[U-Boot] [PATCH] net: Remove Xilinx ll_temac driver
ll_temac driver was used by Xilinx Microblaze big endian and Xilinx ppc405/ppc440 SoCs.
ppc support was removed by: "powerpc: remove 4xx support" (sha1: 98f705c9cefdfdba62c069821bbba10273a0a8ed) and Microblaze BE is not tested for a long time that's why this driver can be removed because none is going to updated it to DM anyway.
Travis build in progress https://travis-ci.org/michalsimek/u-boot/builds/342228152
--- drivers/net/Makefile | 2 - drivers/net/xilinx_ll_temac.c | 394 ------------------------------------- drivers/net/xilinx_ll_temac.h | 307 ----------------------------- drivers/net/xilinx_ll_temac_fifo.c | 139 ------------- drivers/net/xilinx_ll_temac_fifo.h | 118 ----------- drivers/net/xilinx_ll_temac_mdio.c | 177 ----------------- drivers/net/xilinx_ll_temac_mdio.h | 50 ----- drivers/net/xilinx_ll_temac_sdma.c | 307 ----------------------------- drivers/net/xilinx_ll_temac_sdma.h | 266 ------------------------- include/netdev.h | 10 - scripts/config_whitelist.txt | 1 - 11 files changed, 1771 deletions(-) delete mode 100644 drivers/net/xilinx_ll_temac.c delete mode 100644 drivers/net/xilinx_ll_temac.h delete mode 100644 drivers/net/xilinx_ll_temac_fifo.c delete mode 100644 drivers/net/xilinx_ll_temac_fifo.h delete mode 100644 drivers/net/xilinx_ll_temac_mdio.c delete mode 100644 drivers/net/xilinx_ll_temac_mdio.h delete mode 100644 drivers/net/xilinx_ll_temac_sdma.c delete mode 100644 drivers/net/xilinx_ll_temac_sdma.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index ac5443c752c2..4a16c62bac09 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -66,8 +66,6 @@ obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o obj-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o obj-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o -obj-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ - xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o obj-$(CONFIG_ZYNQ_GEM) += zynq_gem.o obj-$(CONFIG_FSL_MC_ENET) += fsl-mc/ obj-$(CONFIG_FSL_MC_ENET) += ldpaa_eth/ diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c deleted file mode 100644 index 1e7e2e49af9c..000000000000 --- a/drivers/net/xilinx_ll_temac.c +++ /dev/null @@ -1,394 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * supports SDMA or FIFO access and MDIO bus communication - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ - -#include <config.h> -#include <common.h> -#include <net.h> -#include <netdev.h> -#include <malloc.h> -#include <asm/io.h> -#include <miiphy.h> - -#include "xilinx_ll_temac.h" -#include "xilinx_ll_temac_fifo.h" -#include "xilinx_ll_temac_sdma.h" -#include "xilinx_ll_temac_mdio.h" - -#if !defined(CONFIG_MII) -# error "LL_TEMAC requires MII -- missing CONFIG_MII" -#endif - -#if !defined(CONFIG_PHYLIB) -# error "LL_TEMAC requires PHYLIB -- missing CONFIG_PHYLIB" -#endif - -struct ll_temac_info { - int flags; - unsigned long base_addr; - unsigned long ctrl_addr; - char *devname; - unsigned int phyaddr; - char *mdio_busname; -}; - -/* Ethernet interface ready status */ -int ll_temac_check_status(struct temac_reg *regs, u32 mask) -{ - unsigned timeout = 50; /* 1usec * 50 = 50usec */ - - /* - * Quote from LL TEMAC documentation: The bits in the RDY - * register are asserted when there is no access in progress. - * When an access is in progress, a bit corresponding to the - * type of access is automatically de-asserted. The bit is - * automatically re-asserted when the access is complete. - */ - while (timeout && (!(in_be32(®s->rdy) & mask))) { - timeout--; - udelay(1); - } - - if (!timeout) { - printf("%s: Timeout on 0x%08x @%p\n", __func__, - mask, ®s->rdy); - return 1; - } - - return 0; -} - -/* - * Indirect write to ll_temac. - * - * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... - * page 23, second paragraph, The use of CTL0 register or CTL1 register - */ -int ll_temac_indirect_set(struct temac_reg *regs, u16 regn, u32 reg_data) -{ - out_be32(®s->lsw, (reg_data & MLSW_MASK)); - out_be32(®s->ctl, CTL_WEN | (regn & CTL_ADDR_MASK)); - - if (ll_temac_check_status(regs, RSE_CFG_WR)) - return 0; - - return 1; -} - -/* - * Indirect read from ll_temac. - * - * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... - * page 23, second paragraph, The use of CTL0 register or CTL1 register - */ -int ll_temac_indirect_get(struct temac_reg *regs, u16 regn, u32* reg_data) -{ - out_be32(®s->ctl, (regn & CTL_ADDR_MASK)); - - if (ll_temac_check_status(regs, RSE_CFG_RR)) - return 0; - - *reg_data = in_be32(®s->lsw) & MLSW_MASK; - return 1; -} - -/* setting sub-controller and ll_temac to proper setting */ -static int ll_temac_setup_ctrl(struct eth_device *dev) -{ - struct ll_temac *ll_temac = dev->priv; - struct temac_reg *regs = (struct temac_reg *)dev->iobase; - - if (ll_temac->ctrlreset && ll_temac->ctrlreset(dev)) - return 0; - - if (ll_temac->ctrlinit && ll_temac->ctrlinit(dev)) - return 0; - - /* Promiscuous mode disable */ - if (!ll_temac_indirect_set(regs, TEMAC_AFM, 0)) - return 0; - - /* Enable Receiver - RX bit */ - if (!ll_temac_indirect_set(regs, TEMAC_RCW1, RCW1_RX)) - return 0; - - /* Enable Transmitter - TX bit */ - if (!ll_temac_indirect_set(regs, TEMAC_TC, TC_TX)) - return 0; - - return 1; -} - -/* - * Configure ll_temac based on negotiated speed and duplex - * reported by PHY handling code - */ -static int ll_temac_adjust_link(struct eth_device *dev) -{ - unsigned int speed, emmc_reg; - struct temac_reg *regs = (struct temac_reg *)dev->iobase; - struct ll_temac *ll_temac = dev->priv; - struct phy_device *phydev = ll_temac->phydev; - - if (!phydev->link) { - printf("%s: No link.\n", phydev->dev->name); - return 0; - } - - switch (phydev->speed) { - case 1000: - speed = EMMC_LSPD_1000; - break; - case 100: - speed = EMMC_LSPD_100; - break; - case 10: - speed = EMMC_LSPD_10; - break; - default: - return 0; - } - - if (!ll_temac_indirect_get(regs, TEMAC_EMMC, &emmc_reg)) - return 0; - - emmc_reg &= ~EMMC_LSPD_MASK; - emmc_reg |= speed; - - if (!ll_temac_indirect_set(regs, TEMAC_EMMC, emmc_reg)) - return 0; - - printf("%s: PHY is %s with %dbase%s, %s%s\n", - dev->name, phydev->drv->name, - phydev->speed, (phydev->port == PORT_TP) ? "T" : "X", - (phydev->duplex) ? "FDX" : "HDX", - (phydev->port == PORT_OTHER) ? ", unkown mode" : ""); - - return 1; -} - -/* setup mac addr */ -static int ll_temac_setup_mac_addr(struct eth_device *dev) -{ - struct temac_reg *regs = (struct temac_reg *)dev->iobase; - u32 val; - - /* set up unicast MAC address filter */ - val = ((dev->enetaddr[3] << 24) | (dev->enetaddr[2] << 16) | - (dev->enetaddr[1] << 8) | (dev->enetaddr[0])); - val &= UAW0_UADDR_MASK; - - if (!ll_temac_indirect_set(regs, TEMAC_UAW0, val)) - return 1; - - val = ((dev->enetaddr[5] << 8) | dev->enetaddr[4]); - val &= UAW1_UADDR_MASK; - - if (!ll_temac_indirect_set(regs, TEMAC_UAW1, val)) - return 1; - - return 0; -} - -/* halt device */ -static void ll_temac_halt(struct eth_device *dev) -{ - struct ll_temac *ll_temac = dev->priv; - struct temac_reg *regs = (struct temac_reg *)dev->iobase; - - /* Disable Receiver */ - ll_temac_indirect_set(regs, TEMAC_RCW0, 0); - - /* Disable Transmitter */ - ll_temac_indirect_set(regs, TEMAC_TC, 0); - - if (ll_temac->ctrlhalt) - ll_temac->ctrlhalt(dev); - - /* Shut down the PHY, as needed */ - phy_shutdown(ll_temac->phydev); -} - -static int ll_temac_init(struct eth_device *dev, bd_t *bis) -{ - struct ll_temac *ll_temac = dev->priv; - int ret; - - printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08lx.\n", - dev->name, dev->index, dev->iobase); - - if (!ll_temac_setup_ctrl(dev)) - return -1; - - /* Start up the PHY */ - ret = phy_startup(ll_temac->phydev); - if (ret) { - printf("%s: Could not initialize PHY %s\n", - dev->name, ll_temac->phydev->dev->name); - return ret; - } - - if (!ll_temac_adjust_link(dev)) { - ll_temac_halt(dev); - return -1; - } - - /* If there's no link, fail */ - return ll_temac->phydev->link ? 0 : -1; -} - -/* - * Discover which PHY is attached to the device, and configure it - * properly. If the PHY is not recognized, then return 0 - * (failure). Otherwise, return 1 - */ -static int ll_temac_phy_init(struct eth_device *dev) -{ - struct ll_temac *ll_temac = dev->priv; - struct phy_device *phydev; - unsigned int supported = PHY_GBIT_FEATURES; - - /* interface - look at driver/net/tsec.c */ - phydev = phy_connect(ll_temac->bus, ll_temac->phyaddr, - dev, PHY_INTERFACE_MODE_NONE); - - phydev->supported &= supported; - phydev->advertising = phydev->supported; - - ll_temac->phydev = phydev; - - phy_config(phydev); - - return 1; -} - -/* - * Initialize a single ll_temac devices - * - * Returns the result of ll_temac phy interface that were initialized - */ -int xilinx_ll_temac_initialize(bd_t *bis, struct ll_temac_info *devinf) -{ - struct eth_device *dev; - struct ll_temac *ll_temac; - - dev = calloc(1, sizeof(*dev)); - if (dev == NULL) - return 0; - - ll_temac = calloc(1, sizeof(struct ll_temac)); - if (ll_temac == NULL) { - free(dev); - return 0; - } - - /* use given name or generate its own unique name */ - if (devinf->devname) { - strncpy(dev->name, devinf->devname, sizeof(dev->name)); - } else { - snprintf(dev->name, sizeof(dev->name), "ll_tem.%lx", - devinf->base_addr); - devinf->devname = dev->name; - } - - dev->iobase = devinf->base_addr; - - dev->priv = ll_temac; - dev->init = ll_temac_init; - dev->halt = ll_temac_halt; - dev->write_hwaddr = ll_temac_setup_mac_addr; - - ll_temac->ctrladdr = devinf->ctrl_addr; - if (devinf->flags & XILINX_LL_TEMAC_M_SDMA_PLB) { - ll_temac_collect_xlplb_sdma_reg_addr(dev); - ll_temac->in32 = ll_temac_xlplb_in32; - ll_temac->out32 = ll_temac_xlplb_out32; - ll_temac->ctrlinit = ll_temac_init_sdma; - ll_temac->ctrlhalt = ll_temac_halt_sdma; - ll_temac->ctrlreset = ll_temac_reset_sdma; - dev->recv = ll_temac_recv_sdma; - dev->send = ll_temac_send_sdma; - } else { - ll_temac->in32 = NULL; - ll_temac->out32 = NULL; - ll_temac->ctrlinit = NULL; - ll_temac->ctrlhalt = NULL; - ll_temac->ctrlreset = ll_temac_reset_fifo; - dev->recv = ll_temac_recv_fifo; - dev->send = ll_temac_send_fifo; - } - - /* Link to specified MDIO bus */ - strncpy(ll_temac->mdio_busname, devinf->mdio_busname, MDIO_NAME_LEN); - ll_temac->bus = miiphy_get_dev_by_name(ll_temac->mdio_busname); - - /* Looking for a valid PHY address if it is not yet set */ - if (devinf->phyaddr == -1) - ll_temac->phyaddr = ll_temac_phy_addr(ll_temac->bus); - else - ll_temac->phyaddr = devinf->phyaddr; - - eth_register(dev); - - /* Try to initialize PHY here, and return */ - return ll_temac_phy_init(dev); -} - -/* - * Initialize a single ll_temac device with its mdio bus behind ll_temac - * - * Returns 1 if the ll_temac device and the mdio bus were initialized - * otherwise returns 0 - */ -int xilinx_ll_temac_eth_init(bd_t *bis, unsigned long base_addr, int flags, - unsigned long ctrl_addr) -{ - struct ll_temac_info devinf; - struct ll_temac_mdio_info mdioinf; - int ret; - - /* prepare the internal driver informations */ - devinf.flags = flags; - devinf.base_addr = base_addr; - devinf.ctrl_addr = ctrl_addr; - devinf.devname = NULL; - devinf.phyaddr = -1; - - mdioinf.name = devinf.mdio_busname = NULL; - mdioinf.regs = (struct temac_reg *)devinf.base_addr; - - ret = xilinx_ll_temac_mdio_initialize(bis, &mdioinf); - if (ret >= 0) { - - /* - * If there was no MDIO bus name then take over the - * new automaticaly generated by the MDIO init code. - */ - if (mdioinf.name != devinf.mdio_busname) - devinf.mdio_busname = mdioinf.name; - - ret = xilinx_ll_temac_initialize(bis, &devinf); - if (ret > 0) - return 1; - - } - - return 0; -} diff --git a/drivers/net/xilinx_ll_temac.h b/drivers/net/xilinx_ll_temac.h deleted file mode 100644 index 56362ba20776..000000000000 --- a/drivers/net/xilinx_ll_temac.h +++ /dev/null @@ -1,307 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * LL_TEMAC interface - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ -#ifndef _XILINX_LL_TEMAC_ -#define _XILINX_LL_TEMAC_ - -#include <config.h> -#include <net.h> -#include <phy.h> -#include <miiphy.h> - -#include <asm/types.h> -#include <asm/byteorder.h> - -#include "xilinx_ll_temac_sdma.h" - -#if !defined(__BIG_ENDIAN) -# error LL_TEMAC requires big endianess -#endif - -/* - * TEMAC Memory and Register Definition - * - * [1]: [0]/ip_documentation/xps_ll_temac.pdf - * page 19, Memory and Register Descriptions - */ -struct temac_reg { - /* direct soft registers (low part) */ - u32 raf; /* Reset and Address Filter */ - u32 tpf; /* Transmit Pause Frame */ - u32 ifgp; /* Transmit Inter Frame Gap Adjustment */ - u32 is; /* Interrupt Status */ - u32 ip; /* Interrupt Pending */ - u32 ie; /* Interrupt Enable */ - u32 ttag; /* Transmit VLAN Tag */ - u32 rtag; /* Receive VLAN Tag */ - /* hard TEMAC registers */ - u32 msw; /* Most Significant Word Data */ - u32 lsw; /* Least Significant Word Data */ - u32 ctl; /* Control */ - u32 rdy; /* Ready Status */ - /* direct soft registers (high part) */ - u32 uawl; /* Unicast Address Word Lower */ - u32 uawu; /* Unicast Address Word Upper */ - u32 tpid0; /* VLAN TPID Word 0 */ - u32 tpid1; /* VLAN TPID Word 1 */ -}; - -/* Reset and Address Filter Registers (raf), [1] p25 */ -#define RAF_SR (1 << 13) -#define RAF_EMFE (1 << 12) -#define RAF_NFE (1 << 11) -#define RAF_RVSTM_POS 9 -#define RAF_RVSTM_MASK (3 << RAF_RVSTM_POS) -#define RAF_TVSTM_POS 7 -#define RAF_TVSTM_MASK (3 << RAF_TVSTM_POS) -#define RAF_RVTM_POS 5 -#define RAF_RVTM_MASK (3 << RAF_RVTM_POS) -#define RAF_TVTM_POS 3 -#define RAF_TVTM_MASK (3 << RAF_TVTM_POS) -#define RAF_BCREJ (1 << 2) -#define RAF_MCREJ (1 << 1) -#define RAF_HTRST (1 << 0) - -/* Transmit Pause Frame Registers (tpf), [1] p28 */ -#define TPF_TPFV_POS 0 -#define TPF_TPFV_MASK (0xFFFF << TPF_TPFV_POS) - -/* Transmit Inter Frame Gap Adjustment Registers (ifgp), [1] p28 */ -#define IFGP_POS 0 -#define IFGP_MASK (0xFF << IFGP_POS) - -/* Interrupt Status, Pending, Enable Registers (is, ip, ie), [1] p29-33 */ -#define ISPE_MR (1 << 7) -#define ISPE_RDL (1 << 6) -#define ISPE_TC (1 << 5) -#define ISPE_RFO (1 << 4) -#define ISPE_RR (1 << 3) -#define ISPE_RC (1 << 2) -#define ISPE_AN (1 << 1) -#define ISPE_HAC (1 << 0) - -/* Transmit, Receive VLAN Tag Registers (ttag, rtag), [1] p34-35 */ -#define TRTAG_TPID_POS 16 -#define TRTAG_TPID_MASK (0xFFFF << TRTAG_TPID_POS) -#define TRTAG_PRIO_POS 13 -#define TRTAG_PRIO_MASK (7 << TRTAG_PRIO_POS) -#define TRTAG_CFI (1 << 12) -#define TRTAG_VID_POS 0 -#define TRTAG_VID_MASK (0xFFF << TRTAG_VID_POS) - -/* Most, Least Significant Word Data Register (msw, lsw), [1] p46 */ -#define MLSW_POS 0 -#define MLSW_MASK (~0UL << MLSW_POS) - -/* LSW Data Register for PHY addresses (lsw), [1] p66 */ -#define LSW_REGAD_POS 0 -#define LSW_REGAD_MASK (0x1F << LSW_REGAD_POS) -#define LSW_PHYAD_POS 5 -#define LSW_PHYAD_MASK (0x1F << LSW_PHYAD_POS) - -/* LSW Data Register for PHY data (lsw), [1] p66 */ -#define LSW_REGDAT_POS 0 -#define LSW_REGDAT_MASK (0xFFFF << LSW_REGDAT_POS) - -/* Control Register (ctl), [1] p47 */ -#define CTL_WEN (1 << 15) -#define CTL_ADDR_POS 0 -#define CTL_ADDR_MASK (0x3FF << CTL_ADDR_POS) - -/* Ready Status Register Ethernet (rdy), [1] p48 */ -#define RSE_HACS_RDY (1 << 14) -#define RSE_CFG_WR (1 << 6) -#define RSE_CFG_RR (1 << 5) -#define RSE_AF_WR (1 << 4) -#define RSE_AF_RR (1 << 3) -#define RSE_MIIM_WR (1 << 2) -#define RSE_MIIM_RR (1 << 1) -#define RSE_FABR_RR (1 << 0) - -/* Unicast Address Word Lower, Upper Registers (uawl, uawu), [1] p35-36 */ -#define UAWL_UADDR_POS 0 -#define UAWL_UADDR_MASK (~0UL << UAWL_UADDR_POS) -#define UAWU_UADDR_POS 0 -#define UAWU_UADDR_MASK (0xFFFF << UAWU_UADDR_POS) - -/* VLAN TPID Word 0, 1 Registers (tpid0, tpid1), [1] p37 */ -#define TPID0_V0_POS 0 -#define TPID0_V0_MASK (0xFFFF << TPID0_V0_POS) -#define TPID0_V1_POS 16 -#define TPID0_V1_MASK (0xFFFF << TPID0_V1_POS) -#define TPID1_V2_POS 0 -#define TPID1_V2_MASK (0xFFFF << TPID1_V2_POS) -#define TPID1_V3_POS 16 -#define TPID1_V3_MASK (0xFFFF << TPID1_V3_POS) - -/* - * TEMAC Indirectly Addressable Register Index Enumeration - * - * [0]: http://www.xilinx.com/support/documentation - * - * [1]: [0]/ip_documentation/xps_ll_temac.pdf - * page 23, PLB Indirectly Addressable TEMAC Registers - */ -enum temac_ctrl { - TEMAC_RCW0 = 0x200, - TEMAC_RCW1 = 0x240, - TEMAC_TC = 0x280, - TEMAC_FCC = 0x2C0, - TEMAC_EMMC = 0x300, - TEMAC_PHYC = 0x320, - TEMAC_MC = 0x340, - TEMAC_UAW0 = 0x380, - TEMAC_UAW1 = 0x384, - TEMAC_MAW0 = 0x388, - TEMAC_MAW1 = 0x38C, - TEMAC_AFM = 0x390, - TEMAC_TIS = 0x3A0, - TEMAC_TIE = 0x3A4, - TEMAC_MIIMWD = 0x3B0, - TEMAC_MIIMAI = 0x3B4 -}; - -/* Receive Configuration Word 0, 1 Registers (RCW0, RCW1), [1] p50-51 */ -#define RCW0_PADDR_POS 0 -#define RCW0_PADDR_MASK (~0UL << RCW_PADDR_POS) -#define RCW1_RST (1 << 31) -#define RCW1_JUM (1 << 30) -#define RCW1_FCS (1 << 29) -#define RCW1_RX (1 << 28) -#define RCW1_VLAN (1 << 27) -#define RCW1_HD (1 << 26) -#define RCW1_LT_DIS (1 << 25) -#define RCW1_PADDR_POS 0 -#define RCW1_PADDR_MASK (0xFFFF << RCW_PADDR_POS) - -/* Transmit Configuration Registers (TC), [1] p52 */ -#define TC_RST (1 << 31) -#define TC_JUM (1 << 30) -#define TC_FCS (1 << 29) -#define TC_TX (1 << 28) -#define TC_VLAN (1 << 27) -#define TC_HD (1 << 26) -#define TC_IFG (1 << 25) - -/* Flow Control Configuration Registers (FCC), [1] p54 */ -#define FCC_FCTX (1 << 30) -#define FCC_FCRX (1 << 29) - -/* Ethernet MAC Mode Configuration Registers (EMMC), [1] p54 */ -#define EMMC_LSPD_POS 30 -#define EMMC_LSPD_MASK (3 << EMMC_LSPD_POS) -#define EMMC_LSPD_1000 (2 << EMMC_LSPD_POS) -#define EMMC_LSPD_100 (1 << EMMC_LSPD_POS) -#define EMMC_LSPD_10 0 -#define EMMC_RGMII (1 << 29) -#define EMMC_SGMII (1 << 28) -#define EMMC_GPCS (1 << 27) -#define EMMC_HOST (1 << 26) -#define EMMC_TX16 (1 << 25) -#define EMMC_RX16 (1 << 24) - -/* RGMII/SGMII Configuration Registers (PHYC), [1] p56 */ -#define PHYC_SLSPD_POS 30 -#define PHYC_SLSPD_MASK (3 << EMMC_SLSPD_POS) -#define PHYC_SLSPD_1000 (2 << EMMC_SLSPD_POS) -#define PHYC_SLSPD_100 (1 << EMMC_SLSPD_POS) -#define PHYC_SLSPD_10 0 -#define PHYC_RLSPD_POS 2 -#define PHYC_RLSPD_MASK (3 << EMMC_RLSPD_POS) -#define PHYC_RLSPD_1000 (2 << EMMC_RLSPD_POS) -#define PHYC_RLSPD_100 (1 << EMMC_RLSPD_POS) -#define PHYC_RLSPD_10 0 -#define PHYC_RGMII_HD (1 << 1) -#define PHYC_RGMII_LINK (1 << 0) - -/* Management Configuration Registers (MC), [1] p57 */ -#define MC_MDIOEN (1 << 6) -#define MC_CLKDIV_POS 0 -#define MC_CLKDIV_MASK (0x3F << MC_CLKDIV_POS) - -/* - * fHOSTCLK fMDC = fHOSTCLK - * fMDC = ------------------- ---------> MC_CLKDIV = -------- - 1 - * (1 + MC_CLKDIV) * 2 2.5 MHz 5MHz - */ -#define MC_CLKDIV(f, m) ((f / (2 * m)) - 1) -#define MC_CLKDIV_25(f) MC_CLKDIV(f, 2500000) -#define MC_CLKDIV_20(f) MC_CLKDIV(f, 2000000) -#define MC_CLKDIV_15(f) MC_CLKDIV(f, 1500000) -#define MC_CLKDIV_10(f) MC_CLKDIV(f, 1000000) - -/* Unicast Address Word 0, 1 Registers (UAW0, UAW1), [1] p58-59 */ -#define UAW0_UADDR_POS 0 -#define UAW0_UADDR_MASK (~0UL << UAW0_UADDR_POS) -#define UAW1_UADDR_POS 0 -#define UAW1_UADDR_MASK (0xFFFF << UAW1_UADDR_POS) - -/* Multicast Address Word 0, 1 Registers (MAW0, MAW1), [1] p60 */ -#define MAW0_MADDR_POS 0 -#define MAW0_MADDR_MASK (~0UL << MAW0_MADDR_POS) -#define MAW1_RNW (1 << 23) -#define MAW1_MAIDX_POS 16 -#define MAW1_MAIDX_MASK (3 << MAW1_MAIDX_POS) -#define MAW1_MADDR_POS 0 -#define MAW1_MADDR_MASK (0xFFFF << MAW1_MADDR_POS) - -/* Address Filter Mode Registers (AFM), [1] p63 */ -#define AFM_PM (1 << 31) - -/* Interrupt Status, Enable Registers (TIS, TIE), [1] p63-65 */ -#define TISE_CFG_W (1 << 6) -#define TISE_CFG_R (1 << 5) -#define TISE_AF_W (1 << 4) -#define TISE_AF_R (1 << 3) -#define TISE_MIIM_W (1 << 2) -#define TISE_MIIM_R (1 << 1) -#define TISE_FABR_R (1 << 0) - -/* MII Management Write Data Registers (MIIMWD), [1] p66 */ -#define MIIMWD_DATA_POS 0 -#define MIIMWD_DATA_MASK (0xFFFF << MIIMWD_DATA_POS) - -/* Ethernet interface ready status */ -int ll_temac_check_status(struct temac_reg *regs, u32 mask); - -/* Indirect write to ll_temac. */ -int ll_temac_indirect_set(struct temac_reg *regs, u16 regn, u32 reg_data); - -/* Indirect read from ll_temac. */ -int ll_temac_indirect_get(struct temac_reg *regs, u16 regn, u32* reg_data); - -struct ll_temac { - phys_addr_t ctrladdr; - phys_addr_t sdma_reg_addr[SDMA_CTRL_REGNUMS]; - - unsigned (*in32)(phys_addr_t); - void (*out32)(phys_addr_t, unsigned); - - int (*ctrlinit) (struct eth_device *); - int (*ctrlhalt) (struct eth_device *); - int (*ctrlreset) (struct eth_device *); - - int phyaddr; - struct phy_device *phydev; - struct mii_dev *bus; - char mdio_busname[MDIO_NAME_LEN]; -}; - -#endif /* _XILINX_LL_TEMAC_ */ diff --git a/drivers/net/xilinx_ll_temac_fifo.c b/drivers/net/xilinx_ll_temac_fifo.c deleted file mode 100644 index 78319d7d918c..000000000000 --- a/drivers/net/xilinx_ll_temac_fifo.c +++ /dev/null @@ -1,139 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * FIFO sub-controller - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * CREDITS: tsec driver - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [F]: [0]/ip_documentation/xps_ll_fifo.pdf - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ - -#include <config.h> -#include <common.h> -#include <net.h> - -#include <asm/types.h> -#include <asm/io.h> - -#include "xilinx_ll_temac.h" -#include "xilinx_ll_temac_fifo.h" - -int ll_temac_reset_fifo(struct eth_device *dev) -{ - struct ll_temac *ll_temac = dev->priv; - struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; - - out_be32(&fifo_ctrl->tdfr, LL_FIFO_TDFR_KEY); - out_be32(&fifo_ctrl->rdfr, LL_FIFO_RDFR_KEY); - out_be32(&fifo_ctrl->isr, ~0UL); - out_be32(&fifo_ctrl->ier, 0); - - return 0; -} - -int ll_temac_recv_fifo(struct eth_device *dev) -{ - int i, length = 0; - u32 *buf = (u32 *)net_rx_packets[0]; - struct ll_temac *ll_temac = dev->priv; - struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; - - if (in_be32(&fifo_ctrl->isr) & LL_FIFO_ISR_RC) { - - /* reset isr */ - out_be32(&fifo_ctrl->isr, ~0UL); - - /* - * MAYBE here: - * while (fifo_ctrl->isr); - */ - - /* - * The length is written (into RLR) by the XPS LL FIFO - * when the packet is received across the RX LocalLink - * interface and the receive data FIFO had enough - * locations that all of the packet data has been saved. - * The RLR should only be read when a receive packet is - * available for processing (the receive occupancy is - * not zero). Once the RLR is read, the receive packet - * data should be read from the receive data FIFO before - * the RLR is read again. - * - * [F] page 17, Receive Length Register (RLR) - */ - if (in_be32(&fifo_ctrl->rdfo) & LL_FIFO_RDFO_MASK) { - length = in_be32(&fifo_ctrl->rlf) & LL_FIFO_RLF_MASK; - } else { - printf("%s: Got error, no receive occupancy\n", - __func__); - return -1; - } - - if (length > PKTSIZE_ALIGN) { - printf("%s: Got error, receive package too big (%i)\n", - __func__, length); - ll_temac_reset_fifo(dev); - return -1; - } - - for (i = 0; i < length; i += 4) - *buf++ = in_be32(&fifo_ctrl->rdfd); - - net_process_received_packet(net_rx_packets[0], length); - } - - return 0; -} - -int ll_temac_send_fifo(struct eth_device *dev, void *packet, int length) -{ - int i; - u32 *buf = (u32 *)packet; - struct ll_temac *ll_temac = dev->priv; - struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; - - if (length < LL_FIFO_TLF_MIN) { - printf("%s: Got error, transmit package too small (%i)\n", - __func__, length); - return -1; - } - - if (length > LL_FIFO_TLF_MAX) { - printf("%s: Got error, transmit package too big (%i)\n", - __func__, length); - return -1; - } - - for (i = 0; i < length; i += 4) - out_be32(&fifo_ctrl->tdfd, *buf++); - - /* - * Once the packet length is written to the TLR it is - * automatically moved to the transmit data FIFO with - * the packet data freeing up the TLR for another value. - * The packet length must be written to the TLR after - * the packet data is written to the transmit data FIFO. - * It is not valid to write data for multiple packets - * to the transmit data FIFO before writing the packet - * length values. - * - * [F] page 17, Transmit Length Register (TLR) - */ - out_be32(&fifo_ctrl->tlf, length); - - return 0; -} diff --git a/drivers/net/xilinx_ll_temac_fifo.h b/drivers/net/xilinx_ll_temac_fifo.h deleted file mode 100644 index c1bf7cc641bc..000000000000 --- a/drivers/net/xilinx_ll_temac_fifo.h +++ /dev/null @@ -1,118 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * FIFO sub-controller interface - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ -#ifndef _XILINX_LL_TEMAC_FIFO_ -#define _XILINX_LL_TEMAC_FIFO_ - -#include <net.h> - -#include <asm/types.h> -#include <asm/byteorder.h> - -#if !defined(__BIG_ENDIAN) -# error LL_TEMAC requires big endianess -#endif - -/* - * FIFO Register Definition - * - * Used for memory mapped access from and to (Rd/Td) the LocalLink (LL) - * Tri-Mode Ether MAC (TEMAC) via the 2 kb full duplex FIFO Controller, - * one for each. - * - * [1]: [0]/ip_documentation/xps_ll_fifo.pdf - * page 10, Registers Definition - */ -struct fifo_ctrl { - u32 isr; /* Interrupt Status Register (RW) */ - u32 ier; /* Interrupt Enable Register (RW) */ - u32 tdfr; /* Transmit Data FIFO Reset (WO) */ - u32 tdfv; /* Transmit Data FIFO Vacancy (RO) */ - u32 tdfd; /* Transmit Data FIFO 32bit wide Data write port (WO) */ - u32 tlf; /* Transmit Length FIFO (WO) */ - u32 rdfr; /* Receive Data FIFO Reset (WO) */ - u32 rdfo; /* Receive Data FIFO Occupancy (RO) */ - u32 rdfd; /* Receive Data FIFO 32bit wide Data read port (RO) */ - u32 rlf; /* Receive Length FIFO (RO) */ - u32 llr; /* LocalLink Reset (WO) */ -}; - -/* Interrupt Status Register (ISR), [1] p11 */ -#define LL_FIFO_ISR_RPURE (1 << 31) /* Receive Packet Underrun Read Err */ -#define LL_FIFO_ISR_RPORE (1 << 30) /* Receive Packet Overrun Read Err */ -#define LL_FIFO_ISR_RPUE (1 << 29) /* Receive Packet Underrun Error */ -#define LL_FIFO_ISR_TPOE (1 << 28) /* Transmit Packet Overrun Error */ -#define LL_FIFO_ISR_TC (1 << 27) /* Transmit Complete */ -#define LL_FIFO_ISR_RC (1 << 26) /* Receive Complete */ -#define LL_FIFO_ISR_TSE (1 << 25) /* Transmit Size Error */ -#define LL_FIFO_ISR_TRC (1 << 24) /* Transmit Reset Complete */ -#define LL_FIFO_ISR_RRC (1 << 23) /* Receive Reset Complete */ - -/* Interrupt Enable Register (IER), [1] p12/p13 */ -#define LL_FIFO_IER_RPURE (1 << 31) /* Receive Packet Underrun Read Err */ -#define LL_FIFO_IER_RPORE (1 << 30) /* Receive Packet Overrun Read Err */ -#define LL_FIFO_IER_RPUE (1 << 29) /* Receive Packet Underrun Error */ -#define LL_FIFO_IER_TPOE (1 << 28) /* Transmit Packet Overrun Error */ -#define LL_FIFO_IER_TC (1 << 27) /* Transmit Complete */ -#define LL_FIFO_IER_RC (1 << 26) /* Receive Complete */ -#define LL_FIFO_IER_TSE (1 << 25) /* Transmit Size Error */ -#define LL_FIFO_IER_TRC (1 << 24) /* Transmit Reset Complete */ -#define LL_FIFO_IER_RRC (1 << 23) /* Receive Reset Complete */ - -/* Transmit Data FIFO Reset (TDFR), [1] p13/p14 */ -#define LL_FIFO_TDFR_KEY 0x000000A5UL - -/* Transmit Data FIFO Vacancy (TDFV), [1] p14 */ -#define LL_FIFO_TDFV_POS 0 -#define LL_FIFO_TDFV_MASK (0x000001FFUL << LL_FIFO_TDFV_POS) - -/* Transmit Length FIFO (TLF), [1] p16/p17 */ -#define LL_FIFO_TLF_POS 0 -#define LL_FIFO_TLF_MASK (0x000007FFUL << LL_FIFO_TLF_POS) -#define LL_FIFO_TLF_MIN ((4 * sizeof(u32)) & LL_FIFO_TLF_MASK) -#define LL_FIFO_TLF_MAX ((510 * sizeof(u32)) & LL_FIFO_TLF_MASK) - -/* Receive Data FIFO Reset (RDFR), [1] p15 */ -#define LL_FIFO_RDFR_KEY 0x000000A5UL - -/* Receive Data FIFO Occupancy (RDFO), [1] p16 */ -#define LL_FIFO_RDFO_POS 0 -#define LL_FIFO_RDFO_MASK (0x000001FFUL << LL_FIFO_RDFO_POS) - -/* Receive Length FIFO (RLF), [1] p17/p18 */ -#define LL_FIFO_RLF_POS 0 -#define LL_FIFO_RLF_MASK (0x000007FFUL << LL_FIFO_RLF_POS) -#define LL_FIFO_RLF_MIN ((4 * sizeof(uint32)) & LL_FIFO_RLF_MASK) -#define LL_FIFO_RLF_MAX ((510 * sizeof(uint32)) & LL_FIFO_RLF_MASK) - -/* LocalLink Reset (LLR), [1] p18 */ -#define LL_FIFO_LLR_KEY 0x000000A5UL - - -/* reset FIFO and IRQ, disable interrupts */ -int ll_temac_reset_fifo(struct eth_device *dev); - -/* receive buffered data from FIFO (polling ISR) */ -int ll_temac_recv_fifo(struct eth_device *dev); - -/* send buffered data to FIFO */ -int ll_temac_send_fifo(struct eth_device *dev, void *packet, int length); - -#endif /* _XILINX_LL_TEMAC_FIFO_ */ diff --git a/drivers/net/xilinx_ll_temac_mdio.c b/drivers/net/xilinx_ll_temac_mdio.c deleted file mode 100644 index b7bab794e570..000000000000 --- a/drivers/net/xilinx_ll_temac_mdio.c +++ /dev/null @@ -1,177 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * MDIO bus access - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * CREDITS: tsec driver - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ - -#include <config.h> -#include <common.h> -#include <miiphy.h> -#include <phy.h> -#include <malloc.h> -#include <asm/io.h> - -#include "xilinx_ll_temac.h" -#include "xilinx_ll_temac_mdio.h" - -#if !defined(CONFIG_MII) -# error "LL_TEMAC requires MII -- missing CONFIG_MII" -#endif - -#if !defined(CONFIG_PHYLIB) -# error "LL_TEMAC requires PHYLIB -- missing CONFIG_PHYLIB" -#endif - -/* - * Prior to PHY access, the MDIO clock must be setup. This driver will set a - * safe default that should work with PLB bus speeds of up to 150 MHz and keep - * the MDIO clock below 2.5 MHz. If the user wishes faster access to the PHY - * then the clock divisor can be set to a different value by setting the - * correct bus speed value with CONFIG_XILINX_LL_TEMAC_CLK. - */ -#if !defined(CONFIG_XILINX_LL_TEMAC_CLK) -#define MDIO_CLOCK_DIV MC_CLKDIV_10(150000000) -#else -#define MDIO_CLOCK_DIV MC_CLKDIV_25(CONFIG_XILINX_LL_TEMAC_CLK) -#endif - -static int ll_temac_mdio_setup(struct mii_dev *bus) -{ - struct temac_reg *regs = (struct temac_reg *)bus->priv; - - /* setup MDIO clock */ - ll_temac_indirect_set(regs, TEMAC_MC, - MC_MDIOEN | (MDIO_CLOCK_DIV & MC_CLKDIV_MASK)); - - return 0; -} - -/* - * Indirect MII PHY read via ll_temac. - * - * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... - * page 67, Using the MII Management to Access PHY Registers - */ -int ll_temac_local_mdio_read(struct temac_reg *regs, int addr, int devad, - int regnum) -{ - out_be32(®s->lsw, - ((addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) | - (regnum & LSW_REGAD_MASK)); - out_be32(®s->ctl, TEMAC_MIIMAI); - - ll_temac_check_status(regs, RSE_MIIM_RR); - - return in_be32(®s->lsw) & LSW_REGDAT_MASK; -} - -/* - * Indirect MII PHY write via ll_temac. - * - * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... - * page 67, Using the MII Management to Access PHY Registers - */ -void ll_temac_local_mdio_write(struct temac_reg *regs, int addr, int devad, - int regnum, u16 value) -{ - out_be32(®s->lsw, (value & LSW_REGDAT_MASK)); - out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMWD); - - out_be32(®s->lsw, - ((addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) | - (regnum & LSW_REGAD_MASK)); - out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMAI); - - ll_temac_check_status(regs, RSE_MIIM_WR); -} - -int ll_temac_phy_read(struct mii_dev *bus, int addr, int devad, int regnum) -{ - struct temac_reg *regs = (struct temac_reg *)bus->priv; - - return ll_temac_local_mdio_read(regs, addr, devad, regnum); -} - -int ll_temac_phy_write(struct mii_dev *bus, int addr, int devad, int regnum, - u16 value) -{ - struct temac_reg *regs = (struct temac_reg *)bus->priv; - - ll_temac_local_mdio_write(regs, addr, devad, regnum, value); - - return 0; -} - -/* - * Use MII register 1 (MII status register) to detect PHY - * - * A Mask used to verify certain PHY features (register content) - * in the PHY detection register: - * Auto-negotiation support, 10Mbps half/full duplex support - */ -#define PHY_DETECT_REG MII_BMSR -#define PHY_DETECT_MASK (BMSR_10FULL | BMSR_10HALF | BMSR_ANEGCAPABLE) - -/* Looking for a valid PHY address */ -int ll_temac_phy_addr(struct mii_dev *bus) -{ - struct temac_reg *regs = (struct temac_reg *)bus->priv; - unsigned short val; - unsigned int phy; - - for (phy = PHY_MAX_ADDR; phy >= 0; phy--) { - val = ll_temac_local_mdio_read(regs, phy, 0, PHY_DETECT_REG); - if ((val != 0xFFFF) && - ((val & PHY_DETECT_MASK) == PHY_DETECT_MASK)) { - /* Found a valid PHY address */ - return phy; - } - } - - return -1; -} - -int xilinx_ll_temac_mdio_initialize(bd_t *bis, struct ll_temac_mdio_info *info) -{ - struct mii_dev *bus = mdio_alloc(); - - if (!bus) { - printf("Failed to allocate LL_TEMAC MDIO bus: %s\n", - info->name); - return -1; - } - - bus->read = ll_temac_phy_read; - bus->write = ll_temac_phy_write; - bus->reset = NULL; - - /* use given name or generate its own unique name */ - if (info->name) { - strncpy(bus->name, info->name, MDIO_NAME_LEN); - } else { - snprintf(bus->name, MDIO_NAME_LEN, "lltemii.%p", info->regs); - info->name = bus->name; - } - - bus->priv = info->regs; - - ll_temac_mdio_setup(bus); - return mdio_register(bus); -} diff --git a/drivers/net/xilinx_ll_temac_mdio.h b/drivers/net/xilinx_ll_temac_mdio.h deleted file mode 100644 index 0603c64457f3..000000000000 --- a/drivers/net/xilinx_ll_temac_mdio.h +++ /dev/null @@ -1,50 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * MDIO bus access interface - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ -#ifndef _XILINX_LL_TEMAC_MDIO_ -#define _XILINX_LL_TEMAC_MDIO_ - -#include <net.h> -#include <miiphy.h> - -#include <asm/types.h> -#include <asm/byteorder.h> - -#include "xilinx_ll_temac.h" - -int ll_temac_local_mdio_read(struct temac_reg *regs, int addr, int devad, - int regnum); -void ll_temac_local_mdio_write(struct temac_reg *regs, int addr, int devad, - int regnum, u16 value); - -int ll_temac_phy_read(struct mii_dev *bus, int addr, int devad, int regnum); -int ll_temac_phy_write(struct mii_dev *bus, int addr, int devad, int regnum, - u16 value); - -int ll_temac_phy_addr(struct mii_dev *bus); - -struct ll_temac_mdio_info { - struct temac_reg *regs; - char *name; -}; - -int xilinx_ll_temac_mdio_initialize(bd_t *bis, struct ll_temac_mdio_info *info); - -#endif /* _XILINX_LL_TEMAC_MDIO_ */ diff --git a/drivers/net/xilinx_ll_temac_sdma.c b/drivers/net/xilinx_ll_temac_sdma.c deleted file mode 100644 index 8176f7b4bc34..000000000000 --- a/drivers/net/xilinx_ll_temac_sdma.c +++ /dev/null @@ -1,307 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * SDMA sub-controller - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * CREDITS: tsec driver - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [M]: [0]/ip_documentation/mpmc.pdf - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ - -#include <config.h> -#include <common.h> -#include <net.h> - -#include <asm/types.h> -#include <asm/io.h> - -#include "xilinx_ll_temac.h" -#include "xilinx_ll_temac_sdma.h" - -#define TX_BUF_CNT 2 - -static unsigned int rx_idx; /* index of the current RX buffer */ -static unsigned int tx_idx; /* index of the current TX buffer */ - -struct rtx_cdmac_bd { - struct cdmac_bd rx[PKTBUFSRX]; - struct cdmac_bd tx[TX_BUF_CNT]; -}; - -/* - * DMA Buffer Descriptor alignment - * - * If the address contained in the Next Descriptor Pointer register is not - * 8-word aligned or reaches beyond the range of available memory, the SDMA - * halts processing and sets the CDMAC_BD_STCTRL_ERROR bit in the respective - * status register (tx_chnl_sts or rx_chnl_sts). - * - * [1]: [0]/ip_documentation/mpmc.pdf - * page 161, Next Descriptor Pointer - */ -static struct rtx_cdmac_bd cdmac_bd __aligned(32); - -/* Xilinx Processor Local Bus (PLB) in/out accessors */ -inline unsigned ll_temac_xlplb_in32(phys_addr_t addr) -{ - return in_be32((void *)addr); -} -inline void ll_temac_xlplb_out32(phys_addr_t addr, unsigned value) -{ - out_be32((void *)addr, value); -} - -/* collect all register addresses for Xilinx PLB in/out accessors */ -void ll_temac_collect_xlplb_sdma_reg_addr(struct eth_device *dev) -{ - struct ll_temac *ll_temac = dev->priv; - struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - - ra[TX_NXTDESC_PTR] = (phys_addr_t)&sdma_ctrl->tx_nxtdesc_ptr; - ra[TX_CURBUF_ADDR] = (phys_addr_t)&sdma_ctrl->tx_curbuf_addr; - ra[TX_CURBUF_LENGTH] = (phys_addr_t)&sdma_ctrl->tx_curbuf_length; - ra[TX_CURDESC_PTR] = (phys_addr_t)&sdma_ctrl->tx_curdesc_ptr; - ra[TX_TAILDESC_PTR] = (phys_addr_t)&sdma_ctrl->tx_taildesc_ptr; - ra[TX_CHNL_CTRL] = (phys_addr_t)&sdma_ctrl->tx_chnl_ctrl; - ra[TX_IRQ_REG] = (phys_addr_t)&sdma_ctrl->tx_irq_reg; - ra[TX_CHNL_STS] = (phys_addr_t)&sdma_ctrl->tx_chnl_sts; - ra[RX_NXTDESC_PTR] = (phys_addr_t)&sdma_ctrl->rx_nxtdesc_ptr; - ra[RX_CURBUF_ADDR] = (phys_addr_t)&sdma_ctrl->rx_curbuf_addr; - ra[RX_CURBUF_LENGTH] = (phys_addr_t)&sdma_ctrl->rx_curbuf_length; - ra[RX_CURDESC_PTR] = (phys_addr_t)&sdma_ctrl->rx_curdesc_ptr; - ra[RX_TAILDESC_PTR] = (phys_addr_t)&sdma_ctrl->rx_taildesc_ptr; - ra[RX_CHNL_CTRL] = (phys_addr_t)&sdma_ctrl->rx_chnl_ctrl; - ra[RX_IRQ_REG] = (phys_addr_t)&sdma_ctrl->rx_irq_reg; - ra[RX_CHNL_STS] = (phys_addr_t)&sdma_ctrl->rx_chnl_sts; - ra[DMA_CONTROL_REG] = (phys_addr_t)&sdma_ctrl->dma_control_reg; -} - -/* Check for TX and RX channel errors. */ -static inline int ll_temac_sdma_error(struct eth_device *dev) -{ - int err; - struct ll_temac *ll_temac = dev->priv; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - - err = ll_temac->in32(ra[TX_CHNL_STS]) & CHNL_STS_ERROR; - err |= ll_temac->in32(ra[RX_CHNL_STS]) & CHNL_STS_ERROR; - - return err; -} - -int ll_temac_init_sdma(struct eth_device *dev) -{ - struct ll_temac *ll_temac = dev->priv; - struct cdmac_bd *rx_dp; - struct cdmac_bd *tx_dp; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - int i; - - printf("%s: SDMA: %d Rx buffers, %d Tx buffers\n", - dev->name, PKTBUFSRX, TX_BUF_CNT); - - /* Initialize the Rx Buffer descriptors */ - for (i = 0; i < PKTBUFSRX; i++) { - rx_dp = &cdmac_bd.rx[i]; - memset(rx_dp, 0, sizeof(*rx_dp)); - rx_dp->next_p = rx_dp; - rx_dp->buf_len = PKTSIZE_ALIGN; - rx_dp->phys_buf_p = (u8 *)net_rx_packets[i]; - flush_cache((u32)rx_dp->phys_buf_p, PKTSIZE_ALIGN); - } - flush_cache((u32)cdmac_bd.rx, sizeof(cdmac_bd.rx)); - - /* Initialize the TX Buffer Descriptors */ - for (i = 0; i < TX_BUF_CNT; i++) { - tx_dp = &cdmac_bd.tx[i]; - memset(tx_dp, 0, sizeof(*tx_dp)); - tx_dp->next_p = tx_dp; - } - flush_cache((u32)cdmac_bd.tx, sizeof(cdmac_bd.tx)); - - /* Reset index counter to the Rx and Tx Buffer descriptors */ - rx_idx = tx_idx = 0; - - /* initial Rx DMA start by writing to respective TAILDESC_PTR */ - ll_temac->out32(ra[RX_CURDESC_PTR], (int)&cdmac_bd.rx[rx_idx]); - ll_temac->out32(ra[RX_TAILDESC_PTR], (int)&cdmac_bd.rx[rx_idx]); - - return 0; -} - -int ll_temac_halt_sdma(struct eth_device *dev) -{ - unsigned timeout = 50; /* 1usec * 50 = 50usec */ - struct ll_temac *ll_temac = dev->priv; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - - /* - * Soft reset the DMA - * - * Quote from MPMC documentation: Writing a 1 to this field - * forces the DMA engine to shutdown and reset itself. After - * setting this bit, software must poll it until the bit is - * cleared by the DMA. This indicates that the reset process - * is done and the pipeline has been flushed. - */ - ll_temac->out32(ra[DMA_CONTROL_REG], DMA_CONTROL_RESET); - while (timeout && (ll_temac->in32(ra[DMA_CONTROL_REG]) - & DMA_CONTROL_RESET)) { - timeout--; - udelay(1); - } - - if (!timeout) { - printf("%s: Timeout\n", __func__); - return -1; - } - - return 0; -} - -int ll_temac_reset_sdma(struct eth_device *dev) -{ - u32 r; - struct ll_temac *ll_temac = dev->priv; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - - /* Soft reset the DMA. */ - if (ll_temac_halt_sdma(dev)) - return -1; - - /* Now clear the interrupts. */ - r = ll_temac->in32(ra[TX_CHNL_CTRL]); - r &= ~CHNL_CTRL_IRQ_MASK; - ll_temac->out32(ra[TX_CHNL_CTRL], r); - - r = ll_temac->in32(ra[RX_CHNL_CTRL]); - r &= ~CHNL_CTRL_IRQ_MASK; - ll_temac->out32(ra[RX_CHNL_CTRL], r); - - /* Now ACK pending IRQs. */ - ll_temac->out32(ra[TX_IRQ_REG], IRQ_REG_IRQ_MASK); - ll_temac->out32(ra[RX_IRQ_REG], IRQ_REG_IRQ_MASK); - - /* Set tail-ptr mode, disable errors for both channels. */ - ll_temac->out32(ra[DMA_CONTROL_REG], - /* Enable use of tail pointer register */ - DMA_CONTROL_TPE | - /* Disable error when 2 or 4 bit coalesce cnt overfl */ - DMA_CONTROL_RXOCEID | - /* Disable error when 2 or 4 bit coalesce cnt overfl */ - DMA_CONTROL_TXOCEID); - - return 0; -} - -int ll_temac_recv_sdma(struct eth_device *dev) -{ - int length, pb_idx; - struct cdmac_bd *rx_dp = &cdmac_bd.rx[rx_idx]; - struct ll_temac *ll_temac = dev->priv; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - - if (ll_temac_sdma_error(dev)) { - - if (ll_temac_reset_sdma(dev)) - return -1; - - ll_temac_init_sdma(dev); - } - - flush_cache((u32)rx_dp, sizeof(*rx_dp)); - - if (!(rx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)) - return 0; - - if (rx_dp->sca.stctrl & (CDMAC_BD_STCTRL_SOP | CDMAC_BD_STCTRL_EOP)) { - pb_idx = rx_idx; - length = rx_dp->sca.app[4] & CDMAC_BD_APP4_RXBYTECNT_MASK; - } else { - pb_idx = -1; - length = 0; - printf("%s: Got part of package, unsupported (%x)\n", - __func__, rx_dp->sca.stctrl); - } - - /* flip the buffer */ - flush_cache((u32)rx_dp->phys_buf_p, length); - - /* reset the current descriptor */ - rx_dp->sca.stctrl = 0; - rx_dp->sca.app[4] = 0; - flush_cache((u32)rx_dp, sizeof(*rx_dp)); - - /* Find next empty buffer descriptor, preparation for next iteration */ - rx_idx = (rx_idx + 1) % PKTBUFSRX; - rx_dp = &cdmac_bd.rx[rx_idx]; - flush_cache((u32)rx_dp, sizeof(*rx_dp)); - - /* DMA start by writing to respective TAILDESC_PTR */ - ll_temac->out32(ra[RX_CURDESC_PTR], (int)&cdmac_bd.rx[rx_idx]); - ll_temac->out32(ra[RX_TAILDESC_PTR], (int)&cdmac_bd.rx[rx_idx]); - - if (length > 0 && pb_idx != -1) - net_process_received_packet(net_rx_packets[pb_idx], length); - - return 0; -} - -int ll_temac_send_sdma(struct eth_device *dev, void *packet, int length) -{ - unsigned timeout = 50; /* 1usec * 50 = 50usec */ - struct cdmac_bd *tx_dp = &cdmac_bd.tx[tx_idx]; - struct ll_temac *ll_temac = dev->priv; - phys_addr_t *ra = ll_temac->sdma_reg_addr; - - if (ll_temac_sdma_error(dev)) { - - if (ll_temac_reset_sdma(dev)) - return -1; - - ll_temac_init_sdma(dev); - } - - tx_dp->phys_buf_p = (u8 *)packet; - tx_dp->buf_len = length; - tx_dp->sca.stctrl = CDMAC_BD_STCTRL_SOP | CDMAC_BD_STCTRL_EOP | - CDMAC_BD_STCTRL_STOP_ON_END; - - flush_cache((u32)packet, length); - flush_cache((u32)tx_dp, sizeof(*tx_dp)); - - /* DMA start by writing to respective TAILDESC_PTR */ - ll_temac->out32(ra[TX_CURDESC_PTR], (int)tx_dp); - ll_temac->out32(ra[TX_TAILDESC_PTR], (int)tx_dp); - - /* Find next empty buffer descriptor, preparation for next iteration */ - tx_idx = (tx_idx + 1) % TX_BUF_CNT; - tx_dp = &cdmac_bd.tx[tx_idx]; - - do { - flush_cache((u32)tx_dp, sizeof(*tx_dp)); - udelay(1); - } while (timeout-- && !(tx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)); - - if (!timeout) { - printf("%s: Timeout\n", __func__); - return -1; - } - - return 0; -} diff --git a/drivers/net/xilinx_ll_temac_sdma.h b/drivers/net/xilinx_ll_temac_sdma.h deleted file mode 100644 index 67a8b0f2ef04..000000000000 --- a/drivers/net/xilinx_ll_temac_sdma.h +++ /dev/null @@ -1,266 +0,0 @@ -/* - * Xilinx xps_ll_temac ethernet driver for u-boot - * - * SDMA sub-controller interface - * - * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net - * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu - * Copyright (C) 2008 - 2011 PetaLogix - * - * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver - * Copyright (C) 2008 Nissin Systems Co.,Ltd. - * March 2008 created - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_ll_temac.pdf - * [A]: [0]/application_notes/xapp1041.pdf - */ -#ifndef _XILINX_LL_TEMAC_SDMA_ -#define _XILINX_LL_TEMAC_SDMA_ - -#include <net.h> - -#include <asm/types.h> -#include <asm/byteorder.h> - -#include <linux/compiler.h> - -#if !defined(__BIG_ENDIAN) -# error LL_TEMAC requires big endianess -#endif - -/* - * DMA Buffer Descriptor for CDMAC - * - * Used for data connection from and to (Rx/Tx) the LocalLink (LL) TEMAC via - * the Communications Direct Memory Access Controller (CDMAC) -- one for each. - * - * overview: - * ftp://ftp.xilinx.com/pub/documentation/misc/mpmc_getting_started.pdf - * - * [1]: [0]/ip_documentation/mpmc.pdf - * page 140, DMA Operation Descriptors - * - * [2]: [0]/user_guides/ug200.pdf - * page 229, DMA Controller -- Descriptor Format - * - * [3]: [0]/ip_documentation/xps_ll_temac.pdf - * page 72, Transmit LocalLink Frame Format - * page 73, Receive LocalLink Frame Format - */ -struct cdmac_bd { - struct cdmac_bd *next_p; /* Next Descriptor Pointer */ - u8 *phys_buf_p; /* Buffer Address */ - u32 buf_len; /* Buffer Length */ - union { - u8 stctrl; /* Status/Control the DMA transfer */ - u32 app[5]; /* application specific data */ - } __packed __aligned(1) sca; -}; - -/* CDMAC Descriptor Status and Control (stctrl), [1] p140, [2] p230 */ -#define CDMAC_BD_STCTRL_ERROR (1 << 7) -#define CDMAC_BD_STCTRL_IRQ_ON_END (1 << 6) -#define CDMAC_BD_STCTRL_STOP_ON_END (1 << 5) -#define CDMAC_BD_STCTRL_COMPLETED (1 << 4) -#define CDMAC_BD_STCTRL_SOP (1 << 3) -#define CDMAC_BD_STCTRL_EOP (1 << 2) -#define CDMAC_BD_STCTRL_DMACHBUSY (1 << 1) - -/* CDMAC Descriptor APP0: Transmit LocalLink Footer Word 3, [3] p72 */ -#define CDMAC_BD_APP0_TXCSCNTRL (1 << 0) - -/* CDMAC Descriptor APP1: Transmit LocalLink Footer Word 4, [3] p73 */ -#define CDMAC_BD_APP1_TXCSBEGIN_POS 16 -#define CDMAC_BD_APP1_TXCSBEGIN_MASK (0xFFFF << CDMAC_BD_APP1_TXCSBEGIN_POS) -#define CDMAC_BD_APP1_TXCSINSERT_POS 0 -#define CDMAC_BD_APP1_TXCSINSERT_MASK (0xFFFF << CDMAC_BD_APP1_TXCSINSERT_POS) - -/* CDMAC Descriptor APP2: Transmit LocalLink Footer Word 5, [3] p73 */ -#define CDMAC_BD_APP2_TXCSINIT_POS 0 -#define CDMAC_BD_APP2_TXCSINIT_MASK (0xFFFF << CDMAC_BD_APP2_TXCSINIT_POS) - -/* CDMAC Descriptor APP0: Receive LocalLink Footer Word 3, [3] p73 */ -#define CDMAC_BD_APP0_MADDRU_POS 0 -#define CDMAC_BD_APP0_MADDRU_MASK (0xFFFF << CDMAC_BD_APP0_MADDRU_POS) - -/* CDMAC Descriptor APP1: Receive LocalLink Footer Word 4, [3] p74 */ -#define CDMAC_BD_APP1_MADDRL_POS 0 -#define CDMAC_BD_APP1_MADDRL_MASK (~0UL << CDMAC_BD_APP1_MADDRL_POS) - -/* CDMAC Descriptor APP2: Receive LocalLink Footer Word 5, [3] p74 */ -#define CDMAC_BD_APP2_BCAST_FRAME (1 << 2) -#define CDMAC_BD_APP2_IPC_MCAST_FRAME (1 << 1) -#define CDMAC_BD_APP2_MAC_MCAST_FRAME (1 << 0) - -/* CDMAC Descriptor APP3: Receive LocalLink Footer Word 6, [3] p74 */ -#define CDMAC_BD_APP3_TLTPID_POS 16 -#define CDMAC_BD_APP3_TLTPID_MASK (0xFFFF << CDMAC_BD_APP3_TLTPID_POS) -#define CDMAC_BD_APP3_RXCSRAW_POS 0 -#define CDMAC_BD_APP3_RXCSRAW_MASK (0xFFFF << CDMAC_BD_APP3_RXCSRAW_POS) - -/* CDMAC Descriptor APP4: Receive LocalLink Footer Word 7, [3] p74 */ -#define CDMAC_BD_APP4_VLANTAG_POS 16 -#define CDMAC_BD_APP4_VLANTAG_MASK (0xFFFF << CDMAC_BD_APP4_VLANTAG_POS) -#define CDMAC_BD_APP4_RXBYTECNT_POS 0 -#define CDMAC_BD_APP4_RXBYTECNT_MASK (0x3FFF << CDMAC_BD_APP4_RXBYTECNT_POS) - -/* - * SDMA Register Definition - * - * [0]: http://www.xilinx.com/support/documentation - * - * [1]: [0]/ip_documentation/mpmc.pdf - * page 54, SDMA Register Summary - * page 160, SDMA Registers - * - * [2]: [0]/user_guides/ug200.pdf - * page 244, DMA Controller -- Programming Interface and Registers - */ -#define SDMA_CTRL_REGTYPE u32 -#define SDMA_CTRL_REGSIZE sizeof(SDMA_CTRL_REGTYPE) -struct sdma_ctrl { - /* Transmit Registers */ - SDMA_CTRL_REGTYPE tx_nxtdesc_ptr; /* TX Next Description Pointer */ - SDMA_CTRL_REGTYPE tx_curbuf_addr; /* TX Current Buffer Address */ - SDMA_CTRL_REGTYPE tx_curbuf_length; /* TX Current Buffer Length */ - SDMA_CTRL_REGTYPE tx_curdesc_ptr; /* TX Current Descriptor Pointer */ - SDMA_CTRL_REGTYPE tx_taildesc_ptr; /* TX Tail Descriptor Pointer */ - SDMA_CTRL_REGTYPE tx_chnl_ctrl; /* TX Channel Control */ - SDMA_CTRL_REGTYPE tx_irq_reg; /* TX Interrupt Register */ - SDMA_CTRL_REGTYPE tx_chnl_sts; /* TX Status Register */ - /* Receive Registers */ - SDMA_CTRL_REGTYPE rx_nxtdesc_ptr; /* RX Next Descriptor Pointer */ - SDMA_CTRL_REGTYPE rx_curbuf_addr; /* RX Current Buffer Address */ - SDMA_CTRL_REGTYPE rx_curbuf_length; /* RX Current Buffer Length */ - SDMA_CTRL_REGTYPE rx_curdesc_ptr; /* RX Current Descriptor Pointer */ - SDMA_CTRL_REGTYPE rx_taildesc_ptr; /* RX Tail Descriptor Pointer */ - SDMA_CTRL_REGTYPE rx_chnl_ctrl; /* RX Channel Control */ - SDMA_CTRL_REGTYPE rx_irq_reg; /* RX Interrupt Register */ - SDMA_CTRL_REGTYPE rx_chnl_sts; /* RX Status Register */ - /* Control Registers */ - SDMA_CTRL_REGTYPE dma_control_reg; /* DMA Control Register */ -}; - -#define SDMA_CTRL_REGNUMS sizeof(struct sdma_ctrl)/SDMA_CTRL_REGSIZE - -/* - * DMAC Register Index Enumeration - * - * [2]: http://www.xilinx.com/support/documentation/user_guides/ug200.pdf - * page 244, DMA Controller -- Programming Interface and Registers - */ -enum dmac_ctrl { - /* Transmit Registers */ - TX_NXTDESC_PTR = 0, /* TX Next Description Pointer */ - TX_CURBUF_ADDR, /* TX Current Buffer Address */ - TX_CURBUF_LENGTH, /* TX Current Buffer Length */ - TX_CURDESC_PTR, /* TX Current Descriptor Pointer */ - TX_TAILDESC_PTR, /* TX Tail Descriptor Pointer */ - TX_CHNL_CTRL, /* TX Channel Control */ - TX_IRQ_REG, /* TX Interrupt Register */ - TX_CHNL_STS, /* TX Status Register */ - /* Receive Registers */ - RX_NXTDESC_PTR, /* RX Next Descriptor Pointer */ - RX_CURBUF_ADDR, /* RX Current Buffer Address */ - RX_CURBUF_LENGTH, /* RX Current Buffer Length */ - RX_CURDESC_PTR, /* RX Current Descriptor Pointer */ - RX_TAILDESC_PTR, /* RX Tail Descriptor Pointer */ - RX_CHNL_CTRL, /* RX Channel Control */ - RX_IRQ_REG, /* RX Interrupt Register */ - RX_CHNL_STS, /* RX Status Register */ - /* Control Registers */ - DMA_CONTROL_REG /* DMA Control Register */ -}; - -/* Rx/Tx Channel Control Register (*_chnl_ctrl), [1] p163, [2] p246/p252 */ -#define CHNL_CTRL_ITO_POS 24 -#define CHNL_CTRL_ITO_MASK (0xFF << CHNL_CTRL_ITO_POS) -#define CHNL_CTRL_IC_POS 16 -#define CHNL_CTRL_IC_MASK (0xFF << CHNL_CTRL_IC_POS) -#define CHNL_CTRL_MSBADDR_POS 12 -#define CHNL_CTRL_MSBADDR_MASK (0xF << CHNL_CTRL_MSBADDR_POS) -#define CHNL_CTRL_AME (1 << 11) -#define CHNL_CTRL_OBWC (1 << 10) -#define CHNL_CTRL_IOE (1 << 9) -#define CHNL_CTRL_LIC (1 << 8) -#define CHNL_CTRL_IE (1 << 7) -#define CHNL_CTRL_IEE (1 << 2) -#define CHNL_CTRL_IDE (1 << 1) -#define CHNL_CTRL_ICE (1 << 0) - -/* All interrupt enable bits */ -#define CHNL_CTRL_IRQ_MASK (CHNL_CTRL_IE | \ - CHNL_CTRL_IEE | \ - CHNL_CTRL_IDE | \ - CHNL_CTRL_ICE) - -/* Rx/Tx Interrupt Status Register (*_irq_reg), [1] p164, [2] p247/p253 */ -#define IRQ_REG_DTV_POS 24 -#define IRQ_REG_DTV_MASK (0xFF << IRQ_REG_DTV_POS) -#define IRQ_REG_CCV_POS 16 -#define IRQ_REG_CCV_MASK (0xFF << IRQ_REG_CCV_POS) -#define IRQ_REG_WRCQ_EMPTY (1 << 14) -#define IRQ_REG_CIC_POS 10 -#define IRQ_REG_CIC_MASK (0xF << IRQ_REG_CIC_POS) -#define IRQ_REG_DIC_POS 8 -#define IRQ_REG_DIC_MASK (3 << 8) -#define IRQ_REG_PLB_RD_NMI (1 << 4) -#define IRQ_REG_PLB_WR_NMI (1 << 3) -#define IRQ_REG_EI (1 << 2) -#define IRQ_REG_DI (1 << 1) -#define IRQ_REG_CI (1 << 0) - -/* All interrupt bits */ -#define IRQ_REG_IRQ_MASK (IRQ_REG_PLB_RD_NMI | \ - IRQ_REG_PLB_WR_NMI | \ - IRQ_REG_EI | IRQ_REG_DI | IRQ_REG_CI) - -/* Rx/Tx Channel Status Register (*_chnl_sts), [1] p165, [2] p249/p255 */ -#define CHNL_STS_ERROR_TAIL (1 << 21) -#define CHNL_STS_ERROR_CMP (1 << 20) -#define CHNL_STS_ERROR_ADDR (1 << 19) -#define CHNL_STS_ERROR_NXTP (1 << 18) -#define CHNL_STS_ERROR_CURP (1 << 17) -#define CHNL_STS_ERROR_BSYWR (1 << 16) -#define CHNL_STS_ERROR (1 << 7) -#define CHNL_STS_IOE (1 << 6) -#define CHNL_STS_SOE (1 << 5) -#define CHNL_STS_CMPLT (1 << 4) -#define CHNL_STS_SOP (1 << 3) -#define CHNL_STS_EOP (1 << 2) -#define CHNL_STS_EBUSY (1 << 1) - -/* DMA Control Register (dma_control_reg), [1] p166, [2] p256 */ -#define DMA_CONTROL_PLBED (1 << 5) -#define DMA_CONTROL_RXOCEID (1 << 4) -#define DMA_CONTROL_TXOCEID (1 << 3) -#define DMA_CONTROL_TPE (1 << 2) -#define DMA_CONTROL_RESET (1 << 0) - -/* Xilinx Processor Local Bus (PLB) in/out accessors */ -unsigned ll_temac_xlplb_in32(phys_addr_t base); -void ll_temac_xlplb_out32(phys_addr_t base, unsigned value); - -/* collect all register addresses for Xilinx PLB in/out accessors */ -void ll_temac_collect_xlplb_sdma_reg_addr(struct eth_device *dev); - -/* initialize both Rx/Tx buffer descriptors */ -int ll_temac_init_sdma(struct eth_device *dev); - -/* halt both Rx/Tx transfers */ -int ll_temac_halt_sdma(struct eth_device *dev); - -/* reset SDMA and IRQ, disable interrupts and errors */ -int ll_temac_reset_sdma(struct eth_device *dev); - -/* receive buffered data from SDMA (polling ISR) */ -int ll_temac_recv_sdma(struct eth_device *dev); - -/* send buffered data to SDMA */ -int ll_temac_send_sdma(struct eth_device *dev, void *packet, int length); - -#endif /* _XILINX_LL_TEMAC_SDMA_ */ diff --git a/include/netdev.h b/include/netdev.h index b9bfebac67f7..a3c04e0bb5d6 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -76,17 +76,7 @@ int tsi108_eth_initialize(bd_t *bis); int uec_standard_init(bd_t *bis); int uli526x_initialize(bd_t *bis); int armada100_fec_register(unsigned long base_addr); -int xilinx_ll_temac_eth_init(bd_t *bis, unsigned long base_addr, int flags, unsigned long ctrl_addr); -/* - * As long as the Xilinx xps_ll_temac ethernet driver has not its own interface - * exported by a public hader file, we need a global definition at this point. - */ -#if defined(CONFIG_XILINX_LL_TEMAC) -#define XILINX_LL_TEMAC_M_FIFO 0 /* use FIFO Ctrl */ -#define XILINX_LL_TEMAC_M_SDMA_PLB (1 << 0)/* use SDMA Ctrl via PLB */ -#define XILINX_LL_TEMAC_M_SDMA_DCR (1 << 1)/* use SDMA Ctrl via DCR */ -#endif
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board. diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4ac89cdde0c6..00fe5da72d05 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4887,7 +4887,6 @@ CONFIG_X86_REFCODE_ADDR CONFIG_X86_REFCODE_RUN_ADDR CONFIG_XGI_XG22_BASE CONFIG_XILINX_GPIO -CONFIG_XILINX_LL_TEMAC_CLK CONFIG_XILINX_SPI_IDLE_VAL CONFIG_XILINX_TB_WATCHDOG CONFIG_XR16L2751
Joe Hershberger
Michal Simek
