[U-Boot] [PATCH] lcd.h: define extern vidinfo_t for all cases
include/lcd.h has different vidinfo for different platforms, and several extern declaration, but one for the default case was missing. This makes them a single extern declaration for everyone.
Signed-off-by: Alessandro Rubini rubini@gnudd.com --- include/lcd.h | 8 ++------ 1 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/include/lcd.h b/include/lcd.h index f054cac..8048419 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -75,8 +75,6 @@ typedef struct vidinfo { u_char vl_wbf; /* Wait between frames */ } vidinfo_t;
-extern vidinfo_t panel_info; - #elif defined CONFIG_PXA250 /* * PXA LCD DMA descriptor @@ -146,8 +144,6 @@ typedef struct vidinfo { struct pxafb_info pxa; } vidinfo_t;
-extern vidinfo_t panel_info; - #elif defined(CONFIG_ATMEL_LCD)
typedef struct vidinfo { @@ -173,8 +169,6 @@ typedef struct vidinfo { u_long mmio; /* Memory mapped registers */ } vidinfo_t;
-extern vidinfo_t panel_info; - #else
typedef struct vidinfo { @@ -190,6 +184,8 @@ typedef struct vidinfo {
#endif /* CONFIG_MPC823, CONFIG_PXA250 or CONFIG_MCC200 or CONFIG_ATMEL_LCD */
+extern vidinfo_t panel_info; + /* Video functions */
#if defined(CONFIG_RBC823)
Acked-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Best Regards, J.
Applied to u-boot-video. Thanks!
Best regards, Anatolij
Alessandro Rubini
Anatolij Gustschin
