[U-Boot] [PATCH] ppc4xx: Move ppc4xx specific prototypes to ppc4xx header
This patch moves some 4xx specific prototypes out of include common.h to a ppc4xx specific header.
Signed-off-by: Stefan Roese sr@denx.de --- This patch is based on the u-boot-ppc4xx repository. It can't be applied directly to the master repository. It's needed to clean up some 4xx specific stuff that I missed in on of the ppc4xx SDRAM related patches. I didn't want to rebase my repository so this additional patch is needed.
board/netstal/hcu5/sdram.c | 2 +- include/asm-ppc/ppc4xx-sdram.h | 14 ++++++++++++++ include/common.h | 21 --------------------- 3 files changed, 15 insertions(+), 22 deletions(-)
diff --git a/board/netstal/hcu5/sdram.c b/board/netstal/hcu5/sdram.c index 66a958c..e5df62e 100644 --- a/board/netstal/hcu5/sdram.c +++ b/board/netstal/hcu5/sdram.c @@ -122,7 +122,7 @@ void sdram_panic(const char *reason) }
#ifdef CONFIG_DDR_ECC -static void blank_string(int size) +void blank_string(int size) { int i;
diff --git a/include/asm-ppc/ppc4xx-sdram.h b/include/asm-ppc/ppc4xx-sdram.h index a1ef029..8efa557 100644 --- a/include/asm-ppc/ppc4xx-sdram.h +++ b/include/asm-ppc/ppc4xx-sdram.h @@ -1402,4 +1402,18 @@
#endif /* CONFIG_SDRAM_PPC4xx_DENALI_DDR2 */
+#ifndef __ASSEMBLY__ +/* + * Prototypes + */ +void inline blank_string(int size); +inline void ppc4xx_ibm_ddr2_register_dump(void); +u32 mfdcr_any(u32); +void mtdcr_any(u32, u32); +u32 ddr_wrdtr(u32); +u32 ddr_clktr(u32); +void spd_ddr_init_hang(void); +u32 DQS_autocalibration(void); +#endif /* __ASSEMBLY__ */ + #endif /* _PPC4xx_SDRAM_H_ */ diff --git a/include/common.h b/include/common.h index 2516bfd..a394988 100644 --- a/include/common.h +++ b/include/common.h @@ -287,27 +287,6 @@ void pciinfo (int, int); #endif #endif
-/* - * Prototypes - */ -#if defined(CONFIG_SDRAM_PPC4xx_IBM_DDR2) -void blank_string(int); -inline void ppc4xx_ibm_ddr2_register_dump(void); -#if defined(CONFIG_440) -u32 mfdcr_any(u32); -void mtdcr_any(u32, u32); -#endif -#if defined(CONFIG_SPD_EEPROM) -u32 ddr_wrdtr(u32); -u32 ddr_clktr(u32); -void spd_ddr_init_hang(void); -#endif -#endif /* defined(CONFIG_SDRAM_PPC4xx_IBM_DDR2) */ - -#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) -u32 DQS_autocalibration(void); -#endif /* CONFIG_PPC4xx_DDR_AUTOCALIBRATION */ - int misc_init_f (void); int misc_init_r (void);
Stefan Roese
