[U-Boot] [PATCH v2 01/12] x86: Allow compiling out realmode/bios code
We don't want this for coreboot, so provide a way of compiling it out.
Signed-off-by: Gabe Black gabeblack@chromium.org Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Rename real mode option to CONFIG_X86_NO_REAL_MODE
README | 6 ++++++ arch/x86/lib/Makefile | 9 ++++++--- arch/x86/lib/video.c | 2 ++ 3 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/README b/README index b9a3685..ed7d270 100644 --- a/README +++ b/README @@ -3668,6 +3668,12 @@ Low Level (hardware related) configuration options: If defined, the x86 reset vector code is excluded. You will need to do this when U-Boot is running from Coreboot.
+- CONFIG_X86_NO_REAL_MODE + If defined, x86 real mode code is omitted. This assumes a + 32-bit environment where such code is not needed. You will + need to do this when U-Boot is running from Coreboot. + + Freescale QE/FMAN Firmware Support: -----------------------------------
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 51836da..4325b25 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -25,11 +25,16 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(ARCH).o
+ifeq ($(CONFIG_X86_NO_REAL_MODE),) SOBJS-$(CONFIG_SYS_PC_BIOS) += bios.o SOBJS-$(CONFIG_SYS_PCI_BIOS) += bios_pci.o -SOBJS-$(CONFIG_SYS_X86_REALMODE) += realmode_switch.o +COBJS-y += realmode.o +SOBJS-y += realmode_switch.o
COBJS-$(CONFIG_SYS_PC_BIOS) += bios_setup.o +COBJS-$(CONFIG_VIDEO) += video_bios.o +endif + COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cmd_boot.o @@ -41,11 +46,9 @@ COBJS-$(CONFIG_SYS_PCAT_INTERRUPTS) += pcat_interrupts.o COBJS-$(CONFIG_SYS_GENERIC_TIMER) += pcat_timer.o COBJS-$(CONFIG_PCI) += pci.o COBJS-$(CONFIG_PCI) += pci_type1.o -COBJS-$(CONFIG_SYS_X86_REALMODE) += realmode.o COBJS-y += relocate.o COBJS-y += string.o COBJS-$(CONFIG_SYS_X86_ISR_TIMER) += timer.o -COBJS-$(CONFIG_VIDEO) += video_bios.o COBJS-$(CONFIG_VIDEO) += video.o COBJS-$(CONFIG_CMD_ZBOOT) += zimage.o
diff --git a/arch/x86/lib/video.c b/arch/x86/lib/video.c index 3d6b24d..20e2416 100644 --- a/arch/x86/lib/video.c +++ b/arch/x86/lib/video.c @@ -222,8 +222,10 @@ int video_init(void)
int drv_video_init(void) { +#ifndef CONFIG_X86_NO_REAL_MODE if (video_bios_init()) return 1; +#endif
return video_init(); }
Hi Simon,
Changes in v2:
Hmm, what to do about boot_zimage() in arch/x86/lib/zimage.c. If you define CONFIG_X86_NO_REAL_MODE but don't define CONFIG_ZBOOT_32 you will get a linker failure. Maybe change:
#if defined CONFIG_ZBOOT_32 to
#if (defined CONFIG_ZBOOT_32 or defined CONFIG_X86_NO_REAL_MODE)
Don't forget the end goal is to surgically remove all 16-bit support (apart from the reset vector for non-coreboot boards)
Regards,
Graeme
Hi Graeme,
On Thu, Nov 29, 2012 at 6:09 PM, Graeme Russ graeme.russ@gmail.com wrote:
Hi Simon,
[snip]
Funny I just had that and took it out. My thought was that it would be a strange board that didn't define both. I will add that code back in.
Regards,
Graeme
Hi Simon,
On Fri, Nov 30, 2012 at 1:17 PM, Simon Glass sjg@chromium.org wrote:
Hi Graeme,
Hi Simon,
[snip]
Not strange - completely broken. Maybe add a #error if CONFIG_X86_NO_REAL_MODE is defined and CONFIG_ZBOOT_32 is not?
It is perfectly legitimate to define CONFIG_ZBOOT_32 while not defining CONFIG_X86_NO_REAL_MODE
Regards,
Graeme
Hi Graham,
On Thu, Nov 29, 2012 at 6:19 PM, Graeme Russ graeme.russ@gmail.com wrote:
Hi Simon,
Hi Graeme,
Hi Simon,
[snip]
OK, I might need to put that in a new patch. Or do you think it is ok to stick it in here? I just sent a new version.
OK.
Regards,
Graeme
Hi Simon,
On Fri, Nov 30, 2012 at 1:25 PM, Simon Glass sjg@chromium.org wrote:
Hi Graham,
Hi Simon,
Hi Graeme,
Hi Simon,
[snip]
I don't think it really matters - that code will go soon anyway
Regards,
Graeme
Graeme Russ
