[U-Boot] [PATCH v6] arm: rmobile: Add support Renesas SH73A0
Renesas SH73A0 is CPU with Cortex-A9. This supports the basic register definition and GPIO.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V6: Changed Makefile that using config. Removed unnecessary ifdefs. V5: Remove dead code. V4: Revert ICCICR. V3: Set COBJS one object per line, and sort the list. Remove ICCICR and ICCPMR. Remove white space. v2: Remove white space. Code which can be communalized was moved to lowlevel_init.
arch/arm/cpu/armv7/rmobile/Makefile | 14 +- arch/arm/cpu/armv7/rmobile/board.c | 31 ++ arch/arm/cpu/armv7/rmobile/cpu_info-sh73a0.c | 48 ++ arch/arm/cpu/armv7/rmobile/cpu_info.c | 36 +- arch/arm/cpu/armv7/rmobile/lowlevel_init.S | 95 ++++ arch/arm/include/asm/arch-rmobile/rmobile.h | 4 + arch/arm/include/asm/arch-rmobile/sh73a0-gpio.h | 553 +++++++++++++++++++++++ arch/arm/include/asm/arch-rmobile/sh73a0.h | 281 ++++++++++++ arch/arm/include/asm/arch-rmobile/sys_proto.h | 29 ++ 9 files changed, 1067 insertions(+), 24 deletions(-) create mode 100644 arch/arm/cpu/armv7/rmobile/board.c create mode 100644 arch/arm/cpu/armv7/rmobile/cpu_info-sh73a0.c create mode 100644 arch/arm/cpu/armv7/rmobile/lowlevel_init.S create mode 100644 arch/arm/include/asm/arch-rmobile/sh73a0-gpio.h create mode 100644 arch/arm/include/asm/arch-rmobile/sh73a0.h create mode 100644 arch/arm/include/asm/arch-rmobile/sys_proto.h
diff --git a/arch/arm/cpu/armv7/rmobile/Makefile b/arch/arm/cpu/armv7/rmobile/Makefile index e7eb90f..77eca4b 100644 --- a/arch/arm/cpu/armv7/rmobile/Makefile +++ b/arch/arm/cpu/armv7/rmobile/Makefile @@ -25,11 +25,17 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).o
-COBJS += cpu_info.o -COBJS += timer.o +SOBJS = lowlevel_init.o +COBJS-y += cpu_info.o +COBJS-y += timer.o
-SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(COBJS-y)) +COBJS-$(CONFIG_DISPLAY_BOARDINFO) += board.o +COBJS-$(CONFIG_SH73A0) += cpu_info-sh73a0.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) START := $(addprefix $(obj),$(START))
all: $(obj).depend $(LIB) diff --git a/arch/arm/cpu/armv7/rmobile/board.c b/arch/arm/cpu/armv7/rmobile/board.c new file mode 100644 index 0000000..2622590 --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/board.c @@ -0,0 +1,31 @@ +/* + * (C) Copyright 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * (C) Copyright 2012 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> + +int checkboard(void) +{ + printf("Board: %s\n", sysinfo.board_string); + return 0; +} diff --git a/arch/arm/cpu/armv7/rmobile/cpu_info-sh73a0.c b/arch/arm/cpu/armv7/rmobile/cpu_info-sh73a0.c new file mode 100644 index 0000000..3086dd8 --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/cpu_info-sh73a0.c @@ -0,0 +1,48 @@ +/* + * (C) Copyright 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * (C) Copyright 2012 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/io.h> + +u32 rmobile_get_cpu_type(void) +{ + u32 id; + u32 type; + struct sh73a0_hpb *hpb = (struct sh73a0_hpb *)HPB_BASE; + + id = readl(hpb->cccr); + type = (id >> 8) & 0xFF; + + return type; +} + +u32 get_cpu_rev(void) +{ + u32 id; + u32 rev; + struct sh73a0_hpb *hpb = (struct sh73a0_hpb *)HPB_BASE; + + id = readl(hpb->cccr); + rev = (id >> 4) & 0xF; + + return rev; +} diff --git a/arch/arm/cpu/armv7/rmobile/cpu_info.c b/arch/arm/cpu/armv7/rmobile/cpu_info.c index 789c2c3..2148958 100644 --- a/arch/arm/cpu/armv7/rmobile/cpu_info.c +++ b/arch/arm/cpu/armv7/rmobile/cpu_info.c @@ -22,7 +22,6 @@ */ #include <common.h> #include <asm/io.h> -#include <asm/arch/rmobile.h>
#ifdef CONFIG_ARCH_CPU_INIT int arch_cpu_init(void) @@ -40,35 +39,32 @@ void enable_caches(void) #endif
#ifdef CONFIG_DISPLAY_CPUINFO -static u32 get_cpu_type(void) +static u32 __rmobile_get_cpu_type(void) { - u32 id; - u32 type; - - id = readl(CCCR); - type = (id >> 8) & 0xFF; - - return type; + return 0x0; } +u32 rmobile_get_cpu_type(void) + __attribute__((weak, alias("__rmobile_get_cpu_type")));
-static u32 get_cpu_rev(void) +static u32 __rmobile_get_cpu_rev(void) { - u32 id; - u32 rev; - - id = readl(CCCR); - rev = (id >> 4) & 0xF; - - return rev; + return 0; } +u32 rmobile_get_cpu_rev(void) + __attribute__((weak, alias("__rmobile_get_cpu_rev")));
int print_cpuinfo(void) { - switch (get_cpu_type()) { + switch (rmobile_get_cpu_type()) { + case 0x37: + printf("CPU: Renesas Electronics SH73A0 rev %d\n", + rmobile_get_cpu_rev()); + break; default: - printf("CPU: Renesas Electronics CPU rev %d\n", get_cpu_rev()); + printf("CPU: Renesas Electronics CPU rev %d\n", + get_cpu_rev()); break; } return 0; } -#endif +#endif /* CONFIG_DISPLAY_CPUINFO */ diff --git a/arch/arm/cpu/armv7/rmobile/lowlevel_init.S b/arch/arm/cpu/armv7/rmobile/lowlevel_init.S new file mode 100644 index 0000000..2cd410b --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/lowlevel_init.S @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.Iwamatsu.yj@renesas.com + * Copyright (C) 2012 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + ldr r0, =MERAM_BASE + mov r1, #0x0 + str r1, [r0] + + mrc p15, 0, r0, c0, c0, 5 + ands r0, r0, #0xF + beq lowlevel_init__ + b wait_interrupt + + .pool + .align 4 + +wait_interrupt: + ldr r1, =ICCICR + mov r2, #0x0 + str r2, [r1] + mov r2, #0xF0 + adds r1, r1, #4 /* ICCPMR */ + str r2, [r1] + ldr r1, =ICCICR + mov r2, #0x1 + str r2, [r1] + +wait_loop: + wfi + + ldr r2, [r1, #0xC] + str r2, [r1, #0x10] + + ldr r0, =MERAM_BASE + ldr r2, [r0] + cmp r2, #0 + movne pc, r2 + + b wait_loop + +wait_loop_end: + .pool + .align 4 + +lowlevel_init__: + + mov r0, #0x200000 + +loop0: + subs r0, r0, #1 + bne loop0 + + ldr sp, MERAM_STACK + + str ip, [sp] /* stash old link register */ + mov ip, lr /* save link reg across call */ + bl s_init + + ldr ip, [sp] /* restore save ip */ + mov lr, ip /* restore link reg */ + + /* back to arch calling code */ + mov pc, lr + + .pool + .align 4 + +ENDPROC(lowlevel_init) + .ltorg + +MERAM_STACK: + .word LOW_LEVEL_MERAM_STACK diff --git a/arch/arm/include/asm/arch-rmobile/rmobile.h b/arch/arm/include/asm/arch-rmobile/rmobile.h index bf5e22a..a3468e9 100644 --- a/arch/arm/include/asm/arch-rmobile/rmobile.h +++ b/arch/arm/include/asm/arch-rmobile/rmobile.h @@ -2,7 +2,11 @@ #define __ASM_ARCH_RMOBILE_H
#if defined(CONFIG_RMOBILE) +#if defined(CONFIG_SH73A0) +#include <asm/arch/sh73a0.h> +#else #error "SOC Name not defined" +#endif #endif /* CONFIG_RMOBILE */
#endif /* __ASM_ARCH_RMOBILE_H */ diff --git a/arch/arm/include/asm/arch-rmobile/sh73a0-gpio.h b/arch/arm/include/asm/arch-rmobile/sh73a0-gpio.h new file mode 100644 index 0000000..398e2c1 --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/sh73a0-gpio.h @@ -0,0 +1,553 @@ +#ifndef __ASM_SH73A0_H__ +#define __ASM_SH73A0_H__ + +/* Pin Function Controller: + * GPIO_FN_xx - GPIO used to select pin function and MSEL switch + * GPIO_PORTxx - GPIO mapped to real I/O pin on CPU + */ +enum { + /* Hardware manual Table 25-1 (GPIO) */ + GPIO_PORT0, GPIO_PORT1, GPIO_PORT2, GPIO_PORT3, GPIO_PORT4, + GPIO_PORT5, GPIO_PORT6, GPIO_PORT7, GPIO_PORT8, GPIO_PORT9, + + GPIO_PORT10, GPIO_PORT11, GPIO_PORT12, GPIO_PORT13, GPIO_PORT14, + GPIO_PORT15, GPIO_PORT16, GPIO_PORT17, GPIO_PORT18, GPIO_PORT19, + + GPIO_PORT20, GPIO_PORT21, GPIO_PORT22, GPIO_PORT23, GPIO_PORT24, + GPIO_PORT25, GPIO_PORT26, GPIO_PORT27, GPIO_PORT28, GPIO_PORT29, + + GPIO_PORT30, GPIO_PORT31, GPIO_PORT32, GPIO_PORT33, GPIO_PORT34, + GPIO_PORT35, GPIO_PORT36, GPIO_PORT37, GPIO_PORT38, GPIO_PORT39, + + GPIO_PORT40, GPIO_PORT41, GPIO_PORT42, GPIO_PORT43, GPIO_PORT44, + GPIO_PORT45, GPIO_PORT46, GPIO_PORT47, GPIO_PORT48, GPIO_PORT49, + + GPIO_PORT50, GPIO_PORT51, GPIO_PORT52, GPIO_PORT53, GPIO_PORT54, + GPIO_PORT55, GPIO_PORT56, GPIO_PORT57, GPIO_PORT58, GPIO_PORT59, + + GPIO_PORT60, GPIO_PORT61, GPIO_PORT62, GPIO_PORT63, GPIO_PORT64, + GPIO_PORT65, GPIO_PORT66, GPIO_PORT67, GPIO_PORT68, GPIO_PORT69, + + GPIO_PORT70, GPIO_PORT71, GPIO_PORT72, GPIO_PORT73, GPIO_PORT74, + GPIO_PORT75, GPIO_PORT76, GPIO_PORT77, GPIO_PORT78, GPIO_PORT79, + + GPIO_PORT80, GPIO_PORT81, GPIO_PORT82, GPIO_PORT83, GPIO_PORT84, + GPIO_PORT85, GPIO_PORT86, GPIO_PORT87, GPIO_PORT88, GPIO_PORT89, + + GPIO_PORT90, GPIO_PORT91, GPIO_PORT92, GPIO_PORT93, GPIO_PORT94, + GPIO_PORT95, GPIO_PORT96, GPIO_PORT97, GPIO_PORT98, GPIO_PORT99, + + GPIO_PORT100, GPIO_PORT101, GPIO_PORT102, GPIO_PORT103, GPIO_PORT104, + GPIO_PORT105, GPIO_PORT106, GPIO_PORT107, GPIO_PORT108, GPIO_PORT109, + + GPIO_PORT110, GPIO_PORT111, GPIO_PORT112, GPIO_PORT113, GPIO_PORT114, + GPIO_PORT115, GPIO_PORT116, GPIO_PORT117, GPIO_PORT118, + + GPIO_PORT128, GPIO_PORT129, + + GPIO_PORT130, GPIO_PORT131, GPIO_PORT132, GPIO_PORT133, GPIO_PORT134, + GPIO_PORT135, GPIO_PORT136, GPIO_PORT137, GPIO_PORT138, GPIO_PORT139, + + GPIO_PORT140, GPIO_PORT141, GPIO_PORT142, GPIO_PORT143, GPIO_PORT144, + GPIO_PORT145, GPIO_PORT146, GPIO_PORT147, GPIO_PORT148, GPIO_PORT149, + + GPIO_PORT150, GPIO_PORT151, GPIO_PORT152, GPIO_PORT153, GPIO_PORT154, + GPIO_PORT155, GPIO_PORT156, GPIO_PORT157, GPIO_PORT158, GPIO_PORT159, + + GPIO_PORT160, GPIO_PORT161, GPIO_PORT162, GPIO_PORT163, GPIO_PORT164, + + GPIO_PORT192, GPIO_PORT193, GPIO_PORT194, + GPIO_PORT195, GPIO_PORT196, GPIO_PORT197, GPIO_PORT198, GPIO_PORT199, + + GPIO_PORT200, GPIO_PORT201, GPIO_PORT202, GPIO_PORT203, GPIO_PORT204, + GPIO_PORT205, GPIO_PORT206, GPIO_PORT207, GPIO_PORT208, GPIO_PORT209, + + GPIO_PORT210, GPIO_PORT211, GPIO_PORT212, GPIO_PORT213, GPIO_PORT214, + GPIO_PORT215, GPIO_PORT216, GPIO_PORT217, GPIO_PORT218, GPIO_PORT219, + + GPIO_PORT220, GPIO_PORT221, GPIO_PORT222, GPIO_PORT223, GPIO_PORT224, + GPIO_PORT225, GPIO_PORT226, GPIO_PORT227, GPIO_PORT228, GPIO_PORT229, + + GPIO_PORT230, GPIO_PORT231, GPIO_PORT232, GPIO_PORT233, GPIO_PORT234, + GPIO_PORT235, GPIO_PORT236, GPIO_PORT237, GPIO_PORT238, GPIO_PORT239, + + GPIO_PORT240, GPIO_PORT241, GPIO_PORT242, GPIO_PORT243, GPIO_PORT244, + GPIO_PORT245, GPIO_PORT246, GPIO_PORT247, GPIO_PORT248, GPIO_PORT249, + + GPIO_PORT250, GPIO_PORT251, GPIO_PORT252, GPIO_PORT253, GPIO_PORT254, + GPIO_PORT255, GPIO_PORT256, GPIO_PORT257, GPIO_PORT258, GPIO_PORT259, + + GPIO_PORT260, GPIO_PORT261, GPIO_PORT262, GPIO_PORT263, GPIO_PORT264, + GPIO_PORT265, GPIO_PORT266, GPIO_PORT267, GPIO_PORT268, GPIO_PORT269, + + GPIO_PORT270, GPIO_PORT271, GPIO_PORT272, GPIO_PORT273, GPIO_PORT274, + GPIO_PORT275, GPIO_PORT276, GPIO_PORT277, GPIO_PORT278, GPIO_PORT279, + + GPIO_PORT280, GPIO_PORT281, GPIO_PORT282, + + GPIO_PORT288, GPIO_PORT289, + + GPIO_PORT290, GPIO_PORT291, GPIO_PORT292, GPIO_PORT293, GPIO_PORT294, + GPIO_PORT295, GPIO_PORT296, GPIO_PORT297, GPIO_PORT298, GPIO_PORT299, + + GPIO_PORT300, GPIO_PORT301, GPIO_PORT302, GPIO_PORT303, GPIO_PORT304, + GPIO_PORT305, GPIO_PORT306, GPIO_PORT307, GPIO_PORT308, GPIO_PORT309, + + /* Table 25-1 (Function 0-7) */ + GPIO_FN_VBUS_0, + GPIO_FN_GPI0, + GPIO_FN_GPI1, + GPIO_FN_GPI2, + GPIO_FN_GPI3, + GPIO_FN_GPI4, + GPIO_FN_GPI5, + GPIO_FN_GPI6, + GPIO_FN_GPI7, + GPIO_FN_SCIFA7_RXD, + GPIO_FN_SCIFA7_CTS_, + GPIO_FN_GPO7, GPIO_FN_MFG0_OUT2, + GPIO_FN_GPO6, GPIO_FN_MFG1_OUT2, + GPIO_FN_GPO5, GPIO_FN_SCIFA0_SCK, GPIO_FN_FSICOSLDT3, \ + GPIO_FN_PORT16_VIO_CKOR, + GPIO_FN_SCIFA0_TXD, + GPIO_FN_SCIFA7_TXD, + GPIO_FN_SCIFA7_RTS_, GPIO_FN_PORT19_VIO_CKO2, + GPIO_FN_GPO0, + GPIO_FN_GPO1, + GPIO_FN_GPO2, GPIO_FN_STATUS0, + GPIO_FN_GPO3, GPIO_FN_STATUS1, + GPIO_FN_GPO4, GPIO_FN_STATUS2, + GPIO_FN_VINT, + GPIO_FN_TCKON, + GPIO_FN_XDVFS1, GPIO_FN_PORT27_I2C_SCL2, GPIO_FN_PORT27_I2C_SCL3, \ + GPIO_FN_MFG0_OUT1, GPIO_FN_PORT27_IROUT, + GPIO_FN_XDVFS2, GPIO_FN_PORT28_I2C_SDA2, GPIO_FN_PORT28_I2C_SDA3, \ + GPIO_FN_PORT28_TPU1TO1, + GPIO_FN_SIM_RST, GPIO_FN_PORT29_TPU1TO1, + GPIO_FN_SIM_CLK, GPIO_FN_PORT30_VIO_CKOR, + GPIO_FN_SIM_D, GPIO_FN_PORT31_IROUT, + GPIO_FN_SCIFA4_TXD, + GPIO_FN_SCIFA4_RXD, GPIO_FN_XWUP, + GPIO_FN_SCIFA4_RTS_, + GPIO_FN_SCIFA4_CTS_, + GPIO_FN_FSIBOBT, GPIO_FN_FSIBIBT, + GPIO_FN_FSIBOLR, GPIO_FN_FSIBILR, + GPIO_FN_FSIBOSLD, + GPIO_FN_FSIBISLD, + GPIO_FN_VACK, + GPIO_FN_XTAL1L, + GPIO_FN_SCIFA0_RTS_, GPIO_FN_FSICOSLDT2, + GPIO_FN_SCIFA0_RXD, + GPIO_FN_SCIFA0_CTS_, GPIO_FN_FSICOSLDT1, + GPIO_FN_FSICOBT, GPIO_FN_FSICIBT, GPIO_FN_FSIDOBT, GPIO_FN_FSIDIBT, + GPIO_FN_FSICOLR, GPIO_FN_FSICILR, GPIO_FN_FSIDOLR, GPIO_FN_FSIDILR, + GPIO_FN_FSICOSLD, GPIO_FN_PORT47_FSICSPDIF, + GPIO_FN_FSICISLD, GPIO_FN_FSIDISLD, + GPIO_FN_FSIACK, GPIO_FN_PORT49_IRDA_OUT, GPIO_FN_PORT49_IROUT, \ + GPIO_FN_FSIAOMC, + GPIO_FN_FSIAOLR, GPIO_FN_BBIF2_TSYNC2, GPIO_FN_TPU2TO2, GPIO_FN_FSIAILR, + + GPIO_FN_FSIAOBT, GPIO_FN_BBIF2_TSCK2, GPIO_FN_TPU2TO3, GPIO_FN_FSIAIBT, + GPIO_FN_FSIAOSLD, GPIO_FN_BBIF2_TXD2, + GPIO_FN_FSIASPDIF, GPIO_FN_PORT53_IRDA_IN, GPIO_FN_TPU3TO3, \ + GPIO_FN_FSIBSPDIF, GPIO_FN_PORT53_FSICSPDIF, + GPIO_FN_FSIBCK, GPIO_FN_PORT54_IRDA_FIRSEL, GPIO_FN_TPU3TO2, \ + GPIO_FN_FSIBOMC, GPIO_FN_FSICCK, GPIO_FN_FSICOMC, + GPIO_FN_FSIAISLD, GPIO_FN_TPU0TO0, + GPIO_FN_A0, GPIO_FN_BS_, + GPIO_FN_A12, GPIO_FN_PORT58_KEYOUT7, GPIO_FN_TPU4TO2, + GPIO_FN_A13, GPIO_FN_PORT59_KEYOUT6, GPIO_FN_TPU0TO1, + GPIO_FN_A14, GPIO_FN_KEYOUT5, + GPIO_FN_A15, GPIO_FN_KEYOUT4, + GPIO_FN_A16, GPIO_FN_KEYOUT3, GPIO_FN_MSIOF0_SS1, + GPIO_FN_A17, GPIO_FN_KEYOUT2, GPIO_FN_MSIOF0_TSYNC, + GPIO_FN_A18, GPIO_FN_KEYOUT1, GPIO_FN_MSIOF0_TSCK, + GPIO_FN_A19, GPIO_FN_KEYOUT0, GPIO_FN_MSIOF0_TXD, + GPIO_FN_A20, GPIO_FN_KEYIN0, GPIO_FN_MSIOF0_RSCK, + GPIO_FN_A21, GPIO_FN_KEYIN1, GPIO_FN_MSIOF0_RSYNC, + GPIO_FN_A22, GPIO_FN_KEYIN2, GPIO_FN_MSIOF0_MCK0, + GPIO_FN_A23, GPIO_FN_KEYIN3, GPIO_FN_MSIOF0_MCK1, + GPIO_FN_A24, GPIO_FN_KEYIN4, GPIO_FN_MSIOF0_RXD, + GPIO_FN_A25, GPIO_FN_KEYIN5, GPIO_FN_MSIOF0_SS2, + GPIO_FN_A26, GPIO_FN_KEYIN6, + GPIO_FN_KEYIN7, + GPIO_FN_D0_NAF0, + GPIO_FN_D1_NAF1, + GPIO_FN_D2_NAF2, + GPIO_FN_D3_NAF3, + GPIO_FN_D4_NAF4, + GPIO_FN_D5_NAF5, + GPIO_FN_D6_NAF6, + GPIO_FN_D7_NAF7, + GPIO_FN_D8_NAF8, + GPIO_FN_D9_NAF9, + GPIO_FN_D10_NAF10, + GPIO_FN_D11_NAF11, + GPIO_FN_D12_NAF12, + GPIO_FN_D13_NAF13, + GPIO_FN_D14_NAF14, + GPIO_FN_D15_NAF15, + GPIO_FN_CS4_, + GPIO_FN_CS5A_, GPIO_FN_PORT91_RDWR, + GPIO_FN_CS5B_, GPIO_FN_FCE1_, + GPIO_FN_CS6B_, GPIO_FN_DACK0, + GPIO_FN_FCE0_, GPIO_FN_CS6A_, + GPIO_FN_WAIT_, GPIO_FN_DREQ0, + GPIO_FN_RD__FSC, + GPIO_FN_WE0__FWE, GPIO_FN_RDWR_FWE, + GPIO_FN_WE1_, + GPIO_FN_FRB, + GPIO_FN_CKO, + GPIO_FN_NBRSTOUT_, + GPIO_FN_NBRST_, + GPIO_FN_BBIF2_TXD, + GPIO_FN_BBIF2_RXD, + GPIO_FN_BBIF2_SYNC, + GPIO_FN_BBIF2_SCK, + GPIO_FN_SCIFA3_CTS_, GPIO_FN_MFG3_IN2, + GPIO_FN_SCIFA3_RXD, GPIO_FN_MFG3_IN1, + GPIO_FN_BBIF1_SS2, GPIO_FN_SCIFA3_RTS_, GPIO_FN_MFG3_OUT1, + GPIO_FN_SCIFA3_TXD, + GPIO_FN_HSI_RX_DATA, GPIO_FN_BBIF1_RXD, + GPIO_FN_HSI_TX_WAKE, GPIO_FN_BBIF1_TSCK, + GPIO_FN_HSI_TX_DATA, GPIO_FN_BBIF1_TSYNC, + GPIO_FN_HSI_TX_READY, GPIO_FN_BBIF1_TXD, + GPIO_FN_HSI_RX_READY, GPIO_FN_BBIF1_RSCK, GPIO_FN_PORT115_I2C_SCL2, \ + GPIO_FN_PORT115_I2C_SCL3, + GPIO_FN_HSI_RX_WAKE, GPIO_FN_BBIF1_RSYNC, GPIO_FN_PORT116_I2C_SDA2, \ + GPIO_FN_PORT116_I2C_SDA3, + GPIO_FN_HSI_RX_FLAG, GPIO_FN_BBIF1_SS1, GPIO_FN_BBIF1_FLOW, + GPIO_FN_HSI_TX_FLAG, + GPIO_FN_VIO_VD, GPIO_FN_PORT128_LCD2VSYN, GPIO_FN_VIO2_VD, \ + GPIO_FN_LCD2D0, + + GPIO_FN_VIO_HD, GPIO_FN_PORT129_LCD2HSYN, GPIO_FN_PORT129_LCD2CS_, \ + GPIO_FN_VIO2_HD, GPIO_FN_LCD2D1, + GPIO_FN_VIO_D0, GPIO_FN_PORT130_MSIOF2_RXD, GPIO_FN_LCD2D10, + GPIO_FN_VIO_D1, GPIO_FN_PORT131_KEYOUT6, GPIO_FN_PORT131_MSIOF2_SS1, \ + GPIO_FN_PORT131_KEYOUT11, GPIO_FN_LCD2D11, + GPIO_FN_VIO_D2, GPIO_FN_PORT132_KEYOUT7, GPIO_FN_PORT132_MSIOF2_SS2, \ + GPIO_FN_PORT132_KEYOUT10, GPIO_FN_LCD2D12, + GPIO_FN_VIO_D3, GPIO_FN_MSIOF2_TSYNC, GPIO_FN_LCD2D13, + GPIO_FN_VIO_D4, GPIO_FN_MSIOF2_TXD, GPIO_FN_LCD2D14, + GPIO_FN_VIO_D5, GPIO_FN_MSIOF2_TSCK, GPIO_FN_LCD2D15, + GPIO_FN_VIO_D6, GPIO_FN_PORT136_KEYOUT8, GPIO_FN_LCD2D16, + GPIO_FN_VIO_D7, GPIO_FN_PORT137_KEYOUT9, GPIO_FN_LCD2D17, + GPIO_FN_VIO_D8, GPIO_FN_PORT138_KEYOUT8, GPIO_FN_VIO2_D0, \ + GPIO_FN_LCD2D6, + GPIO_FN_VIO_D9, GPIO_FN_PORT139_KEYOUT9, GPIO_FN_VIO2_D1, \ + GPIO_FN_LCD2D7, + GPIO_FN_VIO_D10, GPIO_FN_TPU0TO2, GPIO_FN_VIO2_D2, GPIO_FN_LCD2D8, + GPIO_FN_VIO_D11, GPIO_FN_TPU0TO3, GPIO_FN_VIO2_D3, GPIO_FN_LCD2D9, + GPIO_FN_VIO_D12, GPIO_FN_PORT142_KEYOUT10, GPIO_FN_VIO2_D4, \ + GPIO_FN_LCD2D2, + GPIO_FN_VIO_D13, GPIO_FN_PORT143_KEYOUT11, GPIO_FN_PORT143_KEYOUT6, \ + GPIO_FN_VIO2_D5, GPIO_FN_LCD2D3, + GPIO_FN_VIO_D14, GPIO_FN_PORT144_KEYOUT7, GPIO_FN_VIO2_D6, \ + GPIO_FN_LCD2D4, + GPIO_FN_VIO_D15, GPIO_FN_TPU1TO3, GPIO_FN_PORT145_LCD2DISP, \ + GPIO_FN_PORT145_LCD2RS, GPIO_FN_VIO2_D7, GPIO_FN_LCD2D5, + GPIO_FN_VIO_CLK, GPIO_FN_LCD2DCK, GPIO_FN_PORT146_LCD2WR_, \ + GPIO_FN_VIO2_CLK, GPIO_FN_LCD2D18, + GPIO_FN_VIO_FIELD, GPIO_FN_LCD2RD_, GPIO_FN_VIO2_FIELD, GPIO_FN_LCD2D19, + GPIO_FN_VIO_CKO, + GPIO_FN_A27, GPIO_FN_PORT149_RDWR, GPIO_FN_MFG0_IN1, \ + GPIO_FN_PORT149_KEYOUT9, + GPIO_FN_MFG0_IN2, + GPIO_FN_TS_SPSYNC3, GPIO_FN_MSIOF2_RSCK, + GPIO_FN_TS_SDAT3, GPIO_FN_MSIOF2_RSYNC, + GPIO_FN_TPU1TO2, GPIO_FN_TS_SDEN3, GPIO_FN_PORT153_MSIOF2_SS1, + GPIO_FN_SCIFA2_TXD1, GPIO_FN_MSIOF2_MCK0, + GPIO_FN_SCIFA2_RXD1, GPIO_FN_MSIOF2_MCK1, + GPIO_FN_SCIFA2_RTS1_, GPIO_FN_PORT156_MSIOF2_SS2, + GPIO_FN_SCIFA2_CTS1_, GPIO_FN_PORT157_MSIOF2_RXD, + GPIO_FN_DINT_, GPIO_FN_SCIFA2_SCK1, GPIO_FN_TS_SCK3, + GPIO_FN_PORT159_SCIFB_SCK, GPIO_FN_PORT159_SCIFA5_SCK, GPIO_FN_NMI, + GPIO_FN_PORT160_SCIFB_TXD, GPIO_FN_PORT160_SCIFA5_TXD, + GPIO_FN_PORT161_SCIFB_CTS_, GPIO_FN_PORT161_SCIFA5_CTS_, + GPIO_FN_PORT162_SCIFB_RXD, GPIO_FN_PORT162_SCIFA5_RXD, + GPIO_FN_PORT163_SCIFB_RTS_, GPIO_FN_PORT163_SCIFA5_RTS_, \ + GPIO_FN_TPU3TO0, + GPIO_FN_LCDD0, + GPIO_FN_LCDD1, GPIO_FN_PORT193_SCIFA5_CTS_, GPIO_FN_BBIF2_TSYNC1, + GPIO_FN_LCDD2, GPIO_FN_PORT194_SCIFA5_RTS_, GPIO_FN_BBIF2_TSCK1, + GPIO_FN_LCDD3, GPIO_FN_PORT195_SCIFA5_RXD, GPIO_FN_BBIF2_TXD1, + GPIO_FN_LCDD4, GPIO_FN_PORT196_SCIFA5_TXD, + GPIO_FN_LCDD5, GPIO_FN_PORT197_SCIFA5_SCK, GPIO_FN_MFG2_OUT2, \ + GPIO_FN_TPU2TO1, + GPIO_FN_LCDD6, + GPIO_FN_LCDD7, GPIO_FN_TPU4TO1, GPIO_FN_MFG4_OUT2, + GPIO_FN_LCDD8, GPIO_FN_D16, + GPIO_FN_LCDD9, GPIO_FN_D17, + GPIO_FN_LCDD10, GPIO_FN_D18, + GPIO_FN_LCDD11, GPIO_FN_D19, + GPIO_FN_LCDD12, GPIO_FN_D20, + GPIO_FN_LCDD13, GPIO_FN_D21, + GPIO_FN_LCDD14, GPIO_FN_D22, + GPIO_FN_LCDD15, GPIO_FN_PORT207_MSIOF0L_SS1, GPIO_FN_D23, + GPIO_FN_LCDD16, GPIO_FN_PORT208_MSIOF0L_SS2, GPIO_FN_D24, + GPIO_FN_LCDD17, GPIO_FN_D25, + GPIO_FN_LCDD18, GPIO_FN_DREQ2, GPIO_FN_PORT210_MSIOF0L_SS1, GPIO_FN_D26, + GPIO_FN_LCDD19, GPIO_FN_PORT211_MSIOF0L_SS2, GPIO_FN_D27, + GPIO_FN_LCDD20, GPIO_FN_TS_SPSYNC1, GPIO_FN_MSIOF0L_MCK0, GPIO_FN_D28, + GPIO_FN_LCDD21, GPIO_FN_TS_SDAT1, GPIO_FN_MSIOF0L_MCK1, GPIO_FN_D29, + GPIO_FN_LCDD22, GPIO_FN_TS_SDEN1, GPIO_FN_MSIOF0L_RSCK, GPIO_FN_D30, + GPIO_FN_LCDD23, GPIO_FN_TS_SCK1, GPIO_FN_MSIOF0L_RSYNC, GPIO_FN_D31, + GPIO_FN_LCDDCK, GPIO_FN_LCDWR_, + GPIO_FN_LCDRD_, GPIO_FN_DACK2, GPIO_FN_PORT217_LCD2RS, \ + GPIO_FN_MSIOF0L_TSYNC, GPIO_FN_VIO2_FIELD3, GPIO_FN_PORT217_LCD2DISP, + GPIO_FN_LCDHSYN, GPIO_FN_LCDCS_, GPIO_FN_LCDCS2_, GPIO_FN_DACK3, \ + GPIO_FN_PORT218_VIO_CKOR, + GPIO_FN_LCDDISP, GPIO_FN_LCDRS, GPIO_FN_PORT219_LCD2WR_, \ + GPIO_FN_DREQ3, GPIO_FN_MSIOF0L_TSCK, GPIO_FN_VIO2_CLK3, \ + GPIO_FN_LCD2DCK_2, + GPIO_FN_LCDVSYN, GPIO_FN_LCDVSYN2, + GPIO_FN_LCDLCLK, GPIO_FN_DREQ1, GPIO_FN_PORT221_LCD2CS_, \ + GPIO_FN_PWEN, GPIO_FN_MSIOF0L_RXD, GPIO_FN_VIO2_HD3, \ + GPIO_FN_PORT221_LCD2HSYN, + GPIO_FN_LCDDON, GPIO_FN_LCDDON2, GPIO_FN_DACK1, GPIO_FN_OVCN, \ + GPIO_FN_MSIOF0L_TXD, GPIO_FN_VIO2_VD3, GPIO_FN_PORT222_LCD2VSYN, + + GPIO_FN_SCIFA1_TXD, GPIO_FN_OVCN2, + GPIO_FN_EXTLP, GPIO_FN_SCIFA1_SCK, GPIO_FN_PORT226_VIO_CKO2, + GPIO_FN_SCIFA1_RTS_, GPIO_FN_IDIN, + GPIO_FN_SCIFA1_RXD, + GPIO_FN_SCIFA1_CTS_, GPIO_FN_MFG1_IN1, + GPIO_FN_MSIOF1_TXD, GPIO_FN_SCIFA2_TXD2, + GPIO_FN_MSIOF1_TSYNC, GPIO_FN_SCIFA2_CTS2_, + GPIO_FN_MSIOF1_TSCK, GPIO_FN_SCIFA2_SCK2, + GPIO_FN_MSIOF1_RXD, GPIO_FN_SCIFA2_RXD2, + GPIO_FN_MSIOF1_RSCK, GPIO_FN_SCIFA2_RTS2_, GPIO_FN_VIO2_CLK2, \ + GPIO_FN_LCD2D20, + GPIO_FN_MSIOF1_RSYNC, GPIO_FN_MFG1_IN2, GPIO_FN_VIO2_VD2, \ + GPIO_FN_LCD2D21, + GPIO_FN_MSIOF1_MCK0, GPIO_FN_PORT236_I2C_SDA2, + GPIO_FN_MSIOF1_MCK1, GPIO_FN_PORT237_I2C_SCL2, + GPIO_FN_MSIOF1_SS1, GPIO_FN_VIO2_FIELD2, GPIO_FN_LCD2D22, + GPIO_FN_MSIOF1_SS2, GPIO_FN_VIO2_HD2, GPIO_FN_LCD2D23, + GPIO_FN_SCIFA6_TXD, + GPIO_FN_PORT241_IRDA_OUT, GPIO_FN_PORT241_IROUT, GPIO_FN_MFG4_OUT1, \ + GPIO_FN_TPU4TO0, + GPIO_FN_PORT242_IRDA_IN, GPIO_FN_MFG4_IN2, + GPIO_FN_PORT243_IRDA_FIRSEL, GPIO_FN_PORT243_VIO_CKO2, + GPIO_FN_PORT244_SCIFA5_CTS_, GPIO_FN_MFG2_IN1, \ + GPIO_FN_PORT244_SCIFB_CTS_, GPIO_FN_MSIOF2R_RXD, + GPIO_FN_PORT245_SCIFA5_RTS_, GPIO_FN_MFG2_IN2, \ + GPIO_FN_PORT245_SCIFB_RTS_, GPIO_FN_MSIOF2R_TXD, + GPIO_FN_PORT246_SCIFA5_RXD, GPIO_FN_MFG1_OUT1, \ + GPIO_FN_PORT246_SCIFB_RXD, GPIO_FN_TPU1TO0, + GPIO_FN_PORT247_SCIFA5_TXD, GPIO_FN_MFG3_OUT2, \ + GPIO_FN_PORT247_SCIFB_TXD, GPIO_FN_TPU3TO1, + GPIO_FN_PORT248_SCIFA5_SCK, GPIO_FN_MFG2_OUT1, \ + GPIO_FN_PORT248_SCIFB_SCK, GPIO_FN_TPU2TO0, \ + GPIO_FN_PORT248_I2C_SCL3, GPIO_FN_MSIOF2R_TSCK, + GPIO_FN_PORT249_IROUT, GPIO_FN_MFG4_IN1, \ + GPIO_FN_PORT249_I2C_SDA3, GPIO_FN_MSIOF2R_TSYNC, + GPIO_FN_SDHICLK0, + GPIO_FN_SDHICD0, + GPIO_FN_SDHID0_0, + GPIO_FN_SDHID0_1, + GPIO_FN_SDHID0_2, + GPIO_FN_SDHID0_3, + GPIO_FN_SDHICMD0, + GPIO_FN_SDHIWP0, + GPIO_FN_SDHICLK1, + GPIO_FN_SDHID1_0, GPIO_FN_TS_SPSYNC2, + GPIO_FN_SDHID1_1, GPIO_FN_TS_SDAT2, + GPIO_FN_SDHID1_2, GPIO_FN_TS_SDEN2, + GPIO_FN_SDHID1_3, GPIO_FN_TS_SCK2, + GPIO_FN_SDHICMD1, + GPIO_FN_SDHICLK2, + GPIO_FN_SDHID2_0, GPIO_FN_TS_SPSYNC4, + GPIO_FN_SDHID2_1, GPIO_FN_TS_SDAT4, + GPIO_FN_SDHID2_2, GPIO_FN_TS_SDEN4, + GPIO_FN_SDHID2_3, GPIO_FN_TS_SCK4, + GPIO_FN_SDHICMD2, + GPIO_FN_MMCCLK0, + GPIO_FN_MMCD0_0, + GPIO_FN_MMCD0_1, + GPIO_FN_MMCD0_2, + GPIO_FN_MMCD0_3, + GPIO_FN_MMCD0_4, GPIO_FN_TS_SPSYNC5, + GPIO_FN_MMCD0_5, GPIO_FN_TS_SDAT5, + GPIO_FN_MMCD0_6, GPIO_FN_TS_SDEN5, + GPIO_FN_MMCD0_7, GPIO_FN_TS_SCK5, + GPIO_FN_MMCCMD0, + GPIO_FN_RESETOUTS_, GPIO_FN_EXTAL2OUT, + GPIO_FN_MCP_WAIT__MCP_FRB, + GPIO_FN_MCP_CKO, GPIO_FN_MMCCLK1, + GPIO_FN_MCP_D15_MCP_NAF15, + GPIO_FN_MCP_D14_MCP_NAF14, + GPIO_FN_MCP_D13_MCP_NAF13, + GPIO_FN_MCP_D12_MCP_NAF12, + GPIO_FN_MCP_D11_MCP_NAF11, + GPIO_FN_MCP_D10_MCP_NAF10, + GPIO_FN_MCP_D9_MCP_NAF9, + GPIO_FN_MCP_D8_MCP_NAF8, GPIO_FN_MMCCMD1, + GPIO_FN_MCP_D7_MCP_NAF7, GPIO_FN_MMCD1_7, + + GPIO_FN_MCP_D6_MCP_NAF6, GPIO_FN_MMCD1_6, + GPIO_FN_MCP_D5_MCP_NAF5, GPIO_FN_MMCD1_5, + GPIO_FN_MCP_D4_MCP_NAF4, GPIO_FN_MMCD1_4, + GPIO_FN_MCP_D3_MCP_NAF3, GPIO_FN_MMCD1_3, + GPIO_FN_MCP_D2_MCP_NAF2, GPIO_FN_MMCD1_2, + GPIO_FN_MCP_D1_MCP_NAF1, GPIO_FN_MMCD1_1, + GPIO_FN_MCP_D0_MCP_NAF0, GPIO_FN_MMCD1_0, + GPIO_FN_MCP_NBRSTOUT_, + GPIO_FN_MCP_WE0__MCP_FWE, GPIO_FN_MCP_RDWR_MCP_FWE, + + /* MSEL2 special case */ + GPIO_FN_TSIF2_TS_XX1, + GPIO_FN_TSIF2_TS_XX2, + GPIO_FN_TSIF2_TS_XX3, + GPIO_FN_TSIF2_TS_XX4, + GPIO_FN_TSIF2_TS_XX5, + GPIO_FN_TSIF1_TS_XX1, + GPIO_FN_TSIF1_TS_XX2, + GPIO_FN_TSIF1_TS_XX3, + GPIO_FN_TSIF1_TS_XX4, + GPIO_FN_TSIF1_TS_XX5, + GPIO_FN_TSIF0_TS_XX1, + GPIO_FN_TSIF0_TS_XX2, + GPIO_FN_TSIF0_TS_XX3, + GPIO_FN_TSIF0_TS_XX4, + GPIO_FN_TSIF0_TS_XX5, + GPIO_FN_MST1_TS_XX1, + GPIO_FN_MST1_TS_XX2, + GPIO_FN_MST1_TS_XX3, + GPIO_FN_MST1_TS_XX4, + GPIO_FN_MST1_TS_XX5, + GPIO_FN_MST0_TS_XX1, + GPIO_FN_MST0_TS_XX2, + GPIO_FN_MST0_TS_XX3, + GPIO_FN_MST0_TS_XX4, + GPIO_FN_MST0_TS_XX5, + + /* MSEL3 special cases */ + GPIO_FN_SDHI0_VCCQ_MC0_ON, + GPIO_FN_SDHI0_VCCQ_MC0_OFF, + GPIO_FN_DEBUG_MON_VIO, + GPIO_FN_DEBUG_MON_LCDD, + GPIO_FN_LCDC_LCDC0, + GPIO_FN_LCDC_LCDC1, + + /* MSEL4 special cases */ + GPIO_FN_IRQ9_MEM_INT, + GPIO_FN_IRQ9_MCP_INT, + GPIO_FN_A11, + GPIO_FN_KEYOUT8, + GPIO_FN_TPU4TO3, + GPIO_FN_RESETA_N_PU_ON, + GPIO_FN_RESETA_N_PU_OFF, + GPIO_FN_EDBGREQ_PD, + GPIO_FN_EDBGREQ_PU, + + /* Functions with pull-ups */ + GPIO_FN_KEYIN0_PU, + GPIO_FN_KEYIN1_PU, + GPIO_FN_KEYIN2_PU, + GPIO_FN_KEYIN3_PU, + GPIO_FN_KEYIN4_PU, + GPIO_FN_KEYIN5_PU, + GPIO_FN_KEYIN6_PU, + GPIO_FN_KEYIN7_PU, + GPIO_FN_SDHICD0_PU, + GPIO_FN_SDHID0_0_PU, + GPIO_FN_SDHID0_1_PU, + GPIO_FN_SDHID0_2_PU, + GPIO_FN_SDHID0_3_PU, + GPIO_FN_SDHICMD0_PU, + GPIO_FN_SDHIWP0_PU, + GPIO_FN_SDHID1_0_PU, + GPIO_FN_SDHID1_1_PU, + GPIO_FN_SDHID1_2_PU, + GPIO_FN_SDHID1_3_PU, + GPIO_FN_SDHICMD1_PU, + GPIO_FN_SDHID2_0_PU, + GPIO_FN_SDHID2_1_PU, + GPIO_FN_SDHID2_2_PU, + GPIO_FN_SDHID2_3_PU, + GPIO_FN_SDHICMD2_PU, + GPIO_FN_MMCCMD0_PU, + GPIO_FN_MMCCMD1_PU, + GPIO_FN_MMCD0_0_PU, + GPIO_FN_MMCD0_1_PU, + GPIO_FN_MMCD0_2_PU, + GPIO_FN_MMCD0_3_PU, + GPIO_FN_MMCD0_4_PU, + GPIO_FN_MMCD0_5_PU, + GPIO_FN_MMCD0_6_PU, + GPIO_FN_MMCD0_7_PU, + GPIO_FN_FSIACK_PU, + GPIO_FN_FSIAILR_PU, + GPIO_FN_FSIAIBT_PU, + GPIO_FN_FSIAISLD_PU, + + /* end of GPIO */ + GPIO_NR, +}; + +/* DMA slave IDs */ +enum { + SHDMA_SLAVE_INVALID, + SHDMA_SLAVE_SCIF0_TX, + SHDMA_SLAVE_SCIF0_RX, + SHDMA_SLAVE_SCIF1_TX, + SHDMA_SLAVE_SCIF1_RX, + SHDMA_SLAVE_SCIF2_TX, + SHDMA_SLAVE_SCIF2_RX, + SHDMA_SLAVE_SCIF3_TX, + SHDMA_SLAVE_SCIF3_RX, + SHDMA_SLAVE_SCIF4_TX, + SHDMA_SLAVE_SCIF4_RX, + SHDMA_SLAVE_SCIF5_TX, + SHDMA_SLAVE_SCIF5_RX, + SHDMA_SLAVE_SCIF6_TX, + SHDMA_SLAVE_SCIF6_RX, + SHDMA_SLAVE_SCIF7_TX, + SHDMA_SLAVE_SCIF7_RX, + SHDMA_SLAVE_SCIF8_TX, + SHDMA_SLAVE_SCIF8_RX, + SHDMA_SLAVE_SDHI0_TX, + SHDMA_SLAVE_SDHI0_RX, + SHDMA_SLAVE_SDHI1_TX, + SHDMA_SLAVE_SDHI1_RX, + SHDMA_SLAVE_SDHI2_TX, + SHDMA_SLAVE_SDHI2_RX, + SHDMA_SLAVE_MMCIF_TX, + SHDMA_SLAVE_MMCIF_RX, +}; + +/* + * SH73A0 IRQ LOCATION TABLE + * + * 416 ----------------------------------------- + * IRQ0-IRQ15 + * 431 ----------------------------------------- + * ... + * 448 ----------------------------------------- + * sh73a0-intcs + * sh73a0-intca-irq-pins + * 680 ----------------------------------------- + * ... + * 700 ----------------------------------------- + * sh73a0-pint0 + * 731 ----------------------------------------- + * 732 ----------------------------------------- + * sh73a0-pint1 + * 739 ----------------------------------------- + * ... + * 800 ----------------------------------------- + * IRQ16-IRQ31 + * 815 ----------------------------------------- + * ... + * 928 ----------------------------------------- + * sh73a0-intca-irq-pins + * 943 ----------------------------------------- + */ + +/* PINT interrupts are located at Linux IRQ 700 and up */ +#define SH73A0_PINT0_IRQ(irq) ((irq) + 700) +#define SH73A0_PINT1_IRQ(irq) ((irq) + 732) + +#endif /* __ASM_SH73A0_H__ */ diff --git a/arch/arm/include/asm/arch-rmobile/sh73a0.h b/arch/arm/include/asm/arch-rmobile/sh73a0.h new file mode 100644 index 0000000..c33bf21 --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/sh73a0.h @@ -0,0 +1,281 @@ +#ifndef __ASM_ARCH_RMOBILE_SH73A0_H +#define __ASM_ARCH_RMOBILE_SH73A0_H + +/* Global Timer */ +#define GLOBAL_TIMER_BASE_ADDR (0xF0000200) +#define MERAM_BASE (0xE5580000) + +/* GIC */ +#define GIC_BASE (0xF0000100) +#define ICCICR GIC_BASE + +/* Secure control register */ +#define LIFEC_SEC_SRC (0xE6110008) + +/* RWDT */ +#define RWDT_BASE (0xE6020000) + +/* HPB Semaphore Control Registers */ +#define HPB_BASE (0xE6001010) + +/* Bus Semaphore Control Registers */ +#define HPBSCR_BASE (0xE6001600) + +/* SBSC1 */ +#define SBSC1_BASE (0xFE400000) +#define SDMRA1A (SBSC1_BASE + 0x100000) +#define SDMRA2A (SBSC1_BASE + 0x1C0000) +#define SDMRA3A (SBSC1_BASE + 0x104000) + +/* SBSC2 */ +#define SBSC2_BASE (0xFB400000) +#define SDMRA1B (SBSC2_BASE + 0x100000) +#define SDMRA2B (SBSC2_BASE + 0x1C0000) +#define SDMRA3B (SBSC2_BASE + 0x104000) + +/* CPG */ +#define CPG_BASE (0xE6150000) +#define CPG_SRCR_BASE (CPG_BASE + 0x80A0) +#define WUPCR (CPG_BASE + 0x1010) +#define SRESCR (CPG_BASE + 0x1018) +#define PCLKCR (CPG_BASE + 0x1020) + +/* BSC */ +#define BSC_BASE (0xFEC10000) + +/* SCIF */ +#define SCIF0_BASE (0xE6C40000) +#define SCIF1_BASE (0xE6C50000) +#define SCIF2_BASE (0xE6C60000) +#define SCIF3_BASE (0xE6C70000) +#define SCIF4_BASE (0xE6C80000) +#define SCIF5_BASE (0xE6CB0000) +#define SCIF6_BASE (0xE6CC0000) +#define SCIF7_BASE (0xE6CD0000) + +#ifndef __ASSEMBLY__ +#include <asm/types.h> + +/* RWDT */ +struct sh73a0_rwdt { + u16 rwtcnt0; /* 0x00 */ + u16 rwtcsra0; /* 0x04 */ + u16 rwtcsrb0; /* 0x08 */ +}; + +/* HPB Semaphore Control Registers */ +struct sh73a0_hpb { + u32 hpbctrl0; + u32 hpbctrl1; + u32 hpbctrl2; + u32 cccr; + u32 dummy0; /* 0x20 */ + u32 hpbctrl4; + u32 hpbctrl5; + u32 dummy1; /* 0x2C */ + u32 hpbctrl6; +}; + +/* Bus Semaphore Control Registers */ +struct sh73a0_hpb_bscr { + u32 mpsrc; /* 0x00 */ + u32 mpacctl; /* 0x04 */ + u32 dummy0[6]; + u32 smgpiosrc; /* 0x20 */ + u32 smgpioerr; + u32 smgpiotime; + u32 smgpiocnt; + u32 dummy1[4]; /* 0x30 .. 0x3C */ + u32 smcmt2src; + u32 smcmt2err; + u32 smcmt2time; + u32 smcmt2cnt; + u32 smcpgsrc; + u32 smcpgerr; + u32 smcpgtime; + u32 smcpgcnt; + u32 dummy2[4]; /* 0x60 - 0x6C */ + u32 smsyscsrc; + u32 smsyscerr; + u32 smsysctime; + u32 smsysccnt; +}; + +/* SBSC */ +struct sh73a0_sbsc { + u32 dummy0[2]; /* 0x00, 0x04 */ + u32 sdcr0; + u32 sdcr1; + u32 sdpcr; + u32 dummy1; /* 0x14 */ + u32 sdcr0s; + u32 sdcr1s; + u32 rtcsr; + u32 dummy2; /* 0x24 */ + u32 rtcor; + u32 rtcorh; + u32 rtcors; + u32 rtcorsh; + u32 dummy3[2]; /* 0x38, 0x3C */ + u32 sdwcrc0; + u32 sdwcrc1; + u32 sdwcr00; + u32 sdwcr01; + u32 sdwcr10; + u32 sdwcr11; + u32 sdpdcr0; + u32 dummy4; /* 0x5C */ + u32 sdwcr2; + u32 sdwcrc2; + u32 zqccr; + u32 dummy5[6]; /* 0x6C .. 0x80 */ + u32 sdmracr0; + u32 dummy6; /* 0x88 */ + u32 sdmrtmpcr; + u32 dummy7; /* 0x90 */ + u32 sdmrtmpmsk; + u32 dummy8; /* 0x98 */ + u32 sdgencnt; + u32 dphycnt0; + u32 dphycnt1; + u32 dphycnt2; + u32 dummy9[2]; /* 0xAC .. 0xB0 */ + u32 sddrvcr0; + u32 dummy10[14]; /* 0xB8 .. 0xEC */ + u32 dptdivcr0; + u32 dptdivcr1; + u32 dptdivcr2; + u32 dummy11; /* 0xFC */ + u32 sdptcr0; + u32 sdptcr1; + u32 sdptcr2; + u32 sdptcr3; /* 0x10C */ + u32 dummy12[145]; /* 0x110 .. 0x350 */ + u32 dllcnt0; /* 0x354 */ + u32 sbscmon0; +}; + +/* CPG */ +struct sh73a0_sbsc_cpg { + u32 frqcra; /* 0x00 */ + u32 frqcrb; + u32 vclkcr1; + u32 vclkcr2; + u32 zbckcr; + u32 flckcr; + u32 fsiackcr; + u32 vclkcr3; + u32 rtstbcr; + u32 systbcr; + u32 pll1cr; + u32 pll2cr; + u32 mstpsr0; + u32 dummy0; /* 0x34 */ + u32 mstpsr1; + u32 mstpsr5; + u32 mstpsr2; + u32 dummy1; /* 0x44 */ + u32 mstpsr3; + u32 mstpsr4; + u32 dummy2; /* 0x50 */ + u32 astat; + u32 dvfscr0; + u32 dvfscr1; + u32 dsitckcr; + u32 dsi0pckcr; + u32 dsi1pckcr; + u32 dsi0phycr; + u32 dsi1phycr; + u32 sd0ckcr; + u32 sd1ckcr; + u32 sd2ckcr; + u32 subckcr; + u32 spuackcr; + u32 msuckcr; + u32 hsickcr; + u32 fsibckcr; + u32 spuvckcr; + u32 mfck1cr; + u32 mfck2cr; + u32 dummy3[8]; /* 0xA0 .. 0xBC */ + u32 ckscr; + u32 dummy4; /* 0xC4 */ + u32 pll1stpcr; + u32 mpmode; + u32 pllecr; + u32 dummy5; /* 0xD4 */ + u32 pll0cr; + u32 pll3cr; + u32 dummy6; /* 0xE0 */ + u32 frqcrd; + u32 dummyi7; /* 0xE8 */ + u32 vrefcr; + u32 pll0stpcr; + u32 dummy8; /* 0xF4 */ + u32 pll2stpcr; + u32 pll3stpcr; + u32 dummy9[4]; /* 0x100 .. 0x10c */ + u32 rmstpcr0; + u32 rmstpcr1; + u32 rmstpcr2; + u32 rmstpcr3; + u32 rmstpcr4; + u32 rmstpcr5; + u32 dummy10[2]; /* 0x128 .. 0x12c */ + u32 smstpcr0; + u32 smstpcr1; + u32 smstpcr2; + u32 smstpcr3; + u32 smstpcr4; + u32 smstpcr5; + u32 dummy11[10]; /* 0x148 .. 0x16c */ + u32 dvfscr2; + u32 dvfscr3; + u32 dvfscr4; + u32 dvfscr5; /* 0x17C */ +}; + +/* CPG SRCR part OK */ +struct sh73a0_sbsc_cpg_srcr { + u32 srcr0; + u32 dummy0; /* 0xA4 */ + u32 srcr1; + u32 dummy1; /* 0xAC */ + u32 srcr2; + u32 dummy2; /* 0xB4 */ + u32 srcr3; + u32 srcr4; + u32 dummy3; /* 0xC0 */ + u32 srcr5; +}; + +/* BSC */ +struct sh73a0_bsc { + u32 cmncr; + u32 cs0bcr; + u32 cs2bcr; + u32 dummy0; /* 0x0C */ + u32 cs4bcr; + u32 cs5abcr; + u32 cs5bbcr; + u32 cs6abcr; + u32 cs6bbcr; + u32 cs0wcr; + u32 cs2wcr; + u32 dummy1; /* 0x2C */ + u32 cs4wcr; + u32 cs5awcr; + u32 cs5bwcr; + u32 cs6awcr; + u32 cs6bwcr; + u32 rbwtcnt; + u32 busycr; + u32 dummy2; /* 0x5c */ + u32 cs7abcr; + u32 cs7awcr; + u32 dummy3[2]; /* 0x68, 0x6C */ + u32 bromtimcr; +}; +#endif /* __ASSEMBLY__ */ + +#endif /* __ASM_ARCH_RMOBILE_SH73A0_H */ diff --git a/arch/arm/include/asm/arch-rmobile/sys_proto.h b/arch/arm/include/asm/arch-rmobile/sys_proto.h new file mode 100644 index 0000000..fad4e4e --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/sys_proto.h @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ + +struct rmobile_sysinfo { + char *board_string; +}; +extern const struct rmobile_sysinfo sysinfo; + +#endif
Nobuhiro Iwamatsu
