[U-Boot] [PATCH][v6] powerpc/mpc85xx: SECURE BOOT- Add secure boot target for B4860QDS
Changes: 1. L2 cache is being invalidated by Boot ROM code for e6500 core. So removing the invalidation from start.S 2. Clear the LAW and corresponding configuration for CPC. Boot ROM code uses it as hosekeeping area. 3. For Secure boot, CPC is configured as SRAM and used as house keeping area. This configuration is to be disabled once in uboot. Earlier this disabling of CPC as SRAM was happening in cpu_init_r. As a result cache invalidation function was getting skipped in case CPC is configured as SRAM.This was causing random crashes.
Signed-off-by: Aneesh Bansal aneesh.bansal@freescale.com Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com --- README | 4 ++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 27 ++++++++++++++++++++++----- arch/powerpc/cpu/mpc85xx/start.S | 3 ++- arch/powerpc/include/asm/fsl_secure_boot.h | 6 ++++++ boards.cfg | 1 + 5 files changed, 35 insertions(+), 6 deletions(-)
Changes from v4: Renamed the macro to indicate CPC configured as SRAM at U-boot entry to CONFIG_SYS_CPC_REINIT_F
Changes from v5: Corrected the Signed Off
diff --git a/README b/README index 216f0c7..e574d68 100644 --- a/README +++ b/README @@ -427,6 +427,10 @@ The following options need to be configured: In this mode, a single differential clock is used to supply clocks to the sysclock, ddrclock and usbclock.
+ CONFIG_SYS_CPC_REINIT_F + This CONFIG is defined when the CPC is configured as SRAM at the + time of U-boot entry and is required to be re-initialized. + - Generic CPU options: CONFIG_SYS_BIG_ENDIAN, CONFIG_SYS_LITTLE_ENDIAN
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 81aeadd..570965f 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -173,17 +173,14 @@ void config_8560_ioports (volatile ccsr_cpm_t * cpm) #endif
#ifdef CONFIG_SYS_FSL_CPC -static void enable_cpc(void) +#if defined(CONFIG_RAMBOOT_PBL) || defined(CONFIG_SYS_CPC_REINIT_F) +static void disable_cpc_sram(void) { int i; - u32 size = 0;
cpc_corenet_t *cpc = (cpc_corenet_t *)CONFIG_SYS_FSL_CPC_ADDR;
for (i = 0; i < CONFIG_SYS_NUM_CPC; i++, cpc++) { - u32 cpccfg0 = in_be32(&cpc->cpccfg0); - size += CPC_CFG0_SZ_K(cpccfg0); -#ifdef CONFIG_RAMBOOT_PBL if (in_be32(&cpc->cpcsrcr0) & CPC_SRCR0_SRAMEN) { /* find and disable LAW of SRAM */ struct law_entry law = find_law(CONFIG_SYS_INIT_L3_ADDR); @@ -198,8 +195,21 @@ static void enable_cpc(void) out_be32(&cpc->cpccsr0, 0); out_be32(&cpc->cpcsrcr0, 0); } + } +} #endif
+static void enable_cpc(void) +{ + int i; + u32 size = 0; + + cpc_corenet_t *cpc = (cpc_corenet_t *)CONFIG_SYS_FSL_CPC_ADDR; + + for (i = 0; i < CONFIG_SYS_NUM_CPC; i++, cpc++) { + u32 cpccfg0 = in_be32(&cpc->cpccfg0); + size += CPC_CFG0_SZ_K(cpccfg0); + #ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A002 setbits_be32(&cpc->cpchdbcr0, CPC_HDBCR0_TAG_ECC_SCRUB_DIS); #endif @@ -298,6 +308,10 @@ void cpu_init_f (void) law = find_law(CONFIG_SYS_PBI_FLASH_BASE); if (law.index != -1) disable_law(law.index); + +#if defined(CONFIG_SYS_CPC_REINIT_F) + disable_cpc_sram(); +#endif #endif
#ifdef CONFIG_CPM2 @@ -598,6 +612,9 @@ skip_l2: puts("disabled\n"); #endif
+#if defined(CONFIG_RAMBOOT_PBL) + disable_cpc_sram(); +#endif enable_cpc();
#ifndef CONFIG_SYS_FSL_NO_SERDES diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index dbbd8e5..4ef0985 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -115,7 +115,8 @@ _start_e500: #endif
-#if defined(CONFIG_SECURE_BOOT) && defined(CONFIG_E500MC) +#if defined(CONFIG_SECURE_BOOT) && defined(CONFIG_E500MC) && \ + !defined(CONFIG_E6500) /* ISBC uses L2 as stack. * Disable L2 cache here so that u-boot can enable it later * as part of it's normal flow diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 4c7f0b1..8f5bf10 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -15,5 +15,11 @@ #endif #define CONFIG_SYS_PBI_FLASH_WINDOW 0xcff80000
+#if defined(CONFIG_B4860QDS) +#define CONFIG_SYS_CPC_REINIT_F +#undef CONFIG_SYS_INIT_L3_ADDR +#define CONFIG_SYS_INIT_L3_ADDR 0xbff00000 +#endif + #endif #endif diff --git a/boards.cfg b/boards.cfg index a32f46b..cf2b1df 100644 --- a/boards.cfg +++ b/boards.cfg @@ -782,6 +782,7 @@ Active powerpc mpc85xx - freescale b4860qds Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4420QDS_SPIFLASH B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS B4860QDS:PPC_B4860 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_SECURE_BOOT B4860QDS:PPC_B4860,SECURE_BOOT Aneesh Bansal aneesh.bansal@freescale.com Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS_SPIFLASH B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS_SRIO_PCIE_BOOT B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 -
Aneesh Bansal
