[U-Boot] [PATCH v2 0/2] Add usb ethernet support for Arndale
Arndale board has AX88760, which is USB 2.0 Hub & USB 2.0 Ethernet Combo controller, connected to HSIC Phy of USB host controller via USB3503 hub.
This patchset adds support for this usb ethernet controllor.
Changes in v2: - removed setting preboot environment in patch 2
Inderpal Singh (2): usb: ehci: exynos: set/reset hsic phys usb: exynos5: arndale: Add network support
arch/arm/include/asm/arch-exynos/ehci.h | 14 +++++++++ board/samsung/arndale/arndale.c | 13 ++++++++ drivers/usb/host/ehci-exynos.c | 49 +++++++++++++++++++++++++++++++ include/configs/arndale.h | 4 +++ 4 files changed, 80 insertions(+)
The controller has 3 ports. The port0 is for USB 2.0 Phy, port1 and port2 are for HSIC phys. The usb 2.0 phy is already being setup. This patch sets up the hsic phys.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org --- arch/arm/include/asm/arch-exynos/ehci.h | 14 +++++++++++ drivers/usb/host/ehci-exynos.c | 39 +++++++++++++++++++++++++++++++ 2 files changed, 53 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/ehci.h b/arch/arm/include/asm/arch-exynos/ehci.h index d79f25c..d2d70bd 100644 --- a/arch/arm/include/asm/arch-exynos/ehci.h +++ b/arch/arm/include/asm/arch-exynos/ehci.h @@ -29,6 +29,20 @@ #define EHCICTRL_ENAINCR8 (1 << 27) #define EHCICTRL_ENAINCR16 (1 << 26)
+#define HSIC_CTRL_REFCLKSEL (0x2) +#define HSIC_CTRL_REFCLKSEL_MASK (0x3) +#define HSIC_CTRL_REFCLKSEL_SHIFT (23) + +#define HSIC_CTRL_REFCLKDIV_12 (0x24) +#define HSIC_CTRL_REFCLKDIV_MASK (0x7f) +#define HSIC_CTRL_REFCLKDIV_SHIFT (16) + +#define HSIC_CTRL_SIDDQ (0x1 << 6) +#define HSIC_CTRL_FORCESLEEP (0x1 << 5) +#define HSIC_CTRL_FORCESUSPEND (0x1 << 4) +#define HSIC_CTRL_UTMISWRST (0x1 << 2) +#define HSIC_CTRL_PHYSWRST (0x1 << 0) + /* Register map for PHY control */ struct exynos_usb_phy { unsigned int usbphyctrl0; diff --git a/drivers/usb/host/ehci-exynos.c b/drivers/usb/host/ehci-exynos.c index 66b4de0..88e6466 100644 --- a/drivers/usb/host/ehci-exynos.c +++ b/drivers/usb/host/ehci-exynos.c @@ -88,6 +88,8 @@ static int exynos_usb_parse_dt(const void *blob, struct exynos_ehci *exynos) /* Setup the EHCI host controller. */ static void setup_usb_phy(struct exynos_usb_phy *usb) { + u32 hsic_ctrl; + set_usbhost_mode(USB20_PHY_CFG_HOST_LINK_EN);
set_usbhost_phy_ctrl(POWER_USB_HOST_PHY_CTRL_EN); @@ -112,6 +114,32 @@ static void setup_usb_phy(struct exynos_usb_phy *usb) clrbits_le32(&usb->usbphyctrl0, HOST_CTRL0_LINKSWRST | HOST_CTRL0_UTMISWRST); + + /* HSIC Phy Setting */ + hsic_ctrl = (HSIC_CTRL_FORCESUSPEND | + HSIC_CTRL_FORCESLEEP | + HSIC_CTRL_SIDDQ); + + clrbits_le32(&usb->hsicphyctrl1, hsic_ctrl); + clrbits_le32(&usb->hsicphyctrl2, hsic_ctrl); + + hsic_ctrl = (((HSIC_CTRL_REFCLKDIV_12 & HSIC_CTRL_REFCLKDIV_MASK) + << HSIC_CTRL_REFCLKDIV_SHIFT) + | ((HSIC_CTRL_REFCLKSEL & HSIC_CTRL_REFCLKSEL_MASK) + << HSIC_CTRL_REFCLKSEL_SHIFT) + | HSIC_CTRL_UTMISWRST); + + setbits_le32(&usb->hsicphyctrl1, hsic_ctrl); + setbits_le32(&usb->hsicphyctrl2, hsic_ctrl); + + udelay(10); + + clrbits_le32(&usb->hsicphyctrl1, HSIC_CTRL_PHYSWRST | + HSIC_CTRL_UTMISWRST); + + clrbits_le32(&usb->hsicphyctrl2, HSIC_CTRL_PHYSWRST | + HSIC_CTRL_UTMISWRST); + udelay(20);
/* EHCI Ctrl setting */ @@ -125,6 +153,8 @@ static void setup_usb_phy(struct exynos_usb_phy *usb) /* Reset the EHCI host controller. */ static void reset_usb_phy(struct exynos_usb_phy *usb) { + u32 hsic_ctrl; + /* HOST_PHY reset */ setbits_le32(&usb->usbphyctrl0, HOST_CTRL0_PHYSWRST | @@ -133,6 +163,15 @@ static void reset_usb_phy(struct exynos_usb_phy *usb) HOST_CTRL0_FORCESUSPEND | HOST_CTRL0_FORCESLEEP);
+ /* HSIC Phy reset */ + hsic_ctrl = (HSIC_CTRL_FORCESUSPEND | + HSIC_CTRL_FORCESLEEP | + HSIC_CTRL_SIDDQ | + HSIC_CTRL_PHYSWRST); + + setbits_le32(&usb->hsicphyctrl1, hsic_ctrl); + setbits_le32(&usb->hsicphyctrl2, hsic_ctrl); + set_usbhost_phy_ctrl(POWER_USB_HOST_PHY_CTRL_DISABLE); }
Is it OK to set all the ports up unconditionally ? I am not sure about exynos of course, but is it possible there are some machines which don't use the HSIC ports and this would have some kind of adverse effects on those?
Best regards, Marek Vasut
Hi Marek,
Thanks for the review.
I feel it should not cause any side effect as it wont interfere with the normal USB 2.0 phy port. Also, its being done along the same lines as kernel driver at drivers/usb/phy/phy-samsung-usb2.c, which also sets up all ports unconditionally.
Regards, Inder
On Friday, January 03, 2014 at 06:03:47 AM, Inderpal Singh wrote:
Hi Marek,
OK, I won't fight this. I would be much more inclined to being able to conditionally select which ports get configured. Especially, since you do know that information from DT, dont you?
Hi Marek,
all
Ok, Thanks Marek. As of now DT is not providing port information.
Regards, Inder
Hi Marek,
all
Bah, I'd expect -- especially in case of exynos, which is targetting the mobile segment -- to focus on power consumption very much. Anyway, like I said, I won't fight this. Minkyu, what's your take on this one please?
Hi Marek,
all
I agree with Marek.
Thanks, Minkyu Kang.
This patch implements a board specific board_usb_init function in ehci driver to perform reset sequence for USB3503 hub and enables the relevant config options for network to work.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/arndale/arndale.c | 13 +++++++++++++ drivers/usb/host/ehci-exynos.c | 10 ++++++++++ include/configs/arndale.h | 4 ++++ 3 files changed, 27 insertions(+)
diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 052fecd..deca348 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -7,10 +7,23 @@ #include <common.h> #include <asm/arch/pinmux.h> #include <asm/arch/dwmmc.h> +#include <asm/arch/gpio.h> #include <asm/arch/power.h>
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_USB_EHCI_EXYNOS +void exynos_board_usb_init(int value) +{ + struct exynos5_gpio_part1 *gpio = (struct exynos5_gpio_part1 *) + samsung_get_base_gpio_part1(); + + /* Configure gpios for usb 3503 hub's reset and connect */ + s5p_gpio_direction_output(&gpio->x3, 5, value); + s5p_gpio_direction_output(&gpio->d1, 7, value); +} +#endif + int board_init(void) { gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); diff --git a/drivers/usb/host/ehci-exynos.c b/drivers/usb/host/ehci-exynos.c index 88e6466..4be6a60 100644 --- a/drivers/usb/host/ehci-exynos.c +++ b/drivers/usb/host/ehci-exynos.c @@ -175,6 +175,12 @@ static void reset_usb_phy(struct exynos_usb_phy *usb) set_usbhost_phy_ctrl(POWER_USB_HOST_PHY_CTRL_DISABLE); }
+inline void __exynos_board_usb_init(int value) +{ +} +void exynos_board_usb_init(int) + __attribute__((weak, alias("__exynos_board_usb_init"))); + /* * EHCI-initialization * Create the appropriate control structures to manage @@ -201,8 +207,12 @@ int ehci_hcd_init(int index, enum usb_init_type init, gpio_direction_output(ctx->vbus_gpio.gpio, 1); #endif
+ exynos_board_usb_init(0); + setup_usb_phy(ctx->usb);
+ exynos_board_usb_init(1); + *hccr = ctx->hcd; *hcor = (struct ehci_hcor *)((uint32_t) *hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); diff --git a/include/configs/arndale.h b/include/configs/arndale.h index b7fb29e..eda0e4f 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -116,6 +116,10 @@ #define CONFIG_USB_EHCI_EXYNOS #define CONFIG_USB_STORAGE
+#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX + /* MMC SPL */ #define CONFIG_EXYNOS_SPL #define CONFIG_SPL
- struct exynos5_gpio_part1 *gpio = (struct exynos5_gpio_part1 *)
- /* Configure gpios for usb 3503 hub's reset and connect */
- s5p_gpio_direction_output(&gpio->x3, 5, value);
- s5p_gpio_direction_output(&gpio->d1, 7, value);
+} +#endif
Sorry, this is not happening. Why can you not use the existing board_usb_init() and instead have to invent new stuff ?
Hi Marek,
Thanks for review.
+} +#endif
*usb)
I did not use board_usb_init because it has 2 parameters which may not be used as described in usb.h for my use case, which is to only configure gpios for reset and connect of usb 3503 hub.
Let me know if you still feel that board_usb_init should be used. In that case I will have to utilize index parameter in my own way.
Regards, Inder
On Friday, January 03, 2014 at 06:14:38 AM, Inderpal Singh wrote:
Hi Marek,
Thanks for review.
+} +#endif
*usb)
Shall I read that as "I will abuse API" ? You know that this will not happen ;-)
Why can you not reset the USB HUB in regular board_usb_init() simply by toggling the switch's reset gpio as done on the rest of the boards ?
Hi Marek,
Thanks for review.
ehci
+} +#endif
*usb)
Yes, thats an abuse and have not done that yet :-)
Ok, let me try this. If it works I will send the updated patch.
Regards, Inder
Hi Marek,
Thanks for review.
ehci
+} +#endif
*usb)
Thank you!
Inderpal Singh
Minkyu Kang
