[PATCH] arm: imx: Fix spl imx romapi for imx8mn
We experimenting problems with imx8mn family cpu. We try to support boot0 and boot1 fallback. The condition to decide what function the bootrom should choose come from is_boot_from_stream_device
This is a boot from mmcblk0boot0 with some debug
U-Boot SPL 2020.04-5.4.70-2.3.2+gf3bcbdfc62 (Jul 03 2021 - 17:00:27 +0000) power_bd71837_init DDRINFO: start DRAM init DDRINFO: DRAM rate 1600MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done Normal Boot Trying to boot from BOOTROM ROM API interface 2 from boot 131073
Interface is 2 MMC and boot is 131073 and according to this
static int is_boot_from_stream_device(u32 boot) +{ + u32 interface; + + interface = boot >> 16; + if (interface >= BT_DEV_TYPE_USB) + return 1; + + if (interface == BT_DEV_TYPE_MMC && (boot & 1)) + return 1; + + return 0; +}
the return is 1, that does not allow us to boot.
Boot from boot1 give 131072 that is boot1 this let device boot because is_boot_from_stream_device is 0 and romapi use spl_romapi_load_image_seekable
Adjust the bootcondition let us boot from mmcblk0boot0 and mmcblk0boot1 without any problem
mmc partconf 0 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x0 BOOT_PARTITION_ENABLE: 0x1 PARTITION_ACCESS: 0x0
and the board was fused already.
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- arch/arm/mach-imx/spl_imx_romapi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/spl_imx_romapi.c b/arch/arm/mach-imx/spl_imx_romapi.c index 7e6a05a6f3..36f8848d45 100644 --- a/arch/arm/mach-imx/spl_imx_romapi.c +++ b/arch/arm/mach-imx/spl_imx_romapi.c @@ -18,10 +18,11 @@ static int is_boot_from_stream_device(u32 boot) u32 interface;
interface = boot >> 16; + if (interface >= BT_DEV_TYPE_USB) return 1;
- if (interface == BT_DEV_TYPE_MMC && (boot & 1)) + if (!is_imx8mn() && interface == BT_DEV_TYPE_MMC && (boot & 1)) return 1;
Michael Trimarchi
