[U-Boot] [PATCH] ppc4xx: Fix default environment for AMCC boards
Commit 0ad7f0950a9bc0a69b3cd5f34ccf7da25fcf1c6d [ppc4xx: cleanup default environment for AMCC boards] broke the default env for many PPC4xx boards. The '\0' character got removed at the end of some environment commands like "update". This patch adds the missing '\0' characters again.
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/amcc-common.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index 9c53d37..333a4e4 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -282,13 +282,13 @@ "load=tftp 200000 ${u-boot}\0" \ "update=protect off " xstr(CONFIG_SYS_MONITOR_BASE) " FFFFFFFF;" \ "era " xstr(CONFIG_SYS_MONITOR_BASE) " FFFFFFFF;" \ - "cp.b ${fileaddr} " xstr(CONFIG_SYS_MONITOR_BASE) " ${filesize}" \ + "cp.b ${fileaddr} " xstr(CONFIG_SYS_MONITOR_BASE) " ${filesize}\0" \ "upd=run load update\0" \
#define CONFIG_AMCC_DEF_ENV_NAND_UPD \ "u-boot-nand=" xstr(CONFIG_HOSTNAME) "/u-boot-nand.bin\0" \ "nload=tftp 200000 ${u-boot-nand}\0" \ - "nupdate=nand erase 0 100000;nand write 200000 0 100000" \ + "nupdate=nand erase 0 100000;nand write 200000 0 100000\0" \ "nupd=run nload nupdate\0"
#endif /* __AMCC_COMMON_H */
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
