[U-Boot] Porting a freescale sabrelite-like board to master ?
The board I am working on, is based on the Freescale sabrelite board, the manufacturer provides support for it , as an about 1000 lines patch that applies to rel_imx_3.0.35_4.1.0 (3.0.35_4.1.0 is the kernel version I am using)
As that freescale version is too old for me (that is, it does not have support for USB or splashscreen), I would like to use the latest version of mainline u-boot.
I am a little puzzled, when I see that sabrelite support has been removed from main, it seems to have been replaced by the nitrogen board, so my manufacturer patch -badly- applies, especially due to the disparition of flash_header.S ...
I quickly found out that attempting a git rebase of rel_imx_3.0.35_4.1.0 to master was a bad idea, too.
So what would be the easiest and time less costing option to achieve what I want to do ?
Best regards Thierry
Dear Thierry,
The kernel version is actually totally uninteresting here. What matters is what U-Boot version you have. Let me guess - it is some v2009.x - i. e. 5 year old stuff?
It is best to take current code (top of tree in git repository) and port it to your hardware from scratch. You can use your old code as reference, for example how to set up pin muxing and such. Otherwise it is pretty much worthless.
Le 22/02/2014 20:20, Wolfgang Denk a écrit :
Dear Thierry,
Dear Wolfgang,
Sorry for the confusion. I should have been more specific. What I meant is that my current u-boot version is tag "rel_imx_3.0.35_4.1.0" from http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git
If I was mentioning the kernel version, it is just to say that switching to a more recent kernel version is not an option, because we do not have a device tree BSP for it.
If the sabrelite board would still be supported in master, it would be straightforward. So I am thinking about re-bringing support for sabrelite my branch, first.
Hi Thierry,
sabrelite is still supported in master. Its source is located at board/boundary/nitrogen6x/nitrogen6x.c
Regards,
Fabio Estevam
Hi Thierry,
Dear Thierry,
Dear Wolfgang,
Support for SABRE Lite is in the main-line kernel as well, but that's a completely separate topic.
It **is** still in master. It just uses board/boundary/nitrogen6x.c as the implementation.
It doesn't look anything like the 2009.08 code base, because, as Wolfgang said, that's very old.
Regards,
Eric
Dear Thierry,
Yes - which is, as I guessed, based on U-Boot v2009.08 (i. e. 5 yeards old code plus a zillion out-of-tree patches). This is totally unusable for any commercial project; the code is unmaintainable.
As others have explained, this is not your problem. But you still have to port U-Boot to your own hardware.
Hi Thierry,
On 02/22/2014 10:56 AM, Thierry Bultel wrote:
The board I am working on, is based on the Freescale sabrelite board, the manufacturer provides support for it, as an about 1000 lines patch that applies to rel_imx_3.0.35_4.1.0 (3.0.35_4.1.0 is the kernel version I am using)
Are you referring to **another** manufacturer?
We have support for SABRE Lite in main-line and are actively maintaining it.
You should start by using a board file based on Nitrogen6x (which contains support for both Nitrogen6x and SABRE Lite by looking at one pin: http://git.denx.de/?p=u-boot.git;a=blob;f=board/boundary/nitrogen6x/nitrogen...
The differences are minor and explained in more detail here: http://boundarydevices.com/differences-sabre-lite-nitrogen6x
I'd recommend starting with main-line Nitrogen6x code base, and update as needed for your particulars.
Regards,
Eric
Hi Eric
What about i.MX6DL SABRE Auto ? Is it in main-line too ? If yes, which config file should I use ?
By looking at boards.cfg, I could find mx6qsabreauto, ma6dlsabrelite, nitrogen6dl..., but there is no something like mx6dlsabreauto.
The support of it is also in freesacle git mentioned by Thierry
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/commit/?h=imx_v2009....
Thanks, Miao
You should start by using a board file based on Nitrogen6x (which contains support for both Nitrogen6x and SABRE Lite by looking at one pin: http://git.denx.de/?p=u- boot.git;a=blob;f=board/boundary/nitrogen6x/nitrogen6x.c;h=d9c05b07bfa e83466513735cbec95c7f949de7a5;hb=HEAD#l736
Regards,
Eric _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
participants (5)
Eric Nelson
Fabio Estevam
Thierry Bultel
Yan, Miao
