[U-Boot] [PATCH v3 1/7] Tegra114: Add arch-tegra114 include files
Common Tegra files are in arch-tegra, shared between T20/T30/T114. Tegra114-specific headers are in arch-tegra114. Note that some of these will be filled in as more T114 support is added (drivers, WB/LP0 support, etc.).
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - update all new copyright header dates to 2013 - put OSC_FREQ defines in SoC-specific headers - use correct BIT/BCT offsets for T114 ODMDATA - use T30 gpio header for T114 Changes in v3: - Add MAX_NUM_CPU for common clock code use.
arch/arm/include/asm/arch-tegra/clk_rst.h | 56 ++- arch/arm/include/asm/arch-tegra/gp_padctrl.h | 1 + arch/arm/include/asm/arch-tegra/pmc.h | 8 + arch/arm/include/asm/arch-tegra/tegra.h | 2 + arch/arm/include/asm/arch-tegra114/clock-tables.h | 402 +++++++++++++ arch/arm/include/asm/arch-tegra114/clock.h | 28 + arch/arm/include/asm/arch-tegra114/flow.h | 35 ++ arch/arm/include/asm/arch-tegra114/funcmux.h | 31 + arch/arm/include/asm/arch-tegra114/gp_padctrl.h | 59 ++ arch/arm/include/asm/arch-tegra114/gpio.h | 30 + arch/arm/include/asm/arch-tegra114/hardware.h | 22 + arch/arm/include/asm/arch-tegra114/pinmux.h | 618 +++++++++++++++++++++ arch/arm/include/asm/arch-tegra114/pmu.h | 23 + arch/arm/include/asm/arch-tegra114/spl.h | 22 + arch/arm/include/asm/arch-tegra114/tegra.h | 33 ++ 15 files changed, 1365 insertions(+), 5 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra114/clock-tables.h create mode 100644 arch/arm/include/asm/arch-tegra114/clock.h create mode 100644 arch/arm/include/asm/arch-tegra114/flow.h create mode 100644 arch/arm/include/asm/arch-tegra114/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra114/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra114/gpio.h create mode 100644 arch/arm/include/asm/arch-tegra114/hardware.h create mode 100644 arch/arm/include/asm/arch-tegra114/pinmux.h create mode 100644 arch/arm/include/asm/arch-tegra114/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra114/spl.h create mode 100644 arch/arm/include/asm/arch-tegra114/tegra.h
diff --git a/arch/arm/include/asm/arch-tegra/clk_rst.h b/arch/arm/include/asm/arch-tegra/clk_rst.h index b64aa7d..c754ec7 100644 --- a/arch/arm/include/asm/arch-tegra/clk_rst.h +++ b/arch/arm/include/asm/arch-tegra/clk_rst.h @@ -121,16 +121,43 @@ struct clk_rst_ctlr { uint crc_clk_cpug_cmplx; /* _CLK_CPUG_CMPLX_0, 0x378 */ uint crc_clk_cpulp_cmplx; /* _CLK_CPULP_CMPLX_0, 0x37C */ uint crc_cpu_softrst_ctrl; /* _CPU_SOFTRST_CTRL_0, 0x380 */ - uint crc_reserved33[11]; /* _reserved_33, 0x384-3ac */ + uint crc_cpu_softrst_ctrl1; /* _CPU_SOFTRST_CTR1L_0, 0x384 */ + uint crc_cpu_softrst_ctrl2; /* _CPU_SOFTRST_CTRL2_0, 0x388 */ + uint crc_reserved33[9]; /* _reserved_33, 0x38c-3ac */ uint crc_clk_src_vw[TEGRA_CLK_SOURCES_VW]; /* _G3D2_0..., 0x3b0-0x42c */ /* _RST_DEV_V/W_SET_0 0x430 ~ 0x43c */ struct clk_set_clr crc_rst_dev_ex_vw[TEGRA_CLK_REGS_VW]; /* _CLK_ENB_V/W_CLR_0 0x440 ~ 0x44c */ struct clk_set_clr crc_clk_enb_ex_vw[TEGRA_CLK_REGS_VW]; - uint crc_reserved40[12]; /* _reserved_40, 0x450-47C */ - uint crc_pll_cfg0; /* _PLL_CFG0_0, 0x480 */ - uint crc_pll_cfg1; /* _PLL_CFG1_0, 0x484 */ - uint crc_pll_cfg2; /* _PLL_CFG2_0, 0x488 */ + /* Additional (T114) registers */ + uint crc_rst_cpug_cmplx_set; /* _RST_CPUG_CMPLX_SET_0, 0x450 */ + uint crc_rst_cpug_cmplx_clr; /* _RST_CPUG_CMPLX_CLR_0, 0x454 */ + uint crc_rst_cpulp_cmplx_set; /* _RST_CPULP_CMPLX_SET_0, 0x458 */ + uint crc_rst_cpulp_cmplx_clr; /* _RST_CPULP_CMPLX_CLR_0, 0x45C */ + uint crc_clk_cpug_cmplx_set; /* _CLK_CPUG_CMPLX_SET_0, 0x460 */ + uint crc_clk_cpug_cmplx_clr; /* _CLK_CPUG_CMPLX_CLR_0, 0x464 */ + uint crc_clk_cpulp_cmplx_set; /* _CLK_CPULP_CMPLX_SET_0, 0x468 */ + uint crc_clk_cpulp_cmplx_clr; /* _CLK_CPULP_CMPLX_CLR_0, 0x46C */ + uint crc_cpu_cmplx_status; /* _CPU_CMPLX_STATUS_0, 0x470 */ + uint crc_reserved40[1]; /* _reserved_40, 0x474 */ + uint crc_intstatus; /* __INTSTATUS_0, 0x478 */ + uint crc_intmask; /* __INTMASK_0, 0x47C */ + uint crc_utmip_pll_cfg0; /* _UTMIP_PLL_CFG0_0, 0x480 */ + uint crc_utmip_pll_cfg1; /* _UTMIP_PLL_CFG1_0, 0x484 */ + uint crc_utmip_pll_cfg2; /* _UTMIP_PLL_CFG2_0, 0x488 */ + + uint crc_plle_aux; /* _PLLE_AUX_0, 0x48C */ + uint crc_sata_pll_cfg0; /* _SATA_PLL_CFG0_0, 0x490 */ + uint crc_sata_pll_cfg1; /* _SATA_PLL_CFG1_0, 0x494 */ + uint crc_pcie_pll_cfg0; /* _PCIE_PLL_CFG0_0, 0x498 */ + + uint crc_prog_audio_dly_clk; /* _PROG_AUDIO_DLY_CLK_0, 0x49C */ + uint crc_audio_sync_clk_i2s0; /* _AUDIO_SYNC_CLK_I2S0_0, 0x4A0 */ + uint crc_audio_sync_clk_i2s1; /* _AUDIO_SYNC_CLK_I2S1_0, 0x4A4 */ + uint crc_audio_sync_clk_i2s2; /* _AUDIO_SYNC_CLK_I2S2_0, 0x4A8 */ + uint crc_audio_sync_clk_i2s3; /* _AUDIO_SYNC_CLK_I2S3_0, 0x4AC */ + uint crc_audio_sync_clk_i2s4; /* _AUDIO_SYNC_CLK_I2S4_0, 0x4B0 */ + uint crc_audio_sync_clk_spdif; /* _AUDIO_SYNC_CLK_SPDIF_0, 0x4B4 */ };
/* CLK_RST_CONTROLLER_CLK_CPU_CMPLX_0 */ @@ -279,4 +306,23 @@ enum { #define CLK_SYS_RATE_APB_RATE_SHIFT 0 #define CLK_SYS_RATE_APB_RATE_MASK (3 << CLK_SYS_RATE_AHB_RATE_SHIFT)
+/* CLK_RST_CONTROLLER_RST_CPUxx_CMPLX_CLR */ +#define CLR_CPURESET0 (1 << 0) +#define CLR_CPURESET1 (1 << 1) +#define CLR_CPURESET2 (1 << 2) +#define CLR_CPURESET3 (1 << 3) +#define CLR_DBGRESET0 (1 << 12) +#define CLR_DBGRESET1 (1 << 13) +#define CLR_DBGRESET2 (1 << 14) +#define CLR_DBGRESET3 (1 << 15) +#define CLR_CORERESET0 (1 << 16) +#define CLR_CORERESET1 (1 << 17) +#define CLR_CORERESET2 (1 << 18) +#define CLR_CORERESET3 (1 << 19) +#define CLR_CXRESET0 (1 << 20) +#define CLR_CXRESET1 (1 << 21) +#define CLR_CXRESET2 (1 << 22) +#define CLR_CXRESET3 (1 << 23) +#define CLR_NONCPURESET (1 << 29) + #endif /* _TEGRA_CLK_RST_H_ */ diff --git a/arch/arm/include/asm/arch-tegra/gp_padctrl.h b/arch/arm/include/asm/arch-tegra/gp_padctrl.h index e6085a0..209abf1 100644 --- a/arch/arm/include/asm/arch-tegra/gp_padctrl.h +++ b/arch/arm/include/asm/arch-tegra/gp_padctrl.h @@ -35,5 +35,6 @@ /* CHIPID field returned from APB_MISC_GP_HIDREV register */ #define CHIPID_TEGRA20 0x20 #define CHIPID_TEGRA30 0x30 +#define CHIPID_TEGRA114 0x35
#endif /* _TEGRA_GP_PADCTRL_H_ */ diff --git a/arch/arm/include/asm/arch-tegra/pmc.h b/arch/arm/include/asm/arch-tegra/pmc.h index b1d47cd..1bcdcf8 100644 --- a/arch/arm/include/asm/arch-tegra/pmc.h +++ b/arch/arm/include/asm/arch-tegra/pmc.h @@ -128,5 +128,13 @@ struct pmc_ctlr { #define START_CP (1 << 8)
#define CPUPWRREQ_OE (1 << 16) +#define CPUPWRREQ_POL (1 << 15) + +#define CRAILID (0) +#define CE0ID (14) +#define C0NCID (15) +#define CRAIL (1 << CRAILID) +#define CE0 (1 << CE0ID) +#define C0NC (1 << C0NCID)
#endif /* PMC_H */ diff --git a/arch/arm/include/asm/arch-tegra/tegra.h b/arch/arm/include/asm/arch-tegra/tegra.h index 013a3c5..f97cfd0 100644 --- a/arch/arm/include/asm/arch-tegra/tegra.h +++ b/arch/arm/include/asm/arch-tegra/tegra.h @@ -73,6 +73,7 @@ enum { SKU_ID_AP25E = 0x1b, SKU_ID_T25E = 0x1c, SKU_ID_T30 = 0x81, /* Cardhu value */ + SKU_ID_T114_ENG = 0x00, /* Dalmore value, unfused */ };
/* @@ -85,6 +86,7 @@ enum { TEGRA_SOC_T20, TEGRA_SOC_T25, TEGRA_SOC_T30, + TEGRA_SOC_T114,
TEGRA_SOC_CNT, TEGRA_SOC_UNKNOWN = -1, diff --git a/arch/arm/include/asm/arch-tegra114/clock-tables.h b/arch/arm/include/asm/arch-tegra114/clock-tables.h new file mode 100644 index 0000000..d8fa0e1 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/clock-tables.h @@ -0,0 +1,402 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +/* Tegra114 clock PLL tables */ + +#ifndef _TEGRA114_CLOCK_TABLES_H_ +#define _TEGRA114_CLOCK_TABLES_H_ + +/* The PLLs supported by the hardware */ +enum clock_id { + CLOCK_ID_FIRST, + CLOCK_ID_CGENERAL = CLOCK_ID_FIRST, + CLOCK_ID_MEMORY, + CLOCK_ID_PERIPH, + CLOCK_ID_AUDIO, + CLOCK_ID_USB, + CLOCK_ID_DISPLAY, + + /* now the simple ones */ + CLOCK_ID_FIRST_SIMPLE, + CLOCK_ID_XCPU = CLOCK_ID_FIRST_SIMPLE, + CLOCK_ID_EPCI, + CLOCK_ID_SFROM32KHZ, + + /* These are the base clocks (inputs to the Tegra SOC) */ + CLOCK_ID_32KHZ, + CLOCK_ID_OSC, + + CLOCK_ID_COUNT, /* number of PLLs */ + CLOCK_ID_DISPLAY2, /* placeholder */ + CLOCK_ID_NONE = -1, +}; + +/* The clocks supported by the hardware */ +enum periph_id { + PERIPH_ID_FIRST, + + /* Low word: 31:0 (DEVICES_L) */ + PERIPH_ID_CPU = PERIPH_ID_FIRST, + PERIPH_ID_COP, + PERIPH_ID_TRIGSYS, + PERIPH_ID_RESERVED3, + PERIPH_ID_RTC, + PERIPH_ID_TMR, + PERIPH_ID_UART1, + PERIPH_ID_UART2, + + /* 8 */ + PERIPH_ID_GPIO, + PERIPH_ID_SDMMC2, + PERIPH_ID_SPDIF, + PERIPH_ID_I2S1, + PERIPH_ID_I2C1, + PERIPH_ID_NDFLASH, + PERIPH_ID_SDMMC1, + PERIPH_ID_SDMMC4, + + /* 16 */ + PERIPH_ID_RESERVED16, + PERIPH_ID_PWM, + PERIPH_ID_I2S2, + PERIPH_ID_EPP, + PERIPH_ID_VI, + PERIPH_ID_2D, + PERIPH_ID_USBD, + PERIPH_ID_ISP, + + /* 24 */ + PERIPH_ID_3D, + PERIPH_ID_RESERVED24, + PERIPH_ID_DISP2, + PERIPH_ID_DISP1, + PERIPH_ID_HOST1X, + PERIPH_ID_VCP, + PERIPH_ID_I2S0, + PERIPH_ID_CACHE2, + + /* Middle word: 63:32 (DEVICES_H) */ + PERIPH_ID_MEM, + PERIPH_ID_AHBDMA, + PERIPH_ID_APBDMA, + PERIPH_ID_RESERVED35, + PERIPH_ID_KBC, + PERIPH_ID_STAT_MON, + PERIPH_ID_PMC, + PERIPH_ID_FUSE, + + /* 40 */ + PERIPH_ID_KFUSE, + PERIPH_ID_SBC1, + PERIPH_ID_SNOR, + PERIPH_ID_RESERVED43, + PERIPH_ID_SBC2, + PERIPH_ID_RESERVED45, + PERIPH_ID_SBC3, + PERIPH_ID_I2C5, + + /* 48 */ + PERIPH_ID_DSI, + PERIPH_ID_TVO, + PERIPH_ID_MIPI, + PERIPH_ID_HDMI, + PERIPH_ID_CSI, + PERIPH_ID_TVDAC, + PERIPH_ID_I2C2, + PERIPH_ID_UART3, + + /* 56 */ + PERIPH_ID_RESERVED56, + PERIPH_ID_EMC, + PERIPH_ID_USB2, + PERIPH_ID_USB3, + PERIPH_ID_MPE, + PERIPH_ID_VDE, + PERIPH_ID_BSEA, + PERIPH_ID_BSEV, + + /* Upper word 95:64 (DEVICES_U) */ + PERIPH_ID_SPEEDO, + PERIPH_ID_UART4, + PERIPH_ID_UART5, + PERIPH_ID_I2C3, + PERIPH_ID_SBC4, + PERIPH_ID_SDMMC3, + PERIPH_ID_PCIE, + PERIPH_ID_OWR, + + /* 72 */ + PERIPH_ID_AFI, + PERIPH_ID_CORESIGHT, + PERIPH_ID_PCIEXCLK, + PERIPH_ID_AVPUCQ, + PERIPH_ID_RESERVED76, + PERIPH_ID_RESERVED77, + PERIPH_ID_RESERVED78, + PERIPH_ID_DTV, + + /* 80 */ + PERIPH_ID_NANDSPEED, + PERIPH_ID_I2CSLOW, + PERIPH_ID_DSIB, + PERIPH_ID_RESERVED83, + PERIPH_ID_IRAMA, + PERIPH_ID_IRAMB, + PERIPH_ID_IRAMC, + PERIPH_ID_IRAMD, + + /* 88 */ + PERIPH_ID_CRAM2, + PERIPH_ID_RESERVED89, + PERIPH_ID_MDOUBLER, + PERIPH_ID_RESERVED91, + PERIPH_ID_SUSOUT, + PERIPH_ID_RESERVED93, + PERIPH_ID_RESERVED94, + PERIPH_ID_RESERVED95, + + PERIPH_ID_VW_FIRST, + /* V word: 31:0 */ + PERIPH_ID_CPUG = PERIPH_ID_VW_FIRST, + PERIPH_ID_CPULP, + PERIPH_ID_3D2, + PERIPH_ID_MSELECT, + PERIPH_ID_TSENSOR, + PERIPH_ID_I2S3, + PERIPH_ID_I2S4, + PERIPH_ID_I2C4, + + /* 104 */ + PERIPH_ID_SBC5, + PERIPH_ID_SBC6, + PERIPH_ID_AUDIO, + PERIPH_ID_APBIF, + PERIPH_ID_DAM0, + PERIPH_ID_DAM1, + PERIPH_ID_DAM2, + PERIPH_ID_HDA2CODEC2X, + + /* 112 */ + PERIPH_ID_ATOMICS, + PERIPH_ID_EX_RESERVED17, + PERIPH_ID_EX_RESERVED18, + PERIPH_ID_EX_RESERVED19, + PERIPH_ID_EX_RESERVED20, + PERIPH_ID_EX_RESERVED21, + PERIPH_ID_EX_RESERVED22, + PERIPH_ID_ACTMON, + + /* 120 */ + PERIPH_ID_EX_RESERVED24, + PERIPH_ID_EX_RESERVED25, + PERIPH_ID_EX_RESERVED26, + PERIPH_ID_EX_RESERVED27, + PERIPH_ID_SATA, + PERIPH_ID_HDA, + PERIPH_ID_EX_RESERVED30, + PERIPH_ID_EX_RESERVED31, + + /* W word: 31:0 */ + PERIPH_ID_HDA2HDMICODEC, + PERIPH_ID_RESERVED1_SATACOLD, + PERIPH_ID_RESERVED2_PCIERX0, + PERIPH_ID_RESERVED3_PCIERX1, + PERIPH_ID_RESERVED4_PCIERX2, + PERIPH_ID_RESERVED5_PCIERX3, + PERIPH_ID_RESERVED6_PCIERX4, + PERIPH_ID_RESERVED7_PCIERX5, + + /* 136 */ + PERIPH_ID_CEC, + PERIPH_ID_PCIE2_IOBIST, + PERIPH_ID_EMC_IOBIST, + PERIPH_ID_HDMI_IOBIST, + PERIPH_ID_SATA_IOBIST, + PERIPH_ID_MIPI_IOBIST, + PERIPH_ID_EMC1_IOBIST, + PERIPH_ID_XUSB, + + /* 144 */ + PERIPH_ID_CILAB, + PERIPH_ID_CILCD, + PERIPH_ID_CILE, + PERIPH_ID_DSIA_LP, + PERIPH_ID_DSIB_LP, + PERIPH_ID_RESERVED21_ENTROPY, + PERIPH_ID_RESERVED22_W, + PERIPH_ID_RESERVED23_W, + + /* 152 */ + PERIPH_ID_RESERVED24_W, + PERIPH_ID_AMX0, + PERIPH_ID_ADX0, + PERIPH_ID_DVFS, + PERIPH_ID_XUSB_SS, + PERIPH_ID_EMC_DLL, + PERIPH_ID_MC1, + PERIPH_ID_EMC1, + + PERIPH_ID_COUNT, + PERIPH_ID_NONE = -1, +}; + +enum pll_out_id { + PLL_OUT1, + PLL_OUT2, + PLL_OUT3, + PLL_OUT4 +}; + +/* + * Clock peripheral IDs which sadly don't match up with PERIPH_ID. we want + * callers to use the PERIPH_ID for all access to peripheral clocks to avoid + * confusion bewteen PERIPH_ID_... and PERIPHC_... + * + * We don't call this CLOCK_PERIPH_ID or PERIPH_CLOCK_ID as it would just be + * confusing. + */ +enum periphc_internal_id { + /* 0x00 */ + PERIPHC_I2S1, + PERIPHC_I2S2, + PERIPHC_SPDIF_OUT, + PERIPHC_SPDIF_IN, + PERIPHC_PWM, + PERIPHC_05h, + PERIPHC_SBC2, + PERIPHC_SBC3, + + /* 0x08 */ + PERIPHC_08h, + PERIPHC_I2C1, + PERIPHC_I2C5, + PERIPHC_0bh, + PERIPHC_0ch, + PERIPHC_SBC1, + PERIPHC_DISP1, + PERIPHC_DISP2, + + /* 0x10 */ + PERIPHC_CVE, + PERIPHC_11h, + PERIPHC_VI, + PERIPHC_13h, + PERIPHC_SDMMC1, + PERIPHC_SDMMC2, + PERIPHC_G3D, + PERIPHC_G2D, + + /* 0x18 */ + PERIPHC_NDFLASH, + PERIPHC_SDMMC4, + PERIPHC_VFIR, + PERIPHC_EPP, + PERIPHC_MPE, + PERIPHC_MIPI, + PERIPHC_UART1, + PERIPHC_UART2, + + /* 0x20 */ + PERIPHC_HOST1X, + PERIPHC_21h, + PERIPHC_TVO, + PERIPHC_HDMI, + PERIPHC_24h, + PERIPHC_TVDAC, + PERIPHC_I2C2, + PERIPHC_EMC, + + /* 0x28 */ + PERIPHC_UART3, + PERIPHC_29h, + PERIPHC_VI_SENSOR, + PERIPHC_2bh, + PERIPHC_2ch, + PERIPHC_SBC4, + PERIPHC_I2C3, + PERIPHC_SDMMC3, + + /* 0x30 */ + PERIPHC_UART4, + PERIPHC_UART5, + PERIPHC_VDE, + PERIPHC_OWR, + PERIPHC_NOR, + PERIPHC_CSITE, + PERIPHC_I2S0, + PERIPHC_37h, + + PERIPHC_VW_FIRST, + /* 0x38 */ + PERIPHC_G3D2 = PERIPHC_VW_FIRST, + PERIPHC_MSELECT, + PERIPHC_TSENSOR, + PERIPHC_I2S3, + PERIPHC_I2S4, + PERIPHC_I2C4, + PERIPHC_SBC5, + PERIPHC_SBC6, + + /* 0x40 */ + PERIPHC_AUDIO, + PERIPHC_41h, + PERIPHC_DAM0, + PERIPHC_DAM1, + PERIPHC_DAM2, + PERIPHC_HDA2CODEC2X, + PERIPHC_ACTMON, + PERIPHC_EXTPERIPH1, + + /* 0x48 */ + PERIPHC_EXTPERIPH2, + PERIPHC_EXTPERIPH3, + PERIPHC_NANDSPEED, + PERIPHC_I2CSLOW, + PERIPHC_SYS, + PERIPHC_SPEEDO, + PERIPHC_4eh, + PERIPHC_4fh, + + /* 0x50 */ + PERIPHC_50h, + PERIPHC_51h, + PERIPHC_52h, + PERIPHC_53h, + PERIPHC_SATAOOB, + PERIPHC_SATA, + PERIPHC_HDA, + + PERIPHC_COUNT, + + PERIPHC_NONE = -1, +}; + +/* Converts a clock number to a clock register: 0=L, 1=H, 2=U, 0=V, 1=W */ +#define PERIPH_REG(id) \ + (id < PERIPH_ID_VW_FIRST) ? \ + ((id) >> 5) : ((id - PERIPH_ID_VW_FIRST) >> 5) + +/* Mask value for a clock (within PERIPH_REG(id)) */ +#define PERIPH_MASK(id) (1 << ((id) & 0x1f)) + +/* return 1 if a PLL ID is in range */ +#define clock_id_is_pll(id) ((id) >= CLOCK_ID_FIRST && (id) < CLOCK_ID_COUNT) + +/* return 1 if a peripheral ID is in range */ +#define clock_periph_id_isvalid(id) ((id) >= PERIPH_ID_FIRST && \ + (id) < PERIPH_ID_COUNT) + +#endif /* _TEGRA114_CLOCK_TABLES_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/clock.h b/arch/arm/include/asm/arch-tegra114/clock.h new file mode 100644 index 0000000..abbefcd --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/clock.h @@ -0,0 +1,28 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +/* Tegra114 clock control functions */ + +#ifndef _TEGRA114_CLOCK_H_ +#define _TEGRA114_CLOCK_H_ + +#include <asm/arch-tegra/clock.h> + +/* CLK_RST_CONTROLLER_OSC_CTRL_0 */ +#define OSC_FREQ_SHIFT 28 +#define OSC_FREQ_MASK (0xF << OSC_FREQ_SHIFT) + +#endif /* _TEGRA114_CLOCK_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/flow.h b/arch/arm/include/asm/arch-tegra114/flow.h new file mode 100644 index 0000000..c7eb051 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/flow.h @@ -0,0 +1,35 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_FLOW_H_ +#define _TEGRA114_FLOW_H_ + +struct flow_ctlr { + u32 halt_cpu_events; + u32 halt_cop_events; + u32 cpu_csr; + u32 cop_csr; + u32 xrq_events; + u32 halt_cpu1_events; + u32 cpu1_csr; + u32 halt_cpu2_events; + u32 cpu2_csr; + u32 halt_cpu3_events; + u32 cpu3_csr; + u32 cluster_control; +}; + +#endif /* _TEGRA114_FLOW_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/funcmux.h b/arch/arm/include/asm/arch-tegra114/funcmux.h new file mode 100644 index 0000000..7f48f25 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/funcmux.h @@ -0,0 +1,31 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +/* Tegra114 high-level function multiplexing */ + +#ifndef _TEGRA114_FUNCMUX_H_ +#define _TEGRA114_FUNCMUX_H_ + +#include <asm/arch-tegra/funcmux.h> + +/* Configs supported by the func mux */ +enum { + FUNCMUX_DEFAULT = 0, /* default config */ + + /* UART configs */ + FUNCMUX_UART4_GMI = 0, +}; +#endif /* _TEGRA114_FUNCMUX_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/gp_padctrl.h b/arch/arm/include/asm/arch-tegra114/gp_padctrl.h new file mode 100644 index 0000000..c538bdd --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/gp_padctrl.h @@ -0,0 +1,59 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_GP_PADCTRL_H_ +#define _TEGRA114_GP_PADCTRL_H_ + +#include <asm/arch-tegra/gp_padctrl.h> + +/* APB_MISC_GP and padctrl registers */ +struct apb_misc_gp_ctlr { + u32 modereg; /* 0x00: APB_MISC_GP_MODEREG */ + u32 hidrev; /* 0x04: APB_MISC_GP_HIDREV */ + u32 reserved0[22]; /* 0x08 - 0x5C: */ + u32 emu_revid; /* 0x60: APB_MISC_GP_EMU_REVID */ + u32 xactor_scratch; /* 0x64: APB_MISC_GP_XACTOR_SCRATCH */ + u32 aocfg1; /* 0x68: APB_MISC_GP_AOCFG1PADCTRL */ + u32 aocfg2; /* 0x6c: APB_MISC_GP_AOCFG2PADCTRL */ + u32 atcfg1; /* 0x70: APB_MISC_GP_ATCFG1PADCTRL */ + u32 atcfg2; /* 0x74: APB_MISC_GP_ATCFG2PADCTRL */ + u32 atcfg3; /* 0x78: APB_MISC_GP_ATCFG3PADCTRL */ + u32 atcfg4; /* 0x7C: APB_MISC_GP_ATCFG4PADCTRL */ + u32 atcfg5; /* 0x80: APB_MISC_GP_ATCFG5PADCTRL */ + u32 cdev1cfg; /* 0x84: APB_MISC_GP_CDEV1CFGPADCTRL */ + u32 cdev2cfg; /* 0x88: APB_MISC_GP_CDEV2CFGPADCTRL */ + u32 csuscfg; /* 0x8C: APB_MISC_GP_CSUSCFGPADCTRL */ + u32 dap1cfg; /* 0x90: APB_MISC_GP_DAP1CFGPADCTRL */ + u32 dap2cfg; /* 0x94: APB_MISC_GP_DAP2CFGPADCTRL */ + u32 dap3cfg; /* 0x98: APB_MISC_GP_DAP3CFGPADCTRL */ + u32 dap4cfg; /* 0x9C: APB_MISC_GP_DAP4CFGPADCTRL */ + u32 dbgcfg; /* 0xA0: APB_MISC_GP_DBGCFGPADCTRL */ + u32 lcdcfg1; /* 0xA4: APB_MISC_GP_LCDCFG1PADCTRL */ + u32 lcdcfg2; /* 0xA8: APB_MISC_GP_LCDCFG2PADCTRL */ + u32 sdio2cfg; /* 0xAC: APB_MISC_GP_SDIO2CFGPADCTRL */ + u32 sdio3cfg; /* 0xB0: APB_MISC_GP_SDIO3CFGPADCTRL */ + u32 spicfg; /* 0xB4: APB_MISC_GP_SPICFGPADCTRL */ + u32 uaacfg; /* 0xB8: APB_MISC_GP_UAACFGPADCTRL */ + u32 uabcfg; /* 0xBC: APB_MISC_GP_UABCFGPADCTRL */ + u32 uart2cfg; /* 0xC0: APB_MISC_GP_UART2CFGPADCTRL */ + u32 uart3cfg; /* 0xC4: APB_MISC_GP_UART3CFGPADCTRL */ + u32 vicfg1; /* 0xC8: APB_MISC_GP_VICFG1PADCTRL */ + u32 vivttgen; /* 0xCC: APB_MISC_GP_VIVTTGENPADCTRL */ + u32 reserved1[7]; /* 0xD0-0xE8: */ + u32 sdio1cfg; /* 0xEC: APB_MISC_GP_SDIO1CFGPADCTRL */ +}; + +#endif /* _TEGRA114_GP_PADCTRL_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/gpio.h b/arch/arm/include/asm/arch-tegra114/gpio.h new file mode 100644 index 0000000..21853b6 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/gpio.h @@ -0,0 +1,30 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_GPIO_H_ +#define _TEGRA114_GPIO_H_ + +/* + * The Tegra114 GPIO controller has 246 GPIOS in 8 banks of 4 ports, + * each with 8 GPIOs. + */ +#define TEGRA_GPIO_PORTS 4 /* number of ports per bank */ +#define TEGRA_GPIO_BANKS 8 /* number of banks */ + +#include <asm/arch-tegra/gpio.h> +#include <asm/arch-tegra30/gpio.h> + +#endif /* _TEGRA114_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/hardware.h b/arch/arm/include/asm/arch-tegra114/hardware.h new file mode 100644 index 0000000..c21fbb6 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/hardware.h @@ -0,0 +1,22 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_HARDWARE_H_ +#define _TEGRA114_HARDWARE_H_ + +/* include tegra specific hardware definitions */ + +#endif /* _TEGRA114_HARDWARE_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/pinmux.h b/arch/arm/include/asm/arch-tegra114/pinmux.h new file mode 100644 index 0000000..fd22930 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/pinmux.h @@ -0,0 +1,618 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_PINMUX_H_ +#define _TEGRA114_PINMUX_H_ + +/* + * Pin groups which we adjust. There are three basic attributes of each pin + * group which use this enum: + * + * - function + * - pullup / pulldown + * - tristate or normal + */ +enum pmux_pingrp { + PINGRP_ULPI_DATA0 = 0, /* offset 0x3000 */ + PINGRP_ULPI_DATA1, + PINGRP_ULPI_DATA2, + PINGRP_ULPI_DATA3, + PINGRP_ULPI_DATA4, + PINGRP_ULPI_DATA5, + PINGRP_ULPI_DATA6, + PINGRP_ULPI_DATA7, + PINGRP_ULPI_CLK, + PINGRP_ULPI_DIR, + PINGRP_ULPI_NXT, + PINGRP_ULPI_STP, + PINGRP_DAP3_FS, + PINGRP_DAP3_DIN, + PINGRP_DAP3_DOUT, + PINGRP_DAP3_SCLK, + PINGRP_GPIO_PV0, + PINGRP_GPIO_PV1, + PINGRP_SDMMC1_CLK, + PINGRP_SDMMC1_CMD, + PINGRP_SDMMC1_DAT3, + PINGRP_SDMMC1_DAT2, + PINGRP_SDMMC1_DAT1, + PINGRP_SDMMC1_DAT0, + PINGRP_GPIO_PV2, + PINGRP_GPIO_PV3, + PINGRP_CLK2_OUT, + PINGRP_CLK2_REQ, + PINGRP_LCD_PWR1, + PINGRP_LCD_PWR2, + PINGRP_LCD_SDIN, + PINGRP_LCD_SDOUT, + PINGRP_LCD_WR_N, + PINGRP_LCD_CS0_N, + PINGRP_LCD_DC0, + PINGRP_LCD_SCK, + PINGRP_LCD_PWR0, + PINGRP_LCD_PCLK, + PINGRP_LCD_DE, + PINGRP_LCD_HSYNC, + PINGRP_LCD_VSYNC, + PINGRP_LCD_D0, + PINGRP_LCD_D1, + PINGRP_LCD_D2, + PINGRP_LCD_D3, + PINGRP_LCD_D4, + PINGRP_LCD_D5, + PINGRP_LCD_D6, + PINGRP_LCD_D7, + PINGRP_LCD_D8, + PINGRP_LCD_D9, + PINGRP_LCD_D10, + PINGRP_LCD_D11, + PINGRP_LCD_D12, + PINGRP_LCD_D13, + PINGRP_LCD_D14, + PINGRP_LCD_D15, + PINGRP_LCD_D16, + PINGRP_LCD_D17, + PINGRP_LCD_D18, + PINGRP_LCD_D19, + PINGRP_LCD_D20, + PINGRP_LCD_D21, + PINGRP_LCD_D22, + PINGRP_LCD_D23, + PINGRP_LCD_CS1_N, + PINGRP_LCD_M1, + PINGRP_LCD_DC1, + PINGRP_HDMI_INT, + PINGRP_DDC_SCL, + PINGRP_DDC_SDA, + PINGRP_CRT_HSYNC, + PINGRP_CRT_VSYNC, + PINGRP_VI_D0, + PINGRP_VI_D1, + PINGRP_VI_D2, + PINGRP_VI_D3, + PINGRP_VI_D4, + PINGRP_VI_D5, + PINGRP_VI_D6, + PINGRP_VI_D7, + PINGRP_VI_D8, + PINGRP_VI_D9, + PINGRP_VI_D10, + PINGRP_VI_D11, + PINGRP_VI_PCLK, + PINGRP_VI_MCLK, + PINGRP_VI_VSYNC, + PINGRP_VI_HSYNC, + PINGRP_UART2_RXD, + PINGRP_UART2_TXD, + PINGRP_UART2_RTS_N, + PINGRP_UART2_CTS_N, + PINGRP_UART3_TXD, + PINGRP_UART3_RXD, + PINGRP_UART3_CTS_N, + PINGRP_UART3_RTS_N, + PINGRP_GPIO_PU0, + PINGRP_GPIO_PU1, + PINGRP_GPIO_PU2, + PINGRP_GPIO_PU3, + PINGRP_GPIO_PU4, + PINGRP_GPIO_PU5, + PINGRP_GPIO_PU6, + PINGRP_GEN1_I2C_SDA, + PINGRP_GEN1_I2C_SCL, + PINGRP_DAP4_FS, + PINGRP_DAP4_DIN, + PINGRP_DAP4_DOUT, + PINGRP_DAP4_SCLK, + PINGRP_CLK3_OUT, + PINGRP_CLK3_REQ, + PINGRP_GMI_WP_N, + PINGRP_GMI_IORDY, + PINGRP_GMI_WAIT, + PINGRP_GMI_ADV_N, + PINGRP_GMI_CLK, + PINGRP_GMI_CS0_N, + PINGRP_GMI_CS1_N, + PINGRP_GMI_CS2_N, + PINGRP_GMI_CS3_N, + PINGRP_GMI_CS4_N, + PINGRP_GMI_CS6_N, + PINGRP_GMI_CS7_N, + PINGRP_GMI_AD0, + PINGRP_GMI_AD1, + PINGRP_GMI_AD2, + PINGRP_GMI_AD3, + PINGRP_GMI_AD4, + PINGRP_GMI_AD5, + PINGRP_GMI_AD6, + PINGRP_GMI_AD7, + PINGRP_GMI_AD8, + PINGRP_GMI_AD9, + PINGRP_GMI_AD10, + PINGRP_GMI_AD11, + PINGRP_GMI_AD12, + PINGRP_GMI_AD13, + PINGRP_GMI_AD14, + PINGRP_GMI_AD15, + PINGRP_GMI_A16, + PINGRP_GMI_A17, + PINGRP_GMI_A18, + PINGRP_GMI_A19, + PINGRP_GMI_WR_N, + PINGRP_GMI_OE_N, + PINGRP_GMI_DQS, + PINGRP_GMI_RST_N, + PINGRP_GEN2_I2C_SCL, + PINGRP_GEN2_I2C_SDA, + PINGRP_SDMMC4_CLK, + PINGRP_SDMMC4_CMD, + PINGRP_SDMMC4_DAT0, + PINGRP_SDMMC4_DAT1, + PINGRP_SDMMC4_DAT2, + PINGRP_SDMMC4_DAT3, + PINGRP_SDMMC4_DAT4, + PINGRP_SDMMC4_DAT5, + PINGRP_SDMMC4_DAT6, + PINGRP_SDMMC4_DAT7, + PINGRP_SDMMC4_RST_N, + PINGRP_CAM_MCLK, + PINGRP_GPIO_PCC1, + PINGRP_GPIO_PBB0, + PINGRP_CAM_I2C_SCL, + PINGRP_CAM_I2C_SDA, + PINGRP_GPIO_PBB3, + PINGRP_GPIO_PBB4, + PINGRP_GPIO_PBB5, + PINGRP_GPIO_PBB6, + PINGRP_GPIO_PBB7, + PINGRP_GPIO_PCC2, + PINGRP_JTAG_RTCK, + PINGRP_PWR_I2C_SCL, + PINGRP_PWR_I2C_SDA, + PINGRP_KB_ROW0, + PINGRP_KB_ROW1, + PINGRP_KB_ROW2, + PINGRP_KB_ROW3, + PINGRP_KB_ROW4, + PINGRP_KB_ROW5, + PINGRP_KB_ROW6, + PINGRP_KB_ROW7, + PINGRP_KB_ROW8, + PINGRP_KB_ROW9, + PINGRP_KB_ROW10, + PINGRP_KB_ROW11, + PINGRP_KB_ROW12, + PINGRP_KB_ROW13, + PINGRP_KB_ROW14, + PINGRP_KB_ROW15, + PINGRP_KB_COL0, + PINGRP_KB_COL1, + PINGRP_KB_COL2, + PINGRP_KB_COL3, + PINGRP_KB_COL4, + PINGRP_KB_COL5, + PINGRP_KB_COL6, + PINGRP_KB_COL7, + PINGRP_CLK_32K_OUT, + PINGRP_SYS_CLK_REQ, + PINGRP_CORE_PWR_REQ, + PINGRP_CPU_PWR_REQ, + PINGRP_PWR_INT_N, + PINGRP_CLK_32K_IN, + PINGRP_OWR, + PINGRP_DAP1_FS, + PINGRP_DAP1_DIN, + PINGRP_DAP1_DOUT, + PINGRP_DAP1_SCLK, + PINGRP_CLK1_REQ, + PINGRP_CLK1_OUT, + PINGRP_SPDIF_IN, + PINGRP_SPDIF_OUT, + PINGRP_DAP2_FS, + PINGRP_DAP2_DIN, + PINGRP_DAP2_DOUT, + PINGRP_DAP2_SCLK, + PINGRP_SPI2_MOSI, + PINGRP_SPI2_MISO, + PINGRP_SPI2_CS0_N, + PINGRP_SPI2_SCK, + PINGRP_SPI1_MOSI, + PINGRP_SPI1_SCK, + PINGRP_SPI1_CS0_N, + PINGRP_SPI1_MISO, + PINGRP_SPI2_CS1_N, + PINGRP_SPI2_CS2_N, + PINGRP_SDMMC3_CLK, + PINGRP_SDMMC3_CMD, + PINGRP_SDMMC3_DAT0, + PINGRP_SDMMC3_DAT1, + PINGRP_SDMMC3_DAT2, + PINGRP_SDMMC3_DAT3, + PINGRP_SDMMC3_DAT4, + PINGRP_SDMMC3_DAT5, + PINGRP_SDMMC3_DAT6, + PINGRP_SDMMC3_DAT7, + PINGRP_PEX_L0_PRSNT_N, + PINGRP_PEX_L0_RST_N, + PINGRP_PEX_L0_CLKREQ_N, + PINGRP_PEX_WAKE_N, + PINGRP_PEX_L1_PRSNT_N, + PINGRP_PEX_L1_RST_N, + PINGRP_PEX_L1_CLKREQ_N, + PINGRP_PEX_L2_PRSNT_N, + PINGRP_PEX_L2_RST_N, + PINGRP_PEX_L2_CLKREQ_N, + PINGRP_HDMI_CEC, /* offset 0x33e0 */ + PINGRP_SDMMC1_WP_N, + PINGRP_SDMMC3_CD_N, + PINGRP_SPI1_CS1_N, + PINGRP_SPI1_CS2_N, + PINGRP_USB_VBUS_EN0, /* offset 0x33f4 */ + PINGRP_USB_VBUS_EN1, + PINGRP_SDMMC3_CLK_LB_IN, + PINGRP_SDMMC3_CLK_LB_OUT, + PINGRP_NAND_GMI_CLK_LB, + PINGRP_RESET_OUT_N, + PINGRP_COUNT, +}; + +enum pdrive_pingrp { + PDRIVE_PINGROUP_AO1 = 0, /* offset 0x868 */ + PDRIVE_PINGROUP_AO2, + PDRIVE_PINGROUP_AT1, + PDRIVE_PINGROUP_AT2, + PDRIVE_PINGROUP_AT3, + PDRIVE_PINGROUP_AT4, + PDRIVE_PINGROUP_AT5, + PDRIVE_PINGROUP_CDEV1, + PDRIVE_PINGROUP_CDEV2, + PDRIVE_PINGROUP_CSUS, + PDRIVE_PINGROUP_DAP1, + PDRIVE_PINGROUP_DAP2, + PDRIVE_PINGROUP_DAP3, + PDRIVE_PINGROUP_DAP4, + PDRIVE_PINGROUP_DBG, + PDRIVE_PINGROUP_LCD1, + PDRIVE_PINGROUP_LCD2, + PDRIVE_PINGROUP_SDIO2, + PDRIVE_PINGROUP_SDIO3, + PDRIVE_PINGROUP_SPI, + PDRIVE_PINGROUP_UAA, + PDRIVE_PINGROUP_UAB, + PDRIVE_PINGROUP_UART2, + PDRIVE_PINGROUP_UART3, + PDRIVE_PINGROUP_VI1 = 24, /* offset 0x8c8 */ + PDRIVE_PINGROUP_SDIO1 = 33, /* offset 0x8ec */ + PDRIVE_PINGROUP_CRT = 36, /* offset 0x8f8 */ + PDRIVE_PINGROUP_DDC, + PDRIVE_PINGROUP_GMA, + PDRIVE_PINGROUP_GMB, + PDRIVE_PINGROUP_GMC, + PDRIVE_PINGROUP_GMD, + PDRIVE_PINGROUP_GME, + PDRIVE_PINGROUP_GMF, + PDRIVE_PINGROUP_GMG, + PDRIVE_PINGROUP_GMH, + PDRIVE_PINGROUP_OWR, + PDRIVE_PINGROUP_UAD, + PDRIVE_PINGROUP_GPV, + PDRIVE_PINGROUP_DEV3 = 49, /* offset 0x92c */ + PDRIVE_PINGROUP_CEC = 52, /* offset 0x938 */ + PDRIVE_PINGROUP_AT6, + PDRIVE_PINGROUP_DAP5, + PDRIVE_PINGROUP_VBUS, + PDRIVE_PINGROUP_COUNT, +}; + +/* + * Functions which can be assigned to each of the pin groups. The values here + * bear no relation to the values programmed into pinmux registers and are + * purely a convenience. The translation is done through a table search. + */ +enum pmux_func { + PMUX_FUNC_AHB_CLK, + PMUX_FUNC_APB_CLK, + PMUX_FUNC_AUDIO_SYNC, + PMUX_FUNC_CRT, + PMUX_FUNC_DAP1, + PMUX_FUNC_DAP2, + PMUX_FUNC_DAP3, + PMUX_FUNC_DAP4, + PMUX_FUNC_DAP5, + PMUX_FUNC_DISPA, + PMUX_FUNC_DISPB, + PMUX_FUNC_EMC_TEST0_DLL, + PMUX_FUNC_EMC_TEST1_DLL, + PMUX_FUNC_GMI, + PMUX_FUNC_GMI_INT, + PMUX_FUNC_HDMI, + PMUX_FUNC_I2C1, + PMUX_FUNC_I2C2, + PMUX_FUNC_I2C3, + PMUX_FUNC_IDE, + PMUX_FUNC_KBC, + PMUX_FUNC_MIO, + PMUX_FUNC_MIPI_HS, + PMUX_FUNC_NAND, + PMUX_FUNC_OSC, + PMUX_FUNC_OWR, + PMUX_FUNC_PCIE, + PMUX_FUNC_PLLA_OUT, + PMUX_FUNC_PLLC_OUT1, + PMUX_FUNC_PLLM_OUT1, + PMUX_FUNC_PLLP_OUT2, + PMUX_FUNC_PLLP_OUT3, + PMUX_FUNC_PLLP_OUT4, + PMUX_FUNC_PWM, + PMUX_FUNC_PWR_INTR, + PMUX_FUNC_PWR_ON, + PMUX_FUNC_RTCK, + PMUX_FUNC_SDMMC1, + PMUX_FUNC_SDMMC2, + PMUX_FUNC_SDMMC3, + PMUX_FUNC_SDMMC4, + PMUX_FUNC_SFLASH, + PMUX_FUNC_SPDIF, + PMUX_FUNC_SPI1, + PMUX_FUNC_SPI2, + PMUX_FUNC_SPI2_ALT, + PMUX_FUNC_SPI3, + PMUX_FUNC_SPI4, + PMUX_FUNC_TRACE, + PMUX_FUNC_TWC, + PMUX_FUNC_UARTA, + PMUX_FUNC_UARTB, + PMUX_FUNC_UARTC, + PMUX_FUNC_UARTD, + PMUX_FUNC_UARTE, + PMUX_FUNC_ULPI, + PMUX_FUNC_VI, + PMUX_FUNC_VI_SENSOR_CLK, + PMUX_FUNC_XIO, + PMUX_FUNC_BLINK, + PMUX_FUNC_CEC, + PMUX_FUNC_CLK12, + PMUX_FUNC_DAP, + PMUX_FUNC_DAPSDMMC2, + PMUX_FUNC_DDR, + PMUX_FUNC_DEV3, + PMUX_FUNC_DTV, + PMUX_FUNC_VI_ALT1, + PMUX_FUNC_VI_ALT2, + PMUX_FUNC_VI_ALT3, + PMUX_FUNC_EMC_DLL, + PMUX_FUNC_EXTPERIPH1, + PMUX_FUNC_EXTPERIPH2, + PMUX_FUNC_EXTPERIPH3, + PMUX_FUNC_GMI_ALT, + PMUX_FUNC_HDA, + PMUX_FUNC_HSI, + PMUX_FUNC_I2C4, + PMUX_FUNC_I2C5, + PMUX_FUNC_I2CPWR, + PMUX_FUNC_I2S0, + PMUX_FUNC_I2S1, + PMUX_FUNC_I2S2, + PMUX_FUNC_I2S3, + PMUX_FUNC_I2S4, + PMUX_FUNC_NAND_ALT, + PMUX_FUNC_POPSDIO4, + PMUX_FUNC_POPSDMMC4, + PMUX_FUNC_PWM0, + PMUX_FUNC_PWM1, + PMUX_FUNC_PWM2, + PMUX_FUNC_PWM3, + PMUX_FUNC_SATA, + PMUX_FUNC_SPI5, + PMUX_FUNC_SPI6, + PMUX_FUNC_SYSCLK, + PMUX_FUNC_VGP1, + PMUX_FUNC_VGP2, + PMUX_FUNC_VGP3, + PMUX_FUNC_VGP4, + PMUX_FUNC_VGP5, + PMUX_FUNC_VGP6, + + PMUX_FUNC_USB, + PMUX_FUNC_SOC, + PMUX_FUNC_CPU, + PMUX_FUNC_CLK, + PMUX_FUNC_PWRON, + PMUX_FUNC_PMI, + PMUX_FUNC_CLDVFS, + PMUX_FUNC_RESET_OUT_N, + + PMUX_FUNC_SAFE, + PMUX_FUNC_MAX, + + PMUX_FUNC_RSVD1 = 0x8000, + PMUX_FUNC_RSVD2 = 0x8001, + PMUX_FUNC_RSVD3 = 0x8002, + PMUX_FUNC_RSVD4 = 0x8003, +}; + +/* return 1 if a pmux_func is in range */ +#define pmux_func_isvalid(func) ((((func) >= 0) && ((func) < PMUX_FUNC_MAX)) \ + || (((func) >= PMUX_FUNC_RSVD1) && ((func) <= PMUX_FUNC_RSVD4))) + +/* return 1 if a pingrp is in range */ +#define pmux_pingrp_isvalid(pin) (((pin) >= 0) && ((pin) < PINGRP_COUNT)) + +/* The pullup/pulldown state of a pin group */ +enum pmux_pull { + PMUX_PULL_NORMAL = 0, + PMUX_PULL_DOWN, + PMUX_PULL_UP, +}; +/* return 1 if a pin_pupd_is in range */ +#define pmux_pin_pupd_isvalid(pupd) (((pupd) >= PMUX_PULL_NORMAL) && \ + ((pupd) <= PMUX_PULL_UP)) + +/* Defines whether a pin group is tristated or in normal operation */ +enum pmux_tristate { + PMUX_TRI_NORMAL = 0, + PMUX_TRI_TRISTATE = 1, +}; +/* return 1 if a pin_tristate_is in range */ +#define pmux_pin_tristate_isvalid(tristate) (((tristate) >= PMUX_TRI_NORMAL) \ + && ((tristate) <= PMUX_TRI_TRISTATE)) + +enum pmux_pin_io { + PMUX_PIN_OUTPUT = 0, + PMUX_PIN_INPUT = 1, +}; +/* return 1 if a pin_io_is in range */ +#define pmux_pin_io_isvalid(io) (((io) >= PMUX_PIN_OUTPUT) && \ + ((io) <= PMUX_PIN_INPUT)) + +enum pmux_pin_lock { + PMUX_PIN_LOCK_DEFAULT = 0, + PMUX_PIN_LOCK_DISABLE, + PMUX_PIN_LOCK_ENABLE, +}; +/* return 1 if a pin_lock is in range */ +#define pmux_pin_lock_isvalid(lock) (((lock) >= PMUX_PIN_LOCK_DEFAULT) && \ + ((lock) <= PMUX_PIN_LOCK_ENABLE)) + +enum pmux_pin_od { + PMUX_PIN_OD_DEFAULT = 0, + PMUX_PIN_OD_DISABLE, + PMUX_PIN_OD_ENABLE, +}; +/* return 1 if a pin_od is in range */ +#define pmux_pin_od_isvalid(od) (((od) >= PMUX_PIN_OD_DEFAULT) && \ + ((od) <= PMUX_PIN_OD_ENABLE)) + +enum pmux_pin_ioreset { + PMUX_PIN_IO_RESET_DEFAULT = 0, + PMUX_PIN_IO_RESET_DISABLE, + PMUX_PIN_IO_RESET_ENABLE, +}; +/* return 1 if a pin_ioreset_is in range */ +#define pmux_pin_ioreset_isvalid(ioreset) \ + (((ioreset) >= PMUX_PIN_IO_RESET_DEFAULT) && \ + ((ioreset) <= PMUX_PIN_IO_RESET_ENABLE)) + +/* Available power domains used by pin groups */ +enum pmux_vddio { + PMUX_VDDIO_BB = 0, + PMUX_VDDIO_LCD, + PMUX_VDDIO_VI, + PMUX_VDDIO_UART, + PMUX_VDDIO_DDR, + PMUX_VDDIO_NAND, + PMUX_VDDIO_SYS, + PMUX_VDDIO_AUDIO, + PMUX_VDDIO_SD, + PMUX_VDDIO_CAM, + PMUX_VDDIO_GMI, + PMUX_VDDIO_PEXCTL, + PMUX_VDDIO_SDMMC1, + PMUX_VDDIO_SDMMC3, + PMUX_VDDIO_SDMMC4, + + PMUX_VDDIO_NONE +}; + +/* T114 pin drive group and pin mux registers */ +#define PDRIVE_PINGROUP_OFFSET (0x868 >> 2) +#define PMUX_OFFSET ((0x3000 >> 2) - PDRIVE_PINGROUP_OFFSET - \ + PDRIVE_PINGROUP_COUNT) +struct pmux_tri_ctlr { + uint pmt_reserved0; /* ABP_MISC_PP_ reserved offset 00 */ + uint pmt_reserved1; /* ABP_MISC_PP_ reserved offset 04 */ + uint pmt_strap_opt_a; /* _STRAPPING_OPT_A_0, offset 08 */ + uint pmt_reserved2; /* ABP_MISC_PP_ reserved offset 0C */ + uint pmt_reserved3; /* ABP_MISC_PP_ reserved offset 10 */ + uint pmt_reserved4[4]; /* _TRI_STATE_REG_A/B/C/D in t20 */ + uint pmt_cfg_ctl; /* _CONFIG_CTL_0, offset 24 */ + + uint pmt_reserved[528]; /* ABP_MISC_PP_ reserved offs 28-864 */ + + uint pmt_drive[PDRIVE_PINGROUP_COUNT]; /* pin drive grps offs 868 */ + uint pmt_reserved5[PMUX_OFFSET]; + uint pmt_ctl[PINGRP_COUNT]; /* mux/pupd/tri regs, offset 0x3000 */ +}; + +/* + * This defines the configuration for a pin, including the function assigned, + * pull up/down settings and tristate settings. Having set up one of these + * you can call pinmux_config_pingroup() to configure a pin in one step. Also + * available is pinmux_config_table() to configure a list of pins. + */ +struct pingroup_config { + enum pmux_pingrp pingroup; /* pin group PINGRP_... */ + enum pmux_func func; /* function to assign FUNC_... */ + enum pmux_pull pull; /* pull up/down/normal PMUX_PULL_...*/ + enum pmux_tristate tristate; /* tristate or normal PMUX_TRI_... */ + enum pmux_pin_io io; /* input or output PMUX_PIN_... */ + enum pmux_pin_lock lock; /* lock enable/disable PMUX_PIN... */ + enum pmux_pin_od od; /* open-drain or push-pull driver */ + enum pmux_pin_ioreset ioreset; /* input/output reset PMUX_PIN... */ +}; + +/* Set a pin group to tristate */ +void pinmux_tristate_enable(enum pmux_pingrp pin); + +/* Set a pin group to normal (non tristate) */ +void pinmux_tristate_disable(enum pmux_pingrp pin); + +/* Set the pull up/down feature for a pin group */ +void pinmux_set_pullupdown(enum pmux_pingrp pin, enum pmux_pull pupd); + +/* Set the mux function for a pin group */ +void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func); + +/* Set the complete configuration for a pin group */ +void pinmux_config_pingroup(struct pingroup_config *config); + +/* Set a pin group to tristate or normal */ +void pinmux_set_tristate(enum pmux_pingrp pin, int enable); + +/* Set a pin group as input or output */ +void pinmux_set_io(enum pmux_pingrp pin, enum pmux_pin_io io); + +/** + * Configure a list of pin groups + * + * @param config List of config items + * @param len Number of config items in list + */ +void pinmux_config_table(struct pingroup_config *config, int len); + +/* Set a group of pins from a table */ +void pinmux_init(void); + +#endif /* _TEGRA114_PINMUX_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/pmu.h b/arch/arm/include/asm/arch-tegra114/pmu.h new file mode 100644 index 0000000..c6e2381 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/pmu.h @@ -0,0 +1,23 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_PMU_H_ +#define _TEGRA114_PMU_H_ + +/* Set core and CPU voltages to nominal levels */ +int pmu_set_nominal(void); + +#endif /* _TEGRA114_PMU_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/spl.h b/arch/arm/include/asm/arch-tegra114/spl.h new file mode 100644 index 0000000..ebb16fe --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/spl.h @@ -0,0 +1,22 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _ASM_ARCH_SPL_H_ +#define _ASM_ARCH_SPL_H_ + +#define BOOT_DEVICE_RAM 1 + +#endif diff --git a/arch/arm/include/asm/arch-tegra114/tegra.h b/arch/arm/include/asm/arch-tegra114/tegra.h new file mode 100644 index 0000000..a3d12d6 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/tegra.h @@ -0,0 +1,33 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_H_ +#define _TEGRA114_H_ + +#define NV_PA_SDRAM_BASE 0x80000000 /* 0x80000000 for real T114 */ + +#include <asm/arch-tegra/tegra.h> + +#define BCT_ODMDATA_OFFSET 1752 /* offset to ODMDATA word */ + +#undef NVBOOTINFOTABLE_BCTSIZE +#undef NVBOOTINFOTABLE_BCTPTR +#define NVBOOTINFOTABLE_BCTSIZE 0x48 /* BCT size in BIT in IRAM */ +#define NVBOOTINFOTABLE_BCTPTR 0x4C /* BCT pointer in BIT in IRAM */ + +#define MAX_NUM_CPU 4 + +#endif /* TEGRA114_H */
This provides SPL support for T114 boards - AVP early init, plus CPU (A15) init/jump to main U-Boot.
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - update all new copyright header dates to 2013 - use CHIPID directly to figure num cpus - set CPU2/3 bits at runtime using num cpus instead of ifdef - remove private TRUE/FALSE defines, not needed now - clrbits/setbits_le32 used instead of reg read/&/|/write Changes in v3: - only need to powerup the fast cluster
arch/arm/cpu/arm720t/tegra-common/cpu.c | 75 ++++---- arch/arm/cpu/arm720t/tegra-common/cpu.h | 8 +- arch/arm/cpu/arm720t/tegra114/Makefile | 42 +++++ arch/arm/cpu/arm720t/tegra114/config.mk | 19 ++ arch/arm/cpu/arm720t/tegra114/cpu.c | 297 +++++++++++++++++++++++++++++++ 5 files changed, 403 insertions(+), 38 deletions(-) create mode 100644 arch/arm/cpu/arm720t/tegra114/Makefile create mode 100644 arch/arm/cpu/arm720t/tegra114/config.mk create mode 100644 arch/arm/cpu/arm720t/tegra114/cpu.c
diff --git a/arch/arm/cpu/arm720t/tegra-common/cpu.c b/arch/arm/cpu/arm720t/tegra-common/cpu.c index c32925b..119342e 100644 --- a/arch/arm/cpu/arm720t/tegra-common/cpu.c +++ b/arch/arm/cpu/arm720t/tegra-common/cpu.c @@ -25,30 +25,24 @@ #include <asm/arch-tegra/scu.h> #include "cpu.h"
-enum tegra_family_t { - TEGRA_FAMILY_T2x, - TEGRA_FAMILY_T3x, -}; - - -enum tegra_family_t get_family(void) -{ - u32 reg, chip_id; - - reg = readl(NV_PA_APB_MISC_BASE + GP_HIDREV); - - chip_id = reg >> 8; - chip_id &= 0xff; - debug(" tegra_get_family: chip_id = %x\n", chip_id); - if (chip_id == 0x30) - return TEGRA_FAMILY_T3x; - else - return TEGRA_FAMILY_T2x; -} - int get_num_cpus(void) { - return get_family() == TEGRA_FAMILY_T3x ? 4 : 2; + struct apb_misc_gp_ctlr *gp; + uint rev; + + gp = (struct apb_misc_gp_ctlr *)NV_PA_APB_MISC_GP_BASE; + rev = (readl(&gp->hidrev) & HIDREV_CHIPID_MASK) >> HIDREV_CHIPID_SHIFT; + + switch (rev) { + case CHIPID_TEGRA20: + return 2; + break; + case CHIPID_TEGRA30: + case CHIPID_TEGRA114: + default: + return 4; + break; + } }
/* @@ -56,6 +50,7 @@ int get_num_cpus(void) */ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { /* T20: 1 GHz */ + /* n, m, p, cpcon */ {{ 1000, 13, 0, 12}, /* OSC 13M */ { 625, 12, 0, 8}, /* OSC 19.2M */ { 1000, 12, 0, 12}, /* OSC 12M */ @@ -75,6 +70,13 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { { 700, 6, 0, 8}, { 700, 13, 0, 8}, }, + + /* T114: 1.4 GHz */ + {{ 862, 8, 0, 8}, + { 583, 8, 0, 4}, + { 696, 12, 0, 8}, + { 700, 13, 0, 8}, + }, };
void adjust_pllp_out_freqs(void) @@ -159,8 +161,8 @@ void init_pllx(void) sel = &tegra_pll_x_table[chip_type][osc]; pllx_set_rate(pll, sel->n, sel->m, sel->p, sel->cpcon);
- /* adjust PLLP_out1-4 on T30 */ - if (chip_type == TEGRA_SOC_T30) { + /* adjust PLLP_out1-4 on T30/T114 */ + if (chip_type == TEGRA_SOC_T30 || chip_type == TEGRA_SOC_T114) { debug(" init_pllx: adjusting PLLP out freqs\n"); adjust_pllp_out_freqs(); } @@ -196,10 +198,9 @@ void enable_cpu_clock(int enable) */ clk = readl(&clkrst->crc_clk_cpu_cmplx); clk |= 1 << CPU1_CLK_STP_SHIFT; -#if defined(CONFIG_TEGRA30) - clk |= 1 << CPU2_CLK_STP_SHIFT; - clk |= 1 << CPU3_CLK_STP_SHIFT; -#endif + if (get_num_cpus() == 4) + clk |= (1 << CPU2_CLK_STP_SHIFT) + (1 << CPU3_CLK_STP_SHIFT); + /* Stop/Unstop the CPU clock */ clk &= ~CPU0_CLK_STP_MASK; clk |= !enable << CPU0_CLK_STP_SHIFT; @@ -285,7 +286,8 @@ void reset_A9_cpu(int reset)
void clock_enable_coresight(int enable) { - u32 rst, src; + u32 rst, src = 2; + int chip;
debug("clock_enable_coresight entry\n"); clock_set_enable(PERIPH_ID_CORESIGHT, enable); @@ -301,20 +303,23 @@ void clock_enable_coresight(int enable) * Clock divider request for 204MHz would setup CSITE clock as * 144MHz for PLLP base 216MHz and 204MHz for PLLP base 408MHz */ - if (tegra_get_chip_type() == TEGRA_SOC_T30) + chip = tegra_get_chip_type(); + if (chip == TEGRA_SOC_T30 || chip == TEGRA_SOC_T114) src = CLK_DIVIDER(NVBL_PLLP_KHZ, 204000); - else + else if (chip == TEGRA_SOC_T20 || chip == TEGRA_SOC_T25) src = CLK_DIVIDER(NVBL_PLLP_KHZ, 144000); + else + printf("%s: Unknown chip type %X!\n", __func__, chip); clock_ll_set_source_divisor(PERIPH_ID_CSI, 0, src);
/* Unlock the CPU CoreSight interfaces */ rst = CORESIGHT_UNLOCK; writel(rst, CSITE_CPU_DBG0_LAR); writel(rst, CSITE_CPU_DBG1_LAR); -#if defined(CONFIG_TEGRA30) - writel(rst, CSITE_CPU_DBG2_LAR); - writel(rst, CSITE_CPU_DBG3_LAR); -#endif + if (get_num_cpus() == 4) { + writel(rst, CSITE_CPU_DBG2_LAR); + writel(rst, CSITE_CPU_DBG3_LAR); + } } }
diff --git a/arch/arm/cpu/arm720t/tegra-common/cpu.h b/arch/arm/cpu/arm720t/tegra-common/cpu.h index 3e2ea3a..e8e05d7 100644 --- a/arch/arm/cpu/arm720t/tegra-common/cpu.h +++ b/arch/arm/cpu/arm720t/tegra-common/cpu.h @@ -26,10 +26,12 @@ #define PLL_STABILIZATION_DELAY (300) #define IO_STABILIZATION_DELAY (1000)
-#if defined(CONFIG_TEGRA30) -#define NVBL_PLLP_KHZ (408000) -#else /* Tegra20 */ +#if defined(CONFIG_TEGRA20) #define NVBL_PLLP_KHZ (216000) +#elif defined(CONFIG_TEGRA30) || defined(CONFIG_TEGRA114) +#define NVBL_PLLP_KHZ (408000) +#else +#error "Unknown Tegra chip!" #endif
#define PLLX_ENABLED (1 << 30) diff --git a/arch/arm/cpu/arm720t/tegra114/Makefile b/arch/arm/cpu/arm720t/tegra114/Makefile new file mode 100644 index 0000000..6cf7fe9 --- /dev/null +++ b/arch/arm/cpu/arm720t/tegra114/Makefile @@ -0,0 +1,42 @@ +# +# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. +# +# (C) Copyright 2000-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms and conditions of the GNU General Public License, +# version 2, as published by the Free Software Foundation. +# +# This program is distributed in the hope it will be useful, but WITHOUT +# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for +# more details. +# +# You should have received a copy of the GNU General Public License +# along with this program. If not, see http://www.gnu.org/licenses/. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +#COBJS-y += cpu.o t11x.o +COBJS-y += cpu.o + +SRCS := $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm720t/tegra114/config.mk b/arch/arm/cpu/arm720t/tegra114/config.mk new file mode 100644 index 0000000..7947b50 --- /dev/null +++ b/arch/arm/cpu/arm720t/tegra114/config.mk @@ -0,0 +1,19 @@ +# +# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, garyj@denx.de +# +# This program is free software; you can redistribute it and/or modify it +# under the terms and conditions of the GNU General Public License, +# version 2, as published by the Free Software Foundation. +# +# This program is distributed in the hope it will be useful, but WITHOUT +# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for +# more details. +# +# You should have received a copy of the GNU General Public License +# along with this program. If not, see http://www.gnu.org/licenses/. +# +USE_PRIVATE_LIBGCC = yes diff --git a/arch/arm/cpu/arm720t/tegra114/cpu.c b/arch/arm/cpu/arm720t/tegra114/cpu.c new file mode 100644 index 0000000..5962e15 --- /dev/null +++ b/arch/arm/cpu/arm720t/tegra114/cpu.c @@ -0,0 +1,297 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/flow.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/tegra.h> +#include <asm/arch-tegra/clk_rst.h> +#include <asm/arch-tegra/pmc.h> +#include "../tegra-common/cpu.h" + +/* Tegra114-specific CPU init code */ +static void enable_cpu_power_rail(void) +{ + struct pmc_ctlr *pmc = (struct pmc_ctlr *)NV_PA_PMC_BASE; + struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg; + + debug("enable_cpu_power_rail entry\n"); + + /* un-tristate PWR_I2C SCL/SDA, rest of the defaults are correct */ + pinmux_tristate_disable(PINGRP_PWR_I2C_SCL); + pinmux_tristate_disable(PINGRP_PWR_I2C_SDA); + + /* + * Set CPUPWRGOOD_TIMER - APB clock is 1/2 of SCLK (102MHz), + * set it for 25ms (102MHz * .025) + */ + reg = 0x26E8F0; + writel(reg, &pmc->pmc_cpupwrgood_timer); + + /* Set polarity to 0 (normal) and enable CPUPWRREQ_OE */ + clrbits_le32(&pmc->pmc_cntrl, CPUPWRREQ_POL); + setbits_le32(&pmc->pmc_cntrl, CPUPWRREQ_OE); + + /* + * Set CLK_RST_CONTROLLER_CPU_SOFTRST_CTRL2_0_CAR2PMC_CPU_ACK_WIDTH + * to 408 to satisfy the requirement of having at least 16 CPU clock + * cycles before clamp removal. + */ + + clrbits_le32(&clkrst->crc_cpu_softrst_ctrl2, 0xFFF); + setbits_le32(&clkrst->crc_cpu_softrst_ctrl2, 408); +} + +static void enable_cpu_clocks(void) +{ + struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg; + + debug("enable_cpu_clocks entry\n"); + + /* Wait for PLL-X to lock */ + do { + reg = readl(&clkrst->crc_pll_simple[SIMPLE_PLLX].pll_base); + } while ((reg & (1 << 27)) == 0); + + /* Wait until all clocks are stable */ + udelay(PLL_STABILIZATION_DELAY); + + writel(CCLK_BURST_POLICY, &clkrst->crc_cclk_brst_pol); + writel(SUPER_CCLK_DIVIDER, &clkrst->crc_super_cclk_div); + + /* Always enable the main CPU complex clocks */ + clock_enable(PERIPH_ID_CPU); + clock_enable(PERIPH_ID_CPULP); + clock_enable(PERIPH_ID_CPUG); +} + +static void remove_cpu_resets(void) +{ + struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg; + + debug("remove_cpu_resets entry\n"); + /* Take the slow non-CPU partition out of reset */ + reg = readl(&clkrst->crc_rst_cpulp_cmplx_clr); + writel((reg | CLR_NONCPURESET), &clkrst->crc_rst_cpulp_cmplx_clr); + + /* Take the fast non-CPU partition out of reset */ + reg = readl(&clkrst->crc_rst_cpug_cmplx_clr); + writel((reg | CLR_NONCPURESET), &clkrst->crc_rst_cpug_cmplx_clr); + + /* Clear the SW-controlled reset of the slow cluster */ + reg = readl(&clkrst->crc_rst_cpulp_cmplx_clr); + reg |= (CLR_CPURESET0+CLR_DBGRESET0+CLR_CORERESET0+CLR_CXRESET0); + writel(reg, &clkrst->crc_rst_cpulp_cmplx_clr); + + /* Clear the SW-controlled reset of the fast cluster */ + reg = readl(&clkrst->crc_rst_cpug_cmplx_clr); + reg |= (CLR_CPURESET0+CLR_DBGRESET0+CLR_CORERESET0+CLR_CXRESET0); + reg |= (CLR_CPURESET1+CLR_DBGRESET1+CLR_CORERESET1+CLR_CXRESET1); + reg |= (CLR_CPURESET2+CLR_DBGRESET2+CLR_CORERESET2+CLR_CXRESET2); + reg |= (CLR_CPURESET3+CLR_DBGRESET3+CLR_CORERESET3+CLR_CXRESET3); + writel(reg, &clkrst->crc_rst_cpug_cmplx_clr); +} + +/** + * The T114 requires some special clock initialization, including setting up + * the DVC I2C, turning on MSELECT and selecting the G CPU cluster + */ +void t114_init_clocks(void) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + struct flow_ctlr *flow = (struct flow_ctlr *)NV_PA_FLOW_BASE; + u32 val; + + debug("t114_init_clocks entry\n"); + + /* Set active CPU cluster to G */ + clrbits_le32(&flow->cluster_control, 1); + + /* + * Switch system clock to PLLP_OUT4 (108 MHz), AVP will now run + * at 108 MHz. This is glitch free as only the source is changed, no + * special precaution needed. + */ + val = (SCLK_SOURCE_PLLP_OUT4 << SCLK_SWAKEUP_FIQ_SOURCE_SHIFT) | + (SCLK_SOURCE_PLLP_OUT4 << SCLK_SWAKEUP_IRQ_SOURCE_SHIFT) | + (SCLK_SOURCE_PLLP_OUT4 << SCLK_SWAKEUP_RUN_SOURCE_SHIFT) | + (SCLK_SOURCE_PLLP_OUT4 << SCLK_SWAKEUP_IDLE_SOURCE_SHIFT) | + (SCLK_SYS_STATE_RUN << SCLK_SYS_STATE_SHIFT); + writel(val, &clkrst->crc_sclk_brst_pol); + + writel(SUPER_SCLK_ENB_MASK, &clkrst->crc_super_sclk_div); + + debug("Setting up PLLX\n"); + init_pllx(); + + val = (1 << CLK_SYS_RATE_AHB_RATE_SHIFT); + writel(val, &clkrst->crc_clk_sys_rate); + + /* Enable clocks to required peripherals. TBD - minimize this list */ + debug("Enabling clocks\n"); + + clock_set_enable(PERIPH_ID_CACHE2, 1); + clock_set_enable(PERIPH_ID_GPIO, 1); + clock_set_enable(PERIPH_ID_TMR, 1); + clock_set_enable(PERIPH_ID_RTC, 1); + clock_set_enable(PERIPH_ID_CPU, 1); + clock_set_enable(PERIPH_ID_EMC, 1); + clock_set_enable(PERIPH_ID_I2C5, 1); + clock_set_enable(PERIPH_ID_FUSE, 1); + clock_set_enable(PERIPH_ID_PMC, 1); + clock_set_enable(PERIPH_ID_APBDMA, 1); + clock_set_enable(PERIPH_ID_MEM, 1); + clock_set_enable(PERIPH_ID_IRAMA, 1); + clock_set_enable(PERIPH_ID_IRAMB, 1); + clock_set_enable(PERIPH_ID_IRAMC, 1); + clock_set_enable(PERIPH_ID_IRAMD, 1); + clock_set_enable(PERIPH_ID_CORESIGHT, 1); + clock_set_enable(PERIPH_ID_MSELECT, 1); + clock_set_enable(PERIPH_ID_EMC1, 1); + clock_set_enable(PERIPH_ID_MC1, 1); + clock_set_enable(PERIPH_ID_DVFS, 1); + + /* Switch MSELECT clock to PLLP (00) */ + clock_ll_set_source(PERIPH_ID_MSELECT, 0); + + /* + * Clock divider request for 102MHz would setup MSELECT clock as + * 102MHz for PLLP base 408MHz + */ + clock_ll_set_source_divisor(PERIPH_ID_MSELECT, 0, + (NVBL_PLLP_KHZ/102000)); + + /* I2C5 (DVC) gets CLK_M and a divisor of 17 */ + clock_ll_set_source_divisor(PERIPH_ID_I2C5, 3, 16); + + /* Give clocks time to stabilize */ + udelay(1000); + + /* Take required peripherals out of reset */ + debug("Taking periphs out of reset\n"); + reset_set_enable(PERIPH_ID_CACHE2, 0); + reset_set_enable(PERIPH_ID_GPIO, 0); + reset_set_enable(PERIPH_ID_TMR, 0); + reset_set_enable(PERIPH_ID_COP, 0); + reset_set_enable(PERIPH_ID_EMC, 0); + reset_set_enable(PERIPH_ID_I2C5, 0); + reset_set_enable(PERIPH_ID_FUSE, 0); + reset_set_enable(PERIPH_ID_APBDMA, 0); + reset_set_enable(PERIPH_ID_MEM, 0); + reset_set_enable(PERIPH_ID_CORESIGHT, 0); + reset_set_enable(PERIPH_ID_MSELECT, 0); + reset_set_enable(PERIPH_ID_EMC1, 0); + reset_set_enable(PERIPH_ID_MC1, 0); + + debug("t114_init_clocks exit\n"); +} + +static int is_partition_powered(u32 mask) +{ + struct pmc_ctlr *pmc = (struct pmc_ctlr *)NV_PA_PMC_BASE; + u32 reg; + + /* Get power gate status */ + reg = readl(&pmc->pmc_pwrgate_status); + return (reg & mask) == mask; +} + +static int is_clamp_enabled(u32 mask) +{ + struct pmc_ctlr *pmc = (struct pmc_ctlr *)NV_PA_PMC_BASE; + u32 reg; + + /* Get clamp status. TODO: Add pmc_clamp_status alias to pmc.h */ + reg = readl(&pmc->pmc_pwrgate_timer_on); + return (reg & mask) == mask; +} + +static void power_partition(u32 status, u32 partid) +{ + struct pmc_ctlr *pmc = (struct pmc_ctlr *)NV_PA_PMC_BASE; + + debug("%s: status = %08X, part ID = %08X\n", __func__, status, partid); + /* Is the partition already on? */ + if (!is_partition_powered(status)) { + /* No, toggle the partition power state (OFF -> ON) */ + debug("power_partition, toggling state\n"); + clrbits_le32(&pmc->pmc_pwrgate_toggle, 0x1F); + setbits_le32(&pmc->pmc_pwrgate_toggle, partid); + setbits_le32(&pmc->pmc_pwrgate_toggle, START_CP); + + /* Wait for the power to come up */ + while (!is_partition_powered(status)) + ; + + /* Wait for the clamp status to be cleared */ + while (is_clamp_enabled(status)) + ; + + /* Give I/O signals time to stabilize */ + udelay(IO_STABILIZATION_DELAY); + } +} + +void powerup_cpus(void) +{ + debug("powerup_cpus entry\n"); + + /* We boot to the fast cluster */ + debug("powerup_cpus entry: G cluster\n"); + /* Power up the fast cluster rail partition */ + power_partition(CRAIL, CRAILID); + + /* Power up the fast cluster non-CPU partition */ + power_partition(C0NC, C0NCID); + + /* Power up the fast cluster CPU0 partition */ + power_partition(CE0, CE0ID); +} + +void start_cpu(u32 reset_vector) +{ + debug("start_cpu entry, reset_vector = %x\n", reset_vector); + + t114_init_clocks(); + + /* Enable VDD_CPU */ + enable_cpu_power_rail(); + + /* Get the CPU(s) running */ + enable_cpu_clocks(); + + /* Enable CoreSight */ + clock_enable_coresight(1); + + /* Take CPU(s) out of reset */ + remove_cpu_resets(); + + /* + * Set the entry point for CPU execution from reset, + * if it's a non-zero value. + */ + if (reset_vector) + writel(reset_vector, EXCEP_VECTOR_CPU_RESET_VECTOR); + + /* If the CPU(s) don't already have power, power 'em up */ + powerup_cpus(); +}
These files are for code that runs on the CPU (A15) on T114 boards. At this time, there is no A15-specific code here. As T114-specific run-time code is added, it'll go here.
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - update all new copyright header dates to 2013 Changes in v3: - none
arch/arm/cpu/armv7/tegra114/Makefile | 40 +++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/tegra114/config.mk | 19 +++++++++++++++ 2 files changed, 59 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra114/Makefile create mode 100644 arch/arm/cpu/armv7/tegra114/config.mk
diff --git a/arch/arm/cpu/armv7/tegra114/Makefile b/arch/arm/cpu/armv7/tegra114/Makefile new file mode 100644 index 0000000..eb98c8e --- /dev/null +++ b/arch/arm/cpu/armv7/tegra114/Makefile @@ -0,0 +1,40 @@ +# +# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms and conditions of the GNU General Public License, +# version 2, as published by the Free Software Foundation. +# +# This program is distributed in the hope it will be useful, but WITHOUT +# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for +# more details. +# +# You should have received a copy of the GNU General Public License +# along with this program. If not, see http://www.gnu.org/licenses/. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/tegra114/config.mk b/arch/arm/cpu/armv7/tegra114/config.mk new file mode 100644 index 0000000..cb1a19d --- /dev/null +++ b/arch/arm/cpu/armv7/tegra114/config.mk @@ -0,0 +1,19 @@ +# +# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, garyj@denx.de +# +# This program is free software; you can redistribute it and/or modify it +# under the terms and conditions of the GNU General Public License, +# version 2, as published by the Free Software Foundation. +# +# This program is distributed in the hope it will be useful, but WITHOUT +# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for +# more details. +# +# You should have received a copy of the GNU General Public License +# along with this program. If not, see http://www.gnu.org/licenses/. +# +CONFIG_ARCH_DEVICE_TREE := tegra114
These files are used by both SPL and main U-Boot.
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - update all new copyright header dates to 2013 - use ODMDATA correctly in query_dram_size Changes in v3: - rename T114 SKU ID - use common clock code
arch/arm/cpu/tegra-common/ap.c | 9 +- arch/arm/cpu/tegra-common/board.c | 21 +- arch/arm/cpu/tegra114-common/Makefile | 41 ++ arch/arm/cpu/tegra114-common/clock.c | 655 ++++++++++++++++++++++++++++++++ arch/arm/cpu/tegra114-common/funcmux.c | 63 +++ arch/arm/cpu/tegra114-common/pinmux.c | 506 ++++++++++++++++++++++++ 6 files changed, 1291 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/tegra114-common/Makefile create mode 100644 arch/arm/cpu/tegra114-common/clock.c create mode 100644 arch/arm/cpu/tegra114-common/funcmux.c create mode 100644 arch/arm/cpu/tegra114-common/pinmux.c
diff --git a/arch/arm/cpu/tegra-common/ap.c b/arch/arm/cpu/tegra-common/ap.c index aebe29e..236cda8 100644 --- a/arch/arm/cpu/tegra-common/ap.c +++ b/arch/arm/cpu/tegra-common/ap.c @@ -31,6 +31,7 @@ #include <asm/arch-tegra/fuse.h> #include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/scu.h> +#include <asm/arch-tegra/tegra.h> #include <asm/arch-tegra/warmboot.h>
int tegra_get_chip_type(void) @@ -42,7 +43,7 @@ int tegra_get_chip_type(void) /* * This is undocumented, Chip ID is bits 15:8 of the register * APB_MISC + 0x804, and has value 0x20 for Tegra20, 0x30 for - * Tegra30 + * Tegra30, and 0x35 for T114. */ gp = (struct apb_misc_gp_ctlr *)NV_PA_APB_MISC_GP_BASE; rev = (readl(&gp->hidrev) & HIDREV_CHIPID_MASK) >> HIDREV_CHIPID_SHIFT; @@ -68,6 +69,12 @@ int tegra_get_chip_type(void) return TEGRA_SOC_T30; } break; + case CHIPID_TEGRA114: + switch (tegra_sku_id) { + case SKU_ID_T114_ENG: + return TEGRA_SOC_T114; + } + break; } /* unknown sku id */ return TEGRA_SOC_UNKNOWN; diff --git a/arch/arm/cpu/tegra-common/board.c b/arch/arm/cpu/tegra-common/board.c index 1ec6c06..08bfa64 100644 --- a/arch/arm/cpu/tegra-common/board.c +++ b/arch/arm/cpu/tegra-common/board.c @@ -37,8 +37,10 @@ enum { /* UARTs which we can enable */ UARTA = 1 << 0, UARTB = 1 << 1, + UARTC = 1 << 2, UARTD = 1 << 3, - UART_COUNT = 4, + UARTE = 1 << 4, + UART_COUNT = 5, };
/* @@ -68,7 +70,7 @@ unsigned int query_sdram_size(void) case 3: return 0x40000000; /* 1GB */ } -#else /* Tegra30 */ +#else /* Tegra30/Tegra114 */ /* bits 31:28 in OdmData are used for RAM size on T30 */ switch ((reg) >> 28) { case 0: @@ -117,12 +119,18 @@ static int uart_configs[] = { -1, FUNCMUX_UART4_GMC, -1, -#else /* Tegra30 */ +#elif defined(CONFIG_TEGRA30) FUNCMUX_UART1_ULPI, /* UARTA */ -1, -1, -1, -1, +#else /* Tegra114 */ + -1, + -1, + -1, + FUNCMUX_UART4_GMI, /* UARTD */ + -1, #endif };
@@ -138,6 +146,7 @@ static void setup_uarts(int uart_ids) PERIPH_ID_UART2, PERIPH_ID_UART3, PERIPH_ID_UART4, + PERIPH_ID_UART5, }; size_t i;
@@ -161,9 +170,15 @@ void board_init_uart_f(void) #ifdef CONFIG_TEGRA_ENABLE_UARTB uart_ids |= UARTB; #endif +#ifdef CONFIG_TEGRA_ENABLE_UARTC + uart_ids |= UARTC; +#endif #ifdef CONFIG_TEGRA_ENABLE_UARTD uart_ids |= UARTD; #endif +#ifdef CONFIG_TEGRA_ENABLE_UARTE + uart_ids |= UARTE; +#endif setup_uarts(uart_ids); }
diff --git a/arch/arm/cpu/tegra114-common/Makefile b/arch/arm/cpu/tegra114-common/Makefile new file mode 100644 index 0000000..5b53a71 --- /dev/null +++ b/arch/arm/cpu/tegra114-common/Makefile @@ -0,0 +1,41 @@ +# +# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. +# +# (C) Copyright 2000-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms and conditions of the GNU General Public License, +# version 2, as published by the Free Software Foundation. +# +# This program is distributed in the hope it will be useful, but WITHOUT +# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for +# more details. +# +# You should have received a copy of the GNU General Public License +# along with this program. If not, see http://www.gnu.org/licenses/. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC)-common.o + +COBJS-y += clock.o funcmux.o pinmux.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/tegra114-common/clock.c b/arch/arm/cpu/tegra114-common/clock.c new file mode 100644 index 0000000..9b29ce1 --- /dev/null +++ b/arch/arm/cpu/tegra114-common/clock.c @@ -0,0 +1,655 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +/* Tegra114 Clock control functions */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/tegra.h> +#include <asm/arch-tegra/clk_rst.h> +#include <asm/arch-tegra/timer.h> +#include <div64.h> +#include <fdtdec.h> + +/* + * Clock types that we can use as a source. The Tegra114 has muxes for the + * peripheral clocks, and in most cases there are four options for the clock + * source. This gives us a clock 'type' and exploits what commonality exists + * in the device. + * + * Letters are obvious, except for T which means CLK_M, and S which means the + * clock derived from 32KHz. Beware that CLK_M (also called OSC in the + * datasheet) and PLL_M are different things. The former is the basic + * clock supplied to the SOC from an external oscillator. The latter is the + * memory clock PLL. + * + * See definitions in clock_id in the header file. + */ +enum clock_type_id { + CLOCK_TYPE_AXPT, /* PLL_A, PLL_X, PLL_P, CLK_M */ + CLOCK_TYPE_MCPA, /* and so on */ + CLOCK_TYPE_MCPT, + CLOCK_TYPE_PCM, + CLOCK_TYPE_PCMT, + CLOCK_TYPE_PCMT16, + CLOCK_TYPE_PDCT, + CLOCK_TYPE_ACPT, + CLOCK_TYPE_ASPTE, + CLOCK_TYPE_PMDACD2T, + CLOCK_TYPE_PCST, + + CLOCK_TYPE_COUNT, + CLOCK_TYPE_NONE = -1, /* invalid clock type */ +}; + +enum { + CLOCK_MAX_MUX = 8 /* number of source options for each clock */ +}; + +enum { + MASK_BITS_31_30 = 2, /* num of bits used to specify clock source */ + MASK_BITS_31_29, + MASK_BITS_29_28, +}; + +/* + * Clock source mux for each clock type. This just converts our enum into + * a list of mux sources for use by the code. + * + * Note: + * The extra column in each clock source array is used to store the mask + * bits in its register for the source. + */ +#define CLK(x) CLOCK_ID_ ## x +static enum clock_id clock_source[CLOCK_TYPE_COUNT][CLOCK_MAX_MUX+1] = { + { CLK(AUDIO), CLK(XCPU), CLK(PERIPH), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(MEMORY), CLK(CGENERAL), CLK(PERIPH), CLK(AUDIO), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(MEMORY), CLK(CGENERAL), CLK(PERIPH), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(PERIPH), CLK(CGENERAL), CLK(MEMORY), CLK(NONE), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(PERIPH), CLK(CGENERAL), CLK(MEMORY), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(PERIPH), CLK(CGENERAL), CLK(MEMORY), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(PERIPH), CLK(DISPLAY), CLK(CGENERAL), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(AUDIO), CLK(CGENERAL), CLK(PERIPH), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + { CLK(AUDIO), CLK(SFROM32KHZ), CLK(PERIPH), CLK(OSC), + CLK(EPCI), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_29}, + { CLK(PERIPH), CLK(MEMORY), CLK(DISPLAY), CLK(AUDIO), + CLK(CGENERAL), CLK(DISPLAY2), CLK(OSC), CLK(NONE), + MASK_BITS_31_29}, + { CLK(PERIPH), CLK(CGENERAL), CLK(SFROM32KHZ), CLK(OSC), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_29_28} +}; + +/* + * Clock type for each peripheral clock source. We put the name in each + * record just so it is easy to match things up + */ +#define TYPE(name, type) type +static enum clock_type_id clock_periph_type[PERIPHC_COUNT] = { + /* 0x00 */ + TYPE(PERIPHC_I2S1, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_I2S2, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_SPDIF_OUT, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_SPDIF_IN, CLOCK_TYPE_PCM), + TYPE(PERIPHC_PWM, CLOCK_TYPE_PCST), /* only PWM uses b29:28 */ + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SBC2, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_SBC3, CLOCK_TYPE_PCMT), + + /* 0x08 */ + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_I2C1, CLOCK_TYPE_PCMT16), + TYPE(PERIPHC_I2C5, CLOCK_TYPE_PCMT16), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SBC1, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_DISP1, CLOCK_TYPE_PMDACD2T), + TYPE(PERIPHC_DISP2, CLOCK_TYPE_PMDACD2T), + + /* 0x10 */ + TYPE(PERIPHC_CVE, CLOCK_TYPE_PDCT), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_VI, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SDMMC1, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_SDMMC2, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_G3D, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_G2D, CLOCK_TYPE_MCPA), + + /* 0x18 */ + TYPE(PERIPHC_NDFLASH, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_SDMMC4, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_VFIR, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_EPP, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_MPE, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_MIPI, CLOCK_TYPE_PCMT), /* MIPI base-band HSI */ + TYPE(PERIPHC_UART1, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_UART2, CLOCK_TYPE_PCMT), + + /* 0x20 */ + TYPE(PERIPHC_HOST1X, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_TVO, CLOCK_TYPE_PDCT), + TYPE(PERIPHC_HDMI, CLOCK_TYPE_PMDACD2T), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_TVDAC, CLOCK_TYPE_PDCT), + TYPE(PERIPHC_I2C2, CLOCK_TYPE_PCMT16), + TYPE(PERIPHC_EMC, CLOCK_TYPE_MCPT), + + /* 0x28 */ + TYPE(PERIPHC_UART3, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_VI, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SBC4, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_I2C3, CLOCK_TYPE_PCMT16), + TYPE(PERIPHC_SDMMC3, CLOCK_TYPE_PCMT), + + /* 0x30 */ + TYPE(PERIPHC_UART4, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_UART5, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_VDE, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_OWR, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_NOR, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_CSITE, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_I2S0, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + + /* 0x38h */ /* Jumps to reg offset 0x3B0h */ + TYPE(PERIPHC_G3D2, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_MSELECT, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_TSENSOR, CLOCK_TYPE_PCST), /* s/b PCTS */ + TYPE(PERIPHC_I2S3, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_I2S4, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_I2C4, CLOCK_TYPE_PCMT16), + TYPE(PERIPHC_SBC5, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_SBC6, CLOCK_TYPE_PCMT), + + /* 0x40 */ + TYPE(PERIPHC_AUDIO, CLOCK_TYPE_ACPT), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_DAM0, CLOCK_TYPE_ACPT), + TYPE(PERIPHC_DAM1, CLOCK_TYPE_ACPT), + TYPE(PERIPHC_DAM2, CLOCK_TYPE_ACPT), + TYPE(PERIPHC_HDA2CODEC2X, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_ACTMON, CLOCK_TYPE_PCST), /* MASK 31:30 */ + TYPE(PERIPHC_EXTPERIPH1, CLOCK_TYPE_ASPTE), + + /* 0x48 */ + TYPE(PERIPHC_EXTPERIPH2, CLOCK_TYPE_ASPTE), + TYPE(PERIPHC_EXTPERIPH3, CLOCK_TYPE_ASPTE), + TYPE(PERIPHC_NANDSPEED, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_I2CSLOW, CLOCK_TYPE_PCST), /* MASK 31:30 */ + TYPE(PERIPHC_SYS, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SPEEDO, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + + /* 0x50 */ + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SATAOOB, CLOCK_TYPE_PCMT), /* offset 0x420h */ + TYPE(PERIPHC_SATA, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_HDA, CLOCK_TYPE_PCMT), +}; + +/* + * This array translates a periph_id to a periphc_internal_id + * + * Not present/matched up: + * uint vi_sensor; _VI_SENSOR_0, 0x1A8 + * SPDIF - which is both 0x08 and 0x0c + * + */ +#define NONE(name) (-1) +#define OFFSET(name, value) PERIPHC_ ## name +static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = { + /* Low word: 31:0 */ + NONE(CPU), + NONE(COP), + NONE(TRIGSYS), + NONE(RESERVED3), + NONE(RTC), + NONE(TMR), + PERIPHC_UART1, + PERIPHC_UART2, /* and vfir 0x68 */ + + /* 8 */ + NONE(GPIO), + PERIPHC_SDMMC2, + NONE(SPDIF), /* 0x08 and 0x0c, unclear which to use */ + PERIPHC_I2S1, + PERIPHC_I2C1, + PERIPHC_NDFLASH, + PERIPHC_SDMMC1, + PERIPHC_SDMMC4, + + /* 16 */ + NONE(RESERVED16), + PERIPHC_PWM, + PERIPHC_I2S2, + PERIPHC_EPP, + PERIPHC_VI, + PERIPHC_G2D, + NONE(USBD), + NONE(ISP), + + /* 24 */ + PERIPHC_G3D, + NONE(RESERVED25), + PERIPHC_DISP2, + PERIPHC_DISP1, + PERIPHC_HOST1X, + NONE(VCP), + PERIPHC_I2S0, + NONE(CACHE2), + + /* Middle word: 63:32 */ + NONE(MEM), + NONE(AHBDMA), + NONE(APBDMA), + NONE(RESERVED35), + NONE(RESERVED36), + NONE(STAT_MON), + NONE(RESERVED38), + NONE(RESERVED39), + + /* 40 */ + NONE(KFUSE), + NONE(SBC1), /* SBC1, 0x34, is this SPI1? */ + PERIPHC_NOR, + NONE(RESERVED43), + PERIPHC_SBC2, + NONE(RESERVED45), + PERIPHC_SBC3, + PERIPHC_I2C5, + + /* 48 */ + NONE(DSI), + PERIPHC_TVO, /* also CVE 0x40 */ + PERIPHC_MIPI, + PERIPHC_HDMI, + NONE(CSI), + PERIPHC_TVDAC, + PERIPHC_I2C2, + PERIPHC_UART3, + + /* 56 */ + NONE(RESERVED56), + PERIPHC_EMC, + NONE(USB2), + NONE(USB3), + PERIPHC_MPE, + PERIPHC_VDE, + NONE(BSEA), + NONE(BSEV), + + /* Upper word 95:64 */ + PERIPHC_SPEEDO, + PERIPHC_UART4, + PERIPHC_UART5, + PERIPHC_I2C3, + PERIPHC_SBC4, + PERIPHC_SDMMC3, + NONE(PCIE), + PERIPHC_OWR, + + /* 72 */ + NONE(AFI), + PERIPHC_CSITE, + NONE(PCIEXCLK), + NONE(AVPUCQ), + NONE(RESERVED76), + NONE(RESERVED77), + NONE(RESERVED78), + NONE(DTV), + + /* 80 */ + PERIPHC_NANDSPEED, + PERIPHC_I2CSLOW, + NONE(DSIB), + NONE(RESERVED83), + NONE(IRAMA), + NONE(IRAMB), + NONE(IRAMC), + NONE(IRAMD), + + /* 88 */ + NONE(CRAM2), + NONE(RESERVED89), + NONE(MDOUBLER), + NONE(RESERVED91), + NONE(SUSOUT), + NONE(RESERVED93), + NONE(RESERVED94), + NONE(RESERVED95), + + /* V word: 31:0 */ + NONE(CPUG), + NONE(CPULP), + PERIPHC_G3D2, + PERIPHC_MSELECT, + PERIPHC_TSENSOR, + PERIPHC_I2S3, + PERIPHC_I2S4, + PERIPHC_I2C4, + + /* 08 */ + PERIPHC_SBC5, + PERIPHC_SBC6, + PERIPHC_AUDIO, + NONE(APBIF), + PERIPHC_DAM0, + PERIPHC_DAM1, + PERIPHC_DAM2, + PERIPHC_HDA2CODEC2X, + + /* 16 */ + NONE(ATOMICS), + NONE(RESERVED17), + NONE(RESERVED18), + NONE(RESERVED19), + NONE(RESERVED20), + NONE(RESERVED21), + NONE(RESERVED22), + PERIPHC_ACTMON, + + /* 24 */ + NONE(RESERVED24), + NONE(RESERVED25), + NONE(RESERVED26), + NONE(RESERVED27), + PERIPHC_SATA, + PERIPHC_HDA, + NONE(RESERVED30), + NONE(RESERVED31), + + /* W word: 31:0 */ + NONE(HDA2HDMICODEC), + NONE(RESERVED1_SATACOLD), + NONE(RESERVED2_PCIERX0), + NONE(RESERVED3_PCIERX1), + NONE(RESERVED4_PCIERX2), + NONE(RESERVED5_PCIERX3), + NONE(RESERVED6_PCIERX4), + NONE(RESERVED7_PCIERX5), + + /* 40 */ + NONE(CEC), + NONE(PCIE2_IOBIST), + NONE(EMC_IOBIST), + NONE(HDMI_IOBIST), + NONE(SATA_IOBIST), + NONE(MIPI_IOBIST), + NONE(EMC1_IOBIST), + NONE(XUSB), + + /* 48 */ + NONE(CILAB), + NONE(CILCD), + NONE(CILE), + NONE(DSIA_LP), + NONE(DSIB_LP), + NONE(RESERVED21_ENTROPY), + NONE(RESERVED22_W), + NONE(RESERVED23_W), + + /* 56 */ + NONE(RESERVED24_W), + NONE(AMX0), + NONE(ADX0), + NONE(DVFS), + NONE(XUSB_SS), + NONE(EMC_DLL), + NONE(MC1), + NONE(EMC1), +}; + +/* + * Get the oscillator frequency, from the corresponding hardware configuration + * field. Note that T30/T114 support 3 new higher freqs, but we map back + * to the old T20 freqs. Support for the higher oscillators is TBD. + */ +enum clock_osc_freq clock_get_osc_freq(void) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg; + + reg = readl(&clkrst->crc_osc_ctrl); + reg = (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; + + if (reg & 1) /* one of the newer freqs */ + printf("Warning: OSC_FREQ is unsupported! (%d)\n", reg); + + return reg >> 2; /* Map to most common (T20) freqs */ +} + +/* Returns a pointer to the clock source register for a peripheral */ +u32 *get_periph_source_reg(enum periph_id periph_id) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + enum periphc_internal_id internal_id; + + /* Coresight is a special case */ + if (periph_id == PERIPH_ID_CSI) + return &clkrst->crc_clk_src[PERIPH_ID_CSI+1]; + + assert(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT); + internal_id = periph_id_to_internal_id[periph_id]; + assert(internal_id != -1); + if (internal_id >= PERIPHC_VW_FIRST) { + internal_id -= PERIPHC_VW_FIRST; + return &clkrst->crc_clk_src_vw[internal_id]; + } else + return &clkrst->crc_clk_src[internal_id]; +} + +/** + * Given a peripheral ID and the required source clock, this returns which + * value should be programmed into the source mux for that peripheral. + * + * There is special code here to handle the one source type with 5 sources. + * + * @param periph_id peripheral to start + * @param source PLL id of required parent clock + * @param mux_bits Set to number of bits in mux register: 2 or 4 + * @param divider_bits Set to number of divider bits (8 or 16) + * @return mux value (0-4, or -1 if not found) + */ +int get_periph_clock_source(enum periph_id periph_id, + enum clock_id parent, int *mux_bits, int *divider_bits) +{ + enum clock_type_id type; + enum periphc_internal_id internal_id; + int mux; + + assert(clock_periph_id_isvalid(periph_id)); + + internal_id = periph_id_to_internal_id[periph_id]; + assert(periphc_internal_id_isvalid(internal_id)); + + type = clock_periph_type[internal_id]; + assert(clock_type_id_isvalid(type)); + + *mux_bits = clock_source[type][CLOCK_MAX_MUX]; + + if (type == CLOCK_TYPE_PCMT16) + *divider_bits = 16; + else + *divider_bits = 8; + + for (mux = 0; mux < CLOCK_MAX_MUX; mux++) + if (clock_source[type][mux] == parent) + return mux; + + /* if we get here, either us or the caller has made a mistake */ + printf("Caller requested bad clock: periph=%d, parent=%d\n", periph_id, + parent); + return -1; +} + +void clock_set_enable(enum periph_id periph_id, int enable) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 *clk; + u32 reg; + + /* Enable/disable the clock to this peripheral */ + assert(clock_periph_id_isvalid(periph_id)); + if ((int)periph_id < (int)PERIPH_ID_VW_FIRST) + clk = &clkrst->crc_clk_out_enb[PERIPH_REG(periph_id)]; + else + clk = &clkrst->crc_clk_out_enb_vw[PERIPH_REG(periph_id)]; + reg = readl(clk); + if (enable) + reg |= PERIPH_MASK(periph_id); + else + reg &= ~PERIPH_MASK(periph_id); + writel(reg, clk); +} + +void reset_set_enable(enum periph_id periph_id, int enable) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 *reset; + u32 reg; + + /* Enable/disable reset to the peripheral */ + assert(clock_periph_id_isvalid(periph_id)); + if (periph_id < PERIPH_ID_VW_FIRST) + reset = &clkrst->crc_rst_dev[PERIPH_REG(periph_id)]; + else + reset = &clkrst->crc_rst_dev_vw[PERIPH_REG(periph_id)]; + reg = readl(reset); + if (enable) + reg |= PERIPH_MASK(periph_id); + else + reg &= ~PERIPH_MASK(periph_id); + writel(reg, reset); +} + +#ifdef CONFIG_OF_CONTROL +/* + * Convert a device tree clock ID to our peripheral ID. They are mostly + * the same but we are very cautious so we check that a valid clock ID is + * provided. + * + * @param clk_id Clock ID according to tegra114 device tree binding + * @return peripheral ID, or PERIPH_ID_NONE if the clock ID is invalid + */ +enum periph_id clk_id_to_periph_id(int clk_id) +{ + if (clk_id > PERIPH_ID_COUNT) + return PERIPH_ID_NONE; + + switch (clk_id) { + case PERIPH_ID_RESERVED3: + case PERIPH_ID_RESERVED16: + case PERIPH_ID_RESERVED24: + case PERIPH_ID_RESERVED35: + case PERIPH_ID_RESERVED43: + case PERIPH_ID_RESERVED45: + case PERIPH_ID_RESERVED56: + case PERIPH_ID_RESERVED76: + case PERIPH_ID_RESERVED77: + case PERIPH_ID_RESERVED78: + case PERIPH_ID_RESERVED83: + case PERIPH_ID_RESERVED89: + case PERIPH_ID_RESERVED91: + case PERIPH_ID_RESERVED93: + case PERIPH_ID_RESERVED94: + case PERIPH_ID_RESERVED95: + return PERIPH_ID_NONE; + default: + return clk_id; + } +} +#endif /* CONFIG_OF_CONTROL */ + +void clock_early_init(void) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + + /* + * PLLP output frequency set to 408Mhz + * PLLC output frequency set to 600Mhz + * PLLD output frequency set to 925Mhz + */ + switch (clock_get_osc_freq()) { + case CLOCK_OSC_FREQ_12_0: /* OSC is 12Mhz */ + clock_set_rate(CLOCK_ID_PERIPH, 408, 12, 0, 8); + clock_set_rate(CLOCK_ID_CGENERAL, 600, 12, 0, 8); + clock_set_rate(CLOCK_ID_DISPLAY, 925, 12, 0, 12); + break; + + case CLOCK_OSC_FREQ_26_0: /* OSC is 26Mhz */ + clock_set_rate(CLOCK_ID_PERIPH, 408, 26, 0, 8); + clock_set_rate(CLOCK_ID_CGENERAL, 600, 26, 0, 8); + clock_set_rate(CLOCK_ID_DISPLAY, 925, 26, 0, 12); + break; + + case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */ + clock_set_rate(CLOCK_ID_PERIPH, 408, 13, 0, 8); + clock_set_rate(CLOCK_ID_CGENERAL, 600, 13, 0, 8); + clock_set_rate(CLOCK_ID_DISPLAY, 925, 13, 0, 12); + break; + case CLOCK_OSC_FREQ_19_2: + default: + /* + * These are not supported. It is too early to print a + * message and the UART likely won't work anyway due to the + * oscillator being wrong. + */ + break; + } + + /* PLLC_MISC2: Set dynramp_stepA/B. MISC2 maps to pll_out[1] */ + writel(0x00561600, &clkrst->crc_pll[CLOCK_ID_CGENERAL].pll_out[1]); + + /* PLLC_MISC: Set LOCK_ENABLE */ + writel(0x01000000, &clkrst->crc_pll[CLOCK_ID_CGENERAL].pll_misc); + udelay(2); + + /* PLLD_MISC: Set CLKENABLE, CPCON 12, LFCON 1 */ + writel(0x40000C10, &clkrst->crc_pll[CLOCK_ID_DISPLAY].pll_misc); + udelay(2); +} diff --git a/arch/arm/cpu/tegra114-common/funcmux.c b/arch/arm/cpu/tegra114-common/funcmux.c new file mode 100644 index 0000000..5af7550 --- /dev/null +++ b/arch/arm/cpu/tegra114-common/funcmux.c @@ -0,0 +1,63 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +/* Tegra114 high-level function multiplexing */ + +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/funcmux.h> +#include <asm/arch/pinmux.h> + +int funcmux_select(enum periph_id id, int config) +{ + int bad_config = config != FUNCMUX_DEFAULT; + + switch (id) { + case PERIPH_ID_UART4: + switch (config) { + case FUNCMUX_UART4_GMI: + pinmux_set_func(PINGRP_GMI_A16, PMUX_FUNC_UARTD); + pinmux_set_func(PINGRP_GMI_A17, PMUX_FUNC_UARTD); + pinmux_set_func(PINGRP_GMI_A18, PMUX_FUNC_UARTD); + pinmux_set_func(PINGRP_GMI_A19, PMUX_FUNC_UARTD); + + pinmux_set_io(PINGRP_GMI_A16, PMUX_PIN_OUTPUT); + pinmux_set_io(PINGRP_GMI_A17, PMUX_PIN_INPUT); + pinmux_set_io(PINGRP_GMI_A18, PMUX_PIN_INPUT); + pinmux_set_io(PINGRP_GMI_A19, PMUX_PIN_OUTPUT); + + pinmux_tristate_disable(PINGRP_GMI_A16); + pinmux_tristate_disable(PINGRP_GMI_A17); + pinmux_tristate_disable(PINGRP_GMI_A18); + pinmux_tristate_disable(PINGRP_GMI_A19); + break; + } + break; + + /* Add other periph IDs here as needed */ + + default: + debug("%s: invalid periph_id %d", __func__, id); + return -1; + } + + if (bad_config) { + debug("%s: invalid config %d for periph_id %d", __func__, + config, id); + return -1; + } + return 0; +} diff --git a/arch/arm/cpu/tegra114-common/pinmux.c b/arch/arm/cpu/tegra114-common/pinmux.c new file mode 100644 index 0000000..52b3ec4 --- /dev/null +++ b/arch/arm/cpu/tegra114-common/pinmux.c @@ -0,0 +1,506 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +/* Tegra114 pin multiplexing functions */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/tegra.h> +#include <asm/arch/pinmux.h> + +struct tegra_pingroup_desc { + const char *name; + enum pmux_func funcs[4]; + enum pmux_func func_safe; + enum pmux_vddio vddio; + enum pmux_pin_io io; +}; + +#define PMUX_MUXCTL_SHIFT 0 +#define PMUX_PULL_SHIFT 2 +#define PMUX_TRISTATE_SHIFT 4 +#define PMUX_TRISTATE_MASK (1 << PMUX_TRISTATE_SHIFT) +#define PMUX_IO_SHIFT 5 +#define PMUX_OD_SHIFT 6 +#define PMUX_LOCK_SHIFT 7 +#define PMUX_IO_RESET_SHIFT 8 + +/* Convenient macro for defining pin group properties */ +#define PIN(pg_name, vdd, f0, f1, f2, f3, iod) \ + { \ + .vddio = PMUX_VDDIO_ ## vdd, \ + .funcs = { \ + PMUX_FUNC_ ## f0, \ + PMUX_FUNC_ ## f1, \ + PMUX_FUNC_ ## f2, \ + PMUX_FUNC_ ## f3, \ + }, \ + .func_safe = PMUX_FUNC_RSVD1, \ + .io = PMUX_PIN_ ## iod, \ + } + +/* Input and output pins */ +#define PINI(pg_name, vdd, f0, f1, f2, f3) \ + PIN(pg_name, vdd, f0, f1, f2, f3, INPUT) +#define PINO(pg_name, vdd, f0, f1, f2, f3) \ + PIN(pg_name, vdd, f0, f1, f2, f3, OUTPUT) + +const struct tegra_pingroup_desc tegra_soc_pingroups[PINGRP_COUNT] = { + /* NAME VDD f0 f1 f2 f3 */ + PINI(ULPI_DATA0, BB, SPI3, HSI, UARTA, ULPI), + PINI(ULPI_DATA1, BB, SPI3, HSI, UARTA, ULPI), + PINI(ULPI_DATA2, BB, SPI3, HSI, UARTA, ULPI), + PINI(ULPI_DATA3, BB, SPI3, HSI, UARTA, ULPI), + PINI(ULPI_DATA4, BB, SPI2, HSI, UARTA, ULPI), + PINI(ULPI_DATA5, BB, SPI2, HSI, UARTA, ULPI), + PINI(ULPI_DATA6, BB, SPI2, HSI, UARTA, ULPI), + PINI(ULPI_DATA7, BB, SPI2, HSI, UARTA, ULPI), + PINI(ULPI_CLK, BB, SPI1, SPI5, UARTD, ULPI), + PINI(ULPI_DIR, BB, SPI1, SPI5, UARTD, ULPI), + PINI(ULPI_NXT, BB, SPI1, SPI5, UARTD, ULPI), + PINI(ULPI_STP, BB, SPI1, SPI5, UARTD, ULPI), + PINI(DAP3_FS, BB, I2S2, SPI5, DISPA, DISPB), + PINI(DAP3_DIN, BB, I2S2, SPI5, DISPA, DISPB), + PINI(DAP3_DOUT, BB, I2S2, SPI5, DISPA, DISPB), + PINI(DAP3_SCLK, BB, I2S2, SPI5, DISPA, DISPB), + PINI(GPIO_PV0, BB, USB, RSVD2, RSVD3, RSVD4), + PINI(GPIO_PV1, BB, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(SDMMC1_CLK, SDMMC1, SDMMC1, CLK12, RSVD3, RSVD4), + PINI(SDMMC1_CMD, SDMMC1, SDMMC1, SPDIF, SPI4, UARTA), + PINI(SDMMC1_DAT3, SDMMC1, SDMMC1, SPDIF, SPI4, UARTA), + PINI(SDMMC1_DAT2, SDMMC1, SDMMC1, PWM0, SPI4, UARTA), + PINI(SDMMC1_DAT1, SDMMC1, SDMMC1, PWM1, SPI4, UARTA), + PINI(SDMMC1_DAT0, SDMMC1, SDMMC1, RSVD2, SPI4, UARTA), + PINI(GPIO_PV2, BB, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(GPIO_PV3, BB, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(CLK2_OUT, SDMMC1, EXTPERIPH2, RSVD2, RSVD3, RSVD4), + PINI(CLK2_REQ, SDMMC1, DAP, RSVD2, RSVD3, RSVD4), + PINO(LCD_PWR1, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_PWR2, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_SDIN, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_SDOUT, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_WR_N, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_CS0_N, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_DC0, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_SCK, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_PWR0, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_PCLK, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_DE, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_HSYNC, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_VSYNC, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D0, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D1, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D2, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D3, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D4, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D5, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D6, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D7, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D8, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D9, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D10, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D11, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D12, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D13, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D14, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D15, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D16, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D17, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D18, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D19, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D20, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D21, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D22, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_D23, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_CS1_N, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_M1, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINO(LCD_DC1, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(HDMI_INT, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(DDC_SCL, LCD, I2C4, RSVD2, RSVD3, RSVD4), + PINI(DDC_SDA, LCD, I2C4, RSVD2, RSVD3, RSVD4), + PINI(CRT_HSYNC, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(CRT_VSYNC, LCD, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D0, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D1, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D2, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D3, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D4, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D5, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D6, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D7, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D8, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D9, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D10, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_D11, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_PCLK, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_MCLK, VI, RSVD1, RSVD3, RSVD3, RSVD4), + PINI(VI_VSYNC, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(VI_HSYNC, VI, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(UART2_RXD, UART, UARTB, SPDIF, UARTA, SPI4), + PINI(UART2_TXD, UART, UARTB, SPDIF, UARTA, SPI4), + PINI(UART2_RTS_N, UART, UARTA, UARTB, RSVD3, SPI4), + PINI(UART2_CTS_N, UART, UARTA, UARTB, RSVD3, SPI4), + PINI(UART3_TXD, UART, UARTC, RSVD2, RSVD3, SPI4), + PINI(UART3_RXD, UART, UARTC, RSVD2, RSVD3, SPI4), + PINI(UART3_CTS_N, UART, UARTC, SDMMC1, DTV, SPI4), + PINI(UART3_RTS_N, UART, UARTC, PWM0, DTV, DISPA), + PINI(GPIO_PU0, UART, OWR, UARTA, RSVD3, RSVD4), + PINI(GPIO_PU1, UART, RSVD1, UARTA, RSVD3, RSVD4), + PINI(GPIO_PU2, UART, RSVD1, UARTA, RSVD3, RSVD4), + PINI(GPIO_PU3, UART, PWM0, UARTA, DISPA, DISPB), + PINI(GPIO_PU4, UART, PWM1, UARTA, DISPA, DISPB), + PINI(GPIO_PU5, UART, PWM2, UARTA, DISPA, DISPB), + PINI(GPIO_PU6, UART, PWM3, UARTA, USB, DISPB), + PINI(GEN1_I2C_SDA, UART, I2C1, RSVD2, RSVD3, RSVD4), + PINI(GEN1_I2C_SCL, UART, I2C1, RSVD2, RSVD3, RSVD4), + PINI(DAP4_FS, UART, I2S3, RSVD2, DTV, RSVD4), + PINI(DAP4_DIN, UART, I2S3, RSVD2, RSVD3, RSVD4), + PINI(DAP4_DOUT, UART, I2S3, RSVD2, DTV, RSVD4), + PINI(DAP4_SCLK, UART, I2S3, RSVD2, RSVD3, RSVD4), + PINI(CLK3_OUT, UART, EXTPERIPH3, RSVD2, RSVD3, RSVD4), + PINI(CLK3_REQ, UART, DEV3, RSVD2, RSVD3, RSVD4), + PINI(GMI_WP_N, GMI, RSVD1, NAND, GMI, GMI_ALT), + PINI(GMI_IORDY, GMI, SDMMC2, RSVD2, GMI, TRACE), + PINI(GMI_WAIT, GMI, SPI4, NAND, GMI, DTV), + PINI(GMI_ADV_N, GMI, RSVD1, NAND, GMI, TRACE), + PINI(GMI_CLK, GMI, SDMMC2, NAND, GMI, TRACE), + PINI(GMI_CS0_N, GMI, RSVD1, NAND, GMI, USB), + PINI(GMI_CS1_N, GMI, RSVD1, NAND, GMI, SOC), + PINI(GMI_CS2_N, GMI, SDMMC2, NAND, GMI, TRACE), + PINI(GMI_CS3_N, GMI, SDMMC2, NAND, GMI, GMI_ALT), + PINI(GMI_CS4_N, GMI, USB, NAND, GMI, TRACE), + PINI(GMI_CS6_N, GMI, NAND, NAND_ALT, GMI, SPI4), + PINI(GMI_CS7_N, GMI, NAND, NAND_ALT, GMI, SDMMC2), + PINI(GMI_AD0, GMI, RSVD1, NAND, GMI, RSVD4), + PINI(GMI_AD1, GMI, RSVD1, NAND, GMI, RSVD4), + PINI(GMI_AD2, GMI, RSVD1, NAND, GMI, RSVD4), + PINI(GMI_AD3, GMI, RSVD1, NAND, GMI, RSVD4), + PINI(GMI_AD4, GMI, RSVD1, NAND, GMI, RSVD4), + PINI(GMI_AD5, GMI, RSVD1, NAND, GMI, SPI4), + PINI(GMI_AD6, GMI, RSVD1, NAND, GMI, SPI4), + PINI(GMI_AD7, GMI, RSVD1, NAND, GMI, SPI4), + PINI(GMI_AD8, GMI, PWM0, NAND, GMI, DTV), + PINI(GMI_AD9, GMI, PWM1, NAND, GMI, CLDVFS), + PINI(GMI_AD10, GMI, PWM2, NAND, GMI, CLDVFS), + PINI(GMI_AD11, GMI, PWM3, NAND, GMI, USB), + PINI(GMI_AD12, GMI, SDMMC2, NAND, GMI, RSVD4), + PINI(GMI_AD13, GMI, SDMMC2, NAND, GMI, RSVD4), + PINI(GMI_AD14, GMI, SDMMC2, NAND, GMI, DTV), + PINI(GMI_AD15, GMI, SDMMC2, NAND, GMI, DTV), + PINI(GMI_A16, GMI, UARTD, TRACE, GMI, GMI_ALT), + PINI(GMI_A17, GMI, UARTD, RSVD2, GMI, TRACE), + PINI(GMI_A18, GMI, UARTD, RSVD2, GMI, TRACE), + PINI(GMI_A19, GMI, UARTD, SPI4, GMI, TRACE), + PINI(GMI_WR_N, GMI, RSVD1, NAND, GMI, SPI4), + PINI(GMI_OE_N, GMI, RSVD1, NAND, GMI, SOC), + PINI(GMI_DQS, GMI, SDMMC2, NAND, GMI, TRACE), + PINI(GMI_RST_N, GMI, NAND, NAND_ALT, GMI, RSVD4), + PINI(GEN2_I2C_SCL, GMI, I2C2, RSVD2, GMI, RSVD4), + PINI(GEN2_I2C_SDA, GMI, I2C2, RSVD2, GMI, RSVD4), + PINI(SDMMC4_CLK, SDMMC4, SDMMC4, RSVD2, GMI, RSVD4), + PINI(SDMMC4_CMD, SDMMC4, SDMMC4, RSVD2, GMI, RSVD4), + PINI(SDMMC4_DAT0, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT1, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT2, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT3, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT4, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT5, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT6, SDMMC4, SDMMC4, SPI3, GMI, RSVD4), + PINI(SDMMC4_DAT7, SDMMC4, SDMMC4, RSVD2, GMI, RSVD4), + PINI(SDMMC4_RST_N, SDMMC4, RSVD1, RSVD2, RSVD3, SDMMC4), + PINI(CAM_MCLK, CAM, VI, VI_ALT1, VI_ALT2, RSVD4), + PINI(GPIO_PCC1, CAM, I2S4, RSVD2, RSVD3, RSVD4), + PINI(GPIO_PBB0, CAM, I2S4, VI, VI_ALT1, VI_ALT3), + PINI(CAM_I2C_SCL, CAM, VGP1, I2C3, RSVD3, RSVD4), + PINI(CAM_I2C_SDA, CAM, VGP2, I2C3, RSVD3, RSVD4), + PINI(GPIO_PBB3, CAM, VGP3, DISPA, DISPB, RSVD4), + PINI(GPIO_PBB4, CAM, VGP4, DISPA, DISPB, RSVD4), + PINI(GPIO_PBB5, CAM, VGP5, DISPA, DISPB, RSVD4), + PINI(GPIO_PBB6, CAM, VGP6, DISPA, DISPB, RSVD4), + PINI(GPIO_PBB7, CAM, I2S4, RSVD2, RSVD3, RSVD4), + PINI(GPIO_PCC2, CAM, I2S4, RSVD2, RSVD3, RSVD4), + PINI(JTAG_RTCK, SYS, RTCK, RSVD2, RSVD3, RSVD4), + PINI(PWR_I2C_SCL, SYS, I2CPWR, RSVD2, RSVD3, RSVD4), + PINI(PWR_I2C_SDA, SYS, I2CPWR, RSVD2, RSVD3, RSVD4), + PINI(KB_ROW0, SYS, KBC, RSVD2, DTV, RSVD4), + PINI(KB_ROW1, SYS, KBC, RSVD2, DTV, RSVD4), + PINI(KB_ROW2, SYS, KBC, RSVD2, DTV, SOC), + PINI(KB_ROW3, SYS, KBC, DISPA, RSVD3, DISPB), + PINI(KB_ROW4, SYS, KBC, DISPA, SPI2, DISPB), + PINI(KB_ROW5, SYS, KBC, DISPA, SPI2, DISPB), + PINI(KB_ROW6, SYS, KBC, DISPA, RSVD3, DISPB), + PINI(KB_ROW7, SYS, KBC, RSVD2, CLDVFS, UARTA), + PINI(KB_ROW8, SYS, KBC, RSVD2, RSVD3, UARTA), + PINI(KB_ROW9, SYS, KBC, RSVD2, RSVD3, UARTA), + PINI(KB_ROW10, SYS, KBC, RSVD2, RSVD3, UARTA), + PINI(KB_ROW11, SYS, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(KB_ROW12, SYS, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(KB_ROW13, SYS, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(KB_ROW14, SYS, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(KB_ROW15, SYS, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(KB_COL0, SYS, KBC, USB, SPI2, EMC_DLL), + PINI(KB_COL1, SYS, KBC, RSVD2, SPI2, EMC_DLL), + PINI(KB_COL2, SYS, KBC, RSVD2, SPI2, RSVD4), + PINI(KB_COL3, SYS, KBC, DISPA, PWM2, UARTA), + PINI(KB_COL4, SYS, KBC, OWR, SDMMC3, UARTA), + PINI(KB_COL5, SYS, KBC, RSVD2, SDMMC1, RSVD4), + PINI(KB_COL6, SYS, KBC, RSVD2, SPI2, RSVD4), + PINI(KB_COL7, SYS, KBC, RSVD2, SPI2, RSVD4), + PINI(CLK_32K_OUT, SYS, BLINK, SOC, RSVD3, RSVD4), + PINI(SYS_CLK_REQ, SYS, SYSCLK, RSVD2, RSVD3, RSVD4), + PINI(CORE_PWR_REQ, SYS, PWRON, RSVD2, RSVD3, RSVD4), + PINI(CPU_PWR_REQ, SYS, CPU, RSVD2, RSVD3, RSVD4), + PINI(PWR_INT_N, SYS, PMI, RSVD2, RSVD3, RSVD4), + PINI(CLK_32K_IN, SYS, CLK, RSVD2, RSVD3, RSVD4), + PINI(OWR, SYS, OWR, RSVD2, RSVD3, RSVD4), + PINI(DAP1_FS, AUDIO, I2S0, HDA, GMI, RSVD4), + PINI(DAP1_DIN, AUDIO, I2S0, HDA, GMI, RSVD4), + PINI(DAP1_DOUT, AUDIO, I2S0, HDA, GMI, RSVD4), + PINI(DAP1_SCLK, AUDIO, I2S0, HDA, GMI, RSVD4), + PINI(CLK1_REQ, AUDIO, DAP, DAP1, RSVD3, RSVD4), + PINI(CLK1_OUT, AUDIO, EXTPERIPH1, DAP2, RSVD3, RSVD4), + PINI(SPDIF_IN, AUDIO, SPDIF, USB, RSVD3, RSVD4), + PINI(SPDIF_OUT, AUDIO, SPDIF, RSVD2, RSVD3, RSVD4), + PINI(DAP2_FS, AUDIO, I2S1, HDA, RSVD3, RSVD4), + PINI(DAP2_DIN, AUDIO, I2S1, HDA, RSVD3, RSVD4), + PINI(DAP2_DOUT, AUDIO, I2S1, HDA, RSVD3, RSVD4), + PINI(DAP2_SCLK, AUDIO, I2S1, HDA, RSVD3, RSVD4), + PINI(SPI2_MOSI, AUDIO, SPI6, CLDVFS, RSVD3, RSVD4), + PINI(SPI2_MISO, AUDIO, SPI6, RSVD2, RSVD3, RSVD4), + PINI(SPI2_CS0_N, AUDIO, SPI6, SPI1, RSVD3, RSVD4), + PINI(SPI2_SCK, AUDIO, SPI6, CLDVFS, RSVD3, RSVD4), + PINI(SPI1_MOSI, AUDIO, RSVD1, SPI1, SPI2, DAP2), + PINI(SPI1_SCK, AUDIO, RSVD1, SPI1, SPI2, RSVD4), + PINI(SPI1_CS0_N, AUDIO, SPI6, SPI1, SPI2, RSVD4), + PINI(SPI1_MISO, AUDIO, RSVD1, SPI1, SPI2, RSVD4), + PINI(SPI2_CS1_N, AUDIO, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(SPI2_CS2_N, AUDIO, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(SDMMC3_CLK, SDMMC3, SDMMC3, RSVD2, RSVD3, SPI3), + PINI(SDMMC3_CMD, SDMMC3, SDMMC3, PWM3, UARTA, SPI3), + PINI(SDMMC3_DAT0, SDMMC3, SDMMC3, RSVD2, RSVD3, SPI3), + PINI(SDMMC3_DAT1, SDMMC3, SDMMC3, PWM2, UARTA, SPI3), + PINI(SDMMC3_DAT2, SDMMC3, SDMMC3, PWM1, DISPA, SPI3), + PINI(SDMMC3_DAT3, SDMMC3, SDMMC3, PWM0, DISPB, SPI3), + PINI(SDMMC3_DAT4, SDMMC3, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(SDMMC3_DAT5, SDMMC3, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(SDMMC3_DAT6, SDMMC3, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(SDMMC3_DAT7, SDMMC3, RSVD1, RSVD2, RSVD3, RSVD4), + PINI(HDMI_CEC, SYS, CEC, SDMMC3, RSVD3, SOC), + PINI(SDMMC1_WP_N, SDMMC1, SDMMC1, CLK12, SPI4, UARTA), + PINI(SDMMC3_CD_N, SDMMC3, SDMMC3, OWR, RSVD3, RSVD4), + PINI(SPI1_CS1_N, AUDIO, SPI6, RSVD2, SPI2, I2C1), + PINI(SPI1_CS2_N, AUDIO, SPI6, SPI1, SPI2, I2C1), + PINI(USB_VBUS_EN0, SYS, USB, RSVD2, RSVD3, RSVD4), + PINI(USB_VBUS_EN1, SYS, USB, RSVD2, RSVD3, RSVD4), + PINI(SDMMC3_CLK_LB_IN, SDMMC3, SDMMC3, RSVD2, RSVD3, RSVD4), + PINO(SDMMC3_CLK_LB_OUT, SDMMC3, SDMMC3, RSVD2, RSVD3, RSVD4), + PINO(NAND_GMI_CLK_LB, GMI, SDMMC2, NAND, GMI, RSVD4), + PINO(RESET_OUT_N, SYS, RSVD1, RSVD2, RSVD3, RESET_OUT_N), +}; + +void pinmux_set_tristate(enum pmux_pingrp pin, int enable) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *tri = &pmt->pmt_ctl[pin]; + u32 reg; + + /* Error check on pin */ + assert(pmux_pingrp_isvalid(pin)); + + reg = readl(tri); + if (enable) + reg |= PMUX_TRISTATE_MASK; + else + reg &= ~PMUX_TRISTATE_MASK; + writel(reg, tri); +} + +void pinmux_tristate_enable(enum pmux_pingrp pin) +{ + pinmux_set_tristate(pin, 1); +} + +void pinmux_tristate_disable(enum pmux_pingrp pin) +{ + pinmux_set_tristate(pin, 0); +} + +void pinmux_set_pullupdown(enum pmux_pingrp pin, enum pmux_pull pupd) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *pull = &pmt->pmt_ctl[pin]; + u32 reg; + + /* Error check on pin and pupd */ + assert(pmux_pingrp_isvalid(pin)); + assert(pmux_pin_pupd_isvalid(pupd)); + + reg = readl(pull); + reg &= ~(0x3 << PMUX_PULL_SHIFT); + reg |= (pupd << PMUX_PULL_SHIFT); + writel(reg, pull); +} + +void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *muxctl = &pmt->pmt_ctl[pin]; + int i, mux = -1; + u32 reg; + + /* Error check on pin and func */ + assert(pmux_pingrp_isvalid(pin)); + assert(pmux_func_isvalid(func)); + + /* Handle special values */ + if (func == PMUX_FUNC_SAFE) + func = tegra_soc_pingroups[pin].func_safe; + + if (func & PMUX_FUNC_RSVD1) { + mux = func & 0x3; + } else { + /* Search for the appropriate function */ + for (i = 0; i < 4; i++) { + if (tegra_soc_pingroups[pin].funcs[i] == func) { + mux = i; + break; + } + } + } + assert(mux != -1); + + reg = readl(muxctl); + reg &= ~(0x3 << PMUX_MUXCTL_SHIFT); + reg |= (mux << PMUX_MUXCTL_SHIFT); + writel(reg, muxctl); + +} + +void pinmux_set_io(enum pmux_pingrp pin, enum pmux_pin_io io) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *pin_io = &pmt->pmt_ctl[pin]; + u32 reg; + + /* Error check on pin and io */ + assert(pmux_pingrp_isvalid(pin)); + assert(pmux_pin_io_isvalid(io)); + + reg = readl(pin_io); + reg &= ~(0x1 << PMUX_IO_SHIFT); + reg |= (io & 0x1) << PMUX_IO_SHIFT; + writel(reg, pin_io); +} + +static int pinmux_set_lock(enum pmux_pingrp pin, enum pmux_pin_lock lock) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *pin_lock = &pmt->pmt_ctl[pin]; + u32 reg; + + /* Error check on pin and lock */ + assert(pmux_pingrp_isvalid(pin)); + assert(pmux_pin_lock_isvalid(lock)); + + if (lock == PMUX_PIN_LOCK_DEFAULT) + return 0; + + reg = readl(pin_lock); + reg &= ~(0x1 << PMUX_LOCK_SHIFT); + if (lock == PMUX_PIN_LOCK_ENABLE) + reg |= (0x1 << PMUX_LOCK_SHIFT); + else { + /* lock == DISABLE, which isn't possible */ + printf("%s: Warning: lock == %d, DISABLE is not allowed!\n", + __func__, lock); + } + writel(reg, pin_lock); + + return 0; +} + +static int pinmux_set_od(enum pmux_pingrp pin, enum pmux_pin_od od) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *pin_od = &pmt->pmt_ctl[pin]; + u32 reg; + + /* Error check on pin and od */ + assert(pmux_pingrp_isvalid(pin)); + assert(pmux_pin_od_isvalid(od)); + + if (od == PMUX_PIN_OD_DEFAULT) + return 0; + + reg = readl(pin_od); + reg &= ~(0x1 << PMUX_OD_SHIFT); + if (od == PMUX_PIN_OD_ENABLE) + reg |= (0x1 << PMUX_OD_SHIFT); + writel(reg, pin_od); + + return 0; +} + +static int pinmux_set_ioreset(enum pmux_pingrp pin, + enum pmux_pin_ioreset ioreset) +{ + struct pmux_tri_ctlr *pmt = + (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; + u32 *pin_ioreset = &pmt->pmt_ctl[pin]; + u32 reg; + + /* Error check on pin and ioreset */ + assert(pmux_pingrp_isvalid(pin)); + assert(pmux_pin_ioreset_isvalid(ioreset)); + + if (ioreset == PMUX_PIN_IO_RESET_DEFAULT) + return 0; + + reg = readl(pin_ioreset); + reg &= ~(0x1 << PMUX_IO_RESET_SHIFT); + if (ioreset == PMUX_PIN_IO_RESET_ENABLE) + reg |= (0x1 << PMUX_IO_RESET_SHIFT); + writel(reg, pin_ioreset); + + return 0; +} + +void pinmux_config_pingroup(struct pingroup_config *config) +{ + enum pmux_pingrp pin = config->pingroup; + + pinmux_set_func(pin, config->func); + pinmux_set_pullupdown(pin, config->pull); + pinmux_set_tristate(pin, config->tristate); + pinmux_set_io(pin, config->io); + pinmux_set_lock(pin, config->lock); + pinmux_set_od(pin, config->od); + pinmux_set_ioreset(pin, config->ioreset); +} + +void pinmux_config_table(struct pingroup_config *config, int len) +{ + int i; + + for (i = 0; i < len; i++) + pinmux_config_pingroup(&config[i]); +}
These are stripped down for bringup, They'll be filled out later to match-up with the kernel DT contents, and/or as devices are brought up (mmc, usb, spi, etc.).
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - change memory size to 2GB Changes in v3: - none
arch/arm/dts/tegra114.dtsi | 5 +++++ board/nvidia/dts/tegra114-dalmore.dts | 13 +++++++++++++ 2 files changed, 18 insertions(+), 0 deletions(-) create mode 100644 arch/arm/dts/tegra114.dtsi create mode 100644 board/nvidia/dts/tegra114-dalmore.dts
diff --git a/arch/arm/dts/tegra114.dtsi b/arch/arm/dts/tegra114.dtsi new file mode 100644 index 0000000..d06cd12 --- /dev/null +++ b/arch/arm/dts/tegra114.dtsi @@ -0,0 +1,5 @@ +/include/ "skeleton.dtsi" + +/ { + compatible = "nvidia,tegra114"; +}; diff --git a/board/nvidia/dts/tegra114-dalmore.dts b/board/nvidia/dts/tegra114-dalmore.dts new file mode 100644 index 0000000..7315577 --- /dev/null +++ b/board/nvidia/dts/tegra114-dalmore.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/include/ ARCH_CPU_DTS + +/ { + model = "NVIDIA Dalmore"; + compatible = "nvidia,dalmore", "nvidia,tegra114"; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; +};
This patch adds basic Tegra114 (T114) build support - no specific board is targeted.
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - none Changes in v3: - none
board/nvidia/common/board.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index a4af539..e986fcf 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -196,7 +196,7 @@ void gpio_early_init(void) __attribute__((weak, alias("__gpio_early_init")));
int board_early_init_f(void) { -#if defined(CONFIG_TEGRA30) +#if !defined(CONFIG_TEGRA20) pinmux_init(); #endif board_init_uart_f();
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD.
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes in v2: - update all new copyright header dates to 2013 - use correct table names in pinmux_init Changes in v3: - none
board/nvidia/dalmore/Makefile | 36 ++++ board/nvidia/dalmore/dalmore.c | 32 ++++ board/nvidia/dalmore/pinmux-config-dalmore.h | 249 ++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/dalmore.h | 50 +++++ include/configs/tegra114-common.h | 79 ++++++++ 6 files changed, 447 insertions(+), 0 deletions(-) create mode 100644 board/nvidia/dalmore/Makefile create mode 100644 board/nvidia/dalmore/dalmore.c create mode 100644 board/nvidia/dalmore/pinmux-config-dalmore.h create mode 100644 include/configs/dalmore.h create mode 100644 include/configs/tegra114-common.h
diff --git a/board/nvidia/dalmore/Makefile b/board/nvidia/dalmore/Makefile new file mode 100644 index 0000000..699b9f6 --- /dev/null +++ b/board/nvidia/dalmore/Makefile @@ -0,0 +1,36 @@ +# +# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms and conditions of the GNU General Public License, +# version 2, as published by the Free Software Foundation. +# +# This program is distributed in the hope it will be useful, but WITHOUT +# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for +# more details. +# +# You should have received a copy of the GNU General Public License +# along with this program. If not, see http://www.gnu.org/licenses/. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/nvidia/dalmore/dalmore.c b/board/nvidia/dalmore/dalmore.c new file mode 100644 index 0000000..aca3c7d --- /dev/null +++ b/board/nvidia/dalmore/dalmore.c @@ -0,0 +1,32 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/pinmux.h> +#include "pinmux-config-dalmore.h" + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_config_table(tegra114_pinmux_common, + ARRAY_SIZE(tegra114_pinmux_common)); + + pinmux_config_table(unused_pins_lowpower, + ARRAY_SIZE(unused_pins_lowpower)); +} diff --git a/board/nvidia/dalmore/pinmux-config-dalmore.h b/board/nvidia/dalmore/pinmux-config-dalmore.h new file mode 100644 index 0000000..3dd47da --- /dev/null +++ b/board/nvidia/dalmore/pinmux-config-dalmore.h @@ -0,0 +1,249 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _PINMUX_CONFIG_DALMORE_H_ +#define _PINMUX_CONFIG_DALMORE_H_ + +#define DEFAULT_PINMUX(_pingroup, _mux, _pull, _tri, _io) \ + { \ + .pingroup = PINGRP_##_pingroup, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define I2C_PINMUX(_pingroup, _mux, _pull, _tri, _io, _lock, _od) \ + { \ + .pingroup = PINGRP_##_pingroup, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define LV_PINMUX(_pingroup, _mux, _pull, _tri, _io, _lock, _ioreset) \ + { \ + .pingroup = PINGRP_##_pingroup, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ + } + +static struct pingroup_config tegra114_pinmux_common[] = { + /* SDMMC1 pinmux */ + DEFAULT_PINMUX(SDMMC1_CLK, SDMMC1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_CMD, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT3, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT2, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT1, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT0, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_WP_N, SDMMC1, UP, NORMAL, INPUT), + + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CLK_LB_IN, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CLK_LB_OUT, SDMMC3, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(SDMMC3_CMD, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CD_N, SDMMC3, UP, NORMAL, INPUT), + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CLK, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_CMD, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_RST_N, RSVD1, DOWN, NORMAL, INPUT, DISABLE, DISABLE), + + /* I2C1 pinmux */ + I2C_PINMUX(GEN1_I2C_SCL, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN1_I2C_SDA, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C2 pinmux */ + I2C_PINMUX(GEN2_I2C_SCL, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SDA, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C3 pinmux */ + I2C_PINMUX(CAM_I2C_SCL, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SDA, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C4 pinmux */ + I2C_PINMUX(DDC_SCL, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SDA, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* Power I2C pinmux */ + I2C_PINMUX(PWR_I2C_SCL, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SDA, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + DEFAULT_PINMUX(ULPI_DATA0, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_DATA1, UARTA, UP, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA2, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA3, UARTA, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(ULPI_DATA4, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA5, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA6, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA7, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_CLK, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_DIR, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_NXT, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_STP, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(DAP3_FS, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DIN, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DOUT, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_SCLK, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_OUT, EXTPERIPH2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_REQ, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_RXD, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_RTS_N, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_CTS_N, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_TXD, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART3_RXD, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GPIO_PU0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PU1, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GPIO_PU2, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PU3, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PU4, PWM1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GPIO_PU5, PWM2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GPIO_PU6, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_FS, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DIN, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DOUT, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_SCLK, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK3_OUT, EXTPERIPH3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CLK3_REQ, DEV3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WP_N, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS2_N, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD8, PWM0, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD10, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A16, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A17, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A18, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A19, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CAM_MCLK, VI_ALT2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PCC1, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PBB0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PBB3, VGP3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PBB5, VGP5, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PBB6, VGP6, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PBB7, I2S4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PCC2, I2S4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(JTAG_RTCK, RTCK, NORMAL, NORMAL, OUTPUT), + + /* KBC keys */ + DEFAULT_PINMUX(KB_ROW0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW2, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW3, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW4, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW5, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW7, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW8, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW9, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW10, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL2, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL3, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL4, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL5, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL7, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PV0, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PV1, RSVD1, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(CLK_32K_OUT, BLINK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SYS_CLK_REQ, SYSCLK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(OWR, OWR, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_FS, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DIN, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DOUT, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_SCLK, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_REQ, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_OUT, EXTPERIPH1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPDIF_IN, SPDIF, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPDIF_OUT, SPDIF, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(DAP2_FS, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DIN, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DOUT, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_SCLK, I2S1, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(SPI1_MOSI, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_SCK, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS0_N, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS1_N, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS2_N, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MISO, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_CEC, CEC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_INT, RSVD1, NORMAL, TRISTATE, INPUT), + + /* GPIOs */ + /* SDMMC1 CD gpio */ + DEFAULT_PINMUX(GMI_IORDY, RSVD1, UP, NORMAL, INPUT), + + /* Touch RESET */ + DEFAULT_PINMUX(GMI_AD14, NAND, NORMAL, NORMAL, OUTPUT), + + /* Power rails GPIO */ + DEFAULT_PINMUX(SPI2_SCK, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GPIO_PBB4, VGP4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW8, KBC, UP, NORMAL, INPUT), +}; + +static struct pingroup_config unused_pins_lowpower[] = { + DEFAULT_PINMUX(GMI_CS0_N, NAND, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS3_N, NAND, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS4_N, NAND, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS7_N, NAND, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD0, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD1, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD2, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD3, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD4, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD5, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD6, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD7, NAND, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD9, PWM1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD11, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD13, NAND, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WR_N, NAND, NORMAL, TRISTATE, OUTPUT), +}; + +#endif /* _PINMUX_CONFIG_DALMORE_H_ */ diff --git a/boards.cfg b/boards.cfg index b519bc4..bd2ae3d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -291,6 +291,7 @@ seaboard arm armv7:arm720t seaboard nvidia ventana arm armv7:arm720t ventana nvidia tegra20 whistler arm armv7:arm720t whistler nvidia tegra20 cardhu arm armv7:arm720t cardhu nvidia tegra30 +dalmore arm armv7:arm720t dalmore nvidia tegra114 colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 u8500_href arm armv7 u8500 st-ericsson u8500 snowball arm armv7 snowball st-ericsson u8500 diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h new file mode 100644 index 0000000..ce32c80 --- /dev/null +++ b/include/configs/dalmore.h @@ -0,0 +1,50 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/sizes.h> + +#include "tegra114-common.h" + +/* Must be off for Dalmore to boot !?!? FIXME */ +#define CONFIG_SYS_DCACHE_OFF + +/* Enable fdt support for Dalmore. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra114-dalmore +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +/* High-level configuration options */ +#define V_PROMPT "Tegra114 (Dalmore) # " +#define CONFIG_TEGRA_BOARD_STRING "NVIDIA Dalmore" + +/* Board-specific serial config */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_TEGRA_ENABLE_UARTD +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +#define CONFIG_MACH_TYPE MACH_TYPE_DALMORE + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ENV_IS_NOWHERE + +#define MACH_TYPE_DALMORE 4304 /* not yet in mach-types.h */ + +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */ diff --git a/include/configs/tegra114-common.h b/include/configs/tegra114-common.h new file mode 100644 index 0000000..0033530 --- /dev/null +++ b/include/configs/tegra114-common.h @@ -0,0 +1,79 @@ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_COMMON_H_ +#define _TEGRA114_COMMON_H_ +#include "tegra-common.h" + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK 408000000 /* 408MHz (pllp_out0) */ + +/* + * High Level Configuration Options + */ +#define CONFIG_TEGRA114 /* in a NVidia Tegra114 core */ + +/* Environment information, boards can override if required */ +#define CONFIG_LOADADDR 0x80408000 /* def. location for kernel */ + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LOAD_ADDR 0x80A00800 /* default */ +#define CONFIG_STACKBASE 0x82800000 /* 40MB */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_SYS_TEXT_BASE 0x8010E000 + +/* + * Memory layout for where various images get loaded by boot scripts: + * + * scriptaddr can be pretty much anywhere that doesn't conflict with something + * else. Put it above BOOTMAPSZ to eliminate conflicts. + * + * kernel_addr_r must be within the first 128M of RAM in order for the + * kernel's CONFIG_AUTO_ZRELADDR option to work. Since the kernel will + * decompress itself to 0x8000 after the start of RAM, kernel_addr_r + * should not overlap that area, or the kernel will have to copy itself + * somewhere else before decompression. Similarly, the address of any other + * data passed to the kernel shouldn't overlap the start of RAM. Pushing + * this up to 16M allows for a sizable kernel to be decompressed below the + * compressed load address. + * + * fdt_addr_r simply shouldn't overlap anything else. Choosing 32M allows for + * the compressed kernel to be up to 16M too. + * + * ramdisk_addr_r simply shouldn't overlap anything else. Choosing 33M allows + * for the FDT/DTB to be up to 1M, which is hopefully plenty. + */ +#define MEM_LAYOUT_ENV_SETTINGS \ + "scriptaddr=0x90000000\0" \ + "kernel_addr_r=0x81000000\0" \ + "fdt_addr_r=0x82000000\0" \ + "ramdisk_addr_r=0x82100000\0" + +/* Defines for SPL */ +#define CONFIG_SPL_TEXT_BASE 0x80108000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80090000 +#define CONFIG_SPL_STACK 0x800ffffc + +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/tegra114/u-boot-spl.lds" + +#endif /* _TEGRA114_COMMON_H_ */
Changes in v2:
Changes in v3:
- none
Why not just update mach-types.h?
-Allen
On 01/28/2013 04:32 PM, Tom Warren wrote:
Common Tegra files are in arch-tegra, shared between T20/T30/T114. Tegra114-specific headers are in arch-tegra114. Note that some of these will be filled in as more T114 support is added (drivers, WB/LP0 support, etc.).
The series briefly, Reviewed-by: Stephen Warren swarren@nvidia.com
Allen Martin
Stephen Warren
Tom Warren
