[U-Boot] [PATCH 0/7] Tegra2: USB Host Support patch series
This patch series adds USB host support to Tegra2. It has been tested on Seaboard.
Since the Tegra2 includes a vast number of registers it is critical that we make it as easy and error-free as possible to write code which accesses those registers. So a simple bitfield access mechanism is provided which mirrors the notation in many datasheets (16:12 means bits 16 downto 12).
Support is provided for clock and pinmux functions which are used in USB and will be used commonly in future patches. A microsecond timer is required for PLL setup timing.
Finally, as a motivation for all this effort, network booting is enabled for Seaboard. A previous patch containing full documentation want sent to the list on 13-Apr-11 (Add documentation for USB Host Networking).
These patches are prepared against u-boot-arm.git/master.
Simon Glass (7): Tegra2: Add bitfield access macros Tegra2: Add microsecond timer functions Tegra2: Add more clock support Tegra2: add additional pin multiplexing features Tegra2: Use clock and pinmux functions to simplify code Tegra2: Add USB support Tegra2: config: enable network booting
arch/arm/cpu/armv7/tegra2/Makefile | 2 +- arch/arm/cpu/armv7/tegra2/ap20.c | 92 +++------ arch/arm/cpu/armv7/tegra2/clock.c | 163 ++++++++++++++ arch/arm/cpu/armv7/tegra2/pinmux.c | 54 +++++ arch/arm/cpu/armv7/tegra2/timer.c | 27 ++- arch/arm/include/asm/arch-tegra2/bitfield.h | 151 +++++++++++++ arch/arm/include/asm/arch-tegra2/clk_rst.h | 129 +++++------- arch/arm/include/asm/arch-tegra2/clock.h | 264 ++++++++++++++++++++++ arch/arm/include/asm/arch-tegra2/pinmux.h | 156 +++++++++++++- arch/arm/include/asm/arch-tegra2/tegra2.h | 2 + arch/arm/include/asm/arch-tegra2/timer.h | 34 +++ arch/arm/include/asm/arch-tegra2/usb.h | 217 +++++++++++++++++++ board/nvidia/common/Makefile | 53 +++++ board/nvidia/common/board.c | 70 +++---- board/nvidia/common/usb.c | 313 +++++++++++++++++++++++++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-hcd.c | 39 ++++ drivers/usb/host/ehci-tegra.c | 73 +++++++ drivers/usb/host/ehci.h | 6 +- include/configs/seaboard.h | 17 ++ include/configs/tegra2-common.h | 96 ++++++++- test/Makefile | 36 +++ test/bitfield.c | 230 ++++++++++++++++++++ 23 files changed, 2022 insertions(+), 203 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/clock.c create mode 100644 arch/arm/cpu/armv7/tegra2/pinmux.c create mode 100644 arch/arm/include/asm/arch-tegra2/bitfield.h create mode 100644 arch/arm/include/asm/arch-tegra2/clock.h create mode 100644 arch/arm/include/asm/arch-tegra2/timer.h create mode 100644 arch/arm/include/asm/arch-tegra2/usb.h create mode 100644 board/nvidia/common/Makefile create mode 100644 board/nvidia/common/usb.c create mode 100644 drivers/usb/host/ehci-tegra.c create mode 100644 test/Makefile create mode 100644 test/bitfield.c
-- 1.7.3.1
To use these, set things up like this:
struct uart_ctlr *uart = (struct uart_ctlr *)UART_PA_START;
#define UART_PA_START 0x67000000 /* Physical address of UART */ #define UART_FBCON_RANGE 5:3 /* Bit range for the FBCON field */ enum { /* An enum with allowed values */ UART_FBCON_OFF, UART_FBCON_ON, UART_FBCON_MULTI, UART_FBCON_SLAVE, };
This defines a bit field of 3 bits starting at bit 5 and extending down to bit 3, i.e. 5:3
Then: bf_unpack(UART_FBCON) - return the value of bits 5:3 (shifted down to bits 2:0)
bf_pack(UART_FBCON, 4) - return a word with that field set to 4 (so in this case (4 << 3))
bf_update(UART_FBCON, word, val) - update a field within word so that its value is val.
bf_writel(UART_FBCON, 6, &uart->fbcon) - set the UART's FBCON field to 6
bf_enum_writel(UART_FBCON, MULTI, &uart->fbcon) - set the UART's FBCON field to MULTI
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/include/asm/arch-tegra2/bitfield.h | 151 ++++++++++++++++++ test/Makefile | 36 ++++ test/bitfield.c | 230 +++++++++++++++++++++++++++ 3 files changed, 417 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra2/bitfield.h create mode 100644 test/Makefile create mode 100644 test/bitfield.c
diff --git a/arch/arm/include/asm/arch-tegra2/bitfield.h b/arch/arm/include/asm/arch-tegra2/bitfield.h new file mode 100644 index 0000000..6a1bbfa --- /dev/null +++ b/arch/arm/include/asm/arch-tegra2/bitfield.h @@ -0,0 +1,151 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __TEGRA2_BITFIELD_H +#define __TEGRA2_BITFIELD_H + +/* + * Macros for working with bit fields. To use these, set things up like this: + * + * #define UART_PA_START 0x67000000 Physical address of UART + * #define UART_FBCON_RANGE 5:3 Bit range for the FBCON field + * enum { An enum with allowed values + * UART_FBCON_OFF, + * UART_FBCON_ON, + * UART_FBCON_MULTI, + * UART_FBCON_SLAVE, + * }; + * struct uart_ctlr *uart = (struct uart_ctlr *)UART_PA_START; + * + * This defines a bit field of 3 bits starting at bit 5 and extending down + * to bit 3, i.e. 5:3 + * + * Then: + * bf_unpack(UART_FBCON) + * - return the value of bits 5:3 (shifted down to bits 2:0) + * + * bf_pack(UART_FBCON, 4) + * - return a word with that field set to 4 (so in this case (4 << 3)) + * + * bf_update(UART_FBCON, word, val) + * - update a field within word so that its value is val. + * + * bf_enum_writel(UART_FBCON, MULTI, &uart->fbcon) + * - set the UART's FBCON field to MULTI + * + * + * Why have bitfield macros? + * 1. Reability + * 2. Maintainability + * 3. Less error prone + * + * For example, this: + * + * int RegVal = 0; + * RegVal= readl(UsbBase+USB_SUSP_CTRL); + * RegVal |= Bit11; + * writel(RegVal, UsbBase+USB_SUSP_CTRL); + * if(UsbBase == NV_ADDRESS_MAP_USB3_BASE) + * { + * RegVal = readl(UsbBase+USB_SUSP_CTRL); + * RegVal |= Bit12; + * writel(RegVal, UsbBase+USB_SUSP_CTRL); + * } + * + * becomes this: + * + * bitfield_writel(UTMIP_RESET, 1, &usbctlr->susp_ctrl); + * if (id == PERIPH_ID_USB3) + * bitfield_writel(UTMIP_PHY_ENB, 1, &usbctlr->susp_ctrl); + */ + +/* Returns the low bit of the bitfield */ +#define BITFIELD_LOWBIT(range) ((0 ? range) & 0x1f) + +/* Returns the high bit of the bitfield */ +#define BITFIELD_HIGHBIT(range) (1 ? range) + +/* Returns the width of the bitfield (in bits) */ +#define BITFIELD_WIDTH(range) \ + (BITFIELD_HIGHBIT(range) - BITFIELD_LOWBIT(range) + 1) + + +/* + * Returns the number of bits the bitfield needs to be shifted left to pack it. + * This is just the same as the low bit. + */ +#define bf_shift(field) BITFIELD_LOWBIT(field ## _RANGE) + +/* Returns the unshifted mask for the field (i.e. LSB of mask is bit 0) */ +#define bf_rawmask(field) (0xfffffffful >> \ + (32 - BITFIELD_WIDTH(field ## _RANGE))) + +/* Returns the mask for a field. Clear these bits to zero the field */ +#define bf_mask(field) \ + (bf_rawmask(field) << (bf_shift(field))) + +/* Unpacks and returns a value extracted from a field */ +#define bf_unpack(field, word) \ + (((unsigned)(word) >> bf_shift(field)) & bf_rawmask(field)) + +/* + * Packs a value into a field - this masks the value to ensure it does not + * overflow into another field. + */ +#define bf_pack(field, value) \ + ((((unsigned)(value)) & bf_rawmask(field)) \ + << bf_shift(field)) + +/* Sets the value of a field in a word to the given value */ +#define bf_update(field, word, value) \ + ((word) = ((word) & ~bf_mask(field)) | \ + bf_pack(field, value)) + +/* + * Sets the value of a field in a register to the given value using + * readl/writel + */ +#define bf_writel(field, value, reg) ({ \ + u32 *__reg = (u32 *)(reg); \ + u32 __oldval = readl(__reg); \ + bf_update(field, __oldval, value); \ + writel(__oldval, __reg); \ + }) + +/* Unpacks a field from a register using readl */ +#define bf_readl(field, reg) \ + bf_unpack(field, readl(reg)) + +/* + * Clears a field in a register using writel - like + * bf_writel(field, 0, reg) + */ +#define bf_clearl(field, reg) bf_writel(field, 0, reg) + +/* + * Sets the value of a field in a register to the given enum. + * + * The enum should have the field as a prefix. + */ +#define bf_enum_writel(field, _enum, reg) \ + bf_writel(field, field ## _ ## _enum, reg) + +#endif diff --git a/test/Makefile b/test/Makefile new file mode 100644 index 0000000..6d8c6a7 --- /dev/null +++ b/test/Makefile @@ -0,0 +1,36 @@ +# Copyright (c) 2011 The Chromium OS Authors. +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +TESTS=bitfield + +INC=../arch/arm/include/asm/arch-tegra2 +CFLAGS=-DDEBUG -I$(INC) + +all: tests run + +tests: $(TESTS) + +bitfield: bitfield.o + +bitfield.o: $(INC)/bitfield.h + +run: + @echo "Running tests $(TESTS)" + @./bitfield + @echo "Tests completed." diff --git a/test/bitfield.c b/test/bitfield.c new file mode 100644 index 0000000..5fc381d --- /dev/null +++ b/test/bitfield.c @@ -0,0 +1,230 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Bitfield test routines + * + */ + +#include <stdio.h> + +#include "bitfield.h" + + +#define FULL_RANGE 31 : 0 +#define HIGH_RANGE 31 : 30 +#define MID_RANGE 23 : 16 +#define LOW_RANGE 2 : 0 +#define HIGH_SINGLE_RANGE 31 : 31 +#define MID_SINGLE_RANGE 16 : 16 +#define LOW_SINGLE_RANGE 0 : 0 + +static int test_count; + +#ifdef DEBUG +#define assert(x) \ + ({ test_count++; \ + if (!(x)) \ + printf("Assertion failure '%s' %s line %d\n", \ + #x, __FILE__, __LINE__) }) +#define asserteq(x, y) \ + ({ int _x = x; int _y = y; test_count++; \ + if (_x != _y) \ + printf("Assertion failure at %s:%d: '%s' %#x != '%s' %#x\n", \ + __FILE__, __LINE__, #x, _x, #y, _y); }) +#else +#define assert(x) (test_count++) +#define asserteq(x, y) (test_count++) +#endif + + +static void test_low_high(void) +{ + asserteq(BITFIELD_HIGHBIT(FULL_RANGE), 31); + asserteq(BITFIELD_LOWBIT(FULL_RANGE), 0); + asserteq(BITFIELD_HIGHBIT(HIGH_RANGE), 31); + asserteq(BITFIELD_LOWBIT(HIGH_RANGE), 30); + asserteq(BITFIELD_HIGHBIT(MID_RANGE), 23); + asserteq(BITFIELD_LOWBIT(MID_RANGE), 16); + asserteq(BITFIELD_HIGHBIT(LOW_RANGE), 2); + asserteq(BITFIELD_LOWBIT(LOW_RANGE), 0); + asserteq(BITFIELD_HIGHBIT(HIGH_SINGLE_RANGE), 31); + asserteq(BITFIELD_LOWBIT(HIGH_SINGLE_RANGE), 31); + asserteq(BITFIELD_HIGHBIT(MID_SINGLE_RANGE), 16); + asserteq(BITFIELD_LOWBIT(MID_SINGLE_RANGE), 16); + asserteq(BITFIELD_HIGHBIT(LOW_SINGLE_RANGE), 0); + asserteq(BITFIELD_LOWBIT(LOW_SINGLE_RANGE), 0); +} + +static void test_width(void) +{ + asserteq(BITFIELD_WIDTH(FULL_RANGE), 32); + asserteq(BITFIELD_WIDTH(HIGH_RANGE), 2); + asserteq(BITFIELD_WIDTH(MID_RANGE), 8); + asserteq(BITFIELD_WIDTH(LOW_RANGE), 3); + asserteq(BITFIELD_WIDTH(HIGH_SINGLE_RANGE), 1); + asserteq(BITFIELD_WIDTH(MID_SINGLE_RANGE), 1); + asserteq(BITFIELD_WIDTH(LOW_SINGLE_RANGE), 1); +} + +static void test_shift(void) +{ + asserteq(bf_shift(FULL), 0); + asserteq(bf_shift(HIGH), 30); + asserteq(bf_shift(MID), 16); + asserteq(bf_shift(LOW), 0); + asserteq(bf_shift(HIGH_SINGLE), 31); + asserteq(bf_shift(MID_SINGLE), 16); + asserteq(bf_shift(LOW_SINGLE), 0); +} + +static void test_rawmask(void) +{ + asserteq(bf_rawmask(FULL), 0xffffffffU); + asserteq(bf_rawmask(HIGH), 0x3); + asserteq(bf_rawmask(MID), 0xff); + asserteq(bf_rawmask(LOW), 0x7); + asserteq(bf_rawmask(HIGH_SINGLE), 0x1); + asserteq(bf_rawmask(MID_SINGLE), 0x1); + asserteq(bf_rawmask(LOW_SINGLE), 0x1); +} + +static void test_mask(void) +{ + asserteq(bf_mask(FULL), 0xffffffffU); + asserteq(bf_mask(HIGH), 0xc0000000); + asserteq(bf_mask(MID), 0x00ff0000); + asserteq(bf_mask(LOW), 0x7); + asserteq(bf_mask(HIGH_SINGLE), 0x80000000U); + asserteq(bf_mask(MID_SINGLE), 0x00010000); + asserteq(bf_mask(LOW_SINGLE), 0x1); +} + +static void test_unpack(void) +{ + asserteq(bf_unpack(FULL, 0), 0); + asserteq(bf_unpack(FULL, -1U), -1U); + asserteq(bf_unpack(FULL, 0x12345678), 0x12345678); + asserteq(bf_unpack(FULL, 0x87654321), 0x87654321); + asserteq(bf_unpack(FULL, 0xa5a5a5a6), 0xa5a5a5a6); + + asserteq(bf_unpack(HIGH, 0), 0); + asserteq(bf_unpack(HIGH, -1U), 3); + asserteq(bf_unpack(HIGH, 0x12345678), 0); + asserteq(bf_unpack(HIGH, 0x87654321), 2); + asserteq(bf_unpack(HIGH, 0xa5a5a5a6), 2); + + asserteq(bf_unpack(MID, 0), 0); + asserteq(bf_unpack(MID, -1U), 0xff); + asserteq(bf_unpack(MID, 0x12345678), 0x34); + asserteq(bf_unpack(MID, 0x87654321), 0x65); + asserteq(bf_unpack(MID, 0xa5a5a5a6), 0xa5); + + asserteq(bf_unpack(LOW, 0), 0); + asserteq(bf_unpack(LOW, -1U), 7); + asserteq(bf_unpack(LOW, 0x12345678), 0); + asserteq(bf_unpack(LOW, 0x87654321), 1); + asserteq(bf_unpack(LOW, 0xa5a5a5a6), 6); + + asserteq(bf_unpack(HIGH_SINGLE, 0), 0); + asserteq(bf_unpack(HIGH_SINGLE, -1U), 1); + asserteq(bf_unpack(HIGH_SINGLE, 0x12345678), 0); + asserteq(bf_unpack(HIGH_SINGLE, 0x87654321), 1); + asserteq(bf_unpack(HIGH_SINGLE, 0xa5a5a5a6), 1); + + asserteq(bf_unpack(MID_SINGLE, 0), 0); + asserteq(bf_unpack(MID_SINGLE, -1U), 1); + asserteq(bf_unpack(MID_SINGLE, 0x12345678), 0); + asserteq(bf_unpack(MID_SINGLE, 0x87654321), 1); + asserteq(bf_unpack(MID_SINGLE, 0xa5a5a5a6), 1); + + asserteq(bf_unpack(LOW_SINGLE, 0), 0); + asserteq(bf_unpack(LOW_SINGLE, -1U), 1); + asserteq(bf_unpack(LOW_SINGLE, 0x12345678), 0); + asserteq(bf_unpack(LOW_SINGLE, 0x87654321), 1); + asserteq(bf_unpack(LOW_SINGLE, 0xa5a5a5a6), 0); +} + +static void test_pack(void) +{ + asserteq(bf_pack(FULL, 0), 0); + asserteq(bf_pack(FULL, -1U), -1U); + asserteq(bf_pack(FULL, 0x12345678), 0x12345678); + asserteq(bf_pack(FULL, 0x87654321), 0x87654321); + asserteq(bf_pack(FULL, 0xa5a5a5a6), 0xa5a5a5a6); + + asserteq(bf_pack(HIGH, 0), 0); + asserteq(bf_pack(HIGH, -1U), 0xc0000000); + asserteq(bf_pack(HIGH, 0x12345678), 0); + asserteq(bf_pack(HIGH, 0x87654321), 0x40000000); + asserteq(bf_pack(HIGH, 0xa5a5a5a6), 0x80000000); + + asserteq(bf_pack(MID, 0), 0); + asserteq(bf_pack(MID, -1U), 0x00ff0000); + asserteq(bf_pack(MID, 0x12345678), 0x00780000); + asserteq(bf_pack(MID, 0x87654321), 0x00210000); + asserteq(bf_pack(MID, 0xa5a5a5a6), 0x00a60000); + + asserteq(bf_pack(LOW, 0), 0); + asserteq(bf_pack(LOW, -1U), 7); + asserteq(bf_pack(LOW, 0x12345678), 0); + asserteq(bf_pack(LOW, 0x87654321), 1); + asserteq(bf_pack(LOW, 0xa5a5a5a6), 6); + + asserteq(bf_pack(HIGH_SINGLE, 0), 0); + asserteq(bf_pack(HIGH_SINGLE, -1U), 0x80000000u); + asserteq(bf_pack(HIGH_SINGLE, 0x12345678), 0); + asserteq(bf_pack(HIGH_SINGLE, 0x87654321), 0x80000000u); + asserteq(bf_pack(HIGH_SINGLE, 0xa5a5a5a6), 0x00000000u); + + asserteq(bf_pack(MID_SINGLE, 0), 0); + asserteq(bf_pack(MID_SINGLE, -1U), 0x00010000); + asserteq(bf_pack(MID_SINGLE, 0x12345678), 0); + asserteq(bf_pack(MID_SINGLE, 0x87654321), 0x00010000); + asserteq(bf_pack(MID_SINGLE, 0xa5a5a5a6), 0x00000000); + + asserteq(bf_pack(LOW_SINGLE, 0), 0); + asserteq(bf_pack(LOW_SINGLE, -1U), 1); + asserteq(bf_pack(LOW_SINGLE, 0x12345678), 0); + asserteq(bf_pack(LOW_SINGLE, 0x87654321), 1); + asserteq(bf_pack(LOW_SINGLE, 0xa5a5a5a6), 0); +} + +static void test_set(void) +{ +} + +void bf_test(void) +{ + test_low_high(); + test_width(); + test_shift(); + test_rawmask(); + test_unpack(); + test_pack(); +} + +int main(int argc, char *argv[]) +{ + bf_test(); + printf("%d tests run\n", test_count); + return 0; +} -- 1.7.3.1
These functions provide access to the high resolution microsecond timer and tidy up a global variable in the code.
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/tegra2/timer.c | 27 +++++++++++++++++------ arch/arm/include/asm/arch-tegra2/timer.h | 34 ++++++++++++++++++++++++++++++ 2 files changed, 54 insertions(+), 7 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra2/timer.h
diff --git a/arch/arm/cpu/armv7/tegra2/timer.c b/arch/arm/cpu/armv7/tegra2/timer.c index fb061d0..b69c172 100644 --- a/arch/arm/cpu/armv7/tegra2/timer.c +++ b/arch/arm/cpu/armv7/tegra2/timer.c @@ -38,13 +38,12 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/tegra2.h> +#include <asm/arch/timer.h>
DECLARE_GLOBAL_DATA_PTR;
-struct timerus *timer_base = (struct timerus *)NV_PA_TMRUS_BASE; - /* counter runs at 1MHz */ -#define TIMER_CLK (1000000) +#define TIMER_CLK 1000000 #define TIMER_LOAD_VAL 0xffffffff
/* timer without interrupts */ @@ -67,10 +66,10 @@ void set_timer(ulong t) void __udelay(unsigned long usec) { long tmo = usec * (TIMER_CLK / 1000) / 1000; - unsigned long now, last = readl(&timer_base->cntr_1us); + unsigned long now, last = timer_get_us();
while (tmo > 0) { - now = readl(&timer_base->cntr_1us); + now = timer_get_us(); if (last > now) /* count up timer overflow */ tmo -= TIMER_LOAD_VAL - last + now; else @@ -82,7 +81,7 @@ void __udelay(unsigned long usec) void reset_timer_masked(void) { /* reset time, capture current incrementer value time */ - gd->lastinc = readl(&timer_base->cntr_1us) / (TIMER_CLK/CONFIG_SYS_HZ); + gd->lastinc = timer_get_us() / (TIMER_CLK/CONFIG_SYS_HZ); gd->tbl = 0; /* start "advancing" time stamp from 0 */ }
@@ -91,7 +90,7 @@ ulong get_timer_masked(void) ulong now;
/* current tick value */ - now = readl(&timer_base->cntr_1us) / (TIMER_CLK / CONFIG_SYS_HZ); + now = timer_get_us() / (TIMER_CLK / CONFIG_SYS_HZ);
if (now >= gd->lastinc) /* normal mode (non roll) */ /* move stamp forward with absolute diff ticks */ @@ -120,3 +119,17 @@ ulong get_tbclk(void) { return CONFIG_SYS_HZ; } + + +unsigned long timer_get_us(void) +{ + struct timerus *timer_base = (struct timerus *)NV_PA_TMRUS_BASE; + + return readl(&timer_base->cntr_1us); +} + +unsigned long timer_get_future_us(u32 delay) +{ + return timer_get_us() + delay; +} + diff --git a/arch/arm/include/asm/arch-tegra2/timer.h b/arch/arm/include/asm/arch-tegra2/timer.h new file mode 100644 index 0000000..5d5445e --- /dev/null +++ b/arch/arm/include/asm/arch-tegra2/timer.h @@ -0,0 +1,34 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Tegra2 timer functions */ + +#ifndef _TEGRA2_TIMER_H +#define _TEGRA2_TIMER_H + +/* returns the current monotonic timer value in microseconds */ +unsigned long timer_get_us(void); + +/* returns what the time will likely be some microseconds into the future */ +unsigned long timer_get_future_us(u32 delay); + +#endif + -- 1.7.3.1
This adds functions to enable/disable clocks and reset to on-chip peripherals.
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/tegra2/Makefile | 2 +- arch/arm/cpu/armv7/tegra2/ap20.c | 57 ++---- arch/arm/cpu/armv7/tegra2/clock.c | 163 +++++++++++++++++ arch/arm/include/asm/arch-tegra2/clk_rst.h | 100 ++++++----- arch/arm/include/asm/arch-tegra2/clock.h | 264 ++++++++++++++++++++++++++++ board/nvidia/common/board.c | 52 ++---- 6 files changed, 518 insertions(+), 120 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/clock.c create mode 100644 arch/arm/include/asm/arch-tegra2/clock.h
diff --git a/arch/arm/cpu/armv7/tegra2/Makefile b/arch/arm/cpu/armv7/tegra2/Makefile index f1ea915..b35764c 100644 --- a/arch/arm/cpu/armv7/tegra2/Makefile +++ b/arch/arm/cpu/armv7/tegra2/Makefile @@ -28,7 +28,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o -COBJS := ap20.o board.o sys_info.o timer.o +COBJS := ap20.o board.o clock.o sys_info.o timer.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/tegra2/ap20.c b/arch/arm/cpu/armv7/tegra2/ap20.c index 60dd5df..a9bfd6a 100644 --- a/arch/arm/cpu/armv7/tegra2/ap20.c +++ b/arch/arm/cpu/armv7/tegra2/ap20.c @@ -25,6 +25,7 @@ #include <asm/io.h> #include <asm/arch/tegra2.h> #include <asm/arch/clk_rst.h> +#include <asm/arch/clock.h> #include <asm/arch/pmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/scu.h> @@ -35,33 +36,34 @@ u32 s_first_boot = 1; void init_pllx(void) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + struct clk_pll *pll = &clkrst->crc_pll[CLOCK_PLL_ID_XCPU]; u32 reg;
/* If PLLX is already enabled, just return */ - reg = readl(&clkrst->crc_pllx_base); - if (reg & PLL_ENABLE) + reg = readl(&pll->pll_base); + if (reg & PLL_ENABLE_BIT) return;
/* Set PLLX_MISC */ reg = CPCON; /* CPCON[11:8] = 0001 */ - writel(reg, &clkrst->crc_pllx_misc); + writel(reg, &pll->pll_misc);
/* Use 12MHz clock here */ - reg = (PLL_BYPASS | PLL_DIVM); + reg = (PLL_BYPASS_BIT | PLL_DIVM_VALUE); reg |= (1000 << 8); /* DIVN = 0x3E8 */ - writel(reg, &clkrst->crc_pllx_base); + writel(reg, &pll->pll_base);
- reg |= PLL_ENABLE; - writel(reg, &clkrst->crc_pllx_base); + reg |= PLL_ENABLE_BIT; + writel(reg, &pll->pll_base);
- reg &= ~PLL_BYPASS; - writel(reg, &clkrst->crc_pllx_base); + reg &= ~PLL_BYPASS_BIT; + writel(reg, &pll->pll_base); }
static void enable_cpu_clock(int enable) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; - u32 reg, clk; + u32 clk;
/* * NOTE: @@ -83,10 +85,6 @@ static void enable_cpu_clock(int enable) writel(SUPER_CCLK_DIVIDER, &clkrst->crc_super_cclk_div); }
- /* Fetch the register containing the main CPU complex clock enable */ - reg = readl(&clkrst->crc_clk_out_enb_l); - reg |= CLK_ENB_CPU; - /* * Read the register containing the individual CPU clock enables and * always stop the clock to CPU 1. @@ -103,7 +101,7 @@ static void enable_cpu_clock(int enable) }
writel(clk, &clkrst->crc_clk_cpu_cmplx); - writel(reg, &clkrst->crc_clk_out_enb_l); + clock_enable(PERIPH_ID_CPU); }
static int is_cpu_powered(void) @@ -179,7 +177,7 @@ static void enable_cpu_power_rail(void) static void reset_A9_cpu(int reset) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; - u32 reg, cpu; + u32 cpu;
/* * NOTE: Regardless of whether the request is to hold the CPU in reset @@ -193,44 +191,27 @@ static void reset_A9_cpu(int reset) cpu = SET_DBGRESET1 | SET_DERESET1 | SET_CPURESET1; writel(cpu, &clkrst->crc_cpu_cmplx_set);
- reg = readl(&clkrst->crc_rst_dev_l); if (reset) { /* Now place CPU0 into reset */ cpu |= SET_DBGRESET0 | SET_DERESET0 | SET_CPURESET0; writel(cpu, &clkrst->crc_cpu_cmplx_set); - - /* Enable master CPU reset */ - reg |= SWR_CPU_RST; } else { /* Take CPU0 out of reset */ cpu = CLR_DBGRESET0 | CLR_DERESET0 | CLR_CPURESET0; writel(cpu, &clkrst->crc_cpu_cmplx_clr); - - /* Disable master CPU reset */ - reg &= ~SWR_CPU_RST; }
- writel(reg, &clkrst->crc_rst_dev_l); + /* Enable/Disable master CPU reset */ + reset_set_enable(PERIPH_ID_CPU, reset); }
static void clock_enable_coresight(int enable) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; - u32 rst, clk, src; - - rst = readl(&clkrst->crc_rst_dev_u); - clk = readl(&clkrst->crc_clk_out_enb_u); - - if (enable) { - rst &= ~SWR_CSITE_RST; - clk |= CLK_ENB_CSITE; - } else { - rst |= SWR_CSITE_RST; - clk &= ~CLK_ENB_CSITE; - } + u32 rst, src;
- writel(clk, &clkrst->crc_clk_out_enb_u); - writel(rst, &clkrst->crc_rst_dev_u); + clock_set_enable(PERIPH_ID_CORESIGHT, enable); + reset_set_enable(PERIPH_ID_CORESIGHT, !enable);
if (enable) { /* diff --git a/arch/arm/cpu/armv7/tegra2/clock.c b/arch/arm/cpu/armv7/tegra2/clock.c new file mode 100644 index 0000000..4f73d5e --- /dev/null +++ b/arch/arm/cpu/armv7/tegra2/clock.c @@ -0,0 +1,163 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Tegra2 Clock control functions */ + +#include <asm/io.h> +#include <asm/arch/bitfield.h> +#include <asm/arch/clk_rst.h> +#include <asm/arch/clock.h> +#include <asm/arch/timer.h> +#include <asm/arch/tegra2.h> +#include <common.h> + +#ifdef DEBUG +#define assert(x) \ + ({ if (!(x)) printf("Assertion failure '%s' %s line %d\n", \ + #x, __FILE__, __LINE__); }) +#else +#define assert(x) +#endif + +/* + * Get the oscillator frequency, from the corresponding hardware configuration + * field. + */ +enum clock_osc_freq clock_get_osc_freq(void) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg; + + reg = readl(&clkrst->crc_osc_ctrl); + return bf_unpack(OSC_FREQ, reg); +} + +unsigned long clock_start_pll(enum clock_pll_id clkid, u32 divm, u32 divn, + u32 divp, u32 cpcon, u32 lfcon) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 data; + struct clk_pll *pll; + + assert(clock_pll_id_isvalid(clkid)); + pll = &clkrst->crc_pll[clkid]; + + /* + * We cheat by treating all PLL (except PLLU) in the same fashion. + * This works only because: + * - same fields are always mapped at same offsets, except DCCON + * - DCCON is always 0, doesn't conflict + * - M,N, P of PLLP values are ignored for PLLP + */ + + data = bf_pack(PLL_CPCON, cpcon) | + bf_pack(PLL_LFCON, lfcon); + writel(data, &pll->pll_misc); + + data = bf_pack(PLL_DIVM, divm) | + bf_pack(PLL_DIVN, divn) | + bf_pack(PLL_BYPASS, 0) | + bf_pack(PLL_ENABLE, 1); + + if (clkid == CLOCK_PLL_ID_USB) + data |= bf_pack(PLL_VCO_FREQ, divp); + else + data |= bf_pack(PLL_DIVP, divp); + writel(data, &pll->pll_base); + + /* calculate the stable time */ + return timer_get_future_us(CLOCK_PLL_STABLE_DELAY_US); +} + +void clock_set_enable(enum periph_id periph_id, int enable) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 *clk = &clkrst->crc_clk_out_enb[PERIPH_REG(periph_id)]; + u32 reg; + + /* Enable/disable the clock to this peripheral */ + assert(clock_periph_id_isvalid(periph_id)); + reg = readl(clk); + if (enable) + reg |= PERIPH_MASK(periph_id); + else + reg &= ~PERIPH_MASK(periph_id); + writel(reg, clk); +} + +void clock_enable(enum periph_id clkid) +{ + clock_set_enable(clkid, 1); +} + +void clock_disable(enum periph_id clkid) +{ + clock_set_enable(clkid, 0); +} + +void reset_set_enable(enum periph_id periph_id, int enable) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 *reset = &clkrst->crc_rst_dev[PERIPH_REG(periph_id)]; + u32 reg; + + /* Enable/disable reset to the peripheral */ + assert(clock_periph_id_isvalid(periph_id)); + reg = readl(reset); + if (enable) + reg |= PERIPH_MASK(periph_id); + else + reg &= ~PERIPH_MASK(periph_id); + writel(reg, reset); +} + +void reset_periph(enum periph_id periph_id, int us_delay) +{ + /* Put peripheral into reset */ + reset_set_enable(periph_id, 1); + udelay(us_delay); + + /* Remove reset */ + reset_set_enable(periph_id, 0); + + udelay(us_delay); +} + +void reset_cmplx_set_enable(int cpu, int which, int reset) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 mask; + + /* Form the mask, which depends on the cpu chosen. Tegra2 has 2 */ + assert(cpu >= 0 && cpu < 2); + mask = which << cpu; + + /* either enable or disable those reset for that CPU */ + if (reset) + writel(mask, &clkrst->crc_cpu_cmplx_set); + else + writel(mask, &clkrst->crc_cpu_cmplx_clr); +} diff --git a/arch/arm/include/asm/arch-tegra2/clk_rst.h b/arch/arm/include/asm/arch-tegra2/clk_rst.h index bd8ad2c..f51300e 100644 --- a/arch/arm/include/asm/arch-tegra2/clk_rst.h +++ b/arch/arm/include/asm/arch-tegra2/clk_rst.h @@ -24,15 +24,35 @@ #ifndef _CLK_RST_H_ #define _CLK_RST_H_
+ +/* PLL registers - there are several PLLs in the clock controller */ +struct clk_pll { + uint pll_base; /* the control register */ + uint pll_out; /* output control */ + uint reserved; + uint pll_misc; /* other misc things */ +}; + +/* PLL registers - there are several PLLs in the clock controller */ +struct clk_pll_simple { + uint pll_base; /* the control register */ + uint pll_misc; /* other misc things */ +}; + +/* + * Most PLLs use the clk_pll structure, but some have a simpler two-member + * structure for which we use clk_pll_simple. The reason for this non- + * othogonal setup is not stated. + */ +#define TEGRA_CLK_PLLS 6 +#define TEGRA_CLK_SIMPLE_PLLS 3 /* Number of simple PLLs */ +#define TEGRA_CLK_REGS 3 /* Number of clock enable registers */ + /* Clock/Reset Controller (CLK_RST_CONTROLLER_) regs */ struct clk_rst_ctlr { - uint crc_rst_src; /* _RST_SOURCE_0, 0x00 */ - uint crc_rst_dev_l; /* _RST_DEVICES_L_0, 0x04 */ - uint crc_rst_dev_h; /* _RST_DEVICES_H_0, 0x08 */ - uint crc_rst_dev_u; /* _RST_DEVICES_U_0, 0x0C */ - uint crc_clk_out_enb_l; /* _CLK_OUT_ENB_L_0, 0x10 */ - uint crc_clk_out_enb_h; /* _CLK_OUT_ENB_H_0, 0x14 */ - uint crc_clk_out_enb_u; /* _CLK_OUT_ENB_U_0, 0x18 */ + uint crc_rst_src; /* _RST_SOURCE_0,0x00 */ + uint crc_rst_dev[TEGRA_CLK_REGS]; /* _RST_DEVICES_L/H/U_0 */ + uint crc_clk_out_enb[TEGRA_CLK_REGS]; /* _CLK_OUT_ENB_L/H/U_0 */ uint crc_reserved0; /* reserved_0, 0x1C */ uint crc_cclk_brst_pol; /* _CCLK_BURST_POLICY_0,0x20 */ uint crc_super_cclk_div; /* _SUPER_CCLK_DIVIDER_0,0x24 */ @@ -52,44 +72,11 @@ struct clk_rst_ctlr { uint crc_osc_freq_det_stat; /* _OSC_FREQ_DET_STATUS_0,0x5C */ uint crc_reserved2[8]; /* reserved_2[8], 0x60-7C */
- uint crc_pllc_base; /* _PLLC_BASE_0, 0x80 */ - uint crc_pllc_out; /* _PLLC_OUT_0, 0x84 */ - uint crc_reserved3; /* reserved_3, 0x88 */ - uint crc_pllc_misc; /* _PLLC_MISC_0, 0x8C */ + struct clk_pll crc_pll[TEGRA_CLK_PLLS]; /* PLLs from 0x80 to 0xdc */
- uint crc_pllm_base; /* _PLLM_BASE_0, 0x90 */ - uint crc_pllm_out; /* _PLLM_OUT_0, 0x94 */ - uint crc_reserved4; /* reserved_4, 0x98 */ - uint crc_pllm_misc; /* _PLLM_MISC_0, 0x9C */ + /* PLLs from 0xe0 to 0xf4 */ + struct clk_pll_simple crc_pll_simple[TEGRA_CLK_SIMPLE_PLLS];
- uint crc_pllp_base; /* _PLLP_BASE_0, 0xA0 */ - uint crc_pllp_outa; /* _PLLP_OUTA_0, 0xA4 */ - uint crc_pllp_outb; /* _PLLP_OUTB_0, 0xA8 */ - uint crc_pllp_misc; /* _PLLP_MISC_0, 0xAC */ - - uint crc_plla_base; /* _PLLA_BASE_0, 0xB0 */ - uint crc_plla_out; /* _PLLA_OUT_0, 0xB4 */ - uint crc_reserved5; /* reserved_5, 0xB8 */ - uint crc_plla_misc; /* _PLLA_MISC_0, 0xBC */ - - uint crc_pllu_base; /* _PLLU_BASE_0, 0xC0 */ - uint crc_reserved6; /* _reserved_6, 0xC4 */ - uint crc_reserved7; /* _reserved_7, 0xC8 */ - uint crc_pllu_misc; /* _PLLU_MISC_0, 0xCC */ - - uint crc_plld_base; /* _PLLD_BASE_0, 0xD0 */ - uint crc_reserved8; /* _reserved_8, 0xD4 */ - uint crc_reserved9; /* _reserved_9, 0xD8 */ - uint crc_plld_misc; /* _PLLD_MISC_0, 0xDC */ - - uint crc_pllx_base; /* _PLLX_BASE_0, 0xE0 */ - uint crc_pllx_misc; /* _PLLX_MISC_0, 0xE4 */ - - uint crc_plle_base; /* _PLLE_BASE_0, 0xE8 */ - uint crc_plle_misc; /* _PLLE_MISC_0, 0xEC */ - - uint crc_plls_base; /* _PLLS_BASE_0, 0xF0 */ - uint crc_plls_misc; /* _PLLS_MISC_0, 0xF4 */ uint crc_reserved10; /* _reserved_10, 0xF8 */ uint crc_reserved11; /* _reserved_11, 0xFC */
@@ -154,11 +141,11 @@ struct clk_rst_ctlr { uint crc_cpu_cmplx_clr; /* _CPU_CMPLX_CLR_0, 0x344 */ };
-#define PLL_BYPASS (1 << 31) -#define PLL_ENABLE (1 << 30) -#define PLL_BASE_OVRRIDE (1 << 28) -#define PLL_DIVP (1 << 20) /* post divider, b22:20 */ -#define PLL_DIVM 0x0C /* input divider, b4:0 */ +#define PLL_BYPASS_BIT (1 << 31) +#define PLL_ENABLE_BIT (1 << 30) +#define PLL_BASE_OVRRIDE_BIT (1 << 28) +#define PLL_DIVP_VALUE (1 << 20) /* post divider, b22:20 */ +#define PLL_DIVM_VALUE 0x0C /* input divider, b4:0 */
#define SWR_UARTD_RST (1 << 1) #define CLK_ENB_UARTD (1 << 1) @@ -191,4 +178,21 @@ struct clk_rst_ctlr {
#define CPCON (1 << 8)
+/* CLK_RST_CONTROLLER_PLLx_BASE_0 */ +#define PLL_BYPASS_RANGE 31 : 31 +#define PLL_ENABLE_RANGE 30 : 30 +#define PLL_BASE_OVRRIDE_RANGE 28 : 28 +#define PLL_DIVP_RANGE 22 : 20 +#define PLL_DIVN_RANGE 17 : 8 +#define PLL_DIVM_RANGE 4 : 0 + +/* CLK_RST_CONTROLLER_PLLx_MISC_0 */ +#define PLL_CPCON_RANGE 11 : 8 +#define PLL_LFCON_RANGE 7 : 4 +#define PLLU_VCO_FREQ_RANGE 20 : 20 +#define PLL_VCO_FREQ_RANGE 3 : 0 + +/* CLK_RST_CONTROLLER_OSC_CTRL_0 */ +#define OSC_FREQ_RANGE 31 : 30 + #endif /* CLK_RST_H */ diff --git a/arch/arm/include/asm/arch-tegra2/clock.h b/arch/arm/include/asm/arch-tegra2/clock.h new file mode 100644 index 0000000..81a9f02 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra2/clock.h @@ -0,0 +1,264 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Tegra2 clock control functions */ + +#ifndef _CLOCK_H + + +/* Set of oscillator frequencies supported in the internal API. */ +enum clock_osc_freq { + /* All in MHz, so 13_0 is 13.0MHz */ + CLOCK_OSC_FREQ_13_0, + CLOCK_OSC_FREQ_19_2, + CLOCK_OSC_FREQ_12_0, + CLOCK_OSC_FREQ_26_0, + + CLOCK_OSC_FREQ_COUNT, +}; + +/* The PLLs supported by the hardware */ +enum clock_pll_id { + CLOCK_PLL_ID_FIRST, + CLOCK_PLL_ID_CGENERAL = CLOCK_PLL_ID_FIRST, + CLOCK_PLL_ID_MEMORY, + CLOCK_PLL_ID_PERIPH, + CLOCK_PLL_ID_AUDIO, + CLOCK_PLL_ID_USB, + CLOCK_PLL_ID_DISPLAY, + + /* now the simple ones */ + CLOCK_PLL_ID_FIRST_SIMPLE, + CLOCK_PLL_ID_XCPU = CLOCK_PLL_ID_FIRST_SIMPLE, + CLOCK_PLL_ID_EPCI, + CLOCK_PLL_ID_SFROM32KHZ, + + CLOCK_PLL_ID_COUNT, +}; + +/* The clocks supported by the hardware */ +enum periph_id { + PERIPH_ID_FIRST, + + /* Low word: 31:0 */ + PERIPH_ID_CPU = PERIPH_ID_FIRST, + PERIPH_ID_RESERVED1, + PERIPH_ID_RESERVED2, + PERIPH_ID_AC97, + PERIPH_ID_RTC, + PERIPH_ID_TMR, + PERIPH_ID_UART1, + PERIPH_ID_UART2, + + /* 8 */ + PERIPH_ID_GPIO, + PERIPH_ID_SDMMC2, + PERIPH_ID_SPDIF, + PERIPH_ID_I2S1, + PERIPH_ID_I2C1, + PERIPH_ID_NDFLASH, + PERIPH_ID_SDMMC1, + PERIPH_ID_SDMMC4, + + /* 16 */ + PERIPH_ID_TWC, + PERIPH_ID_PWC, + PERIPH_ID_I2S2, + PERIPH_ID_EPP, + PERIPH_ID_VI, + PERIPH_ID_2D, + PERIPH_ID_USBD, + PERIPH_ID_ISP, + + /* 24 */ + PERIPH_ID_3D, + PERIPH_ID_IDE, + PERIPH_ID_DISP2, + PERIPH_ID_DISP1, + PERIPH_ID_HOST1X, + PERIPH_ID_VCP, + PERIPH_ID_RESERVED30, + PERIPH_ID_CACHE2, + + /* Middle word: 63:32 */ + PERIPH_ID_MEM, + PERIPH_ID_AHBDMA, + PERIPH_ID_APBDMA, + PERIPH_ID_RESERVED35, + PERIPH_ID_KBC, + PERIPH_ID_STAT_MON, + PERIPH_ID_PMC, + PERIPH_ID_FUSE, + + /* 40 */ + PERIPH_ID_KFUSE, + PERIPH_ID_SBC1, + PERIPH_ID_SNOR, + PERIPH_ID_SPI1, + PERIPH_ID_SBC2, + PERIPH_ID_XIO, + PERIPH_ID_SBC3, + PERIPH_ID_DVC_I2C, + + /* 48 */ + PERIPH_ID_DSI, + PERIPH_ID_TVO, + PERIPH_ID_MIPI, + PERIPH_ID_HDMI, + PERIPH_ID_CSI, + PERIPH_ID_TVDAC, + PERIPH_ID_I2C2, + PERIPH_ID_UART3, + + /* 56 */ + PERIPH_ID_RESERVED56, + PERIPH_ID_EMC, + PERIPH_ID_USB2, + PERIPH_ID_USB3, + PERIPH_ID_MPE, + PERIPH_ID_VDE, + PERIPH_ID_BSEA, + PERIPH_ID_BSEV, + + /* Upper word 95:64 */ + PERIPH_ID_SPEEDO, + PERIPH_ID_UART4, + PERIPH_ID_UART5, + PERIPH_ID_I2C3, + PERIPH_ID_SBC4, + PERIPH_ID_SDMMC3, + PERIPH_ID_PCIE, + PERIPH_ID_OWR, + + /* 72 */ + PERIPH_ID_AFI, + PERIPH_ID_CORESIGHT, + PERIPH_ID_RESERVED74, + PERIPH_ID_AVPUCQ, + PERIPH_ID_RESERVED76, + PERIPH_ID_RESERVED77, + PERIPH_ID_RESERVED78, + PERIPH_ID_RESERVED79, + + /* 80 */ + PERIPH_ID_RESERVED80, + PERIPH_ID_RESERVED81, + PERIPH_ID_RESERVED82, + PERIPH_ID_RESERVED83, + PERIPH_ID_IRAMA, + PERIPH_ID_IRAMB, + PERIPH_ID_IRAMC, + PERIPH_ID_IRAMD, + + /* 88 */ + PERIPH_ID_CRAM2, + + PERIPH_ID_COUNT, +}; + +/* Converts a clock number to a clock register: 0=L, 1=H, 2=U */ +#define PERIPH_REG(id) ((id) >> 5) + +/* Mask value for a clock (within PERIPH_REG(id)) */ +#define PERIPH_MASK(id) (1 << ((id) & 0x1f)) + +/* return 1 if a PLL ID is in range */ +#define clock_pll_id_isvalid(id) ((id) >= CLOCK_PLL_ID_FIRST && \ + (id) < CLOCK_PLL_ID_COUNT) + +/* return 1 if a peripheral ID is in range */ +#define clock_periph_id_isvalid(id) ((id) >= PERIPH_ID_FIRST && \ + (id) < PERIPH_ID_COUNT) + +/* PLL stabilization delay in usec */ +#define CLOCK_PLL_STABLE_DELAY_US 300 + +/* return the current oscillator clock frequency */ +enum clock_osc_freq clock_get_osc_freq(void); + +/* + * Start PLL using the provided configuration parameters. + * + * @param id clock id + * @param divm input divider + * @param divn feedback divider + * @param divp post divider 2^n + * @param cpcon charge pump setup control + * @param lfcon loop filter setup control + * + * @returns monotonic time in us that the PLL will be stable + */ +unsigned long clock_start_pll(enum clock_pll_id id, u32 divm, u32 divn, + u32 divp, u32 cpcon, u32 lfcon); + +/* + * Enable a clock + * + * @param id clock id + */ +void clock_enable(enum periph_id clkid); + +/* + * Set whether a clock is enabled or disabled. + * + * @param id clock id + * @param enable 1 to enable, 0 to disable + */ +void clock_set_enable(enum periph_id clkid, int enable); + +/* + * Reset a peripheral. This puts it in reset, waits for a delay, then takes + * it out of reset and waits for th delay again. + * + * @param periph_id peripheral to reset + * @param us_delay time to delay in microseconds + */ +void reset_periph(enum periph_id periph_id, int us_delay); + +/* + * Put a peripheral into or out of reset. + * + * @param periph_id peripheral to reset + * @param enable 1 to put into reset, 0 to take out of reset + */ +void reset_set_enable(enum periph_id periph_id, int enable); + + +/* CLK_RST_CONTROLLER_RST_CPU_CMPLX_SET/CLR_0 */ +enum crc_reset_id { + /* Things we can hold in reset for each CPU */ + crc_rst_cpu = 1, + crc_rst_de = 1 << 2, /* What is de? */ + crc_rst_watchdog = 1 << 3, + crc_rst_debug = 1 << 4, +}; + +/* + * Put parts of the CPU complex into or out of reset.\ + * + * @param cpu cpu number (0 or 1 on Tegra2) + * @param which which parts of the complex to affect (OR of crc_reset_id) + * @param reset 1 to assert reset, 0 to de-assert + */ +void reset_cmplx_set_enable(int cpu, int which, int reset); + +#endif + diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 3d6c248..12e79ae 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -28,6 +28,7 @@ #include <asm/arch/sys_proto.h>
#include <asm/arch/clk_rst.h> +#include <asm/arch/clock.h> #include <asm/arch/pinmux.h> #include <asm/arch/uart.h> #include "board.h" @@ -73,33 +74,28 @@ int timer_init(void) static void clock_init_uart(void) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + struct clk_pll *pll = &clkrst->crc_pll[CLOCK_PLL_ID_PERIPH]; u32 reg;
- reg = readl(&clkrst->crc_pllp_base); - if (!(reg & PLL_BASE_OVRRIDE)) { + reg = readl(&pll->pll_base); + if (!(reg & PLL_BASE_OVRRIDE_BIT)) { /* Override pllp setup for 216MHz operation. */ - reg = (PLL_BYPASS | PLL_BASE_OVRRIDE | PLL_DIVP); - reg |= (((NVRM_PLLP_FIXED_FREQ_KHZ/500) << 8) | PLL_DIVM); - writel(reg, &clkrst->crc_pllp_base); + reg = (PLL_BYPASS_BIT | PLL_BASE_OVRRIDE_BIT | PLL_DIVP_VALUE); + reg |= (((NVRM_PLLP_FIXED_FREQ_KHZ/500) << 8) | PLL_DIVM_VALUE); + writel(reg, &pll->pll_base);
- reg |= PLL_ENABLE; - writel(reg, &clkrst->crc_pllp_base); + reg |= PLL_ENABLE_BIT; + writel(reg, &pll->pll_base);
- reg &= ~PLL_BYPASS; - writel(reg, &clkrst->crc_pllp_base); + reg &= ~PLL_BYPASS_BIT; + writel(reg, &pll->pll_base); }
/* Now do the UART reset/clock enable */ #if defined(CONFIG_TEGRA2_ENABLE_UARTA) - /* Assert Reset to UART */ - reg = readl(&clkrst->crc_rst_dev_l); - reg |= SWR_UARTA_RST; /* SWR_UARTA_RST = 1 */ - writel(reg, &clkrst->crc_rst_dev_l); - - /* Enable clk to UART */ - reg = readl(&clkrst->crc_clk_out_enb_l); - reg |= CLK_ENB_UARTA; /* CLK_ENB_UARTA = 1 */ - writel(reg, &clkrst->crc_clk_out_enb_l); + /* Assert UART reset and enable clock */ + reset_set_enable(PERIPH_ID_UART1, 1); + clock_enable(PERIPH_ID_UART1);
/* Enable pllp_out0 to UART */ reg = readl(&clkrst->crc_clk_src_uarta); @@ -110,20 +106,12 @@ static void clock_init_uart(void) udelay(2);
/* De-assert reset to UART */ - reg = readl(&clkrst->crc_rst_dev_l); - reg &= ~SWR_UARTA_RST; /* SWR_UARTA_RST = 0 */ - writel(reg, &clkrst->crc_rst_dev_l); + reset_set_enable(PERIPH_ID_UART1, 0); #endif /* CONFIG_TEGRA2_ENABLE_UARTA */ #if defined(CONFIG_TEGRA2_ENABLE_UARTD) - /* Assert Reset to UART */ - reg = readl(&clkrst->crc_rst_dev_u); - reg |= SWR_UARTD_RST; /* SWR_UARTD_RST = 1 */ - writel(reg, &clkrst->crc_rst_dev_u); - - /* Enable clk to UART */ - reg = readl(&clkrst->crc_clk_out_enb_u); - reg |= CLK_ENB_UARTD; /* CLK_ENB_UARTD = 1 */ - writel(reg, &clkrst->crc_clk_out_enb_u); + /* Assert UART reset and enable clock */ + reset_set_enable(PERIPH_ID_UART4, 1); + clock_enable(PERIPH_ID_UART4);
/* Enable pllp_out0 to UART */ reg = readl(&clkrst->crc_clk_src_uartd); @@ -134,9 +122,7 @@ static void clock_init_uart(void) udelay(2);
/* De-assert reset to UART */ - reg = readl(&clkrst->crc_rst_dev_u); - reg &= ~SWR_UARTD_RST; /* SWR_UARTD_RST = 0 */ - writel(reg, &clkrst->crc_rst_dev_u); + reset_set_enable(PERIPH_ID_UART4, 0); #endif /* CONFIG_TEGRA2_ENABLE_UARTD */ }
-- 1.7.3.1
This adds an enum for each pin and some functions for changing the pin muxing setup.
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/tegra2/Makefile | 2 +- arch/arm/cpu/armv7/tegra2/pinmux.c | 54 ++++++++++ arch/arm/include/asm/arch-tegra2/pinmux.h | 156 +++++++++++++++++++++++++++-- board/nvidia/common/board.c | 10 +-- 4 files changed, 207 insertions(+), 15 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/pinmux.c
diff --git a/arch/arm/cpu/armv7/tegra2/Makefile b/arch/arm/cpu/armv7/tegra2/Makefile index b35764c..f673f03 100644 --- a/arch/arm/cpu/armv7/tegra2/Makefile +++ b/arch/arm/cpu/armv7/tegra2/Makefile @@ -28,7 +28,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o -COBJS := ap20.o board.o clock.o sys_info.o timer.o +COBJS := ap20.o board.o clock.o pinmux.o sys_info.o timer.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/tegra2/pinmux.c b/arch/arm/cpu/armv7/tegra2/pinmux.c new file mode 100644 index 0000000..f00fd7c --- /dev/null +++ b/arch/arm/cpu/armv7/tegra2/pinmux.c @@ -0,0 +1,54 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Tegra2 pin multiplexing functions */ + +#include <asm/io.h> +#include <asm/arch/bitfield.h> +#include <asm/arch/tegra2.h> +#include <asm/arch/pinmux.h> +#include <common.h> + + +void pinmux_set_tristate(enum pmux_pin pin, int enable) +{ + struct pmux_tri_ctlr *pmt = (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *tri = &pmt->pmt_tri[TRISTATE_REG(pin)]; + u32 reg; + + reg = readl(tri); + if (enable) + reg |= TRISTATE_MASK(pin); + else + reg &= ~TRISTATE_MASK(pin); + writel(reg, tri); +} + +void pinmux_tristate_enable(enum pmux_pin pin) +{ + pinmux_set_tristate(pin, 1); +} + +void pinmux_tristate_disable(enum pmux_pin pin) +{ + pinmux_set_tristate(pin, 0); +} + diff --git a/arch/arm/include/asm/arch-tegra2/pinmux.h b/arch/arm/include/asm/arch-tegra2/pinmux.h index 8b4bd8d..d4a0812 100644 --- a/arch/arm/include/asm/arch-tegra2/pinmux.h +++ b/arch/arm/include/asm/arch-tegra2/pinmux.h @@ -24,6 +24,143 @@ #ifndef _PINMUX_H_ #define _PINMUX_H_
+ +/* Pins which we can set to tristate or normal */ +enum pmux_pin { + /* APB_MISC_PP_TRISTATE_REG_A_0 */ + PIN_ATA, + PIN_ATB, + PIN_ATC, + PIN_ATD, + PIN_CDEV1, + PIN_CDEV2, + PIN_CSUS, + PIN_DAP1, + + PIN_DAP2, + PIN_DAP3, + PIN_DAP4, + PIN_DTA, + PIN_DTB, + PIN_DTC, + PIN_DTD, + PIN_DTE, + + PIN_GPU, + PIN_GPV, + PIN_I2CP, + PIN_IRTX, + PIN_IRRX, + PIN_KBCB, + PIN_KBCA, + PIN_PMC, + + PIN_PTA, + PIN_RM, + PIN_KBCE, + PIN_KBCF, + PIN_GMA, + PIN_GMC, + PIN_SDMMC1, + PIN_OWC, + + /* 32: APB_MISC_PP_TRISTATE_REG_B_0 */ + PIN_GME, + PIN_SDC, + PIN_SDD, + PIN_RESERVED0, + PIN_SLXA, + PIN_SLXC, + PIN_SLXD, + PIN_SLXK, + + PIN_SPDI, + PIN_SPDO, + PIN_SPIA, + PIN_SPIB, + PIN_SPIC, + PIN_SPID, + PIN_SPIE, + PIN_SPIF, + + PIN_SPIG, + PIN_SPIH, + PIN_UAA, + PIN_UAB, + PIN_UAC, + PIN_UAD, + PIN_UCA, + PIN_UCB, + + PIN_RESERVED1, + PIN_ATE, + PIN_KBCC, + PIN_RESERVED2, + PIN_RESERVED3, + PIN_GMB, + PIN_GMD, + PIN_DDC, + + /* 64: APB_MISC_PP_TRISTATE_REG_C_0 */ + PIN_LD0, + PIN_LD1, + PIN_LD2, + PIN_LD3, + PIN_LD4, + PIN_LD5, + PIN_LD6, + PIN_LD7, + + PIN_LD8, + PIN_LD9, + PIN_LD10, + PIN_LD11, + PIN_LD12, + PIN_LD13, + PIN_LD14, + PIN_LD15, + + PIN_LD16, + PIN_LD17, + PIN_LHP0, + PIN_LHP1, + PIN_LHP2, + PIN_LVP0, + PIN_LVP1, + PIN_HDINT, + + PIN_LM0, + PIN_LM1, + PIN_LVS, + PIN_LSC0, + PIN_LSC1, + PIN_LSCK, + PIN_LDC, + PIN_LCSN, + + /* 96: APB_MISC_PP_TRISTATE_REG_D_0 */ + PIN_LSPI, + PIN_LSDA, + PIN_LSDI, + PIN_LPW0, + PIN_LPW1, + PIN_LPW2, + PIN_LDI, + PIN_LHS, + + PIN_LPP, + PIN_RESERVED4, + PIN_KBCD, + PIN_GPU7, + PIN_DTF, + PIN_UDA, + PIN_CRTP, + PIN_SDB, +}; + + +#define TEGRA_TRISTATE_REGS 4 + /* APB MISC Pin Mux and Tristate (APB_MISC_PP_) registers */ struct pmux_tri_ctlr { uint pmt_reserved0; /* ABP_MISC_PP_ reserved offset 00 */ @@ -31,10 +168,7 @@ struct pmux_tri_ctlr { uint pmt_strap_opt_a; /* _STRAPPING_OPT_A_0, offset 08 */ uint pmt_reserved2; /* ABP_MISC_PP_ reserved offset 0C */ uint pmt_reserved3; /* ABP_MISC_PP_ reserved offset 10 */ - uint pmt_tri_a; /* _TRI_STATE_REG_A_0, offset 14 */ - uint pmt_tri_b; /* _TRI_STATE_REG_B_0, offset 18 */ - uint pmt_tri_c; /* _TRI_STATE_REG_C_0, offset 1C */ - uint pmt_tri_d; /* _TRI_STATE_REG_D_0, offset 20 */ + uint pmt_tri[TEGRA_TRISTATE_REGS]; /* _TRI_STATE_REG_A/B/C/D_0 14-20 */ uint pmt_cfg_ctl; /* _CONFIG_CTL_0, offset 24 */
uint pmt_reserved[22]; /* ABP_MISC_PP_ reserved offs 28-7C */ @@ -48,8 +182,16 @@ struct pmux_tri_ctlr { uint pmt_ctl_g; /* _PIN_MUX_CTL_G_0, offset 98 */ };
-#define Z_GMC (1 << 29) -#define Z_IRRX (1 << 20) -#define Z_IRTX (1 << 19) +/* Converts a pin number to a tristate register: 0=A, 1=B, 2=C, 3=D */ +#define TRISTATE_REG(id) ((id) >> 5) + +/* Mask value for a tristate (within TRISTATE_REG(id)) */ +#define TRISTATE_MASK(id) (1 << ((id) & 0x1f)) + +/* Set a pin to tristate */ +void pinmux_tristate_enable(enum pmux_pin pin); + +/* Set a pin to normal (non tristate) */ +void pinmux_tristate_disable(enum pmux_pin pin);
#endif /* PINMUX_H */ diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 12e79ae..f07328e 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -140,19 +140,15 @@ static void pin_mux_uart(void) reg &= 0xFFF0FFFF; /* IRRX_/IRTX_SEL [19:16] = 00 UARTA */ writel(reg, &pmt->pmt_ctl_c);
- reg = readl(&pmt->pmt_tri_a); - reg &= ~Z_IRRX; /* Z_IRRX = normal (0) */ - reg &= ~Z_IRTX; /* Z_IRTX = normal (0) */ - writel(reg, &pmt->pmt_tri_a); + pinmux_tristate_disable(PIN_IRRX); + pinmux_tristate_disable(PIN_IRTX); #endif /* CONFIG_TEGRA2_ENABLE_UARTA */ #if defined(CONFIG_TEGRA2_ENABLE_UARTD) reg = readl(&pmt->pmt_ctl_b); reg &= 0xFFFFFFF3; /* GMC_SEL [3:2] = 00, UARTD */ writel(reg, &pmt->pmt_ctl_b);
- reg = readl(&pmt->pmt_tri_a); - reg &= ~Z_GMC; /* Z_GMC = normal (0) */ - writel(reg, &pmt->pmt_tri_a); + pinmux_tristate_disable(PIN_GMC); #endif /* CONFIG_TEGRA2_ENABLE_UARTD */ }
-- 1.7.3.1
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/tegra2/ap20.c | 47 +++++++++------------------- arch/arm/include/asm/arch-tegra2/clk_rst.h | 39 ++--------------------- board/nvidia/common/board.c | 13 ++++--- 3 files changed, 25 insertions(+), 74 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/ap20.c b/arch/arm/cpu/armv7/tegra2/ap20.c index a9bfd6a..7da00cd 100644 --- a/arch/arm/cpu/armv7/tegra2/ap20.c +++ b/arch/arm/cpu/armv7/tegra2/ap20.c @@ -24,6 +24,7 @@ #include "ap20.h" #include <asm/io.h> #include <asm/arch/tegra2.h> +#include <asm/arch/bitfield.h> #include <asm/arch/clk_rst.h> #include <asm/arch/clock.h> #include <asm/arch/pmc.h> @@ -40,23 +41,22 @@ void init_pllx(void) u32 reg;
/* If PLLX is already enabled, just return */ - reg = readl(&pll->pll_base); - if (reg & PLL_ENABLE_BIT) + if (bf_readl(PLL_ENABLE, &pll->pll_base)) return;
/* Set PLLX_MISC */ - reg = CPCON; /* CPCON[11:8] = 0001 */ + reg = bf_pack(PLL_CPCON, 1); writel(reg, &pll->pll_misc);
/* Use 12MHz clock here */ - reg = (PLL_BYPASS_BIT | PLL_DIVM_VALUE); - reg |= (1000 << 8); /* DIVN = 0x3E8 */ + reg = bf_pack(PLL_BYPASS, 1) | bf_pack(PLL_DIVM, 12); + reg |= bf_pack(PLL_DIVN, 1000); writel(reg, &pll->pll_base);
- reg |= PLL_ENABLE_BIT; + reg |= bf_pack(PLL_ENABLE, 1); writel(reg, &pll->pll_base);
- reg &= ~PLL_BYPASS_BIT; + reg &= ~bf_mask(PLL_BYPASS); writel(reg, &pll->pll_base); }
@@ -90,17 +90,12 @@ static void enable_cpu_clock(int enable) * always stop the clock to CPU 1. */ clk = readl(&clkrst->crc_clk_cpu_cmplx); - clk |= CPU1_CLK_STP; - - if (enable) { - /* Unstop the CPU clock */ - clk &= ~CPU0_CLK_STP; - } else { - /* Stop the CPU clock */ - clk |= CPU0_CLK_STP; - } + clk |= bf_pack(CPU1_CLK_STP, 1);
+ /* Stop/Unstop the CPU clock */ + bf_update(CPU0_CLK_STP, clk, enable == 0); writel(clk, &clkrst->crc_clk_cpu_cmplx); + clock_enable(PERIPH_ID_CPU); }
@@ -176,9 +171,6 @@ static void enable_cpu_power_rail(void)
static void reset_A9_cpu(int reset) { - struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; - u32 cpu; - /* * NOTE: Regardless of whether the request is to hold the CPU in reset * or take it out of reset, every processor in the CPU complex @@ -187,19 +179,10 @@ static void reset_A9_cpu(int reset) * are multiple processors in the CPU complex. */
- /* Hold CPU 1 in reset */ - cpu = SET_DBGRESET1 | SET_DERESET1 | SET_CPURESET1; - writel(cpu, &clkrst->crc_cpu_cmplx_set); - - if (reset) { - /* Now place CPU0 into reset */ - cpu |= SET_DBGRESET0 | SET_DERESET0 | SET_CPURESET0; - writel(cpu, &clkrst->crc_cpu_cmplx_set); - } else { - /* Take CPU0 out of reset */ - cpu = CLR_DBGRESET0 | CLR_DERESET0 | CLR_CPURESET0; - writel(cpu, &clkrst->crc_cpu_cmplx_clr); - } + /* Hold CPU 1 in reset, and CPU 0 if asked */ + reset_cmplx_set_enable(1, crc_rst_cpu | crc_rst_de | crc_rst_debug, 1); + reset_cmplx_set_enable(0, crc_rst_cpu | crc_rst_de | crc_rst_debug, + reset);
/* Enable/Disable master CPU reset */ reset_set_enable(PERIPH_ID_CPU, reset); diff --git a/arch/arm/include/asm/arch-tegra2/clk_rst.h b/arch/arm/include/asm/arch-tegra2/clk_rst.h index f51300e..a8c6fb3 100644 --- a/arch/arm/include/asm/arch-tegra2/clk_rst.h +++ b/arch/arm/include/asm/arch-tegra2/clk_rst.h @@ -141,42 +141,9 @@ struct clk_rst_ctlr { uint crc_cpu_cmplx_clr; /* _CPU_CMPLX_CLR_0, 0x344 */ };
-#define PLL_BYPASS_BIT (1 << 31) -#define PLL_ENABLE_BIT (1 << 30) -#define PLL_BASE_OVRRIDE_BIT (1 << 28) -#define PLL_DIVP_VALUE (1 << 20) /* post divider, b22:20 */ -#define PLL_DIVM_VALUE 0x0C /* input divider, b4:0 */ - -#define SWR_UARTD_RST (1 << 1) -#define CLK_ENB_UARTD (1 << 1) -#define SWR_UARTA_RST (1 << 6) -#define CLK_ENB_UARTA (1 << 6) - -#define SWR_CPU_RST (1 << 0) -#define CLK_ENB_CPU (1 << 0) -#define SWR_CSITE_RST (1 << 9) -#define CLK_ENB_CSITE (1 << 9) - -#define SET_CPURESET0 (1 << 0) -#define SET_DERESET0 (1 << 4) -#define SET_DBGRESET0 (1 << 12) - -#define SET_CPURESET1 (1 << 1) -#define SET_DERESET1 (1 << 5) -#define SET_DBGRESET1 (1 << 13) - -#define CLR_CPURESET0 (1 << 0) -#define CLR_DERESET0 (1 << 4) -#define CLR_DBGRESET0 (1 << 12) - -#define CLR_CPURESET1 (1 << 1) -#define CLR_DERESET1 (1 << 5) -#define CLR_DBGRESET1 (1 << 13) - -#define CPU0_CLK_STP (1 << 8) -#define CPU1_CLK_STP (1 << 9) - -#define CPCON (1 << 8) +/* CLK_RST_CONTROLLER_CLK_CPU_CMPLX_0 */ +#define CPU1_CLK_STP_RANGE 9 : 9 +#define CPU0_CLK_STP_RANGE 8 : 8
/* CLK_RST_CONTROLLER_PLLx_BASE_0 */ #define PLL_BYPASS_RANGE 31 : 31 diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index f07328e..ac2e3f8 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -24,6 +24,7 @@ #include <common.h> #include <ns16550.h> #include <asm/io.h> +#include <asm/arch/bitfield.h> #include <asm/arch/tegra2.h> #include <asm/arch/sys_proto.h>
@@ -78,20 +79,20 @@ static void clock_init_uart(void) u32 reg;
reg = readl(&pll->pll_base); - if (!(reg & PLL_BASE_OVRRIDE_BIT)) { + if (!(reg & bf_mask(PLL_BASE_OVRRIDE))) { /* Override pllp setup for 216MHz operation. */ - reg = (PLL_BYPASS_BIT | PLL_BASE_OVRRIDE_BIT | PLL_DIVP_VALUE); - reg |= (((NVRM_PLLP_FIXED_FREQ_KHZ/500) << 8) | PLL_DIVM_VALUE); + reg = bf_mask(PLL_BYPASS) | bf_mask(PLL_BASE_OVRRIDE) | + bf_pack(PLL_DIVP, 1) | bf_pack(PLL_DIVM, 0xc); + reg |= bf_pack(PLL_DIVN, NVRM_PLLP_FIXED_FREQ_KHZ / 500); writel(reg, &pll->pll_base);
- reg |= PLL_ENABLE_BIT; + reg |= bf_mask(PLL_ENABLE); writel(reg, &pll->pll_base);
- /* Now do the UART reset/clock enable */ #if defined(CONFIG_TEGRA2_ENABLE_UARTA) /* Assert UART reset and enable clock */ reset_set_enable(PERIPH_ID_UART1, 1); -- 1.7.3.1
This enables networking booting using a USB dongle plugged into the side seaboard port.
Signed-off-by: Simon Glass sjg@chromium.org --- include/configs/seaboard.h | 5 +++ include/configs/tegra2-common.h | 66 +++++++++++++++++++++++++++++++++++++-- 2 files changed, 68 insertions(+), 3 deletions(-)
diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 76ffd95..696fbff 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -53,4 +53,9 @@ /* Put USB1 in host mode */ #define CONFIG_TEGRA2_USB1_HOST
+#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_EXTRA_ENV_SETTINGS_COMMON \ + "board=seaboard\0" \ + + #endif /* __CONFIG_H */ diff --git a/include/configs/tegra2-common.h b/include/configs/tegra2-common.h index ae417ea..0b6c928 100644 --- a/include/configs/tegra2-common.h +++ b/include/configs/tegra2-common.h @@ -113,6 +113,9 @@ #define CONFIG_EFI_PARTITION #define CONFIG_CMD_EXT2
+/* support USB ethernet adapters */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX
/* include default commands */ #include <config_cmd_default.h> @@ -123,7 +126,37 @@ #undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS #undef CONFIG_CMD_NFS /* NFS support */ -#undef CONFIG_CMD_NET /* network support */ + +/* + * Ethernet support + */ +#define CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP + +/* + * BOOTP / TFTP options + */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_TFTP_TSIZE + +#define CONFIG_IPADDR 10.0.0.2 +#define CONFIG_SERVERIP 10.0.0.1 +#define CONFIG_BOOTFILE uImage + +/* + * We decorate the nfsroot name so that multiple users / boards can easily + * share an NFS server: + * user - username, e.g. 'frank' + * board - board, e.g. 'seaboard' + * serial - serial number, e.g. '1234' + */ +#define CONFIG_ROOTPATH "/export/nfsroot-${user}-${board}-${serial#}" +#define CONFIG_TFTPPATH "/tftpboot/uImage-${user}-${board}-${serial#}"
/* turn on command-line edit/hist/auto */ #define CONFIG_CMDLINE_EDITING @@ -133,10 +166,37 @@ #define CONFIG_SYS_NO_FLASH
/* Environment information */ -#define CONFIG_EXTRA_ENV_SETTINGS \ +#define CONFIG_EXTRA_ENV_SETTINGS_COMMON \ "console=ttyS0,115200n8\0" \ - "mem=" TEGRA2_SYSMEM "\0" \ "smpflag=smp\0" \ + "user=user\0" \ + "serial#=1\0" \ + "tftpserverip=172.22.72.144\0" \ + "nfsserverip=172.22.72.144\0" \ + "extra_bootargs=\0" \ + "platform_extras=mem= " TEGRA2_SYSMEM"\0" \ + "regen_all="\ + "setenv common_bootargs console=${console} " \ + "${platform_extras} noinitrd; " \ + "setenv bootargs ${common_bootargs} ${extra_bootargs} " \ + "${bootdev_bootargs}\0" \ + "regen_net_bootargs=setenv bootdev_bootargs " \ + "dev=/dev/nfs4 rw nfsroot=${nfsserverip}:${rootpath} " \ + "ip=dhcp; " \ + "run regen_all\0" \ + "dhcp_setup=setenv tftppath " CONFIG_TFTPPATH "; " \ + "setenv rootpath " CONFIG_ROOTPATH "; " \ + "setenv autoload n; " \ + "run regen_net_bootargs\0" \ + "dhcp_boot=run dhcp_setup; " \ + "bootp; tftpboot ${loadaddr} ${tftpserverip}:${tftppath}; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "usb start; "\ + "if test ${ethact} != ""; then "\ + "run dhcp_boot ; " \ + "fi ; " \
#define CONFIG_LOADADDR 0x408000 /* def. location for kernel */ #define CONFIG_BOOTDELAY 2 /* -1 to disable auto boot */ -- 1.7.3.1
