[U-Boot] [PATCH] tegra: add CONSOLE_MUX support to tegra-kbc
Add support for CONSOLE_MUX to tegra-kbc driver. This requires adding a flag to struct keyb to know the driver has already been initialized so if we try to initialize it again we can just return success. Also call into iomux_doenv() from drv_keyboard_init to re-evaluate the stdin string.
Signed-off-by: Allen Martin amartin@nvidia.com --- drivers/input/tegra-kbc.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/drivers/input/tegra-kbc.c b/drivers/input/tegra-kbc.c index ab7a9e3..88471d3 100644 --- a/drivers/input/tegra-kbc.c +++ b/drivers/input/tegra-kbc.c @@ -63,6 +63,7 @@ static struct keyb { struct kbc_tegra *kbc; /* tegra keyboard controller */ unsigned char inited; /* 1 if keyboard has been inited */ unsigned char first_scan; /* 1 if this is our first key scan */ + unsigned char created; /* 1 if driver has been created */
/* * After init we must wait a short time before polling the keyboard. @@ -306,6 +307,10 @@ static void tegra_kbc_open(void) */ static int init_tegra_keyboard(void) { + /* check if already created */ + if (config.created) + return 0; + #ifdef CONFIG_OF_CONTROL int node;
@@ -349,6 +354,7 @@ static int init_tegra_keyboard(void) config_kbc_gpio(config.kbc);
tegra_kbc_open(); + config.created = 1; debug("%s: Tegra keyboard ready\n", __func__);
return 0; @@ -357,6 +363,8 @@ static int init_tegra_keyboard(void) int drv_keyboard_init(void) { struct stdio_dev dev; + char *stdinname = getenv("stdin"); + int error;
if (input_init(&config.input, 0)) { debug("%s: Cannot set up input\n", __func__); @@ -372,5 +380,13 @@ int drv_keyboard_init(void) dev.start = init_tegra_keyboard;
/* Register the device. init_tegra_keyboard() will be called soon */ - return input_stdio_register(&dev); + error = input_stdio_register(&dev); + if (error) + return error; +#ifdef CONFIG_CONSOLE_MUX + error = iomux_doenv(stdin, stdinname); + if (error) + return error; +#endif + return 0; }
Dear Allen Martin,
Thanks ;-)
I'll soon be tearing iomux apart btw., it looks like a bucket of crap :-(
Best regards, Marek Vasut
Hi Allen,
unsigned char created; /* 1 if driver has been created */ /* * After init we must wait a short time before polling the keyboard.
if (config.created)
I think this code should go after the 'int node' declaration, shouldn't it?
tegra_kbc_open();
config.created = 1; debug("%s: Tegra keyboard ready\n", __func__); return 0;
int error; if (input_init(&config.input, 0)) { debug("%s: Cannot set up input\n", __func__);
if (error)
return error;
if (error)
return error;
1.7.10.4
Allen Martin
