[PATCH] ARM: uniphier: select DM_ETH
drivers/net/smc911x.c has been converted to DM.
select DM_ETH to enable it for all the UniPhier platform boards.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/Kconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 - configs/uniphier_v7_defconfig | 1 - configs/uniphier_v8_defconfig | 1 - 4 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b494bcae95..954009c8bb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1571,6 +1571,7 @@ config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" select BOARD_LATE_INIT select DM + select DM_ETH select DM_GPIO select DM_I2C select DM_MMC diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 0bc85432df..4ed735369a 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -52,7 +52,6 @@ CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x0 CONFIG_SMC911X_32_BIT=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index 6485ab78fe..e46bdcab42 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -51,7 +51,6 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y -CONFIG_DM_ETH=y CONFIG_SNI_AVE=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 4514468abf..a130bbb747 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -50,7 +50,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 -CONFIG_DM_ETH=y CONFIG_SNI_AVE=y CONFIG_PINCONF=y CONFIG_SPI=y
Masahiro Yamada
