[U-Boot] please pull u-boot-samsung master
Hi Tom,
The following changes since commit e8e3f2d2d48f97b2c79b698eccedce8f4f880993:
Merge branch '2019-03-08-master-imports' (2019-03-08 18:04:13 -0500)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to 0fd36730396a86e5513b45221af60889e6028654:
ARM: Odroid XU3: Enable driver I2C support for OdroidXU3 (2019-03-12 15:56:45 +0900)
---------------------------------------------------------------- Anand Moon (1): ARM: Odroid XU3: Enable driver I2C support for OdroidXU3
Krzysztof Kozlowski (15): adc: exynos-adc: Fix wrong bit operation used to stop the ADC power: regulator: s2mps11: Fix step for LDO27 and LDO35 arm: exynos: Detect revision later, when all resources are ready arm: exynos: odroid-xu3: Display info late to have proper type arm: exynos: Wait till ADC stabilizes before checking Odroid HC1 revision regulator: Add support for ramp delay power: regulator: s2mps11: Add enable delay arm: dts: exynos: Add supply for ADC block to Odroid XU3 family arm: dts: exynos: Add ramp delay property to LDO regulators to Odroid XU3 family arm: exynos: arndale: Replace Chander Kashyap inactive maintainer configs: odroid_xu3: Use consistent syntax for #include configs: odroid_xu3: Unify indentation arm: exynos: Remove duplicated "boardname" env setting arm: dts: exynos: Adjust whitespace around status property arm: exynos: odroid: Fix build if BOARD_TYPES are not set
Minkyu Kang (1): espresso7420: remove duplicated config
arch/arm/dts/exynos5422-odroidxu3.dts | 22 +++++++++++++++++++++- board/samsung/arndale/MAINTAINERS | 4 ++-- board/samsung/common/board.c | 25 +++++++++++++++++++++++-- board/samsung/common/bootscripts/autoboot.cmd | 10 +++++----- board/samsung/common/exynos5-dt-types.c | 54 ++++++++++++++++++++++++++++++++++++++++++++++++++---- board/samsung/common/misc.c | 2 +- board/samsung/odroid/odroid.c | 35 +++++++++++++++++++++++++++++------ configs/odroid-xu3_defconfig | 3 +++ doc/device-tree-bindings/regulator/regulator.txt | 2 ++ drivers/adc/exynos-adc.c | 2 +- drivers/power/regulator/regulator-uclass.c | 47 +++++++++++++++++++++++++++++++++++++++++++++-- drivers/power/regulator/s2mps11_regulator.c | 15 ++++++++++++++- include/configs/espresso7420.h | 2 -- include/configs/odroid.h | 2 +- include/configs/odroid_xu3.h | 20 ++++++++++++-------- include/power/regulator.h | 2 ++ include/samsung/misc.h | 1 + 17 files changed, 212 insertions(+), 36 deletions(-)
On Tue, Mar 12, 2019 at 05:23:37PM +0900, Minkyu Kang wrote:
Hi Tom,
NAK: $ ./tools/genboardscfg.py -f WARNING: Odd Fixes: unknown status for 'arndale'
Hi Tom,
for you to fetch changes up to 1411298cbca83a8527d2c1b5c4d299871fc34cf1:
arndale: fix unknown status (2019-03-14 09:38:41 +0900)
Minkyu Kang (2): espresso7420: remove duplicated config arndale: fix unknown status
arch/arm/dts/exynos5422-odroidxu3.dts | 22 +++++++++++++++++++++- board/samsung/arndale/MAINTAINERS | 2 +- board/samsung/common/board.c | 25 +++++++++++++++++++++++-- board/samsung/common/bootscripts/autoboot.cmd | 10 +++++----- board/samsung/common/exynos5-dt-types.c | 54 ++++++++++++++++++++++++++++++++++++++++++++++++++---- board/samsung/common/misc.c | 2 +- board/samsung/odroid/odroid.c | 35 +++++++++++++++++++++++++++++------ configs/odroid-xu3_defconfig | 3 +++ doc/device-tree-bindings/regulator/regulator.txt | 2 ++ drivers/adc/exynos-adc.c | 2 +- drivers/power/regulator/regulator-uclass.c | 47 +++++++++++++++++++++++++++++++++++++++++++++-- drivers/power/regulator/s2mps11_regulator.c | 15 ++++++++++++++- include/configs/espresso7420.h | 2 -- include/configs/odroid.h | 2 +- include/configs/odroid_xu3.h | 20 ++++++++++++-------- include/power/regulator.h | 2 ++ include/samsung/misc.h | 1 + 17 files changed, 211 insertions(+), 35 deletions(-)
On Thu, Mar 14, 2019 at 01:12:41PM +0900, Minkyu Kang wrote:
Hi Tom,
Hi Tom,
Hi Tom,
That's the valid entry from MAINTAINERS so one of them should be updated (either remove Odd fixes or accept it).
Best regards, Krzysztof
Krzysztof Kozlowski
Minkyu Kang
