[PATCH v4 0/5] rockchip: Add support for Radxa ROCK 5C
Radxa ROCK 5C is a Rockchip RK3588S2 based single board computer.
Cristian Ciocaltea (1): arm64: dts: rockchip: Add HDMI0 node to rk3588
FUKAUMI Naoki (3): arm64: dts: rockchip: enable PCIe on M.2 E key for Radxa ROCK 5A arm64: dts: rockchip: add Radxa ROCK 5C rockchip: Add support for Radxa ROCK 5C
Sam Edwards (1): arm64: dts: rockchip: Split up RK3588's PCIe pinctrls
arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 11 + arch/arm/mach-rockchip/rk3588/Kconfig | 21 + board/radxa/rock-5c-rk3588s/Kconfig | 12 + board/radxa/rock-5c-rk3588s/MAINTAINERS | 7 + configs/rock-5c-rk3588s_defconfig | 84 ++ doc/board/rockchip/rockchip.rst | 1 + .../arm64/rockchip/rk3588-base-pinctrl.dtsi | 271 +++++- .../src/arm64/rockchip/rk3588-base.dtsi | 41 + .../src/arm64/rockchip/rk3588s-rock-5a.dts | 34 + .../src/arm64/rockchip/rk3588s-rock-5c.dts | 920 ++++++++++++++++++ include/configs/rock-5c-rk3588s.h | 15 + 11 files changed, 1369 insertions(+), 48 deletions(-) create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi create mode 100644 board/radxa/rock-5c-rk3588s/Kconfig create mode 100644 board/radxa/rock-5c-rk3588s/MAINTAINERS create mode 100644 configs/rock-5c-rk3588s_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts create mode 100644 include/configs/rock-5c-rk3588s.h
Enable pcie2x1l2 and related combphy/regulator routed to M.2 E key connector on Radxa ROCK 5A.
Tested with Radxa Wireless Module A8:
$ lspci 0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0004:41:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8852BE PCIe 802.11ax Wireless Network Controller
$ ip l 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether c2:58:fc:70:55:86 brd ff:ff:ff:ff:ff:ff 3: wlP4p65s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000 link/ether 2c:05:47:65:5b:ed brd ff:ff:ff:ff:ff:ff
$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub Bus 001 Device 003: ID 0bda:b85b Realtek Semiconductor Corp. Bluetooth Radio Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 006 Device 002: ID 0789:0336 Logitec Corp. LMD USB Device Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
$ hciconfig hci0: Type: Primary Bus: USB BD Address: 2C:05:47:65:5B:EE ACL MTU: 1021:6 SCO MTU: 255:12 UP RUNNING RX bytes:2698 acl:0 sco:0 events:329 errors:0 TX bytes:69393 acl:0 sco:0 commands:329 errors:0
Signed-off-by: FUKAUMI Naoki naoki@radxa.com Link: https://lore.kernel.org/r/20240826080456.525-1-naoki@radxa.com Signed-off-by: Heiko Stuebner heiko@sntech.de (cherry picked from commit b728d4c51f0ce9207daf502f3a85073785c46319) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3588s-rock-5a.dts | 30 +++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts index 03ed48246d36..a385e0991990 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts +++ b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts @@ -65,6 +65,18 @@ regulator-max-microvolt = <12000000>; };
+ vcc3v3_wf: vcc3v3-wf-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_wf"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&pow_en>; + pinctrl-names = "default"; + vin-supply = <&vcc5v0_sys>; + }; + vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed"; regulator-name = "vcc5v0_host"; @@ -114,6 +126,10 @@ }; };
+&combphy0_ps { + status = "okay"; +}; + &combphy2_psu { status = "okay"; }; @@ -293,6 +309,14 @@ }; };
+&pcie2x1l2 { + pinctrl-0 = <&pcie20x1m0_pins>; + pinctrl-names = "default"; + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_wf>; + status = "okay"; +}; + &pinctrl { leds { io_led: io-led { @@ -300,6 +324,12 @@ }; };
+ pcie { + pow_en: pow-en { + rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + power { vcc_5v0_en: vcc-5v0-en { rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
Hi FUKAUMI,
This doesn't seems to be a clean cherry pick from devicetree-rebasing, I get following error:
$ ./tools/update-subtree.sh pick dts b728d4c51f0ce9207daf502f3a85073785c46319
From https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi...
* branch master -> FETCH_HEAD fatal: bad object b728d4c51f0ce9207daf502f3a85073785c46319
-Sumit
enable-active-high;
+&combphy0_ps {
status = "okay";
+&pcie2x1l2 {
status = "okay";
pcie {
pow_en: pow-en {
-- 2.43.0
Hi Sumit,
On 1/3/25 21:53, Sumit Garg wrote:
Hi FUKAUMI,
It's weird, but I'd do it all again Thanks for your review.
-- FUKAUMI Naoki Radxa Computer (Shenzhen) Co., Ltd.
$ ./tools/update-subtree.sh pick dts b728d4c51f0ce9207daf502f3a85073785c46319 From https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi...
- branch master -> FETCH_HEAD
-Sumit
enable-active-high;
+&combphy0_ps {
status = "okay";
- &combphy2_psu { status = "okay"; };
+&pcie2x1l2 {
status = "okay";
- &pinctrl { leds { io_led: io-led {
pcie {
pow_en: pow-en {
-- 2.43.0
On Fri, 3 Jan 2025 at 18:28, FUKAUMI Naoki naoki@radxa.com wrote:
Hi Sumit,
Hi FUKAUMI,
Just double check if these commits already landed in dts/upstream after recent v6.12.dts sync.
-Sumit
-Sumit
enable-active-high;
+&combphy0_ps {
status = "okay";
+&pcie2x1l2 {
status = "okay";
pcie {
pow_en: pow-en {
-- 2.43.0
These pinctrls manage the low-speed PCIe signals: - CLKREQ#: An output on the RK3588 (both RC or EP modes), used to request that external clock-generation circuitry provide a clock. - PERST#: An input on the RK3588 in EP mode, used to detect a reset signal from the RC. In RC mode, the hardware does not use this signal: Linux itself generates it by putting the pin in GPIO mode. - WAKE#: In EP mode, this is an output; in RC mode, this is an input.
Each of these signals serves a distinct purpose, and more importantly, PERST# should not be muxed when the RK3588 is in the RC role. Bundling them together in pinctrl groups prevents proper use: indeed, almost none of the current board-specific .dts files make any use of them. (Exception: Rock 5A recently had a patch land that misuses _pins; this patch corrects that.)
However, on some RK3588 boards, the PCIe 3 controller will indefinitely stall the boot if CLKREQ# is not muxed (details in the next patch). This patch unbundles the signals to allow them to be used.
Signed-off-by: Sam Edwards CFSworks@gmail.com Link: https://lore.kernel.org/r/20240912025034.180233-2-CFSworks@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de (cherry picked from commit 4294e32111781b3de4d73b944cbd1bc1662a9a7a) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../arm64/rockchip/rk3588-base-pinctrl.dtsi | 271 ++++++++++++++---- .../src/arm64/rockchip/rk3588s-rock-5a.dts | 6 +- 2 files changed, 228 insertions(+), 49 deletions(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi b/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi index 30db12c4fc82..b12562e9a985 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi +++ b/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi @@ -1612,23 +1612,43 @@
pcie20x1 { /omit-if-no-ref/ - pcie20x1m0_pins: pcie20x1m0-pins { + pcie20x1m0_clkreqn: pcie20x1m0-clkreqn { rockchip,pins = /* pcie20x1_2_clkreqn_m0 */ - <3 RK_PC7 4 &pcfg_pull_none>, + <3 RK_PC7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m0_perstn: pcie20x1m0-perstn { + rockchip,pins = /* pcie20x1_2_perstn_m0 */ - <3 RK_PD1 4 &pcfg_pull_none>, + <3 RK_PD1 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m0_waken: pcie20x1m0-waken { + rockchip,pins = /* pcie20x1_2_waken_m0 */ <3 RK_PD0 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie20x1m1_pins: pcie20x1m1-pins { + pcie20x1m1_clkreqn: pcie20x1m1-clkreqn { rockchip,pins = /* pcie20x1_2_clkreqn_m1 */ - <4 RK_PB7 4 &pcfg_pull_none>, + <4 RK_PB7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m1_perstn: pcie20x1m1-perstn { + rockchip,pins = /* pcie20x1_2_perstn_m1 */ - <4 RK_PC1 4 &pcfg_pull_none>, + <4 RK_PC1 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m1_waken: pcie20x1m1-waken { + rockchip,pins = /* pcie20x1_2_waken_m1 */ <4 RK_PC0 4 &pcfg_pull_none>; }; @@ -1654,52 +1674,127 @@
pcie30x1 { /omit-if-no-ref/ - pcie30x1m0_pins: pcie30x1m0-pins { + pcie30x1m0_0_clkreqn: pcie30x1m0-0-clkreqn { rockchip,pins = /* pcie30x1_0_clkreqn_m0 */ - <0 RK_PC0 12 &pcfg_pull_none>, + <0 RK_PC0 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_0_perstn: pcie30x1m0-0-perstn { + rockchip,pins = /* pcie30x1_0_perstn_m0 */ - <0 RK_PC5 12 &pcfg_pull_none>, + <0 RK_PC5 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_0_waken: pcie30x1m0-0-waken { + rockchip,pins = /* pcie30x1_0_waken_m0 */ - <0 RK_PC4 12 &pcfg_pull_none>, + <0 RK_PC4 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_1_clkreqn: pcie30x1m0-1-clkreqn { + rockchip,pins = /* pcie30x1_1_clkreqn_m0 */ - <0 RK_PB5 12 &pcfg_pull_none>, + <0 RK_PB5 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_1_perstn: pcie30x1m0-1-perstn { + rockchip,pins = /* pcie30x1_1_perstn_m0 */ - <0 RK_PB7 12 &pcfg_pull_none>, + <0 RK_PB7 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_1_waken: pcie30x1m0-1-waken { + rockchip,pins = /* pcie30x1_1_waken_m0 */ <0 RK_PB6 12 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x1m1_pins: pcie30x1m1-pins { + pcie30x1m1_0_clkreqn: pcie30x1m1-0-clkreqn { rockchip,pins = /* pcie30x1_0_clkreqn_m1 */ - <4 RK_PA3 4 &pcfg_pull_none>, + <4 RK_PA3 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_0_perstn: pcie30x1m1-0-perstn { + rockchip,pins = /* pcie30x1_0_perstn_m1 */ - <4 RK_PA5 4 &pcfg_pull_none>, + <4 RK_PA5 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_0_waken: pcie30x1m1-0-waken { + rockchip,pins = /* pcie30x1_0_waken_m1 */ - <4 RK_PA4 4 &pcfg_pull_none>, + <4 RK_PA4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_1_clkreqn: pcie30x1m1-1-clkreqn { + rockchip,pins = /* pcie30x1_1_clkreqn_m1 */ - <4 RK_PA0 4 &pcfg_pull_none>, + <4 RK_PA0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_1_perstn: pcie30x1m1-1-perstn { + rockchip,pins = /* pcie30x1_1_perstn_m1 */ - <4 RK_PA2 4 &pcfg_pull_none>, + <4 RK_PA2 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_1_waken: pcie30x1m1-1-waken { + rockchip,pins = /* pcie30x1_1_waken_m1 */ <4 RK_PA1 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x1m2_pins: pcie30x1m2-pins { + pcie30x1m2_0_clkreqn: pcie30x1m2-0-clkreqn { rockchip,pins = /* pcie30x1_0_clkreqn_m2 */ - <1 RK_PB5 4 &pcfg_pull_none>, + <1 RK_PB5 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_0_perstn: pcie30x1m2-0-perstn { + rockchip,pins = /* pcie30x1_0_perstn_m2 */ - <1 RK_PB4 4 &pcfg_pull_none>, + <1 RK_PB4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_0_waken: pcie30x1m2-0-waken { + rockchip,pins = /* pcie30x1_0_waken_m2 */ - <1 RK_PB3 4 &pcfg_pull_none>, + <1 RK_PB3 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_1_clkreqn: pcie30x1m2-1-clkreqn { + rockchip,pins = /* pcie30x1_1_clkreqn_m2 */ - <1 RK_PA0 4 &pcfg_pull_none>, + <1 RK_PA0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_1_perstn: pcie30x1m2-1-perstn { + rockchip,pins = /* pcie30x1_1_perstn_m2 */ - <1 RK_PA7 4 &pcfg_pull_none>, + <1 RK_PA7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_1_waken: pcie30x1m2-1-waken { + rockchip,pins = /* pcie30x1_1_waken_m2 */ <1 RK_PA1 4 &pcfg_pull_none>; }; @@ -1721,45 +1816,85 @@
pcie30x2 { /omit-if-no-ref/ - pcie30x2m0_pins: pcie30x2m0-pins { + pcie30x2m0_clkreqn: pcie30x2m0-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m0 */ - <0 RK_PD1 12 &pcfg_pull_none>, + <0 RK_PD1 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m0_perstn: pcie30x2m0-perstn { + rockchip,pins = /* pcie30x2_perstn_m0 */ - <0 RK_PD4 12 &pcfg_pull_none>, + <0 RK_PD4 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m0_waken: pcie30x2m0-waken { + rockchip,pins = /* pcie30x2_waken_m0 */ <0 RK_PD2 12 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x2m1_pins: pcie30x2m1-pins { + pcie30x2m1_clkreqn: pcie30x2m1-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m1 */ - <4 RK_PA6 4 &pcfg_pull_none>, + <4 RK_PA6 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m1_perstn: pcie30x2m1-perstn { + rockchip,pins = /* pcie30x2_perstn_m1 */ - <4 RK_PB0 4 &pcfg_pull_none>, + <4 RK_PB0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m1_waken: pcie30x2m1-waken { + rockchip,pins = /* pcie30x2_waken_m1 */ <4 RK_PA7 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x2m2_pins: pcie30x2m2-pins { + pcie30x2m2_clkreqn: pcie30x2m2-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m2 */ - <3 RK_PD2 4 &pcfg_pull_none>, + <3 RK_PD2 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m2_perstn: pcie30x2m2-perstn { + rockchip,pins = /* pcie30x2_perstn_m2 */ - <3 RK_PD4 4 &pcfg_pull_none>, + <3 RK_PD4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m2_waken: pcie30x2m2-waken { + rockchip,pins = /* pcie30x2_waken_m2 */ <3 RK_PD3 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x2m3_pins: pcie30x2m3-pins { + pcie30x2m3_clkreqn: pcie30x2m3-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m3 */ - <1 RK_PD7 4 &pcfg_pull_none>, + <1 RK_PD7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m3_perstn: pcie30x2m3-perstn { + rockchip,pins = /* pcie30x2_perstn_m3 */ - <1 RK_PB7 4 &pcfg_pull_none>, + <1 RK_PB7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m3_waken: pcie30x2m3-waken { + rockchip,pins = /* pcie30x2_waken_m3 */ <1 RK_PB6 4 &pcfg_pull_none>; }; @@ -1774,45 +1909,85 @@
pcie30x4 { /omit-if-no-ref/ - pcie30x4m0_pins: pcie30x4m0-pins { + pcie30x4m0_clkreqn: pcie30x4m0-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m0 */ - <0 RK_PC6 12 &pcfg_pull_none>, + <0 RK_PC6 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m0_perstn: pcie30x4m0-perstn { + rockchip,pins = /* pcie30x4_perstn_m0 */ - <0 RK_PD0 12 &pcfg_pull_none>, + <0 RK_PD0 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m0_waken: pcie30x4m0-waken { + rockchip,pins = /* pcie30x4_waken_m0 */ <0 RK_PC7 12 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x4m1_pins: pcie30x4m1-pins { + pcie30x4m1_clkreqn: pcie30x4m1-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m1 */ - <4 RK_PB4 4 &pcfg_pull_none>, + <4 RK_PB4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m1_perstn: pcie30x4m1-perstn { + rockchip,pins = /* pcie30x4_perstn_m1 */ - <4 RK_PB6 4 &pcfg_pull_none>, + <4 RK_PB6 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m1_waken: pcie30x4m1-waken { + rockchip,pins = /* pcie30x4_waken_m1 */ <4 RK_PB5 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x4m2_pins: pcie30x4m2-pins { + pcie30x4m2_clkreqn: pcie30x4m2-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m2 */ - <3 RK_PC4 4 &pcfg_pull_none>, + <3 RK_PC4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m2_perstn: pcie30x4m2-perstn { + rockchip,pins = /* pcie30x4_perstn_m2 */ - <3 RK_PC6 4 &pcfg_pull_none>, + <3 RK_PC6 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m2_waken: pcie30x4m2-waken { + rockchip,pins = /* pcie30x4_waken_m2 */ <3 RK_PC5 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x4m3_pins: pcie30x4m3-pins { + pcie30x4m3_clkreqn: pcie30x4m3-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m3 */ - <1 RK_PB0 4 &pcfg_pull_none>, + <1 RK_PB0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m3_perstn: pcie30x4m3-perstn { + rockchip,pins = /* pcie30x4_perstn_m3 */ - <1 RK_PB2 4 &pcfg_pull_none>, + <1 RK_PB2 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m3_waken: pcie30x4m3-waken { + rockchip,pins = /* pcie30x4_waken_m3 */ <1 RK_PB1 4 &pcfg_pull_none>; }; diff --git a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts index a385e0991990..d6a0b559edca 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts +++ b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts @@ -310,7 +310,7 @@ };
&pcie2x1l2 { - pinctrl-0 = <&pcie20x1m0_pins>; + pinctrl-0 = <&pcie2_reset>, <&pcie20x1m0_clkreqn>, <&pcie20x1m0_waken>; pinctrl-names = "default"; reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; vpcie3v3-supply = <&vcc3v3_wf>; @@ -328,6 +328,10 @@ pow_en: pow-en { rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; }; + + pcie2_reset: pcie2-reset { + rockchip,pins = <3 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; };
power {
Ditto here:
$ ./tools/update-subtree.sh pick dts 4294e32111781b3de4d73b944cbd1bc1662a9a7a
* branch master -> FETCH_HEAD fatal: bad object 4294e32111781b3de4d73b944cbd1bc1662a9a7a
-Sumit
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie20x1_2_waken_m0 */ <3 RK_PD0 4 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x1_1_waken_m0 */ <0 RK_PB6 12 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x1_1_waken_m1 */ <4 RK_PA1 4 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x2_waken_m0 */ <0 RK_PD2 12 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x2_waken_m1 */ <4 RK_PA7 4 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x2_waken_m2 */ <3 RK_PD3 4 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x4_waken_m0 */ <0 RK_PC7 12 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x4_waken_m1 */ <4 RK_PB5 4 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
rockchip,pins = /* pcie30x4_waken_m2 */ <3 RK_PC5 4 &pcfg_pull_none>; }; /omit-if-no-ref/
/omit-if-no-ref/
/omit-if-no-ref/
&pcie2x1l2 {
}; }; power {
-- 2.43.0
From: Cristian Ciocaltea cristian.ciocaltea@collabora.com
Add support for the HDMI0 output port found on RK3588 SoC.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@collabora.com Link: https://lore.kernel.org/r/20241019-rk3588-hdmi0-dt-v2-1-466cd80e8ff9@collabo... Signed-off-by: Heiko Stuebner heiko@sntech.de (cherry picked from commit d7bb71e69f58c1b3665a9f926bf8d3855111bf8e) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3588-base.dtsi | 41 +++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi b/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi index ee99166ebd46..3064ecf1e22a 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi +++ b/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi @@ -1254,6 +1254,47 @@ status = "disabled"; };
+ hdmi0: hdmi@fde80000 { + compatible = "rockchip,rk3588-dw-hdmi-qp"; + reg = <0x0 0xfde80000 0x0 0x20000>; + clocks = <&cru PCLK_HDMITX0>, + <&cru CLK_HDMITX0_EARC>, + <&cru CLK_HDMITX0_REF>, + <&cru MCLK_I2S5_8CH_TX>, + <&cru CLK_HDMIHDP0>, + <&cru HCLK_VO1>; + clock-names = "pclk", "earc", "ref", "aud", "hdp", "hclk_vo1"; + interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "avp", "cec", "earc", "main", "hpd"; + phys = <&hdptxphy_hdmi0>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmim0_tx0_cec &hdmim0_tx0_hpd + &hdmim0_tx0_scl &hdmim0_tx0_sda>; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_HDMITX0_REF>, <&cru SRST_HDMIHDP0>; + reset-names = "ref", "hdp"; + rockchip,grf = <&sys_grf>; + rockchip,vo-grf = <&vo1_grf>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi0_in: port@0 { + reg = <0>; + }; + + hdmi0_out: port@1 { + reg = <1>; + }; + }; + }; + qos_gpu_m0: qos@fdf35000 { compatible = "rockchip,rk3588-qos", "syscon"; reg = <0x0 0xfdf35000 0x0 0x20>;
Same here:
$ ./tools/update-subtree.sh pick dts d7bb71e69f58c1b3665a9f926bf8d3855111bf8e
* branch master -> FETCH_HEAD fatal: bad object d7bb71e69f58c1b3665a9f926bf8d3855111bf8e
-Sumit
<&cru HCLK_VO1>;
ports {
#size-cells = <0>;
hdmi0_in: port@0 {
reg = <0>;
hdmi0_out: port@1 {
reg = <1>;
-- 2.43.0
Radxa ROCK 5C is a 8K computer for everything[1] using the Rockchip RK3588S2 chip:
- Rockchip RK3588S2 - Quad A76 and Quad A55 CPU - 6 TOPS NPU - up to 32GB LPDDR4x RAM - eMMC / SPI flash connector - Micro SD Card slot - Gigabit ethernet port (supports PoE with add-on PoE HAT) - WiFi6 / BT5.4 - 1x USB 3.0 Type-A HOST port - 1x USB 3.0 Type-A OTG port - 2x USB 2.0 Type-A HOST port - 1x USB Type-C 5V power port
[1] https://radxa.com/products/rock5/5c
Signed-off-by: FUKAUMI Naoki naoki@radxa.com Link: https://lore.kernel.org/r/20241021090548.1052-2-naoki@radxa.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 3ddf5cdb77e6efd6fe9b70f36dec935e324a3cd2 ]
(cherry picked from commit f80689fcef4b9b07a97b629b4075cc1a4c21a68e) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3588s-rock-5c.dts | 920 ++++++++++++++++++ 1 file changed, 920 insertions(+) create mode 100644 dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts
diff --git a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts new file mode 100644 index 000000000000..9b14d5383cdc --- /dev/null +++ b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts @@ -0,0 +1,920 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3588s.dtsi" + +/ { + model = "Radxa ROCK 5C"; + compatible = "radxa,rock-5c", "rockchip,rk3588s"; + + aliases { + ethernet0 = &gmac1; + mmc0 = &sdhci; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + analog-sound { + compatible = "audio-graph-card"; + label = "rk3588-es8316"; + dais = <&i2s0_8ch_p0>; + routing = "MIC2", "Mic Jack", + "Headphones", "HPOL", + "Headphones", "HPOR"; + widgets = "Microphone", "Mic Jack", + "Headphone", "Headphones"; + }; + + hdmi0-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi0_con_in: endpoint { + remote-endpoint = <&hdmi0_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins>; + + led-0 { + color = <LED_COLOR_ID_GREEN>; + default-state = "on"; + function = LED_FUNCTION_POWER; + gpios = <&gpio3 RK_PC4 GPIO_ACTIVE_HIGH>; + }; + + led-1 { + color = <LED_COLOR_ID_BLUE>; + default-state = "on"; + function = LED_FUNCTION_HEARTBEAT; + gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + fan { + compatible = "pwm-fan"; + #cooling-cells = <2>; + cooling-levels = <0 64 128 192 255>; + fan-supply = <&vcc_5v0>; + pwms = <&pwm3 0 10000 0>; + }; + + pcie2x1l2_3v3: regulator-pcie2x1l2-3v3 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pow_en>; + regulator-name = "pcie2x1l2_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_sysin>; + }; + + vcc5v_dcin: regulator-vcc5v-dcin { + compatible = "regulator-fixed"; + regulator-name = "vcc5v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb_host: regulator-vcc5v0-usb-host { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_host_pwren_h>; + regulator-name = "vcc5v0_usb_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sysin>; + }; + + vcc5v0_usb_otg0: regulator-vcc5v0-usb-otg0 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_otg_pwren_h>; + regulator-name = "vcc5v0_usb_otg0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sysin>; + }; + + vcc_1v1_nldo_s3: regulator-vcc-1v1-nldo-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v1_nldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + vin-supply = <&vcc_sysin>; + }; + + vcc_3v3_pmu: regulator-vcc-3v3-pmu { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3_s3>; + }; + + vcc_3v3_s0: regulator-vcc-3v3-s0 { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_1v8_s0>; + }; + + vcc_5v0: regulator-vcc-5v0 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc_5v0_pwren_h>; + regulator-name = "vcc_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sysin>; + }; + + vcc_sysin: regulator-vcc-sysin { + compatible = "regulator-fixed"; + regulator-name = "vcc_sysin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v_dcin>; + }; + + vcca: regulator-vcca { + compatible = "regulator-fixed"; + regulator-name = "vcca"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <4000000>; + regulator-max-microvolt = <4000000>; + vin-supply = <&vcc_sysin>; + }; + + vdd_3v3: regulator-vdd-3v3 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_wifi_pwr>; + regulator-name = "vdd_3v3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3_s3>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&gmac1 { + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii-id"; + phy-supply = <&vcc_3v3_s0>; + pinctrl-0 = <&gmac1_miim + &gmac1_tx_bus2 + &gmac1_rx_bus2 + &gmac1_rgmii_clk + &gmac1_rgmii_bus + &gmac1_clkinout>; + pinctrl-names = "default"; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu_s0>; + status = "okay"; +}; + +&hdmi0 { + pinctrl-names = "default"; + pinctrl-0 = <&hdmim0_tx0_cec + &hdmim1_tx0_hpd + &hdmim0_tx0_scl + &hdmim0_tx0_sda>; + status = "okay"; +}; + +&hdmi0_in { + hdmi0_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi0>; + }; +}; + +&hdmi0_out { + hdmi0_out_con: endpoint { + remote-endpoint = <&hdmi0_con_in>; + }; +}; + +&hdptxphy_hdmi0 { + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sysin>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sysin>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + eeprom@50 { + compatible = "belling,bl24c16a", "atmel,24c16"; + reg = <0x50>; + pagesize = <16>; + vcc-supply = <&vcc_3v3_pmu>; + }; +}; + +&i2c2 { + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sysin>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c5 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c5m2_xfer>; + status = "okay"; + + rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "rtcic_32kout"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&rtc_int_l>; + }; +}; + +&i2c7 { + status = "okay"; + + audio-codec@11 { + compatible = "everest,es8316"; + reg = <0x11>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>; + + port { + es8316_p0_0: endpoint { + remote-endpoint = <&i2s0_8ch_p0_0>; + }; + }; + }; +}; + +&i2s0_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; + + i2s0_8ch_p0: port { + i2s0_8ch_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&es8316_p0_0>; + }; + }; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id001c.c916"; + reg = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac1_rstn>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + }; +}; + +&pcie2x1l2 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie20x1_2_perstn_m0>; + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&pcie2x1l2_3v3>; + status = "okay"; +}; + +&pinctrl { + leds { + led_pins: led-pins { + rockchip,pins = <3 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>, + <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + mdio { + gmac1_rstn: gmac1-rstn { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie20x1_2_perstn_m0: pcie20x1-2-perstn-m0 { + rockchip,pins = <3 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pow_en: pow-en { + rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + rtc { + rtc_int_l: rtc-int-l { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + usb_host_pwren_h: usb-host-pwren-h { + rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb_otg_pwren_h: usb-otg-pwren-h { + rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb_wifi_pwr: usb-wifi-pwr { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc_5v0_pwren_h: vcc-5v0-pwren-h { + rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm3m1_pins>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + no-sdio; + no-sd; + non-removable; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + no-sdio; + no-mmc; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim0_pins>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <104000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&spi2 { + status = "okay"; + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + system-power-controller; + + vcc1-supply = <&vcc_sysin>; + vcc2-supply = <&vcc_sysin>; + vcc3-supply = <&vcc_sysin>; + vcc4-supply = <&vcc_sysin>; + vcc5-supply = <&vcc_sysin>; + vcc6-supply = <&vcc_sysin>; + vcc7-supply = <&vcc_sysin>; + vcc8-supply = <&vcc_sysin>; + vcc9-supply = <&vcc_sysin>; + vcc10-supply = <&vcc_sysin>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc_sysin>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcca>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl1"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: dcdc-reg1 { + regulator-name = "vdd_gpu_s0"; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_logic_s0: dcdc-reg3 { + regulator-name = "vdd_logic_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vdd_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu_ddr_s3: dcdc-reg10 { + regulator-name = "vcc1v8_pmu_ddr_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_1v8_s0: pldo-reg1 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_1v8_s0: pldo-reg2 { + regulator-name = "vcca_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdda_1v2_s0: pldo-reg3 { + regulator-name = "vdda_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_3v3_s0: pldo-reg4 { + regulator-name = "vcca_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdda_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdda_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdda_0v75_s0: nldo-reg3 { + regulator-name = "vdda_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v85_s0: nldo-reg4 { + regulator-name = "vdda_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-name = "vdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + phy-supply = <&vcc5v0_usb_otg0>; + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy2_host { + /* connected to USB hub, which is powered by vcc_5v0 */ + phy-supply = <&vcc_5v0>; + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_xhci { + dr_mode = "host"; + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host2_xhci { + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vop { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi0: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi0_in_vp0>; + }; +};
Radxa ROCK 5C[1] is a Rockchip RK3588S2 based single board computer.
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- Changes in v4: - ROCK 5A section was removed and most of it rewritten for ROCK 5C - Trivial changes Changes in v3: - Fix compile error Changes in v2: - arch/arm/dts/rk3588s-rock-5-u-boot.dtsi: remove unused node - include/configs/rock-5-rk3588s.h: fix include order --- arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 11 ++++ arch/arm/mach-rockchip/rk3588/Kconfig | 21 ++++++ board/radxa/rock-5c-rk3588s/Kconfig | 12 ++++ board/radxa/rock-5c-rk3588s/MAINTAINERS | 7 ++ configs/rock-5c-rk3588s_defconfig | 84 ++++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/rock-5c-rk3588s.h | 15 +++++ 7 files changed, 151 insertions(+) create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi create mode 100644 board/radxa/rock-5c-rk3588s/Kconfig create mode 100644 board/radxa/rock-5c-rk3588s/MAINTAINERS create mode 100644 configs/rock-5c-rk3588s_defconfig create mode 100644 include/configs/rock-5c-rk3588s.h
diff --git a/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi new file mode 100644 index 000000000000..1dc574c2f219 --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024-2025 Radxa Computer (Shenzhen) Co., Ltd. + */ + +#include "rk3588s-u-boot.dtsi" + +&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index b5a0e624a532..448cfaf0d60d 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -260,6 +260,26 @@ config TARGET_ROCK_5_ITX_RK3588 Front-panel connectors for audio and case-power, -leds Powered by either 12V, ATX power-supply or PoE
+config TARGET_ROCK_5C_RK3588S + bool "Radxa ROCK 5C RK3588S2 board" + select BOARD_LATE_INIT + help + Radxa ROCK 5C is a Rockchip RK3588S2 based single board computer. + + Specification: + + Quad A76 and Quad A55 CPU + 6 TOPS NPU + up to 32GB LPDDR4x RAM + eMMC / SPI flash connector + Micro SD Card slot + Gigabit ethernet port (supports PoE with add-on PoE HAT) + WiFi6 / BT5.4 + 1x USB 3.0 Type-A HOST port + 1x USB 3.0 Type-A OTG port + 2x USB 2.0 Type-A HOST port + 1x USB Type-C 5V power port + config TARGET_SIGE7_RK3588 bool "ArmSoM Sige7 RK3588 board" select BOARD_LATE_INIT @@ -398,6 +418,7 @@ source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" source "board/radxa/rock5b-rk3588/Kconfig" source "board/radxa/rock-5-itx-rk3588/Kconfig" +source "board/radxa/rock-5c-rk3588s/Kconfig" source "board/rockchip/evb_rk3588/Kconfig" source "board/rockchip/toybrick_rk3588/Kconfig" source "board/theobroma-systems/jaguar_rk3588/Kconfig" diff --git a/board/radxa/rock-5c-rk3588s/Kconfig b/board/radxa/rock-5c-rk3588s/Kconfig new file mode 100644 index 000000000000..ec964bdcb934 --- /dev/null +++ b/board/radxa/rock-5c-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ROCK_5C_RK3588S + +config SYS_BOARD + default "rock-5c-rk3588s" + +config SYS_VENDOR + default "radxa" + +config SYS_CONFIG_NAME + default "rock-5c-rk3588s" + +endif diff --git a/board/radxa/rock-5c-rk3588s/MAINTAINERS b/board/radxa/rock-5c-rk3588s/MAINTAINERS new file mode 100644 index 000000000000..17183c739d67 --- /dev/null +++ b/board/radxa/rock-5c-rk3588s/MAINTAINERS @@ -0,0 +1,7 @@ +ROCK-5C-RK3588S +M: FUKAUMI Naoki naoki@radxa.com +S: Maintained +F: arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi +F: board/radxa/rock-5c-rk3588s/ +F: configs/rock-5c-rk3588s_defconfig +F: include/configs/rock-5c-rk3588s.h diff --git a/configs/rock-5c-rk3588s_defconfig b/configs/rock-5c-rk3588s_defconfig new file mode 100644 index 000000000000..59f9f25edcb8 --- /dev/null +++ b/configs/rock-5c-rk3588s_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-rock-5c" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_ROCK_5C_RK3588S=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-rock-5c.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9bab86d23479..dbe199a13c46 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -141,6 +141,7 @@ List of mainline supported Rockchip boards: - Radxa ROCK 5 ITX (rock-5-itx-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588) + - Radxa ROCK 5C (rock-5c-rk3588s) - Rockchip Toybrick TB-RK3588X (toybrick-rk3588) - Theobroma Systems RK3588-SBC Jaguar (jaguar-rk3588) - Theobroma Systems SOM-RK3588-Q7 - Tiger (tiger-rk3588) diff --git a/include/configs/rock-5c-rk3588s.h b/include/configs/rock-5c-rk3588s.h new file mode 100644 index 000000000000..0fd76c96f0ca --- /dev/null +++ b/include/configs/rock-5c-rk3588s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024-2025 Radxa Computer (Shenzhen) Co., Ltd. + */ + +#ifndef __ROCK_5C_RK3588S_H +#define __ROCK_5C_RK3588S_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#endif /* __ROCK_5C_RK3588S_H */
FUKAUMI Naoki
Sumit Garg
