u-boot leaves watchdog enabled by default
Hi Stefan,
it appears that since commit 06985289d45 ("watchdog: Implement generic watchdog_reset() version") - by default - the first watchdog is started unconditionally if CONFIG_WDT is set but never stopped before booting the operating system.
Shouldn't it also be stopped uncondionally? What's worse is that on one board/arch the watchdog is stopped in arch_preboot_os() which is never called in the bootefi case. So even if I'd do a workaround and stop it manually in my board code, I couldn't do that consistently for bootm/bootefi.
Or am I missing something here?
The SoC on my board has a built-in watchdog and I've noticed this behaviour when I was trying to install debian via its stock installer which doesn't have any driver support for it.
-michael
On Tue, Sep 15, 2020 at 12:56 PM Michael Walle michael@walle.cc wrote:
Hi Stefan,
Define CONFIG_WATCHDOG. This takes care of resetting wdt.
Best regards, Rayagonda
-michael
Am 2020-09-15 09:44, schrieb Rayagonda Kokatanur:
Hi Stefan,
Yes as along as you're inside the bootloader, but when u-boot hands control over the OS the watchdog is not serviced anymore; which wouldn't be a problem per se, but it is enabled unconditionally by u-boot.
-michael
Hi Stefan,
Just to add some data. At $dayjob we use this behaviour as a failsafe to make sure our userspace gets to a point where it is servicing the watchdog. That said having a leave-wdt-running environment variable would work for our use case.
Hi Michael, Hi Chris,
Am 2020-09-15 09:44, schrieb Rayagonda Kokatanur: > On Tue, Sep 15, 2020 at 12:56 PM Michael Walle <michael@walle.cc> > wrote: >> >> Hi Stefan, >> >> it appears that since commit 06985289d45 ("watchdog: Implement generic >> watchdog_reset() version") - by default - the first watchdog is >> started >> unconditionally if CONFIG_WDT is set but never stopped before booting >> the operating system. >> >> Shouldn't it also be stopped uncondionally? What's worse is that on >> one >> board/arch the watchdog is stopped in arch_preboot_os() which is never >> called in the bootefi case. So even if I'd do a workaround and stop it >> manually in my board code, I couldn't do that consistently for >> bootm/bootefi. >> >> Or am I missing something here? > > Define CONFIG_WATCHDOG. > This takes care of resetting wdt. Yes as along as you're inside the bootloader, but when u-boot hands control over the OS the watchdog is not serviced anymore; which wouldn't be a problem per se, but it is enabled unconditionally by u-boot.
Yes, this is exactly how this is supposed to work AFAIK.
Michael, are you sure that the watchdog was disabled in U-Boot when booting into the OS before this patch?
I would rather use it the other way around. Something like "wdt-stop- pre-os" to optionally stop the WDT before booting into the OS.
Remark: IMHO, if you don't use the WDT in the OS, it does not make much sense to enable the WDT in U-Boot.
Thanks, Stefan
Yes, we need to be very careful about making it so that a watchdog is disabled and not re-enabled before moving on for a whole bunch of reasons. And the best option would be to just disable the watchdog if it won't be used while the device is running the OS.
Which board are you referring to?
The requirement of the UEFI specification is that if booting fails a system should reset after five minutes by default. We ensure this in the UEFI sub-system before ExitBootServices() using an EFI timer event.
In the UEFI sub-system we currently call in ExitBootServices():
efi_set_watchdog(0); /* this disables the EFI timer */ WATCHDOG_RESET();
Is there any requirement to do more?
Best regards
Heinrich
For EFI or ? What I'm saying is that the watchdog must be left running and not stopped, if we either: - Came in to the world with the watchdog running AND were not specifically told to disable the watching. - Came in to the world and were told to enable a watchdog.
It's that first case with the AND I'm concerned with in general and this thread.
For the EFI case, I assume right now we aren't strictly adhering to the 5 minute rule, but I also assume there's some way for UEFI to tell us to call WATCHDOG_RESET() as needed.
Am 2020-09-21 20:50, schrieb Tom Rini:
See the commit above. It is board/alliedtelesis/x530/x530.c. It might not use EFI, but I tried to use it as a blueprint to disable the watchdog by default and then noticed it won't work in the bootefi case (and I guess the 'go' case).
My reason to start this thread was the fact that a watchdog is started by default in a generic way (i.e. initr_watchdog()) but there is _no_ way to disable it. I'm having a minimal board configuration and I want to be able to boot the debian-installer via EFI -> grub-efi -> d-i. The debian installer is not aware of any watchdog. Thus if u-boot leave it running, it might bite at very inconvenient times like half through the installation.
I'm fine with having a unified way to disable the watchdog per board, let it be a CONFIG_WDT_NO_START or a #define ENV "wdt-stop-pre-os", but it should work with bootm/booti/go/bootefi.
EFI timers seems to be unrelated to the watchdog, right?
-michael
Yes that's the in-tree board we have that uses this although it's for different reasons (HW related). It doesn't use EFI. We had to add code for that board to disable the watchdog pre-boot to maintain compatibility with an old userland. Had we been starting from fresh we would have just made sure that the userland was able to service the watchdog (which we are doing for newer boards).
-michael
Implement
watchdog is
before
is that on
which is
never
workaround and
consistently for
hands
which wouldn't
u-boot.
failsafe to
work for
our use case.
The UEFI spec requires a watchdog with 5 min default time that can be be manipulated via the UEFI API. To be independent of what the hardware offers I implemented it only relying on timer ticks and not actually using a hardware watchdog. Hence the current implementation does not interfere with hardware watchdogs.
Best regards
Heinrich
OK, but why is CONFIG_WDT enabled if you don't want to use the watchdog?
Am 2020-09-22 03:18, schrieb Tom Rini:
> >> called in the bootefi case. So even if I'd do a workaround and > stop it > >> manually in my board code, I couldn't do that consistently for > >> bootm/bootefi. > >> > >> Or am I missing something here? > > > > Define CONFIG_WATCHDOG. > > This takes care of resetting wdt. > > Yes as along as you're inside the bootloader, but when u-boot hands > control over the OS the watchdog is not serviced anymore; which wouldn't > be a problem per se, but it is enabled unconditionally by u-boot. > > > Just to add some data. At $dayjob we use this behaviour as a failsafe to > make sure our userspace gets to a point where it is servicing the > watchdog.
> That said having a leave-wdt-running environment variable would work for > our use case.
I guess we agree, that there are good reasons to have watchdog support in the bootloader (and even to keep in on before starting an OS). Think of tailored embedded operating systems for a specifc use case. In fact, for my board, the initial watchdog might even be enabled before u-boot and supervises the bootloader startup and switches to a failsafe image in case of an error. Thus, there is also a handy command "wdt expire 1" to restart into that image manually.
OTOH, I really want to support generic distributions which doesn't know anything about an already running watchdog.
Oh and I want the user to be able to install and boot a distribution without any change to the bootloader environment. Therefore, the default for this board has to be "watchdog disabled before booting OS". Like I said, I'm fine with having a #define ENV "disable-wdt-pre-os" in the board configuration.
-michael
>> >> called in the bootefi case. So even if I'd do a workaround and >> stop it >> >> manually in my board code, I couldn't do that consistently for >> >> bootm/bootefi. >> >> >> >> Or am I missing something here? >> > >> > Define CONFIG_WATCHDOG. >> > This takes care of resetting wdt. >> >> Yes as along as you're inside the bootloader, but when u-boot hands >> control over the OS the watchdog is not serviced anymore; which wouldn't >> be a problem per se, but it is enabled unconditionally by u-boot. >> >> >> Just to add some data. At $dayjob we use this behaviour as a failsafe to >> make sure our userspace gets to a point where it is servicing the >> watchdog. > > Yes, this is exactly how this is supposed to work AFAIK. > > Michael, are you sure that the watchdog was disabled in U-Boot when > booting into the OS before this patch? > >> That said having a leave-wdt-running environment variable would work for >> our use case. > > I would rather use it the other way around. Something like "wdt-stop- > pre-os" to optionally stop the WDT before booting into the OS. > > Remark: > IMHO, if you don't use the WDT in the OS, it does not make much sense > to enable the WDT in U-Boot.
The next question I have, and I didn't see a good answer to yet in a quick search is, how does this work out on x86 server hardware? Are you supposed to disable the watchdog before installing there too?
But all that said, since we have "wdt stop", perhaps you can find a place to put that in the boot script? Or just declare that if we get far enough to run preboot cmd then it's good enough, and update your call to "wdt expire 1" to be "wdt start && wdt expire 1" ?
Am 2020-09-22 14:36, schrieb Tom Rini:
>>> >> called in the bootefi case. So even if I'd do a workaround and >>> stop it >>> >> manually in my board code, I couldn't do that consistently for >>> >> bootm/bootefi. >>> >> >>> >> Or am I missing something here? >>> > >>> > Define CONFIG_WATCHDOG. >>> > This takes care of resetting wdt. >>> >>> Yes as along as you're inside the bootloader, but when u-boot hands >>> control over the OS the watchdog is not serviced anymore; which wouldn't >>> be a problem per se, but it is enabled unconditionally by u-boot. >>> >>> >>> Just to add some data. At $dayjob we use this behaviour as a failsafe to >>> make sure our userspace gets to a point where it is servicing the >>> watchdog. >> >> Yes, this is exactly how this is supposed to work AFAIK. >> >> Michael, are you sure that the watchdog was disabled in U-Boot when >> booting into the OS before this patch? >> >>> That said having a leave-wdt-running environment variable would work for >>> our use case. >> >> I would rather use it the other way around. Something like "wdt-stop- >> pre-os" to optionally stop the WDT before booting into the OS. >> >> Remark: >> IMHO, if you don't use the WDT in the OS, it does not make much sense >> to enable the WDT in U-Boot. > > Yes, we need to be very careful about making it so that a watchdog is > disabled and not re-enabled before moving on for a whole bunch of > reasons. And the best option would be to just disable the watchdog if > it won't be used while the device is running the OS. >
I can only guess here, but there seems to be no watchdog driver support at all (i.e. there are no wdt modules available).
"wdt expire 1" will automatically start the watchdog, won't it? Anyway, it was just an example why I need the CONFIG_WDT.
Just to get your opinion correct on this topic: you say as soon as the CONFIG_WDT is enabled u-boot will start it and never stop it, although CONFIG_WDT is just "Enable driver model watchdog timer drivers" and the help text is just about that, too.
IMHO it is wrong to enable the watchdog together with that option. There should be another one (even defaulting to 'yes') which tells u-boot whether it should be enabled by default.
config WDT_AUTOSTART boot "Start the (first) watchdog by default" default y help Upon u-boot startup the first watchdog will be started automatically. Be aware, that it will also kept enabled after the bootloader starts the operation system!
-michael
> >>> >> called in the bootefi case. So even if I'd do a workaround and > >>> stop it > >>> >> manually in my board code, I couldn't do that consistently for > >>> >> bootm/bootefi. > >>> >> > >>> >> Or am I missing something here? > >>> > > >>> > Define CONFIG_WATCHDOG. > >>> > This takes care of resetting wdt. > >>> > >>> Yes as along as you're inside the bootloader, but when u-boot hands > >>> control over the OS the watchdog is not serviced anymore; which wouldn't > >>> be a problem per se, but it is enabled unconditionally by u-boot. > >>> > >>> > >>> Just to add some data. At $dayjob we use this behaviour as a failsafe to > >>> make sure our userspace gets to a point where it is servicing the > >>> watchdog. > >> > >> Yes, this is exactly how this is supposed to work AFAIK. > >> > >> Michael, are you sure that the watchdog was disabled in U-Boot when > >> booting into the OS before this patch? > >> > >>> That said having a leave-wdt-running environment variable would work for > >>> our use case. > >> > >> I would rather use it the other way around. Something like "wdt-stop- > >> pre-os" to optionally stop the WDT before booting into the OS. > >> > >> Remark: > >> IMHO, if you don't use the WDT in the OS, it does not make much sense > >> to enable the WDT in U-Boot. > > > > Yes, we need to be very careful about making it so that a watchdog is > > disabled and not re-enabled before moving on for a whole bunch of > > reasons. And the best option would be to just disable the watchdog if > > it won't be used while the device is running the OS. > > > > The requirement of the UEFI specification is that if booting fails a > system should reset after five minutes by default. We ensure this in > the > UEFI sub-system before ExitBootServices() using an EFI timer event. > > In the UEFI sub-system we currently call in ExitBootServices(): > > efi_set_watchdog(0); /* this disables the EFI timer */ > WATCHDOG_RESET(); > > Is there any requirement to do more?
I really do wonder. Perhaps it's just some EFI service that's generally handled?
Right, OK. I'm just wondering if we can use the existing "wdt stop" functionality to cover what you're aiming for.
I will agree that the help text and symbols can use further cleaning up still. CONFIG_WDT implies in CONFIG_WATCHDOG which says:
This option enables U-Boot watchdog support where U-Boot is using watchdog_reset function to service watchdog device in U-Boot. Enable this option if you want to service enabled watchdog by U-Boot. Disable this option if you want U-Boot to start watchdog but never service it.
Which is what we've done (to the best of my knowledge) "forever".
Now, given what I said above looking at commit 06985289d452 ("watchdog: Implement generic watchdog_reset() version") is where we get the current behavior, symbol-wise. At this point, I'm not quite sure how best to do what you're looking for, or if we just have a bug in terms of which symbols are used. It sounds like you just want to stop the watchdog in U-Boot (outside of a specific start-and-trigger case) and let the OS decide if it's going to enable it. And if the OS is going to enable it and you want the watchdog started before OS boot, preboot could be set in the environment to "wdt start" to get it going again (and you enable CONFIG_USE_PREBOOT and set CONFIG_PREBOOT to an empty string, or wdt stop?). Or does that still not cover what you're trying to do?
Hi Tom,
Am 2020-09-22 16:41, schrieb Tom Rini:
See below.
Yes CONFIG_WATCHDOG is implied, but if you disable CONFIG_WATCHDOG it will still be started. Just not serviced.
Now, given what I said above looking at commit 06985289d452 ("watchdog: Implement generic watchdog_reset() version") is where we get the current behavior, symbol-wise. At this point, I'm not quite sure how best to do what you're looking for, or if we just have a bug in terms of which symbols are used. It sounds like you just want to stop the watchdog in U-Boot (outside of a specific start-and-trigger case) and let the OS decide if it's going to enable it. And if the OS is going to enable it and you want the watchdog started before OS boot, preboot could be setf in the environment to "wdt start" to get it going again (and you enable CONFIG_USE_PREBOOT and set CONFIG_PREBOOT to an empty string, or wdt stop?). Or does that still not cover what you're trying to do?
There are two things I want(ed) to achieve: (1) While booting the d-i I noticed my board does watchdog resets. So I digged into this and noticed that since the commit in question, any watchdog will be started unconditionally, which looked wrong to me and is a bit of a suprising behaviour. Esp. when you inherit the device trees from linux where the SoC watchdogs are usually enabled. Also I looked into how you could disable this behavior per-board. I didn't find a reliable method that worked for any boot command. Therefore, I've started this discussion, to find out if this is the intended behavior.
(2) To be able to boot an operating system with the boards default environment, that isn't aware of any watchdog.
For my specific use-case there are the following solutions so far: (a) stop the watchdog via "wdt stop" sometime (b) disable CONFIG_WDT (c) don't start the watchdog at all (d) have a runtime switch in the environment to stop it before booting the OS.
(a) and (b) is currently possible, (c) and (d) would need a patch. (b) is out of question for me, because I need the u-boot wdt commands. (a) sounds like a hack to me, why would you stop it even if I don't want it to be started in the first place. So I'd prefer (c).
I see that someone might prefer (d) as it gives the user the choice without having to recompile u-boot.
But apart from my use case, I could think of others and IMHO we should leave the choice up to the board user (and making it as easy as possible to configure it). So what do about the following:
choice prompt "Watchdog behaviour" default WDT_SUPERVISE_OS
config WDT_SUPERVISE_NOTHING boot "Supervise nothing" help No watchdog will be started.
config WDT_SUPERVISE_U_BOOT boot "Supervise u-boot" help Upon u-boot startup the first watchdog will be started automatically and stopped as soon as an operating system is booted.
config WDT_SUPERVISE_OS boot "Supervise u-boot and operating system" help Upon u-boot startup the first watchdog will be started automatically and kept running even after booting the operating system. Be aware, that the operating system needs to service the watchdog!
endchoice
-michael
On Tue, Sep 22, 2020 at 05:41:47PM +0200, Michael Walle wrote:
Hi Tom,
See below.
endchoice
Can you code this up as a patch please? I think that's likely the best path forward to covering all cases. Thanks.
Hi Stefan,
Am 2020-09-21 11:01, schrieb Stefan Roese:
michael@walle.cc > wrote: >> >> Hi Stefan, >> >> it appears that since commit 06985289d45 ("watchdog: Implement generic >> watchdog_reset() version") - by default - the first watchdog is >> started >> unconditionally if CONFIG_WDT is set but never stopped before booting >> the operating system. >> >> Shouldn't it also be stopped uncondionally? What's worse is that on >> one >> board/arch the watchdog is stopped in arch_preboot_os() which is never >> called in the bootefi case. So even if I'd do a workaround and stop it >> manually in my board code, I couldn't do that consistently for >> bootm/bootefi. >> >> Or am I missing something here? > > Define CONFIG_WATCHDOG. > This takes care of resetting wdt.
If I read the patch correctly, it was per board, wasn't it?
At the moment you end up with a watchdog enabled if you have (a) CONFIG_WDT set, (b) A watchdog defined in the device tree
And no way to stop it reliably (well you could use some kind of bootcmd, but I don't think that is the way to go).
I'm fine with either one. At least I can stop the watchdog reliably.
OTOH a configuration option to not start a watchdog in the first place, should still be a valid choice.
Keep in mind that my board is a "generic" module. I.e. there might be customers which may want to start a watchdog and there might be customers (that is also the debian-installer, for example) which doesn't want it or have no driver for it. This makes even more sense with EFI in place, which provides a universal boot method for any distribution/os (that might not be aware that a watchdog is running).
-michael
participants (6)
Chris Packham
Michael Walle
Rayagonda Kokatanur
Stefan Roese
