[U-Boot] [PATCH] imx8qxp: mek: enable dm-spl for pm
with u-boot,dm-spl added for imx8qx-pm node, and SPL_SIMPLE_BUS enabled, the bind and probe code in board file could be removed.
Also we need to enlarge SYS_MALLOC_F_LEN to avoid calloc fail.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi | 5 +++++ board/freescale/imx8qxp_mek/spl.c | 15 --------------- configs/imx8qxp_mek_defconfig | 2 +- 3 files changed, 6 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi index 5d50eb028e..201559008c 100644 --- a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi @@ -3,6 +3,11 @@ * Copyright 2018 NXP */
+&{/imx8qx-pm} { + + u-boot,dm-spl; +}; + &mu { u-boot,dm-spl; }; diff --git a/board/freescale/imx8qxp_mek/spl.c b/board/freescale/imx8qxp_mek/spl.c index 95ce9f37e8..51f323811a 100644 --- a/board/freescale/imx8qxp_mek/spl.c +++ b/board/freescale/imx8qxp_mek/spl.c @@ -27,21 +27,6 @@ void spl_board_init(void) continue; }
- offset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "nxp,imx8-pd"); - while (offset != -FDT_ERR_NOTFOUND) { - lists_bind_fdt(gd->dm_root, offset_to_ofnode(offset), - NULL, true); - offset = fdt_node_offset_by_compatible(gd->fdt_blob, offset, - "nxp,imx8-pd"); - } - - uclass_find_first_device(UCLASS_POWER_DOMAIN, &dev); - - for (; dev; uclass_find_next_device(&dev)) { - if (device_probe(dev)) - continue; - } - arch_cpu_init();
board_early_init_f(); diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index a94998b8b5..915d8812ad 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x80020000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_IMX8QXP_MEK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y
Hi Stefano,
Are you fine with this patch?
Thanks, Peng.
-----Original Message----- From: Peng Fan Sent: 2019年3月7日 20:44 To: sbabic@denx.de; festevam@gmail.com Cc: dl-uboot-imx uboot-imx@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com Subject: [PATCH] imx8qxp: mek: enable dm-spl for pm
- Copyright 2018 NXP
+&{/imx8qx-pm} {
- u-boot,dm-spl;
"nxp,imx8-pd");
NULL, true);
"nxp,imx8-pd");
continue;
arch_cpu_init();
diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index a94998b8b5..915d8812ad 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x80020000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_IMX8QXP_MEK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -- 2.16.4
Ping..
Thanks, Peng
Hi Stefano,
Thanks, Peng.
+&{/imx8qx-pm} {
- u-boot,dm-spl;
"nxp,imx8-pd");
NULL, true);
"nxp,imx8-pd");
continue;
arch_cpu_init();
with u-boot,dm-spl added for imx8qx-pm node, and SPL_SIMPLE_BUS enabled, the bind and probe code in board file could be removed. Also we need to enlarge SYS_MALLOC_F_LEN to avoid calloc fail. Signed-off-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan
sbabic@denx.de
