[PATCH v4 0/7] Microchip PolarFire SoC support
This patch set adds Microchip PolarFire SoC Icicle Kit support to RISC-V U-Boot.
The patches are based upon latest U-Boot tree (https://gitlab.denx.de/u-boot/u-boot.git) at commit id 7889951d0f56eab746a7c8fde350a022ba0361ca
All drivers namely: NS16550 Serial, Microchip clock, Cadence eMMC and Cadence MACB Ethernet work fine on actual Microchip PolarFire SoC Icicle Kit.
Changes in v4: - Add dual-license GPL or MIT in the device tree - Replace microsemi compatible strings with microchip - Add MACB compatible string for Microchip PolarFire SoC ethernet - Update MACB driver for 32-bit/64-bit DMA based on compatible string
Changes in v3: - Add 'default y if 64BIT' for config DMA_ADDR_T_64BIT - Update MACB driver for 32-bit/64-bit DMA based on design config register - Add phy-handle in MACB driver to read the phy address from device tree - Fix checkpatch warnings in the clock driver - Remove fu540 related compatible strings from soc device tree node - Move refclk device tree node under /soc device tree node - Use local-mac-address instead of mac-address in the device tree - Rename device tree to microchip-mpfs-icicle-kit.dts - Add U-Boot specific dts microchip-mpfs-icicle-kit-u-boot.dtsi file - Drop the imply DMA_ADDR_T_64BIT from board config - Fix some typos - Update doc with Microchip and Custom boot-flow
Changes in v2: - Add clock frequency for the clint device tree node - Move peripheral device tree nodes under /soc device tree node - Device tree nodes are in order based on the address - Enable UART0 for U-Boot logs - Update doc for the U-Boot logs are on UART0 - Move clock and reset index source into patch4 - Remove "dma_addr_r" type in the macb driver - Add lower_32_bits() for 32-bit address in the macb driver - Add set_rate() returns the new clock rate in the clock driver
Padmarao Begari (7): riscv: Add DMA 64-bit address support net: macb: Add DMA 64-bit address support for macb net: macb: Add phy address to read it from device tree clk: Add Microchip PolarFire SoC clock driver riscv: dts: Add device tree for Microchip Icicle Kit riscv: Add Microchip MPFS Icicle Kit support doc: board: Add Microchip MPFS Icicle Kit doc
arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 1 + .../dts/microchip-mpfs-icicle-kit-u-boot.dtsi | 14 + arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 421 +++++++++ arch/riscv/include/asm/types.h | 4 + board/microchip/mpfs_icicle/Kconfig | 24 + board/microchip/mpfs_icicle/mpfs_icicle.c | 97 +- configs/microchip_mpfs_icicle_defconfig | 9 +- doc/board/index.rst | 1 + doc/board/microchip/index.rst | 9 + doc/board/microchip/mpfs_icicle.rst | 827 ++++++++++++++++++ drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/microchip/Kconfig | 5 + drivers/clk/microchip/Makefile | 1 + drivers/clk/microchip/clk_pfsoc.c | 127 +++ drivers/clk/microchip/clk_pfsoc.h | 19 + drivers/clk/microchip/clk_pfsoc_cfg.c | 134 +++ drivers/clk/microchip/clk_pfsoc_periph.c | 173 ++++ drivers/net/macb.c | 144 ++- drivers/net/macb.h | 6 + include/configs/microchip_mpfs_icicle.h | 60 +- .../dt-bindings/clock/microchip,pfsoc-clock.h | 45 + 23 files changed, 2065 insertions(+), 62 deletions(-) create mode 100644 arch/riscv/dts/microchip-mpfs-icicle-kit-u-boot.dtsi create mode 100644 arch/riscv/dts/microchip-mpfs-icicle-kit.dts create mode 100644 doc/board/microchip/index.rst create mode 100644 doc/board/microchip/mpfs_icicle.rst create mode 100644 drivers/clk/microchip/Kconfig create mode 100644 drivers/clk/microchip/Makefile create mode 100644 drivers/clk/microchip/clk_pfsoc.c create mode 100644 drivers/clk/microchip/clk_pfsoc.h create mode 100644 drivers/clk/microchip/clk_pfsoc_cfg.c create mode 100644 drivers/clk/microchip/clk_pfsoc_periph.c create mode 100644 include/dt-bindings/clock/microchip,pfsoc-clock.h
dma_addr_t holds any valid DMA address. If the DMA API only uses 32/64-bit addresses, dma_addr_t need only be 32/64 bits wide.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- arch/riscv/Kconfig | 4 ++++ arch/riscv/include/asm/types.h | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 30b05408b1..55eaee2da6 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -152,6 +152,10 @@ config 32BIT config 64BIT bool
+config DMA_ADDR_T_64BIT + bool + default y if 64BIT + config SIFIVE_CLINT bool depends on RISCV_MMODE || SPL_RISCV_MMODE diff --git a/arch/riscv/include/asm/types.h b/arch/riscv/include/asm/types.h index 403cf9a48f..b800b2d221 100644 --- a/arch/riscv/include/asm/types.h +++ b/arch/riscv/include/asm/types.h @@ -29,7 +29,11 @@ typedef unsigned short umode_t;
#include <stddef.h>
+#ifdef CONFIG_DMA_ADDR_T_64BIT +typedef u64 dma_addr_t; +#else typedef u32 dma_addr_t; +#endif
typedef unsigned long phys_addr_t; typedef unsigned long phys_size_t;
Enable 32-bit or 64-bit DMA in the macb driver based on the macb compatible string of the device tree node.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- drivers/net/macb.c | 131 +++++++++++++++++++++++++++++++++++++++------ drivers/net/macb.h | 6 +++ 2 files changed, 120 insertions(+), 17 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index b80a259ff7..e7c93d4747 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -83,7 +83,16 @@ struct macb_dma_desc { u32 ctrl; };
-#define DMA_DESC_BYTES(n) (n * sizeof(struct macb_dma_desc)) +struct macb_dma_desc_64 { + u32 addrh; + u32 unused; +}; + +#define HW_DMA_CAP_32B 0 +#define HW_DMA_CAP_64B 1 + +#define DMA_DESC_SIZE 16 +#define DMA_DESC_BYTES(n) ((n) * DMA_DESC_SIZE) #define MACB_TX_DMA_DESC_SIZE (DMA_DESC_BYTES(MACB_TX_RING_SIZE)) #define MACB_RX_DMA_DESC_SIZE (DMA_DESC_BYTES(MACB_RX_RING_SIZE)) #define MACB_TX_DUMMY_DMA_DESC_SIZE (DMA_DESC_BYTES(1)) @@ -133,6 +142,7 @@ struct macb_device { #endif phy_interface_t phy_interface; #endif + unsigned short hw_dma_cap; };
struct macb_config { @@ -307,6 +317,24 @@ static inline void macb_invalidate_rx_buffer(struct macb_device *macb)
#if defined(CONFIG_CMD_NET)
+static struct macb_dma_desc_64 *macb_64b_desc(struct macb_dma_desc *desc) +{ + return (struct macb_dma_desc_64 *)((void *)desc + + sizeof(struct macb_dma_desc)); +} + +static void macb_set_addr(struct macb_device *macb, struct macb_dma_desc *desc, + ulong addr) +{ + struct macb_dma_desc_64 *desc_64; + + if (macb->hw_dma_cap & HW_DMA_CAP_64B) { + desc_64 = macb_64b_desc(desc); + desc_64->addrh = upper_32_bits(addr); + } + desc->addr = lower_32_bits(addr); +} + static int _macb_send(struct macb_device *macb, const char *name, void *packet, int length) { @@ -325,8 +353,12 @@ static int _macb_send(struct macb_device *macb, const char *name, void *packet, macb->tx_head++; }
+ if (macb->hw_dma_cap & HW_DMA_CAP_64B) + tx_head = tx_head * 2; + macb->tx_ring[tx_head].ctrl = ctrl; - macb->tx_ring[tx_head].addr = paddr; + macb_set_addr(macb, &macb->tx_ring[tx_head], paddr); + barrier(); macb_flush_ring_desc(macb, TX); macb_writel(macb, NCR, MACB_BIT(TE) | MACB_BIT(RE) | MACB_BIT(TSTART)); @@ -363,19 +395,28 @@ static void reclaim_rx_buffers(struct macb_device *macb, unsigned int new_tail) { unsigned int i; + unsigned int count;
i = macb->rx_tail;
macb_invalidate_ring_desc(macb, RX); while (i > new_tail) { - macb->rx_ring[i].addr &= ~MACB_BIT(RX_USED); + if (macb->hw_dma_cap & HW_DMA_CAP_64B) + count = i * 2; + else + count = i; + macb->rx_ring[count].addr &= ~MACB_BIT(RX_USED); i++; if (i > MACB_RX_RING_SIZE) i = 0; }
while (i < new_tail) { - macb->rx_ring[i].addr &= ~MACB_BIT(RX_USED); + if (macb->hw_dma_cap & HW_DMA_CAP_64B) + count = i * 2; + else + count = i; + macb->rx_ring[count].addr &= ~MACB_BIT(RX_USED); i++; }
@@ -390,16 +431,25 @@ static int _macb_recv(struct macb_device *macb, uchar **packetp) void *buffer; int length; u32 status; + u8 flag = false;
macb->wrapped = false; for (;;) { macb_invalidate_ring_desc(macb, RX);
+ if (macb->hw_dma_cap & HW_DMA_CAP_64B) + next_rx_tail = next_rx_tail * 2; + if (!(macb->rx_ring[next_rx_tail].addr & MACB_BIT(RX_USED))) return -EAGAIN;
status = macb->rx_ring[next_rx_tail].ctrl; if (status & MACB_BIT(RX_SOF)) { + if (macb->hw_dma_cap & HW_DMA_CAP_64B) { + next_rx_tail = next_rx_tail / 2; + flag = true; + } + if (next_rx_tail != macb->rx_tail) reclaim_rx_buffers(macb, next_rx_tail); macb->wrapped = false; @@ -426,11 +476,22 @@ static int _macb_recv(struct macb_device *macb, uchar **packetp) *packetp = buffer; }
+ if (macb->hw_dma_cap & HW_DMA_CAP_64B) { + if (!flag) + next_rx_tail = next_rx_tail / 2; + } + if (++next_rx_tail >= MACB_RX_RING_SIZE) next_rx_tail = 0; macb->next_rx_tail = next_rx_tail; return length; } else { + if (macb->hw_dma_cap & HW_DMA_CAP_64B) { + if (!flag) + next_rx_tail = next_rx_tail / 2; + flag = false; + } + if (++next_rx_tail >= MACB_RX_RING_SIZE) { macb->wrapped = true; next_rx_tail = 0; @@ -718,6 +779,7 @@ static int gmac_init_multi_queues(struct macb_device *macb) { int i, num_queues = 1; u32 queue_mask; + unsigned long paddr;
/* bit 0 is never set but queue 0 always exists */ queue_mask = gem_readl(macb, DCFG6) & 0xff; @@ -731,10 +793,18 @@ static int gmac_init_multi_queues(struct macb_device *macb) macb->dummy_desc->addr = 0; flush_dcache_range(macb->dummy_desc_dma, macb->dummy_desc_dma + ALIGN(MACB_TX_DUMMY_DMA_DESC_SIZE, PKTALIGN)); - - for (i = 1; i < num_queues; i++) - gem_writel_queue_TBQP(macb, macb->dummy_desc_dma, i - 1); - + paddr = macb->dummy_desc_dma; + + for (i = 1; i < num_queues; i++) { + gem_writel_queue_TBQP(macb, lower_32_bits(paddr), i - 1); + gem_writel_queue_RBQP(macb, lower_32_bits(paddr), i - 1); + if (macb->hw_dma_cap & HW_DMA_CAP_64B) { + gem_writel_queue_TBQPH(macb, upper_32_bits(paddr), + i - 1); + gem_writel_queue_RBQPH(macb, upper_32_bits(paddr), + i - 1); + } + } return 0; }
@@ -760,6 +830,9 @@ static void gmac_configure_dma(struct macb_device *macb) dmacfg &= ~GEM_BIT(ENDIA_DESC);
dmacfg &= ~GEM_BIT(ADDR64); + if (macb->hw_dma_cap & HW_DMA_CAP_64B) + dmacfg |= GEM_BIT(ADDR64); + gem_writel(macb, DMACFG, dmacfg); }
@@ -775,6 +848,7 @@ static int _macb_init(struct macb_device *macb, const char *name) unsigned long paddr; int ret; int i; + int count;
/* * macb_halt should have been called at some point before now, @@ -786,20 +860,28 @@ static int _macb_init(struct macb_device *macb, const char *name) for (i = 0; i < MACB_RX_RING_SIZE; i++) { if (i == (MACB_RX_RING_SIZE - 1)) paddr |= MACB_BIT(RX_WRAP); - macb->rx_ring[i].addr = paddr; - macb->rx_ring[i].ctrl = 0; + if (macb->hw_dma_cap & HW_DMA_CAP_64B) + count = i * 2; + else + count = i; + macb->rx_ring[count].ctrl = 0; + macb_set_addr(macb, &macb->rx_ring[count], paddr); paddr += macb->rx_buffer_size; } macb_flush_ring_desc(macb, RX); macb_flush_rx_buffer(macb);
for (i = 0; i < MACB_TX_RING_SIZE; i++) { - macb->tx_ring[i].addr = 0; + if (macb->hw_dma_cap & HW_DMA_CAP_64B) + count = i * 2; + else + count = i; + macb_set_addr(macb, &macb->tx_ring[count], 0); if (i == (MACB_TX_RING_SIZE - 1)) - macb->tx_ring[i].ctrl = MACB_BIT(TX_USED) | + macb->tx_ring[count].ctrl = MACB_BIT(TX_USED) | MACB_BIT(TX_WRAP); else - macb->tx_ring[i].ctrl = MACB_BIT(TX_USED); + macb->tx_ring[count].ctrl = MACB_BIT(TX_USED); } macb_flush_ring_desc(macb, TX);
@@ -812,8 +894,12 @@ static int _macb_init(struct macb_device *macb, const char *name) gem_writel(macb, DMACFG, MACB_ZYNQ_GEM_DMACR_INIT); #endif
- macb_writel(macb, RBQP, macb->rx_ring_dma); - macb_writel(macb, TBQP, macb->tx_ring_dma); + macb_writel(macb, RBQP, lower_32_bits(macb->rx_ring_dma)); + macb_writel(macb, TBQP, lower_32_bits(macb->tx_ring_dma)); + if (macb->hw_dma_cap & HW_DMA_CAP_64B) { + macb_writel(macb, RBQPH, upper_32_bits(macb->rx_ring_dma)); + macb_writel(macb, TBQPH, upper_32_bits(macb->tx_ring_dma)); + }
if (macb_is_gem(macb)) { /* Initialize DMA properties */ @@ -1225,10 +1311,11 @@ static int macb_eth_probe(struct udevice *dev) struct eth_pdata *pdata = dev_get_platdata(dev); struct macb_device *macb = dev_get_priv(dev); const char *phy_mode; + const char *compatible; int ret;
- phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); + phy_mode = dev_read_prop(dev, "phy-mode", NULL); + if (phy_mode) macb->phy_interface = phy_get_interface_by_name(phy_mode); if (macb->phy_interface == -1) { @@ -1236,6 +1323,15 @@ static int macb_eth_probe(struct udevice *dev) return -EINVAL; }
+ compatible = dev_read_prop(dev, "compatible", NULL); + + if (compatible) { + if (!strcmp(compatible, "microchip,mpfs-mss-gem")) + macb->hw_dma_cap = HW_DMA_CAP_64B; + else + macb->hw_dma_cap = HW_DMA_CAP_32B; + } + macb->regs = (void *)pdata->iobase;
macb->is_big_endian = (cpu_to_be32(0x12345678) == 0x12345678); @@ -1324,6 +1420,7 @@ static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,zynq-gem" }, { .compatible = "sifive,fu540-c000-gem", .data = (ulong)&sifive_config }, + { .compatible = "microchip,mpfs-mss-gem" }, { } };
diff --git a/drivers/net/macb.h b/drivers/net/macb.h index 9b16383eba..72b84ae96e 100644 --- a/drivers/net/macb.h +++ b/drivers/net/macb.h @@ -768,5 +768,11 @@ #define GEM_RX_CSUM_CHECKED_MASK 2 #define gem_writel_queue_TBQP(port, value, queue_num) \ writel((value), (port)->regs + GEM_TBQP(queue_num)) +#define gem_writel_queue_TBQPH(port, value, queue_num) \ + writel((value), (port)->regs + GEM_TBQPH(queue_num)) +#define gem_writel_queue_RBQP(port, value, queue_num) \ + writel((value), (port)->regs + GEM_RBQP(queue_num)) +#define gem_writel_queue_RBQPH(port, value, queue_num) \ + writel((value), (port)->regs + GEM_RBQPH(queue_num))
#endif /* __DRIVERS_MACB_H__ */
Read phy address from device tree and use it to find the phy device if not found then search in the range of 0 to 31.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- drivers/net/macb.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index e7c93d4747..16d1597b10 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -531,6 +531,12 @@ static int macb_phy_find(struct macb_device *macb, const char *name) int i; u16 phy_id;
+ phy_id = macb_mdio_read(macb, macb->phy_addr, MII_PHYSID1); + if (phy_id != 0xffff) { + printf("%s: PHY present at %d\n", name, macb->phy_addr); + return 0; + } + /* Search for PHY... */ for (i = 0; i < 32; i++) { macb->phy_addr = i; @@ -1310,6 +1316,7 @@ static int macb_eth_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct macb_device *macb = dev_get_priv(dev); + struct ofnode_phandle_args phandle_args; const char *phy_mode; const char *compatible; int ret; @@ -1323,6 +1330,12 @@ static int macb_eth_probe(struct udevice *dev) return -EINVAL; }
+ /* Read phyaddr from DT */ + if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, + &phandle_args)) + macb->phy_addr = ofnode_read_u32_default(phandle_args.node, + "reg", -1); + compatible = dev_read_prop(dev, "compatible", NULL);
if (compatible) {
Add clock driver code for the Microchip PolarFire SoC. This driver handles reset and clock control of the Microchip PolarFire SoC device.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/microchip/Kconfig | 5 + drivers/clk/microchip/Makefile | 1 + drivers/clk/microchip/clk_pfsoc.c | 127 +++++++++++++ drivers/clk/microchip/clk_pfsoc.h | 19 ++ drivers/clk/microchip/clk_pfsoc_cfg.c | 134 ++++++++++++++ drivers/clk/microchip/clk_pfsoc_periph.c | 173 ++++++++++++++++++ .../dt-bindings/clock/microchip,pfsoc-clock.h | 45 +++++ 9 files changed, 506 insertions(+) create mode 100644 drivers/clk/microchip/Kconfig create mode 100644 drivers/clk/microchip/Makefile create mode 100644 drivers/clk/microchip/clk_pfsoc.c create mode 100644 drivers/clk/microchip/clk_pfsoc.h create mode 100644 drivers/clk/microchip/clk_pfsoc_cfg.c create mode 100644 drivers/clk/microchip/clk_pfsoc_periph.c create mode 100644 include/dt-bindings/clock/microchip,pfsoc-clock.h
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 4dfbad7986..1161fe7b5a 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -173,6 +173,7 @@ source "drivers/clk/exynos/Kconfig" source "drivers/clk/imx/Kconfig" source "drivers/clk/kendryte/Kconfig" source "drivers/clk/meson/Kconfig" +source "drivers/clk/microchip/Kconfig" source "drivers/clk/mvebu/Kconfig" source "drivers/clk/owl/Kconfig" source "drivers/clk/renesas/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index d1e295ac7c..bd8a6eed88 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -28,6 +28,7 @@ obj-$(CONFIG_CLK_EXYNOS) += exynos/ obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ obj-$(CONFIG_CLK_HSDK) += clk-hsdk-cgu.o obj-$(CONFIG_CLK_K210) += kendryte/ +obj-$(CONFIG_CLK_MPFS) += microchip/ obj-$(CONFIG_CLK_MPC83XX) += mpc83xx_clk.o obj-$(CONFIG_CLK_OCTEON) += clk_octeon.o obj-$(CONFIG_CLK_OWL) += owl/ diff --git a/drivers/clk/microchip/Kconfig b/drivers/clk/microchip/Kconfig new file mode 100644 index 0000000000..b70241559d --- /dev/null +++ b/drivers/clk/microchip/Kconfig @@ -0,0 +1,5 @@ +config CLK_MPFS + bool "Clock support for Microchip PolarFire SoC" + depends on CLK && CLK_CCF + help + This enables support clock driver for Microchip PolarFire SoC platform. diff --git a/drivers/clk/microchip/Makefile b/drivers/clk/microchip/Makefile new file mode 100644 index 0000000000..c7f5ad21ae --- /dev/null +++ b/drivers/clk/microchip/Makefile @@ -0,0 +1 @@ +obj-y += clk_pfsoc.o clk_pfsoc_cfg.o clk_pfsoc_periph.o diff --git a/drivers/clk/microchip/clk_pfsoc.c b/drivers/clk/microchip/clk_pfsoc.c new file mode 100644 index 0000000000..dd0e9cacb8 --- /dev/null +++ b/drivers/clk/microchip/clk_pfsoc.c @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <dm/uclass.h> +#include <malloc.h> +#include <linux/err.h> + +#include "clk_pfsoc.h" + +/* All methods are delegated to CCF clocks */ + +static ulong pfsoc_clk_get_rate(struct clk *clk) +{ + struct clk *c; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + return clk_get_rate(c); +} + +static ulong pfsoc_clk_set_rate(struct clk *clk, unsigned long rate) +{ + struct clk *c; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + return clk_set_rate(c, rate); +} + +static int pfsoc_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct clk *c, *p; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + + err = clk_get_by_id(parent->id, &p); + if (err) + return err; + + return clk_set_parent(c, p); +} + +static int pfsoc_clk_endisable(struct clk *clk, bool enable) +{ + struct clk *c; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + return enable ? clk_enable(c) : clk_disable(c); +} + +static int pfsoc_clk_enable(struct clk *clk) +{ + return pfsoc_clk_endisable(clk, true); +} + +static int pfsoc_clk_disable(struct clk *clk) +{ + return pfsoc_clk_endisable(clk, false); +} + +static int pfsoc_clk_probe(struct udevice *dev) +{ + int ret; + void __iomem *base; + u32 clk_rate; + struct clk *clk; + const char *parent_clk_name; + + base = dev_read_addr_ptr(dev); + if (!base) + return -ENODEV; + + clk = kzalloc(sizeof(*clk), GFP_KERNEL); + if (!clk) + return -ENOMEM; + + ret = clk_get_by_index(dev, 0, clk); + if (ret) + return ret; + + dev_read_u32(clk->dev, "clock-frequency", &clk_rate); + parent_clk_name = clk->dev->name; + + ret = pfsoc_clk_register_cfgs(base, clk_rate, parent_clk_name); + if (ret) + return ret; + + ret = pfsoc_clk_register_periphs(base, clk_rate, "clk_ahb"); + + return ret; +} + +static const struct clk_ops pfsoc_clk_ops = { + .set_rate = pfsoc_clk_set_rate, + .get_rate = pfsoc_clk_get_rate, + .set_parent = pfsoc_clk_set_parent, + .enable = pfsoc_clk_enable, + .disable = pfsoc_clk_disable, +}; + +static const struct udevice_id pfsoc_of_match[] = { + { .compatible = "microchip,pfsoc-clkcfg" }, + { } +}; + +U_BOOT_DRIVER(pfsoc_clk) = { + .name = "pfsoc_clk", + .id = UCLASS_CLK, + .of_match = pfsoc_of_match, + .ops = &pfsoc_clk_ops, + .probe = pfsoc_clk_probe, +}; diff --git a/drivers/clk/microchip/clk_pfsoc.h b/drivers/clk/microchip/clk_pfsoc.h new file mode 100644 index 0000000000..6255e0de2d --- /dev/null +++ b/drivers/clk/microchip/clk_pfsoc.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ +#ifndef __MICROCHIP_PFSOC_CLK_H +#define __MICROCHIP_PFSOC_CLK_H + +#include <linux/clk-provider.h> + +int pfsoc_clk_register_cfgs(void __iomem *base, u32 clk_rate, + const char *parent_name); +int pfsoc_clk_register_periphs(void __iomem *base, u32 clk_rate, + const char *parent_name); +int divider_get_val(unsigned long rate, unsigned long parent_rate, + const struct clk_div_table *table, + u8 width, unsigned long flags); + +#endif /* __MICROCHIP_PFSOC_CLK_H */ diff --git a/drivers/clk/microchip/clk_pfsoc_cfg.c b/drivers/clk/microchip/clk_pfsoc_cfg.c new file mode 100644 index 0000000000..ea74311452 --- /dev/null +++ b/drivers/clk/microchip/clk_pfsoc_cfg.c @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <dm/uclass.h> +#include <asm/io.h> +#include <linux/err.h> +#include <dt-bindings/clock/microchip,pfsoc-clock.h> + +#include "clk_pfsoc.h" + +#define PFSOC_CFG_CLOCK "pfsoc_cfg_clock" + +#define REG_CLOCK_CONFIG_CR 0x08 + +static const struct clk_div_table pfsoc_div_cpu_axi_table[] = { + { 0, 1 }, { 1, 2 }, { 2, 4 }, { 3, 8 }, + { 0, 0 } +}; + +static const struct clk_div_table pfsoc_div_ahb_table[] = { + { 1, 2 }, { 2, 4}, { 3, 8 }, + { 0, 0 } +}; + +struct pfsoc_cfg_clock { + unsigned int id; + const char *name; + u8 shift; + u8 width; + const struct clk_div_table *table; + unsigned long flags; +}; + +struct pfsoc_cfg_hw_clock { + struct pfsoc_cfg_clock cfg; + void __iomem *sys_base; + u32 prate; + struct clk hw; +}; + +#define to_pfsoc_cfg_clk(_hw) container_of(_hw, struct pfsoc_cfg_hw_clock, hw) + +static ulong pfsoc_cfg_clk_recalc_rate(struct clk *hw) +{ + struct pfsoc_cfg_hw_clock *cfg_hw = to_pfsoc_cfg_clk(hw); + struct pfsoc_cfg_clock *cfg = &cfg_hw->cfg; + void __iomem *base_addr = cfg_hw->sys_base; + unsigned long rate; + u32 val; + + val = readl(base_addr + REG_CLOCK_CONFIG_CR) >> cfg->shift; + val &= clk_div_mask(cfg->width); + rate = cfg_hw->prate / (1u << val); + hw->rate = rate; + + return rate; +} + +static ulong pfsoc_cfg_clk_set_rate(struct clk *hw, ulong rate) +{ + struct pfsoc_cfg_hw_clock *cfg_hw = to_pfsoc_cfg_clk(hw); + struct pfsoc_cfg_clock *cfg = &cfg_hw->cfg; + void __iomem *base_addr = cfg_hw->sys_base; + u32 val; + int divider_setting; + + divider_setting = divider_get_val(rate, cfg_hw->prate, cfg->table, cfg->width, cfg->flags); + + if (divider_setting < 0) + return divider_setting; + + val = readl(base_addr + REG_CLOCK_CONFIG_CR); + val &= ~(clk_div_mask(cfg->width) << cfg_hw->cfg.shift); + val |= divider_setting << cfg->shift; + writel(val, base_addr + REG_CLOCK_CONFIG_CR); + + return clk_get_rate(hw); +} + +#define CLK_CFG(_id, _name, _shift, _width, _table, _flags) { \ + .cfg.id = _id, \ + .cfg.name = _name, \ + .cfg.shift = _shift, \ + .cfg.width = _width, \ + .cfg.table = _table, \ + .cfg.flags = _flags, \ + } + +static struct pfsoc_cfg_hw_clock pfsoc_cfg_clks[] = { + CLK_CFG(CLK_CPU, "clk_cpu", 0, 2, pfsoc_div_cpu_axi_table, 0), + CLK_CFG(CLK_AXI, "clk_axi", 2, 2, pfsoc_div_cpu_axi_table, 0), + CLK_CFG(CLK_AHB, "clk_ahb", 4, 2, pfsoc_div_ahb_table, 0), +}; + +int pfsoc_clk_register_cfgs(void __iomem *base, u32 clk_rate, + const char *parent_name) +{ + int ret; + int i, id, num_clks; + const char *name; + struct clk *hw; + + num_clks = ARRAY_SIZE(pfsoc_cfg_clks); + for (i = 0; i < num_clks; i++) { + hw = &pfsoc_cfg_clks[i].hw; + pfsoc_cfg_clks[i].sys_base = base; + pfsoc_cfg_clks[i].prate = clk_rate; + name = pfsoc_cfg_clks[i].cfg.name; + ret = clk_register(hw, PFSOC_CFG_CLOCK, name, parent_name); + if (ret) + ERR_PTR(ret); + id = pfsoc_cfg_clks[i].cfg.id; + clk_dm(id, hw); + } + return 0; +} + +const struct clk_ops pfsoc_cfg_clk_ops = { + .set_rate = pfsoc_cfg_clk_set_rate, + .get_rate = pfsoc_cfg_clk_recalc_rate, +}; + +U_BOOT_DRIVER(pfsoc_cfg_clock) = { + .name = PFSOC_CFG_CLOCK, + .id = UCLASS_CLK, + .ops = &pfsoc_cfg_clk_ops, +}; diff --git a/drivers/clk/microchip/clk_pfsoc_periph.c b/drivers/clk/microchip/clk_pfsoc_periph.c new file mode 100644 index 0000000000..74faf61f2c --- /dev/null +++ b/drivers/clk/microchip/clk_pfsoc_periph.c @@ -0,0 +1,173 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <dm/uclass.h> +#include <asm/io.h> +#include <linux/err.h> +#include <dt-bindings/clock/microchip,pfsoc-clock.h> + +#include "clk_pfsoc.h" + +#define PFSOC_PERIPH_CLOCK "pfsoc_periph_clock" + +#define REG_CLOCK_CONFIG_CR 0x08 +#define REG_SUBBLK_CLOCK_CR 0x84 +#define REG_SUBBLK_RESET_CR 0x88 + +#define CFG_CPU_SHIFT 0x0 +#define CFG_AXI_SHIFT 0x2 +#define CFG_AHB_SHIFT 0x4 +#define CFG_WIDTH 0x2 + +struct pfsoc_periph_clock { + unsigned int id; + const char *name; + u8 shift; + unsigned long flags; +}; + +struct pfsoc_periph_hw_clock { + struct pfsoc_periph_clock periph; + void __iomem *sys_base; + u32 prate; + struct clk hw; +}; + +#define to_pfsoc_periph_clk(_hw) container_of(_hw, struct pfsoc_periph_hw_clock, hw) + +static int pfsoc_periph_clk_enable(struct clk *hw) +{ + struct pfsoc_periph_hw_clock *periph_hw = to_pfsoc_periph_clk(hw); + struct pfsoc_periph_clock *periph = &periph_hw->periph; + void __iomem *base_addr = periph_hw->sys_base; + u32 reg, val; + + if (periph->flags != CLK_IS_CRITICAL) { + reg = readl(base_addr + REG_SUBBLK_RESET_CR); + val = reg & ~(1u << periph->shift); + writel(val, base_addr + REG_SUBBLK_RESET_CR); + + reg = readl(base_addr + REG_SUBBLK_CLOCK_CR); + val = reg | (1u << periph->shift); + writel(val, base_addr + REG_SUBBLK_CLOCK_CR); + } + + return 0; +} + +static int pfsoc_periph_clk_disable(struct clk *hw) +{ + struct pfsoc_periph_hw_clock *periph_hw = to_pfsoc_periph_clk(hw); + struct pfsoc_periph_clock *periph = &periph_hw->periph; + void __iomem *base_addr = periph_hw->sys_base; + u32 reg, val; + + if (periph->flags != CLK_IS_CRITICAL) { + reg = readl(base_addr + REG_SUBBLK_RESET_CR); + val = reg | (1u << periph->shift); + writel(val, base_addr + REG_SUBBLK_RESET_CR); + + reg = readl(base_addr + REG_SUBBLK_CLOCK_CR); + val = reg & ~(1u << periph->shift); + writel(val, base_addr + REG_SUBBLK_CLOCK_CR); + } + + return 0; +} + +static ulong pfsoc_periph_clk_recalc_rate(struct clk *hw) +{ + struct pfsoc_periph_hw_clock *periph_hw = to_pfsoc_periph_clk(hw); + void __iomem *base_addr = periph_hw->sys_base; + unsigned long rate; + u32 val; + + val = readl(base_addr + REG_CLOCK_CONFIG_CR) >> CFG_AHB_SHIFT; + val &= clk_div_mask(CFG_WIDTH); + rate = periph_hw->prate / (1u << val); + hw->rate = rate; + + return rate; +} + +#define CLK_PERIPH(_id, _name, _shift, _flags) { \ + .periph.id = _id, \ + .periph.name = _name, \ + .periph.shift = _shift, \ + .periph.flags = _flags, \ + } + +static struct pfsoc_periph_hw_clock pfsoc_periph_clks[] = { + CLK_PERIPH(CLK_ENVM, "clk_periph_envm", 0, CLK_IS_CRITICAL), + CLK_PERIPH(CLK_MAC0, "clk_periph_mac0", 1, 0), + CLK_PERIPH(CLK_MAC1, "clk_periph_mac1", 2, 0), + CLK_PERIPH(CLK_MMC, "clk_periph_mmc", 3, 0), + CLK_PERIPH(CLK_TIMER, "clk_periph_timer", 4, 0), + CLK_PERIPH(CLK_MMUART0, "clk_periph_mmuart0", 5, 0), + CLK_PERIPH(CLK_MMUART1, "clk_periph_mmuart1", 6, 0), + CLK_PERIPH(CLK_MMUART2, "clk_periph_mmuart2", 7, 0), + CLK_PERIPH(CLK_MMUART3, "clk_periph_mmuart3", 8, 0), + CLK_PERIPH(CLK_MMUART4, "clk_periph_mmuart4", 9, 0), + CLK_PERIPH(CLK_SPI0, "clk_periph_spi0", 10, 0), + CLK_PERIPH(CLK_SPI1, "clk_periph_spi1", 11, 0), + CLK_PERIPH(CLK_I2C0, "clk_periph_i2c0", 12, 0), + CLK_PERIPH(CLK_I2C1, "clk_periph_i2c1", 13, 0), + CLK_PERIPH(CLK_CAN0, "clk_periph_can0", 14, 0), + CLK_PERIPH(CLK_CAN1, "clk_periph_can1", 15, 0), + CLK_PERIPH(CLK_USB, "clk_periph_usb", 16, 0), + CLK_PERIPH(CLK_RTC, "clk_periph_rtc", 18, 0), + CLK_PERIPH(CLK_QSPI, "clk_periph_qspi", 19, 0), + CLK_PERIPH(CLK_GPIO0, "clk_periph_gpio0", 20, 0), + CLK_PERIPH(CLK_GPIO1, "clk_periph_gpio1", 21, 0), + CLK_PERIPH(CLK_GPIO2, "clk_periph_gpio2", 22, 0), + CLK_PERIPH(CLK_DDRC, "clk_periph_ddrc", 23, CLK_IS_CRITICAL), + CLK_PERIPH(CLK_FIC0, "clk_periph_fic0", 24, 0), + CLK_PERIPH(CLK_FIC1, "clk_periph_fic1", 25, 0), + CLK_PERIPH(CLK_FIC2, "clk_periph_fic2", 26, 0), + CLK_PERIPH(CLK_FIC3, "clk_periph_fic3", 27, 0), + CLK_PERIPH(CLK_ATHENA, "clk_periph_athena", 28, 0), + CLK_PERIPH(CLK_CFM, "clk_periph_cfm", 29, 0), +}; + +int pfsoc_clk_register_periphs(void __iomem *base, u32 clk_rate, + const char *parent_name) +{ + int ret; + int i, id, num_clks; + const char *name; + struct clk *hw; + + num_clks = ARRAY_SIZE(pfsoc_periph_clks); + for (i = 0; i < num_clks; i++) { + hw = &pfsoc_periph_clks[i].hw; + pfsoc_periph_clks[i].sys_base = base; + pfsoc_periph_clks[i].prate = clk_rate; + name = pfsoc_periph_clks[i].periph.name; + ret = clk_register(hw, PFSOC_PERIPH_CLOCK, name, parent_name); + if (ret) + ERR_PTR(ret); + id = pfsoc_periph_clks[i].periph.id; + clk_dm(id, hw); + } + + return 0; +} + +const struct clk_ops pfsoc_periph_clk_ops = { + .enable = pfsoc_periph_clk_enable, + .disable = pfsoc_periph_clk_disable, + .get_rate = pfsoc_periph_clk_recalc_rate, +}; + +U_BOOT_DRIVER(pfsoc_periph_clock) = { + .name = PFSOC_PERIPH_CLOCK, + .id = UCLASS_CLK, + .ops = &pfsoc_periph_clk_ops, +}; diff --git a/include/dt-bindings/clock/microchip,pfsoc-clock.h b/include/dt-bindings/clock/microchip,pfsoc-clock.h new file mode 100644 index 0000000000..527cff1a28 --- /dev/null +++ b/include/dt-bindings/clock/microchip,pfsoc-clock.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ + +#ifndef _DT_BINDINGS_CLK_MICROCHIP_PFSOC_H_ +#define _DT_BINDINGS_CLK_MICROCHIP_PFSOC_H_ + +#define CLK_CPU 0 +#define CLK_AXI 1 +#define CLK_AHB 2 + +#define CLK_ENVM 3 +#define CLK_MAC0 4 +#define CLK_MAC1 5 +#define CLK_MMC 6 +#define CLK_TIMER 7 +#define CLK_MMUART0 8 +#define CLK_MMUART1 9 +#define CLK_MMUART2 10 +#define CLK_MMUART3 11 +#define CLK_MMUART4 12 +#define CLK_SPI0 13 +#define CLK_SPI1 14 +#define CLK_I2C0 15 +#define CLK_I2C1 16 +#define CLK_CAN0 17 +#define CLK_CAN1 18 +#define CLK_USB 19 +#define CLK_RESERVED 20 +#define CLK_RTC 21 +#define CLK_QSPI 22 +#define CLK_GPIO0 23 +#define CLK_GPIO1 24 +#define CLK_GPIO2 25 +#define CLK_DDRC 26 +#define CLK_FIC0 27 +#define CLK_FIC1 28 +#define CLK_FIC2 29 +#define CLK_FIC3 30 +#define CLK_ATHENA 31 +#define CLK_CFM 32 + +#endif /* _DT_BINDINGS_CLK_MICROCHIP_PFSOC_H_ */
Add device tree for Microchip PolarFire SoC Icicle Kit.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- arch/riscv/dts/Makefile | 1 + .../dts/microchip-mpfs-icicle-kit-u-boot.dtsi | 14 + arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 421 ++++++++++++++++++ 3 files changed, 436 insertions(+) create mode 100644 arch/riscv/dts/microchip-mpfs-icicle-kit-u-boot.dtsi create mode 100644 arch/riscv/dts/microchip-mpfs-icicle-kit.dts
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 3a6f96c67d..01331b0aa1 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -3,6 +3,7 @@ dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_SIFIVE_FU540) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb +dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb
targets += $(dtb-y)
diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit-u-boot.dtsi b/arch/riscv/dts/microchip-mpfs-icicle-kit-u-boot.dtsi new file mode 100644 index 0000000000..f60283fb6b --- /dev/null +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2020 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ + +/ { + aliases { + cpu1 = &cpu1; + cpu2 = &cpu2; + cpu3 = &cpu3; + cpu4 = &cpu4; + }; +}; diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts new file mode 100644 index 0000000000..bf5d65740a --- /dev/null +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts @@ -0,0 +1,421 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* Copyright (c) 2020 Microchip Technology Inc */ + +/dts-v1/; +#include "dt-bindings/clock/microchip,pfsoc-clock.h" + +/* Clock frequency (in Hz) of the rtcclk */ +#define RTCCLK_FREQ 1000000 + +/ { + #address-cells = <2>; + #size-cells = <2>; + model = "Microchip PolarFire-SoC"; + compatible = "microchip,polarfire-soc"; + + aliases { + serial0 = &uart0; + ethernet0 = &emac1; + }; + + chosen { + stdout-path = "serial0"; + }; + + cpucomplex: cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <RTCCLK_FREQ>; + cpu0: cpu@0 { + clocks = <&clkcfg CLK_CPU>; + compatible = "sifive,e51", "sifive,rocket0", "riscv"; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <16384>; + reg = <0>; + riscv,isa = "rv64imac"; + status = "disabled"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu0intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu1: cpu@1 { + clocks = <&clkcfg CLK_CPU>; + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <1>; + riscv,isa = "rv64imafdc"; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu1intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu2: cpu@2 { + clocks = <&clkcfg CLK_CPU>; + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <2>; + riscv,isa = "rv64imafdc"; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu2intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu3: cpu@3 { + clocks = <&clkcfg CLK_CPU>; + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <3>; + riscv,isa = "rv64imafdc"; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu3intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu4: cpu@4 { + clocks = <&clkcfg CLK_CPU>; + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <4>; + riscv,isa = "rv64imafdc"; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu4intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + }; + ddr: memory@80000000 { + device_type = "memory"; + reg = <0x0 0x80000000 0x0 0x40000000>; + clocks = <&clkcfg CLK_DDRC>; + }; + soc: soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "microchip,polarfire-soc", "simple-bus"; + ranges; + clint0: clint@2000000 { + compatible = "riscv,clint0"; + interrupts-extended = <&cpu0intc 3 &cpu0intc 7 + &cpu1intc 3 &cpu1intc 7 + &cpu2intc 3 &cpu2intc 7 + &cpu3intc 3 &cpu3intc 7 + &cpu4intc 3 &cpu4intc 7>; + reg = <0x0 0x2000000 0x0 0x10000>; + reg-names = "control"; + clock-frequency = <RTCCLK_FREQ>; + }; + cachecontroller: cache-controller@2010000 { + compatible = "sifive,fu540-c000-ccache", "cache"; + cache-block-size = <64>; + cache-level = <2>; + cache-sets = <1024>; + cache-size = <2097152>; + cache-unified; + interrupt-parent = <&plic>; + interrupts = <1 2 3>; + reg = <0x0 0x2010000 0x0 0x1000>; + }; + plic: interrupt-controller@c000000 { + #interrupt-cells = <1>; + compatible = "sifive,plic-1.0.0"; + reg = <0x0 0xc000000 0x0 0x4000000>; + riscv,max-priority = <7>; + riscv,ndev = <186>; + interrupt-controller; + interrupts-extended = < + &cpu0intc 11 + &cpu1intc 11 &cpu1intc 9 + &cpu2intc 11 &cpu2intc 9 + &cpu3intc 11 &cpu3intc 9 + &cpu4intc 11 &cpu4intc 9>; + }; + uart0: serial@20000000 { + compatible = "ns16550a"; + reg = <0x0 0x20000000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <90>; + clock-frequency = <150000000>; + clocks = <&clkcfg CLK_MMUART0>; + status = "okay"; + }; + refclk: refclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <600000000>; + clock-output-names = "msspllclk"; + }; + clkcfg: clkcfg@20002000 { + compatible = "microchip,pfsoc-clkcfg"; + reg = <0x0 0x20002000 0x0 0x1000>; + reg-names = "mss_sysreg"; + clocks = <&refclk>; + #clock-cells = <1>; + clock-output-names = "cpu", "axi", "ahb", "envm", + "mac0", "mac1", "mmc", "timer", + "mmuart0", "mmuart1", "mmuart2", + "mmuart3", "mmuart4", "spi0", "spi1", + "i2c0", "i2c1", "can0", "can1", "usb", + "reserved", "rtc", "qspi", "gpio0", + "gpio1", "gpio2", "ddrc", "fic0", + "fic1", "fic2", "fic3", "athena", + "cfm"; + }; + emmc: mmc@20008000 { + compatible = "cdns,sd4hc"; + reg = <0x0 0x20008000 0x0 0x1000>; + interrupt-parent = <&plic>; + interrupts = <88 89>; + pinctrl-names = "default"; + clocks = <&clkcfg CLK_MMC>; + bus-width = <4>; + cap-mmc-highspeed; + mmc-ddr-3_3v; + max-frequency = <200000000>; + non-removable; + no-sd; + no-sdio; + voltage-ranges = <3300 3300>; + status = "okay"; + }; + sdcard: sd@20008000 { + compatible = "cdns,sd4hc"; + reg = <0x0 0x20008000 0x0 0x1000>; + interrupt-parent = <&plic>; + interrupts = <88>; + pinctrl-names = "default"; + clocks = <&clkcfg CLK_MMC>; + bus-width = <4>; + disable-wp; + cap-sd-highspeed; + card-detect-delay = <200>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + max-frequency = <200000000>; + status = "disabled"; + }; + uart1: serial@20100000 { + compatible = "ns16550a"; + reg = <0x0 0x20100000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <91>; + clock-frequency = <150000000>; + clocks = <&clkcfg CLK_MMUART1>; + status = "okay"; + }; + uart2: serial@20102000 { + compatible = "ns16550a"; + reg = <0x0 0x20102000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <92>; + clock-frequency = <150000000>; + clocks = <&clkcfg CLK_MMUART2>; + status = "okay"; + }; + uart3: serial@20104000 { + compatible = "ns16550a"; + reg = <0x0 0x20104000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <93>; + clock-frequency = <150000000>; + clocks = <&clkcfg CLK_MMUART3>; + status = "okay"; + }; + i2c0: i2c@02010a000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "microchip,mpfs-mss-i2c"; + reg = <0x0 0x2010a000 0x0 0x1000>; + interrupt-parent = <&plic>; + interrupts = <58>; + clocks = <&clkcfg CLK_I2C0>; + status = "disabled"; + }; + i2c1: i2c@02010b000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "microchip,mpfs-mss-i2c"; + reg = <0x0 0x2010b000 0x0 0x1000>; + interrupt-parent = <&plic>; + interrupts = <61>; + clocks = <&clkcfg CLK_I2C1>; + status = "disabled"; + pac193x@0x10 { + compatible = "microchip,pac1934"; + reg = <0x10>; + samp-rate = <64>; + status = "disabled"; + ch1: channel@0 { + uohms-shunt-res = <10000>; + rail-name = "VDD"; + channel_enabled; + }; + ch2: channel@1 { + uohms-shunt-res = <10000>; + rail-name = "VDDA25"; + channel_enabled; + }; + ch3: channel@2 { + uohms-shunt-res = <10000>; + rail-name = "VDD25"; + channel_enabled; + }; + ch4: channel@3 { + uohms-shunt-res = <10000>; + rail-name = "VDDA"; + channel_enabled; + }; + }; + }; + emac0: ethernet@20110000 { + compatible = "microchip,mpfs-mss-gem"; + reg = <0x0 0x20110000 0x0 0x2000>; + interrupt-parent = <&plic>; + interrupts = <64 65 66 67>; + local-mac-address = [00 00 00 00 00 00]; + phy-mode = "sgmii"; + clocks = <&clkcfg CLK_MAC0>, <&clkcfg CLK_AXI>; + clock-names = "pclk", "hclk"; + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + phy-handle = <&phy0>; + phy0: ethernet-phy@8 { + reg = <8>; + ti,fifo-depth = <0x01>; + }; + }; + emac1: ethernet@20112000 { + compatible = "microchip,mpfs-mss-gem"; + reg = <0x0 0x20112000 0x0 0x2000>; + interrupt-parent = <&plic>; + interrupts = <70 71 72 73>; + local-mac-address = [00 00 00 00 00 00]; + phy-mode = "sgmii"; + clocks = <&clkcfg CLK_MAC1>, <&clkcfg CLK_AHB>; + clock-names = "pclk", "hclk"; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + phy-handle = <&phy1>; + phy1: ethernet-phy@9 { + reg = <9>; + ti,fifo-depth = <0x01>; + }; + }; + gpio: gpio@0x20122000 { + compatible = "microchip,mpfs-mss-gpio"; + interrupt-parent = <&plic>; + interrupts = <13 14 15 16 17 18 19 20 21 22 23 24 25 26 + 27 28 29 30 31 32 33 34 35 36 37 38 39 + 40 41 42 43 44>; + gpio-controller; + clocks = <&clkcfg CLK_GPIO2>; + reg = <0x00 0x20122000 0x0 0x1000>; + reg-names = "control"; + #gpio-cells = <2>; + status = "disabled"; + }; + }; +};
Hi Padmarao,
On Fri, Nov 27, 2020 at 8:18 PM Padmarao Begari padmarao.begari@microchip.com wrote:
targets += $(dtb-y)
- Copyright (C) 2020 Microchip Technology Inc.
- Padmarao Begari padmarao.begari@microchip.com
aliases {
cpu1 = &cpu1;
cpu2 = &cpu2;
cpu3 = &cpu3;
cpu4 = &cpu4;
#size-cells = <2>;
Should this be: "microchip,polarfire-soc-icicle-kit"?
aliases {
serial0 = &uart0;
ethernet0 = &emac1;
chosen {
cpucomplex: cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu1: cpu@1 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <1>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu2: cpu@2 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <2>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu3: cpu@3 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <3>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu4: cpu@4 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <4>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
soc: soc {
#size-cells = <2>;
ranges;
cache-level = <2>;
cache-unified;
riscv,ndev = <186>;
&cpu0intc 11
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <90>;
status = "okay";
refclk: refclk {
#clock-cells = <0>;
clocks = <&refclk>;
#clock-cells = <1>;
"cfm";
bus-width = <4>;
cap-mmc-highspeed;
mmc-ddr-3_3v;
non-removable;
no-sd;
no-sdio;
status = "okay";
interrupts = <88>;
bus-width = <4>;
disable-wp;
cap-sd-highspeed;
sd-uhs-sdr12;
sd-uhs-sdr25;
sd-uhs-sdr50;
sd-uhs-sdr104;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <91>;
status = "okay";
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <92>;
status = "okay";
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <93>;
status = "okay";
#size-cells = <0>;
interrupts = <58>;
#size-cells = <0>;
interrupts = <61>;
pac193x@0x10 {
reg = <0x10>;
samp-rate = <64>;
ch1: channel@0 {
rail-name = "VDD";
channel_enabled;
ch2: channel@1 {
channel_enabled;
ch3: channel@2 {
channel_enabled;
ch4: channel@3 {
rail-name = "VDDA";
channel_enabled;
phy-mode = "sgmii";
On the Icicle-Kit board, there are 2 etherents ports. Is there a reason why this etherent port is disabled?
#size-cells = <0>;
reg = <8>;
phy-mode = "sgmii";
status = "okay";
#size-cells = <0>;
reg = <9>;
40 41 42 43 44>;
gpio-controller;
#gpio-cells = <2>;
Regards, Bin
On 11/27/20 1:43 PM, Bin Meng wrote:
EXTERNAL EMAIL: Do not click links or open attachments unless you know the content is safe
Hi Padmarao,
snip
#size-cells = <2>;
My preference for this would go to: "microchip,mpfs-icicle-kit". This is the name used to order the board and what is written on the box.
As a rule please use "mpfs" as identifier in place of "polarfire-soc", "pfsoc", "pse", "g5soc" or whatever other variation on the theme when not using the marketing name of the device.
Regards,
Cyril.
Hi Cyril,
the content is safe
Hi Padmarao,
snip
#size-cells = <2>;
ok
ok
Regards Padmarao
Regards,
Cyril.
Hi Bin,
On Fri, Nov 27, 2020 at 7:13 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Padmarao,
targets += $(dtb-y)
aliases {
cpu1 = &cpu1;
cpu2 = &cpu2;
cpu3 = &cpu3;
cpu4 = &cpu4;
#size-cells = <2>;
aliases {
serial0 = &uart0;
ethernet0 = &emac1;
chosen {
cpucomplex: cpus {
#size-cells = <0>;
cpu0: cpu@0 {
"riscv";
reg = <0>;
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu1: cpu@1 {
"riscv";
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <1>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu2: cpu@2 {
"riscv";
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <2>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu3: cpu@3 {
"riscv";
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <3>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
cpu4: cpu@4 {
"riscv";
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <4>;
tlb-split;
status = "okay";
/* kHz uV */
600000 1100000
300000 950000
150000 750000
soc: soc {
#size-cells = <2>;
ranges;
cache-level = <2>;
cache-unified;
riscv,ndev = <186>;
&cpu0intc 11
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <90>;
status = "okay";
refclk: refclk {
#clock-cells = <0>;
clocks = <&refclk>;
#clock-cells = <1>;
"spi1",
"usb",
"gpio0",
"cfm";
bus-width = <4>;
cap-mmc-highspeed;
mmc-ddr-3_3v;
non-removable;
no-sd;
no-sdio;
status = "okay";
interrupts = <88>;
bus-width = <4>;
disable-wp;
cap-sd-highspeed;
sd-uhs-sdr12;
sd-uhs-sdr25;
sd-uhs-sdr50;
sd-uhs-sdr104;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <91>;
status = "okay";
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <92>;
status = "okay";
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <93>;
status = "okay";
#size-cells = <0>;
interrupts = <58>;
#size-cells = <0>;
interrupts = <61>;
pac193x@0x10 {
reg = <0x10>;
samp-rate = <64>;
ch1: channel@0 {
rail-name = "VDD";
channel_enabled;
ch2: channel@1 {
channel_enabled;
ch3: channel@2 {
channel_enabled;
ch4: channel@3 {
rail-name = "VDDA";
channel_enabled;
phy-mode = "sgmii";
Yes, the Icicle kit has two ethernet ports but only one MDIO interface between MAC and PHY-dual port is available i.e connected with ethernet 1 and other port(ethernet 0) MDIO interface is not connected with PHY in the FPGA design that's why it is disabled. only one ethernet port is enabled in the fpga design for Linux bring-up on the Icicle kit at present.
We will update our FPGA design in the future to enable both ethernet ports.
Regards Padmarao
Regards Padmarao
#size-cells = <0>;
reg = <8>;
phy-mode = "sgmii";
status = "okay";
#size-cells = <0>;
reg = <9>;
24 25 26
38 39
40 41 42 43 44>;
gpio-controller;
#gpio-cells = <2>;
Regards, Bin
This patch adds Microchip MPFS Icicle Kit support. For now, only NS16550 Serial, Microchip clock, Cadence eMMC and MACB drivers are only enabled. The Microchip MPFS Icicle defconfig by default builds U-Boot for S-Mode because U-Boot on Microchip PolarFire SoC will run in S-Mode as payload of HSS + OpenSBI.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- board/microchip/mpfs_icicle/Kconfig | 24 ++++++ board/microchip/mpfs_icicle/mpfs_icicle.c | 97 ++++++++++++++++++++++- configs/microchip_mpfs_icicle_defconfig | 9 ++- include/configs/microchip_mpfs_icicle.h | 60 +++++--------- 4 files changed, 145 insertions(+), 45 deletions(-)
diff --git a/board/microchip/mpfs_icicle/Kconfig b/board/microchip/mpfs_icicle/Kconfig index bf8e1a13ec..f4e705a07b 100644 --- a/board/microchip/mpfs_icicle/Kconfig +++ b/board/microchip/mpfs_icicle/Kconfig @@ -20,7 +20,31 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select GENERIC_RISCV select BOARD_EARLY_INIT_F + select BOARD_LATE_INIT imply SMP + imply CLK_CCF + imply CLK_MPFS imply SYS_NS16550 + imply CMD_DHCP + imply CMD_EXT2 + imply CMD_EXT4 + imply CMD_FAT + imply CMD_FS_GENERIC + imply CMD_NET + imply CMD_PING + imply CMD_MMC + imply DOS_PARTITION + imply EFI_PARTITION + imply IP_DYN + imply ISO_PARTITION + imply MACB + imply MII + imply NET_RANDOM_ETHADDR + imply PHY_LIB + imply PHY_VITESSE + imply MMC + imply MMC_WRITE + imply MMC_SDHCI + imply MMC_SDHCI_CADENCE
endif diff --git a/board/microchip/mpfs_icicle/mpfs_icicle.c b/board/microchip/mpfs_icicle/mpfs_icicle.c index 8381361ec3..420ea25ac2 100644 --- a/board/microchip/mpfs_icicle/mpfs_icicle.c +++ b/board/microchip/mpfs_icicle/mpfs_icicle.c @@ -6,10 +6,47 @@
#include <common.h> #include <dm.h> +#include <env.h> #include <init.h> #include <asm/io.h>
-#define MPFS_SYSREG_SOFT_RESET ((unsigned int *)0x20002088) +#define MPFS_SYSREG_SOFT_RESET ((unsigned int *)0x20002088) +#define MPFS_SYS_SERVICE_CR ((unsigned int *)0x37020050) +#define MPFS_SYS_SERVICE_SR ((unsigned int *)0x37020054) +#define MPFS_SYS_SERVICE_MAILBOX ((unsigned char *)0x37020800) + +#define PERIPH_RESET_VALUE 0x1e8u +#define SERVICE_CR_REQ 0x1u +#define SERVICE_SR_BUSY 0x2u + +static void read_device_serial_number(u8 *response, u8 response_size) +{ + u8 idx; + u8 *response_buf; + unsigned int val; + + response_buf = (u8 *)response; + + writel(SERVICE_CR_REQ, MPFS_SYS_SERVICE_CR); + /* + * REQ bit will remain set till the system controller starts + * processing. + */ + do { + val = readl(MPFS_SYS_SERVICE_CR); + } while (SERVICE_CR_REQ == (val & SERVICE_CR_REQ)); + + /* + * Once system controller starts processing the busy bit will + * go high and service is completed when busy bit is gone low + */ + do { + val = readl(MPFS_SYS_SERVICE_SR); + } while (SERVICE_SR_BUSY == (val & SERVICE_SR_BUSY)); + + for (idx = 0; idx < response_size; idx++) + response_buf[idx] = readb(MPFS_SYS_SERVICE_MAILBOX + idx); +}
int board_init(void) { @@ -22,10 +59,64 @@ int board_early_init_f(void) { unsigned int val;
- /* Reset uart peripheral */ + /* Reset uart, mmc peripheral */ val = readl(MPFS_SYSREG_SOFT_RESET); - val = (val & ~(1u << 5u)); + val = (val & ~(PERIPH_RESET_VALUE)); writel(val, MPFS_SYSREG_SOFT_RESET);
return 0; } + +int board_late_init(void) +{ + u32 ret; + u32 node; + u8 idx; + u8 device_serial_number[16] = { 0 }; + unsigned char mac_addr[6]; + char icicle_mac_addr[20]; + void *blob = (void *)gd->fdt_blob; + + node = fdt_path_offset(blob, "ethernet0"); + if (node < 0) { + printf("No ethernet0 path offset\n"); + return -ENODEV; + } + + ret = fdtdec_get_byte_array(blob, node, "local-mac-address", mac_addr, 6); + if (ret) { + printf("No local-mac-address property\n"); + return -EINVAL; + } + + read_device_serial_number(device_serial_number, 16); + + /* Update MAC address with device serial number */ + mac_addr[0] = 0x00; + mac_addr[1] = 0x04; + mac_addr[2] = 0xA3; + mac_addr[3] = device_serial_number[2]; + mac_addr[4] = device_serial_number[1]; + mac_addr[5] = device_serial_number[0]; + + ret = fdt_setprop(blob, node, "local-mac-address", mac_addr, 6); + if (ret) { + printf("Error setting local-mac-address property\n"); + return -ENODEV; + } + + icicle_mac_addr[0] = '['; + + sprintf(&icicle_mac_addr[1], "%pM", mac_addr); + + icicle_mac_addr[18] = ']'; + icicle_mac_addr[19] = '\0'; + + for (idx = 0; idx < 20; idx++) { + if (icicle_mac_addr[idx] == ':') + icicle_mac_addr[idx] = ' '; + } + env_set("icicle_mac_addr", icicle_mac_addr); + + return 0; +} diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig index 2977966473..9abbc18a89 100644 --- a/configs/microchip_mpfs_icicle_defconfig +++ b/configs/microchip_mpfs_icicle_defconfig @@ -1,12 +1,15 @@ CONFIG_RISCV=y CONFIG_ENV_SIZE=0x2000 CONFIG_TARGET_MICROCHIP_ICICLE=y -CONFIG_NR_CPUS=5 CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_SBI_V01=y +CONFIG_DEFAULT_DEVICE_TREE="microchip-mpfs-icicle-kit" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y CONFIG_FIT=y -CONFIG_BOOTDELAY=3 CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_OF_PRIOR_STAGE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MTD=y diff --git a/include/configs/microchip_mpfs_icicle.h b/include/configs/microchip_mpfs_icicle.h index 8a7470545b..97547057b9 100644 --- a/include/configs/microchip_mpfs_icicle.h +++ b/include/configs/microchip_mpfs_icicle.h @@ -7,53 +7,35 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* - * CPU and Board Configuration Options - */ +#include <linux/sizes.h>
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M)
-/* - * Print Buffer Size - */ -#define CONFIG_SYS_PBSIZE \ - (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M)
-/* - * max number of command args - */ -#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN SZ_8M
-/* - * Boot Argument Buffer Size - */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* - * Size of malloc() pool - * 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough - */ -#define CONFIG_SYS_MALLOC_LEN (512 << 10) +#define CONFIG_SYS_BOOTM_LEN SZ_64M
-/* - * Physical Memory Map - */ -#define PHYS_SDRAM_0 0x80000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_0_SIZE 0x40000000 /* 1 GB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_0 +#define CONFIG_STANDALONE_LOAD_ADDR 0x80200000
-/* Init Stack Pointer */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x200000) +/* Environment options */
-#define CONFIG_SYS_LOAD_ADDR 0x80000000 /* SDRAM */ +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(DHCP, dhcp, na)
-/* - * memtest works on DRAM - */ +#include <config_distro_bootcmd.h>
-/* When we use RAM as ENV */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_addr_r=0x84000000\0" \ + "fdt_addr_r=0x88000000\0" \ + "scriptaddr=0x88100000\0" \ + "pxefile_addr_r=0x88200000\0" \ + "ramdisk_addr_r=0x88300000\0" \ + BOOTENV
#endif /* __CONFIG_H */
This doc describes the procedure to build, flash and boot Linux using U-boot on Microchip MPFS Icicle Kit.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com --- doc/board/index.rst | 1 + doc/board/microchip/index.rst | 9 + doc/board/microchip/mpfs_icicle.rst | 827 ++++++++++++++++++++++++++++ 3 files changed, 837 insertions(+) create mode 100644 doc/board/microchip/index.rst create mode 100644 doc/board/microchip/mpfs_icicle.rst
diff --git a/doc/board/index.rst b/doc/board/index.rst index 4b6a996eb1..e329e2744c 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -15,6 +15,7 @@ Board-specific doc freescale/index google/index intel/index + microchip/index kontron/index renesas/index rockchip/index diff --git a/doc/board/microchip/index.rst b/doc/board/microchip/index.rst new file mode 100644 index 0000000000..b09e6788af --- /dev/null +++ b/doc/board/microchip/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Microchip +====== + +.. toctree:: + :maxdepth: 2 + + mpfs_icicle diff --git a/doc/board/microchip/mpfs_icicle.rst b/doc/board/microchip/mpfs_icicle.rst new file mode 100644 index 0000000000..fb3f895ca3 --- /dev/null +++ b/doc/board/microchip/mpfs_icicle.rst @@ -0,0 +1,827 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Microchip PolarFire SoC Icicle Kit +================================== + +RISC-V PolarFire SoC +--------------------- +The PolarFire SoC is the 4+1 64-bit RISC-V SoC from Microchip. + +The Icicle Kit development platform is based on PolarFire SoC and capable +of running Linux. + +Mainline support +---------------- +The support for following drivers are already enabled: + +1. NS16550 UART Driver. +2. Microchip Clock Driver. +3. Cadence MACB ethernet driver for networking support. +4. Cadence MMC Driver for eMMC/SD support. + +Booting from eMMC using HSS +--------------------------- + +Building U-Boot +--------------- + +1. Add the RISC-V toolchain to your PATH. +2. Setup ARCH & cross compilation environment variable: + +.. code-block:: none + + export CROSS_COMPILE=<riscv64 toolchain prefix> + +3. make microchip_mpfs_icicle_defconfig +4. make + +Flashing +-------- + +The current U-Boot port is supported in S-mode only and loaded from DRAM. + +A prior stage M-mode firmware/bootloader (e.g HSS with OpenSBI) is required to +boot the u-boot.bin in S-mode. + +Currently, the u-boot.bin is used as a payload of the HSS firmware(Microchip +boot-flow) and OpenSBI generic platform fw_payload.bin (with u-boot.bin embedded) +as HSS payload(Custom boot-flow) + +Microchip boot-flow +------------------- +HSS with OpenSBI(M-Mode) -> U-Boot(S-Mode) -> Linux(S-Mode) + +Build the HSS((Hart Software Services) - Microchip boot-flow +------------------------------------------------------------ +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services) + +1. Configure + +.. code-block:: none + + make BOARD=icicle-kit-es config + +Alternatively, copy the default config for Microchip boot-flow. + +.. code-block:: none + + cp boards/icicle-kit-es/def_config .config + +2. make BOARD=icicle-kit-es +3. In the Default subdirectory, the standard build will create hss.elf and + various binary formats (hss.hex and hss.bin). + +The FPGA design will use the hss.hex or hss.bin. + +FPGA design with HSS programming file +------------------------------------- +https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boa... +/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md + +The HSS firmware runs from the PolarFire SoC eNVM on reset. + +Creating the HSS payload - Microchip boot-flow +---------------------------------------------- +1. You will be creating a payload from `u-boot-dtb.bin`. + Copy this file to the HSS/tools/hss-payload-generator/test directory. +2. Go to hss-payload-generator source directory. + +.. code-block:: none + + cd hart-software-services/tools/hss-payload-generator + +3. Edit test/uboot.yaml file for hart entry points and correct name of the binary file. + + hart-entry-points: {u54_1: '0x80200000', u54_2: '0x80200000', + u54_3: '0x80200000', u54_4: '0x80200000'} + + payloads: + test/u-boot-dtb.bin: {exec-addr: '0x80200000', owner-hart: u54_1, + secondary-hart: u54_2, secondary-hart: u54_3, secondary-hart: u54_4, + priv-mode: prv_s} + +4. Generate payload + +.. code-block:: none + + ./hss-payload-generator -c test/uboot.yaml payload.bin + +Once the payload binary is generated, it should be copied to the eMMC. + +Please refer to HSS documenation to build the HSS firmware for payload. +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services/blob/master +/tools/hss-payload-generator/README.md) + +Custom boot-flow +---------------- +HSS without OpenSBI(M-Mode) -> OpenSBI(M-Mode) -> U-Boot(S-Mode) -> Linux(S-Mode) + +Build OpenSBI +------------- + +1. Get the OpenSBI source + +.. code-block:: none + + git clone https://github.com/riscv/opensbi.git + cd opensbi + +2. Build + +.. code-block:: none + + make PLATFORM=generic FW_PAYLOAD_PATH=<u-boot-directory>/u-boot.bin + FW_FDT_PATH=<u-boot-directory>/arch/riscv/dts/microchip-mpfs-icicle-kit-.dtb + +3. Output "fw_payload.bin" file available at + "<opensbi-directory>/build/platform/generic/firmware/fw_payload.bin" + +Build the HSS((Hart Software Services)- Custom boot-flow +-------------------------------------------------------- +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services) + +1. Configure + +.. code-block:: none + + make BOARD=icicle-kit-es config + +Alternatively, copy the default custom config for Custom boot-flow. + +.. code-block:: none + + cp boards/icicle-kit-es/def_config_custom .config + +2. make BOARD=icicle-kit-es +3. In the Default subdirectory, the standard build will create hss.elf and + various binary formats (hss.hex and hss.bin). + +The FPGA design will use the hss.hex or hss.bin. + +Creating the HSS payload - Custom boot-flow +------------------------------------------- +1. You will be creating a payload from `fw_payload.bin`. + Copy this file to the HSS/tools/hss-payload-generator/test directory. +2. Go to hss-payload-generator source directory. + +.. code-block:: none + + cd hart-software-services/tools/hss-payload-generator + +3. Edit test/uboot.yaml file for hart entry points and correct name of the binary file. + + hart-entry-points: {u54_1: '0x80000000', u54_2: '0x80000000', + u54_3: '0x80000000', u54_4: '0x80000000'} + + payloads: + test/fw_payload.bin: {exec-addr: '0x80000000', owner-hart: u54_1, + secondary-hart: u54_2, secondary-hart: u54_3, secondary-hart: u54_4, + priv-mode: prv_m} + +4. Generate payload + +.. code-block:: none + + ./hss-payload-generator -c test/uboot.yaml payload.bin + +Once the payload binary is generated, it should be copied to the eMMC. + +Please refer to HSS documenation to build the HSS firmware for payload. +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services/blob/master +/tools/hss-payload-generator/README.md) + +eMMC +---- +Program eMMC with payload binary is explained in the PolarFire SoC documentation. +(Note: PolarFire SoC Documentation git repo is at +https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boa... +/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md#eMMC + +Once the payload image is copied to the eMMC, press CTRL+C in the HSS command +line interface, then type 'boot' and enter to boot the newly copied image. + +.. code-block:: none + + sudo dd if=<payload_binary> of=/dev/sdX bs=512 + +GUID type +--------- +The HSS always picks up HSS payload from a GPT partition with +GIUD type "21686148-6449-6E6F-744E-656564454649" or sector '0' of the eMMC if no +GPT partition. + +Booting +------- +you should see the U-Boot prompt on UART0. + +Sample boot log from MPFS Icicle Kit +------------------------------------------- + +.. code-block:: none + + U-Boot 2021.01-rc1-00391-gb6c870e58b (Nov 10 2020 - 01:21:12 +0530) + + CPU: rv64imafdc + Model: Microchip PolarFire-SoC + DRAM: 1 GiB + MMC: sdhc@20008000: 0 + In: serial@20100000 + Out: serial@20100000 + Err: serial@20100000 + Net: eth0: ethernet@20112000 + Hit any key to stop autoboot: 0 + +Now you can configure your networking, tftp server and use tftp boot method to +load uImage(with initramfs). + +.. code-block:: none + + RISC-V # setenv kernel_addr_r 0x80200000 + RISC-V # setenv fdt_addr_r 0x82200000 + + RISC-V # setenv ipaddr 192.168.1.5 + RISC-V # setenv netmask 255.255.255.0 + RISC-V # setenv serverip 192.168.1.3 + RISC-V # setenv gateway 192.168.1.1 + + RISC-V # tftpboot ${kernel_addr_r} uImage + ethernet@20112000: PHY present at 9 + ethernet@20112000: Starting autonegotiation... + ethernet@20112000: Autonegotiation complete + ethernet@20112000: link up, 1000Mbps full-duplex (lpa: 0x7800) + Using ethernet@20112000 device + TFTP from server 192.168.1.3; our IP address is 192.168.1.5 + Filename 'uImage'. + Load address: 0x80200000 + Loading: ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ############ + 6.4 MiB/s + done + Bytes transferred = 14482480 (dcfc30 hex) + + RISC-V # tftpboot ${fdt_addr_r} microchip-mpfs-icicle-kit.dtb + ethernet@20112000: PHY present at 9 + ethernet@20112000: Starting autonegotiation... + ethernet@20112000: Autonegotiation complete + ethernet@20112000: link up, 1000Mbps full-duplex (lpa: 0x7800) + Using ethernet@20112000 device + TFTP from server 192.168.1.3; our IP address is 192.168.1.5 + Filename 'microchip-mpfs-icicle-kit.dtb'. + Load address: 0x82200000 + Loading: # + 2.5 MiB/s + done + Bytes transferred = 10282 (282a hex) + + RISC-V # bootm ${kernel_addr_r} - ${fdt_addr_r} + ## Booting kernel from Legacy Image at 80200000 ... + Image Name: Linux + Image Type: RISC-V Linux Kernel Image (uncompressed) + Data Size: 14482416 Bytes = 13.8 MiB + Load Address: 80200000 + Entry Point: 80200000 + Verifying Checksum ... OK + ## Flattened Device Tree blob at 82200000 + Booting using the fdt blob at 0x82200000 + Loading Kernel Image + Using Device Tree in place at 0000000082200000, end 0000000082205829 + + Starting kernel ... + + [ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 + [ 0.000000] Linux version 5.6.17 (padmarao@padmarao-VirtualBox) (gcc version 7.2.0 (GCC)) #2 SMP Tue Jun 16 21:27:50 IST 2020 + [ 0.000000] initrd not found or empty - disabling initrd + [ 0.000000] Zone ranges: + [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000bfffffff] + [ 0.000000] Normal empty + [ 0.000000] Movable zone start for each node + [ 0.000000] Early memory node ranges + [ 0.000000] node 0: [mem 0x0000000080200000-0x00000000bfffffff] + [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000000bfffffff] + [ 0.000000] software IO TLB: mapped [mem 0xbb1f5000-0xbf1f5000] (64MB) + [ 0.000000] elf_hwcap is 0x112d + [ 0.000000] percpu: Embedded 14 pages/cpu s24856 r0 d32488 u57344 + [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258055 + [ 0.000000] Kernel command line: console=ttyS0,115200n8 + [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) + [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) + [ 0.000000] Sorting __ex_table... + [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off + [ 0.000000] Memory: 950308K/1046528K available (3289K kernel code, 212K rwdata, 900K rodata, 9476K init, 250K bss, 96220K reserved, 0K cma-reserved) + [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 + [ 0.000000] rcu: Hierarchical RCU implementation. + [ 0.000000] rcu: RCU event tracing is enabled. + [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. + [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. + [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 + [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0 + [ 0.000000] plic: mapped 186 interrupts with 4 handlers for 9 contexts. + [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1] + [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns + [ 0.000015] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns + [ 0.000311] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) + [ 0.000349] pid_max: default: 32768 minimum: 301 + [ 0.000846] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) + [ 0.000964] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) + [ 0.005630] rcu: Hierarchical SRCU implementation. + [ 0.006901] smp: Bringing up secondary CPUs ... + [ 0.012545] smp: Brought up 1 node, 4 CPUs + [ 0.014431] devtmpfs: initialized + [ 0.020526] random: get_random_bytes called from setup_net+0x36/0x192 with crng_init=0 + [ 0.020928] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns + [ 0.020999] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) + [ 0.022768] NET: Registered protocol family 16 + [ 0.035478] microchip-pfsoc-clkcfg 20002000.clkcfg: Registered PFSOC core clocks + [ 0.048429] SCSI subsystem initialized + [ 0.049694] pps_core: LinuxPPS API ver. 1 registered + [ 0.049719] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it + [ 0.049780] PTP clock support registered + [ 0.051781] clocksource: Switched to clocksource riscv_clocksource + [ 0.055326] NET: Registered protocol family 2 + [ 0.056922] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) + [ 0.057053] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) + [ 0.057648] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) + [ 0.058579] TCP: Hash tables configured (established 8192 bind 8192) + [ 0.059648] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) + [ 0.059837] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) + [ 0.060707] NET: Registered protocol family 1 + [ 0.266229] workingset: timestamp_bits=62 max_order=18 bucket_order=0 + [ 0.287107] io scheduler mq-deadline registered + [ 0.287140] io scheduler kyber registered + [ 0.429601] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled + [ 0.433979] printk: console [ttyS0] disabled + [ 0.434154] 20000000.serial: ttyS0 at MMIO 0x20000000 (irq = 18, base_baud = 9375000) is a 16550A + [ 0.928039] printk: console [ttyS0] enabled + [ 0.939804] libphy: Fixed MDIO Bus: probed + [ 0.948702] libphy: MACB_mii_bus: probed + [ 0.993698] macb 20112000.ethernet eth0: Cadence GEM rev 0x0107010c at 0x20112000 irq 21 (56:34:12:00:fc:00) + [ 1.006751] mousedev: PS/2 mouse device common for all mice + [ 1.013803] i2c /dev entries driver + [ 1.019451] sdhci: Secure Digital Host Controller Interface driver + [ 1.027242] sdhci: Copyright(c) Pierre Ossman + [ 1.032731] sdhci-pltfm: SDHCI platform and OF driver helper + [ 1.091826] mmc0: SDHCI controller on 20008000.sdhc [20008000.sdhc] using ADMA 64-bit + [ 1.102738] NET: Registered protocol family 17 + [ 1.170326] Freeing unused kernel memory: 9476K + [ 1.176067] This architecture does not have kernel memory protection. + [ 1.184157] Run /init as init process + Starting logging: OK + Starting mdev... + /etc/init.d/S10mdev: line 21: can't create /proc/sys/kernel/hotplug: nonexiste[ 1.331981] mmc0: mmc_select_hs200 failed, error -74 + nt directory + [ 1.355011] mmc0: new MMC card at address 0001 + [ 1.363981] mmcblk0: mmc0:0001 DG4008 7.28 GiB + [ 1.372248] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB + [ 1.382292] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB + [ 1.390265] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (251:0) + [ 1.425234] GPT:Primary header thinks Alt. header is not at the end of the disk. + [ 1.434656] GPT:2255809 != 15273599 + [ 1.439038] GPT:Alternate GPT header not at the end of the disk. + [ 1.446671] GPT:2255809 != 15273599 + [ 1.451048] GPT: Use GNU Parted to correct GPT errors. + [ 1.457755] mmcblk0: p1 p2 p3 + sort: /sys/devices/platform/Fixed: No such file or directory + modprobe: can't change directory to '/lib/modules': No such file or directory + Initializing random number generator... [ 2.830198] random: dd: uninitialized urandom read (512 bytes read) + done. + Starting network... + [ 3.061867] macb 20112000.ethernet eth0: PHY [20112000.ethernet-ffffffff:09] driver [Vitesse VSC8662] (irq=POLL) + [ 3.074674] macb 20112000.ethernet eth0: configuring for phy/sgmii link mode + [ 3.084263] pps pps0: new PPS source ptp0 + [ 3.089710] macb 20112000.ethernet: gem-ptp-timer ptp clock registered. + udhcpc (v1.24.2) started + Sending discover... + Sending discover... + [ 6.380169] macb 20112000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx + Sending discover... + Sending select for 192.168.1.2... + Lease of 192.168.1.2 obtained, lease time 86400 + deleting routers + adding dns 192.168.1.1 + Starting dropbear sshd: [ 11.385619] random: dropbear: uninitialized urandom read (32 bytes read) + OK + + Welcome to Buildroot + buildroot login: root + Password: + # + +Booting U-Boot and Linux from eMMC +---------------------------------- + +FPGA design with HSS programming file and Linux Image +----------------------------------------------------- +https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boa... +/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md + +The HSS firmware runs from the PolarFire SoC eNVM on reset. + +eMMC +---- +Program eMMC with payload binary and Linux image is explained in the +PolarFire SoC documentation. +The payload binary should copied to partition 2 of the eMMC. + +(Note: PolarFire SoC Documentation git repo is at +https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boa... +/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md#eMMC) + +once the Linux image and payload binary is copied to the eMMC, press CTRL+C +in the HSS command line interface, then type 'boot' and enter to boot the newly +copied payload and Linux image. + +.. code-block:: none + + zcat <linux-image>.wic.gz | sudo dd of=/dev/sdX bs=4096 iflag=fullblock oflag=direct conv=fsync status=progress + + sudo dd if=<payload_binary> of=/dev/sdX2 bs=512 + +You should see the U-Boot prompt on UART0. + +GUID type +--------- +The HSS always picks up HSS payload from a GPT partition with +GIUD type "21686148-6449-6E6F-744E-656564454649" or sector '0' of the eMMC if no +GPT partition. + +Sample boot log from MPFS Icicle Kit +------------------------------------------- + +.. code-block:: none + + U-Boot 2021.01-rc1-00391-gb6c870e58b (Nov 10 2020 - 01:21:12 +0530) + + CPU: rv64imafdc + Model: Microchip PolarFire-SoC + DRAM: 1 GiB + MMC: sdhc@20008000: 0 + In: serial@20100000 + Out: serial@20100000 + Err: serial@20100000 + Net: eth0: ethernet@20112000 + Hit any key to stop autoboot: 0 + + RISC-V # mmc info + Device: sdhc@20008000 + Manufacturer ID: 45 + OEM: 100 + Name: DG400 + Bus Speed: 52000000 + Mode: MMC High Speed (52MHz) + Rd Block Len: 512 + MMC version 5.1 + High Capacity: Yes + Capacity: 7.3 GiB + Bus Width: 4-bit + Erase Group Size: 512 KiB + HC WP Group Size: 8 MiB + User Capacity: 7.3 GiB WRREL + Boot Capacity: 4 MiB ENH + RPMB Capacity: 4 MiB ENH + + RISC-V # mmc part + Partition Map for MMC device 0 -- Partition Type: EFI + + Part Start LBA End LBA Name + Attributes + Type GUID + Partition GUID + 1 0x00002000 0x0000b031 "boot" + attrs: 0x0000000000000004 + type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 + guid: 99ff6a94-f2e7-44dd-a7df-f3a2da106ef9 + 2 0x0000b032 0x0000f031 "primary" + attrs: 0x0000000000000000 + type: 21686148-6449-6e6f-744e-656564454649 + guid: 12006052-e64b-4423-beb0-b956ea00f1ba + 3 0x00010000 0x00226b9f "root" + attrs: 0x0000000000000000 + type: 0fc63daf-8483-4772-8e79-3d69d8477de4 + guid: dd2c5619-2272-4c3c-8dc2-e21942e17ce6 + + RISC-V # fatload mmc 0 ${ramdisk_addr_r} fitimage + RISC-V # bootm ${ramdisk_addr_r} + ## Loading kernel from FIT Image at 88300000 ... + Using 'conf@microchip_icicle-kit-es-a000-microchip.dtb' configuration + Trying 'kernel@1' kernel subimage + Description: Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Start: 0x883000fc + Data Size: 3574555 Bytes = 3.4 MiB + Architecture: RISC-V + OS: Linux + Load Address: 0x80200000 + Entry Point: 0x80200000 + Hash algo: sha256 + Hash value: 21f18d72cf2f0a7192220abb577ad25c77c26960052d779aa02bf55dbf0a6403 + Verifying Hash Integrity ... sha256+ OK + ## Loading fdt from FIT Image at 88300000 ... + Using 'conf@microchip_icicle-kit-es-a000-microchip.dtb' configuration + Trying 'fdt@microchip_icicle-kit-es-a000-microchip.dtb' fdt subimage + Description: Flattened Device Tree blob + Type: Flat Device Tree + Compression: uncompressed + Data Start: 0x88668d44 + Data Size: 9760 Bytes = 9.5 KiB + Architecture: RISC-V + Load Address: 0x82200000 + Hash algo: sha256 + Hash value: 5c3a9f30d41b6b8e53b47916e1f339b3a4d454006554d1f7e1f552ed62409f4b + Verifying Hash Integrity ... sha256+ OK + Loading fdt from 0x88668d44 to 0x82200000 + Booting using the fdt blob at 0x82200000 + Uncompressing Kernel Image + Using Device Tree in place at 0000000082200000, end 000000008220561f + + Starting kernel ... + + [ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 + [ 0.000000] Linux version 5.6.16 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP Fri Oct 9 11:49:47 UTC 2020 + [ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '') + [ 0.000000] printk: bootconsole [sbi0] enabled + [ 0.000000] Zone ranges: + [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000bfffffff] + [ 0.000000] Normal empty + [ 0.000000] Movable zone start for each node + [ 0.000000] Early memory node ranges + [ 0.000000] node 0: [mem 0x0000000080200000-0x00000000bfffffff] + [ 0.000000] Zeroed struct page in unavailable ranges: 512 pages + [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000000bfffffff] + [ 0.000000] software IO TLB: mapped [mem 0xb9e00000-0xbde00000] (64MB) + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] elf_hwcap is 0x112d + [ 0.000000] percpu: Embedded 17 pages/cpu s29784 r8192 d31656 u69632 + [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258055 + [ 0.000000] Kernel command line: earlycon=sbi root=/dev/mmcblk0p3 rootwait console=ttyS0,115200n8 uio_pdrv_genirq.of_id=generic-uio + [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) + [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) + [ 0.000000] Sorting __ex_table... + [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off + [ 0.000000] Memory: 941440K/1046528K available (4118K kernel code, 280K rwdata, 1687K rodata, 169K init, 273K bss, 105088K reserved, 0K cma-reserved) + [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 + [ 0.000000] rcu: Hierarchical RCU implementation. + [ 0.000000] rcu: RCU event tracing is enabled. + [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=5 to nr_cpu_ids=4. + [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. + [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 + [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0 + [ 0.000000] plic: mapped 53 interrupts with 4 handlers for 9 contexts. + [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1] + [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns + [ 0.000015] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns + [ 0.008679] Console: colour dummy device 80x25 + [ 0.013112] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) + [ 0.023368] pid_max: default: 32768 minimum: 301 + [ 0.028314] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) + [ 0.035766] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) + [ 0.047099] rcu: Hierarchical SRCU implementation. + [ 0.052813] smp: Bringing up secondary CPUs ... + [ 0.061581] smp: Brought up 1 node, 4 CPUs + [ 0.067069] devtmpfs: initialized + [ 0.073621] random: get_random_u32 called from bucket_table_alloc.isra.0+0x4e/0x150 with crng_init=0 + [ 0.074409] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns + [ 0.093399] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) + [ 0.101879] NET: Registered protocol family 16 + [ 0.110336] microchip-pfsoc-clkcfg 20002000.clkcfg: Registered PFSOC core clocks + [ 0.132717] usbcore: registered new interface driver usbfs + [ 0.138225] usbcore: registered new interface driver hub + [ 0.143813] usbcore: registered new device driver usb + [ 0.148939] pps_core: LinuxPPS API ver. 1 registered + [ 0.153929] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it + [ 0.163071] PTP clock support registered + [ 0.168521] clocksource: Switched to clocksource riscv_clocksource + [ 0.174927] VFS: Disk quotas dquot_6.6.0 + [ 0.179016] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) + [ 0.205536] NET: Registered protocol family 2 + [ 0.210944] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) + [ 0.219393] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) + [ 0.227497] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) + [ 0.235440] TCP: Hash tables configured (established 8192 bind 8192) + [ 0.242537] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) + [ 0.249285] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) + [ 0.256690] NET: Registered protocol family 1 + [ 0.262585] workingset: timestamp_bits=62 max_order=18 bucket_order=0 + [ 0.281036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) + [ 0.288481] io scheduler mq-deadline registered + [ 0.292983] io scheduler kyber registered + [ 0.298895] microsemi,mss-gpio 20122000.gpio: Microsemi MSS GPIO registered 32 GPIOs + [ 0.453723] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled + [ 0.462911] printk: console [ttyS0] disabled + [ 0.467216] 20100000.serial: ttyS0 at MMIO 0x20100000 (irq = 12, base_baud = 9375000) is a 16550A + [ 0.476201] printk: console [ttyS0] enabled + [ 0.476201] printk: console [ttyS0] enabled + [ 0.484576] printk: bootconsole [sbi0] disabled + [ 0.484576] printk: bootconsole [sbi0] disabled + [ 0.494920] 20102000.serial: ttyS1 at MMIO 0x20102000 (irq = 13, base_baud = 9375000) is a 16550A + [ 0.505068] 20104000.serial: ttyS2 at MMIO 0x20104000 (irq = 14, base_baud = 9375000) is a 16550A + [ 0.533336] loop: module loaded + [ 0.572284] Rounding down aligned max_sectors from 4294967295 to 4294967288 + [ 0.580000] db_root: cannot open: /etc/target + [ 0.585413] libphy: Fixed MDIO Bus: probed + [ 0.591526] libphy: MACB_mii_bus: probed + [ 0.598060] macb 20112000.ethernet eth0: Cadence GEM rev 0x0107010c at 0x20112000 irq 17 (56:34:12:00:fc:00) + [ 0.608352] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver + [ 0.615001] ehci-platform: EHCI generic platform driver + [ 0.620446] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver + [ 0.626632] ohci-platform: OHCI generic platform driver + [ 0.632326] usbcore: registered new interface driver cdc_acm + [ 0.637996] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters + [ 0.646459] i2c /dev entries driver + [ 0.650852] microsemi-mss-i2c 2010b000.i2c: Microsemi I2C Probe Complete + [ 0.658010] sdhci: Secure Digital Host Controller Interface driver + [ 0.664326] sdhci: Copyright(c) Pierre Ossman + [ 0.668754] sdhci-pltfm: SDHCI platform and OF driver helper + [ 0.706845] mmc0: SDHCI controller on 20008000.sdhc [20008000.sdhc] using ADMA 64-bit + [ 0.715052] usbcore: registered new interface driver usbhid + [ 0.720722] usbhid: USB HID core driver + [ 0.725174] pac193x 0-0010: Chip revision: 0x03 + [ 0.733339] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 0 active + [ 0.740127] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 1 active + [ 0.746881] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 2 active + [ 0.753686] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 3 active + [ 0.760495] pac193x 0-0010: :pac193x_prep_iio_channels: Active chip channels: 25 + [ 0.778006] NET: Registered protocol family 10 + [ 0.784929] Segment Routing with IPv6 + [ 0.788875] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver + [ 0.795743] NET: Registered protocol family 17 + [ 0.801191] hctosys: unable to open rtc device (rtc0) + [ 0.807774] Waiting for root device /dev/mmcblk0p3... + [ 0.858506] mmc0: mmc_select_hs200 failed, error -74 + [ 0.865764] mmc0: new MMC card at address 0001 + [ 0.872564] mmcblk0: mmc0:0001 DG4008 7.28 GiB + [ 0.878777] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB + [ 0.886182] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB + [ 0.892633] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (247:0) + [ 0.919029] GPT:Primary header thinks Alt. header is not at the end of the disk. + [ 0.926448] GPT:2255841 != 15273599 + [ 0.930019] GPT:Alternate GPT header not at the end of the disk. + [ 0.936029] GPT:2255841 != 15273599 + [ 0.939583] GPT: Use GNU Parted to correct GPT errors. + [ 0.944800] mmcblk0: p1 p2 p3 + [ 0.966696] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem + [ 0.974105] EXT4-fs (mmcblk0p3): write access will be enabled during recovery + [ 1.052362] random: fast init done + [ 1.057961] EXT4-fs (mmcblk0p3): recovery complete + [ 1.065734] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) + [ 1.074002] VFS: Mounted root (ext4 filesystem) readonly on device 179:3. + [ 1.081654] Freeing unused kernel memory: 168K + [ 1.086108] This architecture does not have kernel memory protection. + [ 1.092629] Run /sbin/init as init process + [ 1.702217] systemd[1]: System time before build time, advancing clock. + [ 1.754192] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) + [ 1.776361] systemd[1]: Detected architecture riscv64. + + Welcome to OpenEmbedded nodistro.0! + + [ 1.829651] systemd[1]: Set hostname to <icicle-kit-es>. + [ 2.648597] random: systemd: uninitialized urandom read (16 bytes read) + [ 2.657485] systemd[1]: Created slice system-getty.slice. + [ OK ] Created slice system-getty.slice. + [ 2.698779] random: systemd: uninitialized urandom read (16 bytes read) + [ 2.706317] systemd[1]: Created slice system-serial\x2dgetty.slice. + [ OK ] Created slice system-serial\x2dgetty.slice. + [ 2.748716] random: systemd: uninitialized urandom read (16 bytes read) + [ 2.756098] systemd[1]: Created slice User and Session Slice. + [ OK ] Created slice User and Session Slice. + [ 2.789065] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. + [ OK ] Started Dispatch Password …ts to Console Directory Watch. + [ 2.828974] systemd[1]: Started Forward Password Requests to Wall Directory Watch. + [ OK ] Started Forward Password R…uests to Wall Directory Watch. + [ 2.869009] systemd[1]: Reached target Paths. + [ OK ] Reached target Paths. + [ 2.898808] systemd[1]: Reached target Remote File Systems. + [ OK ] Reached target Remote File Systems. + [ 2.938771] systemd[1]: Reached target Slices. + [ OK ] Reached target Slices. + [ 2.968754] systemd[1]: Reached target Swap. + [ OK ] Reached target Swap. + [ 2.999283] systemd[1]: Listening on initctl Compatibility Named Pipe. + [ OK ] Listening on initctl Compatibility Named Pipe. + [ 3.060458] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. + [ 3.069826] systemd[1]: Listening on Journal Socket (/dev/log). + [ OK ] Listening on Journal Socket (/dev/log). + [ 3.109601] systemd[1]: Listening on Journal Socket. + [ OK ] Listening on Journal Socket. + [ 3.149868] systemd[1]: Listening on Network Service Netlink Socket. + [ OK ] Listening on Network Service Netlink Socket. + [ 3.189419] systemd[1]: Listening on udev Control Socket. + [ OK ] Listening on udev Control Socket. + [ 3.229179] systemd[1]: Listening on udev Kernel Socket. + [ OK ] Listening on udev Kernel Socket. + [ 3.269520] systemd[1]: Condition check resulted in Huge Pages File System being skipped. + [ 3.278477] systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped. + [ 3.288200] systemd[1]: Condition check resulted in Kernel Debug File System being skipped. + [ 3.302570] systemd[1]: Mounting Temporary Directory (/tmp)... + Mounting Temporary Directory (/tmp)... + [ 3.339226] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped. + [ 3.355883] systemd[1]: Starting File System Check on Root Device... + Starting File System Check on Root Device... + [ 3.407220] systemd[1]: Starting Journal Service... + Starting Journal Service... + [ 3.422441] systemd[1]: Condition check resulted in Load Kernel Modules being skipped. + [ 3.431770] systemd[1]: Condition check resulted in FUSE Control File System being skipped. + [ 3.446415] systemd[1]: Mounting Kernel Configuration File System... + Mounting Kernel Configuration File System... + [ 3.458983] systemd[1]: Starting Apply Kernel Variables... + Starting Apply Kernel Variables... + [ 3.471368] systemd[1]: Starting udev Coldplug all Devices... + Starting udev Coldplug all Devices... + [ 3.491071] systemd[1]: Mounted Temporary Directory (/tmp). + [ OK 3.498114] systemd[1]: Mounted Kernel Configuration File System. + 0m] Mounted Temporary Directory (/tmp). + [ OK ] Mounted Kernel Configuration File System. + [ 3.550853] systemd[1]: Started Apply Kernel Variables. + [ OK 3.557535] systemd[1]: Started Journal Service. + 0m] Started Apply Kernel Variables. + [ OK ] Started Journal Service. + [ OK ] Started udev Coldplug all Devices. + [ OK ] Started File System Check on Root Device. + Starting Remount Root and Kernel File Systems... + [ 8.133469] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null) + [ OK ] Started Remount Root and Kernel File Systems. + Starting Flush Journal to Persistent Storage... + [ 8.215327] systemd-journald[77]: Received client request to flush runtime journal. + Starting Create Static Device Nodes in /dev... + [ OK ] Started Flush Journal to Persistent Storage. + [ OK ] Started Create Static Device Nodes in /dev. + [ OK ] Reached target Local File Systems (Pre). + Mounting /var/volatile... + Starting udev Kernel Device Manager... + [ OK ] Mounted /var/volatile. + Starting Load/Save Random Seed... + [ OK ] Reached target Local File Systems. + Starting Create Volatile Files and Directories... + [ OK ] Started udev Kernel Device Manager. + [ OK ] Started Create Volatile Files and Directories. + Starting Network Time Synchronization... + Starting Update UTMP about System Boot/Shutdown... + [ OK ] Started Update UTMP about System Boot/Shutdown. + [ OK ] Started Network Time Synchronization. + [ 11.618575] random: crng init done + [ 11.622007] random: 7 urandom warning(s) missed due to ratelimiting + [ OK ] Started Load/Save Random Seed. + [ OK ] Reached target System Initialization. + [ OK ] Started Daily Cleanup of Temporary Directories. + [ OK ] Reached target System Time Set. + [ OK ] Reached target System Time Synchronized. + [ OK ] Reached target Timers. + [ OK ] Listening on D-Bus System Message Bus Socket. + [ OK ] Listening on dropbear.socket. + [ OK ] Reached target Sockets. + [ OK ] Reached target Basic System. + [ OK ] Started D-Bus System Message Bus. + Starting IPv6 Packet Filtering Framework... + Starting IPv4 Packet Filtering Framework... + Starting Login Service... + [ OK ] Started IPv6 Packet Filtering Framework. + [ OK ] Started IPv4 Packet Filtering Framework. + [ OK ] Reached target Network (Pre). + Starting Network Service... + [ OK ] Started Login Service. + [ 12.602455] macb 20112000.ethernet eth0: PHY [20112000.ethernet-ffffffff:09] driver [Vitesse VSC8662] (irq=POLL) + [ 12.612795] macb 20112000.ethernet eth0: configuring for phy/sgmii link mode + [ 12.622153] pps pps0: new PPS source ptp0 + [ OK 12.626725] macb 20112000.ethernet: gem-ptp-timer ptp clock registered. + 0m] Started Network Service. + Starting Network Name Resolution... + [ OK ] Started Network Name Resolution. + [ OK ] Reached target Network. + [ OK ] Reached target Host and Network Name Lookups. + [ OK ] Started Collectd. + [ OK ] Started Collectd. + Starting Permit User Sessions... + [ OK ] Started Permit User Sessions. + [ OK ] Started Getty on tty1. + [ OK ] Started Serial Getty on ttyS0. + [ OK ] Reached target Login Prompts. + [ OK ] Reached target Multi-User System. + Starting Update UTMP about System Runlevel Changes... + [ OK ] Started Update UTMP about System Runlevel Changes. + + OpenEmbedded nodistro.0 icicle-kit-es ttyS0 + + icicle-kit-es login: [ 15.795564] macb 20112000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx + [ 15.803306] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready + + icicle-kit-es login: root + root@icicle-kit-es:~#
Hi Padmarao,
- microchip/index kontron/index renesas/index rockchip/index
+Microchip +======
+.. toctree::
- :maxdepth: 2
- mpfs_icicle
- export CROSS_COMPILE=<riscv64 toolchain prefix>
+Flashing +--------
+1. Configure
- make BOARD=icicle-kit-es config
- cp boards/icicle-kit-es/def_config .config
- various binary formats (hss.hex and hss.bin).
- Copy this file to the HSS/tools/hss-payload-generator/test directory.
- cd hart-software-services/tools/hss-payload-generator
- hart-entry-points: {u54_1: '0x80200000', u54_2: '0x80200000',
- payloads:
- test/u-boot-dtb.bin: {exec-addr: '0x80200000', owner-hart: u54_1,
priv-mode: prv_s}
- ./hss-payload-generator -c test/uboot.yaml payload.bin
- git clone https://github.com/riscv/opensbi.git
- cd opensbi
+2. Build
- make PLATFORM=generic FW_PAYLOAD_PATH=<u-boot-directory>/u-boot.bin
- FW_FDT_PATH=<u-boot-directory>/arch/riscv/dts/microchip-mpfs-icicle-kit-.dtb
- "<opensbi-directory>/build/platform/generic/firmware/fw_payload.bin"
+1. Configure
- cp boards/icicle-kit-es/def_config_custom .config
- hart-entry-points: {u54_1: '0x80000000', u54_2: '0x80000000',
- payloads:
- test/fw_payload.bin: {exec-addr: '0x80000000', owner-hart: u54_1,
priv-mode: prv_m}
You could also add a reference to this document which is geared more towards using the HSS payload generator and includes links to pre-built images: https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/sof...
- sudo dd if=<payload_binary> of=/dev/sdX bs=512
- U-Boot 2021.01-rc1-00391-gb6c870e58b (Nov 10 2020 - 01:21:12 +0530)
- CPU: rv64imafdc
- Model: Microchip PolarFire-SoC
- DRAM: 1 GiB
- MMC: sdhc@20008000: 0
- In: serial@20100000
- Out: serial@20100000
- Err: serial@20100000
- Net: eth0: ethernet@20112000
- Hit any key to stop autoboot: 0
- RISC-V # setenv kernel_addr_r 0x80200000
- RISC-V # setenv fdt_addr_r 0x82200000
- RISC-V # setenv ipaddr 192.168.1.5
- RISC-V # setenv netmask 255.255.255.0
- RISC-V # setenv serverip 192.168.1.3
- RISC-V # setenv gateway 192.168.1.1
- RISC-V # tftpboot ${kernel_addr_r} uImage
- ethernet@20112000: PHY present at 9
- ethernet@20112000: Starting autonegotiation...
- ethernet@20112000: Autonegotiation complete
- ethernet@20112000: link up, 1000Mbps full-duplex (lpa: 0x7800)
- Using ethernet@20112000 device
- TFTP from server 192.168.1.3; our IP address is 192.168.1.5
- Filename 'uImage'.
- Load address: 0x80200000
- Loading: #################################################################
6.4 MiB/s
- done
- Bytes transferred = 14482480 (dcfc30 hex)
- RISC-V # tftpboot ${fdt_addr_r} microchip-mpfs-icicle-kit.dtb
- Filename 'microchip-mpfs-icicle-kit.dtb'.
- Load address: 0x82200000
- Loading: #
2.5 MiB/s
- done
- Bytes transferred = 10282 (282a hex)
- RISC-V # bootm ${kernel_addr_r} - ${fdt_addr_r}
- ## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux
- ## Flattened Device Tree blob at 82200000
- Starting kernel ...
- [ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000
- [ 0.000000] Linux version 5.6.17 (padmarao@padmarao-VirtualBox) (gcc version 7.2.0 (GCC)) #2 SMP Tue Jun 16 21:27:50 IST 2020
- [ 0.000000] initrd not found or empty - disabling initrd
- [ 0.000000] Zone ranges:
- [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000bfffffff]
- [ 0.000000] Normal empty
- [ 0.000000] Movable zone start for each node
- [ 0.000000] Early memory node ranges
- [ 0.000000] node 0: [mem 0x0000000080200000-0x00000000bfffffff]
- [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000000bfffffff]
- [ 0.000000] software IO TLB: mapped [mem 0xbb1f5000-0xbf1f5000] (64MB)
- [ 0.000000] elf_hwcap is 0x112d
- [ 0.000000] percpu: Embedded 14 pages/cpu s24856 r0 d32488 u57344
- [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258055
- [ 0.000000] Kernel command line: console=ttyS0,115200n8
- [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
- [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
- [ 0.000000] Sorting __ex_table...
- [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
- [ 0.000000] Memory: 950308K/1046528K available (3289K kernel code, 212K rwdata, 900K rodata, 9476K init, 250K bss, 96220K reserved, 0K cma-reserved)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
- [ 0.000000] rcu: Hierarchical RCU implementation.
- [ 0.000000] rcu: RCU event tracing is enabled.
- [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
- [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
- [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
- [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
- [ 0.000000] plic: mapped 186 interrupts with 4 handlers for 9 contexts.
- [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
- [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
- [ 0.000015] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
- [ 0.000311] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
- [ 0.000349] pid_max: default: 32768 minimum: 301
- [ 0.000846] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
- [ 0.000964] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
- [ 0.005630] rcu: Hierarchical SRCU implementation.
- [ 0.006901] smp: Bringing up secondary CPUs ...
- [ 0.012545] smp: Brought up 1 node, 4 CPUs
- [ 0.014431] devtmpfs: initialized
- [ 0.020526] random: get_random_bytes called from setup_net+0x36/0x192 with crng_init=0
- [ 0.020928] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
- [ 0.020999] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
- [ 0.022768] NET: Registered protocol family 16
- [ 0.035478] microchip-pfsoc-clkcfg 20002000.clkcfg: Registered PFSOC core clocks
- [ 0.048429] SCSI subsystem initialized
- [ 0.049694] pps_core: LinuxPPS API ver. 1 registered
- [ 0.049719] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
- [ 0.049780] PTP clock support registered
- [ 0.051781] clocksource: Switched to clocksource riscv_clocksource
- [ 0.055326] NET: Registered protocol family 2
- [ 0.056922] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
- [ 0.057053] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
- [ 0.057648] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
- [ 0.058579] TCP: Hash tables configured (established 8192 bind 8192)
- [ 0.059648] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
- [ 0.059837] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
- [ 0.060707] NET: Registered protocol family 1
- [ 0.266229] workingset: timestamp_bits=62 max_order=18 bucket_order=0
- [ 0.287107] io scheduler mq-deadline registered
- [ 0.287140] io scheduler kyber registered
- [ 0.429601] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
- [ 0.433979] printk: console [ttyS0] disabled
- [ 0.434154] 20000000.serial: ttyS0 at MMIO 0x20000000 (irq = 18, base_baud = 9375000) is a 16550A
- [ 0.928039] printk: console [ttyS0] enabled
- [ 0.939804] libphy: Fixed MDIO Bus: probed
- [ 0.948702] libphy: MACB_mii_bus: probed
- [ 0.993698] macb 20112000.ethernet eth0: Cadence GEM rev 0x0107010c at 0x20112000 irq 21 (56:34:12:00:fc:00)
- [ 1.006751] mousedev: PS/2 mouse device common for all mice
- [ 1.013803] i2c /dev entries driver
- [ 1.019451] sdhci: Secure Digital Host Controller Interface driver
- [ 1.027242] sdhci: Copyright(c) Pierre Ossman
- [ 1.032731] sdhci-pltfm: SDHCI platform and OF driver helper
- [ 1.091826] mmc0: SDHCI controller on 20008000.sdhc [20008000.sdhc] using ADMA 64-bit
- [ 1.102738] NET: Registered protocol family 17
- [ 1.170326] Freeing unused kernel memory: 9476K
- [ 1.176067] This architecture does not have kernel memory protection.
- [ 1.184157] Run /init as init process
- Starting logging: OK
- Starting mdev...
- /etc/init.d/S10mdev: line 21: can't create /proc/sys/kernel/hotplug: nonexiste[ 1.331981] mmc0: mmc_select_hs200 failed, error -74
- nt directory
- [ 1.355011] mmc0: new MMC card at address 0001
- [ 1.363981] mmcblk0: mmc0:0001 DG4008 7.28 GiB
- [ 1.372248] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB
- [ 1.382292] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB
- [ 1.390265] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (251:0)
- [ 1.425234] GPT:Primary header thinks Alt. header is not at the end of the disk.
- [ 1.434656] GPT:2255809 != 15273599
- [ 1.439038] GPT:Alternate GPT header not at the end of the disk.
- [ 1.446671] GPT:2255809 != 15273599
- [ 1.451048] GPT: Use GNU Parted to correct GPT errors.
- [ 1.457755] mmcblk0: p1 p2 p3
- sort: /sys/devices/platform/Fixed: No such file or directory
- modprobe: can't change directory to '/lib/modules': No such file or directory
- Initializing random number generator... [ 2.830198] random: dd: uninitialized urandom read (512 bytes read)
- done.
- Starting network...
- [ 3.061867] macb 20112000.ethernet eth0: PHY [20112000.ethernet-ffffffff:09] driver [Vitesse VSC8662] (irq=POLL)
- [ 3.074674] macb 20112000.ethernet eth0: configuring for phy/sgmii link mode
- [ 3.084263] pps pps0: new PPS source ptp0
- [ 3.089710] macb 20112000.ethernet: gem-ptp-timer ptp clock registered.
- udhcpc (v1.24.2) started
- Sending discover...
- [ 6.380169] macb 20112000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
- Sending select for 192.168.1.2...
- Lease of 192.168.1.2 obtained, lease time 86400
- deleting routers
- adding dns 192.168.1.1
- Starting dropbear sshd: [ 11.385619] random: dropbear: uninitialized urandom read (32 bytes read)
- OK
- Welcome to Buildroot
- buildroot login: root
- Password:
Should this last sentence read "The payload binary should be copied to partition 2 of the eMMC."? "be" missing.
Uppercase "O" for once?
- zcat <linux-image>.wic.gz | sudo dd of=/dev/sdX bs=4096 iflag=fullblock oflag=direct conv=fsync status=progress
- sudo dd if=<payload_binary> of=/dev/sdX2 bs=512
Missing "the"?: "The HSS always picks up the HSS payload from a GPT partition with"
- CPU: rv64imafdc
- DRAM: 1 GiB
- RISC-V # mmc info
- Device: sdhc@20008000
- Manufacturer ID: 45
- OEM: 100
- Name: DG400
- Bus Speed: 52000000
- Mode: MMC High Speed (52MHz)
- Rd Block Len: 512
- MMC version 5.1
- High Capacity: Yes
- Capacity: 7.3 GiB
- Bus Width: 4-bit
- Erase Group Size: 512 KiB
- HC WP Group Size: 8 MiB
- User Capacity: 7.3 GiB WRREL
- Boot Capacity: 4 MiB ENH
- RPMB Capacity: 4 MiB ENH
- RISC-V # mmc part
- Partition Map for MMC device 0 -- Partition Type: EFI
- Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
- 1 0x00002000 0x0000b031 "boot"
- 2 0x0000b032 0x0000f031 "primary"
- 3 0x00010000 0x00226b9f "root"
- RISC-V # fatload mmc 0 ${ramdisk_addr_r} fitimage
- RISC-V # bootm ${ramdisk_addr_r}
- ## Loading kernel from FIT Image at 88300000 ...
- Using 'conf@microchip_icicle-kit-es-a000-microchip.dtb' configuration
- Trying 'kernel@1' kernel subimage
Type: Kernel Image
OS: Linux
Hash algo: sha256
- Verifying Hash Integrity ... sha256+ OK
- ## Loading fdt from FIT Image at 88300000 ...
- Trying 'fdt@microchip_icicle-kit-es-a000-microchip.dtb' fdt subimage
Hash algo: sha256
- Loading fdt from 0x88668d44 to 0x82200000
- Booting using the fdt blob at 0x82200000
- Uncompressing Kernel Image
- Using Device Tree in place at 0000000082200000, end 000000008220561f
- [ 0.000000] Linux version 5.6.16 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP Fri Oct 9 11:49:47 UTC 2020
- [ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
- [ 0.000000] printk: bootconsole [sbi0] enabled
- [ 0.000000] Zeroed struct page in unavailable ranges: 512 pages
- [ 0.000000] software IO TLB: mapped [mem 0xb9e00000-0xbde00000] (64MB)
- [ 0.000000] CPU with hartid=0 is not available
- [ 0.000000] percpu: Embedded 17 pages/cpu s29784 r8192 d31656 u69632
- [ 0.000000] Kernel command line: earlycon=sbi root=/dev/mmcblk0p3 rootwait console=ttyS0,115200n8 uio_pdrv_genirq.of_id=generic-uio
- [ 0.000000] Memory: 941440K/1046528K available (4118K kernel code, 280K rwdata, 1687K rodata, 169K init, 273K bss, 105088K reserved, 0K cma-reserved)
- [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=5 to nr_cpu_ids=4.
- [ 0.000000] plic: mapped 53 interrupts with 4 handlers for 9 contexts.
- [ 0.008679] Console: colour dummy device 80x25
- [ 0.013112] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
- [ 0.023368] pid_max: default: 32768 minimum: 301
- [ 0.028314] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
- [ 0.035766] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
- [ 0.047099] rcu: Hierarchical SRCU implementation.
- [ 0.052813] smp: Bringing up secondary CPUs ...
- [ 0.061581] smp: Brought up 1 node, 4 CPUs
- [ 0.067069] devtmpfs: initialized
- [ 0.073621] random: get_random_u32 called from bucket_table_alloc.isra.0+0x4e/0x150 with crng_init=0
- [ 0.074409] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
- [ 0.093399] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
- [ 0.101879] NET: Registered protocol family 16
- [ 0.110336] microchip-pfsoc-clkcfg 20002000.clkcfg: Registered PFSOC core clocks
- [ 0.132717] usbcore: registered new interface driver usbfs
- [ 0.138225] usbcore: registered new interface driver hub
- [ 0.143813] usbcore: registered new device driver usb
- [ 0.148939] pps_core: LinuxPPS API ver. 1 registered
- [ 0.153929] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
- [ 0.163071] PTP clock support registered
- [ 0.168521] clocksource: Switched to clocksource riscv_clocksource
- [ 0.174927] VFS: Disk quotas dquot_6.6.0
- [ 0.179016] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
- [ 0.205536] NET: Registered protocol family 2
- [ 0.210944] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
- [ 0.219393] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
- [ 0.227497] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
- [ 0.235440] TCP: Hash tables configured (established 8192 bind 8192)
- [ 0.242537] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
- [ 0.249285] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
- [ 0.256690] NET: Registered protocol family 1
- [ 0.262585] workingset: timestamp_bits=62 max_order=18 bucket_order=0
- [ 0.281036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
- [ 0.288481] io scheduler mq-deadline registered
- [ 0.292983] io scheduler kyber registered
- [ 0.298895] microsemi,mss-gpio 20122000.gpio: Microsemi MSS GPIO registered 32 GPIOs
- [ 0.453723] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
- [ 0.462911] printk: console [ttyS0] disabled
- [ 0.467216] 20100000.serial: ttyS0 at MMIO 0x20100000 (irq = 12, base_baud = 9375000) is a 16550A
- [ 0.476201] printk: console [ttyS0] enabled
- [ 0.484576] printk: bootconsole [sbi0] disabled
- [ 0.494920] 20102000.serial: ttyS1 at MMIO 0x20102000 (irq = 13, base_baud = 9375000) is a 16550A
- [ 0.505068] 20104000.serial: ttyS2 at MMIO 0x20104000 (irq = 14, base_baud = 9375000) is a 16550A
- [ 0.533336] loop: module loaded
- [ 0.572284] Rounding down aligned max_sectors from 4294967295 to 4294967288
- [ 0.580000] db_root: cannot open: /etc/target
- [ 0.585413] libphy: Fixed MDIO Bus: probed
- [ 0.591526] libphy: MACB_mii_bus: probed
- [ 0.598060] macb 20112000.ethernet eth0: Cadence GEM rev 0x0107010c at 0x20112000 irq 17 (56:34:12:00:fc:00)
- [ 0.608352] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- [ 0.615001] ehci-platform: EHCI generic platform driver
- [ 0.620446] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- [ 0.626632] ohci-platform: OHCI generic platform driver
- [ 0.632326] usbcore: registered new interface driver cdc_acm
- [ 0.637996] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
- [ 0.646459] i2c /dev entries driver
- [ 0.650852] microsemi-mss-i2c 2010b000.i2c: Microsemi I2C Probe Complete
- [ 0.658010] sdhci: Secure Digital Host Controller Interface driver
- [ 0.664326] sdhci: Copyright(c) Pierre Ossman
- [ 0.668754] sdhci-pltfm: SDHCI platform and OF driver helper
- [ 0.706845] mmc0: SDHCI controller on 20008000.sdhc [20008000.sdhc] using ADMA 64-bit
- [ 0.715052] usbcore: registered new interface driver usbhid
- [ 0.720722] usbhid: USB HID core driver
- [ 0.725174] pac193x 0-0010: Chip revision: 0x03
- [ 0.733339] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 0 active
- [ 0.740127] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 1 active
- [ 0.746881] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 2 active
- [ 0.753686] pac193x 0-0010: :pac193x_prep_iio_channels: Channel 3 active
- [ 0.760495] pac193x 0-0010: :pac193x_prep_iio_channels: Active chip channels: 25
- [ 0.778006] NET: Registered protocol family 10
- [ 0.784929] Segment Routing with IPv6
- [ 0.788875] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
- [ 0.795743] NET: Registered protocol family 17
- [ 0.801191] hctosys: unable to open rtc device (rtc0)
- [ 0.807774] Waiting for root device /dev/mmcblk0p3...
- [ 0.858506] mmc0: mmc_select_hs200 failed, error -74
- [ 0.865764] mmc0: new MMC card at address 0001
- [ 0.872564] mmcblk0: mmc0:0001 DG4008 7.28 GiB
- [ 0.878777] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB
- [ 0.886182] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB
- [ 0.892633] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (247:0)
- [ 0.919029] GPT:Primary header thinks Alt. header is not at the end of the disk.
- [ 0.926448] GPT:2255841 != 15273599
- [ 0.930019] GPT:Alternate GPT header not at the end of the disk.
- [ 0.936029] GPT:2255841 != 15273599
- [ 0.939583] GPT: Use GNU Parted to correct GPT errors.
- [ 0.944800] mmcblk0: p1 p2 p3
- [ 0.966696] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
- [ 0.974105] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
- [ 1.052362] random: fast init done
- [ 1.057961] EXT4-fs (mmcblk0p3): recovery complete
- [ 1.065734] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
- [ 1.074002] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
- [ 1.081654] Freeing unused kernel memory: 168K
- [ 1.086108] This architecture does not have kernel memory protection.
- [ 1.092629] Run /sbin/init as init process
- [ 1.702217] systemd[1]: System time before build time, advancing clock.
- [ 1.754192] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
- [ 1.776361] systemd[1]: Detected architecture riscv64.
- Welcome to OpenEmbedded nodistro.0!
- [ 1.829651] systemd[1]: Set hostname to <icicle-kit-es>.
- [ 2.648597] random: systemd: uninitialized urandom read (16 bytes read)
- [ 2.657485] systemd[1]: Created slice system-getty.slice.
- [ OK ] Created slice system-getty.slice.
- [ 2.698779] random: systemd: uninitialized urandom read (16 bytes read)
- [ 2.706317] systemd[1]: Created slice system-serial\x2dgetty.slice.
- [ OK ] Created slice system-serial\x2dgetty.slice.
- [ 2.748716] random: systemd: uninitialized urandom read (16 bytes read)
- [ 2.756098] systemd[1]: Created slice User and Session Slice.
- [ OK ] Created slice User and Session Slice.
- [ 2.789065] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
- [ OK ] Started Dispatch Password …ts to Console Directory Watch.
- [ 2.828974] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
- [ OK ] Started Forward Password R…uests to Wall Directory Watch.
- [ 2.869009] systemd[1]: Reached target Paths.
- [ OK ] Reached target Paths.
- [ 2.898808] systemd[1]: Reached target Remote File Systems.
- [ OK ] Reached target Remote File Systems.
- [ 2.938771] systemd[1]: Reached target Slices.
- [ OK ] Reached target Slices.
- [ 2.968754] systemd[1]: Reached target Swap.
- [ OK ] Reached target Swap.
- [ 2.999283] systemd[1]: Listening on initctl Compatibility Named Pipe.
- [ OK ] Listening on initctl Compatibility Named Pipe.
- [ 3.060458] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
- [ 3.069826] systemd[1]: Listening on Journal Socket (/dev/log).
- [ OK ] Listening on Journal Socket (/dev/log).
- [ 3.109601] systemd[1]: Listening on Journal Socket.
- [ OK ] Listening on Journal Socket.
- [ 3.149868] systemd[1]: Listening on Network Service Netlink Socket.
- [ OK ] Listening on Network Service Netlink Socket.
- [ 3.189419] systemd[1]: Listening on udev Control Socket.
- [ OK ] Listening on udev Control Socket.
- [ 3.229179] systemd[1]: Listening on udev Kernel Socket.
- [ OK ] Listening on udev Kernel Socket.
- [ 3.269520] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
- [ 3.278477] systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
- [ 3.288200] systemd[1]: Condition check resulted in Kernel Debug File System being skipped.
- [ 3.302570] systemd[1]: Mounting Temporary Directory (/tmp)...
- [ 3.339226] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
- [ 3.355883] systemd[1]: Starting File System Check on Root Device...
- [ 3.407220] systemd[1]: Starting Journal Service...
- [ 3.422441] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
- [ 3.431770] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
- [ 3.446415] systemd[1]: Mounting Kernel Configuration File System...
- [ 3.458983] systemd[1]: Starting Apply Kernel Variables...
- [ 3.471368] systemd[1]: Starting udev Coldplug all Devices...
- [ 3.491071] systemd[1]: Mounted Temporary Directory (/tmp).
- [ OK 3.498114] systemd[1]: Mounted Kernel Configuration File System.
- 0m] Mounted Temporary Directory (/tmp).
- [ OK ] Mounted Kernel Configuration File System.
- [ 3.550853] systemd[1]: Started Apply Kernel Variables.
- [ OK 3.557535] systemd[1]: Started Journal Service.
- 0m] Started Apply Kernel Variables.
- [ OK ] Started Journal Service.
- [ OK ] Started udev Coldplug all Devices.
- [ OK ] Started File System Check on Root Device.
- [ 8.133469] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
- [ OK ] Started Remount Root and Kernel File Systems.
- [ 8.215327] systemd-journald[77]: Received client request to flush runtime journal.
- [ OK ] Started Flush Journal to Persistent Storage.
- [ OK ] Started Create Static Device Nodes in /dev.
- [ OK ] Reached target Local File Systems (Pre).
- [ OK ] Mounted /var/volatile.
- [ OK ] Reached target Local File Systems.
- [ OK ] Started udev Kernel Device Manager.
- [ OK ] Started Create Volatile Files and Directories.
- [ OK ] Started Update UTMP about System Boot/Shutdown.
- [ OK ] Started Network Time Synchronization.
- [ 11.618575] random: crng init done
- [ 11.622007] random: 7 urandom warning(s) missed due to ratelimiting
- [ OK ] Started Load/Save Random Seed.
- [ OK ] Reached target System Initialization.
- [ OK ] Started Daily Cleanup of Temporary Directories.
- [ OK ] Reached target System Time Set.
- [ OK ] Reached target System Time Synchronized.
- [ OK ] Reached target Timers.
- [ OK ] Listening on D-Bus System Message Bus Socket.
- [ OK ] Listening on dropbear.socket.
- [ OK ] Reached target Sockets.
- [ OK ] Reached target Basic System.
- [ OK ] Started D-Bus System Message Bus.
- [ OK ] Started IPv6 Packet Filtering Framework.
- [ OK ] Started IPv4 Packet Filtering Framework.
- [ OK ] Reached target Network (Pre).
- [ OK ] Started Login Service.
- [ 12.602455] macb 20112000.ethernet eth0: PHY [20112000.ethernet-ffffffff:09] driver [Vitesse VSC8662] (irq=POLL)
- [ 12.612795] macb 20112000.ethernet eth0: configuring for phy/sgmii link mode
- [ 12.622153] pps pps0: new PPS source ptp0
- [ OK 12.626725] macb 20112000.ethernet: gem-ptp-timer ptp clock registered.
- 0m] Started Network Service.
- [ OK ] Started Network Name Resolution.
- [ OK ] Reached target Network.
- [ OK ] Reached target Host and Network Name Lookups.
- [ OK ] Started Collectd.
- [ OK ] Started Permit User Sessions.
- [ OK ] Started Getty on tty1.
- [ OK ] Started Serial Getty on ttyS0.
- [ OK ] Reached target Login Prompts.
- [ OK ] Reached target Multi-User System.
- [ OK ] Started Update UTMP about System Runlevel Changes.
- OpenEmbedded nodistro.0 icicle-kit-es ttyS0
- icicle-kit-es login: [ 15.795564] macb 20112000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
- [ 15.803306] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
- icicle-kit-es login: root
- root@icicle-kit-es:~#
Hi Cyril,
On Fri, Nov 27, 2020 at 10:05 PM Cyril.Jean@microchip.com wrote:
Hi Padmarao,
This doc describes the procedure to build, flash and boot Linux using U-boot on Microchip MPFS Icicle Kit.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Anup Patel anup.patel@wdc.com
doc/board/index.rst | 1 + doc/board/microchip/index.rst | 9 + doc/board/microchip/mpfs_icicle.rst | 827 ++++++++++++++++++++++++++++ 3 files changed, 837 insertions(+) create mode 100644 doc/board/microchip/index.rst create mode 100644 doc/board/microchip/mpfs_icicle.rst
diff --git a/doc/board/index.rst b/doc/board/index.rst index 4b6a996eb1..e329e2744c 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -15,6 +15,7 @@ Board-specific doc freescale/index google/index intel/index
diff --git a/doc/board/microchip/index.rst
b/doc/board/microchip/index.rst
new file mode 100644 index 0000000000..b09e6788af --- /dev/null +++ b/doc/board/microchip/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Microchip +======
+.. toctree::
- :maxdepth: 2
- mpfs_icicle
diff --git a/doc/board/microchip/mpfs_icicle.rst
b/doc/board/microchip/mpfs_icicle.rst
new file mode 100644 index 0000000000..fb3f895ca3 --- /dev/null +++ b/doc/board/microchip/mpfs_icicle.rst @@ -0,0 +1,827 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Microchip PolarFire SoC Icicle Kit +==================================
+RISC-V PolarFire SoC +--------------------- +The PolarFire SoC is the 4+1 64-bit RISC-V SoC from Microchip.
+The Icicle Kit development platform is based on PolarFire SoC and
capable
+of running Linux.
+Mainline support +---------------- +The support for following drivers are already enabled:
+1. NS16550 UART Driver. +2. Microchip Clock Driver. +3. Cadence MACB ethernet driver for networking support. +4. Cadence MMC Driver for eMMC/SD support.
+Booting from eMMC using HSS +---------------------------
+Building U-Boot +---------------
+1. Add the RISC-V toolchain to your PATH. +2. Setup ARCH & cross compilation environment variable:
+3. make microchip_mpfs_icicle_defconfig +4. make
+Flashing +--------
+The current U-Boot port is supported in S-mode only and loaded from
DRAM.
+A prior stage M-mode firmware/bootloader (e.g HSS with OpenSBI) is
required to
+boot the u-boot.bin in S-mode.
+Currently, the u-boot.bin is used as a payload of the HSS
firmware(Microchip
+boot-flow) and OpenSBI generic platform fw_payload.bin (with u-boot.bin
embedded)
+as HSS payload(Custom boot-flow)
+Microchip boot-flow +------------------- +HSS with OpenSBI(M-Mode) -> U-Boot(S-Mode) -> Linux(S-Mode)
+Build the HSS((Hart Software Services) - Microchip boot-flow +------------------------------------------------------------ +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services)
+1. Configure
+Alternatively, copy the default config for Microchip boot-flow.
+2. make BOARD=icicle-kit-es +3. In the Default subdirectory, the standard build will create hss.elf
and
+The FPGA design will use the hss.hex or hss.bin.
+FPGA design with HSS programming file +-------------------------------------
+Creating the HSS payload - Microchip boot-flow +---------------------------------------------- +1. You will be creating a payload from `u-boot-dtb.bin`.
+2. Go to hss-payload-generator source directory.
+3. Edit test/uboot.yaml file for hart entry points and correct name of
the binary file.
u54_3: '0x80200000', u54_4: '0x80200000'}
payloads:
secondary-hart: u54_2, secondary-hart: u54_3,
secondary-hart: u54_4,
priv-mode: prv_s}
+4. Generate payload
+Once the payload binary is generated, it should be copied to the eMMC.
+Please refer to HSS documenation to build the HSS firmware for payload. +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services/blob/master +/tools/hss-payload-generator/README.md)
+Custom boot-flow +---------------- +HSS without OpenSBI(M-Mode) -> OpenSBI(M-Mode) -> U-Boot(S-Mode) ->
Linux(S-Mode)
+Build OpenSBI +-------------
+1. Get the OpenSBI source
- cd opensbi
+2. Build
+3. Output "fw_payload.bin" file available at
+Build the HSS((Hart Software Services)- Custom boot-flow +-------------------------------------------------------- +(Note: HSS git repo is at +https://github.com/polarfire-soc/hart-software-services)
+1. Configure
+Alternatively, copy the default custom config for Custom boot-flow.
and
+Creating the HSS payload - Custom boot-flow +------------------------------------------- +1. You will be creating a payload from `fw_payload.bin`.
the binary file.
u54_3: '0x80000000', u54_4: '0x80000000'}
payloads:
priv-mode: prv_m}
ok
+eMMC +---- +Program eMMC with payload binary is explained in the PolarFire SoC
documentation.
+Once the payload image is copied to the eMMC, press CTRL+C in the HSS
command
+line interface, then type 'boot' and enter to boot the newly copied
image.
eMMC if no
+GPT partition.
+Booting +------- +you should see the U-Boot prompt on UART0.
- CPU: rv64imafdc
- DRAM: 1 GiB
+Now you can configure your networking, tftp server and use tftp boot
method to
+load uImage(with initramfs).
- Loading:
6.4 MiB/s
- done
- Loading: #
2.5 MiB/s
- done
Image Name: Linux
0000000082205829
(64MB)
pages: 258055
free:off
Nodes=1
nr_cpu_ids=4.
nr_cpu_ids=4
contexts.
[0] hartid [1]
bytes, linear)
bytes, linear)
PFSOC core clocks
bytes, linear)
linear)
bytes, linear)
bucket_order=0
disabled
protection.
- Starting mdev...
- nt directory
chardev (251:0)
end of the disk.
directory
- done.
phy/sgmii link mode
registered.
- flow control tx
- deleting routers
- OK
- Password:
ok
CTRL+C
the newly
ok
eMMC if no
+GPT partition.
ok
- CPU: rv64imafdc
- DRAM: 1 GiB
- RISC-V # mmc info
- OEM: 100
- Name: DG400
- Rd Block Len: 512
- MMC version 5.1
- Capacity: 7.3 GiB
- Bus Width: 4-bit
- RISC-V # mmc part
Attributes
Type GUID
Partition GUID
configuration
Type: Kernel Image
OS: Linux
Hash algo: sha256
Hash value:
configuration
Hash algo: sha256
Hash value:
(64MB)
u69632
pages: 258055
free:off
Nodes=1
nr_cpu_ids=4.
nr_cpu_ids=4
contexts.
[0] hartid [1]
bytes, linear)
bytes, linear)
PFSOC core clocks
4096 bytes)
bytes, linear)
linear)
bytes, linear)
bucket_order=0
loaded (major 249)
registered 32 GPIOs
disabled
4294967288
Driver
Complete
active
active
active
active
chip channels: 25
chardev (247:0)
end of the disk.
readonly filesystem
during recovery
device 179:3.
protection.
clock.
read)
read)
read)
Directory Watch.
Pipe.
Socket.
Device...
System...
System.
ratelimiting
phy/sgmii link mode
registered.
ready
Hi Padmarao,
This patch set adds Microchip PolarFire SoC Icicle Kit support to RISC-V U-Boot.
The patches are based upon latest U-Boot tree (https://gitlab.denx.de/u-boot/u-boot.git) at commit id 7889951d0f56eab746a7c8fde350a022ba0361ca
All drivers namely: NS16550 Serial, Microchip clock, Cadence eMMC and Cadence MACB Ethernet work fine on actual Microchip PolarFire SoC Icicle Kit.
Changes in v4:
- Add dual-license GPL or MIT in the device tree
- Replace microsemi compatible strings with microchip
- Add MACB compatible string for Microchip PolarFire SoC ethernet
- Update MACB driver for 32-bit/64-bit DMA based on compatible string
Changes in v3:
- Add 'default y if 64BIT' for config DMA_ADDR_T_64BIT
- Update MACB driver for 32-bit/64-bit DMA based on design config register
- Add phy-handle in MACB driver to read the phy address from device tree
- Fix checkpatch warnings in the clock driver
- Remove fu540 related compatible strings from soc device tree node
- Move refclk device tree node under /soc device tree node
- Use local-mac-address instead of mac-address in the device tree
- Rename device tree to microchip-mpfs-icicle-kit.dts
- Add U-Boot specific dts microchip-mpfs-icicle-kit-u-boot.dtsi file
- Drop the imply DMA_ADDR_T_64BIT from board config
- Fix some typos
- Update doc with Microchip and Custom boot-flow
Changes in v2:
- Add clock frequency for the clint device tree node
- Move peripheral device tree nodes under /soc device tree node
- Device tree nodes are in order based on the address
- Enable UART0 for U-Boot logs
- Update doc for the U-Boot logs are on UART0
- Move clock and reset index source into patch4
- Remove "dma_addr_r" type in the macb driver
- Add lower_32_bits() for 32-bit address in the macb driver
- Add set_rate() returns the new clock rate in the clock driver
Padmarao Begari (7): riscv: Add DMA 64-bit address support net: macb: Add DMA 64-bit address support for macb net: macb: Add phy address to read it from device tree clk: Add Microchip PolarFire SoC clock driver riscv: dts: Add device tree for Microchip Icicle Kit riscv: Add Microchip MPFS Icicle Kit support doc: board: Add Microchip MPFS Icicle Kit doc
arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 1 + .../dts/microchip-mpfs-icicle-kit-u-boot.dtsi | 14 + arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 421 +++++++++ arch/riscv/include/asm/types.h | 4 + board/microchip/mpfs_icicle/Kconfig | 24 + board/microchip/mpfs_icicle/mpfs_icicle.c | 97 +- configs/microchip_mpfs_icicle_defconfig | 9 +- doc/board/index.rst | 1 + doc/board/microchip/index.rst | 9 + doc/board/microchip/mpfs_icicle.rst | 827 ++++++++++++++++++ drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/microchip/Kconfig | 5 + drivers/clk/microchip/Makefile | 1 + drivers/clk/microchip/clk_pfsoc.c | 127 +++ drivers/clk/microchip/clk_pfsoc.h | 19 + drivers/clk/microchip/clk_pfsoc_cfg.c | 134 +++ drivers/clk/microchip/clk_pfsoc_periph.c | 173 ++++ drivers/net/macb.c | 144 ++- drivers/net/macb.h | 6 + include/configs/microchip_mpfs_icicle.h | 60 +- .../dt-bindings/clock/microchip,pfsoc-clock.h | 45 + 23 files changed, 2065 insertions(+), 62 deletions(-) create mode 100644 arch/riscv/dts/microchip-mpfs-icicle-kit-u-boot.dtsi create mode 100644 arch/riscv/dts/microchip-mpfs-icicle-kit.dts create mode 100644 doc/board/microchip/index.rst create mode 100644 doc/board/microchip/mpfs_icicle.rst create mode 100644 drivers/clk/microchip/Kconfig create mode 100644 drivers/clk/microchip/Makefile create mode 100644 drivers/clk/microchip/clk_pfsoc.c create mode 100644 drivers/clk/microchip/clk_pfsoc.h create mode 100644 drivers/clk/microchip/clk_pfsoc_cfg.c create mode 100644 drivers/clk/microchip/clk_pfsoc_periph.c create mode 100644 include/dt-bindings/clock/microchip,pfsoc-clock.h
Can you please rename the files clk_pfsoc_* to mpfs_clk_*? I know this naming is inconsistent but we need to start somewhere. Also pfsoc-clock.h to mpfs-clock.h.
Regards,
Cyril.
Hi Cyril,
On Fri, Nov 27, 2020 at 9:47 PM Cyril.Jean@microchip.com wrote:
Hi Padmarao,
Changes in v4:
Changes in v3:
register
- Fix some typos
Changes in v2:
Ok
Regards Padmarao
Regards,
Cyril.
Bin Meng
Padmarao Begari
Padmarao Begari
