1/2] sh: lowlevel_init coding style cleanup
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- board/mpr2/lowlevel_init.S | 44 +- board/ms7722se/lowlevel_init.S | 34 +- board/ms7750se/lowlevel_init.S | 150 +++--- board/renesas/MigoR/lowlevel_init.S | 10 +- board/renesas/ap325rxa/lowlevel_init.S | 86 ++-- board/renesas/r2dplus/lowlevel_init.S | 126 +++--- board/renesas/r7780mp/lowlevel_init.S | 858 +++++++++++++++--------------- board/renesas/rsk7203/lowlevel_init.S | 214 ++++---- board/renesas/sh7763rdp/lowlevel_init.S | 162 +++--- board/renesas/sh7785lcr/lowlevel_init.S | 2 +- 10 files changed, 846 insertions(+), 840 deletions(-) rewrite board/renesas/r7780mp/lowlevel_init.S (68%)
diff --git a/board/mpr2/lowlevel_init.S b/board/mpr2/lowlevel_init.S index 060957a..187b5bb 100644 --- a/board/mpr2/lowlevel_init.S +++ b/board/mpr2/lowlevel_init.S @@ -33,17 +33,17 @@ lowlevel_init: /* * Set frequency multipliers and dividers in FRQCR. */ - mov.l WTCSR_A,r1 - mov.l WTCSR_D,r0 - mov.w r0,@r1 + mov.l WTCSR_A, r1 + mov.l WTCSR_D, r0 + mov.w r0, @r1
- mov.l WTCNT_A,r1 - mov.l WTCNT_D,r0 - mov.w r0,@r1 + mov.l WTCNT_A, r1 + mov.l WTCNT_D, r0 + mov.w r0, @r1
- mov.l FRQCR_A,r1 - mov.l FRQCR_D,r0 - mov.w r0,@r1 + mov.l FRQCR_A, r1 + mov.l FRQCR_D, r0 + mov.w r0, @r1
/* * Setup CS0 (Flash). @@ -112,21 +112,27 @@ WTCSR_D: .long 0xA507 /* divide by 4096 */ /* * Spansion S29GL256N11 @ 48 MHz */ -CS0BCR_D: .long 0x12490400 /* 1 idle cycle inserted, normal space, 16 bit */ -CS0WCR_D: .long 0x00000340 /* tSW=0.5ck, 6 wait cycles, NO external wait, tHW=0.5ck */ +/* 1 idle cycle inserted, normal space, 16 bit */ +CS0BCR_D: .long 0x12490400 +/* tSW=0.5ck, 6 wait cycles, NO external wait, tHW=0.5ck */ +CS0WCR_D: .long 0x00000340
/* * Samsung K4S511632B-UL75 @ 48 MHz * Micron MT48LC32M16A2-75 @ 48 MHz */ -CS3BCR_D: .long 0x10004400 /* CS3BCR = 0x10004400, minimum idle cycles, SDRAM, 16 bit */ -CS3WCR_D: .long 0x00000091 /* tRP=1ck, tRCD=1ck, CL=2, tRWL=2ck, tRC=4ck */ -SDCR_D1: .long 0x00000012 /* no refresh, 13 rows, 10 cols, NO bank active mode */ -SDCR_D2: .long 0x00000812 /* refresh */ -RTCSR_D: .long 0xA55A0008 /* 1/4, once */ -RTCNT_D: .long 0xA55A005D /* count 93 */ -RTCOR_D: .long 0xa55a005d /* count 93 */ -SDMR3_D: .long 0x440 /* mode register CL2, burst read and SINGLE WRITE */ +/* CS3BCR = 0x10004400, minimum idle cycles, SDRAM, 16 bit */ +CS3BCR_D: .long 0x10004400 +/* tRP=1ck, tRCD=1ck, CL=2, tRWL=2ck, tRC=4ck */ +CS3WCR_D: .long 0x00000091 +/* no refresh, 13 rows, 10 cols, NO bank active mode */ +SDCR_D1: .long 0x00000012 +SDCR_D2: .long 0x00000812 /* refresh */ +RTCSR_D: .long 0xA55A0008 /* 1/4, once */ +RTCNT_D: .long 0xA55A005D /* count 93 */ +RTCOR_D: .long 0xa55a005d /* count 93 */ +/* mode register CL2, burst read and SINGLE WRITE */ +SDMR3_D: .long 0x440
/* * Registers diff --git a/board/ms7722se/lowlevel_init.S b/board/ms7722se/lowlevel_init.S index 8b46595..3e887cf 100644 --- a/board/ms7722se/lowlevel_init.S +++ b/board/ms7722se/lowlevel_init.S @@ -29,11 +29,11 @@ #include <asm/processor.h>
/* - * Board specific low level init code, called _very_ early in the - * startup sequence. Relocation to SDRAM has not happened yet, no - * stack is available, bss section has not been initialised, etc. + * Board specific low level init code, called _very_ early in the + * startup sequence. Relocation to SDRAM has not happened yet, no + * stack is available, bss section has not been initialised, etc. * - * (Note: As no stack is available, no subroutines can be called...). + * (Note: As no stack is available, no subroutines can be called...). */
.global lowlevel_init @@ -203,7 +203,7 @@ bsc_init: mov #0x00, r0 ! SDMR3 data -> R0 mov.b r0, @r1 ! SDMR3 set
- ! BL bit off (init = ON) (?!?) + ! BL bit off (init = ON) (?!?)
stc sr, r0 ! BL bit off(init=ON) mov.l SR_MASK_D, r1 @@ -232,28 +232,28 @@ MSTPCR0_D: .long 0x00001001 MSTPCR2_D: .long 0xffffffff FRQCR_D: .long 0x07022538
-PSELA_A: .long 0xa405014E -PSELA_D: .word 0x0A10 +PSELA_A: .long 0xa405014E +PSELA_D: .word 0x0A10 .align 2
-DRVCR_A: .long 0xa405018A -DRVCR_D: .word 0x0554 +DRVCR_A: .long 0xa405018A +DRVCR_D: .word 0x0554 .align 2
-PCCR_A: .long 0xa4050104 -PCCR_D: .word 0x8800 +PCCR_A: .long 0xa4050104 +PCCR_D: .word 0x8800 .align 2
-PECR_A: .long 0xa4050108 -PECR_D: .word 0x0000 +PECR_A: .long 0xa4050108 +PECR_D: .word 0x0000 .align 2
-PJCR_A: .long 0xa4050110 -PJCR_D: .word 0x1000 +PJCR_A: .long 0xa4050110 +PJCR_D: .word 0x1000 .align 2
-PXCR_A: .long 0xa4050148 -PXCR_D: .word 0x0AAA +PXCR_A: .long 0xa4050148 +PXCR_D: .word 0x0AAA .align 2
CMNCR_A: .long CMNCR diff --git a/board/ms7750se/lowlevel_init.S b/board/ms7750se/lowlevel_init.S index d3e3cd5..de05dd9 100644 --- a/board/ms7750se/lowlevel_init.S +++ b/board/ms7750se/lowlevel_init.S @@ -31,118 +31,118 @@ #include <asm/processor.h>
#ifdef CONFIG_CPU_SH7751 -#define BCR2_D_VALUE 0x2FFC /* Area 1-6 width: 32/32/32/32/32/16 */ -#define WCR1_D_VALUE 0x02770771 /* DMA:0 A6:2 A3:0 A0:1 Others:15 */ +#define BCR2_D_VALUE 0x2FFC /* Area 1-6 width: 32/32/32/32/32/16 */ +#define WCR1_D_VALUE 0x02770771 /* DMA:0 A6:2 A3:0 A0:1 Others:15 */ #ifdef CONFIG_MARUBUN_PCCARD -#define WCR2_D_VALUE 0xFFFE4FE7 /* A6:15 A6B:7 A5:15 A5B:7 A4:15 - A3:2 A2:15 A1:15 A0:6 A0B:7 */ +#define WCR2_D_VALUE 0xFFFE4FE7 /* A6:15 A6B:7 A5:15 A5B:7 A4:15 + A3:2 A2:15 A1:15 A0:6 A0B:7 */ #else /* CONFIG_MARUBUN_PCCARD */ -#define WCR2_D_VALUE 0x7FFE4FE7 /* A6:3 A6B:7 A5:15 A5B:7 A4:15 - A3:2 A2:15 A1:15 A0:6 A0B:7 */ +#define WCR2_D_VALUE 0x7FFE4FE7 /* A6:3 A6B:7 A5:15 A5B:7 A4:15 + A3:2 A2:15 A1:15 A0:6 A0B:7 */ #endif /* CONFIG_MARUBUN_PCCARD */ -#define WCR3_D_VALUE 0x01777771 /* A6: 0-1 A5: 1-3 A4: 1-3 A3: 1-3 - A2: 1-3 A1: 1-3 A0: 0-1 */ -#define RTCOR_D_VALUE 0xA50D /* Write code A5, data 0D (~15us?) */ -#define SDMR3_ADDRESS 0xFF940088 /* SDMR3 address on 32-bit bus */ -#define MCR_D1_VALUE 0x100901B4 /* SDRAM 32-bit, CAS/RAS Refresh, ... */ -#define MCR_D2_VALUE 0x500901B4 /* Same w/MRSET now 1 (mode reg cmd) */ +#define WCR3_D_VALUE 0x01777771 /* A6: 0-1 A5: 1-3 A4: 1-3 A3: 1-3 + A2: 1-3 A1: 1-3 A0: 0-1 */ +#define RTCOR_D_VALUE 0xA50D /* Write code A5, data 0D (~15us?) */ +#define SDMR3_ADDRESS 0xFF940088 /* SDMR3 address on 32-bit bus */ +#define MCR_D1_VALUE 0x100901B4 /* SDRAM 32-bit, CAS/RAS Refresh, .. */ +#define MCR_D2_VALUE 0x500901B4 /* Same w/MRSET now 1 (mode reg cmd) */ #else /* CONFIG_CPU_SH7751 */ -#define BCR2_D_VALUE 0x2E3C /* Area 1-6 width: 32/32/64/16/32/16 */ -#define WCR1_D_VALUE 0x02720777 /* DMA:0 A6:2 A4:2 A3:0 Others:15 */ -#define WCR2_D_VALUE 0xFFFE4FFF /* A6:15 A6B:7 A5:15 A5B:7 A4:15 - A3:2 A2:15 A1:15 A0:15 A0B:7 */ -#define WCR3_D_VALUE 0x01717771 /* A6: 0-1 A5: 1-3 A4: 0-1 A3: 1-3 - A2: 1-3 A1: 1-3 A0: 0-1 */ -#define RTCOR_D_VALUE 0xA510 /* Write code A5, data 10 (~15us?) */ -#define SDMR3_ADDRESS 0xFF940110 /* SDMR3 address on 64-bit bus */ -#define MCR_D1_VALUE 0x8801001C /* SDRAM 64-bit, CAS/RAS Refresh, ... */ -#define MCR_D2_VALUE 0xC801001C /* Same w/MRSET now 1 (mode reg cmd) */ +#define BCR2_D_VALUE 0x2E3C /* Area 1-6 width: 32/32/64/16/32/16 */ +#define WCR1_D_VALUE 0x02720777 /* DMA:0 A6:2 A4:2 A3:0 Others:15 */ +#define WCR2_D_VALUE 0xFFFE4FFF /* A6:15 A6B:7 A5:15 A5B:7 A4:15 + A3:2 A2:15 A1:15 A0:15 A0B:7 */ +#define WCR3_D_VALUE 0x01717771 /* A6: 0-1 A5: 1-3 A4: 0-1 A3: 1-3 + A2: 1-3 A1: 1-3 A0: 0-1 */ +#define RTCOR_D_VALUE 0xA510 /* Write code A5, data 10 (~15us?) */ +#define SDMR3_ADDRESS 0xFF940110 /* SDMR3 address on 64-bit bus */ +#define MCR_D1_VALUE 0x8801001C /* SDRAM 64-bit, CAS/RAS Refresh, .. */ +#define MCR_D2_VALUE 0xC801001C /* Same w/MRSET now 1 (mode reg cmd) */ #endif /* CONFIG_CPU_SH7751 */
.global lowlevel_init .text - .align 2 + .align 2
lowlevel_init:
- mov.l CCR_A, r1 ! CCR Address - mov.l CCR_D_DISABLE, r0 ! CCR Data - mov.l r0, @r1 + mov.l CCR_A, r1 ! CCR Address + mov.l CCR_D_DISABLE, r0 ! CCR Data + mov.l r0, @r1
init_bsc: - mov.l FRQCR_A,r1 /* FRQCR Address */ - mov.l FRQCR_D,r0 /* FRQCR Data */ - mov.w r0,@r1 + mov.l FRQCR_A, r1 /* FRQCR Address */ + mov.l FRQCR_D, r0 /* FRQCR Data */ + mov.w r0, @r1
- mov.l BCR1_A,r1 /* BCR1 Address */ - mov.l BCR1_D,r0 /* BCR1 Data */ - mov.l r0,@r1 + mov.l BCR1_A, r1 /* BCR1 Address */ + mov.l BCR1_D, r0 /* BCR1 Data */ + mov.l r0, @r1
- mov.l BCR2_A,r1 /* BCR2 Address */ - mov.l BCR2_D,r0 /* BCR2 Data */ - mov.w r0,@r1 + mov.l BCR2_A, r1 /* BCR2 Address */ + mov.l BCR2_D, r0 /* BCR2 Data */ + mov.w r0, @r1
- mov.l WCR1_A,r1 /* WCR1 Address */ - mov.l WCR1_D,r0 /* WCR1 Data */ - mov.l r0,@r1 + mov.l WCR1_A, r1 /* WCR1 Address */ + mov.l WCR1_D, r0 /* WCR1 Data */ + mov.l r0, @r1
- mov.l WCR2_A,r1 /* WCR2 Address */ - mov.l WCR2_D,r0 /* WCR2 Data */ - mov.l r0,@r1 + mov.l WCR2_A, r1 /* WCR2 Address */ + mov.l WCR2_D, r0 /* WCR2 Data */ + mov.l r0, @r1
- mov.l WCR3_A,r1 /* WCR3 Address */ - mov.l WCR3_D,r0 /* WCR3 Data */ - mov.l r0,@r1 + mov.l WCR3_A, r1 /* WCR3 Address */ + mov.l WCR3_D, r0 /* WCR3 Data */ + mov.l r0, @r1
- mov.l MCR_A,r1 /* MCR Address */ - mov.l MCR_D1,r0 /* MCR Data1 */ - mov.l r0,@r1 + mov.l MCR_A, r1 /* MCR Address */ + mov.l MCR_D1, r0 /* MCR Data1 */ + mov.l r0, @r1
- mov.l SDMR3_A,r1 /* Set SDRAM mode */ - mov #0,r0 - mov.b r0,@r1 + mov.l SDMR3_A, r1 /* Set SDRAM mode */ + mov #0, r0 + mov.b r0, @r1
! Do you need PCMCIA setting? ! If so, please add the lines here...
- mov.l RTCNT_A,r1 /* RTCNT Address */ - mov.l RTCNT_D,r0 /* RTCNT Data */ - mov.w r0,@r1 + mov.l RTCNT_A, r1 /* RTCNT Address */ + mov.l RTCNT_D, r0 /* RTCNT Data */ + mov.w r0, @r1
- mov.l RTCOR_A,r1 /* RTCOR Address */ - mov.l RTCOR_D,r0 /* RTCOR Data */ - mov.w r0,@r1 + mov.l RTCOR_A, r1 /* RTCOR Address */ + mov.l RTCOR_D, r0 /* RTCOR Data */ + mov.w r0, @r1
- mov.l RTCSR_A,r1 /* RTCSR Address */ - mov.l RTCSR_D,r0 /* RTCSR Data */ - mov.w r0,@r1 + mov.l RTCSR_A, r1 /* RTCSR Address */ + mov.l RTCSR_D, r0 /* RTCSR Data */ + mov.w r0, @r1
- mov.l RFCR_A,r1 /* RFCR Address */ - mov.l RFCR_D,r0 /* RFCR Data */ - mov.w r0,@r1 /* Clear reflesh counter */ + mov.l RFCR_A, r1 /* RFCR Address */ + mov.l RFCR_D, r0 /* RFCR Data */ + mov.w r0, @r1 /* Clear reflesh counter */ /* Wait DRAM refresh 30 times */ - mov #30,r3 + mov #30, r3 1: - mov.w @r1,r0 - extu.w r0,r2 - cmp/hi r3,r2 + mov.w @r1, r0 + extu.w r0, r2 + cmp/hi r3, r2 bf 1b
- mov.l MCR_A,r1 /* MCR Address */ - mov.l MCR_D2,r0 /* MCR Data2 */ - mov.l r0,@r1 + mov.l MCR_A, r1 /* MCR Address */ + mov.l MCR_D2, r0 /* MCR Data2 */ + mov.l r0, @r1
rts - nop + nop
.align 2
-CCR_A: .long CCR -CCR_D_DISABLE: .long 0x0808 +CCR_A: .long CCR +CCR_D_DISABLE: .long 0x0808 FRQCR_A: .long FRQCR FRQCR_D: #ifdef CONFIG_CPU_TYPE_R diff --git a/board/renesas/MigoR/lowlevel_init.S b/board/renesas/MigoR/lowlevel_init.S index 4c1900e..13c83bf 100644 --- a/board/renesas/MigoR/lowlevel_init.S +++ b/board/renesas/MigoR/lowlevel_init.S @@ -29,11 +29,11 @@ #include <asm/processor.h>
.global lowlevel_init @@ -176,7 +176,7 @@ bsc_init: mov #0x00, r0 ! SDMR3 data -> R0 mov.b r0, @r1 ! SDMR3 set
stc sr, r0 ! BL bit off(init=ON) mov.l SR_MASK_D, r1 diff --git a/board/renesas/ap325rxa/lowlevel_init.S b/board/renesas/ap325rxa/lowlevel_init.S index 4f66588..558e779 100644 --- a/board/renesas/ap325rxa/lowlevel_init.S +++ b/board/renesas/ap325rxa/lowlevel_init.S @@ -39,111 +39,111 @@
lowlevel_init: mov.l DRVCRA_A, r1 - mov.l DRVCRA_D, r0 + mov.l DRVCRA_D, r0 mov.w r0, @r1
mov.l DRVCRB_A, r1 - mov.l DRVCRB_D, r0 + mov.l DRVCRB_D, r0 mov.w r0, @r1
mov.l RWTCSR_A, r1 - mov.l RWTCSR_D1, r0 + mov.l RWTCSR_D1, r0 mov.w r0, @r1
mov.l RWTCNT_A, r1 - mov.l RWTCNT_D, r0 + mov.l RWTCNT_D, r0 mov.w r0, @r1
mov.l RWTCSR_A, r1 - mov.l RWTCSR_D2, r0 + mov.l RWTCSR_D2, r0 mov.w r0, @r1
mov.l FRQCR_A, r1 - mov.l FRQCR_D, r0 + mov.l FRQCR_D, r0 mov.l r0, @r1
mov.l CMNCR_A, r1 mov.l CMNCR_D, r0 mov.l r0, @r1
- mov.l CS0BCR_A ,r1 - mov.l CS0BCR_D ,r0 + mov.l CS0BCR_A, r1 + mov.l CS0BCR_D, r0 mov.l r0, @r1
- mov.l CS4BCR_A ,r1 - mov.l CS4BCR_D ,r0 + mov.l CS4BCR_A, r1 + mov.l CS4BCR_D, r0 mov.l r0, @r1
- mov.l CS5ABCR_A ,r1 - mov.l CS5ABCR_D ,r0 + mov.l CS5ABCR_A, r1 + mov.l CS5ABCR_D, r0 mov.l r0, @r1
- mov.l CS5BBCR_A ,r1 - mov.l CS5BBCR_D ,r0 + mov.l CS5BBCR_A, r1 + mov.l CS5BBCR_D, r0 mov.l r0, @r1
- mov.l CS6ABCR_A ,r1 - mov.l CS6ABCR_D ,r0 + mov.l CS6ABCR_A, r1 + mov.l CS6ABCR_D, r0 mov.l r0, @r1
- mov.l CS6BBCR_A ,r1 - mov.l CS6BBCR_D ,r0 + mov.l CS6BBCR_A, r1 + mov.l CS6BBCR_D, r0 mov.l r0, @r1
- mov.l CS0WCR_A ,r1 - mov.l CS0WCR_D ,r0 + mov.l CS0WCR_A, r1 + mov.l CS0WCR_D, r0 mov.l r0, @r1
- mov.l CS4WCR_A ,r1 - mov.l CS4WCR_D ,r0 + mov.l CS4WCR_A, r1 + mov.l CS4WCR_D, r0 mov.l r0, @r1
- mov.l CS5AWCR_A ,r1 - mov.l CS5AWCR_D ,r0 + mov.l CS5AWCR_A, r1 + mov.l CS5AWCR_D, r0 mov.l r0, @r1
- mov.l CS5BWCR_A ,r1 - mov.l CS5BWCR_D ,r0 + mov.l CS5BWCR_A, r1 + mov.l CS5BWCR_D, r0 mov.l r0, @r1
- mov.l CS6AWCR_A ,r1 - mov.l CS6AWCR_D ,r0 + mov.l CS6AWCR_A, r1 + mov.l CS6AWCR_D, r0 mov.l r0, @r1
- mov.l CS6BWCR_A ,r1 - mov.l CS6BWCR_D ,r0 + mov.l CS6BWCR_A, r1 + mov.l CS6BWCR_D, r0 mov.l r0, @r1
mov.l SBSC_SDCR_A, r1 - mov.l SBSC_SDCR_D1, r0 + mov.l SBSC_SDCR_D1, r0 mov.l r0, @r1
mov.l SBSC_SDWCR_A, r1 - mov.l SBSC_SDWCR_D, r0 + mov.l SBSC_SDWCR_D, r0 mov.l r0, @r1
mov.l SBSC_SDPCR_A, r1 - mov.l SBSC_SDPCR_D, r0 + mov.l SBSC_SDPCR_D, r0 mov.l r0, @r1
mov.l SBSC_RTCSR_A, r1 - mov.l SBSC_RTCSR_D, r0 + mov.l SBSC_RTCSR_D, r0 mov.l r0, @r1
mov.l SBSC_RTCNT_A, r1 - mov.l SBSC_RTCNT_D, r0 + mov.l SBSC_RTCNT_D, r0 mov.l r0, @r1
mov.l SBSC_RTCOR_A, r1 - mov.l SBSC_RTCOR_D, r0 + mov.l SBSC_RTCOR_D, r0 mov.l r0, @r1
mov.l SBSC_SDMR3_A1, r1 - mov.l SBSC_SDMR3_D, r0 + mov.l SBSC_SDMR3_D, r0 mov.b r0, @r1
mov.l SBSC_SDMR3_A2, r1 - mov.l SBSC_SDMR3_D, r0 + mov.l SBSC_SDMR3_D, r0 mov.b r0, @r1
mov.l SLEEP_CNT, r1 @@ -153,18 +153,18 @@ lowlevel_init: dt r1
mov.l SBSC_SDMR3_A3, r1 - mov.l SBSC_SDMR3_D, r0 + mov.l SBSC_SDMR3_D, r0 mov.b r0, @r1
mov.l SBSC_SDCR_A, r1 - mov.l SBSC_SDCR_D2, r0 + mov.l SBSC_SDCR_D2, r0 mov.l r0, @r1
mov.l CCR_A, r1 - mov.l CCR_D, r0 + mov.l CCR_D, r0 mov.l r0, @r1
stc sr, r0 ! BL bit off(init=ON) mov.l SR_MASK_D, r1 @@ -211,7 +211,7 @@ SBSC_SDMR3_D: .long 0x00 CMNCR_A: .long CMNCR CS0BCR_A: .long CS0BCR CS4BCR_A: .long CS4BCR -CS5ABCR_A: .long CS5ABCR +CS5ABCR_A: .long CS5ABCR CS5BBCR_A: .long CS5BBCR CS6ABCR_A: .long CS6ABCR CS6BBCR_A: .long CS6BBCR diff --git a/board/renesas/r2dplus/lowlevel_init.S b/board/renesas/r2dplus/lowlevel_init.S index 28d2b37..a057370 100644 --- a/board/renesas/r2dplus/lowlevel_init.S +++ b/board/renesas/r2dplus/lowlevel_init.S @@ -17,92 +17,92 @@ lowlevel_init:
mov.l CCR_A, r1 mov.l CCR_D_D, r0 - mov.l r0,@r1 + mov.l r0, @r1
- mov.l MMUCR_A,r1 - mov.l MMUCR_D,r0 - mov.l r0,@r1 + mov.l MMUCR_A, r1 + mov.l MMUCR_D, r0 + mov.l r0, @r1
- mov.l BCR1_A,r1 - mov.l BCR1_D,r0 - mov.l r0,@r1 + mov.l BCR1_A, r1 + mov.l BCR1_D, r0 + mov.l r0, @r1
- mov.l BCR2_A,r1 - mov.l BCR2_D,r0 - mov.w r0,@r1 + mov.l BCR2_A, r1 + mov.l BCR2_D, r0 + mov.w r0, @r1
- mov.l BCR3_A,r1 - mov.l BCR3_D,r0 - mov.w r0,@r1 + mov.l BCR3_A, r1 + mov.l BCR3_D, r0 + mov.w r0, @r1
- mov.l BCR4_A,r1 - mov.l BCR4_D,r0 - mov.l r0,@r1 + mov.l BCR4_A, r1 + mov.l BCR4_D, r0 + mov.l r0, @r1
- mov.l WCR1_A,r1 - mov.l WCR1_D,r0 - mov.l r0,@r1 + mov.l WCR1_A, r1 + mov.l WCR1_D, r0 + mov.l r0, @r1
- mov.l WCR2_A,r1 - mov.l WCR2_D,r0 - mov.l r0,@r1 + mov.l WCR2_A, r1 + mov.l WCR2_D, r0 + mov.l r0, @r1
- mov.l WCR3_A,r1 - mov.l WCR3_D,r0 - mov.l r0,@r1 + mov.l WCR3_A, r1 + mov.l WCR3_D, r0 + mov.l r0, @r1
- mov.l PCR_A,r1 - mov.l PCR_D,r0 - mov.w r0,@r1 + mov.l PCR_A, r1 + mov.l PCR_D, r0 + mov.w r0, @r1
- mov.l LED_A,r1 - mov #0xff,r0 - mov.w r0,@r1 + mov.l LED_A, r1 + mov #0xff, r0 + mov.w r0, @r1
- mov.l MCR_A,r1 - mov.l MCR_D1,r0 - mov.l r0,@r1 + mov.l MCR_A, r1 + mov.l MCR_D1, r0 + mov.l r0, @r1
- mov.l RTCNT_A,r1 - mov.l RTCNT_D,r0 - mov.w r0,@r1 + mov.l RTCNT_A, r1 + mov.l RTCNT_D, r0 + mov.w r0, @r1
- mov.l RTCOR_A,r1 - mov.l RTCOR_D,r0 - mov.w r0,@r1 + mov.l RTCOR_A, r1 + mov.l RTCOR_D, r0 + mov.w r0, @r1
- mov.l RFCR_A,r1 - mov.l RFCR_D,r0 - mov.w r0,@r1 + mov.l RFCR_A, r1 + mov.l RFCR_D, r0 + mov.w r0, @r1
- mov.l RTCSR_A,r1 - mov.l RTCSR_D,r0 - mov.w r0,@r1 + mov.l RTCSR_A, r1 + mov.l RTCSR_D, r0 + mov.w r0, @r1
- mov.l SDMR3_A,r1 - mov #0x55,r0 - mov.b r0,@r1 + mov.l SDMR3_A, r1 + mov #0x55, r0 + mov.b r0, @r1
/* Wait DRAM refresh 30 times */ - mov.l RFCR_A,r1 - mov #30,r3 + mov.l RFCR_A, r1 + mov #30, r3 1: - mov.w @r1,r0 - extu.w r0,r2 - cmp/hi r3,r2 + mov.w @r1, r0 + extu.w r0, r2 + cmp/hi r3, r2 bf 1b
- mov.l MCR_A,r1 - mov.l MCR_D2,r0 - mov.l r0,@r1 + mov.l MCR_A, r1 + mov.l MCR_D2, r0 + mov.l r0, @r1
- mov.l SDMR3_A,r1 - mov #0,r0 - mov.b r0,@r1 + mov.l SDMR3_A, r1 + mov #0, r0 + mov.b r0, @r1
- mov.l IRLMASK_A,r1 - mov.l IRLMASK_D,r0 - mov.l r0,@r1 + mov.l IRLMASK_A, r1 + mov.l IRLMASK_D, r0 + mov.l r0, @r1
mov.l CCR_A, r1 mov.l CCR_D_E, r0 diff --git a/board/renesas/r7780mp/lowlevel_init.S b/board/renesas/r7780mp/lowlevel_init.S dissimilarity index 68% index ab0499a..0df8c84 100644 --- a/board/renesas/r7780mp/lowlevel_init.S +++ b/board/renesas/r7780mp/lowlevel_init.S @@ -1,429 +1,429 @@ -/* - * Copyright (C) 2007,2008 Nobuhiro Iwamatsu - * - * u-boot/board/r7780mp/lowlevel_init.S - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/processor.h> - -/* - * Board specific low level init code, called _very_ early in the - * startup sequence. Relocation to SDRAM has not happened yet, no - * stack is available, bss section has not been initialised, etc. - * - * (Note: As no stack is available, no subroutines can be called...). - */ - - .global lowlevel_init - - .text - .align 2 - -lowlevel_init: - - mov.l CCR_A, r1 /* Address of Cache Control Register */ - mov.l CCR_D, r0 /* Instruction Cache Invalidate */ - mov.l r0, @r1 - - mov.l FRQCR_A, r1 /* Frequency control register */ - mov.l FRQCR_D, r0 - mov.l r0, @r1 - - /* pin_multi_setting */ - mov.l BBG_PMMR_A,r1 - mov.l BBG_PMMR_D_PMSR1,r0 - mov.l r0,@r1 - - mov.l BBG_PMSR1_A,r1 - mov.l BBG_PMSR1_D,r0 - mov.l r0,@r1 - - mov.l BBG_PMMR_A,r1 - mov.l BBG_PMMR_D_PMSR2,r0 - mov.l r0,@r1 - - mov.l BBG_PMSR2_A,r1 - mov.l BBG_PMSR2_D,r0 - mov.l r0,@r1 - - mov.l BBG_PMMR_A,r1 - mov.l BBG_PMMR_D_PMSR3,r0 - mov.l r0,@r1 - - mov.l BBG_PMSR3_A,r1 - mov.l BBG_PMSR3_D,r0 - mov.l r0,@r1 - - mov.l BBG_PMMR_A,r1 - mov.l BBG_PMMR_D_PMSR4,r0 - mov.l r0,@r1 - - mov.l BBG_PMSR4_A,r1 - mov.l BBG_PMSR4_D,r0 - mov.l r0,@r1 - - mov.l BBG_PMMR_A,r1 - mov.l BBG_PMMR_D_PMSRG,r0 - mov.l r0,@r1 - - mov.l BBG_PMSRG_A,r1 - mov.l BBG_PMSRG_D,r0 - mov.l r0,@r1 - - /* cpg_setting */ - mov.l FRQCR_A,r1 - mov.l FRQCR_D,r0 - mov.l r0,@r1 - - mov.l DLLCSR_A,r1 - mov.l DLLCSR_D,r0 - mov.l r0,@r1 - - nop - nop - nop - nop - nop - nop - nop - nop - nop - nop - - /* wait 200us */ - mov.l REPEAT0_R3,r3 - mov #0,r2 -repeat0: - add #1,r2 - cmp/hs r3,r2 - bf repeat0 - nop - - /* bsc_setting */ - mov.l MMSELR_A,r1 - mov.l MMSELR_D,r0 - mov.l r0,@r1 - - mov.l BCR_A,r1 - mov.l BCR_D,r0 - mov.l r0,@r1 - - mov.l CS0BCR_A,r1 - mov.l CS0BCR_D,r0 - mov.l r0,@r1 - - mov.l CS1BCR_A,r1 - mov.l CS1BCR_D,r0 - mov.l r0,@r1 - - mov.l CS2BCR_A,r1 - mov.l CS2BCR_D,r0 - mov.l r0,@r1 - - mov.l CS4BCR_A,r1 - mov.l CS4BCR_D,r0 - mov.l r0,@r1 - - mov.l CS5BCR_A,r1 - mov.l CS5BCR_D,r0 - mov.l r0,@r1 - - mov.l CS6BCR_A,r1 - mov.l CS6BCR_D,r0 - mov.l r0,@r1 - - mov.l CS0WCR_A,r1 - mov.l CS0WCR_D,r0 - mov.l r0,@r1 - - mov.l CS1WCR_A,r1 - mov.l CS1WCR_D,r0 - mov.l r0,@r1 - - mov.l CS2WCR_A,r1 - mov.l CS2WCR_D,r0 - mov.l r0,@r1 - - mov.l CS4WCR_A,r1 - mov.l CS4WCR_D,r0 - mov.l r0,@r1 - - mov.l CS5WCR_A,r1 - mov.l CS5WCR_D,r0 - mov.l r0,@r1 - - mov.l CS6WCR_A,r1 - mov.l CS6WCR_D,r0 - mov.l r0,@r1 - - mov.l CS5PCR_A,r1 - mov.l CS5PCR_D,r0 - mov.l r0,@r1 - - mov.l CS6PCR_A,r1 - mov.l CS6PCR_D,r0 - mov.l r0,@r1 - - /* ddr_setting */ - /* wait 200us */ - mov.l REPEAT0_R3,r3 - mov #0,r2 -repeat1: - add #1,r2 - cmp/hs r3,r2 - bf repeat1 - nop - - mov.l MIM_U_A,r0 - mov.l MIM_U_D,r1 - synco - mov.l r1,@r0 - synco - - mov.l MIM_L_A,r0 - mov.l MIM_L_D0,r1 - synco - mov.l r1,@r0 - synco - - mov.l STR_L_A,r0 - mov.l STR_L_D,r1 - synco - mov.l r1,@r0 - synco - - mov.l SDR_L_A,r0 - mov.l SDR_L_D,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - nop - - mov.l SCR_L_A,r0 - mov.l SCR_L_D0,r1 - synco - mov.l r1,@r0 - synco - - mov.l SCR_L_A,r0 - mov.l SCR_L_D1,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l EMRS_A,r0 - mov.l EMRS_D,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l MRS1_A,r0 - mov.l MRS1_D,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l SCR_L_A,r0 - mov.l SCR_L_D2,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l SCR_L_A,r0 - mov.l SCR_L_D3,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l SCR_L_A,r0 - mov.l SCR_L_D4,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l MRS2_A,r0 - mov.l MRS2_D,r1 - synco - mov.l r1,@r0 - synco - - nop - nop - nop - - mov.l SCR_L_A,r0 - mov.l SCR_L_D5,r1 - synco - mov.l r1,@r0 - synco - - /* wait 200us */ - mov.l REPEAT0_R1,r3 - mov #0,r2 -repeat2: - add #1,r2 - cmp/hs r3,r2 - bf repeat2 - - synco - - mov.l MIM_L_A,r0 - mov.l MIM_L_D1,r1 - synco - mov.l r1,@r0 - synco - - rts - nop - .align 4 - -RWTCSR_D_1: .word 0xA507 -RWTCSR_D_2: .word 0xA507 -RWTCNT_D: .word 0x5A00 - .align 2 - -BBG_PMMR_A: .long 0xFF800010 -BBG_PMSR1_A: .long 0xFF800014 -BBG_PMSR2_A: .long 0xFF800018 -BBG_PMSR3_A: .long 0xFF80001C -BBG_PMSR4_A: .long 0xFF800020 -BBG_PMSRG_A: .long 0xFF800024 - -BBG_PMMR_D_PMSR1: .long 0xffffbffd -BBG_PMSR1_D: .long 0x00004002 -BBG_PMMR_D_PMSR2: .long 0xfc21a7ff -BBG_PMSR2_D: .long 0x03de5800 -BBG_PMMR_D_PMSR3: .long 0xfffffff8 -BBG_PMSR3_D: .long 0x00000007 -BBG_PMMR_D_PMSR4: .long 0xdffdfff9 -BBG_PMSR4_D: .long 0x20020006 -BBG_PMMR_D_PMSRG: .long 0xffffffff -BBG_PMSRG_D: .long 0x00000000 - -FRQCR_A: .long FRQCR -DLLCSR_A: .long 0xffc40010 -FRQCR_D: .long 0x40233035 -DLLCSR_D: .long 0x00000000 - -/* for DDR-SDRAM */ -MIM_U_A: .long MIM_1 -MIM_L_A: .long MIM_2 -SCR_U_A: .long SCR_1 -SCR_L_A: .long SCR_2 -STR_U_A: .long STR_1 -STR_L_A: .long STR_2 -SDR_U_A: .long SDR_1 -SDR_L_A: .long SDR_2 - -EMRS_A: .long 0xFEC02000 -MRS1_A: .long 0xFEC00B08 -MRS2_A: .long 0xFEC00308 - -MIM_U_D: .long 0x00004000 -MIM_L_D0: .long 0x03e80009 -MIM_L_D1: .long 0x03e80209 -SCR_L_D0: .long 0x3 -SCR_L_D1: .long 0x2 -SCR_L_D2: .long 0x2 -SCR_L_D3: .long 0x4 -SCR_L_D4: .long 0x4 -SCR_L_D5: .long 0x0 -STR_L_D: .long 0x000f0000 -SDR_L_D: .long 0x00000400 -EMRS_D: .long 0x0 -MRS1_D: .long 0x0 -MRS2_D: .long 0x0 - -/* Cache Controller */ -CCR_A: .long CCR -MMUCR_A: .long MMUCR -RWTCNT_A: .long WTCNT - -CCR_D: .long 0x0000090b -CCR_D_2: .long 0x00000103 -MMUCR_D: .long 0x00000004 -MSTPCR0_D: .long 0x00001001 -MSTPCR2_D: .long 0xffffffff - -/* local Bus State Controller */ -MMSELR_A: .long MMSELR -BCR_A: .long BCR -CS0BCR_A: .long CS0BCR -CS1BCR_A: .long CS1BCR -CS2BCR_A: .long CS2BCR -CS4BCR_A: .long CS4BCR -CS5BCR_A: .long CS5BCR -CS6BCR_A: .long CS6BCR -CS0WCR_A: .long CS0WCR -CS1WCR_A: .long CS1WCR -CS2WCR_A: .long CS2WCR -CS4WCR_A: .long CS4WCR -CS5WCR_A: .long CS5WCR -CS6WCR_A: .long CS6WCR -CS5PCR_A: .long CS5PCR -CS6PCR_A: .long CS6PCR - -MMSELR_D: .long 0xA5A50003 -BCR_D: .long 0x00000000 -CS0BCR_D: .long 0x77777770 -CS1BCR_D: .long 0x77777670 -CS2BCR_D: .long 0x77777770 -CS4BCR_D: .long 0x77777770 -CS5BCR_D: .long 0x77777670 -CS6BCR_D: .long 0x77777770 -CS0WCR_D: .long 0x00020006 -CS1WCR_D: .long 0x00232304 -CS2WCR_D: .long 0x7777770F -CS4WCR_D: .long 0x7777770F -CS5WCR_D: .long 0x00101006 -CS6WCR_D: .long 0x77777703 -CS5PCR_D: .long 0x77000000 -CS6PCR_D: .long 0x77000000 - -REPEAT0_R3: .long 0x00002000 -REPEAT0_R1: .long 0x0000200 +/* + * Copyright (C) 2007,2008 Nobuhiro Iwamatsu + * + * u-boot/board/r7780mp/lowlevel_init.S + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/processor.h> + +/* + * Board specific low level init code, called _very_ early in the + * startup sequence. Relocation to SDRAM has not happened yet, no + * stack is available, bss section has not been initialised, etc. + * + * (Note: As no stack is available, no subroutines can be called...). + */ + + .global lowlevel_init + + .text + .align 2 + +lowlevel_init: + + mov.l CCR_A, r1 /* Address of Cache Control Register */ + mov.l CCR_D, r0 /* Instruction Cache Invalidate */ + mov.l r0, @r1 + + mov.l FRQCR_A, r1 /* Frequency control register */ + mov.l FRQCR_D, r0 + mov.l r0, @r1 + + /* pin_multi_setting */ + mov.l BBG_PMMR_A, r1 + mov.l BBG_PMMR_D_PMSR1, r0 + mov.l r0, @r1 + + mov.l BBG_PMSR1_A, r1 + mov.l BBG_PMSR1_D, r0 + mov.l r0, @r1 + + mov.l BBG_PMMR_A, r1 + mov.l BBG_PMMR_D_PMSR2, r0 + mov.l r0, @r1 + + mov.l BBG_PMSR2_A, r1 + mov.l BBG_PMSR2_D, r0 + mov.l r0, @r1 + + mov.l BBG_PMMR_A, r1 + mov.l BBG_PMMR_D_PMSR3, r0 + mov.l r0, @r1 + + mov.l BBG_PMSR3_A, r1 + mov.l BBG_PMSR3_D, r0 + mov.l r0, @r1 + + mov.l BBG_PMMR_A, r1 + mov.l BBG_PMMR_D_PMSR4, r0 + mov.l r0, @r1 + + mov.l BBG_PMSR4_A, r1 + mov.l BBG_PMSR4_D, r0 + mov.l r0, @r1 + + mov.l BBG_PMMR_A, r1 + mov.l BBG_PMMR_D_PMSRG, r0 + mov.l r0, @r1 + + mov.l BBG_PMSRG_A, r1 + mov.l BBG_PMSRG_D, r0 + mov.l r0, @r1 + + /* cpg_setting */ + mov.l FRQCR_A, r1 + mov.l FRQCR_D, r0 + mov.l r0, @r1 + + mov.l DLLCSR_A, r1 + mov.l DLLCSR_D, r0 + mov.l r0, @r1 + + nop + nop + nop + nop + nop + nop + nop + nop + nop + nop + + /* wait 200us */ + mov.l REPEAT0_R3, r3 + mov #0, r2 +repeat0: + add #1, r2 + cmp/hs r3, r2 + bf repeat0 + nop + + /* bsc_setting */ + mov.l MMSELR_A, r1 + mov.l MMSELR_D, r0 + mov.l r0, @r1 + + mov.l BCR_A, r1 + mov.l BCR_D, r0 + mov.l r0, @r1 + + mov.l CS0BCR_A, r1 + mov.l CS0BCR_D, r0 + mov.l r0, @r1 + + mov.l CS1BCR_A, r1 + mov.l CS1BCR_D, r0 + mov.l r0, @r1 + + mov.l CS2BCR_A, r1 + mov.l CS2BCR_D, r0 + mov.l r0, @r1 + + mov.l CS4BCR_A, r1 + mov.l CS4BCR_D, r0 + mov.l r0, @r1 + + mov.l CS5BCR_A, r1 + mov.l CS5BCR_D, r0 + mov.l r0, @r1 + + mov.l CS6BCR_A, r1 + mov.l CS6BCR_D, r0 + mov.l r0, @r1 + + mov.l CS0WCR_A, r1 + mov.l CS0WCR_D, r0 + mov.l r0, @r1 + + mov.l CS1WCR_A, r1 + mov.l CS1WCR_D, r0 + mov.l r0, @r1 + + mov.l CS2WCR_A, r1 + mov.l CS2WCR_D, r0 + mov.l r0, @r1 + + mov.l CS4WCR_A, r1 + mov.l CS4WCR_D, r0 + mov.l r0, @r1 + + mov.l CS5WCR_A, r1 + mov.l CS5WCR_D, r0 + mov.l r0, @r1 + + mov.l CS6WCR_A, r1 + mov.l CS6WCR_D, r0 + mov.l r0, @r1 + + mov.l CS5PCR_A, r1 + mov.l CS5PCR_D, r0 + mov.l r0, @r1 + + mov.l CS6PCR_A, r1 + mov.l CS6PCR_D, r0 + mov.l r0, @r1 + + /* ddr_setting */ + /* wait 200us */ + mov.l REPEAT0_R3, r3 + mov #0, r2 +repeat1: + add #1, r2 + cmp/hs r3, r2 + bf repeat1 + nop + + mov.l MIM_U_A, r0 + mov.l MIM_U_D, r1 + synco + mov.l r1, @r0 + synco + + mov.l MIM_L_A, r0 + mov.l MIM_L_D0, r1 + synco + mov.l r1, @r0 + synco + + mov.l STR_L_A, r0 + mov.l STR_L_D, r1 + synco + mov.l r1, @r0 + synco + + mov.l SDR_L_A, r0 + mov.l SDR_L_D, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + nop + + mov.l SCR_L_A, r0 + mov.l SCR_L_D0, r1 + synco + mov.l r1, @r0 + synco + + mov.l SCR_L_A, r0 + mov.l SCR_L_D1, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l EMRS_A, r0 + mov.l EMRS_D, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l MRS1_A, r0 + mov.l MRS1_D, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l SCR_L_A, r0 + mov.l SCR_L_D2, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l SCR_L_A, r0 + mov.l SCR_L_D3, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l SCR_L_A, r0 + mov.l SCR_L_D4, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l MRS2_A, r0 + mov.l MRS2_D, r1 + synco + mov.l r1, @r0 + synco + + nop + nop + nop + + mov.l SCR_L_A, r0 + mov.l SCR_L_D5, r1 + synco + mov.l r1, @r0 + synco + + /* wait 200us */ + mov.l REPEAT0_R1, r3 + mov #0, r2 +repeat2: + add #1, r2 + cmp/hs r3, r2 + bf repeat2 + + synco + + mov.l MIM_L_A, r0 + mov.l MIM_L_D1, r1 + synco + mov.l r1, @r0 + synco + + rts + nop + .align 4 + +RWTCSR_D_1: .word 0xA507 +RWTCSR_D_2: .word 0xA507 +RWTCNT_D: .word 0x5A00 + .align 2 + +BBG_PMMR_A: .long 0xFF800010 +BBG_PMSR1_A: .long 0xFF800014 +BBG_PMSR2_A: .long 0xFF800018 +BBG_PMSR3_A: .long 0xFF80001C +BBG_PMSR4_A: .long 0xFF800020 +BBG_PMSRG_A: .long 0xFF800024 + +BBG_PMMR_D_PMSR1: .long 0xffffbffd +BBG_PMSR1_D: .long 0x00004002 +BBG_PMMR_D_PMSR2: .long 0xfc21a7ff +BBG_PMSR2_D: .long 0x03de5800 +BBG_PMMR_D_PMSR3: .long 0xfffffff8 +BBG_PMSR3_D: .long 0x00000007 +BBG_PMMR_D_PMSR4: .long 0xdffdfff9 +BBG_PMSR4_D: .long 0x20020006 +BBG_PMMR_D_PMSRG: .long 0xffffffff +BBG_PMSRG_D: .long 0x00000000 + +FRQCR_A: .long FRQCR +DLLCSR_A: .long 0xffc40010 +FRQCR_D: .long 0x40233035 +DLLCSR_D: .long 0x00000000 + +/* for DDR-SDRAM */ +MIM_U_A: .long MIM_1 +MIM_L_A: .long MIM_2 +SCR_U_A: .long SCR_1 +SCR_L_A: .long SCR_2 +STR_U_A: .long STR_1 +STR_L_A: .long STR_2 +SDR_U_A: .long SDR_1 +SDR_L_A: .long SDR_2 + +EMRS_A: .long 0xFEC02000 +MRS1_A: .long 0xFEC00B08 +MRS2_A: .long 0xFEC00308 + +MIM_U_D: .long 0x00004000 +MIM_L_D0: .long 0x03e80009 +MIM_L_D1: .long 0x03e80209 +SCR_L_D0: .long 0x3 +SCR_L_D1: .long 0x2 +SCR_L_D2: .long 0x2 +SCR_L_D3: .long 0x4 +SCR_L_D4: .long 0x4 +SCR_L_D5: .long 0x0 +STR_L_D: .long 0x000f0000 +SDR_L_D: .long 0x00000400 +EMRS_D: .long 0x0 +MRS1_D: .long 0x0 +MRS2_D: .long 0x0 + +/* Cache Controller */ +CCR_A: .long CCR +MMUCR_A: .long MMUCR +RWTCNT_A: .long WTCNT + +CCR_D: .long 0x0000090b +CCR_D_2: .long 0x00000103 +MMUCR_D: .long 0x00000004 +MSTPCR0_D: .long 0x00001001 +MSTPCR2_D: .long 0xffffffff + +/* local Bus State Controller */ +MMSELR_A: .long MMSELR +BCR_A: .long BCR +CS0BCR_A: .long CS0BCR +CS1BCR_A: .long CS1BCR +CS2BCR_A: .long CS2BCR +CS4BCR_A: .long CS4BCR +CS5BCR_A: .long CS5BCR +CS6BCR_A: .long CS6BCR +CS0WCR_A: .long CS0WCR +CS1WCR_A: .long CS1WCR +CS2WCR_A: .long CS2WCR +CS4WCR_A: .long CS4WCR +CS5WCR_A: .long CS5WCR +CS6WCR_A: .long CS6WCR +CS5PCR_A: .long CS5PCR +CS6PCR_A: .long CS6PCR + +MMSELR_D: .long 0xA5A50003 +BCR_D: .long 0x00000000 +CS0BCR_D: .long 0x77777770 +CS1BCR_D: .long 0x77777670 +CS2BCR_D: .long 0x77777770 +CS4BCR_D: .long 0x77777770 +CS5BCR_D: .long 0x77777670 +CS6BCR_D: .long 0x77777770 +CS0WCR_D: .long 0x00020006 +CS1WCR_D: .long 0x00232304 +CS2WCR_D: .long 0x7777770F +CS4WCR_D: .long 0x7777770F +CS5WCR_D: .long 0x00101006 +CS6WCR_D: .long 0x77777703 +CS5PCR_D: .long 0x77000000 +CS6PCR_D: .long 0x77000000 + +REPEAT0_R3: .long 0x00002000 +REPEAT0_R1: .long 0x0000200 diff --git a/board/renesas/rsk7203/lowlevel_init.S b/board/renesas/rsk7203/lowlevel_init.S index e4d6f9e..f6a6231 100644 --- a/board/renesas/rsk7203/lowlevel_init.S +++ b/board/renesas/rsk7203/lowlevel_init.S @@ -29,153 +29,153 @@
lowlevel_init: /* Cache setting */ - mov.l CCR1_A ,r1 - mov.l CCR1_D ,r0 - mov.l r0,@r1 + mov.l CCR1_A, r1 + mov.l CCR1_D, r0 + mov.l r0, @r1
/* ConfigurePortPins */ - mov.l PECRL3_A, r1 - mov.l PECRL3_D, r0 - mov.w r0,@r1 + mov.l PECRL3_A, r1 + mov.l PECRL3_D, r0 + mov.w r0, @r1
- mov.l PCCRL4_A, r1 - mov.l PCCRL4_D0, r0 - mov.w r0,@r1 + mov.l PCCRL4_A, r1 + mov.l PCCRL4_D0, r0 + mov.w r0, @r1
- mov.l PECRL4_A, r1 - mov.l PECRL4_D0, r0 - mov.w r0,@r1 + mov.l PECRL4_A, r1 + mov.l PECRL4_D0, r0 + mov.w r0, @r1
- mov.l PEIORL_A, r1 - mov.l PEIORL_D0, r0 - mov.w r0,@r1 + mov.l PEIORL_A, r1 + mov.l PEIORL_D0, r0 + mov.w r0, @r1
- mov.l PCIORL_A, r1 - mov.l PCIORL_D, r0 - mov.w r0,@r1 + mov.l PCIORL_A, r1 + mov.l PCIORL_D, r0 + mov.w r0, @r1
- mov.l PFCRH2_A, r1 - mov.l PFCRH2_D, r0 - mov.w r0,@r1 + mov.l PFCRH2_A, r1 + mov.l PFCRH2_D, r0 + mov.w r0, @r1
- mov.l PFCRH3_A, r1 - mov.l PFCRH3_D, r0 - mov.w r0,@r1 + mov.l PFCRH3_A, r1 + mov.l PFCRH3_D, r0 + mov.w r0, @r1
- mov.l PFCRH1_A, r1 - mov.l PFCRH1_D, r0 - mov.w r0,@r1 + mov.l PFCRH1_A, r1 + mov.l PFCRH1_D, r0 + mov.w r0, @r1
- mov.l PFIORH_A, r1 - mov.l PFIORH_D, r0 - mov.w r0,@r1 + mov.l PFIORH_A, r1 + mov.l PFIORH_D, r0 + mov.w r0, @r1
- mov.l PECRL1_A, r1 - mov.l PECRL1_D0, r0 - mov.w r0,@r1 + mov.l PECRL1_A, r1 + mov.l PECRL1_D0, r0 + mov.w r0, @r1
- mov.l PEIORL_A, r1 - mov.l PEIORL_D1, r0 - mov.w r0,@r1 + mov.l PEIORL_A, r1 + mov.l PEIORL_D1, r0 + mov.w r0, @r1
/* Configure Operating Frequency */ - mov.l WTCSR_A ,r1 - mov.l WTCSR_D0 ,r0 - mov.w r0,@r1 + mov.l WTCSR_A, r1 + mov.l WTCSR_D0, r0 + mov.w r0, @r1
- mov.l WTCSR_A ,r1 - mov.l WTCSR_D1 ,r0 - mov.w r0,@r1 + mov.l WTCSR_A, r1 + mov.l WTCSR_D1, r0 + mov.w r0, @r1
- mov.l WTCNT_A ,r1 - mov.l WTCNT_D ,r0 - mov.w r0,@r1 + mov.l WTCNT_A, r1 + mov.l WTCNT_D, r0 + mov.w r0, @r1
/* Set clock mode*/ - mov.l FRQCR_A,r1 - mov.l FRQCR_D,r0 - mov.w r0,@r1 + mov.l FRQCR_A, r1 + mov.l FRQCR_D, r0 + mov.w r0, @r1
/* Configure Bus And Memory */ init_bsc_cs0: - mov.l PCCRL4_A,r1 - mov.l PCCRL4_D1,r0 - mov.w r0,@r1 + mov.l PCCRL4_A, r1 + mov.l PCCRL4_D1, r0 + mov.w r0, @r1
- mov.l PECRL1_A,r1 - mov.l PECRL1_D1,r0 - mov.w r0,@r1 + mov.l PECRL1_A, r1 + mov.l PECRL1_D1, r0 + mov.w r0, @r1
- mov.l CMNCR_A,r1 - mov.l CMNCR_D,r0 - mov.l r0,@r1 + mov.l CMNCR_A, r1 + mov.l CMNCR_D, r0 + mov.l r0, @r1
- mov.l SC0BCR_A,r1 - mov.l SC0BCR_D,r0 - mov.l r0,@r1 + mov.l SC0BCR_A, r1 + mov.l SC0BCR_D, r0 + mov.l r0, @r1
- mov.l CS0WCR_A,r1 - mov.l CS0WCR_D,r0 - mov.l r0,@r1 + mov.l CS0WCR_A, r1 + mov.l CS0WCR_D, r0 + mov.l r0, @r1
init_bsc_cs1: - mov.l PECRL4_A,r1 - mov.l PECRL4_D1,r0 - mov.w r0,@r1 + mov.l PECRL4_A, r1 + mov.l PECRL4_D1, r0 + mov.w r0, @r1
- mov.l CS1WCR_A,r1 - mov.l CS1WCR_D,r0 - mov.l r0,@r1 + mov.l CS1WCR_A, r1 + mov.l CS1WCR_D, r0 + mov.l r0, @r1
init_sdram: - mov.l PCCRL2_A,r1 - mov.l PCCRL2_D,r0 - mov.w r0,@r1 + mov.l PCCRL2_A, r1 + mov.l PCCRL2_D, r0 + mov.w r0, @r1
- mov.l PCCRL4_A,r1 - mov.l PCCRL4_D2,r0 - mov.w r0,@r1 + mov.l PCCRL4_A, r1 + mov.l PCCRL4_D2, r0 + mov.w r0, @r1
- mov.l PCCRL1_A,r1 - mov.l PCCRL1_D,r0 - mov.w r0,@r1 + mov.l PCCRL1_A, r1 + mov.l PCCRL1_D, r0 + mov.w r0, @r1
- mov.l PCCRL3_A,r1 - mov.l PCCRL3_D,r0 - mov.w r0,@r1 + mov.l PCCRL3_A, r1 + mov.l PCCRL3_D, r0 + mov.w r0, @r1
- mov.l CS3BCR_A,r1 - mov.l CS3BCR_D,r0 - mov.l r0,@r1 + mov.l CS3BCR_A, r1 + mov.l CS3BCR_D, r0 + mov.l r0, @r1
- mov.l CS3WCR_A,r1 - mov.l CS3WCR_D,r0 - mov.l r0,@r1 + mov.l CS3WCR_A, r1 + mov.l CS3WCR_D, r0 + mov.l r0, @r1
- mov.l SDCR_A,r1 - mov.l SDCR_D,r0 - mov.l r0,@r1 + mov.l SDCR_A, r1 + mov.l SDCR_D, r0 + mov.l r0, @r1
- mov.l RTCOR_A,r1 - mov.l RTCOR_D,r0 - mov.l r0,@r1 + mov.l RTCOR_A, r1 + mov.l RTCOR_D, r0 + mov.l r0, @r1
- mov.l RTCSR_A,r1 - mov.l RTCSR_D,r0 - mov.l r0,@r1 + mov.l RTCSR_A, r1 + mov.l RTCSR_D, r0 + mov.l r0, @r1
/* wait 200us */ - mov.l REPEAT_D,r3 - mov #0,r2 + mov.l REPEAT_D, r3 + mov #0, r2 repeat0: - add #1,r2 - cmp/hs r3,r2 - bf repeat0 + add #1, r2 + cmp/hs r3, r2 + bf repeat0 nop
- mov.l SDRAM_MODE, r1 - mov #0,r0 - mov.l r0, @r1 + mov.l SDRAM_MODE, r1 + mov #0, r0 + mov.l r0, @r1
nop rts @@ -208,8 +208,8 @@ PECRL1_D0: .long 0x00000033
WTCSR_A: .long 0xFFFE0000 -WTCSR_D0: .long 0x0000A518 -WTCSR_D1: .long 0x0000A51D +WTCSR_D0: .long 0x0000A518 +WTCSR_D1: .long 0x0000A51D WTCNT_A: .long 0xFFFE0002 WTCNT_D: .long 0x00005A84 FRQCR_A: .long 0xFFFE0010 @@ -259,7 +259,7 @@ STBCR4_A: .long 0xFFFE040C STBCR4_D: .long 0x00000008 STBCR5_A: .long 0xFFFE0410 STBCR5_D: .long 0x00000000 -STBCR6_A: .long 0xFFFE0414 +STBCR6_A: .long 0xFFFE0414 STBCR6_D: .long 0x00000002 SDRAM_MODE: .long 0xFFFC5040 REPEAT_D: .long 0x00009C40 diff --git a/board/renesas/sh7763rdp/lowlevel_init.S b/board/renesas/sh7763rdp/lowlevel_init.S index 2a44eee..715e75f 100644 --- a/board/renesas/sh7763rdp/lowlevel_init.S +++ b/board/renesas/sh7763rdp/lowlevel_init.S @@ -33,17 +33,17 @@
lowlevel_init:
- mov.l WDTCSR_A, r1 /* Watchdog Control / Status Register */ - mov.l WDTCSR_D, r0 - mov.l r0, @r1 + mov.l WDTCSR_A, r1 /* Watchdog Control / Status Register */ + mov.l WDTCSR_D, r0 + mov.l r0, @r1
- mov.l WDTST_A, r1 /* Watchdog Stop Time Register */ - mov.l WDTST_D, r0 - mov.l r0, @r1 + mov.l WDTST_A, r1 /* Watchdog Stop Time Register */ + mov.l WDTST_D, r0 + mov.l r0, @r1
- mov.l WDTBST_A, r1 /* 0xFFCC0008 (Watchdog Base Stop Time Register */ - mov.l WDTBST_D, r0 - mov.l r0, @r1 + mov.l WDTBST_A, r1 /* 0xFFCC0008 (Watchdog Base Stop Time Register */ + mov.l WDTBST_D, r0 + mov.l r0, @r1
mov.l CCR_A, r1 /* Address of Cache Control Register */ mov.l CCR_CACHE_ICI_D, r0 /* Instruction Cache Invalidate */ @@ -61,107 +61,107 @@ lowlevel_init: mov.l MSTPCR1_D, r0 mov.l r0, @r1
- mov.l RAMCR_A,r1 - mov.l RAMCR_D,r0 + mov.l RAMCR_A, r1 + mov.l RAMCR_D, r0 mov.l r0, @r1
- mov.l MMSELR_A,r1 - mov.l MMSELR_D,r0 + mov.l MMSELR_A, r1 + mov.l MMSELR_D, r0 synco mov.l r0, @r1
- mov.l @r1,r2 /* execute two reads after setting MMSELR*/ - mov.l @r1,r2 + mov.l @r1, r2 /* execute two reads after setting MMSELR*/ + mov.l @r1, r2 synco
/* issue memory read */ - mov.l DDRSD_START_A,r1 /* memory address to read*/ - mov.l @r1,r0 + mov.l DDRSD_START_A, r1 /* memory address to read*/ + mov.l @r1, r0 synco
- mov.l MIM8_A,r1 - mov.l MIM8_D,r0 - mov.l r0,@r1 + mov.l MIM8_A, r1 + mov.l MIM8_D, r0 + mov.l r0, @r1
- mov.l MIMC_A,r1 - mov.l MIMC_D1,r0 - mov.l r0,@r1 + mov.l MIMC_A, r1 + mov.l MIMC_D1, r0 + mov.l r0, @r1
- mov.l STRC_A,r1 - mov.l STRC_D,r0 - mov.l r0,@r1 + mov.l STRC_A, r1 + mov.l STRC_D, r0 + mov.l r0, @r1
- mov.l SDR4_A,r1 - mov.l SDR4_D,r0 - mov.l r0,@r1 + mov.l SDR4_A, r1 + mov.l SDR4_D, r0 + mov.l r0, @r1
- mov.l MIMC_A,r1 - mov.l MIMC_D2,r0 - mov.l r0,@r1 + mov.l MIMC_A, r1 + mov.l MIMC_D2, r0 + mov.l r0, @r1
nop nop nop
- mov.l SCR4_A,r1 - mov.l SCR4_D3,r0 - mov.l r0,@r1 + mov.l SCR4_A, r1 + mov.l SCR4_D3, r0 + mov.l r0, @r1
- mov.l SCR4_A,r1 - mov.l SCR4_D2,r0 - mov.l r0,@r1 + mov.l SCR4_A, r1 + mov.l SCR4_D2, r0 + mov.l r0, @r1
- mov.l SDMR02000_A,r1 - mov.l SDMR02000_D,r0 - mov.l r0,@r1 + mov.l SDMR02000_A, r1 + mov.l SDMR02000_D, r0 + mov.l r0, @r1
- mov.l SDMR00B08_A,r1 - mov.l SDMR00B08_D,r0 - mov.l r0,@r1 + mov.l SDMR00B08_A, r1 + mov.l SDMR00B08_D, r0 + mov.l r0, @r1
- mov.l SCR4_A,r1 - mov.l SCR4_D4,r0 - mov.l r0,@r1 + mov.l SCR4_A, r1 + mov.l SCR4_D4, r0 + mov.l r0, @r1
nop nop nop nop
nop nop nop nop
- mov.l SDMR00308_A,r1 - mov.l SDMR00308_D,r0 - mov.l r0,@r1 + mov.l SDMR00308_A, r1 + mov.l SDMR00308_D, r0 + mov.l r0, @r1
- mov.l MIMC_A,r1 - mov.l MIMC_D3,r0 - mov.l r0,@r1 + mov.l MIMC_A, r1 + mov.l MIMC_D3, r0 + mov.l r0, @r1
- mov.l SCR4_A,r1 - mov.l SCR4_D1,r0 - mov.l DELAY60_D,r3 + mov.l SCR4_A, r1 + mov.l SCR4_D1, r0 + mov.l DELAY60_D, r3
delay_loop_60: - mov.l r0,@r1 + mov.l r0, @r1 dt r3 bf delay_loop_60 nop
- mov.l CCR_A, r1 /* Address of Cache Control Register */ - mov.l CCR_CACHE_D_2, r0 - mov.l r0, @r1 + mov.l CCR_A, r1 /* Address of Cache Control Register */ + mov.l CCR_CACHE_D_2, r0 + mov.l r0, @r1
bsc_init: mov.l BCR_A, r1 @@ -172,9 +172,9 @@ bsc_init: mov.l CS0BCR_D, r0 mov.l r0, @r1
- mov.l CS1BCR_A,r1 - mov.l CS1BCR_D,r0 - mov.l r0,@r1 + mov.l CS1BCR_A, r1 + mov.l CS1BCR_D, r0 + mov.l r0, @r1
mov.l CS2BCR_A, r1 mov.l CS2BCR_D, r0 @@ -224,27 +224,27 @@ bsc_init: mov.l CS6PCR_D, r0 mov.l r0, @r1
- mov.l DELAY200_D,r3 + mov.l DELAY200_D, r3
delay_loop_200: dt r3 bf delay_loop_200 nop
- mov.l PSEL0_A,r1 - mov.l PSEL0_D,r0 - mov.w r0,@r1 + mov.l PSEL0_A, r1 + mov.l PSEL0_D, r0 + mov.w r0, @r1
- mov.l PSEL1_A,r1 - mov.l PSEL1_D,r0 - mov.w r0,@r1 + mov.l PSEL1_A, r1 + mov.l PSEL1_D, r0 + mov.w r0, @r1
- mov.l ICR0_A,r1 - mov.l ICR0_D,r0 - mov.l r0,@r1 + mov.l ICR0_A, r1 + mov.l ICR0_D, r0 + mov.l r0, @r1
stc sr, r0 /* BL bit off(init=ON) */ - mov.l SR_MASK_D, r1 + mov.l SR_MASK_D, r1 and r1, r0 ldc r0, sr
@@ -321,7 +321,7 @@ CS4BCR_D: .long 0x77777670 CS5BCR_D: .long 0x77777670 CS6BCR_D: .long 0x77777670 CS0WCR_D: .long 0x7777770F -CS1WCR_D: .long 0x22000002 +CS1WCR_D: .long 0x22000002 CS2WCR_D: .long 0x7777770F CS4WCR_D: .long 0x7777770F CS5WCR_D: .long 0x7777770F diff --git a/board/renesas/sh7785lcr/lowlevel_init.S b/board/renesas/sh7785lcr/lowlevel_init.S index 50e1789..4cb1d9d 100644 --- a/board/renesas/sh7785lcr/lowlevel_init.S +++ b/board/renesas/sh7785lcr/lowlevel_init.S @@ -305,7 +305,7 @@ CS4WCR_D: .long 0x00101012 CS_USB_BCR_D: .long 0x11111200 CS_USB_WCR_D: .long 0x00020004
-/* SD setting : 32bit mode = CS3, 29bit mode = CS6 */ +/* SD setting : 32bit mode = CS3, 29bit mode = CS6 */ CS_SD_BCR_D: .long 0x00000300 CS_SD_WCR_D: .long 0x00030108
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- board/mpr2/lowlevel_init.S | 49 +++------- board/ms7722se/lowlevel_init.S | 160 ++++++++--------------------- board/ms7750se/lowlevel_init.S | 64 ++++-------- board/renesas/MigoR/lowlevel_init.S | 141 ++++++++------------------ board/renesas/ap325rxa/lowlevel_init.S | 121 ++++++---------------- board/renesas/r2dplus/lowlevel_init.S | 85 ++++----------- board/renesas/r7780mp/lowlevel_init.S | 122 ++++++---------------- board/renesas/rsk7203/lowlevel_init.S | 129 ++++++----------------- board/renesas/sh7763rdp/lowlevel_init.S | 172 +++++++++---------------------- board/renesas/sh7785lcr/lowlevel_init.S | 28 +----- include/asm-sh/macro.h | 52 +++++++++ 11 files changed, 338 insertions(+), 785 deletions(-) create mode 100644 include/asm-sh/macro.h
diff --git a/board/mpr2/lowlevel_init.S b/board/mpr2/lowlevel_init.S index 187b5bb..5f02bd4 100644 --- a/board/mpr2/lowlevel_init.S +++ b/board/mpr2/lowlevel_init.S @@ -22,6 +22,7 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#include <asm/macro.h>
@@ -33,59 +34,35 @@ lowlevel_init: /* * Set frequency multipliers and dividers in FRQCR. */ - mov.l WTCSR_A, r1 - mov.l WTCSR_D, r0 - mov.w r0, @r1 + write16 WTCSR_A, WTCSR_D
- mov.l WTCNT_A, r1 - mov.l WTCNT_D, r0 - mov.w r0, @r1 + write16 WTCNT_A, WTCNT_D
- mov.l FRQCR_A, r1 - mov.l FRQCR_D, r0 - mov.w r0, @r1 + write16 FRQCR_A, FRQCR_D
/* * Setup CS0 (Flash). */ - mov.l CS0BCR_A, r1 - mov.l CS0BCR_D, r0 - mov.l r0, @r1 + write32 CS0BCR_A, CS0BCR_D
- mov.l CS0WCR_A, r1 - mov.l CS0WCR_D, r0 - mov.l r0, @r1 + write32 CS0WCR_A, CS0WCR_D
/* * Setup CS3 (SDRAM). */ - mov.l CS3BCR_A, r1 - mov.l CS3BCR_D, r0 - mov.l r0, @r1 + write32 CS3BCR_A, CS3BCR_D
- mov.l CS3WCR_A, r1 - mov.l CS3WCR_D, r0 - mov.l r0, @r1 + write32 CS3WCR_A, CS3WCR_D
- mov.l SDCR_A, r1 - mov.l SDCR_D1, r0 - mov.l r0, @r1 + write32 SDCR_A, SDCR_D1
- mov.l RTCSR_A, r1 - mov.l RTCSR_D, r0 - mov.l r0, @r1 + write32 RTCSR_A, RTCSR_D
- mov.l RTCNT_A, r1 - mov.l RTCNT_D, r0 - mov.l r0, @r1 + write32 RTCNT_A, RTCNT_D
- mov.l RTCOR_A, r1 - mov.l RTCOR_D, r0 - mov.l r0, @r1 + write32 RTCOR_A, RTCOR_D
- mov.l SDCR_A, r1 - mov.l SDCR_D2, r0 - mov.l r0, @r1 + write32 SDCR_A, SDCR_D2
mov.l SDMR3_A, r1 mov.l SDMR3_D, r0 diff --git a/board/ms7722se/lowlevel_init.S b/board/ms7722se/lowlevel_init.S index 3e887cf..9144e10 100644 --- a/board/ms7722se/lowlevel_init.S +++ b/board/ms7722se/lowlevel_init.S @@ -27,6 +27,7 @@ #include <version.h>
#include <asm/processor.h> +#include <asm/macro.h>
/* * Board specific low level init code, called _very_ early in the @@ -43,165 +44,94 @@
lowlevel_init:
- /* Address of Cache Control Register */ - mov.l CCR_A, r1 - /*Instruction Cache Invalidate */ - mov.l CCR_D, r0 - mov.l r0, @r1 + /* + * Cache Control Register + * Instruction Cache Invalidate + */ + write32 CCR_A, CCR_D
- /* Address of MMU Control Register */ - mov.l MMUCR_A, r1 - /* TI == TLB Invalidate bit */ - mov.l MMUCR_D, r0 - mov.l r0, @r1 + /* + * Address of MMU Control Register + * TI == TLB Invalidate bit + */ + write32 MMUCR_A, MMUCR_D
/* Address of Power Control Register 0 */ - mov.l MSTPCR0_A, r1 - mov.l MSTPCR0_D, r0 - mov.l r0, @r1 + write32 MSTPCR0_A, MSTPCR0_D
/* Address of Power Control Register 2 */ - mov.l MSTPCR2_A, r1 - mov.l MSTPCR2_D, r0 - mov.l r0, @r1 + write32 MSTPCR2_A, MSTPCR2_D
- mov.l SBSCR_A, r1 - mov.w SBSCR_D, r0 - mov.w r0, @r1 + write16 SBSCR_A, SBSCR_D
- mov.l PSCR_A, r1 - mov.w PSCR_D, r0 - mov.w r0, @r1 + write16 PSCR_A, PSCR_D
/* 0xA4520004 (Watchdog Control / Status Register) */ -! mov.l RWTCSR_A, r1 - /* 0xA507 -> timer_STOP/WDT_CLK=max */ -! mov.w RWTCSR_D_1, r0 -! mov.w r0, @r1 +! write16 RWTCSR_A, RWTCSR_D_1 /* 0xA507 -> timer_STOP/WDT_CLK=max */
/* 0xA4520000 (Watchdog Count Register) */ - mov.l RWTCNT_A, r1 - /*0x5A00 -> Clear */ - mov.w RWTCNT_D, r0 - mov.w r0, @r1 + write16 RWTCNT_A, RWTCNT_D /*0x5A00 -> Clear */
/* 0xA4520004 (Watchdog Control / Status Register) */ - mov.l RWTCSR_A, r1 - /* 0xA504 -> timer_STOP/CLK=500ms */ - mov.w RWTCSR_D_2, r0 - mov.w r0, @r1 + write16 RWTCSR_A, RWTCSR_D_2 /* 0xA504 -> timer_STOP/CLK=500ms */
/* 0xA4150000 Frequency control register */ - mov.l FRQCR_A, r1 - mov.l FRQCR_D, r0 ! - mov.l r0, @r1 + write32 FRQCR_A, FRQCR_D
- mov.l CCR_A, r1 - mov.l CCR_D_2, r0 - mov.l r0, @r1 + write32 CCR_A, CCR_D_2
bsc_init:
- mov.l PSELA_A, r1 - mov.w PSELA_D, r0 - mov.w r0, @r1 + write16 PSELA_A, PSELA_D
- mov.l DRVCR_A, r1 - mov.w DRVCR_D, r0 - mov.w r0, @r1 + write16 DRVCR_A, DRVCR_D
- mov.l PCCR_A, r1 - mov.w PCCR_D, r0 - mov.w r0, @r1 + write16 PCCR_A, PCCR_D
- mov.l PECR_A, r1 - mov.w PECR_D, r0 - mov.w r0, @r1 + write16 PECR_A, PECR_D
- mov.l PJCR_A, r1 - mov.w PJCR_D, r0 - mov.w r0, @r1 + write16 PJCR_A, PJCR_D
- mov.l PXCR_A, r1 - mov.w PXCR_D, r0 - mov.w r0, @r1 + write16 PXCR_A, PXCR_D
- mov.l CMNCR_A, r1 ! CMNCR address -> R1 - mov.l CMNCR_D, r0 ! CMNCR data -> R0 - mov.l r0, @r1 ! CMNCR set + write32 CMNCR_A, CMNCR_D
- mov.l CS0BCR_A, r1 ! CS0BCR address -> R1 - mov.l CS0BCR_D, r0 ! CS0BCR data -> R0 - mov.l r0, @r1 ! CS0BCR set + write32 CS0BCR_A, CS0BCR_D
- mov.l CS2BCR_A, r1 ! CS2BCR address -> R1 - mov.l CS2BCR_D, r0 ! CS2BCR data -> R0 - mov.l r0, @r1 ! CS2BCR set + write32 CS2BCR_A, CS2BCR_D
- mov.l CS4BCR_A, r1 ! CS4BCR address -> R1 - mov.l CS4BCR_D, r0 ! CS4BCR data -> R0 - mov.l r0, @r1 ! CS4BCR set + write32 CS4BCR_A, CS4BCR_D
- mov.l CS5ABCR_A, r1 ! CS5ABCR address -> R1 - mov.l CS5ABCR_D, r0 ! CS5ABCR data -> R0 - mov.l r0, @r1 ! CS5ABCR set + write32 CS5ABCR_A, CS5ABCR_D
- mov.l CS5BBCR_A, r1 ! CS5BBCR address -> R1 - mov.l CS5BBCR_D, r0 ! CS5BBCR data -> R0 - mov.l r0, @r1 ! CS5BBCR set + write32 CS5BBCR_A, CS5BBCR_D
- mov.l CS6ABCR_A, r1 ! CS6ABCR address -> R1 - mov.l CS6ABCR_D, r0 ! CS6ABCR data -> R0 - mov.l r0, @r1 ! CS6ABCR set + write32 CS6ABCR_A, CS6ABCR_D
- mov.l CS0WCR_A, r1 ! CS0WCR address -> R1 - mov.l CS0WCR_D, r0 ! CS0WCR data -> R0 - mov.l r0, @r1 ! CS0WCR set + write32 CS0WCR_A, CS0WCR_D
- mov.l CS2WCR_A, r1 ! CS2WCR address -> R1 - mov.l CS2WCR_D, r0 ! CS2WCR data -> R0 - mov.l r0, @r1 ! CS2WCR set + write32 CS2WCR_A, CS2WCR_D
- mov.l CS4WCR_A, r1 ! CS4WCR address -> R1 - mov.l CS4WCR_D, r0 ! CS4WCR data -> R0 - mov.l r0, @r1 ! CS4WCR set + write32 CS4WCR_A, CS4WCR_D
- mov.l CS5AWCR_A, r1 ! CS5AWCR address -> R1 - mov.l CS5AWCR_D, r0 ! CS5AWCR data -> R0 - mov.l r0, @r1 ! CS5AWCR set + write32 CS5AWCR_A, CS5AWCR_D
- mov.l CS5BWCR_A, r1 ! CS5BWCR address -> R1 - mov.l CS5BWCR_D, r0 ! CS5BWCR data -> R0 - mov.l r0, @r1 ! CS5BWCR set + write32 CS5BWCR_A, CS5BWCR_D
- mov.l CS6AWCR_A, r1 ! CS6AWCR address -> R1 - mov.l CS6AWCR_D, r0 ! CS6AWCR data -> R0 - mov.l r0, @r1 ! CS6AWCR set + write32 CS6AWCR_A, CS6AWCR_D
! SDRAM initialization - mov.l SDCR_A, r1 ! SB_SDCR address -> R1 - mov.l SDCR_D, r0 ! SB_SDCR data -> R0 - mov.l r0, @r1 ! SB_SDCR set + write32 SDCR_A, SDCR_D
- mov.l SDWCR_A, r1 ! SB_SDWCR address -> R1 - mov.l SDWCR_D, r0 ! SB_SDWCR data -> R0 - mov.l r0, @r1 ! SB_SDWCR set + write32 SDWCR_A, SDWCR_D
- mov.l SDPCR_A, r1 ! SB_SDPCR address -> R1 - mov.l SDPCR_D, r0 ! SB_SDPCR data -> R0 - mov.l r0, @r1 ! SB_SDPCR set + write32 SDPCR_A, SDPCR_D
- mov.l RTCOR_A, r1 ! SB_RTCOR address -> R1 - mov.l RTCOR_D, r0 ! SB_RTCOR data -> R0 - mov.l r0, @r1 ! SB_RTCOR set + write32 RTCOR_A, RTCOR_D
- mov.l RTCSR_A, r1 ! SB_RTCSR address -> R1 - mov.l RTCSR_D, r0 ! SB_RTCSR data -> R0 - mov.l r0, @r1 ! SB_RTCSR set + write32 RTCSR_A, RTCSR_D
- mov.l SDMR3_A, r1 ! SDMR3 address -> R1 - mov #0x00, r0 ! SDMR3 data -> R0 - mov.b r0, @r1 ! SDMR3 set + write8 SDMR3_A, #0x00
diff --git a/board/ms7750se/lowlevel_init.S b/board/ms7750se/lowlevel_init.S index de05dd9..7108019 100644 --- a/board/ms7750se/lowlevel_init.S +++ b/board/ms7750se/lowlevel_init.S @@ -29,6 +29,7 @@ #include <version.h>
#ifdef CONFIG_CPU_SH7751 #define BCR2_D_VALUE 0x2FFC /* Area 1-6 width: 32/32/32/32/32/16 */ @@ -65,61 +66,37 @@
lowlevel_init:
- mov.l CCR_A, r1 ! CCR Address - mov.l CCR_D_DISABLE, r0 ! CCR Data - mov.l r0, @r1 + write32 CCR_A, CCR_D_DISABLE
init_bsc: - mov.l FRQCR_A, r1 /* FRQCR Address */ - mov.l FRQCR_D, r0 /* FRQCR Data */ - mov.w r0, @r1 + write16 FRQCR_A, FRQCR_D
- mov.l BCR1_A, r1 /* BCR1 Address */ - mov.l BCR1_D, r0 /* BCR1 Data */ - mov.l r0, @r1 + write32 BCR1_A, BCR1_D
- mov.l BCR2_A, r1 /* BCR2 Address */ - mov.l BCR2_D, r0 /* BCR2 Data */ - mov.w r0, @r1 + write16 BCR2_A, BCR2_D
- mov.l WCR1_A, r1 /* WCR1 Address */ - mov.l WCR1_D, r0 /* WCR1 Data */ - mov.l r0, @r1 + write32 WCR1_A, WCR1_D
- mov.l WCR2_A, r1 /* WCR2 Address */ - mov.l WCR2_D, r0 /* WCR2 Data */ - mov.l r0, @r1 + write32 WCR2_A, WCR2_D
- mov.l WCR3_A, r1 /* WCR3 Address */ - mov.l WCR3_D, r0 /* WCR3 Data */ - mov.l r0, @r1 + write32 WCR3_A, WCR3_D
- mov.l MCR_A, r1 /* MCR Address */ - mov.l MCR_D1, r0 /* MCR Data1 */ - mov.l r0, @r1 + write32 MCR_A, MCR_D1
- mov.l SDMR3_A, r1 /* Set SDRAM mode */ - mov #0, r0 - mov.b r0, @r1 + /* Set SDRAM mode */ + write8 SDMR3_A, #0
- mov.l RTCNT_A, r1 /* RTCNT Address */ - mov.l RTCNT_D, r0 /* RTCNT Data */ - mov.w r0, @r1 + write16 RTCNT_A, RTCNT_D
- mov.l RTCOR_A, r1 /* RTCOR Address */ - mov.l RTCOR_D, r0 /* RTCOR Data */ - mov.w r0, @r1 + write16 RTCOR_A, RTCOR_D
- mov.l RTCSR_A, r1 /* RTCSR Address */ - mov.l RTCSR_D, r0 /* RTCSR Data */ - mov.w r0, @r1 + write16 RTCSR_A, RTCSR_D + + write16 RFCR_A, RFCR_D
- mov.l RFCR_A, r1 /* RFCR Address */ - mov.l RFCR_D, r0 /* RFCR Data */ - mov.w r0, @r1 /* Clear reflesh counter */ /* Wait DRAM refresh 30 times */ mov #30, r3 1: @@ -128,13 +105,10 @@ init_bsc: cmp/hi r3, r2 bf 1b
- mov.l MCR_A, r1 /* MCR Address */ - mov.l MCR_D2, r0 /* MCR Data2 */ - mov.l r0, @r1 + write32 MCR_A, MCR_D2
rts nop diff --git a/board/renesas/MigoR/lowlevel_init.S b/board/renesas/MigoR/lowlevel_init.S index 13c83bf..1da603a 100644 --- a/board/renesas/MigoR/lowlevel_init.S +++ b/board/renesas/MigoR/lowlevel_init.S @@ -27,6 +27,7 @@ #include <version.h>
/* * Board specific low level init code, called _very_ early in the @@ -42,139 +43,81 @@ .align 2
lowlevel_init: - mov.l CCR_A, r1 ! Address of Cache Control Register - mov.l CCR_D, r0 ! Instruction Cache Invalidate - mov.l r0, @r1 + write32 CCR_A, CCR_D ! Address of Cache Control Register + ! Instruction Cache Invalidate
- mov.l MMUCR_A, r1 ! Address of MMU Control Register - mov.l MMUCR_D, r0 ! TI == TLB Invalidate bit - mov.l r0, @r1 + write32 MMUCR_A, MMUCR_D ! Address of MMU Control Register + ! TI == TLB Invalidate bit
- mov.l MSTPCR0_A, r1 ! Address of Power Control Register 0 - mov.l MSTPCR0_D, r0 ! - mov.l r0, @r1 + write32 MSTPCR0_A, MSTPCR0_D ! Address of Power Control Register 0
- mov.l MSTPCR2_A, r1 ! Address of Power Control Register 2 - mov.l MSTPCR2_D, r0 ! - mov.l r0, @r1 + write32 MSTPCR2_A, MSTPCR2_D ! Address of Power Control Register 2
- mov.l PFC_PULCR_A, r1 - mov.w PFC_PULCR_D, r0 - mov.w r0,@r1 + write16 PFC_PULCR_A, PFC_PULCR_D
- mov.l PFC_DRVCR_A, r1 - mov.w PFC_DRVCR_D, r0 - mov.w r0, @r1 + write16 PFC_DRVCR_A, PFC_DRVCR_D
- mov.l SBSCR_A, r1 ! - mov.w SBSCR_D, r0 ! - mov.w r0, @r1 + write16 SBSCR_A, SBSCR_D
- mov.l PSCR_A, r1 ! - mov.w PSCR_D, r0 ! - mov.w r0, @r1 + write16 PSCR_A, PSCR_D
- mov.l RWTCSR_A, r1 ! 0xA4520004 (Watchdog Control / Status Register) - mov.w RWTCSR_D_1, r0 ! 0xA507 -> timer_STOP/WDT_CLK=max - mov.w r0, @r1 + write16 RWTCSR_A, RWTCSR_D_1 ! 0xA4520004 (Watchdog Control / Status Register) + ! 0xA507 -> timer_STOP / WDT_CLK = max
- mov.l RWTCNT_A, r1 ! 0xA4520000 (Watchdog Count Register) - mov.w RWTCNT_D, r0 ! 0x5A00 -> Clear - mov.w r0, @r1 + write16 RWTCNT_A, RWTCNT_D ! 0xA4520000 (Watchdog Count Register) + ! 0x5A00 -> Clear
- mov.l RWTCSR_A, r1 ! 0xA4520004 (Watchdog Control / Status Register) - mov.w RWTCSR_D_2, r0 ! 0xA504 -> timer_STOP/CLK=500ms - mov.w r0, @r1 + write16 RWTCSR_A, RWTCSR_D_2 ! 0xA4520004 (Watchdog Control / Status Register) + ! 0xA504 -> timer_STOP / CLK = 500ms
- mov.l DLLFRQ_A, r1 ! 20080115 - mov.l DLLFRQ_D, r0 ! 20080115 - mov.l r0, @r1 + write32 DLLFRQ_A, DLLFRQ_D ! 20080115 + ! 20080115
- mov.l FRQCR_A, r1 ! 0xA4150000 Frequency control register - mov.l FRQCR_D, r0 ! 20080115 - mov.l r0, @r1 + write32 FRQCR_A, FRQCR_D ! 0xA4150000 Frequency control register + ! 20080115
- mov.l CCR_A, r1 ! Address of Cache Control Register - mov.l CCR_D_2, r0 ! ?? - mov.l r0, @r1 + write32 CCR_A, CCR_D_2 ! Address of Cache Control Register + ! ??
bsc_init: - mov.l CMNCR_A, r1 ! CMNCR address -> R1 - mov.l CMNCR_D, r0 ! CMNCR data -> R0 - mov.l r0, @r1 ! CMNCR set + write32 CMNCR_A, CMNCR_D
- mov.l RTCNT_A, r1 ! SB_RTCNT address -> R1 - mov.l RTCNT_D, r0 ! SB_RTCNT data -> R0 - mov.l r0, @r1 + write32 RTCNT_A, RTCNT_D
- mov.l RFCR_A, r1 ! SB_RFCR address -> R1 - mov.l RFCR_D, r0 ! SB_RFCR data -> R0 - mov.l r0, @r1 + write32 RFCR_A, RFCR_D
diff --git a/board/renesas/ap325rxa/lowlevel_init.S b/board/renesas/ap325rxa/lowlevel_init.S index 558e779..b32f491 100644 --- a/board/renesas/ap325rxa/lowlevel_init.S +++ b/board/renesas/ap325rxa/lowlevel_init.S @@ -23,6 +23,7 @@ #include <config.h> #include <version.h> #include <asm/processor.h> +#include <asm/macro.h>
/* * Board specific low level init code, called _very_ early in the @@ -38,113 +39,59 @@ .align 2
lowlevel_init: - mov.l DRVCRA_A, r1 - mov.l DRVCRA_D, r0 - mov.w r0, @r1 + write16 DRVCRA_A, DRVCRA_D
- mov.l DRVCRB_A, r1 - mov.l DRVCRB_D, r0 - mov.w r0, @r1 + write16 DRVCRB_A, DRVCRB_D
- mov.l RWTCSR_A, r1 - mov.l RWTCSR_D1, r0 - mov.w r0, @r1 + write16 RWTCSR_A, RWTCSR_D1
- mov.l RWTCNT_A, r1 - mov.l RWTCNT_D, r0 - mov.w r0, @r1 + write16 RWTCNT_A, RWTCNT_D
- mov.l RWTCSR_A, r1 - mov.l RWTCSR_D2, r0 - mov.w r0, @r1 + write16 RWTCSR_A, RWTCSR_D2
- mov.l FRQCR_A, r1 - mov.l FRQCR_D, r0 - mov.l r0, @r1 + write32 FRQCR_A, FRQCR_D
- mov.l CMNCR_A, r1 - mov.l CMNCR_D, r0 - mov.l r0, @r1 + write32 CMNCR_A, CMNCR_D
- mov.l CS4BCR_A, r1 - mov.l CS4BCR_D, r0 - mov.l r0, @r1 + write32 CS4BCR_A, CS4BCR_D
- mov.l CS5ABCR_A, r1 - mov.l CS5ABCR_D, r0 - mov.l r0, @r1 + write32 CS5ABCR_A, CS5ABCR_D
- mov.l CS5BBCR_A, r1 - mov.l CS5BBCR_D, r0 - mov.l r0, @r1 + write32 CS5BBCR_A, CS5BBCR_D
- mov.l CS6ABCR_A, r1 - mov.l CS6ABCR_D, r0 - mov.l r0, @r1 + write32 CS6ABCR_A, CS6ABCR_D
- mov.l CS6BBCR_A, r1 - mov.l CS6BBCR_D, r0 - mov.l r0, @r1 + write32 CS6BBCR_A, CS6BBCR_D
- mov.l CS4WCR_A, r1 - mov.l CS4WCR_D, r0 - mov.l r0, @r1 + write32 CS4WCR_A, CS4WCR_D
- mov.l CS5AWCR_A, r1 - mov.l CS5AWCR_D, r0 - mov.l r0, @r1 + write32 CS5AWCR_A, CS5AWCR_D
- mov.l CS5BWCR_A, r1 - mov.l CS5BWCR_D, r0 - mov.l r0, @r1 + write32 CS5BWCR_A, CS5BWCR_D
- mov.l CS6AWCR_A, r1 - mov.l CS6AWCR_D, r0 - mov.l r0, @r1 + write32 CS6AWCR_A, CS6AWCR_D
- mov.l CS6BWCR_A, r1 - mov.l CS6BWCR_D, r0 - mov.l r0, @r1 + write32 CS6BWCR_A, CS6BWCR_D
- mov.l SBSC_SDCR_A, r1 - mov.l SBSC_SDCR_D1, r0 - mov.l r0, @r1 + write32 SBSC_SDCR_A, SBSC_SDCR_D1
- mov.l SBSC_SDWCR_A, r1 - mov.l SBSC_SDWCR_D, r0 - mov.l r0, @r1 + write32 SBSC_SDWCR_A, SBSC_SDWCR_D
- mov.l SBSC_SDPCR_A, r1 - mov.l SBSC_SDPCR_D, r0 - mov.l r0, @r1 + write32 SBSC_SDPCR_A, SBSC_SDPCR_D
- mov.l SBSC_RTCSR_A, r1 - mov.l SBSC_RTCSR_D, r0 - mov.l r0, @r1 + write32 SBSC_RTCSR_A, SBSC_RTCSR_D
- mov.l SBSC_RTCNT_A, r1 - mov.l SBSC_RTCNT_D, r0 - mov.l r0, @r1 + write32 SBSC_RTCNT_A, SBSC_RTCNT_D
- mov.l SBSC_RTCOR_A, r1 - mov.l SBSC_RTCOR_D, r0 - mov.l r0, @r1 + write32 SBSC_RTCOR_A, SBSC_RTCOR_D
- mov.l SBSC_SDMR3_A1, r1 - mov.l SBSC_SDMR3_D, r0 - mov.b r0, @r1 + write8 SBSC_SDMR3_A1, SBSC_SDMR3_D
- mov.l SBSC_SDMR3_A2, r1 - mov.l SBSC_SDMR3_D, r0 - mov.b r0, @r1 + write8 SBSC_SDMR3_A2, SBSC_SDMR3_D
mov.l SLEEP_CNT, r1 2: tst r1, r1 @@ -152,17 +99,11 @@ lowlevel_init: bf/s 2b dt r1
- mov.l SBSC_SDMR3_A3, r1 - mov.l SBSC_SDMR3_D, r0 - mov.b r0, @r1 + write8 SBSC_SDMR3_A3, SBSC_SDMR3_D
- mov.l SBSC_SDCR_A, r1 - mov.l SBSC_SDCR_D2, r0 - mov.l r0, @r1 + write32 SBSC_SDCR_A, SBSC_SDCR_D2
- mov.l CCR_A, r1 - mov.l CCR_D, r0 - mov.l r0, @r1 + write32 CCR_A, CCR_D
diff --git a/board/renesas/r2dplus/lowlevel_init.S b/board/renesas/r2dplus/lowlevel_init.S index a057370..2f6a9b7 100644 --- a/board/renesas/r2dplus/lowlevel_init.S +++ b/board/renesas/r2dplus/lowlevel_init.S @@ -8,6 +8,7 @@ #include <version.h>
.global lowlevel_init .text @@ -15,73 +16,39 @@
lowlevel_init:
- mov.l CCR_A, r1 - mov.l CCR_D_D, r0 - mov.l r0, @r1 + write32 CCR_A, CCR_D_D
- mov.l MMUCR_A, r1 - mov.l MMUCR_D, r0 - mov.l r0, @r1 + write32 MMUCR_A, MMUCR_D
- mov.l BCR1_A, r1 - mov.l BCR1_D, r0 - mov.l r0, @r1 + write32 BCR1_A, BCR1_D
- mov.l BCR2_A, r1 - mov.l BCR2_D, r0 - mov.w r0, @r1 + write16 BCR2_A, BCR2_D
- mov.l BCR3_A, r1 - mov.l BCR3_D, r0 - mov.w r0, @r1 + write16 BCR3_A, BCR3_D
- mov.l BCR4_A, r1 - mov.l BCR4_D, r0 - mov.l r0, @r1 + write32 BCR4_A, BCR4_D
- mov.l WCR1_A, r1 - mov.l WCR1_D, r0 - mov.l r0, @r1 + write32 WCR1_A, WCR1_D
- mov.l WCR2_A, r1 - mov.l WCR2_D, r0 - mov.l r0, @r1 + write32 WCR2_A, WCR2_D
- mov.l WCR3_A, r1 - mov.l WCR3_D, r0 - mov.l r0, @r1 + write32 WCR3_A, WCR3_D
- mov.l PCR_A, r1 - mov.l PCR_D, r0 - mov.w r0, @r1 + write16 PCR_A, PCR_D
- mov.l LED_A, r1 - mov #0xff, r0 - mov.w r0, @r1 + write16 LED_A, #0xff
- mov.l MCR_A, r1 - mov.l MCR_D1, r0 - mov.l r0, @r1 + write32 MCR_A, MCR_D1
- mov.l RTCNT_A, r1 - mov.l RTCNT_D, r0 - mov.w r0, @r1 + write16 RTCNT_A, RTCNT_D
- mov.l RTCOR_A, r1 - mov.l RTCOR_D, r0 - mov.w r0, @r1 + write16 RTCOR_A, RTCOR_D
- mov.l RFCR_A, r1 - mov.l RFCR_D, r0 - mov.w r0, @r1 + write16 RFCR_A, RFCR_D
- mov.l RTCSR_A, r1 - mov.l RTCSR_D, r0 - mov.w r0, @r1 + write16 RTCSR_A, RTCSR_D
- mov.l SDMR3_A, r1 - mov #0x55, r0 - mov.b r0, @r1 + write8 SDMR3_A, #0x55
/* Wait DRAM refresh 30 times */ mov.l RFCR_A, r1 @@ -92,21 +59,13 @@ lowlevel_init: cmp/hi r3, r2 bf 1b
- mov.l MCR_A, r1 - mov.l MCR_D2, r0 - mov.l r0, @r1 + write32 MCR_A, MCR_D2
- mov.l SDMR3_A, r1 - mov #0, r0 - mov.b r0, @r1 + write8 SDMR3_A, #0
- mov.l IRLMASK_A, r1 - mov.l IRLMASK_D, r0 - mov.l r0, @r1 + write32 IRLMASK_A, IRLMASK_D
- mov.l CCR_A, r1 - mov.l CCR_D_E, r0 - mov.l r0, @r1 + write32 CCR_A, CCR_D_E
rts nop diff --git a/board/renesas/r7780mp/lowlevel_init.S b/board/renesas/r7780mp/lowlevel_init.S index 0df8c84..bbea621 100644 --- a/board/renesas/r7780mp/lowlevel_init.S +++ b/board/renesas/r7780mp/lowlevel_init.S @@ -22,6 +22,7 @@ #include <config.h> #include <version.h> #include <asm/processor.h> +#include <asm/macro.h>
/* * Board specific low level init code, called _very_ early in the @@ -38,63 +39,36 @@
lowlevel_init:
- mov.l CCR_A, r1 /* Address of Cache Control Register */ - mov.l CCR_D, r0 /* Instruction Cache Invalidate */ - mov.l r0, @r1 + write32 CCR_A, CCR_D /* Address of Cache Control Register */ + /* Instruction Cache Invalidate */
- mov.l FRQCR_A, r1 /* Frequency control register */ - mov.l FRQCR_D, r0 - mov.l r0, @r1 + write32 FRQCR_A, FRQCR_D /* Frequency control register */
/* pin_multi_setting */ - mov.l BBG_PMMR_A, r1 - mov.l BBG_PMMR_D_PMSR1, r0 - mov.l r0, @r1 + write32 BBG_PMMR_A, BBG_PMMR_D_PMSR1
- mov.l BBG_PMSR1_A, r1 - mov.l BBG_PMSR1_D, r0 - mov.l r0, @r1 + write32 BBG_PMSR1_A, BBG_PMSR1_D
- mov.l BBG_PMMR_A, r1 - mov.l BBG_PMMR_D_PMSR2, r0 - mov.l r0, @r1 + write32 BBG_PMMR_A, BBG_PMMR_D_PMSR2
- mov.l BBG_PMSR2_A, r1 - mov.l BBG_PMSR2_D, r0 - mov.l r0, @r1 + write32 BBG_PMSR2_A, BBG_PMSR2_D
- mov.l BBG_PMMR_A, r1 - mov.l BBG_PMMR_D_PMSR3, r0 - mov.l r0, @r1 + write32 BBG_PMMR_A, BBG_PMMR_D_PMSR3
- mov.l BBG_PMSR3_A, r1 - mov.l BBG_PMSR3_D, r0 - mov.l r0, @r1 + write32 BBG_PMSR3_A, BBG_PMSR3_D
- mov.l BBG_PMMR_A, r1 - mov.l BBG_PMMR_D_PMSR4, r0 - mov.l r0, @r1 + write32 BBG_PMMR_A, BBG_PMMR_D_PMSR4
- mov.l BBG_PMSR4_A, r1 - mov.l BBG_PMSR4_D, r0 - mov.l r0, @r1 + write32 BBG_PMSR4_A, BBG_PMSR4_D
- mov.l BBG_PMMR_A, r1 - mov.l BBG_PMMR_D_PMSRG, r0 - mov.l r0, @r1 + write32 BBG_PMMR_A, BBG_PMMR_D_PMSRG
- mov.l BBG_PMSRG_A, r1 - mov.l BBG_PMSRG_D, r0 - mov.l r0, @r1 + write32 BBG_PMSRG_A, BBG_PMSRG_D
/* cpg_setting */ - mov.l FRQCR_A, r1 - mov.l FRQCR_D, r0 - mov.l r0, @r1 + write32 FRQCR_A, FRQCR_D
- mov.l DLLCSR_A, r1 - mov.l DLLCSR_D, r0 - mov.l r0, @r1 + write32 DLLCSR_A, DLLCSR_D
nop nop @@ -117,69 +91,37 @@ repeat0: nop
/* bsc_setting */ - mov.l MMSELR_A, r1 - mov.l MMSELR_D, r0 - mov.l r0, @r1 + write32 MMSELR_A, MMSELR_D
- mov.l BCR_A, r1 - mov.l BCR_D, r0 - mov.l r0, @r1 + write32 BCR_A, BCR_D
- mov.l CS1BCR_A, r1 - mov.l CS1BCR_D, r0 - mov.l r0, @r1 + write32 CS1BCR_A, CS1BCR_D
- mov.l CS2BCR_A, r1 - mov.l CS2BCR_D, r0 - mov.l r0, @r1 + write32 CS2BCR_A, CS2BCR_D
- mov.l CS5BCR_A, r1 - mov.l CS5BCR_D, r0 - mov.l r0, @r1 + write32 CS5BCR_A, CS5BCR_D
- mov.l CS6BCR_A, r1 - mov.l CS6BCR_D, r0 - mov.l r0, @r1 + write32 CS6BCR_A, CS6BCR_D
- mov.l CS1WCR_A, r1 - mov.l CS1WCR_D, r0 - mov.l r0, @r1 + write32 CS1WCR_A, CS1WCR_D
- mov.l CS2WCR_A, r1 - mov.l CS2WCR_D, r0 - mov.l r0, @r1 + write32 CS2WCR_A, CS2WCR_D
- mov.l CS5WCR_A, r1 - mov.l CS5WCR_D, r0 - mov.l r0, @r1 + write32 CS5WCR_A, CS5WCR_D
- mov.l CS6WCR_A, r1 - mov.l CS6WCR_D, r0 - mov.l r0, @r1 + write32 CS6WCR_A, CS6WCR_D
- mov.l CS5PCR_A, r1 - mov.l CS5PCR_D, r0 - mov.l r0, @r1 + write32 CS5PCR_A, CS5PCR_D
- mov.l CS6PCR_A, r1 - mov.l CS6PCR_D, r0 - mov.l r0, @r1 + write32 CS6PCR_A, CS6PCR_D
/* ddr_setting */ /* wait 200us */ diff --git a/board/renesas/rsk7203/lowlevel_init.S b/board/renesas/rsk7203/lowlevel_init.S index f6a6231..7b9ecd8 100644 --- a/board/renesas/rsk7203/lowlevel_init.S +++ b/board/renesas/rsk7203/lowlevel_init.S @@ -21,6 +21,7 @@ #include <version.h>
@@ -29,140 +30,76 @@
lowlevel_init: /* Cache setting */ - mov.l CCR1_A, r1 - mov.l CCR1_D, r0 - mov.l r0, @r1 + write32 CCR1_A ,CCR1_D
/* ConfigurePortPins */ - mov.l PECRL3_A, r1 - mov.l PECRL3_D, r0 - mov.w r0, @r1 + write16 PECRL3_A, PECRL3_D
- mov.l PCCRL4_A, r1 - mov.l PCCRL4_D0, r0 - mov.w r0, @r1 + write16 PCCRL4_A, PCCRL4_D0
- mov.l PECRL4_A, r1 - mov.l PECRL4_D0, r0 - mov.w r0, @r1 + write16 PECRL4_A, PECRL4_D0
- mov.l PEIORL_A, r1 - mov.l PEIORL_D0, r0 - mov.w r0, @r1 + write16 PEIORL_A, PEIORL_D0
- mov.l PCIORL_A, r1 - mov.l PCIORL_D, r0 - mov.w r0, @r1 + write16 PCIORL_A, PCIORL_D
- mov.l PFCRH2_A, r1 - mov.l PFCRH2_D, r0 - mov.w r0, @r1 + write16 PFCRH2_A, PFCRH2_D
- mov.l PFCRH3_A, r1 - mov.l PFCRH3_D, r0 - mov.w r0, @r1 + write16 PFCRH3_A, PFCRH3_D
- mov.l PFCRH1_A, r1 - mov.l PFCRH1_D, r0 - mov.w r0, @r1 + write16 PFCRH1_A, PFCRH1_D
- mov.l PFIORH_A, r1 - mov.l PFIORH_D, r0 - mov.w r0, @r1 + write16 PFIORH_A, PFIORH_D
- mov.l PECRL1_A, r1 - mov.l PECRL1_D0, r0 - mov.w r0, @r1 + write16 PECRL1_A, PECRL1_D0
- mov.l PEIORL_A, r1 - mov.l PEIORL_D1, r0 - mov.w r0, @r1 + write16 PEIORL_A, PEIORL_D1
/* Configure Operating Frequency */ - mov.l WTCSR_A, r1 - mov.l WTCSR_D0, r0 - mov.w r0, @r1 + write16 WTCSR_A, WTCSR_D0
- mov.l WTCSR_A, r1 - mov.l WTCSR_D1, r0 - mov.w r0, @r1 + write16 WTCSR_A, WTCSR_D1
/* Set clock mode*/ - mov.l FRQCR_A, r1 - mov.l FRQCR_D, r0 - mov.w r0, @r1 + write16 FRQCR_A, FRQCR_D
/* Configure Bus And Memory */ init_bsc_cs0: - mov.l PCCRL4_A, r1 - mov.l PCCRL4_D1, r0 - mov.w r0, @r1 + write16 PCCRL4_A, PCCRL4_D1
- mov.l PECRL1_A, r1 - mov.l PECRL1_D1, r0 - mov.w r0, @r1 + write16 PECRL1_A, PECRL1_D1
- mov.l SC0BCR_A, r1 - mov.l SC0BCR_D, r0 - mov.l r0, @r1 + write32 SC0BCR_A, SC0BCR_D
init_bsc_cs1: - mov.l PECRL4_A, r1 - mov.l PECRL4_D1, r0 - mov.w r0, @r1 + write16 PECRL4_A, PECRL4_D1
init_sdram: - mov.l PCCRL2_A, r1 - mov.l PCCRL2_D, r0 - mov.w r0, @r1 + write16 PCCRL2_A, PCCRL2_D
- mov.l PCCRL4_A, r1 - mov.l PCCRL4_D2, r0 - mov.w r0, @r1 + write16 PCCRL4_A, PCCRL4_D2
- mov.l PCCRL1_A, r1 - mov.l PCCRL1_D, r0 - mov.w r0, @r1 + write16 PCCRL1_A, PCCRL1_D
- mov.l PCCRL3_A, r1 - mov.l PCCRL3_D, r0 - mov.w r0, @r1 + write16 PCCRL3_A, PCCRL3_D
- mov.l SDCR_A, r1 - mov.l SDCR_D, r0 - mov.l r0, @r1 + write32 SDCR_A, SDCR_D
/* wait 200us */ mov.l REPEAT_D, r3 diff --git a/board/renesas/sh7763rdp/lowlevel_init.S b/board/renesas/sh7763rdp/lowlevel_init.S index 715e75f..3747bf6 100644 --- a/board/renesas/sh7763rdp/lowlevel_init.S +++ b/board/renesas/sh7763rdp/lowlevel_init.S @@ -25,6 +25,7 @@ #include <version.h>
@@ -33,44 +34,33 @@
lowlevel_init:
- mov.l WDTCSR_A, r1 /* Watchdog Control / Status Register */ - mov.l WDTCSR_D, r0 - mov.l r0, @r1 + write32 WDTCSR_A, WDTCSR_D /* Watchdog Control / Status Register */
- mov.l WDTST_A, r1 /* Watchdog Stop Time Register */ - mov.l WDTST_D, r0 - mov.l r0, @r1 + write32 WDTST_A, WDTST_D /* Watchdog Stop Time Register */
- mov.l WDTBST_A, r1 /* 0xFFCC0008 (Watchdog Base Stop Time Register */ - mov.l WDTBST_D, r0 - mov.l r0, @r1 + write32 WDTBST_A, WDTBST_D /* + * 0xFFCC0008 + * Watchdog Base Stop Time Register + */
- mov.l CCR_A, r1 /* Address of Cache Control Register */ - mov.l CCR_CACHE_ICI_D, r0 /* Instruction Cache Invalidate */ - mov.l r0, @r1 + write32 CCR_A, CCR_CACHE_ICI_D /* Address of Cache Control Register */ + /* Instruction Cache Invalidate */
- mov.l MMUCR_A, r1 /* Address of MMU Control Register */ - mov.l MMU_CONTROL_TI_D, r0 /* TI == TLB Invalidate bit */ - mov.l r0, @r1 + write32 MMUCR_A, MMU_CONTROL_TI_D /* MMU Control Register */ + /* TI == TLB Invalidate bit */
- mov.l MSTPCR0_A, r1 /* Address of Power Control Register 0 */ - mov.l MSTPCR0_D, r0 - mov.l r0, @r1 + write32 MSTPCR0_A, MSTPCR0_D /* Address of Power Control Register 0 */
- mov.l MSTPCR1_A, r1 /*i Address of Power Control Register 1 */ - mov.l MSTPCR1_D, r0 - mov.l r0, @r1 + write32 MSTPCR1_A, MSTPCR1_D /* Address of Power Control Register 1 */
- mov.l RAMCR_A, r1 - mov.l RAMCR_D, r0 - mov.l r0, @r1 + write32 RAMCR_A, RAMCR_D
mov.l MMSELR_A, r1 mov.l MMSELR_D, r0 synco mov.l r0, @r1
- mov.l @r1, r2 /* execute two reads after setting MMSELR*/ + mov.l @r1, r2 /* execute two reads after setting MMSELR */ mov.l @r1, r2 synco
@@ -79,75 +69,47 @@ lowlevel_init: mov.l @r1, r0 synco
- mov.l MIM8_A, r1 - mov.l MIM8_D, r0 - mov.l r0, @r1 + write32 MIM8_A, MIM8_D
- mov.l MIMC_A, r1 - mov.l MIMC_D1, r0 - mov.l r0, @r1 + write32 MIMC_A, MIMC_D1
- mov.l STRC_A, r1 - mov.l STRC_D, r0 - mov.l r0, @r1 + write32 STRC_A, STRC_D
- mov.l SDR4_A, r1 - mov.l SDR4_D, r0 - mov.l r0, @r1 + write32 SDR4_A, SDR4_D
- mov.l MIMC_A, r1 - mov.l MIMC_D2, r0 - mov.l r0, @r1 + write32 MIMC_A, MIMC_D2
nop nop nop
- mov.l SCR4_A, r1 - mov.l SCR4_D3, r0 - mov.l r0, @r1 + write32 SCR4_A, SCR4_D3
- mov.l SCR4_A, r1 - mov.l SCR4_D2, r0 - mov.l r0, @r1 + write32 SCR4_A, SCR4_D2
- mov.l SDMR02000_A, r1 - mov.l SDMR02000_D, r0 - mov.l r0, @r1 + write32 SDMR02000_A, SDMR02000_D
- mov.l SDMR00B08_A, r1 - mov.l SDMR00B08_D, r0 - mov.l r0, @r1 + write32 SDMR00B08_A, SDMR00B08_D
- mov.l SCR4_A, r1 - mov.l SCR4_D4, r0 - mov.l r0, @r1 + write32 SCR4_A, SCR4_D4
nop nop nop nop
nop nop nop nop
- mov.l SDMR00308_A, r1 - mov.l SDMR00308_D, r0 - mov.l r0, @r1 + write32 SDMR00308_A, SDMR00308_D
- mov.l MIMC_A, r1 - mov.l MIMC_D3, r0 - mov.l r0, @r1 + write32 MIMC_A, MIMC_D3
mov.l SCR4_A, r1 mov.l SCR4_D1, r0 @@ -159,70 +121,38 @@ delay_loop_60: bf delay_loop_60 nop
- mov.l CCR_A, r1 /* Address of Cache Control Register */ - mov.l CCR_CACHE_D_2, r0 - mov.l r0, @r1 + write32 CCR_A, CCR_CACHE_D_2 /* Address of Cache Control Register */
bsc_init: - mov.l BCR_A, r1 - mov.l BCR_D, r0 - mov.l r0, @r1 + write32 BCR_A, BCR_D
@@ -231,17 +161,11 @@ delay_loop_200: bf delay_loop_200 nop
- mov.l PSEL0_A, r1 - mov.l PSEL0_D, r0 - mov.w r0, @r1 + write16 PSEL0_A, PSEL0_D
- mov.l PSEL1_A, r1 - mov.l PSEL1_D, r0 - mov.w r0, @r1 + write16 PSEL1_A, PSEL1_D
- mov.l ICR0_A, r1 - mov.l ICR0_D, r0 - mov.l r0, @r1 + write32 ICR0_A, ICR0_D
stc sr, r0 /* BL bit off(init=ON) */ mov.l SR_MASK_D, r1 diff --git a/board/renesas/sh7785lcr/lowlevel_init.S b/board/renesas/sh7785lcr/lowlevel_init.S index 4cb1d9d..f5ebeb9 100644 --- a/board/renesas/sh7785lcr/lowlevel_init.S +++ b/board/renesas/sh7785lcr/lowlevel_init.S @@ -19,33 +19,7 @@ #include <config.h> #include <version.h> #include <asm/processor.h> - -.macro write32, addr, data - mov.l \addr ,r1 - mov.l \data ,r0 - mov.l r0, @r1 -.endm - -.macro write16, addr, data - mov.l \addr ,r1 - mov.l \data ,r0 - mov.w r0, @r1 -.endm - -.macro write8, addr, data - mov.l \addr ,r1 - mov.l \data ,r0 - mov.b r0, @r1 -.endm - -.macro wait_timer, time - mov.l \time ,r3 -1: - nop - tst r3, r3 - bf/s 1b - dt r3 -.endm +#include <asm/macro.h>
diff --git a/include/asm-sh/macro.h b/include/asm-sh/macro.h new file mode 100644 index 0000000..61f792a --- /dev/null +++ b/include/asm-sh/macro.h @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2008 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MACRO_H__ +#define __MACRO_H__ +#ifdef __ASSEMBLY__ + +.macro write32, addr, data + mov.l \addr ,r1 + mov.l \data ,r0 + mov.l r0, @r1 +.endm + +.macro write16, addr, data + mov.l \addr ,r1 + mov.l \data ,r0 + mov.w r0, @r1 +.endm + +.macro write8, addr, data + mov.l \addr ,r1 + mov.l \data ,r0 + mov.b r0, @r1 +.endm + +.macro wait_timer, time + mov.l \time ,r3 +1: + nop + tst r3, r3 + bf/s 1b + dt r3 +.endm + +#endif /* __ASSEMBLY__ */ +#endif /* __MACRO_H__ */
On Sat, 20 Dec 2008 19:29:48 +0100 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com wrote:
board/mpr2/lowlevel_init.S | 44 +- board/ms7722se/lowlevel_init.S | 34 +- board/ms7750se/lowlevel_init.S | 150 +++--- board/renesas/MigoR/lowlevel_init.S | 10 +- board/renesas/ap325rxa/lowlevel_init.S | 86 ++-- board/renesas/r2dplus/lowlevel_init.S | 126 +++--- board/renesas/r7780mp/lowlevel_init.S | 858 +++++++++++++++--------------- board/renesas/rsk7203/lowlevel_init.S | 214 ++++---- board/renesas/sh7763rdp/lowlevel_init.S | 162 +++--- board/renesas/sh7785lcr/lowlevel_init.S | 2 +- 10 files changed, 846 insertions(+), 840 deletions(-) rewrite board/renesas/r7780mp/lowlevel_init.S (68%)
Applied, thanks.
Best regards, Nobuhiro
Nobuhiro Iwamatsu
